Question: which ode to verify against? original or the root?
This might be more of a math question but I am using dsolve and odetest.
I have number of problems like this. Given an ode, where we need to first solve for y'(x) to isolate it. Say the ode has y'(x) under square root. So need to first square the ode.
Then say we obtain two roots. i.e. two solutions. Each is now an ode that can be solved directly.
Each one of these is solved on its own and generates a solution.
Now the question is this: Should one verify the solution of each of these root ode's against the original ode or against each root on its own that was used to generate this specific solution?
For example, given the ode sqrt(1 + diff(y(x), x)^2) + a*diff(y(x), x) = x then maple first solves for diff(y(x), x). This gives two new ode's. So we end up with two solutions. But odetest will not verify these two solutions against the orginal ode.
It does verify each solution however against each of the root ode's.
But should not the two generated solutions satisfy the original ode? Is it OK just to verify the solution against each root?
Here is worksheet example showing one such problem. I know that squaring an equation introduces extraneous solutions. but  in this case both solutions fail to verify against the original ode and not just one!
I am asking what is the accepted approach to this problem? Will it be OK to always verify the solution against the root of the original ode, or should one verify against the original ode used to solve for these roots? I have many ode's like this where odetest do not verify the solution generated because I am using the original ode to check the solution against.
original_ode:=sqrt(1 + diff(y(x), x)^2) + a*diff(y(x), x) = x;
(1+(diff(y(x), x))^2)^(1/2)+a*(diff(y(x), x)) = x
maple_sol_direct:=[dsolve(ode)];
[y(x) = ((1/2)*x*(a^2+x^2-1)^(1/2)+(1/8)*(4*a^2-4)*ln(x+(a^2+x^2-1)^(1/2))+(1/2)*a*x^2)/((a-1)*(a+1))+c__1, y(x) = -((1/2)*x*(a^2+x^2-1)^(1/2)+(1/8)*(4*a^2-4)*ln(x+(a^2+x^2-1)^(1/2))-(1/2)*a*x^2)/((a-1)*(a+1))+c__1]
#this shows none of these solutions verify
map(X->odetest(X,original_ode),maple_sol_direct);
[((a^2-1)*(a^2+x^2-1)^(1/2)*((a^4+a^2*x^2+2*a*x*(a^2+x^2-1)^(1/2)-a^2+x^2)/(a^2-1)^2)^(1/2)+a^3+a*x^2+x*(a^2+x^2-1)^(1/2)-a)/((a^2+x^2-1)^(1/2)*(a^2-1)), ((a^2-1)*(a^2+x^2-1)^(1/2)*((a^4+a^2*x^2-2*a*x*(a^2+x^2-1)^(1/2)-a^2+x^2)/(a^2-1)^2)^(1/2)-a^3-a*x^2+x*(a^2+x^2-1)^(1/2)+a)/((a^2+x^2-1)^(1/2)*(a^2-1))]
#now we solve the original ode for y' (which is what maple does internall)
generated_odes:=[PDEtools:-Solve(original_ode,diff(y(x),x))];
[diff(y(x), x) = (a*x+(a^2+x^2-1)^(1/2))/(a^2-1), diff(y(x), x) = -(-a*x+(a^2+x^2-1)^(1/2))/(a^2-1)]
#now solve say the first
maple_sol:=dsolve(generated_odes[1]);
odetest(maple_sol,original_ode); #failes to verify against original ode
y(x) = ((1/2)*x*(a^2+x^2-1)^(1/2)+(1/8)*(4*a^2-4)*ln(x+(a^2+x^2-1)^(1/2))+(1/2)*a*x^2)/(a^2-1)+c__1
#but solution above verifies the first root ode found
odetest(maple_sol,generated_odes[1]);
0
#same for second root ode
maple_sol:=dsolve(generated_odes[2]);
y(x) = -((1/2)*x*(a^2+x^2-1)^(1/2)+(1/8)*(4*a^2-4)*ln(x+(a^2+x^2-1)^(1/2))-(1/2)*a*x^2)/(a^2-1)+c__1
#but solution above verifies the second root ode found
odetest(maple_sol,generated_odes[2]);
0
Download which_ode_to_verify_against.mw
Update
I think the verification should be done against the original ode and not against each of the root odes.
After all, this is the ode the user is asking to solve. Also the user have no idea what the root ode's are in order to use odetest against them and get zero residue.
I think the issue is that it is just it is hard to symbolically verify that the residue from odetest is zero or not. This is the zero test problem.
I found that it depends on the value of a.
if we assume a>1 or a<-1, then one of the two solutions is the correct one and the other is the extraneous as expected.
But using simplify with this assumption, maple was still not able to verify the residue is zero. But plotting it shows that this is the case.
Here is worksheet showing this.
Original ode generated two solutions. We then find the residue of each by calling odetest. Plotting each residue over say x=-3..3 and giving different values for a shows that one residue is always zero when a>1  (which means one solution is correct) and when a<-1 then it flips.
At a=1 and a=-1, there is dvision by zero. For a between -1 and +1, both solution are wrong !
So the bottom line is this:
Maple's solutions are as expected. Nothing wrong with them. After all, this is quadrature ode. So it is just one step to solve, which is to do integration. So if the integration is correct, that is it.
The hard part is to know which is the correct solution of the two, as it depends on value of a but simplify could not verify symbolically even using assumptions that residue is zero. Also when giving odetest assumptions on it still could not verify the solution.
May be someone can find clever way to verify one of the residues is zero symbolically with this assumption. I could not.
Only numercially this is possible by plotting and looking. Here is worksheet. The problem with using the root ode's to verify the two solutions against gives true on both of them.
But this is false true. As only one of these two solutions is correct and it depends on the value of which of the two solution is the correct one!
maple_sol:=map(X->dsolve(X),generated_odes);
the_residue:=map(X->odetest(X,original_ode),maple_sol);
[y(x) = ((1/2)*x*(a^2+x^2-1)^(1/2)+(1/8)*(4*a^2-4)*ln(x+(a^2+x^2-1)^(1/2))+(1/2)*a*x^2)/(a^2-1)+c__1, y(x) = -((1/2)*x*(a^2+x^2-1)^(1/2)+(1/8)*(4*a^2-4)*ln(x+(a^2+x^2-1)^(1/2))-(1/2)*a*x^2)/(a^2-1)+c__1]
#try using simplify with assumptions.
map(X->(simplify(X) assuming a>1),the_residue);
[(a^3+a*x^2+x*(a^2+x^2-1)^(1/2)+(a^2+x^2-1)^(1/2)*(a^4+(x^2-1)*a^2+2*a*x*(a^2+x^2-1)^(1/2)+x^2)^(1/2)-a)/((a^2-1)*(a^2+x^2-1)^(1/2)), (-a^3-a*x^2+x*(a^2+x^2-1)^(1/2)+(a^2+x^2-1)^(1/2)*(a^4+(x^2-1)*a^2-2*a*x*(a^2+x^2-1)^(1/2)+x^2)^(1/2)+a)/((a^2-1)*(a^2+x^2-1)^(1/2))]
map(X->(simplify(X) assuming a<-1),the_residue);
#try assumption on odetest directly, does not work
the_residue:=map(X->(odetest(X,original_ode) assuming a>1),maple_sol);
[(a^3+a*x^2+(a^4+a^2*x^2+2*a*x*(a^2+x^2-1)^(1/2)-a^2+x^2)^(1/2)*(a^2+x^2-1)^(1/2)+x*(a^2+x^2-1)^(1/2)-a)/((a^2-1)*(a^2+x^2-1)^(1/2)), (-a^3-a*x^2+(a^4+a^2*x^2-2*a*x*(a^2+x^2-1)^(1/2)-a^2+x^2)^(1/2)*(a^2+x^2-1)^(1/2)+x*(a^2+x^2-1)^(1/2)+a)/((a^2-1)*(a^2+x^2-1)^(1/2))]
#try plotting the residual to see if it is zero numerically
map(X->plot(eval(X,a=2),x=-3..3),the_residue);
[INTERFACE_PLOT(CURVES(Matrix(200, 2, {(1, 1) = -3.0, (1, 2) = 2.618802153517006, (2, 1) = -2.9684543698492463, (2, 2) = 2.6034550758917687, (3, 1) = -2.9410066857286434, (3, 2) = 2.590181362962417, (4, 1) = -2.910138894271357, (4, 2) = 2.575344310737094, (5, 1) = -2.8790664910552763, (5, 2) = 2.560508024329546, (6, 1) = -2.848141769547739, (6, 2) = 2.545843347529254, (7, 1) = -2.819470594070352, (7, 2) = 2.532339525525828, (8, 1) = -2.789783252562814, (8, 2) = 2.518452765450757, (9, 1) = -2.7590805615075378, (9, 2) = 2.5041958210804007, (10, 1) = -2.728476334371859, (10, 2) = 2.4900931430863973, (11, 1) = -2.6969961250251258, (11, 2) = 2.4757026400512974, (12, 1) = -2.6692683394974877, (12, 2) = 2.4631270922987567, (13, 1) = -2.6380534203015076, (13, 2) = 2.449084332125028, (14, 1) = -2.6067103296482412, (14, 2) = 2.435108692807071, (15, 1) = -2.5765054540703516, (15, 2) = 2.4217618332961304, (16, 1) = -2.549076533366834, (16, 2) = 2.4097471932125414, (17, 1) = -2.516460893668342, (17, 2) = 2.395594630396337, (18, 1) = -2.488831168643216, (18, 2) = 2.383722172327674, (19, 1) = -2.456691230050251, (19, 2) = 2.3700496670113598, (20, 1) = -2.4282419384924623, (20, 2) = 2.3580739981355596, (21, 1) = -2.3970285566834173, (21, 2) = 2.3450752692086643, (22, 1) = -2.367306035879397, (22, 2) = 2.3328374099950797, (23, 1) = -2.3362937035175877, (23, 2) = 2.3202178090411376, (24, 1) = -2.307814701407035, (24, 2) = 2.3087667359350257, (25, 1) = -2.2770962502512564, (25, 2) = 2.296566692349589, (26, 1) = -2.2451884127638193, (26, 2) = 2.28406500769504, (27, 1) = -2.217412546432161, (27, 2) = 2.2733275068829815, (28, 1) = -2.1874138498492464, (28, 2) = 2.261886426430375, (29, 1) = -2.156422260904523, (29, 2) = 2.2502407765573778, (30, 1) = -2.126103037386935, (30, 2) = 2.2390234610349937, (31, 1) = -2.0967676296482414, (31, 2) = 2.228339806259257, (32, 1) = -2.064195660904523, (32, 2) = 2.216678111428435, (33, 1) = -2.034928298291457, (33, 2) = 2.2063844067912797, (34, 1) = -2.0036791417085427, (34, 2) = 2.1955920067901236, (35, 1) = -1.9753627613065328, (35, 2) = 2.1859939179137977, (36, 1) = -1.9444054781909548, (36, 2) = 2.175703225298527, (37, 1) = -1.9152770873366836, (37, 2) = 2.1662186393631018, (38, 1) = -1.8848295259296484, (38, 2) = 2.1565152906060243, (39, 1) = -1.8550614693467338, (39, 2) = 2.1472421971205087, (40, 1) = -1.8238970728643218, (40, 2) = 2.1377665525179372, (41, 1) = -1.793882055075377, (41, 2) = 2.1288711086925667, (42, 1) = -1.7631873642211056, (42, 2) = 2.1200146603868495, (43, 1) = -1.7327468409045226, (43, 2) = 2.111478055543716, (44, 1) = -1.7047751614070352, (44, 2) = 2.103855865739976, (45, 1) = -1.6727164601005025, (45, 2) = 2.09538845788584, (46, 1) = -1.644042775477387, (46, 2) = 2.0880643481039733, (47, 1) = -1.6134706471356783, (47, 2) = 2.0805214734302417, (48, 1) = -1.584209219396985, (48, 2) = 2.073565895480531, (49, 1) = -1.5517181644221105, (49, 2) = 2.066153205692597, (50, 1) = -1.523583298190955, (50, 2) = 2.0600053043871487, (51, 1) = -1.4916499733668342, (51, 2) = 2.0533402668685277, (52, 1) = -1.4625462144723618, (52, 2) = 2.0475630519855956, (53, 1) = -1.430711276080402, (53, 2) = 2.041577007883342, (54, 1) = -1.4032431081407037, (54, 2) = 2.0366990612312046, (55, 1) = -1.371960071155779, (55, 2) = 2.0314758699762687, (56, 1) = -1.3417422018090452, (56, 2) = 2.0267749793640206, (57, 1) = -1.3115440730653267, (57, 2) = 2.0224241192898096, (58, 1) = -1.2814570377889447, (58, 2) = 2.018443010161291, (59, 1) = -1.2525528159798995, (59, 2) = 2.0149592710003934, (60, 1) = -1.2213065867336683, (60, 2) = 2.011578419968024, (61, 1) = -1.1915266646231155, (61, 2) = 2.0087379140907733, (62, 1) = -1.1601846988944724, (62, 2) = 2.0061609451697384, (63, 1) = -1.1318126725628141, (63, 2) = 2.0042018697946085, (64, 1) = -1.1004562721608042, (64, 2) = 2.0024599516310926, (65, 1) = -1.0704223046231156, (65, 2) = 2.0012181016584103, (66, 1) = -1.0404614406030153, (66, 2) = 2.0004051529975033, (67, 1) = -1.0091672020100502, (67, 2) = 2.000020961276726, (68, 1) = -.9803440658291458, (68, 2) = 2.000097064142108, (69, 1) = -.950825231758794, (69, 2) = 2.0006119928845933, (70, 1) = -.9182329314572866, (70, 2) = 2.0017057871067765, (71, 1) = -.8887232731658292, (71, 2) = 2.003182256488408, (72, 1) = -.8585441201005026, (72, 2) = 2.0051806163792336, (73, 1) = -.8278526987939698, (73, 2) = 2.0077301503538707, (74, 1) = -.7996413102512561, (74, 2) = 2.0105431625197916, (75, 1) = -.7695688836180903, (75, 2) = 2.0140468355507135, (76, 1) = -.7397253702512563, (76, 2) = 2.018049067665526, (77, 1) = -.707802087437186, (77, 2) = 2.0229207486171226, (78, 1) = -.679631173266332, (78, 2) = 2.0277362608405256, (79, 1) = -.6471277863316587, (79, 2) = 2.033905208171417, (80, 1) = -.6177959855276383, (80, 2) = 2.0400456979376016, (81, 1) = -.5887737018090453, (81, 2) = 2.0466660186095775, (82, 1) = -.557565423316583, (82, 2) = 2.054399251371265, (83, 1) = -.5262309009045225, (83, 2) = 2.062814356999972, (84, 1) = -.4977211251256284, (84, 2) = 2.0710458120302153, (85, 1) = -.467445009648241, (85, 2) = 2.080395573901162, (86, 1) = -.43789847999999987, (86, 2) = 2.0901321734962743, (87, 1) = -.4058697301507541, (87, 2) = 2.101378672267316, (88, 1) = -.3781559565829147, (88, 2) = 2.1116978358271643, (89, 1) = -.3463256801005028, (89, 2) = 2.1242303559862217, (90, 1) = -.31640354683417105, (90, 2) = 2.1366819898761236, (91, 1) = -.28677042874371894, (91, 2) = 2.1496599351368615, (92, 1) = -.2571137372864323, (92, 2) = 2.163298046445263, (93, 1) = -.22686578924623113, (93, 2) = 2.1778830484824354, (94, 1) = -.19480347105527684, (94, 2) = 2.194092538325835, (95, 1) = -.16540546492462305, (95, 2) = 2.2096373387205572, (96, 1) = -.13638585798994995, (96, 2) = 2.2256256753153867, (97, 1) = -.1053643757788949, (97, 2) = 2.243427241456501, (98, 1) = -0.7441042462311565e-1, (98, 2) = 2.2619243027301903, (99, 1) = -0.466274152763817e-1, (99, 2) = 2.2791527992671883, (100, 1) = -0.13716437185929742e-1, (100, 2) = 2.3003291995354886, (101, 1) = 0.13821943115577717e-1, (101, 2) = 2.3186892380141626, (102, 1) = 0.4603117206030127e-1, (102, 2) = 2.3409039338272386, (103, 1) = 0.7677176080402015e-1, (103, 2) = 2.3628497019174124, (104, 1) = .10421944492462298, (104, 2) = 2.383057596918908, (105, 1) = .13508723638190956, (105, 2) = 2.406472459979865, (106, 1) = .16615963959798963, (106, 2) = 2.4307765512356734, (107, 1) = .19708436110552752, (107, 2) = 2.4556929565983054, (108, 1) = .22575553658291447, (108, 2) = 2.479438807673681, (109, 1) = .2554428780904523, (109, 2) = 2.504676374505919, (110, 1) = .2861455691457282, (110, 2) = 2.531467989207787, (111, 1) = .31674979628140676, (111, 2) = 2.5588672247983357, (112, 1) = .34823000562814066, (112, 2) = 2.587766637483634, (113, 1) = .37595779115577876, (113, 2) = 2.6138168996886026, (114, 1) = .40717271035175884, (114, 2) = 2.6438039335574617, (115, 1) = .4385158010050252, (115, 2) = 2.674610242117389, (116, 1) = .4687206765829144, (116, 2) = 2.7049497742651196, (117, 1) = .4961495972864318, (117, 2) = 2.7330484328451297, (118, 1) = .5287652369849245, (118, 2) = 2.7671295854107036, (119, 1) = .5563949620100499, (119, 2) = 2.7965617517116854, (120, 1) = .5885349006030149, (120, 2) = 2.8314359637785733, (121, 1) = .6169841921608037, (121, 2) = 2.8628690617930492, (122, 1) = .6481975739698491, (122, 2) = 2.897955029430453, (123, 1) = .677920094773869, (123, 2) = 2.93193800399096, (124, 1) = .7089324271356783, (124, 2) = 2.9679809326740423, (125, 1) = .7374114292462313, (125, 2) = 3.001596770773898, (126, 1) = .76812988040201, (126, 2) = 3.038400902970377, (127, 1) = .8000377178894471, (127, 2) = 3.077217436963366, (128, 1) = .8278135842211056, (128, 2) = 3.1114851826847643, (129, 1) = .8578122808040196, (129, 2) = 3.148985004267594, (130, 1) = .888803869748743, (130, 2) = 3.188249411782034, (131, 1) = .9191230932663319, (131, 2) = 3.227165939645544, (132, 1) = .948458501005025, (132, 2) = 3.265284049533865, (133, 1) = .9810304697487435, (133, 2) = 3.3081310142232376, (134, 1) = 1.0102978323618084, (134, 2) = 3.3470902196124115, (135, 1) = 1.0415469889447229, (135, 2) = 3.389156386620323, (136, 1) = 1.0698633693467334, (136, 2) = 3.427683503758898, (137, 1) = 1.1008206524623114, (137, 2) = 3.4702384716157253, (138, 1) = 1.129949043316583, (138, 2) = 3.5106845456345934, (139, 1) = 1.1603966047236183, (139, 2) = 3.553372397295079, (140, 1) = 1.1901646613065324, (140, 2) = 3.5955032769361948, (141, 1) = 1.221329057788945, (141, 2) = 3.6400194488953788, (142, 1) = 1.2513440755778893, (142, 2) = 3.683279750414722, (143, 1) = 1.2820387664321604, (143, 2) = 3.7279016029740153, (144, 1) = 1.3124792897487438, (144, 2) = 3.7725259575619376, (145, 1) = 1.3404509692462305, (145, 2) = 3.8138497404616314, (146, 1) = 1.3725096705527635, (146, 2) = 3.861577424594867, (147, 1) = 1.4011833551758794, (147, 2) = 3.904588655774397, (148, 1) = 1.4317554835175876, (148, 2) = 3.9507750466152984, (149, 1) = 1.4610169112562819, (149, 2) = 3.9952900071216986, (150, 1) = 1.4935079662311557, (150, 2) = 4.045062749485724, (151, 1) = 1.5216428324623115, (151, 2) = 4.088447830439323, (152, 1) = 1.5535761572864324, (152, 2) = 4.138003011832534, (153, 1) = 1.5826799161809042, (153, 2) = 4.183449485466524, (154, 1) = 1.6145148545728638, (154, 2) = 4.233460969909385, (155, 1) = 1.6419830225125631, (155, 2) = 4.276858148281676, (156, 1) = 1.6732660594974869, (156, 2) = 4.3265525741832045, (157, 1) = 1.7034839288442214, (157, 2) = 4.374821138795024, (158, 1) = 1.7336820575879397, (158, 2) = 4.42331268131251, (159, 1) = 1.7637690928643206, (159, 2) = 4.471872332825193, (160, 1) = 1.792673314673367, (160, 2) = 4.518748792876914, (161, 1) = 1.8239195439195983, (161, 2) = 4.5696660229814015, (162, 1) = 1.8536994660301502, (162, 2) = 4.618422350438029, (163, 1) = 1.8850414317587942, (163, 2) = 4.669970641386326, (164, 1) = 1.913413458090452, (164, 2) = 4.716836417571029, (165, 1) = 1.944769858492462, (165, 2) = 4.7688495776710385, (166, 1) = 1.9748038260301506, (166, 2) = 4.8188779959480135, (167, 1) = 2.0047646900502514, (167, 2) = 4.868983012571075, (168, 1) = 2.0360589286432154, (168, 2) = 4.921523996578452, (169, 1) = 2.06488206482412, (169, 2) = 4.970097733788132, (170, 1) = 2.094400898894472, (170, 2) = 5.020019802315094, (171, 1) = 2.1269931991959794, (171, 2) = 5.075341211504158, (172, 1) = 2.156502857487437, (172, 2) = 5.125607972064607, (173, 1) = 2.1866820105527633, (173, 2) = 5.177185381228431, (174, 1) = 2.217373431859296, (174, 2) = 5.229810392176731, (175, 1) = 2.2455848204020104, (175, 2) = 5.278332330610496, (176, 1) = 2.275657247035176, (176, 2) = 5.330208765245516, (177, 1) = 2.30550076040201, (177, 2) = 5.381843230194378, (178, 1) = 2.33742404321608, (178, 2) = 5.4372404381487875, (179, 1) = 2.365594957386934, (179, 2) = 5.4862637352290635, (180, 1) = 2.3980983443216077, (180, 2) = 5.542982766786983, (181, 1) = 2.427430145125628, (181, 2) = 5.59430757925006, (182, 1) = 2.456452428844221, (182, 2) = 5.645218549289771, (183, 1) = 2.4876607073366834, (183, 2) = 5.7001025707611115, (184, 1) = 2.518995229748744, (184, 2) = 5.75534933696038, (185, 1) = 2.547505005527638, (185, 2) = 5.805735253004692, (186, 1) = 2.5777811210050254, (186, 2) = 5.859364570694414, (187, 1) = 2.607327650653266, (187, 2) = 5.911819591918552, (188, 1) = 2.6393564005025123, (188, 2) = 5.9688099166408275, (189, 1) = 2.667070174070351, (189, 2) = 6.018227766988365, (190, 1) = 2.698900450552763, (190, 2) = 6.075103704796472, (191, 1) = 2.7288225838190954, (191, 2) = 6.128682193645554, (192, 1) = 2.758455701909548, (192, 2) = 6.181847723993656, (193, 1) = 2.788112393366834, (193, 2) = 6.235157321929659, (194, 1) = 2.8183603414070344, (194, 2) = 6.289632209080143, (195, 1) = 2.8504226595979896, (195, 2) = 6.347485006729213, (196, 1) = 2.8798206657286434, (196, 2) = 6.400627815359849, (197, 1) = 2.9088402726633165, (197, 2) = 6.453175941222253, (198, 1) = 2.9398617548743715, (198, 2) = 6.509444982813266, (199, 1) = 2.97081570603015, (199, 2) = 6.565688117114613, (200, 1) = 3.0, (200, 2) = 6.618802153517006}, datatype = float[8]), COLOUR(RGB, .47058824, 0., 0.54901961e-1, _ATTRIBUTE("source" = "mathdefault"))), AXESLABELS(x, ""), VIEW(-3. .. 3., DEFAULT, _ATTRIBUTE("source" = "mathdefault")), _ATTRIBUTE("input" = [TABLE([1 = plot, 2 = [(1/3)*(6+2*x^2+(12+5*x^2+4*x*(x^2+3)^(1/2))^(1/2)*(x^2+3)^(1/2)+x*(x^2+3)^(1/2))/(x^2+3)^(1/2)], 3 = (x = -3 .. 3)]), "originalview" = [-3. .. 3., 2.00002096127672591 .. 6.61880215351700585], "originalaxesticks" = AXESTICKS(DEFAULT, DEFAULT, _ATTRIBUTE("source" = "mathdefault"))])), INTERFACE_PLOT(CURVES(Matrix(4275, 2, {(1, 1) = -3.0, (1, 2) = -0.6837200662697115e-15, (2, 1) = -2.9990141990577888, (2, 2) = .0, (3, 1) = -2.998028398115578, (3, 2) = .0, (4, 1) = -2.997042597173367, (4, 2) = 0.17105647169475397e-15, (5, 1) = -2.996056796231156, (5, 2) = 0.34219731609203613e-15, (6, 1) = -2.9950709952889447, (6, 2) = 0.171140861731156e-15, (7, 1) = -2.9940851943467335, (7, 2) = .0, (8, 1) = -2.9930993934045222, (8, 2) = -0.3424506422675371e-15, (9, 1) = -2.9921135924623115, (9, 2) = -0.17126757686660214e-15, (10, 1) = -2.9911277915201007, (10, 2) = -0.17130984996402752e-15, (11, 1) = -2.9901419905778894, (11, 2) = -0.17135214043372566e-15, (12, 1) = -2.989156189635678, (12, 2) = .0, (13, 1) = -2.988170388693467, (13, 2) = 0.17143677352066652e-15, (14, 1) = -2.9871845877512557, (14, 2) = -0.3429582323065476e-15, (15, 1) = -2.986198786809045, (15, 2) = .0, (16, 1) = -2.985212985866834, (16, 2) = 0.34312770727035483e-15, (17, 1) = -2.984227184924623, (17, 2) = .0, (18, 1) = -2.9832413839824117, (18, 2) = -0.17164866079055953e-15, (19, 1) = -2.982255583040201, (19, 2) = .0, (20, 1) = -2.98126978209799, (20, 2) = -0.5152006130426966e-15, (21, 1) = -2.980283981155779, (21, 2) = -0.1717760022958917e-15, (22, 1) = -2.9792981802135676, (22, 2) = 0.17181848436768184e-15, (23, 1) = -2.978312379271357, (23, 2) = -0.34372196780791236e-15, (24, 1) = -2.977326578329146, (24, 2) = 0.34380700182480444e-15, (25, 1) = -2.976340777386935, (25, 2) = 0.3438920708014155e-15, (26, 1) = -2.9753549764447236, (26, 2) = .0, (27, 1) = -2.974369175502513, (27, 2) = 0.5160934705429525e-15, (28, 1) = -2.973383374560302, (28, 2) = -0.3441474876433322e-15, (29, 1) = -2.9723975736180908, (29, 2) = .0, (30, 1) = -2.9714117726758795, (30, 2) = -0.17215897030923173e-15, (31, 1) = -2.9704259717336683, (31, 2) = 0.17220160983816225e-15, (32, 1) = -2.969440170791457, (32, 2) = 0.3444885338015571e-15, (33, 1) = -2.9684543698492463, (33, 2) = .0, (34, 1) = -2.967596629720477, (34, 2) = -0.34464817345364115e-15, (35, 1) = -2.966738889591708, (35, 2) = 0.6894449809588651e-15, (36, 1) = -2.9658811494629393, (36, 2) = 0.34479683409705105e-15, (37, 1) = -2.9650234093341705, (37, 2) = 0.5173068064749464e-15, (38, 1) = -2.9641656692054017, (38, 2) = 0.17247280057415324e-15, (39, 1) = -2.963307929076633, (39, 2) = 0.3450200246022126e-15, (40, 1) = -2.962450188947864, (40, 2) = .0, (41, 1) = -2.9615924488190952, (41, 2) = 0.17258447570862857e-15, (42, 1) = -2.9607347086903264, (42, 2) = -0.1726217273993334e-15, (43, 1) = -2.9598769685615576, (43, 2) = 0.17265899242142473e-15, (44, 1) = -2.9590192284327888, (44, 2) = -0.3453925415599416e-15, (45, 1) = -2.95816148830402, (45, 2) = -0.3454671249600798e-15, (46, 1) = -2.957303748175251, (46, 2) = 0.1727708675267006e-15, (47, 1) = -2.9564460080464823, (47, 2) = 0.5184245577750646e-15, (48, 1) = -2.9555882679177135, (48, 2) = 0.17284551768007146e-15, (49, 1) = -2.9547305277889446, (49, 2) = -0.34576572559383864e-15, (50, 1) = -2.953872787660176, (50, 2) = .0, (51, 1) = -2.953015047531407, (51, 2) = .0, (52, 1) = -2.952157307402638, (52, 2) = .0, (53, 1) = -2.9512995672738693, (53, 2) = -0.17303237698367246e-15, (54, 1) = -2.9504418271451005, (54, 2) = -0.17306978898554786e-15, (55, 1) = -2.9495840870163317, (55, 2) = .0, (56, 1) = -2.948726346887563, (56, 2) = -0.17314465317100996e-15, (57, 1) = -2.947868606758794, (57, 2) = -0.1731821053647361e-15, (58, 1) = -2.947010866630025, (58, 2) = 0.34643914193177104e-15, (59, 1) = -2.9461531265012564, (59, 2) = 0.34651409995905623e-15, (60, 1) = -2.9452953863724876, (60, 2) = .0, (61, 1) = -2.9444376462437187, (61, 2) = .0, (62, 1) = -2.94357990611495, (62, 2) = 0.1733695675461156e-15, (63, 1) = -2.942722165986181, (63, 2) = -0.1734071002604319e-15, (64, 1) = -2.9418644258574123, (64, 2) = -0.1734446464125922e-15, (65, 1) = -2.9410066857286434, (65, 2) = -0.1734822060076669e-15, (66, 1) = -2.9400420672456034, (66, 2) = -0.17352446176671971e-15, (67, 1) = -2.9390774487625633, (67, 2) = -0.5207002036233832e-15, (68, 1) = -2.9381128302795227, (68, 2) = -0.3472180486762057e-15, (69, 1) = -2.9371482117964827, (69, 2) = 0.3473026623297139e-15, (70, 1) = -2.9361835933134426, (70, 2) = -0.17369365502860198e-15, (71, 1) = -2.935218974830402, (71, 2) = 0.17373599593655003e-15, (72, 1) = -2.934254356347362, (72, 2) = 0.5213350616877389e-15, (73, 1) = -2.933289737864322, (73, 2) = -0.17382072891390294e-15, (74, 1) = -2.932325119381282, (74, 2) = .0, (75, 1) = -2.9313605008982417, (75, 2) = .0, (76, 1) = -2.930395882415201, (76, 2) = -0.3478959127835101e-15, (77, 1) = -2.929431263932161, (77, 2) = 0.17399039971637317e-15, (78, 1) = -2.928466645449121, (78, 2) = -0.5220985804070349e-15, (79, 1) = -2.9275020269660805, (79, 2) = -0.34815067531376457e-15, (80, 1) = -2.9265374084830404, (80, 2) = .0, (81, 1) = -2.9255727900000004, (81, 2) = 0.3483206880676687e-15, (82, 1) = -2.9246081715169603, (82, 2) = 0.3484057458080118e-15, (83, 1) = -2.92364355303392, (83, 2) = 0.5227362567147701e-15, (84, 1) = -2.9226789345508797, (84, 2) = -0.1742879820437983e-15, (85, 1) = -2.9217143160678396, (85, 2) = -0.1743305623278421e-15, (86, 1) = -2.9207496975847995, (86, 2) = 0.17437315976426613e-15, (87, 1) = -2.919785079101759, (87, 2) = .0, (88, 1) = -2.918820460618719, (88, 2) = -0.1744584061230997e-15, (89, 1) = -2.917855842135679, (89, 2) = -0.5235031651797936e-15, (90, 1) = -2.9168912236526383, (90, 2) = .0, (91, 1) = -2.9159266051695982, (91, 2) = -0.17458640448447792e-15, (92, 1) = -2.914961986686558, (92, 2) = 0.3492582099732283e-15, (93, 1) = -2.9139973682035176, (93, 2) = -0.17467182269160613e-15, (94, 1) = -2.9130327497204775, (94, 2) = 0.17471455760666398e-15, (95, 1) = -2.9120681312374375, (95, 2) = 0.17475730973899757e-15, (96, 1) = -2.911103512754397, (96, 2) = -0.3496001581916334e-15, (97, 1) = -2.910138894271357, (97, 2) = 0.5245285970529922e-15, (98, 1) = -2.9091678816708546, (98, 2) = 0.34977190660166464e-15, (99, 1) = -2.908196869070352, (99, 2) = .0, (100, 1) = -2.907225856469849, (100, 2) = 0.34994436193571535e-15, (101, 1) = -2.9062548438693465, (101, 2) = -0.3500306420661747e-15, (102, 1) = -2.9043128186683416, (102, 2) = -0.3502033073274869e-15, (103, 1) = -2.9023707934673366, (103, 2) = -0.3503761126873514e-15, (104, 1) = -2.901399780866834, (104, 2) = 0.17523128397049935e-15, (105, 1) = -2.9004287682663317, (105, 2) = -0.3505490582633923e-15, (106, 1) = -2.8994577556658294, (106, 2) = 0.35063558366923363e-15, (107, 1) = -2.8984867430653267, (107, 2) = 0.3507221441732236e-15, (108, 1) = -2.897515730464824, (108, 2) = 0.35080873979006193e-15, (109, 1) = -2.8965447178643218, (109, 2) = -0.35089537053444803e-15, (110, 1) = -2.8955737052638195, (110, 2) = 0.17549101821054021e-15, (111, 1) = -2.894602692663317, (111, 2) = 0.1755343687323284e-15, (112, 1) = -2.893631680062814, (112, 2) = -0.1755777368399371e-15, (113, 1) = -2.892660667462312, (113, 2) = -0.17562112254071432e-15, (114, 1) = -2.8916896548618096, (114, 2) = 0.17566452584200772e-15, (115, 1) = -2.890718642261307, (115, 2) = .0, (116, 1) = -2.8897476296608042, (116, 2) = -0.5272541558265948e-15, (117, 1) = -2.8887766170603015, (117, 2) = 0.17579484142245506e-15, (118, 1) = -2.887805604459799, (118, 2) = -0.35167663039856186e-15, (119, 1) = -2.8868345918592966, (119, 2) = 0.1758818066133545e-15, (120, 1) = -2.8858635792587943, (120, 2) = -0.1759253156720207e-15, (121, 1) = -2.8848925666582916, (121, 2) = 0.17596884238262402e-15, (122, 1) = -2.883921554057789, (122, 2) = -0.35202477350501646e-15, (123, 1) = -2.8829505414572862, (123, 2) = -0.1760559487890168e-15, (124, 1) = -2.8819795288567835, (124, 2) = -0.17609952849949254e-15, (125, 1) = -2.8810085162562813, (125, 2) = -0.3522862517825555e-15, (126, 1) = -2.880037503655779, (126, 2) = 0.5285602229151428e-15, (127, 1) = -2.8790664910552763, (127, 2) = 0.3524607474962865e-15, (128, 1) = -2.8781000935081655, (128, 2) = 0.7050952668916502e-15, (129, 1) = -2.877133695961055, (129, 2) = 0.17631727724036903e-15, (130, 1) = -2.876167298413945, (130, 2) = -0.17636075530774803e-15, (131, 1) = -2.875200900866834, (131, 2) = .0, (132, 1) = -2.8742345033197236, (132, 2) = .0, (133, 1) = -2.8732681057726133, (133, 2) = 0.17649129488176424e-15, (134, 1) = -2.8723017082255025, (134, 2) = .0, (135, 1) = -2.871335310678392, (135, 2) = -0.1765784091466743e-15, (136, 1) = -2.869402515584171, (136, 2) = -0.1766655937848698e-15, (137, 1) = -2.86746972048995, (137, 2) = -0.17675284885419526e-15, (138, 1) = -2.8665033229428394, (138, 2) = -0.5303895084558156e-15, (139, 1) = -2.865536925395729, (139, 2) = 0.1768401744124845e-15, (140, 1) = -2.8645705278486187, (140, 2) = 0.35376772728612097e-15, (141, 1) = -2.863604130301508, (141, 2) = -0.53078271155268e-15, (142, 1) = -2.862637732754397, (142, 2) = 0.5309138851296269e-15, (143, 1) = -2.8616713352072867, (143, 2) = -0.35403007445446525e-15, (144, 1) = -2.8607049376601763, (144, 2) = .0, (145, 1) = -2.8597385401130655, (145, 2) = -0.17710257459930127e-15, (146, 1) = -2.8587721425659547, (146, 2) = -0.17714636980179287e-15, (147, 1) = -2.8578057450188443, (147, 2) = -0.5315705480746572e-15, (148, 1) = -2.856839347471734, (148, 2) = .0, (149, 1) = -2.855872949924623, (149, 2) = -0.3545557231235198e-15, (150, 1) = -2.8549065523775123, (150, 2) = 0.354643455113296e-15, (151, 1) = -2.853940154830402, (151, 2) = 0.17736561126768445e-15, (152, 1) = -2.8529737572832916, (152, 2) = -0.17740951270208713e-15, (153, 1) = -2.852007359736181, (153, 2) = 0.3549068637341466e-15, (154, 1) = -2.8510409621890704, (154, 2) = 0.1774973687698591e-15, (155, 1) = -2.85007456464196, (155, 2) = .0, (156, 1) = -2.8491081670948493, (156, 2) = 0.17758529581769027e-15, (157, 1) = -2.848141769547739, (157, 2) = 0.17762928597716363e-15, (158, 1) = -2.8472457953140706, (158, 2) = 0.177670086357763e-15, (159, 1) = -2.846349821080402, (159, 2) = 0.1777109020157289e-15, (160, 1) = -2.8454538468467336, (160, 2) = -0.17775173295680784e-15, (161, 1) = -2.8445578726130654, (161, 2) = 0.3555851583734913e-15, (162, 1) = -2.843661898379397, (162, 2) = 0.17783344071128745e-15, (163, 1) = -2.842765924145729, (163, 2) = 0.35574863507235517e-15, (164, 1) = -2.8418699499120605, (164, 2) = .0, (165, 1) = -2.8409739756783923, (165, 2) = 0.1779561171099769e-15, (166, 1) = -2.840078001444724, (166, 2) = .0, (167, 1) = -2.8391820272110557, (167, 2) = 0.35607595590816793e-15, (168, 1) = -2.838286052977387, (168, 2) = .0, (169, 1) = -2.8373900787437187, (169, 2) = -0.356239800228854e-15, (170, 1) = -2.8364941045100505, (170, 2) = -0.17816088420253625e-15, (171, 1) = -2.8355981302763817, (171, 2) = .0, (172, 1) = -2.8347021560427135, (172, 2) = 0.1782428984233217e-15, (173, 1) = -2.833806181809045, (173, 2) = -0.35656785713494435e-15, (174, 1) = -2.832910207575377, (174, 2) = .0, (175, 1) = -2.8320142333417087, (175, 2) = 0.17836603495196796e-15, (176, 1) = -2.8311182591080404, (176, 2) = -0.35681422240756532e-15, (177, 1) = -2.830222284874372, (177, 2) = -0.35689640567257344e-15, (178, 1) = -2.829326310640704, (178, 2) = .0, (179, 1) = -2.8284303364070356, (179, 2) = -0.35706086453258455e-15, (180, 1) = -2.827534362173367, (180, 2) = .0, (181, 1) = -2.8266383879396986, (181, 2) = 0.3572254465756697e-15, (182, 1) = -2.8257424137060303, (182, 2) = .0, (183, 1) = -2.8248464394723616, (183, 2) = .0, (184, 1) = -2.8239504652386933, (184, 2) = 0.5362088262136301e-15, (185, 1) = -2.823054491005025, (185, 2) = -0.5363324708665847e-15, (186, 1) = -2.8221585167713568, (186, 2) = -0.35763744121086135e-15, (187, 1) = -2.8212625425376885, (187, 2) = .0, (188, 1) = -2.82036656830402, (188, 2) = 0.1789012275582189e-15, (189, 1) = -2.819470594070352, (189, 2) = 0.3578850084117687e-15, (190, 1) = -2.8185428646482413, (190, 2) = -0.17898526007027041e-15, (191, 1) = -2.8176151352261307, (191, 2) = -0.1790280325110895e-15, (192, 1) = -2.81668740580402, (192, 2) = 0.17907082153469127e-15, (193, 1) = -2.8157596763819095, (193, 2) = 0.17911362714742437e-15, (194, 1) = -2.814831946959799, (194, 2) = .0, (195, 1) = -2.8139042175376883, (195, 2) = .0, (196, 1) = -2.812976488115578, (196, 2) = 0.17924214358388055e-15, (197, 1) = -2.8120487586934675, (197, 2) = 0.17928501561660214e-15, (198, 