Question: Simplify expressions
simplify is a procedure in Maple that have as parameter an assumption ¿Have the assumption a default value? For example, if we consider the following code:
f:= (x^3 - 27) / (x^2 - 3 * x):
print(f = simplify(f));
The output of that code assume that denominator is not zero, so I think the procedure have a default value for assume parameter.
