Question: Why is the output of an inert integral not in 2D Math
I am updating older files.
Executing with the attached code snippet from a worksheet created with Maple 16 outputs for an inert integral
instead of
Why is that and how can I fix my old worksheets to make them work with Maple 2023?
Maybe related: Execution with (or return) does not evaluate the document blocks. When all document blocks are expanded with "right click show command" the cursor does not advance to the next execution group. I can't remenber if this behaviour was allways like this or has changed.
A suggestion for Maplesoft: I have stopped using document blocks with hidden code since hiding and showing commands requires too much time (to many clicks and mouse movements). A simple double click on the marker of the document block could facilitate hiding and showing code allot.
Output_of_Int_not_in_2d.mw