1) = -2.811121029271357, (198, 2) = -0.1793279042701809e-15, (199, 1) = -2.8101932998492467, (199, 2) = 0.17937080955095843e-15, (200, 1) = -2.809265570427136, (200, 2) = -0.17941373146527522e-15, (201, 1) = -2.8083378410050255, (201, 2) = -0.17945667001947054e-15, (202, 1) = -2.807410111582915, (202, 2) = 0.1794996252198824e-15, (203, 1) = -2.8064823821608043, (203, 2) = 0.17954259707284763e-15, (204, 1) = -2.8055546527386936, (204, 2) = -0.17958558558470176e-15, (205, 1) = -2.804626923316583, (205, 2) = -0.1796285907617791e-15, (206, 1) = -2.8036991938944724, (206, 2) = .0, (207, 1) = -2.802771464472362, (207, 2) = .0, (208, 1) = -2.801843735050251, (208, 2) = -0.5392731190430244e-15, (209, 1) = -2.8009160056281406, (209, 2) = -0.17980077824896295e-15, (210, 1) = -2.79998827620603, (210, 2) = 0.3596877336942536e-15, (211, 1) = -2.7990605467839194, (211, 2) = 0.17988697214849298e-15, (212, 1) = -2.798132817361809, (212, 2) = -0.3598601883187735e-15, (213, 1) = -2.7972050879396986, (213, 2) = .0, (214, 1) = -2.796277358517588, (214, 2) = -0.18001638833505147e-15, (215, 1) = -2.795349629095478, (215, 2) = .0, (216, 1) = -2.794421899673367, (216, 2) = .0, (217, 1) = -2.7934941702512566, (217, 2) = -0.18014595507806002e-15, (218, 1) = -2.792566440829146, (218, 2) = 0.36037835495774915e-15, (219, 1) = -2.7916387114070353, (219, 2) = 0.18023241663345568e-15, (220, 1) = -2.7907109819849247, (220, 2) = -0.3605513450962351e-15, (221, 1) = -2.789783252562814, (221, 2) = .0, (222, 1) = -2.788823793467337, (222, 2) = .0, (223, 1) = -2.7878643343718594, (223, 2) = -0.3608170075984219e-15, (224, 1) = -2.786904875276382, (224, 2) = -0.36090662002223266e-15, (225, 1) = -2.7859454161809047, (225, 2) = 0.18049813418358176e-15, (226, 1) = -2.784985957085427, (226, 2) = 0.36108595264716403e-15, (227, 1) = -2.7840264979899496, (227, 2) = .0, (228, 1) = -2.7830670388944725, (228, 2) = -0.1806327145340773e-15, (229, 1) = -2.782107579798995, (229, 2) = 0.18067761061851327e-15, (230, 1) = -2.7811481207035174, (230, 2) = 0.18072252469836577e-15, (231, 1) = -2.7801886616080402, (231, 2) = -0.18076745678060083e-15, (232, 1) = -2.7792292025125627, (232, 2) = 0.3616248137443657e-15, (233, 1) = -2.778269743417085, (233, 2) = -0.36171474996014847e-15, (234, 1) = -2.777310284321608, (234, 2) = 0.18090236111123575e-15, (235, 1) = -2.7763508252261304, (235, 2) = -0.18094736527262623e-15, (236, 1) = -2.775391366130653, (236, 2) = .0, (237, 1) = -2.7744319070351757, (237, 2) = 0.18103742771392059e-15, (238, 1) = -2.7734724479396986, (238, 2) = -0.18108248600773297e-15, (239, 1) = -2.772512988844221, (239, 2) = -0.36225512471918305e-15, (240, 1) = -2.7715535297487435, (240, 2) = .0, (241, 1) = -2.7705940706532663, (241, 2) = .0, (242, 1) = -2.7686751524623117, (242, 2) = .0, (243, 1) = -2.766756234271357, (243, 2) = .0, (244, 1) = -2.76579677517588, (244, 2) = 0.1814436030314179e-15, (245, 1) = -2.7648373160804023, (245, 2) = -0.36297764819533963e-15, (246, 1) = -2.7638778569849247, (246, 2) = .0, (247, 1) = -2.7629183978894476, (247, 2) = -0.18157932059867486e-15, (248, 1) = -2.76195893879397, (248, 2) = .0, (249, 1) = -2.7609994796984925, (249, 2) = 0.36333977927443635e-15, (250, 1) = -2.7600400206030153, (250, 2) = -0.18171520137538525e-15, (251, 1) = -2.7590805615075378, (251, 2) = -0.5452815938061456e-15, (252, 1) = -2.758124179409548, (252, 2) = .0, (253, 1) = -2.757167797311558, (253, 2) = -0.18185095451052506e-15, (254, 1) = -2.756211415213568, (254, 2) = -0.18189619321723014e-15, (255, 1) = -2.755255033115578, (255, 2) = -0.18194144999026813e-15, (256, 1) = -2.7542986510175878, (256, 2) = -0.18198672483648614e-15, (257, 1) = -2.753342268919598, (257, 2) = .0, (258, 1) = -2.7523858868216085, (258, 2) = -0.18207732877583946e-15, (259, 1) = -2.7514295047236184, (259, 2) = 0.1821226578826582e-15, (260, 1) = -2.7504731226256283, (260, 2) = -0.36433601018004734e-15, (261, 1) = -2.749516740527638, (261, 2) = 0.1822133704047721e-15, (262, 1) = -2.748560358429648, (262, 2) = -0.36451750766747493e-15, (263, 1) = -2.7476039763316584, (263, 2) = .0, (264, 1) = -2.7466475942336688, (264, 2) = .0, (265, 1) = -2.7456912121356787, (265, 2) = -0.36479002574848597e-15, (266, 1) = -2.7447348300376886, (266, 2) = 0.5473214064851178e-15, (267, 1) = -2.7437784479396985, (267, 2) = .0, (268, 1) = -2.7428220658417084, (268, 2) = -0.182531435188514e-15, (269, 1) = -2.7418656837437183, (269, 2) = 0.36515389121632936e-15, (270, 1) = -2.740909301645728, (270, 2) = 0.3652449483932481e-15, (271, 1) = -2.7399529195477386, (271, 2) = 0.1826680209607058e-15, (272, 1) = -2.738996537449749, (272, 2) = 0.18271358590722116e-15, (273, 1) = -2.738040155351759, (273, 2) = .0, (274, 1) = -2.7370837732537687, (274, 2) = .0, (275, 1) = -2.7361273911557786, (275, 2) = 0.18285038990944698e-15, (276, 1) = -2.732301862763819, (276, 2) = 0.1830330502126225e-15, (277, 1) = -2.728476334371859, (277, 2) = 0.18321600230515695e-15, (278, 1) = -2.727492577829774, (278, 2) = .0, (279, 1) = -2.7265088212876885, (279, 2) = -0.36662042086233053e-15, (280, 1) = -2.725525064745603, (280, 2) = .0, (281, 1) = -2.7245413082035173, (281, 2) = .0, (282, 1) = -2.7235575516614317, (282, 2) = -0.366903335365733e-15, (283, 1) = -2.7225737951193465, (283, 2) = -0.18349885881296602e-15, (284, 1) = -2.7215900385772613, (284, 2) = .0, (285, 1) = -2.7206062820351757, (285, 2) = -0.3671865983733038e-15, (286, 1) = -2.71962252549309, (286, 2) = 0.18364054844495743e-15, (287, 1) = -2.718638768951005, (287, 2) = 0.36737563418809145e-15, (288, 1) = -2.71765501240892, (288, 2) = -0.36747021028253783e-15, (289, 1) = -2.7166712558668342, (289, 2) = .0, (290, 1) = -2.7156874993247486, (290, 2) = 0.55148921837854e-15, (291, 1) = -2.7147037427826635, (291, 2) = -0.367754171490447e-15, (292, 1) = -2.7137199862405783, (292, 2) = -0.1839244514584466e-15, (293, 1) = -2.7127362296984927, (293, 2) = 0.367943673213039e-15, (294, 1) = -2.711752473156407, (294, 2) = 0.18401924119677582e-15, (295, 1) = -2.710768716614322, (295, 2) = -0.36813333047309243e-15, (296, 1) = -2.709784960072237, (296, 2) = -0.18411410873315806e-15, (297, 1) = -2.708801203530151, (297, 2) = .0, (298, 1) = -2.7078174469880656, (298, 2) = -0.18420905412620043e-15, (299, 1) = -2.70683369044598, (299, 2) = -0.18425655603726987e-15, (300, 1) = -2.7058499339038944, (300, 2) = -0.36860815486891777e-15, (301, 1) = -2.7048661773618092, (301, 2) = -0.36870323665015765e-15, (302, 1) = -2.703882420819724, (302, 2) = .0, (303, 1) = -2.7028986642776385, (303, 2) = 0.5533402758475237e-15, (304, 1) = -2.701914907735553, (304, 2) = -0.1844943580305903e-15, (305, 1) = -2.7009311511934673, (305, 2) = -0.18454197696798346e-15, (306, 1) = -2.6999473946513817, (306, 2) = 0.18458961543531576e-15, (307, 1) = -2.6989636381092965, (307, 2) = .0, (308, 1) = -2.6979798815672114, (308, 2) = 0.36936990197792184e-15, (309, 1) = -2.6969961250251258, (309, 2) = .0, (310, 1) = -2.696129631727387, (310, 2) = .0, (311, 1) = -2.6952631384296484, (311, 2) = 0.18481671893509234e-15, (312, 1) = -2.69439664513191, (312, 2) = 0.36971755426267234e-15, (313, 1) = -2.693530151834171, (313, 2) = 0.18490085051662062e-15, (314, 1) = -2.6917971652386936, (314, 2) = 0.1849850428741782e-15, (315, 1) = -2.6900641786432162, (315, 2) = 0.18506929604747803e-15, (316, 1) = -2.6891976853454773, (316, 2) = 0.18511144545243226e-15, (317, 1) = -2.688331192047739, (317, 2) = .0, (318, 1) = -2.6874646987500004, (318, 2) = -0.18519578992373258e-15, (319, 1) = -2.6865982054522615, (319, 2) = 0.18523798499998562e-15, (320, 1) = -2.6857317121545226, (320, 2) = 0.37056039061981633e-15, (321, 1) = -2.684865218856784, (321, 2) = -0.37064484171689636e-15, (322, 1) = -2.6839987255590456, (322, 2) = .0, (323, 1) = -2.6831322322613067, (323, 2) = 0.3708138353823235e-15, (324, 1) = -2.682265738963568, (324, 2) = .0, (325, 1) = -2.6813992456658293, (325, 2) = 0.3709829510753326e-15, (326, 1) = -2.680532752368091, (326, 2) = .0, (327, 1) = -2.679666259070352, (327, 2) = -0.1855760944374662e-15, (328, 1) = -2.678799765772613, (328, 2) = -0.37123685358937443e-15, (329, 1) = -2.6779332724748746, (329, 2) = .0, (330, 1) = -2.677066779177136, (330, 2) = 0.18570313734842222e-15, (331, 1) = -2.676200285879397, (331, 2) = -0.18574551555478973e-15, (332, 1) = -2.6753337925816583, (332, 2) = .0, (333, 1) = -2.67446729928392, (333, 2) = .0, (334, 1) = -2.6736008059861813, (334, 2) = -0.37174548390192993e-15, (335, 1) = -2.6727343126884424, (335, 2) = -0.18591518135844328e-15, (336, 1) = -2.6718678193907035, (336, 2) = .0, (337, 1) = -2.671001326092965, (337, 2) = 0.18600010611601735e-15, (338, 1) = -2.6701348327952266, (338, 2) = .0, (339, 1) = -2.6692683394974877, (339, 2) = .0, (340, 1) = -2.6380534203015076, (340, 2) = .0, (341, 1) = -2.6067103296482412, (341, 2) = .0, (342, 1) = -2.5765054540703516, (342, 2) = .0, (343, 1) = -2.5756483002983668, (343, 2) = -0.19076840315949823e-15, (344, 1) = -2.5747911465263815, (344, 2) = -0.3816242550950504e-15, (345, 1) = -2.5739339927543967, (345, 2) = .0, (346, 1) = -2.573076838982412, (346, 2) = .0, (347, 1) = -2.572219685210427, (347, 2) = -0.28641509068682744e-15, (348, 1) = -2.5713625314384423, (348, 2) = -0.954935901235301e-16, (349, 1) = -2.570505377666457, (349, 2) = 0.9551549111545099e-16, (350, 1) = -2.5696482238944722, (350, 2) = 0.9553739987357744e-16, (351, 1) = -2.5687910701224874, (351, 2) = -0.5733558984006798e-15, (352, 1) = -2.567933916350502, (352, 2) = -0.19116248139452112e-15, (353, 1) = -2.5670767625785174, (353, 2) = -0.1912063455344389e-15, (354, 1) = -2.5662196088065325, (354, 2) = -0.9562511261218829e-16, (355, 1) = -2.5653624550345477, (355, 2) = 0.573882361406182e-15, (356, 1) = -2.564505301262563, (356, 2) = 0.2870070469078209e-15, (357, 1) = -2.5636481474905777, (357, 2) = 0.28707293645733297e-15, (358, 1) = -2.562790993718593, (358, 2) = 0.9571294978606678e-16, (359, 1) = -2.561933839946608, (359, 2) = -0.38293971415598723e-15, (360, 1) = -2.561076686174623, (360, 2) = 0.9575691508008838e-16, (361, 1) = -2.560219532402638, (361, 2) = -0.9577890941152688e-16, (362, 1) = -2.559362378630653, (362, 2) = -0.9580091153549586e-16, (363, 1) = -2.5585052248586684, (363, 2) = -0.9582292145417696e-16, (364, 1) = -2.5576480710866836, (364, 2) = 0.4792246958487499e-15, (365, 1) = -2.5567909173146983, (365, 2) = 0.9586696468439277e-16, (366, 1) = -2.5559337635427135, (366, 2) = 0.2876669940008438e-15, (367, 1) = -2.5550766097707287, (367, 2) = 0.1918220782391791e-15, (368, 1) = -2.5542194559987434, (368, 2) = 0.28779926413346933e-15, (369, 1) = -2.5533623022267586, (369, 2) = 0.9595514477715212e-16, (370, 1) = -2.552505148454774, (370, 2) = -0.1919544186394897e-15, (371, 1) = -2.550790840910804, (371, 2) = -0.96021361843385e-16, (372, 1) = -2.549076533366834, (372, 2) = .0, (373, 1) = -2.548057294626256, (373, 2) = -0.2882754895795086e-15, (374, 1) = -2.547038055885678, (374, 2) = 0.3844725005949087e-15, (375, 1) = -2.5460188171451, (375, 2) = -0.9614443150301223e-16, (376, 1) = -2.5449995784045223, (376, 2) = -0.9617074892630896e-16, (377, 1) = -2.5439803396639444, (377, 2) = -0.2885912322666931e-15, (378, 1) = -2.5429611009233666, (378, 2) = -0.4811170849719406e-15, (379, 1) = -2.5419418621827887, (379, 2) = .0, (380, 1) = -2.540922623442211, (380, 2) = .0, (381, 1) = -2.539903384701633, (381, 2) = .0, (382, 1) = -2.538884145961055, (382, 2) = 0.9632888611741792e-16, (383, 1) = -2.5378649072204773, (383, 2) = 0.9635528112475323e-16, (384, 1) = -2.5368456684798995, (384, 2) = -0.19276337445979282e-15, (385, 1) = -2.5358264297393216, (385, 2) = 0.9640810443642858e-16, (386, 1) = -2.5348071909987437, (386, 2) = .0, (387, 1) = -2.533787952258166, (387, 2) = .0, (388, 1) = -2.532768713517588, (388, 2) = 0.4824371135005433e-15, (389, 1) = -2.53174947477701, (389, 2) = -0.19302776869585102e-15, (390, 1) = -2.5307302360364323, (390, 2) = 0.3861614284598993e-15, (391, 1) = -2.5297109972958545, (391, 2) = -0.965668410048127e-16, (392, 1) = -2.5286917585552766, (392, 2) = -0.19318667204198198e-15, (393, 1) = -2.5276725198146988, (393, 2) = 0.1932396843341147e-15, (394, 1) = -2.526653281074121, (394, 2) = -0.28993907833966513e-15, (395, 1) = -2.525634042333543, (395, 2) = .0, (396, 1) = -2.524614803592965, (396, 2) = 0.19339885483999333e-15, (397, 1) = -2.5235955648523873, (397, 2) = -0.9672597812100573e-16, (398, 1) = -2.5225763261118095, (398, 2) = 0.9675253996957657e-16, (399, 1) = -2.5215570873712316, (399, 2) = 0.19355822593846185e-15, (400, 1) = -2.5205378486306538, (400, 2) = 0.2904170913704586e-15, (401, 1) = -2.519518609890076, (401, 2) = 0.968322924358554e-16, (402, 1) = -2.518499371149498, (402, 2) = 0.29057669672954133e-15, (403, 1) = -2.51748013240892, (403, 2) = -0.2906565496468964e-15, (404, 1) = -2.516460893668342, (404, 2) = -0.9691214535671028e-16, (405, 1) = -2.5155974647613064, (405, 2) = -0.1938694243809906e-15, (406, 1) = -2.5147340358542714, (406, 2) = 0.9695728704386608e-16, (407, 1) = -2.5138706069472363, (407, 2) = 0.9697986991894269e-16, (408, 1) = -2.5130071780402012, (408, 2) = 0.38800984327137136e-15, (409, 1) = -2.512143749133166, (409, 2) = -0.9702505974268198e-16, (410, 1) = -2.5112803202261307, (410, 2) = 0.38819066678229265e-15, (411, 1) = -2.510416891319095, (411, 2) = -0.9707028167862716e-16, (412, 1) = -2.50955346241206, (412, 2) = 0.970929046939523e-16, (413, 1) = -2.508690033505025, (413, 2) = 0.38846214297461877e-15, (414, 1) = -2.50782660459799, (414, 2) = .0, (415, 1) = -2.506963175690955, (415, 2) = 0.19432164390920672e-15, (416, 1) = -2.5060997467839194, (416, 2) = -0.29155043136014973e-15, (417, 1) = -2.505236317876884, (417, 2) = .0, (418, 1) = -2.504372888969849, (418, 2) = -0.3889152463254799e-15, (419, 1) = -2.503509460062814, (419, 2) = 0.19450298176285877e-15, (420, 1) = -2.5026460311557788, (420, 2) = -0.1945483564610832e-15, (421, 1) = -2.5017826022487437, (421, 2) = .0, (422, 1) = -2.5009191733417087, (422, 2) = -0.9731957708426971e-16, (423, 1) = -2.5000557444346736, (423, 2) = 0.9734228859305206e-16, (424, 1) = -2.499192315527638, (424, 2) = 0.19473001631844062e-15, (425, 1) = -2.4983288866206026, (425, 2) = 0.3895509431394062e-15, (426, 1) = -2.4974654577135675, (426, 2) = 0.9741047147202047e-16, (427, 1) = -2.4966020288065325, (427, 2) = -0.2922996456683979e-15, (428, 1) = -2.4957385998994974, (428, 2) = -0.9745596703925785e-16, (429, 1) = -2.4948751709924624, (429, 2) = -0.9747872692346334e-16, (430, 1) = -2.4940117420854273, (430, 2) = 0.9750149487748058e-16, (431, 1) = -2.4931483131783923, (431, 2) = .0, (432, 1) = -2.4922848842713567, (432, 2) = .0, (433, 1) = -2.4914214553643212, (433, 2) = -0.9756984717901327e-16, (434, 1) = -2.490558026457286, (434, 2) = 0.3903705897315014e-15, (435, 1) = -2.489694597550251, (435, 2) = 0.9761545576683555e-16, (436, 1) = -2.488831168643216, (436, 2) = 0.6834679052806047e-15, (437, 1) = -2.487826795562186, (437, 2) = 0.29299446981154127e-15, (438, 1) = -2.486822422481156, (438, 2) = 0.1953827706004078e-15, (439, 1) = -2.485818049400126, (439, 2) = 0.19543591655045426e-15, (440, 1) = -2.4848136763190953, (440, 2) = 0.4887227109939594e-15, (441, 1) = -2.483809303238065, (441, 2) = 0.5866268224446115e-15, (442, 1) = -2.4828049301570347, (442, 2) = -0.2933932287130688e-15, (443, 1) = -2.4818005570760047, (443, 2) = 0.9782435969274914e-16, (444, 1) = -2.4807961839949746, (444, 2) = -0.39140394976988014e-15, (445, 1) = -2.4797918109139445, (445, 2) = -0.978776261567036e-16, (446, 1) = -2.4787874378329144, (446, 2) = -0.2937128275158891e-15, (447, 1) = -2.4777830647518844, (447, 2) = 0.29379280947427013e-15, (448, 1) = -2.4767786916708543, (448, 2) = -0.39183043247301945e-15, (449, 1) = -2.475774318589824, (449, 2) = -0.39193716288915774e-15, (450, 1) = -2.474769945508794, (450, 2) = -0.19602196861337505e-15, (451, 1) = -2.473765572427764, (451, 2) = 0.3921507554984189e-15, (452, 1) = -2.4727611993467336, (452, 2) = -0.19612880885838334e-15, (453, 1) = -2.471756826265703, (453, 2) = -0.294273392920782e-15, (454, 1) = -2.470752453184673, (454, 2) = -0.9811786851095252e-16, (455, 1) = -2.469748080103643, (455, 2) = 0.2944338511332089e-15, (456, 1) = -2.468743707022613, (456, 2) = -0.1963427531541523e-15, (457, 1) = -2.4677393339415827, (457, 2) = 0.9819814711209781e-16, (458, 1) = -2.4667349608605527, (458, 2) = 0.39289971461035516e-15, (459, 1) = -2.4657305877795226, (459, 2) = 0.1965034424033295e-15, (460, 1) = -2.4647262146984925, (460, 2) = -0.9827852476243637e-16, (461, 1) = -2.4627174685364324, (461, 2) = .0, (462, 1) = -2.4607087223743718, (462, 2) = 0.9838584918451468e-16, (463, 1) = -2.4597043492933413, (463, 2) = -0.29523812355073875e-15, (464, 1) = -2.458699976212311, (464, 2) = -0.9843957754623024e-16, (465, 1) = -2.457695603131281, (465, 2) = 0.39386583310216538e-15, (466, 1) = -2.456691230050251, (466, 2) = -0.19698670008249836e-15, (467, 1) = -2.45580218968907, (467, 2) = -0.2955514890635415e-15, (468, 1) = -2.454913149327889, (468, 2) = 0.9854098465292685e-16, (469, 1) = -2.454024108966708, (469, 2) = 0.1971296298772136e-15, (470, 1) = -2.4531350686055275, (470, 2) = 0.9858865388033573e-16, (471, 1) = -2.452246028244347, (471, 2) = -0.1972250029604516e-15, (472, 1) = -2.451356987883166, (472, 2) = 0.4931817887019293e-15, (473, 1) = -2.450467947521985, (473, 2) = -0.29598066798876467e-15, (474, 1) = -2.449578907160804, (474, 2) = .0, (475, 1) = -2.448689866799623, (475, 2) = 0.3948319140141032e-15, (476, 1) = -2.447800826438442, (476, 2) = 0.19746373885157827e-15, (477, 1) = -2.446911786077261, (477, 2) = 0.9875576901881766e-16, (478, 1) = -2.44602274571608, (478, 2) = 0.4938983864235027e-15, (479, 1) = -2.445133705354899, (479, 2) = 0.9880359422552348e-16, (480, 1) = -2.444244664993718, (480, 2) = -0.19765503968673796e-15, (481, 1) = -2.443355624632537, (481, 2) = 0.9885145414031616e-16, (482, 1) = -2.4424665842713567, (482, 2) = -0.1977507942368815e-15, (483, 1) = -2.441577543910176, (483, 2) = -0.19779869755963026e-15, (484, 1) = -2.440688503548995, (484, 2) = 0.1978466182530167e-15, (485, 1) = -2.439799463187814, (485, 2) = -0.9894727816058599e-16, (486, 1) = -2.438910422826633, (486, 2) = -0.39588502353644107e-15, (487, 1) = -2.438021382465452, (487, 2) = 0.9899524229913999e-16, (488, 1) = -2.437132342104271, (488, 2) = -0.9901923740773056e-16, (489, 1) = -2.4362433017430902, (489, 2) = 0.990432412119339e-16, (490, 1) = -2.4353542613819092, (490, 2) = -0.4953362685689927e-15, (491, 1) = -2.4344652210207283, (491, 2) = 0.29727382474610867e-15, (492, 1) = -2.4335761806595473, (492, 2) = 0.19823060963737707e-15, (493, 1) = -2.4326871402983663, (493, 2) = 0.3965573737031744e-15, (494, 1) = -2.4317980999371858, (494, 2) = .0, (495, 1) = -2.4309090595760052, (495, 2) = 0.39674978703798835e-15, (496, 1) = -2.4300200192148242, (496, 2) = 0.19842302298030869e-15, (497, 1) = -2.4291309788536433, (497, 2) = 0.9923558493271527e-16, (498, 1) = -2.4282419384924623, (498, 2) = .0, (499, 1) = -2.42726652031093, (499, 2) = -0.29785829717723247e-15, (500, 1) = -2.426291102129397, (500, 2) = 0.9931254152348676e-16, (501, 1) = -2.425315683947864, (501, 2) = 0.9933899448508224e-16, (502, 1) = -2.4243402657663315, (502, 2) = .0, (503, 1) = -2.423364847584799, (503, 2) = 0.198783863820843e-15, (504, 1) = -2.422389429403266, (504, 2) = -0.1988368327588944e-15, (505, 1) = -2.4214140112217333, (505, 2) = .0, (506, 1) = -2.420438593040201, (506, 2) = -0.19894283368675255e-15, (507, 1) = -2.4194631748586684, (507, 2) = 0.2984937985305904e-15, (508, 1) = -2.4184877566771354, (508, 2) = 0.995244593593018e-16, (509, 1) = -2.4175123384956025, (509, 2) = 0.9955099639330328e-16, (510, 1) = -2.41653692031407, (510, 2) = -0.4978877197407067e-15, (511, 1) = -2.4155615021325376, (511, 2) = -0.29881230607925224e-15, (512, 1) = -2.414586083951005, (512, 2) = -0.19926134126145506e-15, (513, 1) = -2.4136106657694727, (513, 2) = 0.9965724976366245e-16, (514, 1) = -2.41263524758794, (514, 2) = 0.39873535771123007e-15, (515, 1) = -2.411659829406407, (515, 2) = 0.9971043962574264e-16, (516, 1) = -2.4106844112248744, (516, 2) = 0.19947410072008472e-15, (517, 1) = -2.409708993043342, (517, 2) = 0.19952734326655154e-15, (518, 1) = -2.4087335748618095, (518, 2) = 0.9979030344800654e-16, (519, 1) = -2.407758156680277, (519, 2) = 0.19963389161358569e-15, (520, 1) = -2.406782738498744, (520, 2) = 0.9984359871218741e-16, (521, 1) = -2.4058073203172112, (521, 2) = -0.4993513108336871e-15, (522, 1) = -2.4048319021356788, (522, 2) = -0.9989693617298456e-16, (523, 1) = -2.4038564839541463, (523, 2) = -0.19984724146692993e-15, (524, 1) = -2.4028810657726134, (524, 2) = 0.4997515792535463e-15, (525, 1) = -2.4019056475910805, (525, 2) = -0.29993106458172734e-15, (526, 1) = -2.400930229409548, (526, 2) = .0, (527, 1) = -2.3999548112280156, (527, 2) = -0.10003046456824765e-15, (528, 1) = -2.3989793930464827, (528, 2) = -0.40022880775096684e-15, (529, 1) = -2.3980039748649498, (529, 2) = 0.2001678997531374e-15, (530, 1) = -2.3970285566834173, (530, 2) = -0.20022141677445107e-15, (531, 1) = -2.3960997279082914, (531, 2) = .0, (532, 1) = -2.395170899133166, (532, 2) = .0, (533, 1) = -2.3942420703580405, (533, 2) = 0.10018720793692287e-15, (534, 1) = -2.3933132415829146, (534, 2) = -0.10021272697344301e-15, (535, 1) = -2.392384412807789, (535, 2) = .0, (536, 1) = -2.3914555840326637, (536, 2) = -0.3007913815176433e-15, (537, 1) = -2.3905267552575378, (537, 2) = -0.10028934167271572e-15, (538, 1) = -2.3895979264824123, (538, 2) = 0.30094469732835817e-15, (539, 1) = -2.388669097707287, (539, 2) = -0.20068093230307697e-15, (540, 1) = -2.387740268932161, (540, 2) = -0.702562299607569e-15, (541, 1) = -2.3868114401570355, (541, 2) = 0.4015665162407382e-15, (542, 1) = -2.38588261138191, (542, 2) = 0.10041722493094686e-15, (543, 1) = -2.384953782606784, (543, 2) = 0.3013284912463861e-15, (544, 1) = -2.3840249538316587, (544, 2) = 0.10046844551581898e-15, (545, 1) = -2.3830961250565332, (545, 2) = 0.10049407023410172e-15, (546, 1) = -2.3821672962814073, (546, 2) = -0.10051970457238944e-15, (547, 1) = -2.3812384675062814, (547, 2) = -0.20109069706551277e-15, (548, 1) = -2.380309638731156, (548, 2) = -0.5028550105863595e-15, (549, 1) = -2.3793808099560305, (549, 2) = -0.20119333065600087e-15, (550, 1) = -2.3784519811809046, (550, 2) = .0, (551, 1) = -2.3775231524057787, (551, 2) = -0.6038881238179768e-15, (552, 1) = -2.3765943236306533, (552, 2) = -0.20134742547606802e-15, (553, 1) = -2.375665494855528, (553, 2) = -0.10069941447415969e-15, (554, 1) = -2.374736666080402, (554, 2) = 0.5036256292337303e-15, (555, 1) = -2.373807837305276, (555, 2) = 0.10075084685782764e-15, (556, 1) = -2.3728790085301505, (556, 2) = -0.6046594650566036e-15, (557, 1) = -2.371950179755025, (557, 2) = .0, (558, 1) = -2.371021350979899, (558, 2) = -0.20165613548462724e-15, (559, 1) = -2.3700925222047737, (559, 2) = .0, (560, 1) = -2.3691636934296483, (560, 2) = .0, (561, 1) = -2.3682348646545224, (561, 2) = 0.30271612633804696e-15, (562, 1) = -2.367306035879397, (562, 2) = -0.10093116398310662e-15, (563, 1) = -2.3663369004930903, (563, 2) = 0.3028742457249567e-15, (564, 1) = -2.365367765106784, (564, 2) = -0.2019700206929676e-15, (565, 1) = -2.3643986297204775, (565, 2) = -0.40404779719941617e-15, (566, 1) = -2.363429494334171, (566, 2) = 0.4041555950827052e-15, (567, 1) = -2.3624603589478643, (567, 2) = -0.10106585876119107e-15, (568, 1) = -2.3614912235615577, (568, 2) = -0.1010928292736326e-15, (569, 1) = -2.360522088175251, (569, 2) = -0.2022396206204581e-15, (570, 1) = -2.3595529527889445, (570, 2) = 0.10114680187320226e-15, (571, 1) = -2.358583817402638, (571, 2) = 0.10117380396476797e-15, (572, 1) = -2.3576146820163313, (572, 2) = -0.6072048995228127e-15, (573, 1) = -2.356645546630025, (573, 2) = -0.30368351922752383e-15, (574, 1) = -2.3556764112437185, (574, 2) = 0.10125487343308223e-15, (575, 1) = -2.354707275857412, (575, 2) = -0.10128191766104885e-15, (576, 1) = -2.3537381404711057, (576, 2) = 0.10130897242859198e-15, (577, 1) = -2.352769005084799, (577, 2) = -0.1013360377378895e-15, (578, 1) = -2.3517998696984925, (578, 2) = -0.3040893407733385e-15, (579, 1) = -2.350830734312186, (579, 2) = -0.40556079996170857e-15, (580, 1) = -2.3498615989258793, (580, 2) = 0.5070864846899551e-15, (581, 1) = -2.3488924635395727, (581, 2) = 0.20288880887191367e-15, (582, 1) = -2.347923328153266, (582, 2) = -0.10147152248647028e-15, (583, 1) = -2.345985057380653, (583, 2) = -0.10152579025369115e-15, (584, 1) = -2.34404678660804, (584, 2) = -0.1015801002566905e-15, (585, 1) = -2.3430776512217335, (585, 2) = -0.20321454220380524e-15, (586, 1) = -2.3421085158354273, (586, 2) = 0.10163445251240087e-15, (587, 1) = -2.3411393804491207, (587, 2) = .0, (588, 1) = -2.340170245062814, (588, 2) = 0.5084442351882487e-15, (589, 1) = -2.3392011096765075, (589, 2) = 0.3051481804697425e-15, (590, 1) = -2.338231974290201, (590, 2) = 0.20348656769831796e-15, (591, 1) = -2.3372628389038943, (591, 2) = .0, (592, 1) = -2.3362937035175877, (592, 2) = -0.10179776296354429e-15, (593, 1) = -2.335403734701633, (593, 2) = -0.10182279155590261e-15, (594, 1) = -2.3345137658856783, (594, 2) = -0.40739131628723183e-15, (595, 1) = -2.3336237970697233, (595, 2) = -0.20374575102569212e-15, (596, 1) = -2.332733828253769, (596, 2) = 0.10189793088059777e-15, (597, 1) = -2.331843859437814, (597, 2) = 0.10192299517663919e-15, (598, 1) = -2.330953890621859, (598, 2) = -0.20389613680508314e-15, (599, 1) = -2.3300639218059045, (599, 2) = 0.20394630111974261e-15, (600, 1) = -2.3291739529899496, (600, 2) = -0.10199824165018998e-15, (601, 1) = -2.3282839841739946, (601, 2) = 0.20404668335010845e-15, (602, 1) = -2.32739401535804, (602, 2) = -0.2040969012720317e-15, (603, 1) = -2.326504046542085, (603, 2) = -0.5103678426731089e-15, (604, 1) = -2.3256140777261303, (604, 2) = -0.10209869537241396e-15, (605, 1) = -2.324724108910176, (605, 2) = .0, (606, 1) = -2.323834140094221, (606, 2) = -0.5107448793585027e-15, (607, 1) = -2.322944171278266, (607, 2) = -0.20434825907250845e-15, (608, 1) = -2.3220542024623114, (608, 2) = 0.10219929214611281e-15, (609, 1) = -2.321164233646357, (609, 2) = -0.30667339110838053e-15, (610, 1) = -2.320274264830402, (610, 2) = -0.4089985768312346e-15, (611, 1) = -2.319384296014447, (611, 2) = -0.10227483366266542e-15, (612, 1) = -2.3184943271984926, (612, 2) = 0.30690009620659825e-15, (613, 1) = -2.3176043583825376, (613, 2) = -0.30697571828372364e-15, (614, 1) = -2.3167143895665827, (614, 2) = -0.30705136722384877e-15, (615, 1) = -2.315824420750628, (615, 2) = 0.2047513620209568e-15, (616, 1) = -2.3149344519346733, (616, 2) = -0.20480183047395257e-15, (617, 1) = -2.3140444831187184, (617, 2) = -0.20485231684450722e-15, (618, 1) = -2.313154514302764, (618, 2) = -0.5122570528389109e-15, (619, 1) = -2.312264545486809, (619, 2) = -0.1024766716750288e-15, (620, 1) = -2.311374576670854, (620, 2) = 0.20500388349091017e-15, (621, 1) = -2.3104846078548995, (621, 2) = -0.10252722078051754e-15, (622, 1) = -2.3095946390389446, (622, 2) = 0.20510501756333498e-15, (623, 1) = -2.3087046702229896, (623, 2) = -0.30773341725105344e-15, (624, 1) = -2.307814701407035, (624, 2) = 0.10260311168800948e-15, (625, 1) = -2.306854749808417, (625, 2) = 0.10263041761675781e-15, (626, 1) = -2.305894798209799, (626, 2) = 0.10265773398395816e-15, (627, 1) = -2.304934846611181, (627, 2) = -0.10268506079139855e-15, (628, 1) = -2.303974895012563, (628, 2) = 0.20542479608171972e-15, (629, 1) = -2.303014943413945, (629, 2) = 0.10273974573411591e-15, (630, 1) = -2.302054991815327, (630, 2) = 0.2055342077458668e-15, (631, 1) = -2.3010950402167087, (631, 2) = 0.3083834173772157e-15, (632, 1) = -2.3001350886180907, (632, 2) = -0.10282185149428375e-15, (633, 1) = -2.2991751370194726, (633, 2) = -0.20569848196062826e-15, (634, 1) = -2.2982151854208546, (634, 2) = .0, (635, 1) = -2.2972552338222365, (635, 2) = 0.2058081026235504e-15, (636, 1) = -2.2962952822236185, (636, 2) = -0.4117258886426405e-15, (637, 1) = -2.2953353306250004, (637, 2) = .0, (638, 1) = -2.2943753790263823, (638, 2) = -0.10298634523331998e-15, (639, 1) = -2.293415427427764, (639, 2) = -0.20602759492101097e-15, (640, 1) = -2.2924554758291458, (640, 2) = -0.41216504060209144e-15, (641, 1) = -2.2914955242305277, (641, 2) = 0.6184123998303544e-15, (642, 1) = -2.290535572631909, (642, 2) = .0, (643, 1) = -2.289575621033291, (643, 2) = 0.10312371101439893e-15, (644, 1) = -2.288615669434673, (644, 2) = -0.20630243114507906e-15, (645, 1) = -2.287655717836055, (645, 2) = -0.10317873060187286e-15, (646, 1) = -2.286695766237437, (646, 2) = 0.10320625610404879e-15, (647, 1) = -2.285735814638819, (647, 2) = -0.5161689604035486e-15, (648, 1) = -2.284775863040201, (648, 2) = -0.20652267706698115e-15, (649, 1) = -2.283815911441583, (649, 2) = -0.10328889546401874e-15, (650, 1) = -2.2828559598429647, (650, 2) = 0.10331646287391408e-15, (651, 1) = -2.2818960082443467, (651, 2) = 0.4133761630591555e-15, (652, 1) = -2.2809360566457286, (652, 2) = -0.10337162913824785e-15, (653, 1) = -2.2799761050471106, (653, 2) = -0.31019768398766433e-15, (654, 1) = -2.2790161534484925, (654, 2) = -0.5171341866964958e-15, (655, 1) = -2.2780562018498745, (655, 2) = 0.10345445717006284e-15, (656, 1) = -2.2770962502512564, (656, 2) = 0.10348208748975331e-15, (657, 1) = -2.276099130329774, (657, 2) = 0.31053239620260396e-15, (658, 1) = -2.2751020104082915, (658, 2) = .0, (659, 1) = -2.274104890486809, (659, 2) = 0.20713651037164296e-15, (660, 1) = -2.2731077705653266, (660, 2) = -0.31079100118938056e-15, (661, 1) = -2.272110650643844, (661, 2) = 0.4145030277304559e-15, (662, 1) = -2.2711135307223618, (662, 2) = -0.10365452479599339e-15, (663, 1) = -2.2701164108008793, (663, 2) = -0.2073666079766e-15, (664, 1) = -2.269119290879397, (664, 2) = 0.3111362835336787e-15, (665, 1) = -2.2681221709579145, (665, 2) = -0.20748179273291058e-15, (666, 1) = -2.267125051036432, (666, 2) = 0.10376970955566125e-15, (667, 1) = -2.2661279311149496, (667, 2) = .0, (668, 1) = -2.265130811193467, (668, 2) = -0.10382736994265401e-15, (669, 1) = -2.2641336912719847, (669, 2) = 0.10385621714374281e-15, (670, 1) = -2.2631365713505023, (670, 2) = .0, (671, 1) = -2.26213945142902, (671, 2) = 0.20782789113858114e-15, (672, 1) = -2.261142331507538, (672, 2) = .0, (673, 1) = -2.260145211586056, (673, 2) = 0.20794343874027372e-15, (674, 1) = -2.2591480916645734, (674, 2) = 0.10400062329031372e-15, (675, 1) = -2.258150971743091, (675, 2) = -0.20805907711823302e-15, (676, 1) = -2.2571538518216085, (676, 2) = -0.10405846517812606e-15, (677, 1) = -2.256156731900126, (677, 2) = .0, (678, 1) = -2.2551596119786437, (678, 2) = -0.3123490574191233e-15, (679, 1) = -2.2541624920571612, (679, 2) = -0.10414531315206073e-15, (680, 1) = -2.253165372135679, (680, 2) = .0, (681, 1) = -2.2521682522141964, (681, 2) = -0.1042032685809379e-15, (682, 1) = -2.251171132292714, (682, 2) = 0.31269679000155654e-15, (683, 1) = -2.2501740123712315, (683, 2) = .0, (684, 1) = -2.249176892449749, (684, 2) = 0.20858057384840325e-15, (685, 1) = -2.2481797725282666, (685, 2) = -0.20863863152927123e-15, (686, 1) = -2.247182652606784, (686, 2) = 0.20869671194111773e-15, (687, 1) = -2.2461855326853017, (687, 2) = -0.3131322226303394e-15, (688, 1) = -2.2451884127638193, (688, 2) = 0.31321941145429126e-15, (689, 1) = -2.2443204169409547, (689, 2) = .0, (690, 1) = -2.2434524211180906, (690, 2) = -0.10445709636647749e-15, (691, 