Question: WavelengthToColor values and color
One might be flabbergasted by the following
with(ColorTools):
Colors dosn't appear to match values given from this wavelength to rgb converter from here https://www.johndcook.com/wavelength_to_RGB.html
Although the color is in agreement when converting the value given back into a color value.
So in maple WavelengthToColor(622) does not match the color above however (heads up using the method="linear" option makes it closer) if we go through the paces and convert #ff6f00 to a color, it comes out properly.  One might think is something wrong with the WavelengthToColor command?
HexToRGB24("#ff6f00")
RGB24ToRGB([255,111,0])
Color([1,.43529412,0])
Ok the color seems right but that's not what WavelengthToColor(622) gives
So as it turns out using method=linear makes it closer.
Time is short I haven't time to compose the question properly but likely has something to do with the HSV Colorspaces.  It's confusing.
