Question: Maple Fails during a while cycle - Why?
Hello, I found this very strange behavior in Maple and I can't explain why this is not working
A little bit of context first:
1. I placed a polygon as a boundary for a section and then two polygons that correspond to inner holes to the first one.
2. Then I proceed to create a regular mesh that places N x M points spread across the region (OK here)
3. A procedure checks weather or not a Point is inside the region, on the borders or in the inner holes (OK here)
4. Then I want to select the closest (but exterior) ones so I can create a path using the mesh points.
Here is where I find the issue. I start at a vertex called V[1,1] and I want to arrive at V[1,2] (in the document they are blue solid points marked they are near-vertices near the original polygons). The procedure that I apply finds a path towards the V[1,2] as I was expecting but when the procedure hits the V[1,2] coordinates the while loop does not stop
The condition I wrote was:    while point<>V[1,2] do  where 'point' is correctly generated by another procedure.
This happens in a 40 by 50 mesh but with other configurations it works properly (there are also another kind of errors but it's inherent to lack of optimization in my procedures).
What baffles me is why doesn't it stop the cycle, if I test the condition outside the loop it DOES recognize the points are indeed equal. Is it something in Maple or is it something in my PC?
Thanks to anyone who can see the error or the problem because I don't understand the nature of the problem.
Not_Working.mw