1) = -2.2425844252952265, (691, 2) = 0.10448242223344258e-15, (692, 1) = -2.241716429472362, (692, 2) = -0.10450775671907201e-15, (693, 1) = -2.2408484336494974, (693, 2) = -0.20906619964860584e-15, (694, 1) = -2.2399804378266333, (694, 2) = 0.20911690310013325e-15, (695, 1) = -2.239112442003769, (695, 2) = .0, (696, 1) = -2.2382444461809046, (696, 2) = -0.1046091808668894e-15, (697, 1) = -2.23737645035804, (697, 2) = -0.3139036753793479e-15, (698, 1) = -2.236508454535176, (698, 2) = 0.4186397787075077e-15, (699, 1) = -2.2356404587123118, (699, 2) = -0.31405601855722473e-15, (700, 1) = -2.234772462889447, (700, 2) = -0.10471074298727357e-15, (701, 1) = -2.2339044670665826, (701, 2) = 0.3142084652470919e-15, (702, 1) = -2.2330364712437185, (702, 2) = 0.31428472741569423e-15, (703, 1) = -2.2321684754208544, (703, 2) = 0.3143610154702661e-15, (704, 1) = -2.23130047959799, (704, 2) = -0.20962488627561885e-15, (705, 1) = -2.2304324837751253, (705, 2) = 0.10483788974926145e-15, (706, 1) = -2.229564487952261, (706, 2) = 0.2097266899839466e-15, (707, 1) = -2.228696492129397, (707, 2) = .0, (708, 1) = -2.2278284963065325, (708, 2) = -0.20982856274918968e-15, (709, 1) = -2.226960500483668, (709, 2) = 0.1049397625161989e-15, (710, 1) = -2.2260925046608038, (710, 2) = 0.41986100916980613e-15, (711, 1) = -2.2252245088379397, (711, 2) = -0.20998150140837027e-15, (712, 1) = -2.224356513015075, (712, 2) = 0.4200650310089047e-15, (713, 1) = -2.2234885171922105, (713, 2) = -0.21008354687479012e-15, (714, 1) = -2.2226205213693464, (714, 2) = 0.21013459552101264e-15, (715, 1) = -2.2217525255464823, (715, 2) = -0.1050928307223684e-15, (716, 1) = -2.2208845297236177, (716, 2) = 0.31535511697135157e-15, (717, 1) = -2.2200165339007536, (717, 2) = 0.21028784513109819e-15, (718, 1) = -2.2191485380778895, (718, 2) = -0.10516948144845457e-15, (719, 1) = -2.218280542255025, (719, 2) = 0.10519504897328468e-15, (720, 1) = -2.217412546432161, (720, 2) = -0.1052206251408177e-15, (721, 1) = -2.2164750871639445, (721, 2) = -0.21049651562236763e-15, (722, 1) = -2.2155376278957286, (722, 2) = 0.31582770169432686e-15, (723, 1) = -2.2146001686275127, (723, 2) = -0.2106071068050994e-15, (724, 1) = -2.213662709359297, (724, 2) = -0.21066243265090856e-15, (725, 1) = -2.212725250091081, (725, 2) = -0.10535888933442923e-15, (726, 1) = -2.2117877908228647, (726, 2) = .0, (727, 1) = -2.2108503315546484, (727, 2) = 0.1054142656143079e-15, (728, 1) = -2.2099128722864325, (728, 2) = 0.10544196888704938e-15, (729, 1) = -2.206163035213568, (729, 2) = 0.10555288288440966e-15, (730, 1) = -2.202413198140704, (730, 2) = 0.1056639583741751e-15, (731, 1) = -2.201475738872488, (731, 2) = -0.10569175248623417e-15, (732, 1) = -2.2005382796042716, (732, 2) = 0.2114391133916237e-15, (733, 1) = -2.1996008203360553, (733, 2) = 0.10574737100372875e-15, (734, 1) = -2.1986633610678394, (734, 2) = 0.21155039082159364e-15, (735, 1) = -2.1977259017996236, (735, 2) = -0.2116060598356386e-15, (736, 1) = -2.1967884425314073, (736, 2) = 0.5291543726279536e-15, (737, 1) = -2.195850983263191, (737, 2) = -0.21171745846979365e-15, (738, 1) = -2.194913523994975, (738, 2) = -0.2117731880930292e-15, (739, 1) = -2.193976064726759, (739, 2) = 0.10591446896121231e-15, (740, 1) = -2.193038605458543, (740, 2) = 0.3178270619392478e-15, (741, 1) = -2.1921011461903266, (741, 2) = -0.10597024910287611e-15, (742, 1) = -2.1911636869221107, (742, 2) = 0.21199630866266892e-15, (743, 1) = -2.190226227653895, (743, 2) = -0.10602606966585716e-15, (744, 1) = -2.1892887683856785, (744, 2) = -0.10605399510716812e-15, (745, 1) = -2.1883513091174622, (745, 2) = .0, (746, 1) = -2.1874138498492464, (746, 2) = -0.31832962893901744e-15, (747, 1) = -2.186445362694724, (747, 2) = -0.21227751505504294e-15, (748, 1) = -2.185476875540201, (748, 2) = -0.31850294859582627e-15, (749, 1) = -2.1845083883856784, (749, 2) = 0.31858965698104754e-15, (750, 1) = -2.183539901231156, (750, 2) = 0.318676397740442e-15, (751, 1) = -2.1825714140766337, (751, 2) = 0.21250878058412838e-15, (752, 1) = -2.181602926922111, (752, 2) = 0.3188499763904511e-15, (753, 1) = -2.180634439767588, (753, 2) = -0.31893681428533836e-15, (754, 1) = -2.1796659526130657, (754, 2) = 0.10634122818764783e-15, (755, 1) = -2.1786974654585434, (755, 2) = -0.10637019574177494e-15, (756, 1) = -2.1777289783040206, (756, 2) = 0.10639917409150304e-15, (757, 1) = -2.1767604911494978, (757, 2) = .0, (758, 1) = -2.1757920039949754, (758, 2) = .0, (759, 1) = -2.1748235168404526, (759, 2) = 0.10648617392089172e-15, (760, 1) = -2.17385502968593, (760, 2) = -0.10651519545956955e-15, (761, 1) = -2.1728865425314074, (761, 2) = 0.10654422779706848e-15, (762, 1) = -2.1719180553768846, (762, 2) = -0.3197198128020024e-15, (763, 1) = -2.170949568222362, (763, 2) = -0.21320464974193623e-15, (764, 1) = -2.1699810810678395, (764, 2) = -0.21326277921712268e-15, (765, 1) = -2.1690125939133167, (765, 2) = 0.2133209302947216e-15, (766, 1) = -2.168044106758794, (766, 2) = 0.21337910297587185e-15, (767, 1) = -2.1670756196042715, (767, 2) = -0.3201559458925364e-15, (768, 1) = -2.1661071324497487, (768, 2) = -0.10674775657663745e-15, (769, 1) = -2.165138645295226, (769, 2) = -0.3203306259775469e-15, (770, 1) = -2.1641701581407036, (770, 2) = .0, (771, 1) = -2.1602962095226133, (771, 2) = 0.10692263114123979e-15, (772, 1) = -2.156422260904523, (772, 2) = 0.21407886061174847e-15, (773, 1) = -2.1554747851695986, (773, 2) = 0.3212040687699889e-15, (774, 1) = -2.1545273094346737, (774, 2) = .0, (775, 1) = -2.153579833699749, (775, 2) = 0.10712523919271416e-15, (776, 1) = -2.1526323579648245, (776, 2) = 0.10715386284539252e-15, (777, 1) = -2.1507374064949754, (777, 2) = .0, (778, 1) = -2.148842455025126, (778, 2) = -0.10726846091760924e-15, (779, 1) = -2.147894979290202, (779, 2) = 0.10729713630270658e-15, (780, 1) = -2.146947503555277, (780, 2) = -0.1073258220352519e-15, (781, 1) = -2.146000027820352, (781, 2) = .0, (782, 1) = -2.1450525520854278, (782, 2) = 0.10738322454386457e-15, (783, 1) = -2.144105076350503, (783, 2) = 0.10741194132049488e-15, (784, 1) = -2.143157600615578, (784, 2) = -0.214881336891398e-15, (785, 1) = -2.1422101248806538, (785, 2) = 0.10746940591973216e-15, (786, 1) = -2.141262649145729, (786, 2) = -0.10749815374283905e-15, (787, 1) = -2.140315173410804, (787, 2) = -0.21505382383050756e-15, (788, 1) = -2.1393676976758798, (788, 2) = .0, (789, 1) = -2.138420221940955, (789, 2) = 0.2151689186177805e-15, (790, 1) = -2.13747274620603, (790, 2) = -0.32283974559158147e-15, (791, 1) = -2.1365252704711057, (791, 2) = .0, (792, 1) = -2.135577794736181, (792, 2) = -0.32301257407318835e-15, (793, 1) = -2.134630319001256, (793, 2) = -0.10769967829697926e-15, (794, 1) = -2.1336828432663317, (794, 2) = 0.10772850892021091e-15, (795, 1) = -2.1327353675314074, (795, 2) = 0.2155146997884795e-15, (796, 1) = -2.1317878917964825, (796, 2) = -0.32335860365761073e-15, (797, 1) = -2.1308404160615577, (797, 2) = .0, (798, 1) = -2.1298929403266333, (798, 2) = 0.4313757396897332e-15, (799, 1) = -2.128945464591709, (799, 2) = .0, (800, 1) = -2.127997988856784, (800, 2) = -0.5395085501539278e-15, (801, 1) = -2.1270505131218593, (801, 2) = -0.4317224524484466e-15, (802, 1) = -2.126103037386935, (802, 2) = -0.10795952654497126e-15, (803, 1) = -2.1251863058951006, (803, 2) = .0, (804, 1) = -2.1242695744032667, (804, 2) = .0, (805, 1) = -2.123352842911433, (805, 2) = -0.32413053262753633e-15, (806, 1) = -2.1224361114195984, (806, 2) = .0, (807, 1) = -2.121519379927764, (807, 2) = -0.32429864665130923e-15, (808, 1) = -2.1206026484359297, (808, 2) = 0.10812758242398457e-15, (809, 1) = -2.1196859169440954, (809, 2) = 0.10815562565503407e-15, (810, 1) = -2.1187691854522614, (810, 2) = -0.10818367857690563e-15, (811, 1) = -2.1178524539604275, (811, 2) = 0.10821174118957695e-15, (812, 1) = -2.116935722468593, (812, 2) = 0.21647962698603162e-15, (813, 1) = -2.116018990976759, (813, 2) = .0, (814, 1) = -2.1151022594849245, (814, 2) = -0.32488796151605385e-15, (815, 1) = -2.11418552799309, (815, 2) = 0.10832408854746743e-15, (816, 1) = -2.113268796501256, (816, 2) = .0, (817, 1) = -2.1123520650094223, (817, 2) = -0.32514096110971264e-15, (818, 1) = -2.111435333517588, (818, 2) = 0.21681690163343615e-15, (819, 1) = -2.1105186020257536, (819, 2) = .0, (820, 1) = -2.1096018705339197, (820, 2) = -0.10846474078102821e-15, (821, 1) = -2.1086851390420858, (821, 2) = 0.10849290029829097e-15, (822, 1) = -2.1077684075502514, (822, 2) = .0, (823, 1) = -2.105934944566583, (823, 2) = -0.10857743698889752e-15, (824, 1) = -2.104101481582915, (824, 2) = -0.2172676864602091e-15, (825, 1) = -2.1031847500910805, (825, 2) = 0.1086620608844318e-15, (826, 1) = -2.1022680185992466, (826, 2) = 0.3260708646829638e-15, (827, 1) = -2.1013512871074127, (827, 2) = -0.21743705051914002e-15, (828, 1) = -2.1004345556155783, (828, 2) = .0, (829, 1) = -2.099517824123744, (829, 2) = 0.217550056777231e-15, (830, 1) = -2.0986010926319096, (830, 2) = .0, (831, 1) = -2.0976843611400753, (831, 2) = 0.10883157026973888e-15, (832, 1) = -2.0967676296482414, (832, 2) = -0.10885985574171297e-15, (833, 1) = -2.0804816452763824, (833, 2) = .0, (834, 1) = -2.064195660904523, (834, 2) = 0.10987113802319607e-15, (835, 1) = -2.0632810558228645, (835, 2) = .0, (836, 1) = -2.062366450741206, (836, 2) = -0.3297848788677448e-15, (837, 1) = -2.0614518456595476, (837, 2) = .0, (838, 1) = -2.0605372405778897, (838, 2) = -0.10998548638776058e-15, (839, 1) = -2.0596226354962317, (839, 2) = -0.2200281950783066e-15, (840, 1) = -2.0587080304145733, (840, 2) = -0.33012815493978614e-15, (841, 1) = -2.057793425332915, (841, 2) = .0, (842, 1) = -2.0568788202512565, (842, 2) = .0, (843, 1) = -2.055964215169598, (843, 2) = .0, (844, 1) = -2.0550496100879396, (844, 2) = .0, (845, 1) = -2.054135005006281, (845, 2) = 0.22037193299845549e-15, (846, 1) = -2.0532203999246232, (846, 2) = 0.22042928998856533e-15, (847, 1) = -2.0523057948429653, (847, 2) = 0.22048666621366153e-15, (848, 1) = -2.051391189761307, (848, 2) = .0, (849, 1) = -2.0504765846796484, (849, 2) = -0.220601476362456e-15, (850, 1) = -2.04956197959799, (850, 2) = -0.33098836542437707e-15, (851, 1) = -2.0486473745163316, (851, 2) = .0, (852, 1) = -2.047732769434673, (852, 2) = 0.33116075371156295e-15, (853, 1) = -2.046818164353015, (853, 2) = 0.2208313274086623e-15, (854, 1) = -2.045903559271357, (854, 2) = -0.22088883823303296e-15, (855, 1) = -2.044988954189699, (855, 2) = 0.11047318413953757e-15, (856, 1) = -2.0440743491080404, (856, 2) = 0.33150587631753003e-15, (857, 1) = -2.043159744026382, (857, 2) = .0, (858, 1) = -2.0422451389447236, (858, 2) = 0.11055953686471267e-15, (859, 1) = -2.0385867186180904, (859, 2) = .0, (860, 1) = -2.034928298291457, (860, 2) = -0.11079023344658713e-15, (861, 1) = -2.033951762148241, (861, 2) = -0.33246320897278664e-15, (862, 1) = -2.032975226005025, (862, 2) = .0, (863, 1) = -2.0319986898618088, (863, 2) = .0, (864, 1) = -2.0310221537185926, (864, 2) = -0.33274093181681085e-15, (865, 1) = -2.0300456175753765, (865, 2) = -0.11094452391121877e-15, (866, 1) = -2.0290690814321604, (866, 2) = -0.22195082964115327e-15, (867, 1) = -2.0280925452889447, (867, 2) = -0.4440252666627288e-15, (868, 1) = -2.0271160091457285, (868, 2) = 0.2220744588903827e-15, (869, 1) = -2.0261394730025124, (869, 2) = -0.2221363063154881e-15, (870, 1) = -2.0251629368592967, (870, 2) = -0.2221981756039289e-15, (871, 1) = -2.0241864007160806, (871, 2) = -0.2222600667529218e-15, (872, 1) = -2.0232098645728644, (872, 2) = 0.2223219797596511e-15, (873, 1) = -2.0222333284296483, (873, 2) = .0, (874, 1) = -2.021256792286432, (874, 2) = .0, (875, 1) = -2.020280256143216, (875, 2) = .0, (876, 1) = -2.01930372, (876, 2) = 0.11128492515325335e-15, (877, 1) = -2.018327183856784, (877, 2) = .0, (878, 1) = -2.0173506477135676, (878, 2) = -0.11134695832539925e-15, (879, 1) = -2.0163741115703515, (879, 2) = 0.22275598258015983e-15, (880, 1) = -2.0153975754271354, (880, 2) = 0.1114090351717891e-15, (881, 1) = -2.0144210392839192, (881, 2) = .0, (882, 1) = -2.013444503140703, (882, 2) = 0.1114711556800654e-15, (883, 1) = -2.0124679669974874, (883, 2) = 0.11150223230347792e-15, (884, 1) = -2.0114914308542713, (884, 2) = .0, (885, 1) = -2.010514894711055, (885, 2) = -0.11156441828084243e-15, (886, 1) = -2.0095383585678395, (886, 2) = 0.11159552763154137e-15, (887, 1) = -2.0085618224246233, (887, 2) = 0.11162664788805526e-15, (888, 1) = -2.007585286281407, (888, 2) = -0.2233155580974327e-15, (889, 1) = -2.006608750138191, (889, 2) = .0, (890, 1) = -2.005632213994975, (890, 2) = 0.2234401481514521e-15, (891, 1) = -2.004655677851759, (891, 2) = -0.11175123793865606e-15, (892, 1) = -2.0036791417085427, (892, 2) = 0.22356482539779193e-15, (893, 1) = -1.9966000466080402, (893, 2) = 0.22401746018861886e-15, (894, 1) = -1.9895209515075378, (894, 2) = 0.22447123872408967e-15, (895, 1) = -1.9877511777324122, (895, 2) = 0.11229243094827764e-15, (896, 1) = -1.9859814039572865, (896, 2) = .0, (897, 1) = -1.9850965170697237, (897, 2) = -0.11237771523117296e-15, (898, 1) = -1.9842116301821608, (898, 2) = 0.22481232232058554e-15, (899, 1) = -1.983326743294598, (899, 2) = -0.1124346160042371e-15, (900, 1) = -1.9824418564070352, (900, 2) = .0, (901, 1) = -1.9815569695194724, (901, 2) = 0.22498310486061986e-15, (902, 1) = -1.9806720826319095, (902, 2) = -0.4500801360370562e-15, (903, 1) = -1.9797871957443467, (903, 2) = 0.22509704899338774e-15, (904, 1) = -1.9789023088567839, (904, 2) = .0, (905, 1) = -1.978017421969221, (905, 2) = -0.11260553219050094e-15, (906, 1) = -1.9771325350816582, (906, 2) = .0, (907, 1) = -1.9762476481940956, (907, 2) = .0, (908, 1) = -1.9753627613065328, (908, 2) = -0.1126911105039668e-15, (909, 1) = -1.9714931009170855, (909, 2) = .0, (910, 1) = -1.9676234405276383, (910, 2) = 0.1129410599597707e-15, (911, 1) = -1.9666560254302765, (911, 2) = -0.33891705433657e-15, (912, 1) = -1.9656886103329145, (912, 2) = -0.11300365354661607e-15, (913, 1) = -1.9647211952355528, (913, 2) = 0.22606993252136857e-15, (914, 1) = -1.963753780138191, (914, 2) = -0.11306628958534568e-15, (915, 1) = -1.9627863650408293, (915, 2) = -0.33929287055460093e-15, (916, 1) = -1.9618189499434675, (916, 2) = .0, (917, 1) = -1.9608515348461055, (917, 2) = .0, (918, 1) = -1.9598841197487438, (918, 2) = -0.11319168894165835e-15, (919, 1) = -1.9521447989698493, (919, 2) = .0, (920, 1) = -1.9444054781909548, (920, 2) = 0.11369498047668599e-15, (921, 1) = -1.9434952159767587, (921, 2) = 0.22744932420352506e-15, (922, 1) = -1.9425849537625628, (922, 2) = -0.34126305921146626e-15, (923, 1) = -1.941674691548367, (923, 2) = -0.11378405338053478e-15, (924, 1) = -1.940764429334171, (924, 2) = -0.1138137630295562e-15, (925, 1) = -1.9398541671199752, (925, 2) = .0, (926, 1) = -1.938943904905779, (926, 2) = 0.11387321033507437e-15, (927, 1) = -1.938033642691583, (927, 2) = -0.11390294798680927e-15, (928, 1) = -1.937123380477387, (928, 2) = -0.1139326949679956e-15, (929, 1) = -1.9362131182631912, (929, 2) = 0.22792490255243156e-15, (930, 1) = -1.935302856048995, (930, 2) = 0.22798443381807475e-15, (931, 1) = -1.934392593834799, (931, 2) = 0.2280439837280265e-15, (932, 1) = -1.9334823316206031, (932, 2) = 0.1140517761386814e-15, (933, 1) = -1.9325720694064072, (933, 2) = .0, (934, 1) = -1.9316618071922111, (934, 2) = 0.3423341179115183e-15, (935, 1) = -1.930751544978015, (935, 2) = -0.22828236971199566e-15, (936, 1) = -1.9298412827638192, (936, 2) = 0.4566840255380755e-15, (937, 1) = -1.9289310205496233, (937, 2) = -0.11420083722019955e-15, (938, 1) = -1.9280207583354272, (938, 2) = -0.2284613547209771e-15, (939, 1) = -1.927110496121231, (939, 2) = 0.22852105360563897e-15, (940, 1) = -1.9262002339070352, (940, 2) = .0, (941, 1) = -1.9252899716928393, (941, 2) = -0.11432025358326666e-15, (942, 1) = -1.9243797094786432, (942, 2) = .0, (943, 1) = -1.9234694472644471, (943, 2) = 0.11438001754070914e-15, (944, 1) = -1.9225591850502513, (944, 2) = 0.11440991345422749e-15, (945, 1) = -1.9216489228360554, (945, 2) = 0.34331945596221893e-15, (946, 1) = -1.9207386606218593, (946, 2) = -0.34340919941272006e-15, (947, 1) = -1.9198283984076632, (947, 2) = -0.22899931380408243e-15, (948, 1) = -1.9189181361934673, (948, 2) = 0.1145295899447738e-15, (949, 1) = -1.9180078739792714, (949, 2) = 0.22911906452610604e-15, (950, 1) = -1.9170976117650755, (950, 2) = .0, (951, 1) = -1.9161873495508797, (951, 2) = 0.3438583341459078e-15, (952, 1) = -1.9152770873366836, (952, 2) = 0.22929882968752e-15, (953, 1) = -1.913374114748744, (953, 2) = 0.11471209960938318e-15, (954, 1) = -1.9114711421608042, (954, 2) = .0, (955, 1) = -1.9105196558668343, (955, 2) = 0.11480620262167956e-15, (956, 1) = -1.9095681695728643, (956, 2) = -0.2296751810196671e-15, (957, 1) = -1.9086166832788947, (957, 2) = -0.11486898850122146e-15, (958, 1) = -1.9076651969849248, (958, 2) = 0.22980079318507823e-15, (959, 1) = -1.9067137106909549, (959, 2) = -0.1149318147804635e-15, (960, 1) = -1.9057622243969852, (960, 2) = 0.11496324306165295e-15, (961, 1) = -1.9048107381030153, (961, 2) = 0.11499468143274694e-15, (962, 1) = -1.9038592518090454, (962, 2) = 0.34507838967109812e-15, (963, 1) = -1.9029077655150755, (963, 2) = -0.11505758843111208e-15, (964, 1) = -1.9019562792211056, (964, 2) = -0.23017811410313567e-15, (965, 1) = -1.9010047929271359, (965, 2) = 0.11512053574829717e-15, (966, 1) = -1.900053306633166, (966, 2) = -0.3454560735535348e-15, (967, 1) = -1.899101820339196, (967, 2) = 0.11518352335673693e-15, (968, 1) = -1.8981503340452264, (968, 2) = 0.2304300645229598e-15, (969, 1) = -1.8971988477512565, (969, 2) = 0.11524655122856148e-15, (970, 1) = -1.8962473614572866, (970, 2) = -0.11527808025445007e-15, (971, 1) = -1.8952958751633167, (971, 2) = -0.2306192386711899e-15, (972, 1) = -1.8943443888693468, (972, 2) = 0.11534116846842616e-15, (973, 1) = -1.893392902575377, (973, 2) = 0.11537272764935434e-15, (974, 1) = -1.8924414162814072, (974, 2) = 0.461617187499084e-15, (975, 1) = -1.8914899299874373, (975, 2) = 0.23087175228209633e-15, (976, 1) = -1.8905384436934676, (976, 2) = -0.11546746544453847e-15, (977, 1) = -1.8895869573994977, (977, 2) = .0, (978, 1) = -1.8886354711055278, (978, 2) = 0.34659202244541606e-15, (979, 1) = -1.8876839848115579, (979, 2) = 0.2311245870830464e-15, (980, 1) = -1.886732498517588, (980, 2) = 0.34678176887101024e-15, (981, 1) = -1.8857810122236183, (981, 2) = 0.1156255623911677e-15, (982, 1) = -1.8848295259296484, (982, 2) = -0.3469716355207546e-15, (983, 1) = -1.8838992741614322, (983, 2) = 0.11568816464024824e-15, (984, 1) = -1.8829690223932163, (984, 2) = 0.11571912700597038e-15, (985, 1) = -1.8820387706250001, (985, 2) = 0.2315001978676903e-15, (986, 1) = -1.881108518856784, (986, 2) = 0.11578108042028178e-15, (987, 1) = -1.880178267088568, (987, 2) = .0, (988, 1) = -1.879248015320352, (988, 2) = -0.11584307205438634e-15, (989, 1) = -1.8783177635521358, (989, 2) = 0.11587408219478183e-15, (990, 1) = -1.8773875117839198, (990, 2) = -0.2318102037583883e-15, (991, 1) = -1.8736665047110554, (991, 2) = -0.2320585519662002e-15, (992, 1) = -1.869945497638191, (992, 2) = -0.23230720498685046e-15, (993, 1) = -1.8625034834924623, (993, 2) = -0.2328054235107654e-15, (994, 1) = -1.8550614693467338, (994, 2) = -0.23330485532267047e-15, (995, 1) = -1.8540875819566582, (995, 2) = 0.23337030223489247e-15, (996, 1) = -1.853113694566583, (996, 2) = 0.4668715396887413e-15, (997, 1) = -1.8521398071765076, (997, 2) = 0.11675062907076656e-15, (998, 1) = -1.8511659197864323, (998, 2) = 0.2335667671167618e-15, (999, 1) = -1.850192032396357, (999, 2) = -0.1168161483801961e-15, (1000, 1) = -1.8492181450062815, (1000, 2) = .0, (1001, 1) = -1.848244257616206, (1001, 2) = 0.1168817090069839e-15, (1002, 1) = -1.8472703702261306, (1002, 2) = 0.4676580192087024e-15, (1003, 1) = -1.8433748206658291, (1003, 2) = 0.3511373732391786e-15, (1004, 1) = -1.8394792711055277, (1004, 2) = 0.23435448414408477e-15, (1005, 1) = -1.8385053837154524, (1005, 2) = .0, (1006, 1) = -1.837531496325377, (1006, 2) = 0.11724302923490122e-15, (1007, 1) = -1.8365576089353017, (1007, 2) = .0, (1008, 1) = -1.8355837215452262, (1008, 2) = 0.3519265723622633e-15, (1009, 1) = -1.8346098341551507, (1009, 2) = 0.11734178694682448e-15, (1010, 1) = -1.8336359467650754, (1010, 2) = 0.2347494533760396e-15, (1011, 1) = -1.832662059375, (1011, 2) = 0.11740767667241593e-15, (1012, 1) = -1.8316881719849247, (1012, 2) = -0.23488127378946203e-15, (1013, 1) = -1.8277926224246233, (1013, 2) = -0.23514516011339296e-15, (1014, 1) = -1.8238970728643218, (1014, 2) = -0.23540937319302986e-15, (1015, 1) = -1.8163933184170855, (1015, 2) = -0.1179596143496049e-15, (1016, 1) = -1.8088895639698492, (1016, 2) = .0, (1017, 1) = -1.8079515946639448, (1017, 2) = 0.4729885116409428e-15, (1018, 1) = -1.8070136253580402, (1018, 2) = 0.11827912075501641e-15, (1019, 1) = -1.8060756560521356, (1019, 2) = -0.11831112295923665e-15, (1020, 1) = -1.8051376867462312, (1020, 2) = -0.11834313451757265e-15, (1021, 1) = -1.8041997174403268, (1021, 2) = 0.11837515542467873e-15, (1022, 1) = -1.8032617481344222, (1022, 2) = .0, (1023, 1) = -1.8023237788285176, (1023, 2) = -0.236878450527417e-15, (1024, 1) = -1.8013858095226132, (1024, 2) = -0.35541382255449233e-15, (1025, 1) = -1.8004478402167088, (1025, 2) = 0.23700666486624054e-15, (1026, 1) = -1.7995098709108042, (1026, 2) = -0.11853540000312102e-15, (1027, 1) = -1.7985719016048995, (1027, 2) = -0.2371349537787097e-15, (1028, 1) = -1.7976339322989952, (1028, 2) = 0.11859956308632143e-15, (1029, 1) = -1.7966959629930905, (1029, 2) = -0.2372633171769963e-15, (1030, 1) = -1.795757993687186, (1030, 2) = .0, (1031, 1) = -1.7948200243812815, (1031, 2) = 0.23739175497255965e-15, (1032, 1) = -1.793882055075377, (1032, 2) = .0, (1033, 1) = -1.7862083823618091, (1033, 2) = .0, (1034, 1) = -1.7785347096482411, (1034, 2) = .0, (1035, 1) = -1.777575500559045, (1035, 2) = -0.23857588597736536e-15, (1036, 1) = -1.7766162914698491, (1036, 2) = -0.2386419349687778e-15, (1037, 1) = -1.7756570823806532, (1037, 2) = 0.11935400157588248e-15, (1038, 1) = -1.7746978732914571, (1038, 2) = .0, (1039, 1) = -1.7737386642022612, (1039, 2) = 0.11942009852029875e-15, (1040, 1) = -1.7727794551130653, (1040, 2) = 0.2389063227203826e-15, (1041, 1) = -1.7718202460238692, (1041, 2) = -0.1194862337698107e-15, (1042, 1) = -1.7708610369346733, (1042, 2) = -0.1195193157425779e-15, (1043, 1) = -1.7699018278454774, (1043, 2) = .0, (1044, 1) = -1.7689426187562813, (1044, 2) = -0.3587565250533334e-15, (1045, 1) = -1.7679834096670854, (1045, 2) = 0.11961861897359046e-15, (1046, 1) = -1.7670242005778896, (1046, 2) = 0.35895521739793253e-15, (1047, 1) = -1.7660649914886934, (1047, 2) = 0.11968486882156434e-15, (1048, 1) = -1.7651057823994976, (1048, 2) = .0, (1049, 1) = -1.7641465733103017, (1049, 2) = -0.11975115676204282e-15, (1050, 1) = -1.7631873642211056, (1050, 2) = 0.1197843150000556e-15, (1051, 1) = -1.7555772333919597, (1051, 2) = .0, (1052, 1) = -1.747967102562814, (1052, 2) = -0.1203117208288999e-15, (1053, 1) = -1.747015836209171, (1053, 2) = 0.1203447624975164e-15, (1054, 1) = -1.7460645698555277, (1054, 2) = -0.12037781339533178e-15, (1055, 1) = -1.7451133035018844, (1055, 2) = -0.24082174703048046e-15, (1056, 1) = -1.7441620371482411, (1056, 2) = 0.2408878857002195e-15, (1057, 1) = -1.7422595044409548, (1057, 2) = 0.1205101091360732e-15, (1058, 1) = -1.7403569717336684, (1058, 2) = .0, (1059, 1) = -1.7394057053800251, (1059, 2) = 0.12060942749742065e-15, (1060, 1) = -1.7384544390263819, (1060, 2) = -0.24128510394163445e-15, (1061, 1) = -1.7375031726727386, (1061, 2) = -0.2413513712170323e-15, (1062, 1) = -1.7365519063190955, (1062, 2) = .0, (1063, 1) = -1.7356006399654524, (1063, 2) = 0.2414839606948491e-15, (1064, 1) = -1.7346493736118092, (1064, 2) = .0, (1065, 1) = -1.7336981072581659, (1065, 2) = 0.12080831165508722e-15, (1066, 1) = -1.7327468409045226, (1066, 2) = -0.24168298200725827e-15, (1067, 1) = -1.7318727259202262, (1067, 2) = -0.24174397483920903e-15, (1068, 1) = -1.7309986109359297, (1068, 2) = -0.2418049830605751e-15, (1069, 1) = -1.730124495951633, (1069, 2) = .0, (1070, 1) = -1.7292503809673367, (1070, 2) = .0, (1071, 1) = -1.7283762659830402, (1071, 2) = -0.12099404997209398e-15, (1072, 1) = -1.7275021509987436, (1072, 2) = .0, (1073, 1) = -1.7266280360144473, (1073, 2) = -0.4842205091970862e-15, (1074, 1) = -1.7257539210301507, (1074, 2) = -0.12108567745490408e-15, (1075, 1) = -1.7248798060458541, (1075, 2) = .0, (1076, 1) = -1.7240056910615578, (1076, 2) = 0.24229360144096615e-15, (1077, 1) = -1.7231315760772612, (1077, 2) = 0.2423547476369245e-15, (1078, 1) = -1.7222574610929646, (1078, 2) = .0, (1079, 1) = -1.7213833461086683, (1079, 2) = 0.12123854291473592e-15, (1080, 1) = -1.7205092311243717, (1080, 2) = -0.2425382778018931e-15, (1081, 1) = -1.7196351161400751, (1081, 2) = .0, (1082, 1) = -1.7187610011557788, (1082, 2) = 0.242660707438319e-15, (1083, 1) = -1.7117680812814071, (1083, 2) = 0.2431510334055877e-15, (1084, 1) = -1.7047751614070352, (1084, 2) = 0.2436423264639009e-15, (1085, 1) = -1.7027714925753767, (1085, 2) = 0.12189163656150302e-15, (1086, 1) = -1.7007678237437185, (1086, 2) = .0, (1087, 1) = -1.6997659893278894, (1087, 2) = .0, (1088, 1) = -1.6987641549120602, (1088, 2) = .0, (1089, 1) = -1.697762320496231, (1089, 2) = 0.2441359837731839e-15, (1090, 1) = -1.696760486080402, (1090, 2) = -0.1221032923588109e-15, (1091, 1) = -1.6927531484170855, (1091, 2) = -0.2444891838803665e-15, (1092, 1) = -1.688745810753769, (1092, 2) = -0.3671581420387618e-15, (1093, 1) = -1.6847384730904524, (1093, 2) = -0.24505531585048567e-15, (1094, 1) = -1.6807311354271357, (1094, 2) = -0.12266942301622437e-15, (1095, 1) = -1.676723797763819, (1095, 2) = .0, (1096, 1) = -1.6727164601005025, (1096, 2) = 0.12295341404433523e-15, (1097, 1) = -1.67182040745603, (1097, 2) = -0.1229852026713176e-15, (1098, 1) = -1.6709243548115578, (1098, 2) = .0, (1099, 1) = -1.6700283021670854, (1099, 2) = 0.1230488027645834e-15, (1100, 1) = -1.669132249522613, (1100, 2) = .0, (1101, 1) = -1.6682361968781407, (1101, 2) = 0.12311243325821272e-15, (1102, 1) = -1.6673401442336684, (1102, 2) = 0.12314425988556085e-15, (1103, 1) = -1.666444091589196, (1103, 2) = 0.246352188178858e-15, (1104, 1) = -1.6655480389447237, (1104, 2) = .0, (1105, 1) = -1.6619638283668343, (1105, 2) = -0.1233353784790137e-15, (1106, 1) = -1.6583796177889447, (1106, 2) = -0.18519441233283416e-15, (1107, 1) = -1.6574835651444721, (1107, 2) = .0, (1108, 1) = -1.6565875124999998, (1108, 2) = .0, (1109, 1) = -1.6556914598555275, (1109, 2) = .0, (1110, 1) = -1.6547954072110551, (1110, 2) = 0.24718124914609064e-15, (1111, 1) = -1.6538993545665828, (1111, 2) = 0.12362256400714662e-15, (1112, 1) = -1.6530033019221104, (1112, 2) = -0.24730902179331355e-15, (1113, 1) = -1.652107249277638, (1113, 2) = -0.6184323261665423e-16, (1114, 1) = -1.6512111966331657, (1114, 2) = -0.12371842700881007e-15, (1115, 1) = -1.6503151439886934, (1115, 2) = -0.12375039621484556e-15, (1116, 1) = -1.649419091344221, (1116, 2) = 0.1237823728430745e-15, (1117, 1) = -1.6485230386997487, (1117, 2) = -0.1857215353276979e-15, (1118, 1) = -1.6476269860552764, (1118, 2) = -0.1857695224989426e-15, (1119, 1) = -1.646730933410804, (1119, 2) = .0, (1120, 1) = -1.6458348807663317, (1120, 2) = 0.1239103534102578e-15, (1121, 1) = -1.6449388281218593, (1121, 2) = -0.2478847340469778e-15, (1122, 1) = -1.644042775477387, (1122, 2) = 0.18596158201253297e-15, (1123, 1) = -1.6430873964667085, (1123, 2) = 0.12400853716721657e-15, (1124, 1) = -1.64213201745603, (1124, 2) = -0.12404269468613184e-15, (1125, 1) = -1.6411766384453519, (1125, 2) = -0.4342690119415209e-15, (1126, 1) = -1.6402212594346735, (1126, 2) = 0.18616655214385327e-15, (1127, 1) = -1.639265880423995, (1127, 2) = -0.37243565189769764e-15, (1128, 1) = -1.6383105014133168, (1128, 2) = -0.12417940815423409e-15, (1129, 1) = -1.6373551224026384, (1129, 2) = -0.24842721463412787e-15, (1130, 1) = -1.63639974339196, (1130, 2) = .0, (1131, 1) = -1.6354443643812815, (1131, 2) = -0.18642304578601346e-15, (1132, 1) = -1.634488985370603, (1132, 2) = .0, (1133, 1) = -1.6335336063599246, (1133, 2) = 0.6217524341767231e-16, (1134, 1) = -1.6325782273492462, (1134, 2) = -0.12438472737854106e-15, (1135, 1) = -1.6316228483385677, (1135, 2) = 0.18662846424874288e-15, (1136, 1) = -1.6306674693278893, (1136, 2) = -0.1866798497797059e-15, (1137, 1) = -1.629712090317211, (1137, 2) = -0.24897499685939526e-15, (1138, 1) = -1.6287567113065327, (1138, 2) = -0.6226088594235382e-16, (1139, 1) = -1.6278013322958542, (1139, 2) = -0.24911210708133153e-15, (1140, 1) = -1.626845953285176, (1140, 2) = -0.31147585846676076e-15, (1141, 1) = -1.6258905742744976, (1141, 2) = -0.24924928282384534e-15, (1142, 1) = -1.6249351952638191, (1142, 2) = -0.18698842140808107e-15, (1143, 1) = -1.6239798162531407, (1143, 2) = -0.12469326195613192e-15, (1144, 1) = -1.6230244372424623, (1144, 2) = .0, (1145, 1) = -1.6220690582317838, (1145, 2) = 0.6238095754271466e-16, (1146, 1) = -1.6211136792211054, (1146, 2) = -0.12479625384188377e-15, (1147, 1) = -1.620158300210427, (1147, 2) = 0.6241530035571057e-16, (1148, 1) = -1.6192029211997485, (1148, 2) = -0.1248649556829092e-15, (1149, 1) = -1.6182475421890703, (1149, 2) = -0.31224829686295607e-15, (1150, 1) = -1.6172921631783919, (1150, 2) = .0, (1151, 1) = -1.6153814051570352, (1151, 2) = .0, (1152, 1) = -1.6134706471356783, (1152, 2) = .0, (1153, 1) = -1.606155290201005, (1153, 2) = 0.6266747362171195e-16, (1154, 1) = -1.5988399332663317, (1154, 2) = 0.1883986570155935e-15, (1155, 1) = -1.5970110940326634, (1155, 2) = 0.1256652161085474e-15, (1156, 1) = -1.5951822547989951, (1156, 2) = .0, (1157, 1) = -1.5933534155653266, (1157, 2) = .0, (1158, 1) = -1.5915245763316583, (1158, 2) = .0, (1159, 1) = -1.590610156714824, (1159, 2) = 0.18884524692251065e-15, (1160, 1) = -1.58969573709799, (1160, 2) = -0.6296497380722231e-16, (1161, 1) = -1.5887813174811558, (1161, 2) = -0.12596307102792318e-15, (1162, 1) = -1.5878668978643216, (1162, 2) = 0.25199240302272797e-15, (1163, 1) = -1.5869524782474875, (1163, 2) = 0.2520586781079843e-15, (1164, 1) = -1.5860380586306533, (1164, 2) = -0.25212496729000674e-15, (1165, 1) = -1.585123639013819, (1165, 2) = .0, (1166, 1) = -1.584209219396985, (1166, 2) = 0.6306439696440484e-16, (1167, 1) = -1.5801478375251257, (1167, 2) = .0, (1168, 1) = -1.5760864556532663, (1168, 2) = -0.632118240120027e-16, (1169, 1) = -1.5750711101853014, (1169, 2) = 0.3793816299785946e-15, (1170, 1) = -1.5740557647173365, (1170, 2) = -0.1897461707131557e-15, (1171, 1) = -1.5730404192493719, (1171, 2) = 0.12653435945635753e-15, (1172, 1) = -1.572025073781407, (1172, 2) = 0.6328564012677454e-16, (1173, 1) = -1.5699943828454774, (1173, 2) = 0.6332257361743712e-16, (1174, 1) = -1.5679636919095477, (1174, 2) = 0.6335952398093842e-16, (1175, 1) = -1.5659330009736179, (1175, 2) = .0, (1176, 1) = -1.5639023100376883, (1176, 2) = -0.6343347507620617e-16, (1177, 1) = -1.5628869645697234, (1177, 2) = 0.19035591989246738e-15, (1178, 1) = -1.5618716191017588, (1178, 2) = 0.6347047568192068e-16, (1179, 1) = -1.5608562736337939, (1179, 2) = .0, (1180, 1) = -1.559840928165829, (1180, 2) = 0.38104495745020525e-15, (1181, 1) = -1.5588255826978643, (1181, 2) = -0.1905780232031802e-15, (1182, 1) = -1.5578102372298994, (1182, 