Question: solution of differential equations
Good day to all the members who read this question.
I ask for your help to find the right way to solve this two differential equations (is attached the file). Used the common code "dsolve" but is not working on this problem. Doesn't matter if the solution is numeric or algebraic.
I will thaks a lot your kind help.
Best regards to all of you
DIFFERENTIAL_EQUATION.mw
with(PDEtools)
First Part
The differential equation to solve:
(Delta*LinearAlgebra:-Transpose(D[1/2])*D__0-I*`μ__e`*D__0/(lambda+I*`μ__e`*r)-2*(`μ__e`^2*r^2+lambda^2))*R(r)
Definitions
D__n = `∂__r`+I*omega(a^2+r^2)/Delta+I*a*m/Delta+2*n*(r-M)/Delta
LinearAlgebra:-Transpose(D[n]) = `∂__r`-I*omega(a^2+r^2)/Delta-I*a*m/Delta+2*n*(r-M)/Delta
a := 1; M := 1; omega := 1; m := 1; `μ__e` := 1; lambda := 1
Delta := -2*M*r+a^2+r^2
I divided the differential equation in 3 parts (A, B, C).
A := (-I*omega(a^2+r^2)-I*a*m+r-M)*(diff(R(r), r)+I*omega(a^2+r^2)*R(r)/Delta+I*a*m*R(r)/Delta)+Delta*(diff(R(r), r, r))+I*omega(a^2+r^2)*(diff(R(r), r))+I*a*m*(diff(R(r), r))
B := -I*`μ__e`*(diff(R(r), r)+I*omega(a^2+r^2)*R(r)/Delta+I*a*m*R(r)/Delta)/(lambda+I*`μ__e`*r)
C := -(2*(`μ__e`^2*r^2+lambda^2))*R(r)
DE := A+B+C
E := dsolve(DE)
R(r) = DESol({diff(diff(_Y(r), r), r)-(1-r+I/(1+I*r))*(diff(_Y(r), r))/(r^2-2*r+1)-(-(2*I)*((-1-2*I)+r)/(r^2-2*r+1)-2/((1+I*r)*(r^2-2*r+1))+2*r^2+2)*_Y(r)/(r^2-2*r+1)}, {_Y(r)})
dsolve({DE, DE(0) = 1}, numeric, range = 0 .. 20)
Error, (in dsolve/numeric/type_check) insufficient initial/boundary value information for procedure defined problem
Second Part
[`#msub(mi("L",fontweight = "bold"),mfrac(mn("1",fontweight = "bold"),mn("2",fontweight = "bold"),linethickness = "1"))`*LinearAlgebra:-Transpose(L[1/2])+a*`μ__e`*sin(theta)*LinearAlgebra:-Transpose(L[1/2])/(lambda+a*`μ__e`*cos(theta))+2*(lambda^2+a^2*`μ__e`*cos(theta)^2)]*S(theta) = 0
Definitions:
L__n = a*omega*`sinθ`+m*`cosecθ`+n*`cotθ`+`∂__θ`
LinearAlgebra:-Transpose(L[n]) = -a*omega*`sinθ`-m*`cosecθ`+n*`cotθ`+`∂__θ`
Also I divided the differential equation in 3 parts (A, B, C).
F := (omega*a*sin(theta)+m/sin(theta)+1/(2*tan(theta)))(diff(S(theta), theta)-omega*a*sin(theta)*S(theta)-m*S(theta)/sin(theta)+S(theta)/(2*tan(theta)))+diff(S(theta), theta, theta)-omega*a*sin(theta)*(diff(S(theta), theta))-m*(diff(S(theta), theta))/sin(theta)+(diff(S(theta), theta))/(2*tan(theta))
G := a*`μ__e`*sin(theta)*(diff(S(theta), theta)-omega*a*sin(theta)*S(theta)-m*S(theta)/sin(theta)+S(theta)/(2*tan(theta)))/(lambda+a*`μ__e`*cos(theta))
H := (2*(lambda^2+a^2*`μ__e`*cos(theta)^2))*S(theta)
DF := F+G+H
dsolve(DF)
dsolve({DF, DF(0) = 1}, numeric, range = 0 .. 20)
Download DIFFERENTIAL_EQUATION.mw
