Question: Trouble getting the Sample(X, out) command to output the data used to sample the distribution X. I am specifying the rtable correctly?
out_parameter_for_Sample(_)_and_rtables.mw
When I generate sample data using a random variable, a normal distribution and the Sample command, I want to see the sample and the values used to randomly evaluate the distribution which generates said sample. The Maple help sheets say you can so this with the out parameter in the Sample command. I try several different calls and hoped the rtable is filled on execution. As seen below, the execution fails. Am a specifying the rtable incorrectly? See attached Maple sheet.
with(Statistics)
with(LinearAlgebra)
When I generate sample data using a random variable, a normal distribution and the Sample commands, I want to see the sample and the values used to randomly evaluate the distribution. The Maple help sheets say you can so this with the out parameter in the Sample command.
From the help, we are required to specify a float rtable, that will be filled when the Sample command is succesfully executed.
Define a random variable.
X := RandomVariable(Normal(0, 1))
_R
Sample that random variable. We sample it 10 times and look at the output.
A := Sample(X, 10)
Vector[row](%id = 36893491057099280004)
The float rtable is defined with the sample number of elements as will be sampled.
tab1 := rtable(1 .. 10, datatype = float)
Array(%id = 36893491057099270012)
tab2 := convert(rtable(1 .. 10, datatype = float), list)
[HFloat(0.0), HFloat(0.0), HFloat(0.0), HFloat(0.0), HFloat(0.0), HFloat(0.0), HFloat(0.0), HFloat(0.0), HFloat(0.0), HFloat(0.0)]
Now I try several different calls and hope the rtable is filled on execution.
A := Sample(X, 10, out)
Error, invalid input: no implementation of Statistics:-Sample:-ModuleApply matches the arguments in call, 'Statistics:-Sample:-ModuleApply(X,10,out)'
A := Sample(X, 10, out = tab1)
Error, invalid input: no implementation of Statistics:-Sample:-ModuleApply matches the arguments in call, 'Statistics:-Sample:-ModuleApply(X,10,out = tab1)'
A := Sample(X, 10, out = tab2)
Error, invalid input: no implementation of Statistics:-Sample:-ModuleApply matches the arguments in call, 'Statistics:-Sample:-ModuleApply(X,10,out = tab2)'
A := Sample(X, 10, out = true)
Error, invalid input: no implementation of Statistics:-Sample:-ModuleApply matches the arguments in call, 'Statistics:-Sample:-ModuleApply(X,10,out = true)'
As seen above, the execution fails. Am a specifying the rtable incorrectly?
Download out_parameter_for_Sample(_)_and_rtables.mw
