Question: any way to get two equations solved
i have two euations including integration which has two unkwnon x1 and x2.
how can i get these equations solved, thanks for the help.
with(DirectSearch)
[BoundedObjective, CompromiseProgramming, DataFit, ExponentialWeightedSum, GlobalOptima, GlobalSearch, Minimax, ModifiedTchebycheff, Search, SolveEquations, WeightedProduct, WeightedSum]
with(LinearAlgebra):
with(Student:-Calculus1):
with(Student:-NumericalAnalysis):
A:=convert(taylor(exp(Q),Q,6),polynom);
1+Q+(1/2)*Q^2+(1/6)*Q^3+(1/24)*Q^4+(1/120)*Q^5
Q:=a[11]*(E[r])^2+a[22]*(E[theta])^2+2*a[12]*E[r]*E[theta];
E[r]^2*a[11]+2*E[r]*E[theta]*a[12]+E[theta]^2*a[22]
psi:=0.5*c*(exp(Q)-1);
.5*c*(exp(E[r]^2*a[11]+2*E[r]*E[theta]*a[12]+E[theta]^2*a[22])-1)
F:=Matrix(3,3,[[lambda[r],0,0],[0,lambda[theta],0],[0,0,lambda[z]]]);
Matrix(3, 3, {(1, 1) = lambda[r], (1, 2) = 0, (1, 3) = 0, (2, 1) = 0, (2, 2) = lambda[theta], (2, 3) = 0, (3, 1) = 0, (3, 2) = 0, (3, 3) = lambda[z]})
sigma[r]:=-p+diff(psi,E[r])*F[1,1]^2;
-p+.5*c*(2*E[r]*a[11]+2*E[theta]*a[12])*exp(E[r]^2*a[11]+2*E[r]*E[theta]*a[12]+E[theta]^2*a[22])*lambda[r]^2
sigma[theta]:=-p+diff(psi,E[theta])*F[2,2]^2;
-p+.5*c*(2*E[r]*a[12]+2*E[theta]*a[22])*exp(E[r]^2*a[11]+2*E[r]*E[theta]*a[12]+E[theta]^2*a[22])*lambda[theta]^2
sigma[z]:=-p+diff(psi,E[z])*F[3,3]^2;
-p
p1:=diff(psi,E[r])*F[1,1]^2;#Pressure is constituted form 3 parts, one part is p1, other part is p2 and a constant p0
E[r]:=0.5*(lambda[r]^2-1);
.5*lambda[r]^2-.5
E[theta]:=0.5*(lambda[theta]^2-1);
.5*lambda[theta]^2-.5
E[z]:=0.5*(lambda[z]^2-1);
.5*lambda[z]^2-.5
lambda[r]:=x2*sqrt((r^2-x1)/x2)/r;
x2*((r^2-x1)/x2)^(1/2)/r
lambda[theta]:=r/sqrt((r^2-x1)/x2);
r/((r^2-x1)/x2)^(1/2)
(14)
lambda[z]:=1/x2;
1/x2
(15)
sigma[r];
-p+.5*c*(2*(.5*x2*(r^2-x1)/r^2-.5)*a[11]+2*(.5*r^2*x2/(r^2-x1)-.5)*a[12])*exp((.5*x2*(r^2-x1)/r^2-.5)^2*a[11]+2*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)*a[12]+(.5*r^2*x2/(r^2-x1)-.5)^2*a[22])*x2*(r^2-x1)/r^2
(16)
sigma[theta]:
sigma[z]:
#p2:=int((sigma[r]-sigma[theta])/r,r):%Pressure is constituted form 2 parts, one part is p1, other part is p2 and and a constant p0
Digits:=10:
c:=790000:
a[11]:=0.539:
a[22]:=0.368:
a[12]:=0.653:
p_in:=10000:
p_out:=0:
r_in:=5.4e-3:
r_out:=6.1e-3:
F_a:=0.381846:
p21:=(c/2)*(((r^2-x1)/r^3)-(x2*r/(r^2-x1)))*exp(Q);
395000*((r^2-x1)/r^3-x2*r/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)
(17)
p22:=(c/2)*Int(exp(Q)*(3*x2*r^6-r^6+5*x1*r^4-x1*x2*r^4-7*x1^2*r^2+3*x1^3)/(r^4*(r^2-x1)^2),r=r_in..r_out);#This is the part that should be maintained as an integral until the final solution
395000*(Int(exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*(3*r^6*x2-r^6-r^4*x1*x2+5*r^4*x1-7*r^2*x1^2+3*x1^3)/(r^4*(r^2-x1)^2), r = 0.54e-2 .. 0.61e-2))
(18)
p2:=p21-p22;#p2 is computed using the integration by part method