2) = -0.19063358007476676e-15, (1183, 1) = -1.5567948917619345, (1183, 2) = 0.38137829863140453e-15, (1184, 1) = -1.5557795462939699, (1184, 2) = 0.12716315393450422e-15, (1185, 1) = -1.55374885535804, (1185, 2) = 0.6361864367064832e-16, (1186, 1) = -1.5517181644221105, (1186, 2) = -0.636557267366915e-16, (1187, 1) = -1.5508389498523871, (1187, 2) = .0, (1188, 1) = -1.5499597352826635, (1188, 2) = -0.19106355334679608e-15, (1189, 1) = -1.54908052071294, (1189, 2) = -0.25481567149697545e-15, (1190, 1) = -1.5482013061432163, (1190, 2) = 0.25487995068748737e-15, (1191, 1) = -1.5473220915734927, (1191, 2) = 0.12747212100621446e-15, (1192, 1) = -1.546442877003769, (1192, 2) = -0.19125640908768343e-15, (1193, 1) = -1.5455636624340454, (1193, 2) = -0.19130464573449414e-15, (1194, 1) = -1.5446844478643218, (1194, 2) = -0.19135289143350654e-15, (1195, 1) = -1.5438052332945982, (1195, 2) = -0.12760076411228874e-15, (1196, 1) = -1.5429260187248746, (1196, 2) = 0.1276329399486306e-15, (1197, 1) = -1.542046804155151, (1197, 2) = 0.12766512178711754e-15, (1198, 1) = -1.5411675895854273, (1198, 2) = 0.6384865480840514e-16, (1199, 1) = -1.53940916044598, (1199, 2) = -0.6388085160295997e-16, (1200, 1) = -1.5376507313065328, (1200, 2) = -0.19173918094185346e-15, (1201, 1) = -1.5367715167368092, (1201, 2) = -0.6392916912429196e-16, (1202, 1) = -1.5358923021670856, (1202, 2) = -0.6394528089713252e-16, (1203, 1) = -1.535013087597362, (1203, 2) = 0.1918841868807239e-15, (1204, 1) = -1.5341338730276384, (1204, 2) = 0.2559100532321593e-15, (1205, 1) = -1.5332546584579148, (1205, 2) = .0, (1206, 1) = -1.5323754438881911, (1206, 2) = -0.32004878750995085e-15, (1207, 1) = -1.5314962293184675, (1207, 2) = -0.6402588400358314e-16, (1208, 1) = -1.530617014748744, (1208, 2) = .0, (1209, 1) = -1.5297378001790203, (1209, 2) = 0.1921744373635135e-15, (1210, 1) = -1.5288585856092967, (1210, 2) = 0.3844456863551492e-15, (1211, 1) = -1.527979371039573, (1211, 2) = 0.1281808384849356e-15, (1212, 1) = -1.5271001564698494, (1212, 2) = 0.25642624132791263e-15, (1213, 1) = -1.5262209419001258, (1213, 2) = -0.1282454086440405e-15, (1214, 1) = -1.5253417273304022, (1214, 2) = 0.32069425603438964e-15, (1215, 1) = -1.5244625127606786, (1215, 2) = .0, (1216, 1) = -1.523583298190955, (1216, 2) = .0, (1217, 1) = -1.522585381790201, (1217, 2) = -0.6418949053484519e-16, (1218, 1) = -1.5215874653894474, (1218, 2) = -0.6420783113017716e-16, (1219, 1) = -1.5205895489886938, (1219, 2) = -0.25690470166255205e-15, (1220, 1) = -1.51959163258794, (1220, 2) = 0.19273357014822226e-15, (1221, 1) = -1.518593716187186, (1221, 2) = -0.12852575004595045e-15, (1222, 1) = -1.5175957997864322, (1222, 2) = 0.25712492131123205e-15, (1223, 1) = -1.5165978833856784, (1223, 2) = 0.12859917857736485e-15, (1224, 1) = -1.5155999669849247, (1224, 2) = -0.19295385569105542e-15, (1225, 1) = -1.514602050584171, (1225, 2) = -0.38601790886527693e-15, (1226, 1) = -1.5136041341834172, (1226, 2) = -0.19306406406491626e-15, (1227, 1) = -1.5126062177826634, (1227, 2) = -0.2574922460825847e-15, (1228, 1) = -1.5116083013819095, (1228, 2) = -0.32195719316280756e-15, (1229, 1) = -1.5106103849811556, (1229, 2) = 0.19322945804606314e-15, (1230, 1) = -1.509612468580402, (1230, 2) = 0.6442820366030422e-16, (1231, 1) = -1.5086145521796483, (1231, 2) = 0.19333977467600087e-15, (1232, 1) = -1.5076166357788945, (1232, 2) = .0, (1233, 1) = -1.5036249701758795, (1233, 2) = .0, (1234, 1) = -1.4996333045728645, (1234, 2) = .0, (1235, 1) = -1.4986353881721106, (1235, 2) = -0.3231533293636525e-15, (1236, 1) = -1.497637471771357, (1236, 2) = 0.193947277924268e-15, (1237, 1) = -1.4966395553706033, (1237, 2) = .0, (1238, 1) = -1.4956416389698495, (1238, 2) = -0.2587438264386308e-15, (1239, 1) = -1.4946437225690956, (1239, 2) = -0.647043937910699e-16, (1240, 1) = -1.4936458061683417, (1240, 2) = 0.647228344252181e-16, (1241, 1) = -1.4926478897675879, (1241, 2) = .0, (1242, 1) = -1.4916499733668342, (1242, 2) = 0.6475972601519632e-16, (1243, 1) = -1.490740480901382, (1243, 2) = 0.32388270951813847e-15, (1244, 1) = -1.4898309884359295, (1244, 2) = 0.32396680315129076e-15, (1245, 1) = -1.4889214959704773, (1245, 2) = 0.19443054656432598e-15, (1246, 1) = -1.488012003505025, (1246, 2) = 0.12965401314036683e-15, (1247, 1) = -1.4871025110395728, (1247, 2) = 0.19453150130840953e-15, (1248, 1) = -1.4861930185741206, (1248, 2) = -0.25944265511575454e-15, (1249, 1) = -1.4852835261086683, (1249, 2) = 0.3243874829577184e-15, (1250, 1) = -1.484374033643216, (1250, 2) = -0.12978866440044395e-15, (1251, 1) = -1.4834645411777638, (1251, 2) = -0.19473351179368133e-15, (1252, 1) = -1.4825550487123116, (1252, 2) = -0.38956807066477426e-15, (1253, 1) = -1.4816455562468593, (1253, 2) = 0.38966913439088567e-15, (1254, 1) = -1.480736063781407, (1254, 2) = 0.6496170245381901e-16, (1255, 1) = -1.4798265713159549, (1255, 2) = -0.2599142077453168e-15, (1256, 1) = -1.4789170788505026, (1256, 2) = 0.6499540417218052e-16, (1257, 1) = -1.4780075863850504, (1257, 2) = -0.6501225915419168e-16, (1258, 1) = -1.4770980939195981, (1258, 2) = -0.6502911687516436e-16, (1259, 1) = -1.4761886014541459, (1259, 2) = -0.3902758639672999e-15, (1260, 1) = -1.4752791089886936, (1260, 2) = -0.4554398835358131e-15, (1261, 1) = -1.4743696165232414, (1261, 2) = 0.2603188255984541e-15, (1262, 1) = -1.4734601240577891, (1262, 2) = -0.1301931500082179e-15, (1263, 1) = -1.4716411391268847, (1263, 2) = -0.6513032031394257e-16, (1264, 1) = -1.46982215419598, (1264, 2) = 0.6516407637614293e-16, (1265, 1) = -1.4689126617305277, (1265, 2) = -0.26072383368412965e-15, (1266, 1) = -1.4680031692650752, (1266, 2) = -0.2607913725278454e-15, (1267, 1) = -1.467093676799623, (1267, 2) = 0.6521473050154311e-16, (1268, 1) = -1.4661841843341707, (1268, 2) = -0.3261581026118693e-15, (1269, 1) = -1.4652746918687185, (1269, 2) = -0.26099405274812997e-15, (1270, 1) = -1.4643651994032663, (1270, 2) = 0.19579622546424182e-15, (1271, 1) = -1.463455706937814, (1271, 2) = -0.1305646128361249e-15, (1272, 1) = -1.4625462144723618, (1272, 2) = 0.3264960348475251e-15, (1273, 1) = -1.461551372647613, (1273, 2) = -0.13063539301984078e-15, (1274, 1) = -1.4605565308228643, (1274, 2) = .0, (1275, 1) = -1.4595616889981156, (1275, 2) = 0.6535468493420199e-16, (1276, 1) = -1.4585668471733668, (1276, 2) = 0.2614927351933575e-15, (1277, 1) = -1.457572005348618, (1277, 2) = -0.32695842875306815e-15, (1278, 1) = -1.4565771635238693, (1278, 2) = .0, (1279, 1) = -1.4555823216991206, (1279, 2) = .0, (1280, 1) = -1.4545874798743719, (1280, 2) = 0.6544721003686383e-16, (1281, 1) = -1.4535926380496231, (1281, 2) = -0.19639717272649923e-15, (1282, 1) = -1.4525977962248744, (1282, 2) = -0.3929054489143248e-15, (1283, 1) = -1.4516029544001257, (1283, 2) = 0.13100552351494923e-15, (1284, 1) = -1.450608112575377, (1284, 2) = -0.2620851401894011e-15, (1285, 1) = -1.4496132707506282, (1285, 2) = .0, (1286, 1) = -1.4486184289258794, (1286, 2) = 0.19667502192309153e-15, (1287, 1) = -1.4476235871011307, (1287, 2) = 0.6557687292455359e-16, (1288, 1) = -1.446628745276382, (1288, 2) = -0.26238163274254173e-15, (1289, 1) = -1.4456339034516332, (1289, 2) = 0.19684183924221585e-15, (1290, 1) = -1.4446390616268845, (1290, 2) = -0.19689746279890087e-15, (1291, 1) = -1.4436442198021358, (1291, 2) = -0.13130206346413106e-15, (1292, 1) = -1.442649377977387, (1292, 2) = -0.3283478940054364e-15, (1293, 1) = -1.4416545361526383, (1293, 2) = 0.13137625759278588e-15, (1294, 1) = -1.4406596943278895, (1294, 2) = -0.13141336341530218e-15, (1295, 1) = -1.4396648525031408, (1295, 2) = 0.1971757125735142e-15, (1296, 1) = -1.438670010678392, (1296, 2) = -0.6574379623657129e-16, (1297, 1) = -1.4376751688536433, (1297, 2) = 0.6576235783344253e-16, (1298, 1) = -1.4366803270288946, (1298, 2) = .0, (1299, 1) = -1.4356854852041459, (1299, 2) = 0.13159897927967557e-15, (1300, 1) = -1.4346906433793971, (1300, 2) = 0.19745417948525078e-15, (1301, 1) = -1.4327009597298996, (1301, 2) = 0.13171041744756575e-15, (1302, 1) = -1.430711276080402, (1302, 2) = 0.6589236890638412e-16, (1303, 1) = -1.4298528958322865, (1303, 2) = -0.1977252115405529e-15, (1304, 1) = -1.4289945155841708, (1304, 2) = 0.6592444086547626e-16, (1305, 1) = -1.4281361353360553, (1305, 2) = -0.19782143986623553e-15, (1306, 1) = -1.4272777550879399, (1306, 2) = -0.6595652110979516e-16, (1307, 1) = -1.4264193748398242, (1307, 2) = 0.13194512864349855e-15, (1308, 1) = -1.4255609945917087, (1308, 2) = -0.26395443833753103e-15, (1309, 1) = -1.4247026143435932, (1309, 2) = 0.264018627563159e-15, (1310, 1) = -1.4238442340954776, (1310, 2) = 0.13204141246809996e-15, (1311, 1) = -1.4229858538473619, (1311, 2) = .0, (1312, 1) = -1.4221274735992464, (1312, 2) = 0.6605281100337651e-16, (1313, 1) = -1.421269093351131, (1313, 2) = -0.1321377328310595e-15, (1314, 1) = -1.4204107131030153, (1314, 2) = -0.13216984767342019e-15, (1315, 1) = -1.4195523328548996, (1315, 2) = 0.661009832599247e-16, (1316, 1) = -1.418693952606784, (1316, 2) = 0.6611704467816617e-16, (1317, 1) = -1.4178355723586686, (1317, 2) = 0.13226621616882505e-15, (1318, 1) = -1.416977192110553, (1318, 2) = .0, (1319, 1) = -1.4161188118624373, (1319, 2) = .0, (1320, 1) = -1.4152604316143218, (1320, 2) = -0.6618131016074265e-16, (1321, 1) = -1.4144020513662063, (1321, 2) = -0.6619738144849714e-16, (1322, 1) = -1.4135436711180906, (1322, 2) = -0.26485381875571077e-15, (1323, 1) = -1.412685290869975, (1323, 2) = -0.331147649374623e-15, (1324, 1) = -1.4118269106218595, (1324, 2) = -0.662456069993635e-16, (1325, 1) = -1.410968530373744, (1325, 2) = -0.13252337211021065e-15, (1326, 1) = -1.4101101501256283, (1326, 2) = -0.6627776703499632e-16, (1327, 1) = -1.4092517698775127, (1327, 2) = 0.66293849931868e-16, (1328, 1) = -1.4083933896293972, (1328, 2) = 0.6630993473853714e-16, (1329, 1) = -1.4075350093812817, (1329, 2) = -0.13265204289561155e-15, (1330, 1) = -1.406676629133166, (1330, 2) = -0.1326842201049223e-15, (1331, 1) = -1.4058182488850504, (1331, 2) = 0.13271640109055146e-15, (1332, 1) = -1.404959868636935, (1332, 2) = 0.13274858583801445e-15, (1333, 1) = -1.4041014883888194, (1333, 2) = .0, (1334, 1) = -1.4032431081407037, (1334, 2) = .0, (1335, 1) = -1.4022655132349249, (1335, 2) = -0.6642481713882445e-16, (1336, 1) = -1.401287918329146, (1336, 2) = -0.1993294601941194e-15, (1337, 1) = -1.4003103234233671, (1337, 2) = -0.6646149204701111e-16, (1338, 1) = -1.3993327285175883, (1338, 2) = -0.19943949922470236e-15, (1339, 1) = -1.3983551336118094, (1339, 2) = -0.19949452941253855e-15, (1340, 1) = -1.3973775387060305, (1340, 2) = 0.2660660888958381e-15, (1341, 1) = -1.3963999438002515, (1341, 2) = 0.19960461096998368e-15, (1342, 1) = -1.3954223488944726, (1342, 2) = 0.6655322075801319e-16, (1343, 1) = -1.3944447539886937, (1343, 2) = .0, (1344, 1) = -1.3934671590829146, (1344, 2) = -0.13317985717891256e-15, (1345, 1) = -1.3924895641771358, (1345, 2) = 0.13321657192842358e-15, (1346, 1) = -1.391511969271357, (1346, 2) = -0.2665065825211186e-15, (1347, 1) = -1.390534374365578, (1347, 2) = .0, (1348, 1) = -1.3895567794597992, (1348, 2) = -0.6666337179206961e-16, (1349, 1) = -1.3885791845540203, (1349, 2) = 0.13336347653117387e-15, (1350, 1) = -1.3876015896482414, (1350, 2) = -0.133400213972014e-15, (1351, 1) = -1.3866239947424626, (1351, 2) = 0.13343695588432778e-15, (1352, 1) = -1.3856463998366837, (1352, 2) = 0.20021055336859892e-15, (1353, 1) = -1.3846688049309046, (1353, 2) = 0.6675522651689735e-16, (1354, 1) = -1.3836912100251257, (1354, 2) = -0.6677360411301472e-16, (1355, 1) = -1.3827136151193469, (1355, 2) = -0.20037595169985153e-15, (1356, 1) = -1.3817360202135678, (1356, 2) = -0.33405182933205638e-15, (1357, 1) = -1.380758425307789, (1357, 2) = -0.6682875000107795e-16, (1358, 1) = -1.37978083040201, (1358, 2) = -0.2673885451704234e-15, (1359, 1) = -1.3778256405904523, (1359, 2) = -0.1337678306014768e-15, (1360, 1) = -1.3758704507788946, (1360, 2) = -0.6692070279953791e-16, (1361, 1) = -1.3748928558731157, (1361, 2) = 0.1338781994086061e-15, (1362, 1) = -1.3739152609673368, (1362, 2) = -0.26782999478928663e-15, (1363, 1) = -1.3729376660615578, (1363, 2) = 0.6697589976706892e-16, (1364, 1) = -1.371960071155779, (1364, 2) = -0.1339886058039883e-15, (1365, 1) = -1.3710157627386934, (1365, 2) = 0.6701208137183715e-16, (1366, 1) = -1.3700714543216082, (1366, 2) = -0.33514930873679063e-15, (1367, 1) = -1.3691271459045227, (1367, 2) = -0.26819057607231063e-15, (1368, 1) = -1.3681828374874372, (1368, 2) = 0.6706542817349381e-16, (1369, 1) = -1.3672385290703517, (1369, 2) = 0.13416642840616398e-15, (1370, 1) = -1.3662942206532662, (1370, 2) = -0.20130300628888484e-15, (1371, 1) = -1.365349912236181, (1371, 2) = .0, (1372, 1) = -1.3644056038190955, (1372, 2) = -0.6713658343129289e-16, (1373, 1) = -1.3625169869849247, (1373, 2) = .0, (1374, 1) = -1.3606283701507538, (1374, 2) = 0.6720776799818873e-16, (1375, 1) = -1.3596840617336683, (1375, 2) = -0.6722556863954547e-16, (1376, 1) = -1.3587397533165828, (1376, 2) = 0.3362168552966555e-15, (1377, 1) = -1.3577954448994976, (1377, 2) = 0.13452235049358705e-15, (1378, 1) = -1.356851136482412, (1378, 2) = -0.1345579623823156e-15, (1379, 1) = -1.3559068280653266, (1379, 2) = -0.6729678888162605e-16, (1380, 1) = -1.3549625196482413, (1380, 2) = 0.3365729915368876e-15, (1381, 1) = -1.3540182112311558, (1381, 2) = .0, (1382, 1) = -1.3530739028140704, (1382, 2) = 0.5388017785706576e-15, (1383, 1) = -1.3521295943969849, (1383, 2) = -0.6736803688777905e-16, (1384, 1) = -1.3511852859798994, (1384, 2) = 0.13477170629199265e-15, (1385, 1) = -1.3502409775628141, (1385, 2) = .0, (1386, 1) = -1.3492966691457287, (1386, 2) = -0.2696859627759048e-15, (1387, 1) = -1.3483523607286432, (1387, 2) = -0.6743931196179816e-16, (1388, 1) = -1.347408052311558, (1388, 2) = .0, (1389, 1) = -1.3464637438944724, (1389, 2) = 0.20242487829024386e-15, (1390, 1) = -1.345519435477387, (1390, 2) = 0.33746392804231574e-15, (1391, 1) = -1.343630818643216, (1391, 2) = 0.2025853283950062e-15, (1392, 1) = -1.3417422018090452, (1392, 2) = 0.13512821271650467e-15, (1393, 1) = -1.3407985102858042, (1393, 2) = -0.27032771539192e-15, (1394, 1) = -1.339854818762563, (1394, 2) = 0.20279925868408135e-15, (1395, 1) = -1.3389111272393217, (1395, 2) = -0.6761757848720178e-16, (1396, 1) = -1.3379674357160805, (1396, 2) = 0.40581243368573307e-15, (1397, 1) = -1.3370237441928392, (1397, 2) = 0.33826617132358255e-15, (1398, 1) = -1.336080052669598, (1398, 2) = 0.6767106442722301e-16, (1399, 1) = -1.3351363611463567, (1399, 2) = -0.13537779218104665e-15, (1400, 1) = -1.3341926696231154, (1400, 2) = -0.20312018772992697e-15, (1401, 1) = -1.3304179035301507, (1401, 2) = -0.6777807652231818e-16, (1402, 1) = -1.3266431374371859, (1402, 2) = .0, (1403, 1) = -1.3256994459139446, (1403, 2) = -0.6786729276774424e-16, (1404, 1) = -1.3247557543907034, (1404, 2) = -0.1357702803765349e-15, (1405, 1) = -1.3238120628674621, (1405, 2) = -0.20370896691700808e-15, (1406, 1) = -1.322868371344221, (1406, 2) = 0.203762517325079e-15, (1407, 1) = -1.32192467982098, (1407, 2) = 0.679386905847244e-16, (1408, 1) = -1.3209809882977388, (1408, 2) = .0, (1409, 1) = -1.3200372967744975, (1409, 2) = .0, (1410, 1) = -1.3190936052512563, (1410, 2) = .0, (1411, 1) = -1.318149913728015, (1411, 2) = 0.34005054830243826e-15, (1412, 1) = -1.3172062222047738, (1412, 2) = .0, (1413, 1) = -1.3162625306815325, (1413, 2) = -0.13609165387342669e-15, (1414, 1) = -1.3153188391582915, (1414, 2) = -0.1361273749365728e-15, (1415, 1) = -1.3143751476350505, (1415, 2) = -0.6808154924643594e-16, (1416, 1) = -1.3134314561118092, (1416, 2) = .0, (1417, 1) = -1.312487764588568, (1417, 2) = 0.6811727649513037e-16, (1418, 1) = -1.3115440730653267, (1418, 2) = 0.34067570970974324e-15, (1419, 1) = -1.3106038532129398, (1419, 2) = 0.3407647142877007e-15, (1420, 1) = -1.309663633360553, (1420, 2) = -0.681707449516565e-16, (1421, 1) = -1.308723413508166, (1421, 2) = -0.6818854821248227e-16, (1422, 1) = -1.307783193655779, (1422, 2) = 0.6820635262817842e-16, (1423, 1) = -1.3068429738033922, (1423, 2) = -0.13644831637376467e-15, (1424, 1) = -1.3059027539510053, (1424, 2) = 0.1364839297534155e-15, (1425, 1) = -1.3049625340986184, (1425, 2) = 0.20477931805723426e-15, (1426, 1) = -1.3040223142462313, (1426, 2) = .0, (1427, 1) = -1.3030820943938441, (1427, 2) = .0, (1428, 1) = -1.3021418745414572, (1428, 2) = .0, (1429, 1) = -1.3012016546890703, (1429, 2) = 0.13666202974996318e-15, (1430, 1) = -1.3002614348366834, (1430, 2) = 0.13669765620119752e-15, (1431, 1) = -1.2993212149842965, (1431, 2) = 0.27346656949388135e-15, (1432, 1) = -1.2983809951319096, (1432, 2) = .0, (1433, 1) = -1.2974407752795227, (1433, 2) = -0.6840227401264883e-16, (1434, 1) = -1.2965005554271358, (1434, 2) = 0.6842009135473232e-16, (1435, 1) = -1.295560335574749, (1435, 2) = 0.6843790969562326e-16, (1436, 1) = -1.294620115722362, (1436, 2) = .0, (1437, 1) = -1.2936798958699751, (1437, 2) = 0.684735493251183e-16, (1438, 1) = -1.292739676017588, (1438, 2) = -0.2739654823572322e-15, (1439, 1) = -1.2917994561652009, (1439, 2) = 0.13701838560695306e-15, (1440, 1) = -1.290859236312814, (1440, 2) = .0, (1441, 1) = -1.289919016460427, (1441, 2) = 0.6854484003265776e-16, (1442, 1) = -1.2889787966080402, (1442, 2) = .0, (1443, 1) = -1.2852179171984925, (1443, 2) = .0, (1444, 1) = -1.2814570377889447, (1444, 2) = .0, (1445, 1) = -1.280553780857412, (1445, 2) = -0.13744485582317373e-15, (1446, 1) = -1.2796505239258793, (1446, 2) = 0.1374791204381242e-15, (1447, 1) = -1.2787472669943467, (1447, 2) = 0.3437834662184316e-15, (1448, 1) = -1.2778440100628141, (1448, 2) = -0.6877382697428641e-16, (1449, 1) = -1.2769407531312815, (1449, 2) = 0.3439548069983428e-15, (1450, 1) = -1.2760374961997487, (1450, 2) = -0.1376161930172368e-15, (1451, 1) = -1.275134239268216, (1451, 2) = 0.20647569686970244e-15, (1452, 1) = -1.2742309823366833, (1452, 2) = 0.13768473746452015e-15, (1453, 1) = -1.2733277254051507, (1453, 2) = -0.20657851747325928e-15, (1454, 1) = -1.2724244684736181, (1454, 2) = .0, (1455, 1) = -1.2715212115420855, (1455, 2) = 0.13778756382586245e-15, (1456, 1) = -1.2706179546105527, (1456, 2) = -0.6891092088662661e-16, (1457, 1) = -1.26971469767902, (1457, 2) = 0.13785612092961915e-15, (1458, 1) = -1.2688114407474873, (1458, 2) = 0.6894520063610007e-16, (1459, 1) = -1.2679081838159547, (1459, 2) = 0.6896234138909726e-16, (1460, 1) = -1.2670049268844221, (1460, 2) = -0.6897948271237953e-16, (1461, 1) = -1.2661016699528895, (1461, 2) = -0.1379932491890089e-15, (1462, 1) = -1.265198413021357, (1462, 2) = .0, (1463, 1) = -1.2642951560898243, (1463, 2) = -0.6903090998940851e-16, (1464, 1) = -1.2633918991582915, (1464, 2) = 0.1380961069583974e-15, (1465, 1) = -1.2615853852952261, (1465, 2) = 0.6908234198582653e-16, (1466, 1) = -1.259778871432161, (1466, 2) = .0, (1467, 1) = -1.2588756145006283, (1467, 2) = -0.6913377838987428e-16, (1468, 1) = -1.2579723575690955, (1468, 2) = 0.34575462391617705e-15, (1469, 1) = -1.2570691006375627, (1469, 2) = -0.13833614323973592e-15, (1470, 1) = -1.2561658437060301, (1470, 2) = .0, (1471, 1) = -1.2552625867744975, (1471, 2) = 0.2768094663049513e-15, (1472, 1) = -1.254359329842965, (1472, 2) = 0.6921951467256799e-16, (1473, 1) = -1.2534560729114324, (1473, 2) = 0.13847332633071038e-15, (1474, 1) = -1.2525528159798995, (1474, 2) = -0.6925381204284337e-16, (1475, 1) = -1.251576371315955, (1475, 2) = 0.6927235085267674e-16, (1476, 1) = -1.25059992665201, (1476, 2) = .0, (1477, 1) = -1.2496234819880654, (1477, 2) = .0, (1478, 1) = -1.2486470373241207, (1478, 2) = -0.6932796974780773e-16, (1479, 1) = -1.2476705926601759, (1479, 2) = 0.34673255075758775e-15, (1480, 1) = -1.2466941479962312, (1480, 2) = -0.2080951527486492e-15, (1481, 1) = -1.2457177033322866, (1481, 2) = -0.6938359202685466e-16, (1482, 1) = -1.2447412586683417, (1482, 2) = -0.13880426693670776e-15, (1483, 1) = -1.2427883693404522, (1483, 2) = -0.6943921728347694e-16, (1484, 1) = -1.2408354800125627, (1484, 2) = .0, (1485, 1) = -1.239859035348618, (1485, 2) = 0.2084845353269897e-15, (1486, 1) = -1.2388825906846734, (1486, 2) = -0.6951338821739625e-16, (1487, 1) = -1.2379061460207286, (1487, 2) = 0.6953193155029857e-16, (1488, 1) = -1.236929701356784, (1488, 2) = 0.3477523754619682e-15, (1489, 1) = -1.2359532566928393, (1489, 2) = -0.13913803765668532e-15, (1490, 1) = -1.2349768120288944, (1490, 2) = 0.6958756274277772e-16, (1491, 1) = -1.2340003673649498, (1491, 2) = .0, (1492, 1) = -1.2330239227010051, (1492, 2) = 0.6962465104548932e-16, (1493, 1) = -1.2320474780370603, (1493, 2) = 0.20892958620865464e-15, (1494, 1) = -1.2310710333731156, (1494, 2) = -0.6966173987700442e-16, (1495, 1) = -1.230094588709171, (1495, 2) = .0, (1496, 1) = -1.2291181440452261, (1496, 2) = -0.13939765822666683e-15, (1497, 1) = -1.2281416993812813, (1497, 2) = 0.13943474768885795e-15, (1498, 1) = -1.2271652547173366, (1498, 2) = -0.13947183726004147e-15, (1499, 1) = -1.226188810053392, (1499, 2) = -0.34877231727239413e-15, (1500, 1) = -1.2252123653894471, (1500, 2) = 0.13954601660428838e-15, (1501, 1) = -1.2242359207255025, (1501, 2) = -0.20937465947198565e-15, (1502, 1) = -1.2232594760615578, (1502, 2) = -0.20943029401294324e-15, (1503, 1) = -1.222283031397613, (1503, 2) = -0.6982864282735507e-16, (1504, 1) = -1.2213065867336683, (1504, 2) = -0.13969437522134893e-15, (1505, 1) = -1.2203759641677134, (1505, 2) = 0.27945944832958586e-15, (1506, 1) = -1.2194453416017588, (1506, 2) = -0.13976507297994717e-15, (1507, 1) = -1.218514719035804, (1507, 2) = .0, (1508, 1) = -1.2175840964698492, (1508, 2) = .0, (1509, 1) = -1.2166534739038943, (1509, 2) = 0.2098066775711861e-15, (1510, 1) = -1.2157228513379397, (1510, 2) = -0.13990646640766335e-15, (1511, 1) = -1.214792228771985, (1511, 2) = -0.6997090708422143e-16, (1512, 1) = -1.2138616062060301, (1512, 2) = 0.13997716163542317e-15, (1513, 1) = -1.2129309836400752, (1513, 2) = 0.14001250878084966e-15, (1514, 1) = -1.2120003610741206, (1514, 2) = 0.1400478555769193e-15, (1515, 1) = -1.211069738508166, (1515, 2) = -0.7004160099789015e-16, (1516, 1) = -1.210139115942211, (1516, 2) = -0.1401185480095325e-15, (1517, 1) = -1.2092084933762561, (1517, 2) = 0.14015389359022693e-15, (1518, 1) = -1.2082778708103015, (1518, 2) = 0.14018923870986607e-15, (1519, 1) = -1.2073472482443468, (1519, 2) = -0.14022458334040377e-15, (1520, 1) = -1.206416625678392, (1520, 2) = 0.2103898911806177e-15, (1521, 1) = -1.205486003112437, (1521, 2) = -0.21044290653261986e-15, (1522, 1) = -1.2045553805464824, (1522, 2) = 0.28066122803243145e-15, (1523, 1) = -1.2036247579805277, (1523, 2) = -0.7018297820445579e-16, (1524, 1) = -1.2026941354145728, (1524, 2) = -0.2808025963430885e-15, (1525, 1) = -1.201763512848618, (1525, 2) = -0.7021831963788757e-16, (1526, 1) = -1.2008328902826633, (1526, 2) = .0, (1527, 1) = -1.1999022677167086, (1527, 2) = -0.7025365969771634e-16, (1528, 1) = -1.1989716451507537, (1528, 2) = -0.21081398753090682e-15, (1529, 1) = -1.1980410225847988, (1529, 2) = -0.2108669948102973e-15, (1530, 1) = -1.1971104000188442, (1530, 2) = -0.7030666696281534e-16, (1531, 1) = -1.1961797774528895, (1531, 2) = 0.1406486704816034e-15, (1532, 1) = -1.1952491548869346, (1532, 2) = .0, (1533, 1) = -1.193387909755025, (1533, 2) = 0.703773374428548e-16, (1534, 1) = -1.1915266646231155, (1534, 2) = 0.14082533981402613e-15, (1535, 1) = -1.1905472281940954, (1535, 2) = -0.7043126198676495e-16, (1536, 1) = -1.1895677917650753, (1536, 2) = -0.35224926747267833e-15, (1537, 1) = -1.1885883553360552, (1537, 2) = 0.14093688882681087e-15, (1538, 1) = -1.1876089189070351, (1538, 2) = -0.7048703472642434e-16, (1539, 1) = -1.186629482478015, (1539, 2) = -0.14101124883322465e-15, (1540, 1) = -1.185650046048995, (1540, 2) = 0.2115726404008776e-15, (1541, 1) = -1.1846706096199748, (1541, 2) = -0.21162840558127368e-15, (1542, 1) = -1.1836911731909547, (1542, 2) = 0.21168416873981352e-15, (1543, 1) = -1.1827117367619346, (1543, 2) = -0.21173992982519496e-15, (1544, 1) = -1.1817323003329145, (1544, 2) = -0.14119712585735e-15, (1545, 1) = -1.1807528639038944, (1545, 2) = 0.7061714852360672e-16, (1546, 1) = -1.1797734274748743, (1546, 2) = -0.3531786668800104e-15, (1547, 1) = -1.1787939910458543, (1547, 2) = .0, (1548, 1) = -1.1778145546168342, (1548, 2) = -0.21201870235280056e-15, (1549, 1) = -1.176835118187814, (1549, 2) = 0.7069148330560222e-16, (1550, 1) = -1.175855681758794, (1550, 2) = 0.21213019504599924e-15, (1551, 1) = -1.1748762453297739, (1551, 2) = 0.7072864589611672e-16, (1552, 1) = -1.1738968089007538, (1552, 2) = .0, (1553, 1) = -1.1729173724717337, (1553, 2) = -0.7076580510131993e-16, (1554, 1) = -1.1719379360427136, (1554, 2) = .0, (1555, 1) = -1.1709584996136935, (1555, 2) = -0.212408882345592e-15, (1556, 1) = -1.1699790631846734, (1556, 2) = -0.7082153725670996e-16, (1557, 1) = -1.1689996267556533, (1557, 2) = .0, (1558, 1) = -1.1680201903266332, (1558, 2) = 0.7085868738792645e-16, (1559, 1) = -1.167040753897613, (1559, 2) = -0.14175452201831313e-15, (1560, 1) = -1.166061317468593, (1560, 2) = -0.7089583364399038e-16, (1561, 1) = -1.1650818810395729, (1561, 2) = 0.2127432158243452e-15, (1562, 1) = -1.1641024446105528, (1562, 2) = -0.7093297588385408e-16, (1563, 1) = -1.1631230081815327, (1563, 2) = 0.7095154545350046e-16, (1564, 1) = -1.1621435717525126, (1564, 2) = 0.2129103418979505e-15, (1565, 1) = -1.1611641353234925, (1565, 2) = 0.7098868140353539e-16, (1566, 1) = -1.1601846988944724, (1566, 2) = .0, (1567, 1) = -1.1459986857286433, (1567, 2) = .0, (1568, 1) = -1.1318126725628141, (1568, 2) = .0, (1569, 1) = -1.1161344723618092, (1569, 2) = .0, (1570, 1) = -1.1004562721608042, (1570, 2) = .0, (1571, 1) = -1.0995177106752516, (1571, 2) = -0.7215437023537088e-16, (1572, 1) = -1.0985791491896988, (1572, 2) = 0.2886882411704876e-15, (1573, 1) = -1.097640587704146, (1573, 2) = 0.7218974824388096e-16, (1574, 1) = -1.0967020262185931, (1574, 2) = -0.14441486814347668e-15, (1575, 1) = -1.0957634647330403, (1575, 2) = 0.7222511775875846e-16, (1576, 1) = -1.0948249032474875, (1576, 2) = .0, (1577, 1) = -1.0938863417619347, (1577, 2) = -0.21678143592124545e-15, (1578, 1) = -1.092947780276382, (1578, 2) = -0.7227815580005117e-16, (1579, 1) = -1.0920092187908295, (1579, 2) = -0.7229583074884879e-16, (1580, 1) = -1.0910706573052766, (1580, 2) = 0.36156751734621554e-15, (1581, 1) = -1.0901320958197238, (1581, 2) = -0.21699352183092985e-15, (1582, 1) = -1.089193534334171, (1582, 2) = 0.14469768430886524e-15, (1583, 1) = -1.0882549728486182, (1583, 2) = -0.1447330161679372e-15, (1584, 1) = -1.0873164113630653, (1584, 2) = .0, (1585, 1) = -1.0863778498775125, (1585, 2) = -0.1448036660571619e-15, (1586, 1) = -1.08543928839196, (1586, 2) = -0.7241949200824294e-16, (1587, 1) = -1.0779307965075378, (1587, 2) = -0.7256067767449474e-16, (1588, 1) = -1.0704223046231156, (1588, 2) = -0.7270170365334883e-16, (1589, 1) = -1.0694860276224873, (1589, 2) = 0.14543855467420623e-15, (1590, 1) = -1.0685497506218593, (1590, 2) = .0, (1591, 1) = -1.0676134736212313, (1591, 2) = .0, (1592, 1) = -1.0666771966206032, (1592, 2) = -0.14554396489507215e-15, (1593, 1) = -1.0657409196199752, (1593, 2) = 0.7278954544372584e-16, (1594, 1) = -1.064804642619347, (1594, 2) = -0.728071057227023e-16, (1595, 1) = -1.0638683656187187, (1595, 2) = 0.14564932653257104e-15, (1596, 1) = -1.0629320886180906, (1596, 2) = -0.7284221805627015e-16, (1597, 1) = -1.0619958116174626, (1597, 2) = 0.21857931022327596e-15, (1598, 1) = -1.0610595346168343, (1598, 2) = .0, (1599, 1) = -1.060123257616206, (1599, 2) = -0.21868459716658932e-15, (1600, 1) = -1.059186980615578, (1600, 2) = -0.7291240931522327e-16, (1601, 1) = -1.05825070361495, (1601, 2) = -0.21878985018972746e-15, (1602, 1) = -1.0573144266143217, (1602, 2) = -0.14589497589579172e-15, (1603, 1) = -1.0563781496136935, (1603, 2) = 0.729650229507998e-16, (1604, 1) = -1.0554418726130654, (1604, 2) = 0.7298255505354519e-16, (1605, 1) = -1.0545055956124374, (1605, 2) = -0.21900025271309264e-15, (1606, 1) = -1.0535693186118091, (1606, 2) = 0.7301761048479697e-16, (1607, 1) = -1.0526330416111809, (1607, 2) = 0.14607026755271625e-15, (1608, 1) = -1.0516967646105528, (1608, 2) = -0.21915796228161078e-15, (1609, 1) = -1.0507604876099248, (1609, 2) = 0.1461403428375945e-15, (1610, 1) = -1.0498242106092965, (1610, 2) = -0.1461753714651552e-15, (1611, 1) = -1.0488879336086683, (1611, 2) = 0.14621039403324876e-15, (1612, 1) = -1.0479516566080402, (1612, 2) = 0.1462454105046507e-15, (1613, 1) = -1.0470153796074122, (1613, 2) = -0.29256084168417145e-15, (1614, 1) = -1.046079102606784, (1614, 2) = 0.3657885625205698e-15, (1615, 1) = -1.0451428256061557, (1615, 2) = 0.3658760574142515e-15, (1616, 1) = -1.0442065486055276, (1616, 2) = 0.7319270733853824e-16, (1617, 1) = -1.0432702716048996, (1617, 2) = 0.14642040010487758e-15, (1618, 1) = -1.0423339946042716, (1618, 2) = -0.7322768960578766e-16, (1619, 1) = -1.0413977176036435, (1619, 2) = 0.14649035195959057e-15, (1620, 1) = -1.0404614406030153, (1620, 2) = -0.14652531831129346e-15, (1621, 1) = -1.0248143213065326, (1621, 2) = -0.1471086965114306e-15, (1622, 1) = -1.0091672020100502, (1622, 2) = -0.14769009945764272e-15, (1623, 1) = -1.008266479004397, (1623, 2) = .0, (1624, 1) = -1.0073657559987437, (1624, 2) = 0.7387845056847929e-16, (1625, 1) = -1.0064650329930904, (1625, 2) = 0.14779029116836663e-15, (1626, 1) = -1.0055643099874372, (1626, 2) = .0, (1627, 1) = -1.004663586981784, (1627, 2) = .0, (1628, 1) = -1.0037628639761307, (1628, 2) = 0.2218356264111475e-15, (1629, 1) = -1.0028621409704774, (1629, 2) = 0.7396188920894308e-16, (1630, 1) = -1.0019614179648242, (1630, 2) = 0.14795713183486065e-15, (1631, 1) = -1.001060694959171, (1631, 2) = -0.7399523891148694e-16, (1632, 1) = -1.0001599719535177, (1632, 2) = -0.22203572452020312e-15, (1633, 1) = -.9992592489478644, (1633, 2) = -0.2591000078990389e-15, (1634, 1) = -.9983585259422111, (1634, 2) = -0.14809047085969753e-15, (1635, 1) = -.9974578029365577, (1635, 2) = 0.14812378677770617e-15, (1636, 1) = -.9965570799309045, (1636, 2) = .0, (1637, 1) = -.9956563569252512, (1637, 2) = 0.7409519787944111e-16, (1638, 1) = -.994755633919598, (1638, 2) = -0.2593914553137913e-15, (1639, 1) = -.9938549109139447, (1639, 2) = 0.29651394805832157e-15, (1640, 1) = -.9929541879082915, (1640, 2) = 0.3707256288959744e-16, (1641, 1) = -.9920534649026382, (1641, 2) = 0.3708088032565543e-16, (1642, 1) = -.991152741896985, (1642, 2) = .0, (1643, 1) = -.9902520188913317, (1643, 2) = -0.22258505593900804e-15, (1644, 1) = -.9893512958856785, (1644, 2) = -0.18552910433334286e-15, (1645, 1) = -.9884505728800252, (1645, 2) = .0, (1646, 1) = -.9875498498743719, (1646, 2) = 0.11136731399458367e-15, (1647, 1) = -.9866491268687185, (1647, 2) = -0.3713074356820311e-16, (1648, 1) = -.9857484038630653, (1648, 2) = 0.37139047129013356e-16, (1649, 1) = -.984847680857412, (1649, 2) = -0.7429469734318147e-16, (1650, 1) = -.9839469578517588, (1650, 2) = 0.7431129637378047e-16, (1651, 1) = -.9830462348461055, (1651, 2) = .0, (1652, 1) = -.9821455118404523, (1652, 2) = -0.18586120549711752e-15, (1653, 1) = -.981244788834799, (1653, 2) = -0.7436106895703034e-16, (1654, 1) = -.9803440658291458, (1654, 2) = 0.2231329547642687e-15, (1655, 1) = -.9794216022644473, (1655, 2) = -0.22318389052145303e-15, (1656, 1) = -.9784991386997488, (1656, 2) = 0.14882320878427402e-15, (1657, 