Question: "Error, cannot split rhs into multiple assignment" when using function "Eigenvectors"
Hi there!
The first time I compile the following code, I get the error message
"Error, cannot split rhs into multiple assignment."
when trying to solve an issue with the procedure. I then have to compile the procedure over and over again, until it finally works (which it does eventually, without changing the code.) The problematic line is
Knoten, Eigenvektoren := Eigenvectors(evalf[15](M));
it is one of the last lines within the code below. Is it possible to get rid of that issue? It is annoying and unprofessional to have to compile a code over and over again until it finally works.
GaußKronrodQuadraturKurz:= proc(Unten, Oben, f,G,n)::real;
  #Unten:= Untere Intervallgrenze; Oben:= Obere Intervallgrenze; G:= Gewicht;
  #f:= zu untersuchende Funktion; n:= Berechnung der Knotenanzahl mittels 2*n+1
local
A,B,P,S,T, #Listen
a,b,p,s,t, #Listenelemente
i,j,k, #Laufvariablen
M, #werdende Gauss-Kronrod-Jacobi-Matrix
m, #Matrixeinträge
u,l, #Hilfsvariablen Gemischte Momente
RekursivesZwischenergebnis,Gewichte,Knoten,Eigenvektoren,AktuellerNormierterVektor,Hilfsvariable,Endergebnis;
with(LinearAlgebra):
A := [seq(a[i], i = 0 .. n)];
B := [seq(b[i], i = 0 .. n)];
P := [seq(p[i], i = -1 .. ceil(3*n/2)+1)];
S := [seq(s[i], i = -1 .. floor(n/2))];
T := [seq(t[i], i = -1 .. floor(n/2))];
p[-1]:= 0;
p[0]:=1;
for i from -1 to floor(n/2) do
  s[i]:=0;
  t[i]:=0
end do;
for j from 1 to 2*n+1 do
  RekursivesZwischenergebnis:= x^j;
  for i from 0 to j-1 do
    RekursivesZwischenergebnis:= RekursivesZwischenergebnis -
    (int(x^j*p[i],x=Unten..Oben)/int(p[i]*p[i],x=Unten..Oben))*p[i]                  #Gram-Schmidt algorithm
  end do;
  p[j]:=RekursivesZwischenergebnis;
end do;
a[0]:=-coeff(p[1],x,0);
  #p[0+1]=(x-a[0])*p[0]-b[0]*p[0-1] -> p[1]=x*p[0]-a[0]*p[0]-b[0]*p[-1] ->
  #p[1]=x*1-a[0]*1-0 -> a[0]=x-p[1] -> a[0]= -coeff(p[1],x,0), da p[1] monisch ist und von Grad 1    #ist
b[0]:=int(p[0]^2, x=Unten..Oben); #by definition
for j from 1 to ceil(3*n/2) do
  #Genau genommen muss a nur bis floor(3/(2*n)) initialisiert werden, allerdings wird der Wert       #ohnehin für die Berechnung von b gebraucht. Die Initialisierung schadet nicht.
