Question: On creating a DataFrame with ArrayTools
Hi!
I have trouble using ArrayTools, specifically Extend, to create a DataFrame. DF1 and DF2 are, even though awkwardly, created correctly, DF 3 does not work. My code is this:
with(ArrayTools):
with(DocumentTools):
nOben:=10;
nUnten:=3;
InitialisierungDF:=Vector(nOben-nUnten+1); #Initialisierung des Dataframes für die Tabelle
InitialisierungSpalte:=Vector[row](nOben-nUnten+1);
for i from 1 to nOben-nUnten+1 do
 InitialisierungDF(i):=oE;
 InitialisierungSpalte(i):=n=i;
end do;
print(InitialisierungDF);
print(InitialisierungSpalte);
DF1:= DataFrame( < InitialisierungDF | InitialisierungDF | InitialisierungDF | InitialisierungDF>,
            columns = [ GK, PZP, PZM, PY],
            rows = InitialisierungSpalte);
DF2:= DataFrame( < InitialisierungDF | InitialisierungDF | InitialisierungDF | InitialisierungDF>,
Tabulate(DF1);
print(Extend(InitialisierungDF,[oE]));
print(Extend(InitialisierungSpalte,[RMSE]));
InitialisierungDF:=Extend(InitialisierungDF,[oE]);
InitialisierungSpalte:=Extend(InitialisierungSpalte,[RMSE]);
DF3:= DataFrame( < InitialisierungDF | InitialisierungDF | InitialisierungDF | InitialisierungDF>,
The result is supposed to be a math table of the form
           GK   PZP    PZM   PY
n=1     oE     oE       oE     oE
n=2     oE     oE       oE     oE
RMSE  oE    oE      oE       oE
I have run into multiple problems, potentially bugs. First, I have to initialize awkwardly with
end do;
because InitialisierungDF:=Vector(1..nOben-nUnten+1,oE) doesn't work and produces entries like oE(1) for whatever reason.
Then, creating the data frame DF3 does not work at all with the above mentioned code.
end do;
DF3:= DataFrame(<Extend(InitialisierungDF,[oE])|Extend(InitialisierungDF,[oE])|Extend(InitialisierungDF),[oE]|Extend(InitialisierungDF,[oE])>,
            rows = Extend(InitialisierungSpalte,[RMSE]));
doesn't work either, however, this time a different error occurs. Looking at the vectors the dimensions seem to be correct in each case, though. Any suggestions on how to fix these things?