1) = -.9775766751350503, (1657, 2) = -0.14885714844691714e-15, (1658, 1) = -.9766542115703518, (1658, 2) = .0, (1659, 1) = -.9757317480056533, (1659, 2) = -0.3723125032331919e-16, (1660, 1) = -.9748092844409548, (1660, 2) = -0.11171918579880703e-15, (1661, 1) = -.9738868208762563, (1661, 2) = 0.11174461392928415e-15, (1662, 1) = -.9729643573115578, (1662, 2) = -0.37256678443944896e-16, (1663, 1) = -.9720418937468593, (1663, 2) = -0.11179544997687034e-15, (1664, 1) = -.9711194301821608, (1664, 2) = .0, (1665, 1) = -.9701969666174624, (1665, 2) = -0.1864104314597903e-15, (1666, 1) = -.9692745030527639, (1666, 2) = 0.26103385716449033e-15, (1667, 1) = -.9683520394880654, (1667, 2) = 0.2237940807778196e-15, (1668, 1) = -.9674295759233669, (1668, 2) = -0.3357672624040744e-15, (1669, 1) = -.9665071123586684, (1669, 2) = 0.1865796571300815e-15, (1670, 1) = -.9655846487939699, (1670, 2) = 0.7464877385943766e-16, (1671, 1) = -.9637397216645729, (1671, 2) = .0, (1672, 1) = -.9618947945351759, (1672, 2) = -0.37358185526686606e-16, (1673, 1) = -.9609723309704774, (1673, 2) = -0.3736662927156175e-16, (1674, 1) = -.9600498674057789, (1674, 2) = 0.11212521190406527e-15, (1675, 1) = -.9591274038410804, (1675, 2) = 0.7476701921209232e-16, (1676, 1) = -.9582049402763819, (1676, 2) = 0.7478389235120664e-16, (1677, 1) = -.9572824767116834, (1677, 2) = -0.7480076066663417e-16, (1678, 1) = -.9563600131469849, (1678, 2) = -0.14963524827653396e-15, (1679, 1) = -.9554375495822864, (1679, 2) = 0.2245034482379246e-15, (1680, 1) = -.9545150860175879, (1680, 2) = 0.7485133646960535e-16, (1681, 1) = -.9535926224528894, (1681, 2) = 0.3743409264449186e-16, (1682, 1) = -.952670158888191, (1682, 2) = .0, (1683, 1) = -.9517476953234925, (1683, 2) = 0.7490186813417427e-16, (1684, 1) = -.950825231758794, (1684, 2) = 0.14983740423905226e-15, (1685, 1) = -.9426771566834171, (1685, 2) = 0.375335885423714e-16, (1686, 1) = -.9345290816080403, (1686, 2) = -0.7521524905147453e-16, (1687, 1) = -.9324920628391961, (1687, 2) = .0, (1688, 1) = -.9304550440703518, (1688, 2) = 0.3764456474336513e-16, (1689, 1) = -.9294365346859297, (1689, 2) = -0.37653791545630494e-16, (1690, 1) = -.9284180253015076, (1690, 2) = 0.301304120152877e-15, (1691, 1) = -.9273995159170856, (1691, 2) = 0.7534447029961963e-16, (1692, 1) = -.9263810065326634, (1692, 2) = 0.2260887115423346e-15, (1693, 1) = -.9253624971482413, (1693, 2) = -0.11307199598046885e-15, (1694, 1) = -.9243439877638192, (1694, 2) = 0.22619925207042584e-15, (1695, 1) = -.9233254783793972, (1695, 2) = -0.3770908196441029e-16, (1696, 1) = -.922306968994975, (1696, 2) = -0.7543657034153772e-16, (1697, 1) = -.9212884596105528, (1697, 2) = -0.11318245485017655e-15, (1698, 1) = -.9202699502261308, (1698, 2) = 0.15094672515270667e-15, (1699, 1) = -.9192514408417087, (1699, 2) = 0.3774587417100299e-16, (1700, 1) = -.9182329314572866, (1700, 2) = -0.22653038150641676e-15, (1701, 1) = -.9173107546356785, (1701, 2) = 0.1888169042049196e-15, (1702, 1) = -.9163885778140705, (1702, 2) = 0.37771695231277246e-16, (1703, 1) = -.9154664009924625, (1703, 2) = 0.18890003372378932e-15, (1704, 1) = -.9145442241708543, (1704, 2) = 0.11336494611267128e-15, (1705, 1) = -.9126998705276383, (1705, 2) = 0.756098478378351e-16, (1706, 1) = -.9108555168844222, (1706, 2) = -0.37821520790866536e-16, (1707, 1) = -.9099333400628142, (1707, 2) = -0.7565962964372469e-16, (1708, 1) = -.9090111632412061, (1708, 2) = 0.37838105902078566e-16, (1709, 1) = -.9080889864195981, (1709, 2) = -0.37846394020906887e-16, (1710, 1) = -.9071668095979901, (1710, 2) = -0.18927339583864315e-15, (1711, 1) = -.906244632776382, (1711, 2) = -0.18931480665957398e-15, (1712, 1) = -.905322455954774, (1712, 2) = 0.3787124050282605e-16, (1713, 1) = -.904400279133166, (1713, 2) = 0.15151806667925117e-15, (1714, 1) = -.9034781023115579, (1714, 2) = -0.11366336946664532e-15, (1715, 1) = -.9025559254899498, (1715, 2) = -0.22737635969617685e-15, (1716, 1) = -.9016337486683418, (1716, 2) = 0.18952163520287754e-15, (1717, 1) = -.9007115718467338, (1717, 2) = 0.1516503643406501e-15, (1718, 1) = -.8997893950251257, (1718, 2) = 0.7584170414484605e-16, (1719, 1) = -.8988672182035177, (1719, 2) = -0.3792910999164596e-16, (1720, 1) = -.8979450413819097, (1720, 2) = -0.11381209449633025e-15, (1721, 1) = -.8970228645603016, (1721, 2) = .0, (1722, 1) = -.8961006877386936, (1722, 2) = .0, (1723, 1) = -.8951785109170856, (1723, 2) = 0.1138863323207555e-15, (1724, 1) = -.8942563340954774, (1724, 2) = -0.11391105957479701e-15, (1725, 1) = -.8933341572738694, (1725, 2) = -0.1139357774312878e-15, (1726, 1) = -.8924119804522614, (1726, 2) = 0.26590780033505853e-15, (1727, 1) = -.8905676268090453, (1727, 2) = 0.19001645715308148e-15, (1728, 1) = -.8887232731658292, (1728, 2) = 0.15207896615644015e-15, (1729, 1) = -.8877801746325378, (1729, 2) = 0.26619703782860455e-15, (1730, 1) = -.8868370760992463, (1730, 2) = -0.15214620651067387e-15, (1731, 1) = -.8858939775659549, (1731, 2) = 0.3043596130145613e-15, (1732, 1) = -.8849508790326635, (1732, 2) = -0.38053348247065845e-16, (1733, 1) = -.884007780499372, (1733, 2) = 0.15224696590710496e-15, (1734, 1) = -.8830646819660806, (1734, 2) = 0.38070131304311276e-16, (1735, 1) = -.8821215834327891, (1735, 2) = -0.38078517718020104e-16, (1736, 1) = -.8811784848994976, (1736, 2) = 0.22852140423744697e-15, (1737, 1) = -.880235386366206, (1737, 2) = -0.38095280257302125e-16, (1738, 1) = -.8792922878329146, (1738, 2) = 0.38103656359519963e-16, (1739, 1) = -.8783491892996231, (1739, 2) = -0.7622405800240201e-16, (1740, 1) = -.8774060907663317, (1740, 2) = -0.19060199085320449e-15, (1741, 1) = -.8764629922330403, (1741, 2) = 0.1143862915683739e-15, (1742, 1) = -.8755198936997488, (1742, 2) = .0, (1743, 1) = -.8745767951664574, (1743, 2) = 0.11443645418493224e-15, (1744, 1) = -.8736336966331659, (1744, 2) = -0.15261535956612066e-15, (1745, 1) = -.8726905980998745, (1745, 2) = -0.3816219152382765e-16, (1746, 1) = -.871747499566583, (1746, 2) = -0.3817053961343537e-16, (1747, 1) = -.8708044010332916, (1747, 2) = -0.19089442074287527e-15, (1748, 1) = -.8698613025000002, (1748, 2) = -0.1145616753523738e-15, (1749, 1) = -.8689182039667087, (1749, 2) = 0.11458668752485435e-15, (1750, 1) = -.8679751054334173, (1750, 2) = 0.38203896309246e-16, (1751, 1) = -.8670320069001258, (1751, 2) = .0, (1752, 1) = -.8660889083668343, (1752, 2) = -0.1146616592828431e-15, (1753, 1) = -.8651458098335427, (1753, 2) = -0.3822887605468371e-16, (1754, 1) = -.8642027113002513, (1754, 2) = -0.26766036764514964e-15, (1755, 1) = -.8632596127669598, (1755, 2) = .0, (1756, 1) = -.8623165142336684, (1756, 2) = -0.19126911532594407e-15, (1757, 1) = -.861373415700377, (1757, 2) = .0, (1758, 1) = -.8604303171670855, (1758, 2) = 0.15308174424479163e-15, (1759, 1) = -.8594872186337941, (1759, 2) = -0.3827873702022786e-16, (1760, 1) = -.8585441201005026, (1760, 2) = 0.38287034270728187e-16, (1761, 1) = -.8575850131846735, (1761, 2) = -0.3063637483598358e-15, (1762, 1) = -.8566259062688444, (1762, 2) = -0.15321559583540785e-15, (1763, 1) = -.8556667993530152, (1763, 2) = -0.76624650999568e-16, (1764, 1) = -.854707692437186, (1764, 2) = 0.2299244889312191e-15, (1765, 1) = -.8537485855213569, (1765, 2) = 0.1916458345626316e-15, (1766, 1) = -.8527894786055277, (1766, 2) = -0.7667516351831912e-16, (1767, 1) = -.8518303716896986, (1767, 2) = 0.7669198536499669e-16, (1768, 1) = -.8508712647738694, (1768, 2) = 0.7670879933985492e-16, (1769, 1) = -.8499121578580403, (1769, 2) = 0.15345121083528425e-15, (1770, 1) = -.8489530509422112, (1770, 2) = 0.11511360535962816e-15, (1771, 1) = -.847993944026382, (1771, 2) = -0.7675919378089084e-16, (1772, 1) = -.8470348371105528, (1772, 2) = -0.38387988007871626e-16, (1773, 1) = -.8460757301947237, (1773, 2) = -0.7679275025230654e-16, (1774, 1) = -.8451166232788945, (1774, 2) = 0.7680951646522366e-16, (1775, 1) = -.8441575163630654, (1775, 2) = 0.7682627462911661e-16, (1776, 1) = -.8431984094472362, (1776, 2) = 0.384215123592933e-16, (1777, 1) = -.8422393025314071, (1777, 2) = .0, (1778, 1) = -.841280195615578, (1778, 2) = -0.15375300114511706e-15, (1779, 1) = -.8403210886997488, (1779, 2) = 0.7689322628615918e-16, (1780, 1) = -.8393619817839196, (1780, 2) = 0.1538198876470687e-15, (1781, 1) = -.8374437679522613, (1781, 2) = 0.7694335426757932e-16, (1782, 1) = -.835525554120603, (1782, 2) = -0.3848836585021552e-16, (1783, 1) = -.8345664472047739, (1783, 2) = 0.7699340797373832e-16, (1784, 1) = -.8336073402889448, (1784, 2) = -0.19252518979375352e-15, (1785, 1) = -.8326482333731156, (1785, 2) = 0.15405347101219256e-15, (1786, 1) = -.8316891264572864, (1786, 2) = -0.11556508007081799e-15, (1787, 1) = -.8307300195414573, (1787, 2) = -0.7706002951518439e-16, (1788, 1) = -.8297709126256281, (1788, 2) = -0.15415332776865846e-15, (1789, 1) = -.828811805709799, (1789, 2) = .0, (1790, 1) = -.8278526987939698, (1790, 2) = 0.2698846752815498e-15, (1791, 1) = -.82697109290201, (1791, 2) = 0.38562587183947816e-16, (1792, 1) = -.8260894870100502, (1792, 2) = -0.3857021715139435e-16, (1793, 1) = -.8252078811180905, (1793, 2) = -0.3857784350397832e-16, (1794, 1) = -.8243262752261307, (1794, 2) = .0, (1795, 1) = -.8234446693341708, (1795, 2) = 0.7718617064895729e-16, (1796, 1) = -.822563063442211, (1796, 2) = 0.11580210231701274e-15, (1797, 1) = -.8216814575502511, (1797, 2) = 0.7721662513043839e-16, (1798, 1) = -.8207998516582914, (1798, 2) = 0.7723184138615494e-16, (1799, 1) = -.8172734280904521, (1799, 2) = .0, (1800, 1) = -.813747004522613, (1800, 2) = -0.3867665256731692e-16, (1801, 1) = -.8128653986306531, (1801, 2) = 0.1547369090270578e-15, (1802, 1) = -.8119837927386934, (1802, 2) = -0.7738359636070613e-16, (1803, 1) = -.8111021868467336, (1803, 2) = 0.386993653279622e-16, (1804, 1) = -.8102205809547738, (1804, 2) = -0.3870692868946458e-16, (1805, 1) = -.8093389750628139, (1805, 2) = -0.38714488254726355e-16, (1806, 1) = -.8084573691708541, (1806, 2) = -0.11616613204082115e-15, (1807, 1) = -.8075757632788942, (1807, 2) = -0.15491838382383855e-15, (1808, 1) = -.8066941573869345, (1808, 2) = -0.1162114322148915e-15, (1809, 1) = -.8058125514949748, (1809, 2) = 0.2712128184532167e-15, (1810, 1) = -.8049309456030149, (1810, 2) = 0.11625668634684021e-15, (1811, 1) = -.8040493397110551, (1811, 2) = -0.7751953071383803e-16, (1812, 1) = -.8031677338190952, (1812, 2) = -0.11630189419259033e-15, (1813, 1) = -.8022861279271354, (1813, 2) = 0.11632448068178203e-15, (1814, 1) = -.8014045220351756, (1814, 2) = -0.19391175917959137e-15, (1815, 1) = -.8005229161432159, (1815, 2) = -0.38789872879970764e-16, (1816, 1) = -.7996413102512561, (1816, 2) = 0.11639217004763878e-15, (1817, 1) = -.7846050969346732, (1817, 2) = 0.155699946532664e-15, (1818, 1) = -.7695688836180903, (1818, 2) = 0.19525696230744654e-15, (1819, 1) = -.7686362738253767, (1819, 2) = 0.27341434614501045e-15, (1820, 1) = -.7677036640326631, (1820, 2) = -0.11720096208101878e-15, (1821, 1) = -.7667710542399495, (1821, 2) = -0.19537388805438746e-15, (1822, 1) = -.765838444447236, (1822, 2) = 0.11724768913708996e-15, (1823, 1) = -.7649058346545226, (1823, 2) = .0, (1824, 1) = -.763973224861809, (1824, 2) = .0, (1825, 1) = -.7630406150690954, (1825, 2) = -0.39105890332269824e-16, (1826, 1) = -.7621080052763818, (1826, 2) = 0.1955682819030442e-15, (1827, 1) = -.7611753954836682, (1827, 2) = -0.1564856702055734e-15, (1828, 1) = -.7602427856909546, (1828, 2) = -0.7825834766447285e-16, (1829, 1) = -.759310175898241, (1829, 2) = 0.3913692521074463e-16, (1830, 1) = -.7583775661055275, (1830, 2) = -0.11743401502355414e-15, (1831, 1) = -.757444956312814, (1831, 2) = 0.15660965284460142e-15, (1832, 1) = -.7565123465201005, (1832, 2) = 0.35244134827405923e-15, (1833, 1) = -.7555797367273869, (1833, 2) = 0.11750364436000289e-15, (1834, 1) = -.7546471269346733, (1834, 2) = .0, (1835, 1) = -.7537145171419597, (1835, 2) = -0.3918332983791847e-16, (1836, 1) = -.7527819073492461, (1836, 2) = 0.15676418621010996e-15, (1837, 1) = -.7518492975565325, (1837, 2) = 0.11759627479627293e-15, (1838, 1) = -.750916687763819, (1838, 2) = -0.7841292992831721e-16, (1839, 1) = -.7499840779711056, (1839, 2) = -0.392141666362739e-16, (1840, 1) = -.749051468178392, (1840, 2) = 0.2353311796158457e-15, (1841, 1) = -.7481188583856784, (1841, 2) = -0.39229554850791137e-16, (1842, 1) = -.7471862485929648, (1842, 2) = 0.19618620684124896e-15, (1843, 1) = -.7462536388002512, (1843, 2) = -0.15697969123681187e-15, (1844, 1) = -.7453210290075376, (1844, 2) = 0.3925259916116407e-16, (1845, 1) = -.744388419214824, (1845, 2) = -0.23556162246984375e-15, (1846, 1) = -.7434558094221105, (1846, 2) = 0.27487555583693986e-15, (1847, 1) = -.7425231996293971, (1847, 2) = 0.1571023902325632e-15, (1848, 1) = -.7415905898366835, (1848, 2) = 0.15713301371660104e-15, (1849, 1) = -.7406579800439699, (1849, 2) = 0.2750363290405285e-15, (1850, 1) = -.7397253702512563, (1850, 2) = .0, (1851, 1) = -.7377301650753769, (1851, 2) = -0.11794466712013497e-15, (1852, 1) = -.7357349598994976, (1852, 2) = -0.15732481824165942e-15, (1853, 1) = -.7347373573115579, (1853, 2) = -0.15735741340548653e-15, (1854, 1) = -.7337397547236182, (1854, 2) = 0.27543247299647357e-15, (1855, 1) = -.7327421521356785, (1855, 2) = 0.39355632917984006e-16, (1856, 1) = -.7317445495477387, (1856, 2) = -0.1574550546515217e-15, (1857, 1) = -.7307469469597989, (1857, 2) = -0.2756032185315676e-15, (1858, 1) = -.7297493443718592, (1858, 2) = -0.2362800419934194e-15, (1859, 1) = -.7287517417839195, (1859, 2) = 0.7877623911845737e-16, (1860, 1) = -.7277541391959799, (1860, 2) = 0.11818867808165438e-15, (1861, 1) = -.7267565366080402, (1861, 2) = 0.27583028471217837e-15, (1862, 1) = -.7257589340201005, (1862, 2) = -0.7882484124902457e-16, (1863, 1) = -.7247613314321608, (1863, 2) = -0.19710254361480987e-15, (1864, 1) = -.7237637288442211, (1864, 2) = 0.3154287253389255e-15, (1865, 1) = -.7227661262562814, (1865, 2) = 0.3943666644227945e-16, (1866, 1) = -.7217685236683418, (1866, 2) = 0.3944473603225284e-16, (1867, 1) = -.7207709210804021, (1867, 2) = 0.7890559884365799e-16, (1868, 1) = -.7197733184924624, (1868, 2) = .0, (1869, 1) = -.7187757159045227, (1869, 2) = 0.3946890753793044e-16, (1870, 1) = -.717778113316583, (1870, 2) = -0.31581561786808375e-15, (1871, 1) = -.7167805107286433, (1871, 2) = -0.19742495333401418e-15, (1872, 1) = -.7157829081407036, (1872, 2) = -0.15797209128927798e-15, (1873, 1) = -.7147853055527638, (1873, 2) = 0.2765073407919642e-15, (1874, 1) = -.7137877029648241, (1874, 2) = 0.3950906823804315e-16, (1875, 1) = -.7127901003768844, (1875, 2) = .0, (1876, 1) = -.7117924977889447, (1876, 2) = 0.11857526506997022e-15, (1877, 1) = -.710794895201005, (1877, 2) = .0, (1878, 1) = -.7097972926130653, (1878, 2) = 0.39541083054041345e-16, (1879, 1) = -.7087996900251257, (1879, 2) = -0.11864721249288102e-15, (1880, 1) = -.707802087437186, (1880, 2) = 0.15822820882394317e-15, (1881, 1) = -.7069217463693468, (1881, 2) = -0.19782045046961084e-15, (1882, 1) = -.7060414053015076, (1882, 2) = -0.15828449189491448e-15, (1883, 1) = -.7051610642336684, (1883, 2) = 0.11873445250415668e-15, (1884, 1) = -.7042807231658292, (1884, 2) = -0.2375110419972206e-15, (1885, 1) = -.70340038209799, (1885, 2) = -0.7918438291497893e-16, (1886, 1) = -.7025200410301509, (1886, 2) = 0.19799602098940487e-15, (1887, 1) = -.7016396999623117, (1887, 2) = 0.1188186356300363e-15, (1888, 1) = -.7007593588944725, (1888, 2) = 0.2376792868990828e-15, (1889, 1) = -.6998790178266333, (1889, 2) = .0, (1890, 1) = -.6989986767587941, (1890, 2) = -0.3962720443647066e-16, (1891, 1) = -.6981183356909549, (1891, 2) = -0.23780515057103373e-15, (1892, 1) = -.6972379946231158, (1892, 2) = 0.35677056574863775e-15, (1893, 1) = -.6963576535552766, (1893, 2) = -0.3964815105644875e-16, (1894, 1) = -.6954773124874374, (1894, 2) = 0.2379307380255123e-15, (1895, 1) = -.6945969714195982, (1895, 2) = 0.11898626941427168e-15, (1896, 1) = -.693716630351759, (1896, 2) = .0, (1897, 1) = -.6866739018090455, (1897, 2) = 0.3972455761010677e-16, (1898, 1) = -.679631173266332, (1898, 2) = 0.7955945494436792e-16, (1899, 1) = -.6471277863316587, (1899, 2) = 0.4002983047667309e-16, (1900, 1) = -.6324618859296485, (1900, 2) = -0.4014015072579584e-16, (1901, 1) = -.6177959855276383, (1901, 2) = -0.8049765580611e-16, (1902, 1) = -.61054041459799, (1902, 2) = 0.4030197017955458e-16, (1903, 1) = -.6032848436683418, (1903, 2) = 0.16141876790575644e-15, (1904, 1) = -.6023778973021358, (1904, 2) = -0.807225046680219e-16, (1905, 1) = -.6014709509359297, (1905, 2) = -0.4036780601499214e-16, (1906, 1) = -.6005640045697237, (1906, 2) = -0.20187176503772307e-15, (1907, 1) = -.5996570582035177, (1907, 2) = -0.8076178659966317e-16, (1908, 1) = -.5978431654711056, (1908, 2) = .0, (1909, 1) = -.5960292727386935, (1909, 2) = 0.1212209616889085e-15, (1910, 1) = -.5951223263724875, (1910, 2) = 0.12124048152927617e-15, (1911, 1) = -.5942153800062815, (1911, 2) = 0.1616799747411654e-15, (1912, 1) = -.5933084336400755, (1912, 2) = -0.404264867444076e-16, (1913, 1) = -.5924014872738694, (1913, 2) = 0.40432973008616034e-16, (1914, 1) = -.5905875945414574, (1914, 2) = 0.12133777531505692e-15, (1915, 1) = -.5887737018090453, (1915, 2) = 0.24275309927962315e-15, (1916, 1) = -.5848726669974875, (1916, 2) = 0.16194621377313149e-15, (1917, 1) = -.5809716321859297, (1917, 2) = 0.4051412926053376e-16, (1918, 1) = -.5799963734830402, (1918, 2) = .0, (1919, 1) = -.5790211147801508, (1919, 2) = 0.1215836069126259e-15, (1920, 1) = -.5780458560772614, (1920, 2) = 0.12160418017542808e-15, (1921, 1) = -.5770705973743719, (1921, 2) = -0.8108315278518937e-16, (1922, 1) = -.5760953386714824, (1922, 2) = 0.8109683591715139e-16, (1923, 1) = -.575120079968593, (1923, 2) = 0.4055525140843358e-16, (1924, 1) = -.5741448212657037, (1924, 2) = -0.12168623018255932e-15, (1925, 1) = -.5731695625628141, (1925, 2) = -0.8113778780237872e-16, (1926, 1) = -.5653674929396986, (1926, 2) = -0.12186940889823572e-15, (1927, 1) = -.557565423316583, (1927, 2) = -0.16270739587272336e-15, (1928, 1) = -.5565862194912061, (1928, 2) = -0.28478486696502754e-15, (1929, 1) = -.5556070156658293, (1929, 2) = 0.16276098960969919e-15, (1930, 1) = -.5546278118404524, (1930, 2) = .0, (1931, 1) = -.5536486080150754, (1931, 2) = 0.16281444748614286e-15, (1932, 1) = -.5526694041896985, (1932, 2) = 0.8142056266466782e-16, (1933, 1) = -.5516902003643216, (1933, 2) = -0.40716942257660606e-16, (1934, 1) = -.5507109965389447, (1934, 2) = -0.12217078389839255e-15, (1935, 1) = -.5497317927135679, (1935, 2) = 0.8146047688606376e-16, (1936, 1) = -.548752588888191, (1936, 2) = 0.18331593153145426e-15, (1937, 1) = -.5477733850628141, (1937, 2) = -0.10185875077492447e-15, (1938, 1) = -.5467941812374373, (1938, 2) = -0.8150023667455182e-16, (1939, 1) = -.5458149774120603, (1939, 2) = -0.10189181935221203e-15, (1940, 1) = -.5448357735866833, (1940, 2) = .0, (1941, 1) = -.5438565697613065, (1941, 2) = 0.815398412365604e-16, (1942, 1) = -.5428773659359296, (1942, 2) = 0.24465902437629747e-15, (1943, 1) = -.5418981621105528, (1943, 2) = 0.20391539412377172e-15, (1944, 1) = -.5409189582851759, (1944, 2) = -0.611844673346019e-16, (1945, 1) = -.539939754459799, (1945, 2) = 0.10199050560750832e-15, (1946, 1) = -.5389605506344222, (1946, 2) = 0.10200687717478304e-15, (1947, 1) = -.5379813468090452, (1947, 2) = 0.18364180840120499e-15, (1948, 1) = -.5370021429836682, (1948, 2) = -0.12244746565829778e-15, (1949, 1) = -.5360229391582914, (1949, 2) = -0.6123351636916971e-16, (1950, 1) = -.5350437353329145, (1950, 2) = -0.10207214455310942e-15, (1951, 1) = -.5340645315075376, (1951, 2) = .0, (1952, 1) = -.5301477162060301, (1952, 2) = -0.20430646706190278e-16, (1953, 1) = -.5262309009045225, (1953, 2) = -0.4088708226856249e-16, (1954, 1) = -.5253399704114321, (1954, 2) = -0.6133939254659551e-16, (1955, 1) = -.5244490399183417, (1955, 2) = 0.1431456846965623e-15, (1956, 1) = -.5235581094252513, (1956, 2) = 0.1022614958322614e-15, (1957, 1) = -.5226671789321607, (1957, 2) = 0.16364168873474045e-15, (1958, 1) = -.5217762484390702, (1958, 2) = 0.6137435789634596e-16, (1959, 1) = -.5208853179459798, (1959, 2) = -0.16368819025443262e-15, (1960, 1) = -.5199943874528894, (1960, 2) = -0.6139177360633507e-16, (1961, 1) = -.519103456959799, (1961, 2) = 0.20466821554243753e-15, (1962, 1) = -.5155397349874372, (1962, 2) = 0.10239186085945716e-15, (1963, 1) = -.5119760130150754, (1963, 2) = 0.6146958778770338e-16, (1964, 1) = -.5101941520288946, (1964, 2) = .0, (1965, 1) = -.5084122910427137, (1965, 2) = -0.8200516991249051e-16, (1966, 1) = -.5075213605496232, (1966, 2) = -0.2050414044829672e-15, (1967, 1) = -.5066304300565327, (1967, 2) = -0.14354889225231038e-15, (1968, 1) = -.5057394995634423, (1968, 2) = -0.2050982495023389e-16, (1969, 1) = -.5048485690703519, (1969, 2) = 0.24615193765398556e-15, (1970, 1) = -.5039576385772615, (1970, 2) = -0.28721691830799224e-15, (1971, 1) = -.5030667080841711, (1971, 2) = 0.41036646051798756e-16, (1972, 1) = -.5021757775910807, (1972, 2) = 0.6156344414666744e-16, (1973, 1) = -.5012848470979901, (1973, 2) = -0.22576366151266857e-15, (1974, 1) = -.5003939166048997, (1974, 2) = 0.8210714623642785e-16, (1975, 1) = -.49950298611180927, (1975, 2) = -0.20529600035541822e-16, (1976, 1) = -.4986120556187188, (1976, 2) = -0.821296386093493e-16, (1977, 1) = -.4977211251256284, (1977, 2) = -0.3080282310615768e-15, (1978, 1) = -.49677499651696, (1978, 2) = -0.10269095375099138e-15, (1979, 1) = -.49582886790829167, (1979, 2) = -0.20541161724989832e-16, (1980, 1) = -.49488273929962334, (1980, 2) = 0.41088256644078176e-16, (1981, 1) = -.49393661069095496, (1981, 2) = 0.8218836213963866e-16, (1982, 1) = -.49204435347361825, (1982, 2) = 0.4110600356478264e-16, (1983, 1) = -.49015209625628153, (1983, 2) = .0, (1984, 1) = -.48920596764761315, (1984, 2) = -0.14393284928133099e-15, (1985, 1) = -.4882598390389448, (1985, 2) = 0.8225908553800659e-16, (1986, 1) = -.4873137104302765, (1986, 2) = 0.1028385136413804e-15, (1987, 1) = -.4863675818216081, (1987, 2) = 0.20570629636541713e-16, (1988, 1) = -.4854214532129397, (1988, 2) = 0.8229420841161149e-16, (1989, 1) = -.4844753246042714, (1989, 2) = -0.22634117133065455e-15, (1990, 1) = -.48352919599560307, (1990, 2) = -0.22637322052787907e-15, (1991, 1) = -.4825830673869347, (1991, 2) = .0, (1992, 1) = -.4816369387782663, (1992, 2) = -0.6175559226466392e-16, (1993, 1) = -.48069081016959797, (1993, 2) = -0.20588097582624055e-16, (1994, 1) = -.47974468156092964, (1994, 2) = -0.8236397305405929e-16, (1995, 1) = -.47879855295226126, (1995, 2) = 0.4118776891572972e-16, (1996, 1) = -.4778524243435929, (1996, 2) = 0.20596771159317025e-16, (1997, 1) = -.47690629573492455, (1997, 2) = 0.8239861344607657e-16, (1998, 1) = -.4759601671262562, (1998, 2) = 0.6180759317437207e-16, (1999, 1) = -.47501403851758783, (1999, 2) = -0.20605404242789555e-16, (2000, 1) = -.47406790990891945, (2000, 2) = 0.2060827290917865e-16, (2001, 1) = -.4731217813002511, (2001, 2) = -0.6183341115287812e-16, (2002, 1) = -.4721756526915828, (2002, 2) = 0.618419899854147e-16, (2003, 1) = -.4712295240829144, (2003, 2) = 0.12370111041236152e-15, (2004, 1) = -.470283395474246, (2004, 2) = 0.6185910679622706e-16, (2005, 1) = -.4693372668655777, (2005, 2) = 0.4124509649108e-16, (2006, 1) = -.46839113825690937, (2006, 2) = -0.8250155867792252e-16, (2007, 1) = -.467445009648241, (2007, 2) = 0.6188467959279098e-16, (2008, 1) = -.4526717448241204, (2008, 2) = 0.20671925931655937e-16, (2009, 1) = -.43789847999999987, (2009, 2) = -0.8285795061152573e-16, (2010, 1) = -.421884105075377, (2010, 2) = -0.20759312744740692e-16, (2011, 1) = -.4058697301507541, (2011, 2) = 0.20802744102675557e-16, (2012, 1) = -.40500367472675913, (2012, 2) = -0.8322021030617484e-16, (2013, 1) = -.40413761930276415, (2013, 2) = -0.12484414131293919e-15, (2014, 1) = -.40327156387876917, (2014, 2) = -0.4161931405004237e-16, (2015, 1) = -.4024055084547742, (2015, 2) = -0.18730757691585232e-15, (2016, 1) = -.4015394530307792, (2016, 2) = -0.8325697911158048e-16, (2017, 1) = -.4006733976067842, (2017, 2) = 0.8326612952911705e-16, (2018, 1) = -.39980734218278924, (2018, 2) = 0.1040940789966583e-15, (2019, 1) = -.39894128675879426, (2019, 2) = 0.20821095024586802e-16, (2020, 1) = -.3954770650628143, (2020, 2) = -0.2083016991851875e-16, (2021, 1) = -.3920128433668344, (2021, 2) = -0.6251753216370466e-16, (2022, 1) = -.3911467879428394, (2022, 2) = 0.18757276818258263e-15, (2023, 1) = -.39028073251884443, (2023, 2) = -0.10421827874930647e-15, (2024, 1) = -.38941467709484945, (2024, 2) = 0.6253766571666338e-16, (2025, 1) = -.38854862167085447, (2025, 2) = 0.10424058574817738e-15, (2026, 1) = -.3876825662468595, (2026, 2) = -0.6255102443313746e-16, (2027, 1) = -.3868165108228645, (2027, 2) = -0.10426280776033071e-15, (2028, 1) = -.3859504553988695, (2028, 2) = -0.6256433210494875e-16, (2029, 1) = -.38508439997487454, (2029, 2) = 0.12514193353253096e-15, (2030, 1) = -.3816201782788946, (2030, 2) = 0.2086579242511914e-16, (2031, 1) = -.3781559565829147, (2031, 2) = -0.6262358214029808e-16, (2032, 1) = -.3771612604428393, (2032, 2) = 0.626310683320978e-16, (2033, 1) = -.37616656430276396, (2033, 2) = 0.1252770749623803e-15, (2034, 1) = -.37517186816268855, (2034, 2) = 0.41763993045332736e-16, (2035, 1) = -.3741771720226132, (2035, 2) = 0.8353789943064093e-16, (2036, 1) = -.37318247588253783, (2036, 2) = 0.10443473746103857e-15, (2037, 1) = -.3721877797424624, (2037, 2) = -0.6266824325944698e-16, (2038, 1) = -.37119308360238706, (2038, 2) = 0.626756269020052e-16, (2039, 1) = -.3701983874623117, (2039, 2) = -0.1253659867697668e-15, (2040, 1) = -.36920369132223635, (2040, 2) = 0.8358712358493315e-16, (2041, 1) = -.368208995182161, (2041, 2) = 0.6269767479410576e-16, (2042, 1) = -.3672142990420856, (2042, 2) = 0.2090166322726174e-16, (2043, 1) = -.3662196029020102, (2043, 2) = -0.41808191554970336e-16, (2044, 1) = -.36522490676193486, (2044, 2) = -0.14634565802935658e-15, (2045, 1) = -.36423021062185945, (2045, 2) = -0.20908943615267977e-16, (2046, 1) = -.3632355144817841, (2046, 2) = 0.8364543556011115e-16, (2047, 1) = -.36224081834170874, (2047, 2) = -0.4182753678703764e-16, (2048, 1) = -.360251426061558, (2048, 2) = .0, (2049, 1) = -.35826203378140725, (2049, 2) = 0.10461674283765212e-15, (2050, 1) = -.3572673376413319, (2050, 2) = 0.10462864559664188e-15, (2051, 1) = -.3562726415012565, (2051, 2) = .0, (2052, 1) = -.3552779453611811, (2052, 2) = -0.10465236394317436e-15, (2053, 1) = -.35428324922110577, (2053, 2) = -0.1465298512548394e-15, (2054, 1) = -.35229385694095505, (2054, 2) = -0.10468772306248048e-15, (2055, 1) = -.3503044646608043, (2055, 2) = 0.20942229968539928e-16, (2056, 1) = -.3493097685207289, (2056, 2) = 0.14661194708907484e-15, (2057, 1) = -.3483150723806535, (2057, 2) = -0.6284067573530189e-16, (2058, 1) = -.34732037624057815, (2058, 2) = -0.6284764226408642e-16, (2059, 1) = -.3463256801005028, (2059, 2) = -0.4190306078490953e-16, (2060, 1) = -.3453906134359299, (2060, 2) = -0.20953702480475162e-16, (2061, 1) = -.34445554677135704, (2061, 2) = -0.8382347747586433e-16, (2062, 1) = -.34352048010678415, (2062, 2) = 0.10479015526404027e-15, (2063, 1) = -.34258541344221133, (2063, 2) = -0.6288056258067311e-16, (2064, 1) = -.3416503467776385, (2064, 2) = 0.2096233878611445e-15, (2065, 1) = -.3407152801130656, (2065, 2) = 0.10482242412693605e-15, (2066, 1) = -.33978021344849274, (2066, 2) = -0.1886996307566499e-15, (2067, 1) = -.33884514678391986, (2067, 2) = -0.2096876122376414e-16, (2068, 1) = -.337910080119347, (2068, 2) = 0.10485445786366968e-15, (2069, 1) = -.3369750134547741, (2069, 2) = 0.1887571501333594e-15, (2070, 1) = -.3360399467902012, (2070, 2) = 0.20975136544972353e-16, (2071, 1) = -.3351048801256284, (2071, 2) = -0.41954502316328886e-16, (2072, 1) = -.33416981346105556, (2072, 2) = 0.1258761630962216e-15, (2073, 1) = -.3332347467964827, (2073, 2) = -0.20981464613575865e-16, (2074, 1) = -.3322996801319098, (2074, 2) = -0.4196712689155414e-16, (2075, 1) = -.3313646134673369, (2075, 2) = -0.4197131401529236e-16, (2076, 1) = -.32762434680904545, (2076, 2) = -0.6298193535677917e-16, (2077, 1) = -.323884080150754, (2077, 2) = -0.10501107587291804e-15, (2078, 1) = -.3201438134924625, (2078, 2) = -0.210103668597565e-16, (2079, 1) = -.31640354683417105, (2079, 2) = 0.2101843319550895e-16, (2080, 1) = -.31547751189384443, (2080, 2) = 0.8408166833614214e-16, (2081, 1) = -.3145514769535178, (2081, 2) = 0.18920156145395016e-15, (2082, 1) = -.3136254420131912, (2082, 2) = 0.21024369090054714e-16, (2083, 1) = -.31269940707286453, (2083, 2) = -0.1471843603876006e-15, (2084, 1) = -.31177337213253786, (2084, 2) = 0.8411320014793264e-16, (2085, 1) = -.31084733719221125, (2085, 2) = 0.6309077280505216e-16, (2086, 1) = -.30992130225188463, (2086, 2) = 0.2103220988770733e-16, (2087, 1) = -.308995267311558, (2087, 2) = 0.14723909823307364e-15, (2088, 1) = -.3080692323712314, (2088, 2) = 0.10518049302637826e-15, (2089, 1) = -.3071431974309048, (2089, 2) = -0.42076070055247026e-16, (2090, 1) = -.3062171624905782, (2090, 2) = .0, (2091, 1) = -.3052911275502515, (2091, 2) = .0, (2092, 1) = -.30436509260992484, (2092, 2) = 0.8417524997581494e-16, (2093, 1) = -.3034390576695982, (2093, 2) = -0.841829108024683e-16, (2094, 1) = -.3025130227292716, (2094, 2) = 0.42095275183956794e-16, (2095, 1) = -.301586987788945, (2095, 2) = -0.631486264905182e-16, (2096, 1) = -.3006609528486184, (2096, 2) = 0.21051441410678857e-16, (2097, 1) = -.29973491790829176, (2097, 2) = -0.8421334131594395e-16, (2098, 1) = -.29880888296796515, (2098, 2) = 0.6316567174178138e-16, (2099, 1) = -.2978828480276385, (2099, 2) = 0.8422842864404982e-16, (2100, 1) = -.2969568130873118, (2100, 2) = -0.2105898506576267e-16, (2101, 1) = -.2960307781469852, (2101, 2) = -0.10530428811854509e-15, (2102, 1) = -.2951047432066586, (2102, 2) = -0.42125449660786673e-16, (2103, 1) = -.29417870826633197, (2103, 2) = 0.1474521067695764e-15, (2104, 1) = -.29325267332600535, (2104, 2) = -0.16853154537757007e-15, (2105, 1) = -.29232663838567874, (2105, 2) = -0.21068294298451682e-16, (2106, 1) = -.2914006034453521, (2106, 2) = 0.4214028011143753e-16, (2107, 1) = -.29047456850502545, (2107, 2) = -0.2107198043959265e-16, (2108, 1) = -.2895485335646988, (2108, 2) = -0.10536907722839629e-15, (2109, 1) = -.28862249862437217, (2109, 2) = 0.2107564506959526e-16, (2110, 1) = -.28769646368404556, (2110, 2) = 0.6323240792090446e-16, (2111, 1) = -.28677042874371894, (2111, 2) = -0.2107928815343624e-16, (2112, 1) = -.2719420830150756, (2112, 2) = -0.10553837513580722e-16, (2113, 1) = -.2571137372864323, (2113, 2) = 0.6340398330151759e-16, (2114, 1) = -.25333274378140713, (2114, 2) = 0.4228263192801426e-16, (2115, 1) = -.249551750276382, (2115, 2) = -0.5286969597644592e-16, (2116, 1) = -.2486065019001257, (2116, 2) = 0.10574752261344068e-15, (2117, 1) = -.24766125352386942, (2117, 2) = -0.21151124856712646e-16, (2118, 1) = -.24671600514761313, (2118, 2) = 0.12691643633123167e-15, (2119, 1) = -.24577075677135685, (2119, 2) = 0.200966307083625e-15, (2120, 1) = -.24482550839510056, (2120, 2) = -0.21155951029207025e-16, (2121, 1) = -.24388026001884427, (2121, 2) = -0.13752406284427361e-15, (2122, 1) = -.242935011642588, (2122, 2) = -0.12695483647229113e-15, (2123, 1) = -.2419897632663317, (2123, 2) = -0.10580362435820027e-16, (2124, 