Question: Kronecker delta not recognized
 Hello,
  Doing simple calculations I found Maple 2024 and 2023 don't recognize Kronecker delta in the expression
Full worksheet attached. Is there any way to let Maple handle this?
Remaining questions:
1. Doing calculations using Int and value left the result unevaluated eq. (6) and eq. (7) while using int gives 0. Why?
2. Is there possibility to substitute indexed (i.e.) atomic variables like p__m? For example changing by command p__m to p__k.
Thank you in advance,
delta_kron-problem.mw