395000*((r^2-x1)/r^3-x2*r/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)-395000*(Int(exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*(3*r^6*x2-r^6-r^4*x1*x2+5*r^4*x1-7*r^2*x1^2+3*x1^3)/(r^4*(r^2-x1)^2), r = 0.54e-2 .. 0.61e-2))
(19)
p0:=(p_out+eval(p2,r=r_out));#p0 is the constant which is defined form the boundary conditions either p_out=subs(r=r_out,sigma[r]) or p_in=subs(r=r_in,sigma[r])
395000*(-4405655.099*x1+163.9344262-0.61e-2*x2/(-x1+0.3721e-4))*exp(.539*(13437.24805*x2*(-x1+0.3721e-4)-.5)^2+1.306*(13437.24805*x2*(-x1+0.3721e-4)-.5)*(0.18605e-4*x2/(-x1+0.3721e-4)-.5)+.368*(0.18605e-4*x2/(-x1+0.3721e-4)-.5)^2)-395000*(Int(exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*(3*r^6*x2-r^6-r^4*x1*x2+5*r^4*x1-7*r^2*x1^2+3*x1^3)/(r^4*(r^2-x1)^2), r = 0.54e-2 .. 0.61e-2))
(20)
p:=p1+p2+p0;#p is the total pressure
395000.0*(.5390*x2*(r^2-x1)/r^2-1.1920+.6530*r^2*x2/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*x2*(r^2-x1)/r^2+395000*((r^2-x1)/r^3-x2*r/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)-790000*(Int(exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*(3*r^6*x2-r^6-r^4*x1*x2+5*r^4*x1-7*r^2*x1^2+3*x1^3)/(r^4*(r^2-x1)^2), r = 0.54e-2 .. 0.61e-2))+395000*(-4405655.099*x1+163.9344262-0.61e-2*x2/(-x1+0.3721e-4))*exp(.539*(13437.24805*x2*(-x1+0.3721e-4)-.5)^2+1.306*(13437.24805*x2*(-x1+0.3721e-4)-.5)*(0.18605e-4*x2/(-x1+0.3721e-4)-.5)+.368*(0.18605e-4*x2/(-x1+0.3721e-4)-.5)^2)
(21)
#p:=H+H00;
eq1:=Int((sigma[r]-sigma[theta])/r,r=r_in..r_out);
Int((395000.0*(.5390*x2*(r^2-x1)/r^2-1.1920+.6530*r^2*x2/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*x2*(r^2-x1)/r^2-395000.0*(.6530*x2*(r^2-x1)/r^2-1.0210+.3680*r^2*x2/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*r^2*x2/(r^2-x1))/r, r = 0.54e-2 .. 0.61e-2)
(22)
eq2:=Int(2*Pi*sigma[z]*r,r=r_in..r_out);
Int(2*Pi*(-395000.0*(.5390*x2*(r^2-x1)/r^2-1.1920+.6530*r^2*x2/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*x2*(r^2-x1)/r^2-395000*((r^2-x1)/r^3-x2*r/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)+790000*(Int(exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*(3*r^6*x2-r^6-r^4*x1*x2+5*r^4*x1-7*r^2*x1^2+3*x1^3)/(r^4*(r^2-x1)^2), r = 0.54e-2 .. 0.61e-2))-395000*(-4405655.099*x1+163.9344262-0.61e-2*x2/(-x1+0.3721e-4))*exp(.539*(13437.24805*x2*(-x1+0.3721e-4)-.5)^2+1.306*(13437.24805*x2*(-x1+0.3721e-4)-.5)*(0.18605e-4*x2/(-x1+0.3721e-4)-.5)+.368*(0.18605e-4*x2/(-x1+0.3721e-4)-.5)^2))*r, r = 0.54e-2 .. 0.61e-2)
(23)
#eq1:=Quadrature((sigma[r]-sigma[theta])/r,r=r_in..r_out,method=gaussian[5],output=value):
#eq2:=Quadrature(2*Pi*sigma[z]*r,r=r_in..r_out,method=gaussian[5],output=value):
eq1=evalf(p_out-p_in)
Int((395000.0*(.5390*x2*(r^2-x1)/r^2-1.1920+.6530*r^2*x2/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*x2*(r^2-x1)/r^2-395000.0*(.6530*x2*(r^2-x1)/r^2-1.0210+.3680*r^2*x2/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*r^2*x2/(r^2-x1))/r, r = 0.54e-2 .. 0.61e-2) = -10000.