1) = -.24009926651381913, (2124, 2) = 0.42327756613983416e-16, (2125, 1) = -.23820876976130656, (2125, 2) = 0.12700205042295055e-15, (2126, 1) = -.23726352138505027, (2126, 2) = 0.7408997641611484e-16, (2127, 1) = -.236318273008794, (2127, 2) = -0.529252878255858e-16, (2128, 1) = -.2353730246325377, (2128, 2) = 0.4234331943923509e-16, (2129, 1) = -.23442777625628142, (2129, 2) = 0.14821238918168656e-15, (2130, 1) = -.23348252788002513, (2130, 2) = .0, (2131, 1) = -.23253727950376885, (2131, 2) = -0.20117445427962175e-15, (2132, 1) = -.23159203112751256, (2132, 2) = -0.7412222822618231e-16, (2133, 1) = -.23064678275125627, (2133, 2) = 0.16943435816848419e-15, (2134, 1) = -.229701534375, (2134, 2) = 0.21180804174945808e-16, (2135, 1) = -.2287562859987437, (2135, 2) = -0.14827615390693048e-15, (2136, 1) = -.22781103762248742, (2136, 2) = -0.10591902672673073e-15, (2137, 1) = -.22686578924623113, (2137, 2) = 0.11651913407299252e-15, (2138, 1) = -.210834630150754, (2138, 2) = 0.10604848484014125e-16, (2139, 1) = -.19480347105527684, (2139, 2) = -0.10616192465937432e-16, (2140, 1) = -.19296609567211098, (2140, 2) = -0.2123487514435111e-16, (2141, 1) = -.19112872028894512, (2141, 2) = -0.3185601393294197e-16, (2142, 1) = -.1902100325973622, (2142, 2) = 0.14866997479337565e-15, (2143, 1) = -.18929134490577926, (2143, 2) = -0.6371936202155551e-16, (2144, 1) = -.18837265721419633, (2144, 2) = -0.7434350405177748e-16, (2145, 1) = -.1874539695226134, (2145, 2) = 0.11683215101824166e-15, (2146, 1) = -.18653528183103046, (2146, 2) = -0.7435194092456719e-16, (2147, 1) = -.18561659413944753, (2147, 2) = 0.8497843361907099e-16, (2148, 1) = -.1846979064478646, (2148, 2) = 0.8498319763683297e-16, (2149, 1) = -.18377921875628167, (2149, 2) = -0.12748190821877755e-15, (2150, 1) = -.18286053106469874, (2150, 2) = -0.21248164283619602e-16, (2151, 1) = -.1819418433731158, (2151, 2) = -0.1274960288866755e-15, (2152, 1) = -.18102315568153288, (2152, 2) = -0.4250101258544536e-16, (2153, 1) = -.18010446798994995, (2153, 2) = -0.10625834357788638e-16, (2154, 1) = -.1727549664572865, (2154, 2) = -0.5315190440718991e-16, (2155, 1) = -.16540546492462305, (2155, 2) = -0.9571269143075583e-16, (2156, 1) = -.1644986022079145, (2156, 2) = 0.319058070560214e-16, (2157, 1) = -.16359173949120598, (2157, 2) = 0.8508633386488587e-16, (2158, 1) = -.16268487677449744, (2158, 2) = 0.53181558171788855e-16, (2159, 1) = -.1617780140577889, (2159, 2) = 0.20209974570208045e-15, (2160, 1) = -.16087115134108038, (2160, 2) = -0.8509874393821979e-16, (2161, 1) = -.15996428862437184, (2161, 2) = -0.8510283557171153e-16, (2162, 1) = -.1590574259076633, (2162, 2) = 0.11702199390736953e-15, (2163, 1) = -.15815056319095477, (2163, 2) = -0.10638868899123155e-16, (2164, 1) = -.15724370047424624, (2164, 2) = 0.9575434705633714e-16, (2165, 1) = -.1563368377575377, (2165, 2) = 0.10639872069350463e-15, (2166, 1) = -.15542997504082917, (2166, 2) = 0.19152664956938538e-15, (2167, 1) = -.15452311232412064, (2167, 2) = -0.20217641500174961e-15, (2168, 1) = -.1536162496074121, (2168, 2) = -0.17026169038357397e-15, (2169, 1) = -.15270938689070357, (2169, 2) = 0.31925533571616466e-16, (2170, 1) = -.15180252417399503, (2170, 2) = -0.9578097513877981e-16, (2171, 1) = -.1508956614572865, (2171, 2) = -0.42571255156434966e-16, (2172, 1) = -.14726821059045236, (2172, 2) = -0.5322359174336967e-16, (2173, 1) = -.14364075972361823, (2173, 2) = -0.14372879695796277e-15, (2174, 1) = -.1427338970069097, (2174, 2) = -0.8517628206449939e-16, (2175, 1) = -.14182703429020116, (2175, 2) = 0.7453243086328868e-16, (2176, 1) = -.14092017157349263, (2176, 2) = 0.2129588429426603e-16, (2177, 1) = -.1400133088567841, (2177, 2) = 0.37269369649347416e-16, (2178, 1) = -.13910644614007556, (2178, 2) = 0.15973256498990768e-16, (2179, 1) = -.13819958342336702, (2179, 2) = -0.10649281158877284e-16, (2180, 1) = -.1372927207066585, (2180, 2) = 0.5324860902979808e-17, (2181, 1) = -.13638585798994995, (2181, 2) = 0.9585143645554642e-16, (2182, 1) = -.13250817271356807, (2182, 2) = 0.47933997633309165e-16, (2183, 1) = -.1286304874371862, (2183, 2) = -0.5326893594986433e-17, (2184, 1) = -.12475280216080431, (2184, 2) = 0.6393313604672153e-16, (2185, 1) = -.12087511688442243, (2185, 2) = 0.11190066142849303e-15, (2186, 1) = -.11893627424623149, (2186, 2) = 0.5861915289475668e-16, (2187, 1) = -.11699743160804055, (2187, 2) = -0.21317673285387816e-16, (2188, 1) = -.11602801028894508, (2188, 2) = 0.11192197954661254e-15, (2189, 1) = -.1150585889698496, (2189, 2) = -0.9060687516425084e-16, (2190, 1) = -.11408916765075414, (2190, 2) = -0.17589041772216898e-15, (2191, 1) = -.11311974633165867, (2191, 2) = 0.10660414978892288e-16, (2192, 1) = -.11118090369346773, (2192, 2) = 0.21322368907704153e-16, (2193, 1) = -.10924206105527678, (2193, 2) = 0.11728134867419223e-15, (2194, 1) = -.10827263973618131, (2194, 2) = -0.3198694207704766e-16, (2195, 1) = -.10730321841708584, (2195, 2) = 0.5331341987293466e-17, (2196, 1) = -.10633379709799037, (2196, 2) = -0.12262508229380325e-15, (2197, 1) = -.1053643757788949, (2197, 2) = 0.9597072603266759e-16, (2198, 1) = -.1043970648052768, (2198, 2) = -0.26659433253618306e-16, (2199, 1) = -.1034297538316587, (2199, 2) = -0.6931684058841777e-16, (2200, 1) = -.1024624428580406, (2200, 2) = -0.10131257959073905e-15, (2201, 1) = -.1014951318844225, (2201, 2) = -0.47991741854087124e-16, (2202, 1) = -.1005278209108044, (2202, 2) = -0.15997766554748014e-16, (2203, 1) = -0.9956050993718629e-1, (2203, 2) = -0.5866036330728577e-16, (2204, 1) = -0.9859319896356819e-1, (2204, 2) = 0.9065981184156307e-16, (2205, 1) = -0.9762588798995009e-1, (2205, 2) = .0, (2206, 1) = -0.9665857701633199e-1, (2206, 2) = .0, (2207, 1) = -0.9569126604271389e-1, (2207, 2) = 0.3200057806878286e-16, (2208, 1) = -0.9472395506909578e-1, (2208, 2) = -0.11733904414003065e-15, (2209, 1) = -0.9375664409547768e-1, (2209, 2) = -0.9067382665383183e-16, (2210, 1) = -0.9278933312185958e-1, (2210, 2) = 0.9601046025226955e-16, (2211, 1) = -0.9182202214824148e-1, (2211, 2) = -0.6400887315890239e-16, (2212, 1) = -0.9085471117462338e-1, (2212, 2) = -0.106684588459105e-16, (2213, 1) = -0.8988740020100527e-1, (2213, 2) = 0.10668768874326127e-15, (2214, 1) = -0.8601815630653287e-1, (2214, 2) = 0.3200992818219975e-16, (2215, 1) = -0.8214891241206046e-1, (2215, 2) = -0.3201339157041806e-16, (2216, 1) = -0.8118160143844236e-1, (2216, 2) = 0.37349938132483404e-16, (2217, 1) = -0.8021429046482426e-1, (2217, 2) = 0.9070934772183352e-16, (2218, 1) = -0.7924697949120615e-1, (2218, 2) = 0.32015885218611706e-16, (2219, 1) = -0.7827966851758805e-1, (2219, 2) = 0.10672232211019196e-16, (2220, 1) = -0.7731235754396995e-1, (2220, 2) = 0.10672499380965353e-16, (2221, 1) = -0.7634504657035185e-1, (2221, 2) = 0.18677335685102096e-15, (2222, 1) = -0.7537773559673375e-1, (2222, 2) = 0.112066750039394e-15, (2223, 1) = -0.7441042462311565e-1, (2223, 2) = -0.1707724971868033e-15, (2224, 1) = -0.7354220558103021e-1, (2224, 2) = 0.12808211000513082e-15, (2225, 1) = -0.7267398653894477e-1, (2225, 2) = 0.5870554028559285e-16, (2226, 1) = -0.7180576749685934e-1, (2226, 2) = 0.10940806298639849e-15, (2227, 1) = -0.709375484547739e-1, (2227, 2) = -0.19480373879157097e-15, (2228, 1) = -0.7006932941268847e-1, (2228, 2) = -0.15744732488413281e-15, (2229, 1) = -0.6920111037060303e-1, (2229, 2) = -0.6404765809283866e-16, (2230, 1) = -0.683328913285176e-1, (2230, 2) = -0.8806727978210664e-16, (2231, 1) = -0.6746467228643216e-1, (2231, 2) = 0.12009410140290027e-15, (2232, 1) = -0.6399179611809042e-1, (2232, 2) = 0.11209634464099439e-15, (2233, 1) = -0.6051891994974867e-1, (2233, 2) = 0.8007458078729983e-17, (2234, 1) = -0.587824818655778e-1, (2234, 2) = 0.4270791587233935e-16, (2235, 1) = -0.5704604378140693e-1, (2235, 2) = 0.4537868005165116e-16, (2236, 1) = -0.56177824739321494e-1, (2236, 2) = -0.13079951260900082e-15, (2237, 1) = -0.5530960569723606e-1, (2237, 2) = 0.1414793038891078e-15, (2238, 1) = -0.5444138665515062e-1, (2238, 2) = 0.14682047489101297e-15, (2239, 1) = -0.5357316761306519e-1, (2239, 2) = -0.17618732098915961e-15, (2240, 1) = -0.5270494857097975e-1, (2240, 2) = -0.17885957388689635e-15, (2241, 1) = -0.51836729528894315e-1, (2241, 2) = 0.4004379339081653e-16, (2242, 1) = -0.5096851048680888e-1, (2242, 2) = -0.12280279162161411e-15, (2243, 1) = -0.50100291444723444e-1, (2243, 2) = -0.5339329830218344e-17, (2244, 1) = -0.4923207240263801e-1, (2244, 2) = .0, (2245, 1) = -0.4836385336055257e-1, (2245, 2) = -0.10411989626712084e-15, (2246, 1) = -0.47495634318467136e-1, (2246, 2) = -0.40046669014202627e-16, (2247, 1) = -0.466274152763817e-1, (2247, 2) = -0.24028328428373913e-16, (2248, 1) = -0.4559894721105508e-1, (2248, 2) = -0.26698564463992518e-16, (2249, 1) = -0.4457047914572845e-1, (2249, 2) = -0.7742703284302311e-16, (2250, 1) = -0.4354201108040183e-1, (2250, 2) = 0.854380154629592e-16, (2251, 1) = -0.42513543015075206e-1, (2251, 2) = 0.2669977343197491e-17, (2252, 1) = -0.4045660688442196e-1, (2252, 2) = -0.8010159737027595e-17, (2253, 1) = -0.3839967075376871e-1, (2253, 2) = -0.11748551719147537e-15, (2254, 1) = -0.34285798492462216e-1, (2254, 2) = .0, (2255, 1) = -0.3017192623115572e-1, (2255, 2) = 0.4005564568361986e-16, (2256, 1) = -0.2194418170854273e-1, (2256, 2) = 0.26705671834811037e-16, (2257, 1) = -0.13716437185929742e-1, (2257, 2) = -0.6676744414276193e-16, (2258, 1) = -0.11995288417085526e-1, (2258, 2) = 0.1335358731369121e-17, (2259, 1) = -0.1027413964824131e-1, (2259, 2) = 0.12619220621511217e-15, (2260, 1) = -0.9413565263819201e-2, (2260, 2) = -0.9681439983554242e-16, (2261, 1) = -0.8552990879397093e-2, (2261, 2) = -0.11784679726685513e-15, (2262, 1) = -0.7692416494974985e-2, (2262, 2) = -0.9080567576104399e-16, (2263, 1) = -0.6831842110552877e-2, (2263, 2) = 0.39393720812774675e-16, (2264, 1) = -0.5971267726130769e-2, (2264, 2) = -0.6075991825144748e-16, (2265, 1) = -0.5110693341708661e-2, (2265, 2) = 0.159244654244179e-15, (2266, 1) = -0.4250118957286553e-2, (2266, 2) = -0.7177703696021608e-17, (2267, 1) = -0.33895445728644447e-2, (2267, 2) = 0.1200180142401461e-15, (2268, 1) = -0.25289701884423366e-2, (2268, 2) = -0.4907555791343083e-16, (2269, 1) = -0.16683958040202285e-2, (2269, 2) = 0.10040464576881005e-15, (2270, 1) = -0.8078214195981204e-3, (2270, 2) = 0.731960977663649e-16, (2271, 1) = 0.52752964823987725e-4, (2271, 2) = -0.117574374592121e-15, (2272, 1) = 0.69373480402008525e-2, (2272, 2) = -0.5575211680423016e-16, (2273, 1) = 0.13821943115577717e-1, (2273, 2) = -0.5341392945047707e-17, (2274, 1) = 0.4603117206030127e-1, (2274, 2) = 0.12548242527247554e-15, (2275, 1) = 0.5371631924623099e-1, (2275, 2) = 0.7474594502734436e-16, (2276, 1) = 0.6140146643216071e-1, (2276, 2) = 0.3736746839804874e-16, (2277, 1) = 0.6236210983040193e-1, (2277, 2) = 0.1601431238417255e-15, (2278, 1) = 0.6332275322864314e-1, (2278, 2) = 0.7206295749385416e-16, (2279, 1) = 0.6428339662688436e-1, (2279, 2) = 0.16547452618535426e-15, (2280, 1) = 0.6524404002512557e-1, (2280, 2) = 0.667222174819657e-16, (2281, 1) = 0.6620468342336679e-1, (2281, 2) = -0.8807147617923846e-16, (2282, 1) = 0.67165326821608e-1, (2282, 2) = -0.1200949068386945e-15, (2283, 1) = 0.6812597021984922e-1, (2283, 2) = -0.6938666767601285e-16, (2284, 1) = 0.6908661361809043e-1, (2284, 2) = 0.3469257287194996e-16, (2285, 1) = 0.7100790041457286e-1, (2285, 2) = 0.1867977953132541e-16, (2286, 1) = 0.7292918721105529e-1, (2286, 2) = -0.8538934889338953e-16, (2287, 1) = 0.738898306092965e-1, (2287, 2) = -0.16010127241311958e-16, (2288, 1) = 0.7485047400753772e-1, (2288, 2) = -0.10139506228099218e-15, (2289, 1) = 0.7581111740577894e-1, (2289, 2) = 0.16009361222461493e-16, (2290, 1) = 0.7677176080402015e-1, (2290, 2) = 0.20278029783765077e-15, (2291, 1) = 0.7762950093278899e-1, (2291, 2) = -0.16008618225337283e-16, (2292, 1) = 0.7848724106155783e-1, (2292, 2) = 0.1067217444949785e-16, (2293, 1) = 0.7934498119032667e-1, (2293, 2) = 0.4802370368829295e-16, (2294, 1) = 0.802027213190955e-1, (2294, 2) = -0.1654112145473712e-15, (2295, 1) = 0.8106046144786434e-1, (2295, 2) = -0.11738590351984235e-15, (2296, 1) = 0.8191820157663318e-1, (2296, 2) = -0.106711976937239e-16, (2297, 1) = 0.8277594170540202e-1, (2297, 2) = -0.10670947019243388e-15, (2298, 1) = 0.8363368183417086e-1, (2298, 2) = -0.10670693751639533e-16, (2299, 1) = 0.844914219629397e-1, (2299, 2) = -0.8002828418600937e-16, (2300, 1) = 0.8534916209170854e-1, (2300, 2) = 0.20273340934650471e-15, (2301, 1) = 0.8620690222047737e-1, (2301, 2) = 0.7468942876970225e-16, (2302, 1) = 0.8706464234924621e-1, (2302, 2) = -0.5334827380593208e-17, (2303, 1) = 0.8792238247801505e-1, (2303, 2) = -0.14937143950976423e-15, (2304, 1) = 0.8878012260678389e-1, (2304, 2) = 0.6934927819255353e-16, (2305, 1) = 0.8963786273555273e-1, (2305, 2) = -0.5334424159167188e-17, (2306, 1) = 0.9049560286432157e-1, (2306, 2) = -0.11202003042526517e-15, (2307, 1) = 0.9392656337939692e-1, (2307, 2) = 0.53337262423079385e-17, (2308, 1) = 0.9735752389447228e-1, (2308, 2) = 0.1226623266706147e-15, (2309, 1) = .10078848440954763, (2309, 2) = 0.5865796607126657e-16, (2310, 1) = .10421944492462298, (2310, 2) = -0.42655355681431076e-16, (2311, 1) = .11965334065326627, (2311, 2) = 0.5861748933767739e-16, (2312, 1) = .13508723638190956, (2312, 2) = 0.12248398809991742e-15, (2313, 1) = .1506234379899496, (2313, 2) = 0.10642958290047928e-15, (2314, 1) = .16615963959798963, (2314, 2) = 0.4253721723140017e-16, (2315, 1) = .1671260371451002, (2315, 2) = 0.425349547912076e-16, (2316, 1) = .16809243469221075, (2316, 2) = 0.1063316989868651e-15, (2317, 1) = .1690588322393213, (2317, 2) = 0.21265195824116644e-16, (2318, 1) = .17002522978643186, (2318, 2) = 0.10632022739480042e-15, (2319, 1) = .17099162733354242, (2319, 2) = .0, (2320, 1) = .17195802488065298, (2320, 2) = 0.7441603989935703e-16, (2321, 1) = .17292442242776354, (2321, 2) = -0.10630278121795438e-15, (2322, 1) = .1738908199748741, (2322, 2) = -0.1275562826545046e-15, (2323, 1) = .17582361506909522, (2323, 2) = -0.7439953421325761e-16, (2324, 1) = .17775641016331634, (2324, 2) = -0.42509227419571166e-16, (2325, 1) = .1787228077104269, (2325, 2) = 0.8501362464354404e-16, (2326, 1) = .17968920525753745, (2326, 2) = 0.23377411499468465e-15, (2327, 1) = .180655602804648, (2327, 2) = -0.3187645807074801e-16, (2328, 1) = .18162200035175857, (2328, 2) = 0.9562385470037267e-16, (2329, 1) = .1835547954459797, (2329, 2) = -0.10623636693304055e-16, (2330, 1) = .1854875905402008, (2330, 2) = -0.8497910396820743e-16, (2331, 1) = .18645398808731137, (2331, 2) = 0.1062175890933895e-16, (2332, 1) = .18742038563442193, (2332, 2) = -0.10621126666229842e-16, (2333, 1) = .18838678318153249, (2333, 2) = 0.42481965073664003e-16, (2334, 1) = .18935318072864304, (2334, 2) = -0.42479410870491403e-16, (2335, 1) = .1903195782757536, (2335, 2) = 0.11681132117142191e-15, (2336, 1) = .19128597582286416, (2336, 2) = 0.10618566164040298e-15, (2337, 1) = .19225237336997472, (2337, 2) = -0.743254271531919e-16, (2338, 1) = .19321877091708528, (2338, 2) = -0.31851801058336147e-16, (2339, 1) = .19418516846419584, (2339, 2) = -0.636996763794999e-16, (2340, 1) = .1951515660113064, (2340, 2) = 0.9554359768135886e-16, (2341, 1) = .19611796355841696, (2341, 2) = -0.1061529472526289e-15, (2342, 1) = .19708436110552752, (2342, 2) = -0.9553167912337314e-16, (2343, 1) = .19798033533919585, (2343, 2) = -0.9552611579026104e-16, (2344, 1) = .1988763095728642, (2344, 2) = 0.16981427235776681e-15, (2345, 1) = .19977228380653256, (2345, 2) = .0, (2346, 1) = .2006682580402009, (2346, 2) = 0.955092803075285e-16, (2347, 1) = .20156423227386921, (2347, 2) = 0.6366908001931881e-16, (2348, 1) = .20246020650753757, (2348, 2) = .0, (2349, 1) = .20335618074120593, (2349, 2) = 0.10610247430472555e-16, (2350, 1) = .20425215497487426, (2350, 2) = -0.2015825984962475e-15, (2351, 1) = .20514812920854258, (2351, 2) = -0.53044853894990116e-16, (2352, 1) = .20604410344221094, (2352, 2) = 0.53041642137191383e-16, (2353, 1) = .2069400776758793, (2353, 2) = -0.14850756751574578e-15, (2354, 1) = .20783605190954763, (2354, 2) = 0.10607035680124617e-15, (2355, 1) = .20873202614321595, (2355, 2) = 0.16970216459789155e-15, (2356, 1) = .2096280003768843, (2356, 2) = 0.53028661086099944e-16, (2357, 1) = .21052397461055267, (2357, 2) = -0.21210152942385927e-16, (2358, 1) = .211419948844221, (2358, 2) = 0.1166485985588647e-15, (2359, 1) = .21858774271356773, (2359, 2) = 0.6359432756920897e-16, (2360, 1) = .22575553658291447, (2360, 2) = 0.10593520872866105e-16, (2361, 1) = .2276109954271356, (2361, 2) = .0, (2362, 1) = .2294664542713567, (2362, 2) = -0.12708707187667144e-15, (2363, 1) = .23039418369346726, (2363, 2) = 0.31769548057306136e-16, (2364, 1) = .23132191311557782, (2364, 2) = 0.42356426208739434e-16, (2365, 1) = .23224964253768837, (2365, 2) = 0.20117885755854658e-15, (2366, 1) = .23317737195979893, (2366, 2) = .0, (2367, 1) = .2341051013819095, (2367, 2) = 0.9528175072783238e-16, (2368, 1) = .23503283080402004, (2368, 2) = -0.11644717800727155e-15, (2369, 1) = .2359605602261306, (2369, 2) = -0.317560505122193e-16, (2370, 1) = .23688828964824116, (2370, 2) = -0.4233836172540453e-16, (2371, 1) = .23781601907035171, (2371, 2) = -0.3175148362581398e-16, (2372, 1) = .23874374849246227, (2372, 2) = -0.6349837502624182e-16, (2373, 1) = .23967147791457283, (2373, 2) = -0.13756982616698799e-15, (2374, 1) = .24059920733668338, (2374, 2) = 0.740706632795407e-16, (2375, 1) = .24152693675879394, (2375, 2) = 0.3174224856479654e-16, (2376, 1) = .2424546661809045, (2376, 2) = -0.6347983746171608e-16, (2377, 1) = .24338239560301506, (2377, 2) = 0.317375804808428e-16, (2378, 1) = .2443101250251256, (2378, 2) = 0.10578411273493813e-16, (2379, 1) = .24523785444723617, (2379, 2) = 0.10577626251840976e-16, (2380, 1) = .24616558386934673, (2380, 2) = .0, (2381, 1) = .24709331329145728, (2381, 2) = -0.21152095623267826e-16, (2382, 1) = .24802104271356784, (2382, 2) = 0.21150508793885533e-15, (2383, 1) = .25173196040201007, (2383, 2) = 0.8457642255690107e-16, (2384, 1) = .2554428780904523, (2384, 2) = -0.3170642000000497e-16, (2385, 1) = .27079422361809025, (2385, 2) = -0.6332944276200843e-16, (2386, 1) = .2861455691457282, (2386, 2) = -0.12648307443738808e-15, (2387, 1) = .2871019512437182, (2387, 2) = -0.1264718257336615e-15, (2388, 1) = .2880583333417081, (2388, 2) = 0.4215351417063231e-16, (2389, 1) = .28901471543969803, (2389, 2) = 0.10537435400073131e-15, (2390, 1) = .289971097537688, (2390, 2) = -0.8429191508630725e-16, (2391, 1) = .290927479635678, (2391, 2) = 0.8428432401771868e-16, (2392, 1) = .2918838617336679, (2392, 2) = -0.6320753251061694e-16, (2393, 1) = .29284024383165785, (2393, 2) = 0.42134536547502284e-16, (2394, 1) = .29379662592964784, (2394, 2) = 0.8426141327969903e-16, (2395, 1) = .2947530080276378, (2395, 2) = -0.1263805958815837e-15, (2396, 1) = .29570939012562775, (2396, 2) = 0.12636903755790988e-15, (2397, 1) = .2966657722236177, (2397, 2) = 0.8423829665193158e-16, (2398, 1) = .29762215432160766, (2398, 2) = 0.6317290908549447e-16, (2399, 1) = .29857853641959764, (2399, 2) = -0.6316707858334981e-16, (2400, 1) = .29953491851758757, (2400, 2) = 0.1263224619946165e-15, (2401, 1) = .3004913006155775, (2401, 2) = -0.8420715512293245e-16, (2402, 1) = .3014476827135675, (2402, 2) = -0.12629896926577672e-15, (2403, 1) = .30240406481155746, (2403, 2) = -0.8419144784570191e-16, (2404, 1) = .3033604469095474, (2404, 2) = 0.4209178007420019e-16, (2405, 1) = .3043168290075373, (2405, 2) = 0.10521956221488693e-15, (2406, 1) = .3052732111055273, (2406, 2) = -0.8416771673623967e-16, (2407, 1) = .3071859753015072, (2407, 2) = 0.21037945691909856e-16, (2408, 1) = .3090987394974871, (2408, 2) = 0.8413575840362169e-16, (2409, 1) = .3100551215954771, (2409, 2) = -0.16825542474771028e-15, (2410, 1) = .31101150369346703, (2410, 2) = -0.10514955475744493e-15, (2411, 1) = .31196788579145696, (2411, 2) = 0.16822310544052267e-15, (2412, 1) = .31292426788944694, (2412, 2) = .0, (2413, 1) = .31483703208542685, (2413, 2) = 0.4204357228023463e-16, (2414, 1) = .31674979628140676, (2414, 2) = 0.10508845029985638e-15, (2415, 1) = .3324899009547737, (2415, 2) = 0.41966273813450055e-16, (2416, 1) = .34823000562814066, (2416, 2) = -0.628412722035759e-16, (2417, 1) = .34909649892587935, (2417, 2) = -0.4189012702302825e-16, (2418, 1) = .34996299222361804, (2418, 2) = -0.8377212736451939e-16, (2419, 1) = .35082948552135673, (2419, 2) = 0.6282298718244846e-16, (2420, 1) = .3516959788190954, (2420, 2) = 0.10469477587345123e-15, (2421, 1) = .3525624721168341, (2421, 2) = 0.16749528149500868e-15, (2422, 1) = .3534289654145728, (2422, 2) = -0.16747888614536876e-15, (2423, 1) = .3542954587123115, (2423, 2) = -0.6279842076813834e-16, (2424, 1) = .3551619520100502, (2424, 2) = -0.10465374327322694e-15, (2425, 1) = .3560284453077889, (2425, 2) = -0.6278605790435957e-16, (2426, 1) = .35689493860552757, (2426, 2) = 0.2092661886729384e-16, (2427, 1) = .35776143190326626, (2427, 2) = -0.8369818942532648e-16, (2428, 1) = .35862792520100495, (2428, 2) = -0.20922471439404155e-16, (2429, 1) = .35949441849874364, (2429, 2) = 0.20920391120689015e-16, (2430, 1) = .36036091179648233, (2430, 2) = 0.1255098384262222e-15, (2431, 1) = .361227405094221, (2431, 2) = 0.4183243458927791e-16, (2432, 1) = .3620938983919597, (2432, 2) = -0.10457061897846047e-15, (2433, 1) = .3629603916896984, (2433, 2) = -0.10456012955866804e-15, (2434, 1) = .3638268849874371, (2434, 2) = -0.6272977094092159e-16, (2435, 1) = .3646933782851758, (2435, 2) = 0.14635471903940781e-15, (2436, 1) = .3655598715829145, (2436, 2) = 0.104528529959622e-15, (2437, 1) = .36642636488065317, (2437, 2) = 0.14632513427061424e-15, (2438, 1) = .36729285817839186, (2438, 2) = 0.6270441259306777e-16, (2439, 1) = .36815935147613055, (2439, 2) = -0.12539608055382896e-15, (2440, 1) = .36902584477386924, (2440, 2) = -0.14628052808728403e-15, (2441, 1) = .372491817964824, (2441, 2) = -0.6266598295858841e-16, (2442, 1) = .37595779115577876, (2442, 2) = 0.6264010298793423e-16, (2443, 1) = .37693325738065314, (2443, 2) = -0.8351037587704028e-16, (2444, 1) = .3779087236055275, (2444, 2) = 0.835005925775809e-16, (2445, 1) = .3788841898304019, (2445, 2) = -0.6261809058263602e-16, (2446, 1) = .3798596560552763, (2446, 2) = -0.41740480249764044e-16, (2447, 1) = .38083512228015065, (2447, 2) = -0.10433888971293332e-15, (2448, 1) = .38181058850502503, (2448, 2) = 0.20865310320183703e-16, (2449, 1) = .3827860547298994, (2449, 2) = 0.6258851179162183e-16, (2450, 1) = .3837615209547738, (2450, 2) = -0.20860358779867844e-16, (2451, 1) = .38473698717964816, (2451, 2) = 0.2085787487438546e-16, (2452, 1) = .38571245340452254, (2452, 2) = 0.12513231332193858e-15, (2453, 1) = .3866879196293969, (2453, 2) = -0.6255867247175973e-16, (2454, 1) = .3876633858542713, (2454, 2) = 0.10425195345712275e-15, (2455, 1) = .38961431830402005, (2455, 2) = 0.6253612272959732e-16, (2456, 1) = .3915652507537688, (2456, 2) = 0.2084033625915752e-16, (2457, 1) = .3993689805527638, (2457, 2) = 0.6245990992072181e-16, (2458, 1) = .40717271035175884, (2458, 2) = 0.8319705266952144e-16, (2459, 1) = .4081521819346734, (2459, 2) = -0.4159328060049592e-16, (2460, 1) = .40913165351758796, (2460, 2) = -0.20794012126863069e-15, (2461, 1) = .4101111251005025, (2461, 2) = -0.18712240788385166e-15, (2462, 1) = .41109059668341713, (2462, 2) = 0.2078873988748689e-16, (2463, 1) = .41207006826633175, (2463, 2) = 0.1870748625113345e-15, (2464, 1) = .4130495398492463, (2464, 2) = .0, (2465, 1) = .41402901143216086, (2465, 2) = 0.1454655432663959e-15, (2466, 1) = .4150084830150754, (2466, 2) = 0.6233439606554612e-16, (2467, 1) = .41598795459799, (2467, 2) = 0.8310186755270013e-16, (2468, 1) = .41696742618090454, (2468, 2) = .0, (2469, 1) = .4179468977638191, (2469, 2) = 0.1038506043312419e-15, (2470, 1) = .4189263693467337, (2470, 2) = 0.8306975996484435e-16, (2471, 1) = .4208853125125629, (2471, 2) = 0.8304825018435976e-16, (2472, 1) = .422844255678392, (2472, 2) = 0.830266568738845e-16, (2473, 1) = .42480319884422113, (2473, 2) = 0.4150249012309204e-16, (2474, 1) = .4267621420100503, (2474, 2) = -0.41491610257270335e-16, (2475, 1) = .4287210851758795, (2475, 2) = 0.20740344473186933e-16, (2476, 1) = .4306800283417086, (2476, 2) = 0.4146972629755238e-16, (2477, 1) = .43165949992462316, (2477, 2) = -0.8292845900994515e-16, (2478, 1) = .4326389715075377, (2478, 2) = 0.10364680604551495e-15, (2479, 1) = .4336184430904523, (2479, 2) = -0.829064101014325e-16, (2480, 1) = .4345979146733669, (2480, 2) = -0.2072383870799121e-16, (2481, 1) = .4355773862562815, (2481, 2) = -0.1657685581099948e-15, (2482, 1) = .43655685783919607, (2482, 2) = 0.8287318279754895e-16, (2483, 1) = .4375363294221106, (2483, 2) = -0.1035775826083355e-15, (2484, 1) = .4385158010050252, (2484, 2) = -0.16570185789886917e-15, (2485, 1) = .4394597033668342, (2485, 2) = -0.8284017695223107e-16, (2486, 1) = .44040360572864323, (2486, 2) = -0.20707351508688378e-16, (2487, 1) = .4413475080904523, (2487, 2) = -0.10352327027664327e-15, (2488, 1) = .44229141045226134, (2488, 2) = 0.20701951884063093e-16, (2489, 1) = .44323531281407036, (2489, 2) = 0.4139849000196497e-16, (2490, 1) = .44417921517587944, (2490, 2) = -0.18626880070965472e-15, (2491, 1) = .44512311753768846, (2491, 2) = 0.16555053699016376e-15, (2492, 1) = .4460670198994975, (2492, 2) = 0.16552876913481397e-15, (2493, 1) = .4470109222613065, (2493, 2) = .0, (2494, 1) = .44795482462311553, (2494, 2) = -0.20685640121966727e-16, (2495, 1) = .4488987269849246, (2495, 2) = -0.8273162038499955e-16, (2496, 1) = .44984262934673364, (2496, 2) = -0.18612148861373908e-15, (2497, 1) = .45078653170854266, (2497, 2) = 0.4135484208787315e-16, (2498, 1) = .45173043407035174, (2498, 2) = 0.12404803217775429e-15, (2499, 1) = .45267433643216076, (2499, 2) = -0.20671918364745714e-16, (2500, 1) = .4536182387939698, (2500, 2) = 0.12401496033272532e-15, (2501, 1) = .4545621411557788, (2501, 2) = -0.6199919132374419e-16, (2502, 1) = .45550604351758783, (2502, 2) = -0.20663629528296606e-16, (2503, 1) = .4564499458793969, (2503, 2) = 0.18594771590497486e-15, (2504, 1) = .45739384824120594, (2504, 2) = -0.6197424149259235e-16, (2505, 1) = .45833775060301496, (2505, 2) = .0, (2506, 1) = .45928165296482404, (2506, 2) = 0.20652513012626947e-16, (2507, 1) = .46022555532663306, (2507, 2) = 0.16519777892286132e-15, (2508, 1) = .4611694576884421, (2508, 2) = -0.20646927123146455e-16, (2509, 1) = .4621133600502511, (2509, 2) = .0, (2510, 1) = .46305726241206013, (2510, 2) = 0.6192396863622227e-16, (2511, 1) = .4640011647738692, (2511, 2) = -0.412770277779628e-16, (2512, 1) = .46494506713567824, (2512, 2) = 0.20635700329150292e-16, (2513, 1) = .46683287185929634, (2513, 2) = -0.8252023809681342e-16, (2514, 1) = .4687206765829144, (2514, 2) = -0.10312200256907522e-15, (2515, 1) = .4695778303548993, (2515, 2) = .0, (2516, 1) = .4704349841268842, (2516, 2) = -0.6185773757891463e-16, (2517, 1) = .47129213789886915, (2517, 2) = 0.10308331464946157e-15, (2518, 1) = .47214929167085407, (2518, 2) = 0.8245630508519189e-16, (2519, 1) = .473006445442839, (2519, 2) = -0.8244594355420802e-16, (2520, 1) = .4738635992148239, (2520, 2) = 0.18548002607719273e-15, (2521, 1) = .4747207529868088, (2521, 2) = 0.20606293969410024e-16, (2522, 1) = .47557790675879374, (2522, 2) = 0.6181107732727538e-16, (2523, 1) = .4790065218467334, (2523, 2) = 0.1029662466417493e-15, (2524, 1) = .4824351369346731, (2524, 2) = 0.16466197784882144e-15, (2525, 1) = .483292290706658, (2525, 2) = -0.4116022505229249e-16, (2526, 1) = .48414944447864294, (2526, 2) = -0.41154948316817393e-16, (2527, 1) = .48500659825062786, (2527, 2) = .0, (2528, 1) = .4858637520226128, (2528, 2) = -0.20572186453569706e-16, (2529, 1) = .4867209057945977, (2529, 2) = -0.6170861137789799e-16, (2530, 1) = .4875780595665826, (2530, 2) = -0.4113376830915323e-16, (2531, 1) = .48843521333856754, (2531, 2) = 0.8225691017663344e-16, (2532, 1) = .48929236711055246, (2532, 2) = 0.4112313459894231e-16, (2533, 1) = .4901495208825374, (2533, 2) = -0.2055890342527804e-16, (2534, 1) = .4910066746545223, (2534, 2) = .0, (2535, 1) = .4918638284265072, (2535, 2) = 0.8221425922976676e-16, (2536, 1) = .49272098219849214, (2536, 2) = 0.20550890073339897e-15, (2537, 1) = .49357813597047706, (2537, 2) = -0.20548211728815055e-16, (2538, 1) = .494435289742462, (2538, 2) = -0.1643642382291636e-15, (2539, 1) = .4952924435144469, (2539, 2) = -0.12325706536567415e-15, (2540, 1) = .4961495972864318, (2540, 2) = 0.14378108556350008e-15, (2541, 1) = .5124574171356782, (2541, 2) = 0.40976627890218606e-16, (2542, 1) = .5287652369849245, (2542, 2) = -0.2043520605299e-16, (2543, 1) = .5322189526130652, (2543, 2) = -0.40847598661878507e-16, (2544, 1) = .5356726682412059, (2544, 2) = -0.102061688066145e-15, (2545, 1) = .536536097148241, (2545, 2) = 0.1224567817695733e-15, (2546, 1) = .5373995260552762, (2546, 2) = 0.16325268984879055e-15, (2547, 1) = .5382629549623114, (2547, 2) = -0.2040370542675191e-16, (2548, 1) = .5391263838693465, (2548, 2) = .0, (2549, 1) = .5408532416834169, (2549, 2) = 0.12237025572462535e-15, (2550, 1) = .5425800994974872, (2550, 2) = 0.14272475331003202e-15, (2551, 1) = .5494875307537685, (2551, 2) = 0.6109784160314565e-16, (2552, 1) = .5563949620100499, (2552, 2) = .0, (2553, 1) = .5644299466582912, (2553, 2) = 0.40629618905927314e-16, (2554, 1) = .5724649313065324, (2554, 2) = 0.16229525712061281e-15, (2555, 1) = .576482423630653, (2555, 2) = 0.8109140695614593e-16, (2556, 1) = .5804999159547737, (2556, 2) = .0, (2557, 1) = .5815042890358039, (2557, 2) = -0.4051037155582948e-16, (2558, 1) = .582508662116834, (2558, 2) = -0.40503279542197146e-16, (2559, 1) = .5835130351978641, (2559, 2) = 0.4049617902288474e-16, (2560, 1) = .5845174082788943, (2560, 2) = -0.4048907001391982e-16, (2561, 1) = .5855217813599245, (2561, 2) = -0.8096390506266669e-16, (2562, 1) = .5865261544409546, (2562, 2) = -0.8094965318231913e-16, (2563, 1) = .5875305275219848, (2563, 2) = 0.8093538441887194e-16, (2564, 1) = .5885349006030149, (2564, 2) = .0, (2565, 1) = .5903129813253767, (2565, 2) = 0.40447883601047095e-16, (2566, 1) = .5920910620477385, (2566, 2) = 0.8087038306565667e-16, (2567, 1) = .5929801024089194, (2567, 2) = .0, (2568, 1) = .5938691427701004, (2568, 2) = 0.8084494657322868e-16, (2569, 1) = .5947581831312813, (2569, 2) = 0.1212483131237999e-15, (2570, 1) = .5956472234924621, (2570, 2) = -0.8081945790299792e-16, (2571, 1) = .596536263853643, (2571, 2) = 0.4040334702845194e-16, (2572, 1) = .5974253042148239, (2572, 2) = -0.161587834466404e-15, (2573, 1) = .5983143445760049, (2573, 2) = 0.8078112745417933e-16, (2574, 1) = .5992033849371857, (2574, 2) = 0.12115248711318852e-15, (2575, 1) = .6000924252983666, (2575, 2) = 0.8075550911933351e-16, (2576, 1) = .6009814656595476, (2576, 2) = .0, (2577, 1) = .6018705060207284, (2577, 2) = -0.4036491961535824e-16, (2578, 1) = .6027595463819093, (2578, 2) = .0, (2579, 1) = .6036485867430902, (2579, 2) = -0.8070411796671843e-16, (2580, 1) = .6045376271042711, (2580, 2) = -0.8069123812470872e-16, (2581, 1) = .605426667465452, (2581, 2) = 0.16135669101153364e-15, (2582, 1) = .6063157078266329, (2582, 2) = -0.806654401322015e-16, (2583, 1) = .6072047481878138, (2583, 2) = -0.40326261013161784e-16, (2584, 1) = .6080937885489948, (2584, 2) = -0.40319795605222845e-16, (2585, 