Question: Why does simplify command turn these three expressions to one single expression?
In the code below, I define an expression, then turn it into a function of omega_d.
Consider the results (5) and (6) below.
I take the derivative of the function relative to omega_d, set the derivative to zero and ask Maple to solve for the critical point (ie, the omega_d at which the derivative is zero).
I get the correct result in (5), ie three different critical points. But when I simplify this result, Maple returns only one of the critical points.
Why?
expr := f/sqrt((`ω__0`^2-`ω__d`^2)^2+`γ__b`^2*`ω__d`^2)
f/((omega__0^2-omega__d^2)^2+gamma__b^2*omega__d^2)^(1/2)
A := unapply(expr, `ω__d`)
proc (omega__d) options operator, arrow; f/((omega__0^2-omega__d^2)^2+gamma__b^2*omega__d^2)^(1/2) end proc
diff(A(`ω__d`), `ω__d`)
-(1/2)*f*(-4*(omega__0^2-omega__d^2)*omega__d+2*gamma__b^2*omega__d)/((omega__0^2-omega__d^2)^2+gamma__b^2*omega__d^2)^(3/2)
simplify(diff(A(`ω__d`), `ω__d`))
-f*omega__d*(gamma__b^2-2*omega__0^2+2*omega__d^2)/(omega__d^4+(gamma__b^2-2*omega__0^2)*omega__d^2+omega__0^4)^(3/2)
solve(diff(A(`ω__d`), `ω__d`) = 0, `ω__d`)
0, (1/2)*(-2*gamma__b^2+4*omega__0^2)^(1/2), -(1/2)*(-2*gamma__b^2+4*omega__0^2)^(1/2)
simplify(solve(diff(A(`ω__d`), `ω__d`) = 0, `ω__d`))
0
This was a problem for me just now because I used the command in (6) first and just could not figure out what the heck was going on. I did the calculations by hand to check, and then finally found out it was this simplify command.
Download simplifysolve.mw