  a[j]:= coeff(p[j],x,j-1)- coeff(p[j+1],x,j);
    #p[j+1]=(x-a[j])*p[j]-b[j]*p[j-1] -> p[j+1]=x*p[j]-a[j]*p[j]-b[j]p[j-1] ->
    #coeff(p[j+1],x,j)=coeff(x*p[j],x,j)-coeff(a[j]*p[j],x,j)
      #(da b[j]*p[j-1] vom Grad j-1 ist) ->
    #coeff(p[j+1],x,j)=coeff(x*p[j],x,j)-a[j], da p[j] monisch ist ->
    #coeff(p[j+1],x,j)=coeff(p[j],x,j-1)-a[j]->
    #a[j]=coeff(p[j],x,j-1)-coeff(p[j+1],x,j)
  b[j]:=  quo((x-a[j])*p[j]-p[j+1],p[j-1],x);
     #p[j+1]=(x-a[j])*p[j]-b[j]*p[j-1] -> -p[j+1]+(x-a[j])*p[j]= b[j]*p[j-1]
     #b[j]=((x-a[j])*p[j]-p[j+1])/p[j-1]
end do;
t[0]:=b[n+1]; #t[0]:= /hat{b}[0], Beginn der ostwärtigen Phase
for i from 0 to n-2 do # n-2 ist die Anzahl der zu berechnenden Diagonalen
  u:=0;
  for k from floor((i+1)/2) to 0 by -1 do # aufgrund des diagonalen Vorgehens ist nur bei jedem
                                          # zweiten Schleifendurchlauf eine Inkrementierung
                                          # vorzunehmen
    l:=i-k;
    u:=u+(a[k+n+1]-a[l])*t[k]+b[k+n+1]*s[k-1]-b[l]*s[k]; # Ausrechnen gemischter Momente über die
                                                         # fünfgliedrige Rekursion
    s[k]:=u
  end do;
  for j from -1 to floor(n/2) do  # Durchrotieren der Werte der gemischten Momente, da ein                                           # jeweiliges gemischtes Moment beim zweiten auf die Generierung                                    # folgenden
                                  # Schleifendurchlauf das letzte mal benötigt und danach über-
                                  # schrieben wird. Die am Ende vorliegenden Werte sind gerade
                                  # die, die bei der südwärtigen Phase benötigt werden.
    Hilfsvariable:=s[j];
    s[j]:=t[j];
    t[j]:=Hilfsvariable
  end do;
end do;
for j from floor(n/2) to 0 by -1 do
    s[j]:=s[j-1]
end do;
for i from n-1 to 2*n-3 do #entspricht der Anzahl der restlichen Diagonalen
  u:=0;
  for k from i+1-n to floor((i-1)/2) do #berechnet die gemischten Momente innerhalb einer
                                        #Diagonalen, von oben rechts nach unten links.
    l:=i-k;
    j:=n-1-l;
    u:=u-(a[k+n+1]-a[l])*t[j]-b[k+n+1]*s[j]+b[l]*s[j+1];
    s[j]:=u
  end do;
  if i mod 2 = 0 then #Ausrechnen eines fehlenden Koeffizienzen über die fünfgliedrige Rekursion                         #am Eintrag (k,k)
    k:= i/2;
    a[k+n+1]:=a[k]+(s[j]-b[k+n+1]*s[j+1])/t[j+1]
  else                #Ausrechnen eines fehlenden Koeffizienzen über die fünfgliedrige Rekursion                         #am Eintrag (k,k-1)
    k:=(i+1)/2;
    b[k+n+1]:=s[j]/s[j+1]
  end if;
  for j from -1 to floor(n/2) do #Erneutes Durchrotieren der Werte der gemischten Momente
    s[j]:=t[j];
    t[j]:=Hilfsvariable
  end do;
end do;
a[2*n]:=a[n-1]-b[2*n]*s[0]/t[0]; #Berechnung des letzten fehlenden Koeffizienten über die                                           #fünfgliedrige Rekursion am Eintrag (n-1,n-1)
M:=Matrix(2*n+1, shape=symmetric);#definieren der werdenden Gauß-Krondrod-Matrix
M(1,1):=a[0];
for m from 2 to (2*n+1) do #generieren der Gauss-Kronrod-Matrix
  M(m-1,m):= sqrt(b[m-1]);
  M(m,m-1):= sqrt(b[m-1]);
  M(m,m):= a[m-1];
end do;
Knoten, Eigenvektoren := Eigenvectors(evalf[15](M));# "Die gesuchten Knoten sind die Eigenwerte #dieser Matrix, und die Gewichte sind proportional zu den ersten Komponenten der normalisierten #Eigenvektoren"
for m from 1 to 2*n+1 do
  AktuellerNormierterVektor:= Normalize(Column(Eigenvektoren,m),Euclidean);
  Gewichte[m]:=AktuellerNormierterVektor[1]^2*b[0]
end do;
Endergebnis:=Re(add(Gewichte[i]*eval(f*diff(G,x),x=Knoten[i]),i=1..2*n+1));
end proc
An example of an application of the procedure is
GaußKronrodQuadraturKurz(-2, 1, 3*x*3*x^2*sin(x),x,3)
Thank you very much!