(24)
eq2=F_a
Int(2*Pi*(-395000.0*(.5390*x2*(r^2-x1)/r^2-1.1920+.6530*r^2*x2/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*x2*(r^2-x1)/r^2-395000*((r^2-x1)/r^3-x2*r/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)+790000*(Int(exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*(3*r^6*x2-r^6-r^4*x1*x2+5*r^4*x1-7*r^2*x1^2+3*x1^3)/(r^4*(r^2-x1)^2), r = 0.54e-2 .. 0.61e-2))-395000*(-4405655.099*x1+163.9344262-0.61e-2*x2/(-x1+0.3721e-4))*exp(.539*(13437.24805*x2*(-x1+0.3721e-4)-.5)^2+1.306*(13437.24805*x2*(-x1+0.3721e-4)-.5)*(0.18605e-4*x2/(-x1+0.3721e-4)-.5)+.368*(0.18605e-4*x2/(-x1+0.3721e-4)-.5)^2))*r, r = 0.54e-2 .. 0.61e-2) = .381846
(25)
fsolve({eq1=evalf(p_out-p_in),eq2=F_a},{x1,x2});
fsolve({Int((395000.0*(.5390*x2*(r^2-x1)/r^2-1.1920+.6530*r^2*x2/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*x2*(r^2-x1)/r^2-395000.0*(.6530*x2*(r^2-x1)/r^2-1.0210+.3680*r^2*x2/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*r^2*x2/(r^2-x1))/r, r = 0.54e-2 .. 0.61e-2) = -10000., Int(2*Pi*(-395000.0*(.5390*x2*(r^2-x1)/r^2-1.1920+.6530*r^2*x2/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*x2*(r^2-x1)/r^2-395000*((r^2-x1)/r^3-x2*r/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)+790000*(Int(exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*(3*r^6*x2-r^6-r^4*x1*x2+5*r^4*x1-7*r^2*x1^2+3*x1^3)/(r^4*(r^2-x1)^2), r = 0.54e-2 .. 0.61e-2))-395000*(-4405655.099*x1+163.9344262-0.61e-2*x2/(-x1+0.3721e-4))*exp(.539*(13437.24805*x2*(-x1+0.3721e-4)-.5)^2+1.306*(13437.24805*x2*(-x1+0.3721e-4)-.5)*(0.18605e-4*x2/(-x1+0.3721e-4)-.5)+.368*(0.18605e-4*x2/(-x1+0.3721e-4)-.5)^2))*r, r = 0.54e-2 .. 0.61e-2) = .381846}, {x1, x2})
(26)
SolveEquations([eq1=evalf(p_out-p_in),eq2=F_a]);
Warning, objective function returns unfeasible value HFloat(undefined) for initial point [x1 = .9, x2 = .9]; trying to find a feasible initial point
Error, (in DirectSearch:-Search) cannot find feasible initial point; specify a new one
fsolve_problem.mw
