Question: How to get a=b=c output?
For compact technical documentation it would be desirable to create output in the form of a=b=c, which is a style that is commonly used in textbooks (probably for the same reason).
It is possible to create such an output with non executable math and probably also with document blocks. This is error prone and time consuming. I am looking for a solution where I can use Maple commands to refer to expressions to assemble an a=b=c output.
The advantage: Using commands would change the output when the expression change (at least after re-execution of the document).
How can this be done?
