Question: Probe Info tooltips not visible on Linux
My PC is dual-booted (Win10 and Ubuntu 20.04+KDE). After creating a plot (even the simplest one) and enabling Probe Info as described in  https://www.maplesoft.com/support/help/maple/view.aspx?path=worksheet%2Fplotinterface%2Fpointprobei I do not see tooltip with cursor position. All other tooltips (Palettes, Toolbar etc.) work fine, it is only the probe Info tooltip that does not work. The same plot done while running Maple on Win10 works as expected - tooltip is visible.
Can someone confirm whether it works for them using Linux? I wonder whether this could be Java-related problem when running on Linux KDE with compositing and using Nvidia driver (e.g. color of tooltip is white on white, or rendering does not work as expected).
I do not remember whether it ever worked on Linux. At this moment I am using Maple2021 but for testing purposes I reinstalled Maple2020 and the problem is the same.
Thanks,
Alex
