Question: How is Maple able to arrive at an exact solution to int[y'(x)*(x^2)/(x^2 -1)] =(int[sqrt(y(x))])^(-2/3) ?
For this integro-differential equation,
Equation:= int[y'(x)* (x^2)/[(x^2)-1],x)  =  (int[sqrt(y(x)])^(-2/3)
Maple is able to obtain an exact intrinsic solution
from which an exact solution can be extracted, namely,
ExtrinsicSolution:= y(x) = sqrt(3)*(-8*_C1*x^(8/3) + 12*x^2 - 3)^(3/4)
My question concerns how was this solution obtained.
Even more, specifically, 'odeadvisor' suggests converting the
equation in question to the form
ode:= y = G(x,diff(y(x),x));
However, I cannot reconcile how this can be applied to an equation which
contains two integrals. (Regretably, I am not able to directly, attach my
Maple worksheet directly on to this sheet). The situation is that after
applying 'dsolve' to the above 'Equation', Maple comes back with an
intrinsic solution which can was used to obtain the 'ExtrinsicSolution' in
the above.  So it is the missing steps between applyingthe dsolve command
to Equation and the intrinsic solution which MS provides which, in turn, leads
to the 'Extrinsic Solution' above. I would greatly, appreciate if anyone can
fill in the missing steps.
