Question: How do I correct the exact solution in this code?
I have written the following attached code to use Euler explicit method to solve the following IVP
diff(y(x), x) = 2*(1+x)-y(x), y(2) = 5
With Exact solution  y(x) = 2*x+exp(-x)/exp(-2)
However, I found out that my exact results are not correct while the numerical results are okay. What have I done wrong in the code? Can someone modify the code?
Thank you and kind regards.
