Question: Query regarding the output of a procedure
Hi,
I am struggling with the output of a procedure. A dummy code is as follows:
fun := x^2+y^2;
temp_proc := proc(x, y)
local out1, out2, out3:
if x > 0 then out1 := fun; out2 := 2*fun; out3 := k*fun;
elif x <= 0 then out1 := fun; out2 := -2*fun; out3 := -k*fun;
end if:
return(out1, out2, out3);
xt := -1: yt := 2:
out1_fin := temp_proc(xt, yt)[1];
out2_fin := temp_proc(xt, yt)[2];
out3_fin := temp_proc(xt, yt)[3];
xt and yt are numerical input parameters. I expect to obtain "out1_fin" and "out2_fin" in numerical form and "out3_fin" in symbolic form. All three outputs should substitute xt and yt for x and y, respectively, wherever relevant.
However, currently, the output I am getting is not after substituting the values of xy and yt. The output is as follows:
out1_fin := x^2+y^2
out2_fin := -2*x^2-2*y^2
out3_fin := -k*(x^2+y^2)
May I get some help in resolving the issue?
Also, would a procedure be a good idea for this task, or would a module be better?
I would appreciate any guidance in this regard. Thank you.
Regards,
Omkar
