Question: different result for loop on expr if it is complex vs. real
When running this
expr:=5;
for item in expr do
    print(item);
od;
it prints 5 as expected. When when running
expr:=I;  (* NOTICE this is complex  I not the number 1 *)
for item in expr do
    print(item);
od;
it prints the number 1 and not I
I am sure there is a good reason why this happens.
But what should one do to insure they get the complex I in the second example when iterating over a sum of numbers, which in this example happened to be just one number who is complex? I know I can add explicit check to avoid this edge case.
The problem is that I want to iterate of sum of iterms, One or more of them can be complex I. (it is a result of doing series expansion of function at infinity, and I want to iterate over each term in the series one by one).
expr:=9+I:
for item in expr do
    print(item);
od;
Gives   9,1   and not 9,I
While
expr:=a+I:
for item in expr do
    print(item);
od;
does now give exected output   I,a  and not 1,a
What should one do to insure the for loop always get each term in the sum, even if it is complex?
I can't check the item inside the loop, because by then it is too late as the compelx I is lost already.
Is there a better way to iterate over sum of terms and look at each term as is and not lose the complex I in the way?
Maple 2022.1
Update
For now, I am doing this hack. Since the input is always a sum (with + or - terms), then I convert the input to string, split on delimitors and then parse the entries back to Maple and now it is a list so I can iterate over each term.
expr:=I+3:
String(expr):
StringTools:-SubstituteAll(%,"+","|+"):
StringTools:-SubstituteAll(%,"-","|-"):
StringTools:-Split(%,"|"):
map(Z->parse(Z),%):
for item in % do
    print(item);
od;
And when expr is
expr:=1+5*I+sin(x)-sqrt(8)*I-a;
It is a hack, but I could not find a relaible way to iterate over each term in the sum of terms without losing the complex I if one term was complex. I need to test this more. It is meant to work only on expression which is sum of terms, which is where I will use it.
Compare the output of the above for expr:=1-I;
The for loop gives 1,-1  but the string hack gives 1,-I which is what I wanted.
Ofcourse the above could fail if there is a "-" or "+" inside the term itself (for example  1+I+sin(1-x) , but this do not happen for the cases I am using this for, which just looking at terms of series expansion around either zero or infinity. These will be just power series terms separated by "+" or possibly "-"
If there is better way do this, that will be great.
