Question: Warning, cannot determine statement number; procedure may have changed in-place
Many times when using the debugger, and hitting the NEXT button I get the message
The problem is that after this, hitting NEXT will not go to next statement any more. It will bypass and return from the current procedure. but hitting STEP will make it go to next statement, But STEP will also go into next block which I might not want to do.
Only way to fix this is to terminate the debugging session and start all over again.
it is random and comes up in different places. The code in in .mla file and I step through it.
I am sure anyone who have used the buildin debugger have seen this message before. It shows for me many times.
What causes it and what can one do to not make it show up or clear it up so one does not have to restart the debugging each time it shows up?
Here is a screen shot.  I am also wondering if this happens using the emacs interface to the Maple debugger? I have not used the emacs interface to the debugger before.
Maple 2021.2 on windows 10