1) = .6089828289101756, (2585, 2) = -0.1612532954137647e-15, (2586, 1) = .6098718692713565, (2586, 2) = -0.8061369153794975e-16, (2587, 1) = .6107609096325374, (2587, 2) = 0.40300361362982895e-16, (2588, 1) = .6116499499937182, (2588, 2) = .0, (2589, 1) = .6125389903548992, (2589, 2) = 0.8057474726212262e-16, (2590, 1) = .6134280307160801, (2590, 2) = -0.8056174065490653e-16, (2591, 1) = .615206111438442, (2591, 2) = .0, (2592, 1) = .6169841921608037, (2592, 2) = 0.8050958891164143e-16, (2593, 1) = .6179596103423364, (2593, 2) = .0, (2594, 1) = .6189350285238691, (2594, 2) = .0, (2595, 1) = .6199104467054017, (2595, 2) = .0, (2596, 1) = .6208858648869344, (2596, 2) = 0.8045214079960945e-16, (2597, 1) = .6218612830684671, (2597, 2) = .0, (2598, 1) = .6228367012499998, (2598, 2) = -0.16084665461670252e-15, (2599, 1) = .6238121194315325, (2599, 2) = -0.8040889830713818e-16, (2600, 1) = .624787537613065, (2600, 2) = 0.1607889090163901e-15, (2601, 1) = .6267383739761303, (2601, 2) = 0.40182761317549225e-16, (2602, 1) = .6286892103391957, (2602, 2) = -0.4016826596251107e-16, (2603, 1) = .630640046702261, (2603, 2) = 0.4015374130696278e-16, (2604, 1) = .6325908830653264, (2604, 2) = 0.8027837493776266e-16, (2605, 1) = .6364925557914571, (2605, 2) = 0.401099927170006e-16, (2606, 1) = .6403942285175878, (2606, 2) = .0, (2607, 1) = .6413696466991203, (2607, 2) = -0.40073337226608026e-16, (2608, 1) = .642345064880653, (2608, 2) = .0, (2609, 1) = .6433204830621857, (2609, 2) = -0.8011724998622324e-16, (2610, 1) = .6442959012437184, (2610, 2) = -0.40051258213034646e-16, (2611, 1) = .6452713194252511, (2611, 2) = -0.8008776868744276e-16, (2612, 1) = .6462467376067837, (2612, 2) = -0.4003650339990748e-16, (2613, 1) = .6472221557883164, (2613, 2) = 0.800582307926547e-16, (2614, 1) = .6481975739698491, (2614, 2) = 0.12006516104314216e-15, (2615, 1) = .6519128890703516, (2615, 2) = .0, (2616, 1) = .6556282041708541, (2616, 2) = -0.39965155963492205e-16, (2617, 1) = .6565570329459798, (2617, 2) = 0.3995805705329883e-16, (2618, 1) = .6574858617211053, (2618, 2) = -0.1198528556483064e-15, (2619, 1) = .6584146904962309, (2619, 2) = 0.1198315213938236e-15, (2620, 1) = .6593435192713566, (2620, 2) = 0.39936722811520056e-16, (2621, 1) = .6612011768216078, (2621, 2) = .0, (2622, 1) = .6630588343718591, (2622, 2) = -0.7981638020783779e-16, (2623, 1) = .6649164919221103, (2623, 2) = 0.3989388667072963e-16, (2624, 1) = .6667741494723616, (2624, 2) = 0.7975911730667652e-16, (2625, 1) = .6686318070226128, (2625, 2) = -0.3986520615324645e-16, (2626, 1) = .6704894645728641, (2626, 2) = -0.7970165854384239e-16, (2627, 1) = .6714182933479897, (2627, 2) = .0, (2628, 1) = .6723471221231153, (2628, 2) = -0.15934571244317285e-15, (2629, 1) = .6732759508982409, (2629, 2) = 0.23897531074194034e-15, (2630, 1) = .6742047796733666, (2630, 2) = 0.11946600831376672e-15, (2631, 1) = .6751336084484922, (2631, 2) = .0, (2632, 1) = .6760624372236178, (2632, 2) = -0.11942266006398627e-15, (2633, 1) = .6769912659987434, (2633, 2) = 0.3980031964913139e-16, (2634, 1) = .677920094773869, (2634, 2) = -0.15917231984930356e-15, (2635, 1) = .6788892301601757, (2635, 2) = .0, (2636, 1) = .6798583655464822, (2636, 2) = 0.7955590609267827e-16, (2637, 1) = .6808275009327887, (2637, 2) = 0.39770379877467724e-16, (2638, 1) = .6817966363190953, (2638, 2) = .0, (2639, 1) = .6837349070917083, (2639, 2) = 0.3974762169974804e-16, (2640, 1) = .6856731778643214, (2640, 2) = 0.7946483499790077e-16, (2641, 1) = .6895497194095475, (2641, 2) = 0.7940386523288305e-16, (2642, 1) = .6934262609547737, (2642, 2) = 0.7934269304827855e-16, (2643, 1) = .6953645317273868, (2643, 2) = .0, (2644, 1) = .6973028024999999, (2644, 2) = -0.3964066013887314e-16, (2645, 1) = .6982719378863064, (2645, 2) = -0.11889891893736646e-15, (2646, 1) = .6992410732726129, (2646, 2) = -0.3962527962260049e-16, (2647, 1) = .7002102086589195, (2647, 2) = 0.39617580083602013e-16, (2648, 1) = .701179344045226, (2648, 2) = 0.7921974875283238e-16, (2649, 1) = .7021484794315325, (2649, 2) = .0, (2650, 1) = .7031176148178391, (2650, 2) = -0.3959444451461767e-16, (2651, 1) = .7040867502041456, (2651, 2) = .0, (2652, 1) = .7050558855904521, (2652, 2) = 0.7915798030285886e-16, (2653, 1) = .7060250209767587, (2653, 2) = 0.19785626908744475e-15, (2654, 1) = .7069941563630652, (2654, 2) = -0.7912702280200256e-16, (2655, 1) = .7079632917493717, (2655, 2) = 0.19777881458111621e-15, (2656, 1) = .7089324271356783, (2656, 2) = 0.11864402513222017e-15, (2657, 1) = .709822395951633, (2657, 2) = 0.11862264590954929e-15, (2658, 1) = .7107123647675878, (2658, 2) = -0.11860125143994806e-15, (2659, 1) = .7116023335835426, (2659, 2) = 0.7905322783766248e-16, (2660, 1) = .7124923023994973, (2660, 2) = -0.3951947229741751e-16, (2661, 1) = .714272240031407, (2661, 2) = .0, (2662, 1) = .7160521776633165, (2662, 2) = 0.11847256628836148e-15, (2663, 1) = .7169421464792713, (2663, 2) = 0.7896737734386331e-16, (2664, 1) = .7178321152952261, (2664, 2) = -0.3947651692020216e-16, (2665, 1) = .7187220841111809, (2665, 2) = -0.15787736074104489e-15, (2666, 1) = .7196120529271357, (2666, 2) = -0.39462158478100844e-16, (2667, 1) = .7205020217430904, (2667, 2) = -0.39454971809709136e-16, (2668, 1) = .7213919905590452, (2668, 2) = -0.3944778019107022e-16, (2669, 1) = .7222819593750001, (2669, 2) = -0.39440583633164276e-16, (2670, 1) = .7231719281909548, (2670, 2) = 0.3943338214696744e-16, (2671, 1) = .7240618970069095, (2671, 2) = .0, (2672, 1) = .7249518658228643, (2672, 2) = 0.78837928867171e-16, (2673, 1) = .7258418346388191, (2673, 2) = -0.3941174822833231e-16, (2674, 1) = .7267318034547738, (2674, 2) = 0.7880905427730414e-16, (2675, 1) = .7276217722707287, (2675, 2) = -0.7879460235100072e-16, (2676, 1) = .7285117410866835, (2676, 2) = -0.3939007034982856e-16, (2677, 1) = .7294017099026382, (2677, 2) = 0.236297008035503e-15, (2678, 1) = .730291678718593, (2678, 2) = .0, (2679, 1) = .7311816475345478, (2679, 2) = 0.39368348807142737e-16, (2680, 1) = .7320716163505026, (2680, 2) = 0.39361098640819154e-16, (2681, 1) = .7329615851664574, (2681, 2) = .0, (2682, 1) = .7338515539824122, (2682, 2) = .0, (2683, 1) = .7347415227983669, (2683, 2) = 0.7867863867716254e-16, (2684, 1) = .7356314916143217, (2684, 2) = 0.19666025003241477e-15, (2685, 1) = .7365214604302766, (2685, 2) = 0.11797432773069693e-15, (2686, 1) = .7374114292462313, (2686, 2) = 0.7863499412147371e-16, (2687, 1) = .76812988040201, (2687, 2) = 0.390634255014834e-16, (2688, 1) = .8000377178894471, (2688, 2) = -0.3879401047494016e-16, (2689, 1) = .8009057137123115, (2689, 2) = -0.3878660768549733e-16, (2690, 1) = .8017737095351758, (2690, 2) = -0.7755840222388405e-16, (2691, 1) = .8026417053580401, (2691, 2) = .0, (2692, 1) = .8035097011809045, (2692, 2) = .0, (2693, 1) = .8043776970037688, (2693, 2) = -0.7751391756788666e-16, (2694, 1) = .8052456928266332, (2694, 2) = -0.7749907434250042e-16, (2695, 1) = .8061136886494975, (2695, 2) = 0.3874211182307057e-16, (2696, 1) = .8069816844723617, (2696, 2) = -0.3873468274911146e-16, (2697, 1) = .807849680295226, (2697, 2) = .0, (2698, 1) = .8087176761180903, (2698, 2) = -0.11615944038795736e-15, (2699, 1) = .8095856719409547, (2699, 2) = 0.11613711980860815e-15, (2700, 1) = .810453667763819, (2700, 2) = 0.1161147881682214e-15, (2701, 1) = .8113216635866833, (2701, 2) = -0.38697481831942027e-16, (2702, 1) = .8121896594095477, (2702, 2) = -0.1934501530340542e-15, (2703, 1) = .813057655232412, (2703, 2) = -0.11604772717103243e-15, (2704, 1) = .8139256510552764, (2704, 2) = -0.15470046876879833e-15, (2705, 1) = .8147936468781407, (2705, 2) = -0.7733531004405704e-16, (2706, 1) = .815661642701005, (2706, 2) = .0, (2707, 1) = .8165296385238694, (2707, 2) = -0.7730543960836182e-16, (2708, 1) = .8173976343467337, (2708, 2) = -0.7729049355155115e-16, (2709, 1) = .8182656301695981, (2709, 2) = 0.3863777014721946e-16, (2710, 1) = .8191336259924624, (2710, 2) = -0.772605798562645e-16, (2711, 1) = .8200016218153268, (2711, 2) = 0.7724561225625455e-16, (2712, 1) = .820869617638191, (2712, 2) = -0.1930765937840572e-15, (2713, 1) = .8217376134610552, (2713, 2) = 0.772156556475704e-16, (2714, 1) = .8226056092839196, (2714, 2) = 0.3860033333864258e-16, (2715, 1) = .8234736051067839, (2715, 2) = .0, (2716, 1) = .8243416009296483, (2716, 2) = 0.19292666875175896e-15, (2717, 1) = .8252095967525126, (2717, 2) = .0, (2718, 1) = .8260775925753769, (2718, 2) = -0.3857032006856131e-16, (2719, 1) = .8269455883982413, (2719, 2) = 0.7712561593303909e-16, (2720, 1) = .8278135842211056, (2720, 2) = -0.15422116947915506e-15, (2721, 1) = .8353132583668341, (2721, 2) = -0.11547063549822252e-15, (2722, 1) = .8428129325125626, (2722, 2) = -0.3842487725313913e-16, (2723, 1) = .8465627695854269, (2723, 2) = 0.767842332104199e-16, (2724, 1) = .8503126066582911, (2724, 2) = 0.1150778841937043e-15, (2725, 1) = .8512500659265072, (2725, 2) = 0.7670215956975074e-16, (2726, 1) = .8521875251947233, (2726, 2) = -0.11502858321292834e-15, (2727, 1) = .8531249844629394, (2727, 2) = 0.766692772026465e-16, (2728, 1) = .8540624437311554, (2728, 2) = 0.1533056495507734e-15, (2729, 1) = .8549999029993713, (2729, 2) = 0.7663636488370646e-16, (2730, 1) = .8559373622675874, (2730, 2) = -0.11492984632667985e-15, (2731, 1) = .8568748215358035, (2731, 2) = 0.38301711400560786e-16, (2732, 1) = .8578122808040196, (2732, 2) = 0.11488041098577965e-15, (2733, 1) = .86168622942211, (2733, 2) = 0.7651875208624763e-16, (2734, 1) = .8655601780402005, (2734, 2) = -0.3822521965162568e-16, (2735, 1) = .866528665194723, (2735, 2) = -0.382166709461809e-16, (2736, 1) = .8674971523492456, (2736, 2) = .0, (2737, 1) = .8684656395037682, (2737, 2) = 0.3819956209605085e-16, (2738, 1) = .8694341266582909, (2738, 2) = 0.15276400790795718e-15, (2739, 1) = .8704026138128136, (2739, 2) = .0, (2740, 1) = .8713711009673362, (2740, 2) = -0.7634774082969169e-16, (2741, 1) = .8723395881218587, (2741, 2) = -0.19082649498659146e-15, (2742, 1) = .8733080752763813, (2742, 2) = -0.7631344767834076e-16, (2743, 1) = .8810559725125622, (2743, 2) = -0.3808798943896259e-16, (2744, 1) = .888803869748743, (2744, 2) = .0, (2745, 1) = .8925937726884416, (2745, 2) = -0.3798520524641197e-16, (2746, 1) = .8963836756281403, (2746, 2) = -0.7590266861061323e-16, (2747, 1) = .9001735785678389, (2747, 2) = 0.3791741087543785e-16, (2748, 1) = .9039634815075375, (2748, 2) = 0.11365030710539805e-15, (2749, 1) = .9058584329773868, (2749, 2) = 0.7573285788616664e-16, (2750, 1) = .9077533844472361, (2750, 2) = 0.37849409526480174e-16, (2751, 1) = .9087008601821607, (2751, 2) = .0, (2752, 1) = .9096483359170854, (2752, 2) = -0.37832377544293696e-16, (2753, 1) = .9105958116520101, (2753, 2) = 0.22694314121940795e-15, (2754, 1) = .9115432873869347, (2754, 2) = 0.1890766654432178e-15, (2755, 1) = .9124907631218593, (2755, 2) = 0.3780680621200649e-16, (2756, 1) = .913438238856784, (2756, 2) = -0.11339482875439385e-15, (2757, 1) = .9143857145917087, (2757, 2) = -0.15115897287392319e-15, (2758, 1) = .9153331903266333, (2758, 2) = -0.3778120712450629e-16, (2759, 1) = .9162806660615579, (2759, 2) = -0.3777266798098069e-16, (2760, 1) = .9172281417964826, (2760, 2) = 0.15105650319732782e-15, (2761, 1) = .9181756175314073, (2761, 2) = 0.7551116118195264e-16, (2762, 1) = .9191230932663319, (2762, 2) = -0.1509881294692734e-15, (2763, 1) = .920039824758166, (2763, 2) = 0.37738758661988526e-16, (2764, 1) = .9209565562500002, (2764, 2) = -0.15092192861936211e-15, (2765, 1) = .9218732877418343, (2765, 2) = 0.15088881142469178e-15, (2766, 1) = .9227900192336685, (2766, 2) = -0.7542784155254814e-16, (2767, 1) = .9246234822173369, (2767, 2) = 0.3769734831388391e-16, (2768, 1) = .9264569452010052, (2768, 2) = 0.7536152969953868e-16, (2769, 1) = .9273736766928393, (2769, 2) = 0.37672469017676014e-16, (2770, 1) = .9282904081846735, (2770, 2) = .0, (2771, 1) = .9292071396765076, (2771, 2) = -0.7531173840909491e-16, (2772, 1) = .9301238711683418, (2772, 2) = 0.18823782621966497e-15, (2773, 1) = .9310406026601761, (2773, 2) = -0.752785171884297e-16, (2774, 1) = .9319573341520102, (2774, 2) = 0.3763094926557724e-16, (2775, 1) = .9328740656438443, (2775, 2) = 0.37622637268193915e-16, (2776, 1) = .9337907971356785, (2776, 2) = .0, (2777, 1) = .9356242601193467, (2777, 2) = .0, (2778, 1) = .9374577231030151, (2778, 2) = .0, (2779, 1) = .9383744545948494, (2779, 2) = -0.37572709808638786e-16, (2780, 1) = .9392911860866835, (2780, 2) = -0.15025751765606566e-15, (2781, 1) = .9402079175785176, (2781, 2) = 0.37556046431659035e-16, (2782, 1) = .9411246490703518, (2782, 2) = 0.3754771087164536e-16, (2783, 1) = .9420413805621859, (2783, 2) = 0.3753937274404348e-16, (2784, 1) = .94295811205402, (2784, 2) = 0.11259309617673255e-15, (2785, 1) = .9438748435458542, (2785, 2) = -0.150090755305177e-15, (2786, 1) = .9447915750376884, (2786, 2) = 0.11254302916868943e-15, (2787, 1) = .9457083065295226, (2787, 2) = .0, (2788, 1) = .9466250380213568, (2788, 2) = -0.1499905757753938e-15, (2789, 1) = .9475417695131909, (2789, 2) = 0.7497858124310064e-16, (2790, 1) = .948458501005025, (2790, 2) = .0, (2791, 1) = .9647444853768843, (2791, 2) = 0.7466417204681757e-16, (2792, 1) = .9810304697487435, (2792, 2) = 0.11154752253379023e-15, (2793, 1) = .9883473104020097, (2793, 2) = 0.37115082942215367e-16, (2794, 1) = .995664151055276, (2794, 2) = .0, (2795, 1) = .9965787561369343, (2795, 2) = -0.3703907340076078e-16, (2796, 1) = .9974933612185926, (2796, 2) = -0.18515308961614768e-15, (2797, 1) = .9984079663002507, (2797, 2) = -0.3702216048539291e-16, (2798, 1) = .999322571381909, (2798, 2) = -0.1480548043862654e-15, (2799, 1) = 1.0002371764635674, (2799, 2) = -0.7401047953210813e-16, (2800, 1) = 1.0011517815452255, (2800, 2) = -0.7399355300629806e-16, (2801, 1) = 1.002066386626884, (2801, 2) = .0, (2802, 1) = 1.0029809917085422, (2802, 2) = 0.14791937686910616e-15, (2803, 1) = 1.0048102018718588, (2803, 2) = 0.7392580862613607e-16, (2804, 1) = 1.0066394120351752, (2804, 2) = .0, (2805, 1) = 1.0075540171168336, (2805, 2) = -0.7387496066813548e-16, (2806, 1) = 1.0084686221984918, (2806, 2) = 0.14771600778087636e-15, (2807, 1) = 1.00938322728015, (2807, 2) = -0.7384104341421658e-16, (2808, 1) = 1.0102978323618084, (2808, 2) = 0.7382407925783139e-16, (2809, 1) = 1.0415469889447229, (2809, 2) = .0, (2810, 1) = 1.0424318758322857, (2810, 2) = -0.14645172268700133e-15, (2811, 1) = 1.0433167627198485, (2811, 2) = -0.7320933152090738e-16, (2812, 1) = 1.0442016496074114, (2812, 2) = .0, (2813, 1) = 1.0450865364949742, (2813, 2) = .0, (2814, 1) = 1.045971423382537, (2814, 2) = 0.7315972518273318e-16, (2815, 1) = 1.0468563102700998, (2815, 2) = 0.7314318416594472e-16, (2816, 1) = 1.0477411971576627, (2816, 2) = 0.14625328078021554e-15, (2817, 1) = 1.0486260840452255, (2817, 2) = 0.7311009387098198e-16, (2818, 1) = 1.0495109709327883, (2818, 2) = -0.14618708924861366e-15, (2819, 1) = 1.0503958578203512, (2819, 2) = 0.7307699266580155e-16, (2820, 1) = 1.051280744707914, (2820, 2) = .0, (2821, 1) = 1.0521656315954768, (2821, 2) = .0, (2822, 1) = 1.0530505184830397, (2822, 2) = -0.2190819620285806e-15, (2823, 1) = 1.0539354053706025, (2823, 2) = -0.7301075802715509e-16, (2824, 1) = 1.0548202922581653, (2824, 2) = -0.7299419274457893e-16, (2825, 1) = 1.0557051791457281, (2825, 2) = 0.7297762484406275e-16, (2826, 1) = 1.056590066033291, (2826, 2) = -0.7296105434118394e-16, (2827, 1) = 1.0574749529208538, (2827, 2) = .0, (2828, 1) = 1.0583598398084166, (2828, 2) = .0, (2829, 1) = 1.0592447266959795, (2829, 2) = 0.14582265474768327e-15, (2830, 1) = 1.0601296135835423, (2830, 2) = .0, (2831, 1) = 1.0610145004711051, (2831, 2) = 0.7287816333513988e-16, (2832, 1) = 1.061899387358668, (2832, 2) = 0.21858473263222426e-15, (2833, 1) = 1.0627842742462308, (2833, 2) = 0.728449892591206e-16, (2834, 1) = 1.066323821796482, (2834, 2) = .0, (2835, 1) = 1.0698633693467334, (2835, 2) = -0.7271219504501146e-16, (2836, 1) = 1.0708307844440952, (2836, 2) = -0.7269403576583911e-16, (2837, 1) = 1.071798199541457, (2837, 2) = -0.7267587369075083e-16, (2838, 1) = 1.072765614638819, (2838, 2) = .0, (2839, 1) = 1.0737330297361807, (2839, 2) = 0.14527908246457944e-15, (2840, 1) = 1.0756678599309044, (2840, 2) = 0.7260319782826366e-16, (2841, 1) = 1.077602690125628, (2841, 2) = .0, (2842, 1) = 1.0785701052229897, (2842, 2) = 0.7254866254515887e-16, (2843, 1) = 1.0795375203203514, (2843, 2) = 0.14506095763145813e-15, (2844, 1) = 1.0805049354177134, (2844, 2) = -0.7251229246819292e-16, (2845, 1) = 1.0814723505150752, (2845, 2) = -0.7249410352216139e-16, (2846, 1) = 1.082439765612437, (2846, 2) = -0.14495182399443253e-15, (2847, 1) = 1.083407180709799, (2847, 2) = 0.7245771791291017e-16, (2848, 1) = 1.0843745958071607, (2848, 2) = .0, (2849, 1) = 1.0853420109045224, (2849, 2) = 0.14484264428855958e-15, (2850, 1) = 1.0863094260018842, (2850, 2) = -0.7240312049891492e-16, (2851, 1) = 1.087276841099246, (2851, 2) = 0.14476983274421587e-15, (2852, 1) = 1.088244256196608, (2852, 2) = 0.1447334195665312e-15, (2853, 1) = 1.0892116712939697, (2853, 2) = 0.21704550225529652e-15, (2854, 1) = 1.0901790863913314, (2854, 2) = 0.7233028929695607e-16, (2855, 1) = 1.0911465014886934, (2855, 2) = .0, (2856, 1) = 1.0921139165860552, (2856, 2) = .0, (2857, 1) = 1.093081331683417, (2857, 2) = .0, (2858, 1) = 1.0969509920728642, (2858, 2) = .0, (2859, 1) = 1.1008206524623114, (2859, 2) = .0, (2860, 1) = 1.1017309146765073, (2860, 2) = .0, (2861, 1) = 1.1026411768907034, (2861, 2) = 0.14419096806461236e-15, (2862, 1) = 1.1035514391048995, (2862, 2) = 0.7207831874506795e-16, (2863, 1) = 1.1044617013190954, (2863, 2) = -0.7206115156327059e-16, (2864, 1) = 1.1053719635332913, (2864, 2) = 0.7204398250264764e-16, (2865, 1) = 1.1062822257474874, (2865, 2) = 0.7202681157890979e-16, (2866, 1) = 1.1071924879616835, (2866, 2) = 0.7200963880774484e-16, (2867, 1) = 1.1081027501758793, (2867, 2) = -0.2159773926144531e-15, (2868, 1) = 1.1090130123900752, (2868, 2) = -0.14395057557154067e-15, (2869, 1) = 1.1099232746042713, (2869, 2) = 0.7195810956622183e-16, (2870, 1) = 1.1108335368184674, (2870, 2) = 0.1438818591235368e-15, (2871, 1) = 1.1117437990326633, (2871, 2) = 0.7192374778798331e-16, (2872, 1) = 1.1126540612468592, (2872, 2) = 0.14381312852083395e-15, (2873, 1) = 1.1135643234610553, (2873, 2) = -0.7188937899459686e-16, (2874, 1) = 1.1144745856752514, (2874, 2) = .0, (2875, 1) = 1.1153848478894473, (2875, 2) = -0.21556500993057256e-15, (2876, 1) = 1.1162951101036431, (2876, 2) = 0.7183781292254543e-16, (2877, 1) = 1.1172053723178392, (2877, 2) = 0.7182062085852726e-16, (2878, 1) = 1.1181156345320353, (2878, 2) = -0.7180342713354934e-16, (2879, 1) = 1.1190258967462312, (2879, 2) = .0, (2880, 1) = 1.119936158960427, (2880, 2) = 0.14353806952450368e-15, (2881, 1) = 1.1208464211746232, (2881, 2) = -0.7175183614664384e-16, (2882, 1) = 1.1217566833888193, (2882, 2) = 0.21520390779449766e-15, (2883, 1) = 1.1226669456030152, (2883, 2) = 0.21515230239634965e-15, (2884, 1) = 1.123577207817211, (2884, 2) = 0.7170023076377152e-16, (2885, 1) = 1.1244874700314071, (2885, 2) = 0.716830258417169e-16, (2886, 1) = 1.1253977322456032, (2886, 2) = 0.7166581938118263e-16, (2887, 1) = 1.1263079944597991, (2887, 2) = 0.14329722279475146e-15, (2888, 1) = 1.128128518888191, (2888, 2) = 0.716141909206578e-16, (2889, 1) = 1.129949043316583, (2889, 2) = .0, (2890, 1) = 1.130900529610553, (2890, 2) = -0.14312353894742647e-15, (2891, 1) = 1.131852015904523, (2891, 2) = -0.7154377285020915e-16, (2892, 1) = 1.1328035021984926, (2892, 2) = -0.7152577467943313e-16, (2893, 1) = 1.1337549884924625, (2893, 2) = .0, (2894, 1) = 1.1347064747864324, (2894, 2) = 0.7148977376466282e-16, (2895, 1) = 1.135657961080402, (2895, 2) = 0.28588708421959645e-15, (2896, 1) = 1.136609447374372, (2896, 2) = -0.28581506746529833e-15, (2897, 1) = 1.1375609336683419, (2897, 2) = -0.7143576121598633e-16, (2898, 1) = 1.1385124199623118, (2898, 2) = 0.714177541209042e-16, (2899, 1) = 1.1394639062562817, (2899, 2) = 0.14279949119614143e-15, (2900, 1) = 1.1404153925502514, (2900, 2) = 0.14276347132890238e-15, (2901, 1) = 1.1413668788442213, (2901, 2) = 0.7136372433698364e-16, (2902, 1) = 1.1423183651381912, (2902, 2) = 0.2140371348977366e-15, (2903, 1) = 1.1432698514321609, (2903, 2) = .0, (2904, 1) = 1.1442213377261308, (2904, 2) = -0.14261936432092916e-15, (2905, 1) = 1.1451728240201007, (2905, 2) = 0.14258333085288082e-15, (2906, 1) = 1.14897876919598, (2906, 2) = 0.7121958556228884e-16, (2907, 1) = 1.1527847143718595, (2907, 2) = .0, (2908, 1) = 1.1537362006658294, (2908, 2) = -0.7112945789696922e-16, (2909, 1) = 1.1546876869597993, (2909, 2) = 0.7111142881887241e-16, (2910, 1) = 1.155639173253769, (2910, 2) = 0.7109339859773103e-16, (2911, 1) = 1.1565906595477389, (2911, 2) = -0.7107536725004775e-16, (2912, 1) = 1.1575421458417088, (2912, 2) = -0.7105733479229813e-16, (2913, 1) = 1.1584936321356785, (2913, 2) = -0.142078602481861e-15, (2914, 1) = 1.1594451184296484, (2914, 2) = .0, (2915, 1) = 1.1603966047236183, (2915, 2) = 0.2840129236919965e-15, (2916, 1) = 1.1613268564918342, (2916, 2) = .0, (2917, 1) = 1.1622571082600504, (2917, 2) = 0.1419359231085426e-15, (2918, 1) = 1.1631873600282665, (2918, 2) = .0, (2919, 1) = 1.1641176117964824, (2919, 2) = 0.7093268831423083e-16, (2920, 1) = 1.1650478635646986, (2920, 2) = 0.7091505028050499e-16, (2921, 1) = 1.1659781153329147, (2921, 2) = -0.14179482264909092e-15, (2922, 1) = 1.1669083671011307, (2922, 2) = 0.7087977146149884e-16, (2923, 1) = 1.1678386188693468, (2923, 2) = -0.7086213070648697e-16, (2924, 1) = 1.168768870637563, (2924, 2) = -0.7084448907460697e-16, (2925, 1) = 1.169699122405779, (2925, 2) = -0.7082684658093126e-16, (2926, 1) = 1.170629374173995, (2926, 2) = .0, (2927, 1) = 1.1715596259422112, (2927, 2) = 0.1415831181367175e-15, (2928, 1) = 1.1724898777104271, (2928, 2) = 0.707739140794832e-16, (2929, 1) = 1.1734201294786433, (2929, 2) = -0.7075626828885447e-16, (2930, 1) = 1.1743503812468594, (2930, 2) = .0, (2931, 1) = 1.1752806330150753, (2931, 2) = -0.7072097436210845e-16, (2932, 1) = 1.1762108847832913, (2932, 2) = 0.2121099787674448e-15, (2933, 1) = 1.1771411365515074, (2933, 2) = 0.14137135481483169e-15, (2934, 1) = 1.1780713883197236, (2934, 2) = 0.7066802783176145e-16, (2935, 1) = 1.1790016400879395, (2935, 2) = 0.7065037754367734e-16, (2936, 1) = 1.1799318918561557, (2936, 2) = .0, (2937, 1) = 1.1808621436243718, (2937, 2) = -0.14123014977879855e-15, (2938, 1) = 1.1817923953925877, (2938, 2) = 0.7059742255273343e-16, (2939, 1) = 1.1827226471608039, (2939, 2) = -0.7057976956269405e-16, (2940, 1) = 1.18365289892902, (2940, 2) = -0.2116863478019511e-15, (2941, 1) = 1.184583150697236, (2941, 2) = -0.14108892336256062e-15, (2942, 1) = 1.1855134024654521, (2942, 2) = -0.7052680681923724e-16, (2943, 1) = 1.1864436542336683, (2943, 2) = 0.7050915136248327e-16, (2944, 1) = 1.1873739060018842, (2944, 2) = -0.7049149532562265e-16, (2945, 1) = 1.1883041577701003, (2945, 2) = 0.7047383872323505e-16, (2946, 1) = 1.1892344095383165, (2946, 2) = .0, (2947, 1) = 1.1901646613065324, (2947, 2) = .0, (2948, 1) = 1.2057468595477387, (2948, 2) = 0.7014268208249618e-16, (2949, 1) = 1.221329057788945, (2949, 2) = 0.13969352167518056e-15, (2950, 1) = 1.2222670270948495, (2950, 2) = -0.6982894678383375e-16, (2951, 1) = 1.223204996400754, (2951, 2) = 0.6981113269318596e-16, (2952, 1) = 1.2241429657066587, (2952, 2) = -0.6979331857963151e-16, (2953, 1) = 1.225080935012563, (2953, 2) = -0.13955100891426003e-15, (2954, 1) = 1.2260189043184675, (2954, 2) = -0.1395153806792325e-15, (2955, 1) = 1.2269568736243721, (2955, 2) = .0, (2956, 1) = 1.2278948429302767, (2956, 2) = 0.6972206217516646e-16, (2957, 1) = 1.2288328122361811, (2957, 2) = 0.6970424815597555e-16, (2958, 1) = 1.2297707815420855, (2958, 2) = -0.6968643419726259e-16, (2959, 1) = 1.2307087508479901, (2959, 2) = -0.1393372406256761e-15, (2960, 1) = 1.2316467201538948, (2960, 2) = .0, (2961, 1) = 1.2325846894597992, (2961, 2) = .0, (2962, 1) = 1.2335226587657036, (2962, 2) = -0.6961517924302699e-16, (2963, 1) = 1.2344606280716082, (2963, 2) = -0.27838946317345703e-15, (2964, 1) = 1.2353985973775128, (2964, 2) = -0.695795524866701e-16, (2965, 1) = 1.2363365666834172, (2965, 2) = 0.20868521800981868e-15, (2966, 1) = 1.2372745359893216, (2966, 2) = .0, (2967, 1) = 1.2382125052952262, (2967, 2) = .0, (2968, 1) = 1.2391504746011308, (2968, 2) = -0.13901660192488553e-15, (2969, 1) = 1.2400884439070352, (2969, 2) = -0.694904885750229e-16, (2970, 1) = 1.2410264132129396, (2970, 2) = 0.13894535282434252e-15, (2971, 1) = 1.2419643825188442, (2971, 2) = 0.6945486448740135e-16, (2972, 1) = 1.2429023518247488, (2972, 2) = 0.1388741056284042e-15, (2973, 1) = 1.2438403211306532, (2973, 2) = -0.6941924140603775e-16, (2974, 1) = 1.2447782904365576, (2974, 2) = -0.1388028605526959e-15, (2975, 1) = 1.2457162597424623, (2975, 2) = 0.6938361943854776e-16, (2976, 1) = 1.2466542290483669, (2976, 2) = -0.6936580890602761e-16, (2977, 1) = 1.2475921983542713, (2977, 2) = -0.6934799869215342e-16, (2978, 1) = 1.2485301676601757, (2978, 2) = .0, (2979, 1) = 1.2494681369660803, (2979, 2) = .0, (2980, 1) = 1.250406106271985, (2980, 2) = .0, (2981, 1) = 1.2513440755778893, (2981, 2) = 0.20783028386872452e-15, (2982, 1) = 1.2523032846670854, (2982, 2) = 0.6925854961152203e-16, (2983, 1) = 1.2532624937562813, (2983, 2) = 0.6924033835035203e-16, (2984, 1) = 1.2542217028454772, (2984, 2) = -0.692221275201751e-16, (2985, 1) = 1.2551809119346733, (2985, 2) = 0.692039171350747e-16, (2986, 1) = 1.2561401210238692, (2986, 2) = .0, (2987, 1) = 1.257099330113065, (2987, 2) = .0, (2988, 1) = 1.2580585392022612, (2988, 2) = -0.6914928879066718e-16, (2989, 1) = 1.259017748291457, (2989, 2) = -0.1382621606523478e-15, (2990, 1) = 1.259976957380653, (2990, 2) = -0.6911287237677427e-16, (2991, 1) = 1.260936166469849, (2991, 2) = .0, (2992, 1) = 1.261895375559045, (2992, 2) = -0.13815291615784648e-15, (2993, 1) = 1.2628545846482409, (2993, 2) = .0, (2994, 1) = 1.263813793737437, (2994, 2) = -0.6904004600818268e-16, (2995, 1) = 1.2647730028266329, (2995, 2) = 0.690218408425715e-16, (2996, 1) = 1.2657322119158287, (2996, 2) = 0.6900363627519606e-16, (2997, 1) = 1.2666914210050249, (2997, 2) = -0.13797086463964089e-15, (2998, 1) = 1.267650630094221, (2998, 2) = -0.6896722899018228e-16, (2999, 1) = 1.2686098391834169, (2999, 2) = .0, (3000, 1) = 1.2695690482726127, (3000, 2) = -0.2067924727888093e-15, (3001, 1) = 1.2705282573618089, (3001, 2) = 0.6891262289267163e-16, (3002, 1) = 1.2714874664510047, (3002, 2) = 0.20668326660849053e-15, (3003, 1) = 1.2724466755402006, (3003, 2) = -0.13775244441403493e-15, (3004, 1) = 1.2734058846293967, (3004, 2) = -0.13771604583762508e-15, (3005, 1) = 1.2743650937185926, (3005, 2) = 0.6883982435176809e-16, (3006, 1) = 1.2782019300753764, (3006, 2) = .0, (3007, 1) = 1.2820387664321604, (3007, 2) = -0.6869426339482764e-16, (3008, 1) = 1.2858438318467333, (3008, 2) = -0.6862210513273439e-16, (3009, 1) = 1.2896488972613063, (3009, 2) = -0.6854996094638496e-16, (3010, 1) = 1.2906001636149496, (3010, 2) = 0.137063854390909e-15, (3011, 1) = 1.2915514299685928, (3011, 2) = 0.6851389438834673e-16, (3012, 1) = 1.2925026963222361, (3012, 2) = .0, (3013, 1) = 1.2934539626758792, (3013, 2) = 0.13695566331303597e-15, (3014, 1) = 1.2944052290295223, (3014, 2) = .0, (3015, 1) = 1.2953564953831656, (3015, 2) = 0.13688354570497042e-15, (3016, 1) = 1.2963077617368088, (3016, 2) = -0.20527123486508522e-15, (3017, 1) = 1.2972590280904521, (3017, 2) = .0, (3018, 1) = 1.2982102944440954, (3018, 2) = -0.6838769223228702e-16, (3019, 1) = 1.2991615607977387, (3019, 2) = 0.6836966743214868e-16, (3020, 1) = 1.300112827151382, (3020, 2) = .0, (3021, 1) = 1.301064093505025, (3021, 2) = -0.6833362101701497e-16, (3022, 1) = 1.3020153598586681, (3022, 2) = .0, (3023, 1) = 1.3029666262123114, (3023, 2) = 0.6829757893201859e-16, (3024, 1) = 1.3039178925659547, (3024, 2) = .0, (3025, 1) = 1.304869158919598, (3025, 2) = .0, (3026, 1) = 1.3058204252732413, (3026, 2) = 0.13648704828254054e-15, (3027, 1) = 1.3067716916268846, (3027, 2) = -0.6822550815038979e-16, (3028, 1) = 1.3077229579805278, (3028, 2) = -0.13641498663288446e-15, (3029, 1) = 1.308674224334171, (3029, 2) = .0, (3030, 1) = 1.309625490687814, (3030, 2) = 0.13634293433713697e-15, (3031, 1) = 1.3105767570414573, (3031, 2) = .0, (3032, 1) = 1.3115280233951006, (3032, 2) = .0, (3033, 1) = 1.3124792897487438, (3033, 2) = -0.6811743693074699e-16, (3034, 1) = 1.3133534047330402, (3034, 2) = 0.6810088973854901e-16, (3035, 1) = 1.3142275197173368, (3035, 2) = 0.13616868718946127e-15, (3036, 1) = 1.3151016347016333, (3036, 2) = -0.13613559701742537e-15, (3037, 1) = 1.3159757496859297, (3037, 2) = -0.1361025089797969e-15, (3038, 1) = 1.316849864670226, (3038, 2) = 0.6803471154767366e-16, (3039, 1) = 1.3177239796545226, (3039, 2) = .0, (3040, 1) = 1.3185980946388192, (3040, 2) = -0.6800162893044778e-16, (3041, 1) = 1.3194722096231155, (3041, 2) = -0.679850892741306e-16, (3042, 1) = 1.3229686695603013, (3042, 2) = .0, (3043, 1) = 1.3264651294974872, (3043, 2) = 0.6785281290491453e-16, (3044, 1) = 1.3334580493718589, (3044, 2) = .0, (3045, 1) = 1.3404509692462305, (3045, 2) = -0.6758849287575188e-16, (3046, 1) = 1.3414528036620597, (3046, 2) = -0.13513914348898202e-15, (3047, 1) = 1.3424546380778888, (3047, 2) = 0.13510130475342997e-15, (3048, 1) = 1.343456472493718, (3048, 2) = 0.13506346957153307e-15, (3049, 1) = 1.344458306909547, (3049, 2) = -0.6751281898495886e-16, (3050, 1) = 1.3454601413253762, (3050, 2) = -0.6749390498757581e-16, (3051, 1) = 1.3464619757412053, (3051, 2) = -0.6747499280687175e-16, (3052, 1) = 1.3474638101570346, (3052, 2) = -0.6745608245607167e-16, (3053, 1) = 1.3484656445728638, (3053, 2) = 0.13487434789674247e-15, (3054, 1) = 1.349467478988693, (3054, 2) = 0.6741826729693681e-16, (3055, 1) = 1.3504693134045223, (3055, 2) = 0.1347987250298108e-15, (3056, 1) = 1.3514711478203514, (3056, 2) = -0.1347609192307696e-15, (3057, 1) = 1.3524729822361805, (3057, 2) = .0, (3058, 1) = 1.3534748166520096, (3058, 2) = .0, (3059, 1) = 1.3544766510678388, (3059, 2) = .0, (3060, 1) = 1.355478485483668, (3060, 2) = 0.6730486710354368e-16, (3061, 1) = 1.356480319899497, (3061, 2) = -0.2691438952486872e-15, (3062, 1) = 1.3574821543153262, (3062, 2) = 0.13453416496268927e-15, (3063, 1) = 1.3584839887311553, (3063, 2) = 0.1344963862479319e-15, (3064, 1) = 1.3594858231469844, (3064, 2) = -0.6722930575291054e-16, (3065, 1) = 1.3604876575628135, (3065, 2) = .0, (3066, 1) = 1.3614894919786427, (3066, 2) = 0.6719153702112377e-16, (3067, 1) = 1.3624913263944718, (3067, 2) = -0.6717265568599715e-16, (3068, 1) = 1.3634931608103011, (3068, 2) = 0.6715377638840334e-16, (3069, 1) = 1.3644949952261303, (3069, 2) = -0.671348991410725e-16, (3070, 1) = 1.3654968296419594, (3070, 2) = 0.20134807187011785e-15, (3071, 1) = 1.3664986640577887, (3071, 2) = 0.20129145254392856e-15, (3072, 1) = 1.3675004984736179, (3072, 2) = 0.13415655965505393e-15, (3073, 1) = 1.368502332889447, (3073, 2) = -0.6705941090797328e-16, (3074, 1) = 1.3695041673052761, (3074, 2) = 0.20112163230570418e-15, (3075, 1) = 1.3705060017211053, (3075, 2) = .0, (3076, 1) = 1.3715078361369344, (3076, 2) = .0, (3077, 1) = 1.3725096705527635, (3077, 2) = -0.13396791298001917e-15, (3078, 1) = 1.3743017758417082, (3078, 2) = .0, (3079, 1) = 1.376093881130653, (3079, 2) = 0.6691649846183366e-16, (3080, 1) = 1.3769899337751252, (3080, 2) = -0.6689963834834616e-16, (3081, 1) = 1.3778859864195976, (3081, 2) = 0.20064834002991375e-15, (3082, 1) = 1.37878203906407, (3082, 2) = 0.13373184691104416e-15, (3083, 1) = 1.3796780917085425, (3083, 2) = .0, (3084, 1) = 1.380574144353015, (3084, 2) = .0, (3085, 1) = 1.3814701969974874, (3085, 2) = .0, (3086, 1) = 1.3823662496419598, (3086, 2) = -0.667985152526108e-16, (3087, 1) = 1.383262302286432, (3087, 2) = 0.13356333549870538e-15, (3088, 1) = 1.3841583549309044, (3088, 2) = 0.6676482208251848e-16, (3089, 1) = 1.3850544075753768, (3089, 2) = -0.13349595652158912e-15, (3090, 1) = 1.3859504602198491, (3090, 2) = 0.6673113629284928e-16, (3091, 1) = 1.3868465128643215, (3091, 2) = -0.6671429618733296e-16, (3092, 1) = 1.3877425655087938, (3092, 2) = 0.2000923738586339e-15, (3093, 1) = 1.3886386181532662, (3093, 2) = -0.20004186479429582e-15, (3094, 1) = 1.3895346707977385, (3094, 2) = -0.2666551485263652e-15, (3095, 1) = 1.3904307234422109, (3095, 2) = 0.26658781824773784e-15, (3096, 1) = 1.3913267760866832, (3096, 2) = .0, (3097, 1) = 1.3922228287311555, (3097, 2) = 0.666132951473964e-16, (3098, 1) = 1.393118881375628, (3098, 2) = -0.6659646831958248e-16, (3099, 1) = 1.3940149340201005, (3099, 2) = 0.13315928684550746e-15, (3100, 1) = 1.394910986664573, (3100, 2) = 0.13312564093079823e-15, (3101, 1) = 1.3958070393090454, (3101, 2) = .0, (3102, 1) = 1.3967030919535177, (3102, 2) = 0.19958754120893738e-15, (3103, 1) = 1.39759914459799, (3103, 2) = 0.6651236331480263e-16, (3104, 1) = 1.3993912498869348, (3104, 2) = -0.6647873506660546e-16, (3105, 1) = 1.4011833551758794, (3105, 2) = -0.19933534433558208e-15, (3106, 1) = 1.4021387341865579, (3106, 2) = -0.6642719493485009e-16, (3107, 1) = 1.4030941131972363, (3107, 2) = -0.6640927738253714e-16, (3108, 1) = 1.4040494922079145, (3108, 2) = -0.6639136213166049e-16, (3109, 1) = 1.405004871218593, (3109, 2) = -0.6637344919226924e-16, (3110, 1) = 1.4069156292399496, (3110, 2) = -0.6633763028802564e-16, (3111, 1) = 1.4088263872613065, (3111, 2) = -0.6630182074974433e-16, (3112, 1) = 1.41264790330402, (3112, 2) = .0, (3113, 1) = 1.4164694193467335, (3113, 2) = 0.13231735568461218e-15, (3114, 1) = 1.417424798357412, (3114, 2) = 0.132281591712735e-15, (3115, 1) = 1.4183801773680904, (3115, 2) = -0.2644916652808889e-15, (3116, 1) = 1.4193355563787686, (3116, 2) = 0.13221007848716093e-15, (3117, 1) = 1.420290935389447, (3117, 2) = -0.6608716463613002e-16, (3118, 1) = 1.4222016934108037, (3118, 2) = -0.13210284573488482e-15, (3119, 1) = 1.4241124514321606, (3119, 2) = -0.19804707327364495e-15, (3120, 1) = 1.425067830442839, (3120, 2) = -0.19799348692276856e-15, (3121, 1) = 1.4260232094535175, (3121, 2) = 0.13195993876829355e-15, (3122, 1) = 1.4269785884641957, (3122, 2) = -0.6596211233041856e-16, (3123, 1) = 1.427933967474874, (3123, 2) = .0, (3124, 1) = 1.4298447254962308, (3124, 2) = -0.6590855648250663e-16, (3125, 1) = 1.4317554835175876, (3125, 2) = -0.13174573087911547e-15, (3126, 1) = 1.4390708404522612, (3126, 2) = .0, (3127, 1) = 1.4463861973869347, (3127, 2) = 0.1311998552683734e-15, (3128, 1) = 1.447300617003769, (3128, 2) = 0.6558288997237591e-16, (3129, 1) = 1.4482150366206032, (3129, 2) = 0.6556585482337915e-16, (3130, 1) = 1.4491294562374373, (3130, 2) = -0.13109764439021597e-15, (3131, 1) = 1.4500438758542715, (3131, 2) = -0.13106358419091184e-15, (3132, 1) = 1.4509582954711058, (3132, 2) = 0.6551476453229834e-16, (3133, 1) = 1.4518727150879398, (3133, 2) = 0.32748869756746325e-15, (3134, 1) = 1.452787134704774, (3134, 2) = -0.13096143409375627e-15, (3135, 1) = 1.4537015543216083, (3135, 2) = -0.19639109142082847e-15, (3136, 1) = 1.4555303935552768, (3136, 2) = -0.6542966503830518e-16, (3137, 1) = 1.457359232788945, (3137, 2) = .0, (3138, 1) = 1.4582736524057793, (3138, 2) = .0, (3139, 1) = 1.4591880720226134, (3139, 2) = -0.6536163189665835e-16, (3140, 1) = 1.4601024916394476, (3140, 2) = .0, (3141, 1) = 1.4610169112562819, (3141, 2) = 0.19598289294163705e-15, (3142, 1) = 1.4620322567242465, (3142, 2) = 0.13061751738728257e-15, (3143, 1) = 1.4630476021922114, (3143, 2) = 0.6528988965929406e-16, (3144, 1) = 1.4640629476601763, (3144, 2) = -0.6527102388793822e-16, (3145, 1) = 1.465078293128141, (3145, 2) = 0.13050432277996196e-15, (3146, 1) = 1.4660936385961059, (3146, 2) = -0.13046660435160534e-15, (3147, 1) = 1.4671089840640708, (3147, 2) = 0.13042889251151338e-15, (3148, 1) = 1.4681243295320354, (3148, 2) = 0.6519559364016958e-16, (3149, 1) = 1.4691396750000003, (3149, 2) = -0.6517674433934107e-16, (3150, 1) = 1.4732010568718596, (3150, 2) = 0.6510138048867095e-16, (3151, 1) = 1.4772624387437188, (3151, 2) = 0.13005214098233611e-15, (3152, 1) = 1.4853852024874372, (3152, 2) = 0.6487561463444176e-16, (3153, 1) = 1.4935079662311557, (3153, 2) = -0.6472538185922412e-16, (3154, 1) = 1.4943871808008793, (3154, 2) = .0, (3155, 1) = 1.495266395370603, (3155, 2) = 0.12938577816735225e-15, (3156, 1) = 1.4961456099403265, (3156, 2) = .0, (3157, 1) = 1.4970248245100501, (3157, 2) = 0.6466040704649784e-16, (3158, 1) = 1.4979040390797738, (3158, 2) = -0.2585766802813061e-15, (3159, 1) = 1.4987832536494974, (3159, 2) = -0.19388380739206096e-15, (3160, 1) = 1.499662468219221, (3160, 2) = 0.6461170423375114e-16, (3161, 1) = 1.5005416827889446, (3161, 2) = -0.6459547538567642e-16, (3162, 1) = 1.5014208973586682, (3162, 2) = .0, (3163, 1) = 1.5023001119283919, (3163, 2) = 0.12912605172133627e-15, (3164, 1) = 1.5031793264981155, (3164, 2) = 0.1290936103919549e-15, (3165, 1) = 1.504058541067839, (3165, 2) = 0.6453058727130041e-16, (3166, 1) = 1.5049377556375627, (3166, 2) = -0.6451437209272258e-16, (3167, 1) = 1.5058169702072863, (3167, 2) = -0.12899631933263035e-15, (3168, 1) = 1.50669618477701, (3168, 2) = 0.12896389999627028e-15, (3169, 1) = 1.5075753993467336, (3169, 2) = -0.12893148618845027e-15, (3170, 1) = 1.511092257625628, (3170, 2) = .0, (3171, 1) = 1.5146091159045225, (3171, 2) = 0.12867237619416578e-15, (3172, 1) = 1.518125974183417, (3172, 2) = 0.642714780404671e-16, (3173, 1) = 1.5216428324623115, (3173, 2) = .0, (3174, 1) = 1.5226407488630653, (3174, 2) = 0.641884730577458e-16, (3175, 1) = 1.523638665263819, (3175, 2) = 0.6417013636646167e-16, (3176, 1) = 1.5246365816645726, (3176, 2) = -0.641518033826785e-16, (3177, 1) = 1.5256344980653265, (3177, 2) = 0.6413347411481257e-16, (3178, 1) = 1.5266324144660803, (3178, 2) = 0.19234544571377122e-15, (3179, 1) = 1.5276303308668342, (3179, 2) = -0.12819365352076442e-15, (3180, 1) = 1.528628247267588, (3180, 2) = .0, (3181, 1) = 1.5296261636683417, (3181, 2) = 0.6406019437004016e-16, (3182, 1) = 1.533617829271357, (3182, 2) = 0.6398697474726295e-16, (3183, 1) = 1.537609494874372, (3183, 2) = 0.6391381577410838e-16, (3184, 1) = 1.5386074112751258, (3184, 2) = -0.6389553556859938e-16, (3185, 1) = 1.5396053276758794, (3185, 2) = 0.19163177758328734e-15, (3186, 1) = 1.540603244076633, (3186, 2) = -0.6385898665967144e-16, (3187, 1) = 1.541601160477387, (3187, 2) = -0.12768143594475537e-15, (3188, 1) = 1.5435969932788947, (3188, 2) = -0.6380419217227465e-16, (3189, 1) = 1.5455928260804022, (3189, 2) = 0.6376768185808079e-16, (3190, 1) = 1.5465907424811558, (3190, 2) = -0.6374943252808944e-16, (3191, 1) = 1.5475886588819097, (3191, 2) = 0.19119356128019464e-15, (3192, 1) = 1.5485865752826635, (3192, 2) = .0, (3193, 1) = 1.5495844916834174, (3193, 2) = 0.6369470794147141e-16, (3194, 1) = 1.5505824080841712, (3194, 2) = 0.6367647423995784e-16, (3195, 1) = 1.5515803244849249, (3195, 2) = 0.6365824446518845e-16, (3196, 1) = 1.5525782408856785, (3196, 2) = -0.6364001862496868e-16, (3197, 1) = 1.5535761572864324, (3197, 2) = -0.6362179672708191e-16, (3198, 1) = 1.5681280367336683, (3198, 2) = 0.6335653294367944e-16, (3199, 1) = 1.5826799161809042, (3199, 2) = 0.12618426514661e-15, (3200, 1) = 1.598597385376884, (3200, 2) = 0.6280393549244186e-16, (3201, 1) = 1.6145148545728638, (3201, 2) = .0, (3202, 1) = 1.6153732348209795, (3202, 2) = -0.1250027504768325e-15, (3203, 1) = 1.616231615069095, (3203, 2) = -0.6248592704418267e-16, (3204, 1) = 1.6170899953172104, (3204, 2) = .0, (3205, 1) = 1.6179483755653261, (3205, 2) = 0.6245504041442577e-16, (3206, 1) = 1.6196651360615575, (3206, 2) = .0, (3207, 1) = 1.6213818965577886, (3207, 2) = -0.1247866126076396e-15, (3208, 1) = 1.622240276805904, (3208, 2) = .0, (3209, 1) = 1.6230986570540198, (3209, 2) = .0, (3210, 1) = 1.6239570373021355, (3210, 2) = 0.12469408020725685e-15, (3211, 1) = 1.6248154175502512, (3211, 2) = -0.18699487382229956e-15, (3212, 1) = 1.6256737977983668, (3212, 2) = -0.6231621240316425e-16, (3213, 1) = 1.6265321780464823, (3213, 2) = 0.6230080349480069e-16, (3214, 1) = 1.6273905582945978, (3214, 2) = .0, (3215, 1) = 1.6282489385427135, (3215, 2) = -0.12453999116330424e-15, (3216, 1) = 1.6291073187908292, (3216, 2) = -0.12450919316954305e-15, (3217, 1) = 1.6299656990389446, (3217, 2) = 0.1244784017992103e-15, (3218, 1) = 1.63082407928706, (3218, 2) = 0.6222380853007846e-16, (3219, 1) = 1.6316824595351758, (3219, 2) = -0.12441683896021239e-15, (3220, 1) = 1.6333992200314071, (3220, 2) = -0.6217765135443087e-16, (3221, 1) = 1.6351159805276383, (3221, 2) = .0, (3222, 1) = 1.6359743607757538, (3222, 2) = 0.6213152415983371e-16, (3223, 1) = 1.6368327410238694, (3223, 2) = .0, (3224, 1) = 1.6376911212719851, (3224, 2) = 0.6210078940443204e-16, (3225, 1) = 1.6385495015201008, (3225, 2) = 0.6208542705055165e-16, (3226, 1) = 1.6394078817682165, (3226, 2) = -0.12414013610196193e-15, (3227, 1) = 1.640266262016332, (3227, 2) = 0.24821884963811546e-15, (3228, 1) = 1.6411246422644474, (3228, 2) = .0, (3229, 1) = 1.6419830225125631, (3229, 2) = -0.620240112161635e-16, (3230, 1) = 1.642960617418342, (3230, 2) = 0.6200653469909372e-16, (3231, 1) = 1.6439382123241209, (3231, 2) = -0.18596718767397406e-15, (3232, 1) = 1.6449158072298997, (3232, 2) = 0.6197159479840229e-16, (3233, 1) = 1.6458934021356786, (3233, 2) = .0, (3234, 1) = 1.6478485919472363, (3234, 2) = -0.619192178639114e-16, (3235, 1) = 1.649803781758794, (3235, 2) = -0.12376864383207675e-15, (3236, 1) = 1.6537141613819095, (3236, 2) = -0.12362916607324408e-15, (3237, 1) = 1.657624541005025, (3237, 2) = -0.12348983026614253e-15, (3238, 1) = 1.6615349206281405, (3238, 2) = -0.12335063709287757e-15, (3239, 1) = 1.665445300251256, (3239, 2) = -0.1232115872267894e-15, (3240, 1) = 1.6664228951570348, (3240, 2) = .0, (3241, 1) = 1.6674004900628137, (3241, 2) = -0.12314211624197354e-15, (3242, 1) = 1.6683780849685925, (3242, 2) = .0, (3243, 1) = 1.6693556798743714, (3243, 2) = .0, (3244, 1) = 1.6713108696859291, (3244, 2) = .0, (3245, 1) = 1.6732660594974869, (3245, 2) = .0, (3246, 1) = 1.6742103679145723, (3246, 2) = .0, (3247, 1) = 1.6751546763316578, (3247, 2) = 0.12286695378587583e-15, (3248, 1) = 1.6760989847487433, (3248, 2) = .0, (3249, 1) = 1.6770432931658288, (3249, 2) = -0.1228000214657073e-15, (3250, 1) = 1.6779876015829143, (3250, 2) = 0.1227665680630645e-15, (3251, 1) = 1.6789319099999997, (3251, 2) = -0.24546624635458985e-15, (3252, 1) = 1.679876218417085, (3252, 2) = -0.12269968681729676e-15, (3253, 1) = 1.6808205268341705, (3253, 2) = -0.1226662589919395e-15, (3254, 1) = 1.6845977605025122, (3254, 2) = .0, (3255, 1) = 1.6883749941708541, (3255, 2) = 0.12239914469106117e-15, (3256, 1) = 1.692152227839196, (3256, 2) = .0, (3257, 1) = 1.6959294615075378, (3257, 2) = -0.12213258162440162e-15, (3258, 1) = 1.6968737699246232, (3258, 2) = .0, (3259, 1) = 1.6978180783417085, (3259, 2) = 0.12206602749982862e-15, (3260, 1) = 1.698762386758794, (3260, 2) = .0, (3261, 1) = 1.6997066951758795, (3261, 2) = 0.12199950816631723e-15, (3262, 1) = 1.700651003592965, (3262, 2) = 0.12196626156695634e-15, (3263, 1) = 1.7015953120100504, (3263, 2) = .0, (3264, 1) = 1.702539620427136, (3264, 2) = .0, (3265, 1) = 1.7034839288442214, (3265, 2) = .0, (3266, 1) = 1.711033461030151, (3266, 2) = -0.12160129968828694e-15, (3267, 1) = 1.7185829932160805, (3267, 2) = -0.2426731768599862e-15, (3268, 1) = 1.7195266847393218, (3268, 2) = .0, (3269, 1) = 1.720470376262563, (3269, 2) = 0.12127049908517769e-15, (3270, 1) = 1.7214140677858043, (3270, 2) = .0, (3271, 1) = 1.7223577593090453, (3271, 2) = .0, (3272, 1) = 1.7242451423555276, (3272, 2) = .0, (3273, 1) = 1.7261325254020101, (3273, 2) = .0, (3274, 1) = 1.7270762169252514, (3274, 2) = -0.1210394664300316e-15, (3275, 1) = 1.7280199084484926, (3275, 2) = .0, (3276, 1) = 1.7289635999717339, (3276, 2) = .0, (3277, 1) = 1.729907291494975, (3277, 2) = 0.24188117249229163e-15, (3278, 1) = 1.730850983018216, (3278, 2) = -0.1209076440811079e-15, (3279, 1) = 1.7317946745414572, (3279, 2) = -0.1208747108765149e-15, (3280, 1) = 1.7327383660646984, (3280, 2) = .0, (3281, 1) = 1.7336820575879397, (3281, 2) = -0.12080887137804057e-15, (3282, 1) = 1.7346222774403266, (3282, 2) = .0, (3283, 1) = 1.7355624972927135, (3283, 2) = .0, (3284, 1) = 1.7365027171451004, (3284, 2) = -0.1207105424377498e-15, (3285, 1) = 1.7374429369974873, (3285, 2) = .0, (3286, 1) = 1.7383831568498742, (3286, 2) = 0.1206450344887135e-15, (3287, 1) = 1.7393233767022611, (3287, 2) = 0.12061229393889292e-15, (3288, 1) = 1.740263596554648, (3288, 2) = 0.12057956234830073e-15, (3289, 1) = 1.741203816407035, (3289, 2) = .0, (3290, 1) = 1.7421440362594218, (3290, 2) = 0.24102825214587986e-15, (3291, 1) = 1.7430842561118087, (3291, 2) = -0.2409628428043554e-15, (3292, 1) = 1.7440244759641956, (3292, 2) = .0, (3293, 1) = 1.7449646958165825, (3293, 2) = .0, (3294, 1) = 1.7459049156689694, (3294, 2) = .0, (3295, 1) = 1.7468451355213563, (3295, 2) = .0, (3296, 1) = 1.7477853553737432, (3296, 2) = -0.120318032995418e-15, (3297, 1) = 1.7487255752261301, (3297, 2) = -0.12028538235170997e-15, (3298, 1) = 1.749665795078517, (3298, 2) = -0.12025274073651163e-15, (3299, 1) = 1.750606014930904, (3299, 2) = .0, (3300, 1) = 1.7515462347832909, (3300, 2) = 0.12018748461878353e-15, (3301, 1) = 1.7524864546356778, (3301, 2) = -0.1201548701297618e-15, (3302, 1) = 1.7534266744880647, (3302, 2) = -0.12012226469626578e-15, (3303, 1) = 1.7543668943404516, (3303, 2) = .0, (3304, 1) = 1.7553071141928385, (3304, 2) = 0.12005708102259613e-15, (3305, 1) = 1.7562473340452254, (3305, 2) = .0, (3306, 1) = 1.760008213454773, (3306, 2) = .0, (3307, 1) = 1.7637690928643206, (3307, 2) = .0, (3308, 1) = 1.7709951483165822, (3308, 2) = .0, (3309, 1) = 1.7782212037688438, (3309, 2) = .0, (3310, 1) = 1.7791244607003764, (3310, 2) = .0, (3311, 1) = 1.7800277176319093, (3311, 2) = 0.11920355956640708e-15, (3312, 1) = 1.780930974563442, (3312, 2) = 0.1191724933623645e-15, (3313, 1) = 1.7818342314949747, (3313, 2) = 0.11914143569284138e-15, (3314, 1) = 1.7827374884265073, (3314, 2) = -0.11911038656313036e-15, (3315, 1) = 1.78364074535804, (3315, 2) = .0, (3316, 1) = 1.7845440022895729, (3316, 2) = -0.11904831394421597e-15, (3317, 1) = 1.7854472592211055, (3317, 2) = 0.11901729046549906e-15, (3318, 1) = 1.7890602869472363, (3318, 2) = 0.1188932822103226e-15, (3319, 1) = 1.792673314673367, (3319, 2) = 0.11876941125784943e-15, (3320, 1) = 1.8082964292964827, (3320, 2) = .0, (3321, 1) = 1.8239195439195983, (3321, 2) = -0.11770392408643126e-15, (3322, 1) = 1.8313645244472363, (3322, 2) = .0, (3323, 1) = 1.8388095049748743, (3323, 2) = 0.11719985915676218e-15, (3324, 1) = 1.839740127540829, (3324, 2) = .0, (3325, 1) = 1.8406707501067838, (3325, 2) = 0.1171370194709795e-15, (3326, 1) = 1.8416013726727387, (3326, 2) = 0.2342112274142153e-15, (3327, 1) = 1.8425319952386934, (3327, 2) = -0.11707421733517215e-15, (3328, 1) = 1.843462617804648, (3328, 2) = .0, (3329, 1) = 1.8443932403706027, (3329, 2) = -0.23402290556952333e-15, (3330, 1) = 1.8453238629365574, (3330, 2) = -0.11698008461506316e-15, (3331, 1) = 1.8462544855025123, (3331, 2) = -0.11694872585485394e-15, (3332, 1) = 1.8471851080684671, (3332, 2) = .0, (3333, 1) = 1.8481157306344218, (3333, 2) = -0.11688603658024043e-15, (3334, 1) = 1.8490463532003765, (3334, 2) = .0, (3335, 1) = 1.8499769757663311, (3335, 2) = 0.1168233849953995e-15, (3336, 1) = 1.8509075983322858, (3336, 2) = 0.2335841466946657e-15, (3337, 1) = 1.8518382208982407, (3337, 2) = -0.23352154226899477e-15, (3338, 1) = 1.8527688434641956, (3338, 2) = -0.11672947836111536e-15, (3339, 1) = 1.8536994660301502, (3339, 2) = -0.11669819503138967e-15, (3340, 1) = 1.8546789024591703, (3340, 2) = -0.116665281004205e-15, (3341, 1) = 1.8556583388881904, (3341, 2) = -0.23326475489368275e-15, (3342, 1) = 1.8566377753172105, (3342, 2) = -0.1165994843641292e-15, (3343, 1) = 1.8576172117462306, (3343, 2) = 0.11656660176087526e-15, (3344, 1) = 1.8585966481752507, (3344, 2) = 0.11653372964186293e-15, (3345, 1) = 1.8595760846042708, (3345, 2) = 0.11650086801185206e-15, (3346, 1) = 1.860555521033291, (3346, 2) = -0.11646801687557918e-15, (3347, 1) = 1.8615349574623112, (3347, 2) = .0, (3348, 1) = 1.8634938303203517, (3348, 2) = 0.116369526476203e-15, (3349, 1) = 1.8654527031783918, (3349, 2) = 0.23260783752885726e-15, (3350, 1) = 1.866432139607412, (3350, 2) = .0, (3351, 1) = 1.867411576036432, (3351, 2) = -0.11623835313930327e-15, (3352, 1) = 1.8683910124654521, (3352, 2) = .0, (3353, 1) = 1.8693704488944722, (3353, 2) = .0, (3354, 1) = 1.8713293217525124, (3354, 2) = .0, (3355, 1) = 1.8732881946105526, (3355, 2) = .0, (3356, 1) = 1.8742676310395727, (3356, 2) = .0, (3357, 1) = 1.8752470674685928, (3357, 2) = -0.11597651222978588e-15, (3358, 1) = 1.876226503897613, (3358, 2) = -0.1159438296185689e-15, (3359, 1) = 1.8772059403266332, (3359, 2) = -0.11591115757807547e-15, (3360, 1) = 1.8781853767556536, (3360, 2) = .0, (3361, 1) = 1.8791648131846737, (3361, 2) = -0.11584584522653014e-15, (3362, 1) = 1.8801442496136938, (3362, 2) = .0, (3363, 1) = 1.8811236860427138, (3363, 2) = -0.231561150418934e-15, (3364, 1) = 1.882103122471734, (3364, 2) = 0.11574795608699228e-15, (3365, 1) = 1.883082558900754, (3365, 2) = .0, (3366, 1) = 1.8840619953297741, (3366, 2) = 0.11568274963521313e-15, (3367, 1) = 1.8850414317587942, (3367, 2) = 0.2313003246285292e-15, (3368, 1) = 1.8859280575816586, (3368, 2) = -0.11562067208998855e-15, (3369, 1) = 1.886814683404523, (3369, 2) = .0, (3370, 1) = 1.887701309227387, (3370, 2) = -0.1155617177342169e-15, (3371, 1) = 1.8885879350502515, (3371, 2) = .0, (3372, 1) = 1.8894745608731158, (3372, 2) = 0.115502798189039e-15, (3373, 1) = 1.89036118669598, (3373, 2) = -0.11547335147794973e-15, (3374, 1) = 1.8912478125188443, (3374, 2) = -0.11544391347851186e-15, (3375, 1) = 1.8921344383417087, (3375, 2) = -0.11541448419369572e-15, (3376, 1) = 1.893021064164573, (3376, 2) = -0.115385063626457e-15, (3377, 1) = 1.8939076899874374, (3377, 2) = .0, (3378, 1) = 1.8947943158103016, (3378, 2) = 0.11532624865646136e-15, (3379, 1) = 1.895680941633166, (3379, 2) = 0.2305937085190854e-15, (3380, 1) = 1.8974541932788944, (3380, 2) = 0.1152380916563503e-15, (3381, 1) = 1.8992274449246231, (3381, 2) = .0, (3382, 1) = 1.9010006965703519, (3382, 2) = .0, (3383, 1) = 1.9027739482160804, (3383, 2) = .0, (3384, 1) = 1.9036605740389447, (3384, 2) = 0.1150326978466032e-15, (3385, 1) = 1.9045471998618089, (3385, 2) = -0.2300067817404328e-15, (3386, 1) = 1.9054338256846732, (3386, 2) = .0, (3387, 1) = 1.9063204515075376, (3387, 2) = 0.11494480319248042e-15, (3388, 1) = 1.907207077330402, (3388, 2) = 0.11491552249659517e-15, (3389, 1) = 1.9080937031532663, (3389, 2) = -0.2297725011326347e-15, (3390, 1) = 1.9089803289761305, (3390, 2) = -0.11485698740434347e-15, (3391, 1) = 1.9098669547989948, (3391, 2) = 0.22965546602671173e-15, (3392, 1) = 1.9107535806218592, (3392, 2) = .0, (3393, 1) = 1.9116402064447233, (3393, 2) = .0, (3394, 1) = 1.9125268322675877, (3394, 2) = -0.11474002249292275e-15, (3395, 1) = 1.913413458090452, (3395, 2) = -0.114710803212422e-15, (3396, 1) = 1.9212525581909545, (3396, 2) = .0, (3397, 1) = 1.929091658291457, (3397, 2) = 0.11419557217291694e-15, (3398, 1) = 1.9300715458040199, (3398, 2) = 0.11416346174925876e-15, (3399, 1) = 1.9310514333165827, (3399, 2) = .0, (3400, 1) = 1.9320313208291455, (3400, 2) = .0, (3401, 1) = 1.9330112083417084, (3401, 2) = .0, (3402, 1) = 1.934970983366834, (3402, 2) = -0.11400307148613328e-15, (3403, 1) = 1.9369307583919595, (3403, 2) = -0.2278779819428276e-15, (3404, 1) = 1.9379106459045223, (3404, 2) = -0.11390696692429983e-15, (3405, 1) = 1.938890533417085, (3405, 2) = -0.11387495368804854e-15, (3406, 1) = 1.9398704209296478, (3406, 2) = .0, (3407, 1) = 1.9408503084422106, (3407, 2) = -0.11381095966011166e-15, (3408, 1) = 1.9428100834673363, (3408, 2) = .0, (3409, 1) = 1.944769858492462, (3409, 2) = 0.11368310146524453e-15, (3410, 1) = 1.9457084199780148, (3410, 2) = 0.11365251070845633e-15, (3411, 1) = 1.9466469814635676, (3411, 2) = -0.11362192989127905e-15, (3412, 1) = 1.9475855429491205, (3412, 2) = 0.2271827180324238e-15, (3413, 1) = 1.948524104434673, (3413, 2) = -0.11356079808573787e-15, (3414, 1) = 1.9494626659202257, (3414, 2) = -0.2270604942046473e-15, (3415, 1) = 1.9504012274057785, (3415, 2) = .0, (3416, 1) = 1.9513397888913313, (3416, 2) = .0, (3417, 1) = 1.9522783503768841, (3417, 2) = .0, (3418, 1) = 1.953216911862437, (3418, 2) = -0.1134081426880314e-15, (3419, 1) = 1.9541554733479898, (3419, 2) = -0.11337764147634972e-15, (3420, 1) = 1.9550940348335426, (3420, 2) = 0.1133471502261883e-15, (3421, 1) = 1.9560325963190952, (3421, 2) = .0, (3422, 1) = 1.9569711578046478, (3422, 2) = .0, (3423, 1) = 1.9579097192902006, (3423, 2) = -0.1132557362682836e-15, (3424, 1) = 1.9588482807757535, (3424, 2) = .0, (3425, 1) = 1.9597868422613063, (3425, 2) = 0.11319484348000855e-15, (3426, 1) = 1.960725403746859, (3426, 2) = .0, (3427, 1) = 1.961663965232412, (3427, 2) = .0, (3428, 1) = 1.9626025267179648, (3428, 2) = -0.1131035791187299e-15, (3429, 1) = 1.9635410882035174, (3429, 2) = .0, (3430, 1) = 1.96447964968907, (3430, 2) = .0, (3431, 1) = 1.9654182111746228, (3431, 2) = 0.11301240459653847e-15, (3432, 1) = 1.9663567726601756, (3432, 2) = 0.22596406612732906e-15, (3433, 1) = 1.9672953341457284, (3433, 2) = 0.11295167152167202e-15, (3434, 1) = 1.9682338956312813, (3434, 2) = -0.11292131997270936e-15, (3435, 1) = 1.969172457116834, (3435, 2) = -0.11289097841890947e-15, (3436, 1) = 1.970111018602387, (3436, 2) = -0.22572129372477954e-15, (3437, 1) = 1.9710495800879395, (3437, 2) = -0.2256606506105042e-15, (3438, 1) = 1.972926703059045, (3438, 2) = -0.11276971219745321e-15, (3439, 1) = 1.9748038260301506, (3439, 2) = .0, (3440, 1) = 1.9757401030307786, (3440, 2) = .0, (3441, 1) = 1.9766763800314069, (3441, 2) = 0.22529750671143865e-15, (3442, 1) = 1.9776126570320351, (3442, 2) = -0.1126185754240297e-15, (3443, 1) = 1.9785489340326632, (3443, 2) = .0, (3444, 1) = 1.9794852110332912, (3444, 2) = .0, (3445, 1) = 1.9804214880339195, (3445, 2) = 0.2250562028766702e-15, (3446, 1) = 1.9813577650345477, (3446, 2) = -0.1124979633860108e-15, (3447, 1) = 1.9822940420351758, (3447, 2) = -0.22493567061665455e-15, (3448, 1) = 1.9832303190358038, (3448, 2) = .0, (3449, 1) = 1.984166596036432, (3449, 2) = -0.2248152181688545e-15, (3450, 1) = 1.9851028730370603, (3450, 2) = -0.33713253282583757e-15, (3451, 1) = 1.9860391500376884, (3451, 2) = 0.22469484556315126e-15, (3452, 1) = 1.9869754270383164, (3452, 2) = .0, (3453, 1) = 1.9879117040389447, (3453, 2) = 0.11228727641447587e-15, (3454, 1) = 1.988847981039573, (3454, 2) = .0, (3455, 1) = 1.989784258040201, (3455, 2) = 0.1122271699975953e-15, (3456, 1) = 1.9916568120414573, (3456, 2) = 0.1121671035451661e-15, (3457, 1) = 1.9935293660427136, (3457, 2) = 0.11210707707118623e-15, (3458, 1) = 1.9944656430433416, (3458, 2) = .0, (3459, 1) = 1.9954019200439699, (3459, 2) = .0, (3460, 1) = 1.9963381970445981, (3460, 2) = 0.1120171123498563e-15, (3461, 1) = 1.9972744740452262, (3461, 2) = .0, (3462, 1) = 1.9982107510458542, (3462, 2) = -0.11195718588171396e-15, (3463, 1) = 1.9991470280464825, (3463, 2) = .0, (3464, 1) = 2.0000833050471107, (3464, 2) = 0.11189729943918493e-15, (3465, 1) = 2.0010195820477388, (3465, 2) = -0.11186737123158341e-15, (3466, 1) = 2.0019558590483673, (3466, 2) = -0.1118374530352262e-15, (3467, 1) = 2.0028921360489953, (3467, 2) = .0, (3468, 1) = 2.0038284130496233, (3468, 2) = 0.1117776466825661e-15, (3469, 1) = 2.0047646900502514, (3469, 2) = .0, (3470, 1) = 2.0057426350062815, (3470, 2) = -0.33514965280115223e-15, (3471, 1) = 2.0067205799623116, (3471, 2) = 0.11168535426875626e-15, (3472, 1) = 2.0076985249183417, (3472, 2) = 0.1116541685362281e-15, (3473, 1) = 2.0086764698743718, (3473, 2) = 0.11162299373783932e-15, (3474, 1) = 2.010632359786432, (3474, 2) = .0, (3475, 1) = 2.012588249698492, (3475, 2) = -0.11149840391922292e-15, (3476, 1) = 2.0135661946545222, (3476, 2) = -0.11146728381654418e-15, (3477, 1) = 2.0145441396105523, (3477, 2) = -0.11143617465789387e-15, (3478, 1) = 2.0155220845665824, (3478, 2) = -0.11140507644486232e-15, (3479, 1) = 2.0165000295226125, (3479, 2) = -0.22274797835804666e-15, (3480, 1) = 2.0174779744786426, (3480, 2) = .0, (3481, 1) = 2.0184559194346727, (3481, 2) = .0, (3482, 1) = 2.0194338643907033, (3482, 2) = 0.22256158616030915e-15, (3483, 1) = 2.0204118093467334, (3483, 2) = .0, (3484, 1) = 2.0213897543027635, (3484, 2) = -0.11121871711165588e-15, (3485, 1) = 2.022367699258794, (3485, 2) = 0.22237539112221466e-15, (3486, 1) = 2.023345644214824, (3486, 2) = 0.1111566849683112e-15, (3487, 1) = 2.024323589170854, (3487, 2) = .0, (3488, 1) = 2.0253015341268843, (3488, 2) = .0, (3489, 1) = 2.0262794790829144, (3489, 2) = -0.1110637189507936e-15, (3490, 1) = 2.0272574240389445, (3490, 2) = 0.11103275220328313e-15, (3491, 1) = 2.0282353689949746, (3491, 2) = -0.1110017964205829e-15, (3492, 1) = 2.0292133139510047, (3492, 2) = 0.11097085160405642e-15, (3493, 1) = 2.030191258907035, (3493, 2) = -0.22187983551010275e-15, (3494, 1) = 2.031169203863065, (3494, 2) = .0, (3495, 1) = 2.032147148819095, (3495, 2) = 0.11087808296491682e-15, (3496, 1) = 2.033125093775125, (3496, 2) = -0.2216943640528067e-15, (3497, 1) = 2.034103038731155, (3497, 2) = -0.11081629206064352e-15, (3498, 1) = 2.0350809836871853, (3498, 2) = .0, (3499, 1) = 2.0360589286432154, (3499, 2) = 0.11075454505244349e-15, (3500, 1) = 2.0369596516488686, (3500, 2) = 0.22145224838598683e-15, (3501, 1) = 2.037860374654522, (3501, 2) = -0.11069771264596454e-15, (3502, 1) = 2.038761097660175, (3502, 2) = 0.11066931041230062e-15, (3503, 1) = 2.0396618206658284, (3503, 2) = 0.11064091749293423e-15, (3504, 1) = 2.0405625436714816, (3504, 2) = 0.11061253388878681e-15, (3505, 1) = 2.041463266677135, (3505, 2) = .0, (3506, 1) = 2.042363989682788, (3506, 2) = -0.11055579462977878e-15, (3507, 1) = 2.0432647126884413, (3507, 2) = .0, (3508, 1) = 2.0441654356940946, (3508, 2) = -0.11049909264242537e-15, (3509, 1) = 2.045066158699748, (3509, 2) = 0.11047075562780472e-15, (3510, 1) = 2.045966881705401, (3510, 2) = 0.1104424279336983e-15, (3511, 1) = 2.0468676047110543, (3511, 2) = -0.11041410956095002e-15, (3512, 1) = 2.0477683277167076, (3512, 2) = -0.3311574015311786e-15, (3513, 1) = 2.048669050722361, (3513, 2) = .0, (3514, 1) = 2.049569773728014, (3514, 2) = 0.11032921037912872e-15, (3515, 1) = 2.0504704967336678, (3515, 2) = .0, (3516, 1) = 2.0513712197393215, (3516, 2) = -0.33081797263905206e-15, (3517, 1) = 2.0522719427449747, (3517, 2) = .0, (3518, 1) = 2.053172665750628, (3518, 2) = 0.11021614201832957e-15, (3519, 1) = 2.054073388756281, (3519, 2) = -0.11018789824551499e-15, (3520, 1) = 2.0549741117619345, (3520, 2) = 0.22031932760232526e-15, (3521, 1) = 2.0558748347675877, (3521, 2) = -0.11013143868600772e-15, (3522, 1) = 2.056775557773241, (3522, 2) = 0.11010322290077468e-15, (3523, 1) = 2.057676280778894, (3523, 2) = .0, (3524, 1) = 2.0585770037845474, (3524, 2) = .0, (3525, 1) = 2.0594777267902007, (3525, 2) = 0.11001863153169107e-15, (3526, 1) = 2.060378449795854, (3526, 2) = 0.2199809061463527e-15, (3527, 1) = 2.061279172801507, (3527, 2) = .0, (3528, 1) = 2.0621798958071604, (3528, 2) = -0.10993412415695929e-15, (3529, 1) = 2.0630806188128137, (3529, 2) = -0.2198119474011348e-15, (3530, 1) = 2.063981341818467, (3530, 2) = 0.32963349773852793e-15, (3531, 1) = 2.06488206482412, (3531, 2) = 0.10984970079441391e-15, (3532, 1) = 2.065804528388819, (3532, 2) = -0.21964179935152217e-15, (3533, 1) = 2.066726991953517, (3533, 2) = .0, (3534, 1) = 2.0676494555182154, (3534, 2) = 0.10976332681924654e-15, (3535, 1) = 2.068571919082914, (3535, 2) = 0.3292036652479678e-15, (3536, 1) = 2.069494382647613, (3536, 2) = -0.21941158628267618e-15, (3537, 1) = 2.070416846212311, (3537, 2) = -0.10967704099589996e-15, (3538, 1) = 2.0713393097770094, (3538, 2) = -0.21929659729387415e-15, (3539, 1) = 2.072261773341708, (3539, 2) = .0, (3540, 1) = 2.075951627600502, (3540, 2) = .0, (3541, 1) = 2.079641481859296, (3541, 2) = .0, (3542, 1) = 2.080563945423995, (3542, 2) = 0.10936141408636177e-15, (3543, 1) = 2.081486408988693, (3543, 2) = -0.109332779534696e-15, (3544, 1) = 2.0824088725533914, (3544, 2) = -0.2186083095715434e-15, (3545, 1) = 2.08333133611809, (3545, 2) = 0.21855107968007694e-15, (3546, 1) = 2.084253799682789, (3546, 2) = .0, (3547, 1) = 2.085176263247487, (3547, 2) = 0.10921833935988851e-15, (3548, 1) = 2.0860987268121853, (3548, 2) = 0.10918975382631585e-15, (3549, 1) = 2.087021190376884, (3549, 2) = -0.10916117809762246e-15, (3550, 1) = 2.0879436539415828, (3550, 2) = 0.109132612174203e-15, (3551, 1) = 2.088866117506281, (3551, 2) = .0, (3552, 1) = 2.0897885810709793, (3552, 2) = 0.10907550974470979e-15, (3553, 1) = 2.090711044635678, (3553, 2) = 0.2180939464787415e-15, (3554, 1) = 2.0916335082003767, (3554, 2) = -0.21803689308155024e-15, (3555, 1) = 2.092555971765075, (3555, 2) = 0.21797985929852646e-15, (3556, 1) = 2.0934784353297733, (3556, 2) = -0.21792284513032902e-15, (3557, 1) = 2.094400898894472, (3557, 2) = 0.10893292528879766e-15, (3558, 1) = 2.1106970490452257, (3558, 2) = .0, (3559, 1) = 2.1269931991959794, (3559, 2) = -0.10793236182565325e-15, (3560, 1) = 2.130681906482412, (3560, 2) = .0, (3561, 1) = 2.134370613768844, (3561, 2) = 0.10770757980598433e-15, (3562, 1) = 2.138059321055276, (3562, 2) = 0.10759542412724355e-15, (3563, 1) = 2.1417480283417083, (3563, 2) = 0.10748342532319486e-15, (3564, 1) = 2.1454367356281407, (3564, 2) = .0, (3565, 1) = 2.1491254429145727, (3565, 2) = -0.10725989828633626e-15, (3566, 1) = 2.1500476197361804, (3566, 2) = -0.1072320015179727e-15, (3567, 1) = 2.1509697965577885, (3567, 2) = 0.10720411455117596e-15, (3568, 1) = 2.1518919733793966, (3568, 2) = -0.10717623738564085e-15, (3569, 1) = 2.1528141502010048, (3569, 2) = 0.10714837002105295e-15, (3570, 1) = 2.153736327022613, (3570, 2) = -0.10712051245708854e-15, (3571, 1) = 2.154658503844221, (3571, 2) = 0.1070926646934147e-15, (3572, 1) = 2.155580680665829, (3572, 2) = 0.1070648267296893e-15, (3573, 1) = 2.156502857487437, (3573, 2) = -0.10703699856556099e-15, (3574, 1) = 2.1574459560207284, (3574, 2) = .0, (3575, 1) = 2.15838905455402, (3575, 2) = -0.10698011006390415e-15, (3576, 1) = 2.1593321530873117, (3576, 2) = -0.21390336237090535e-15, (3577, 1) = 2.160275251620603, (3577, 2) = .0, (3578, 1) = 2.161218350153894, (3578, 2) = -0.10689485417122674e-15, (3579, 1) = 2.162161448687186, (3579, 2) = -0.21373291206918353e-15, (3580, 1) = 2.1631045472204775, (3580, 2) = 0.10683806814435193e-15, (3581, 1) = 2.1640476457537687, (3581, 2) = -0.2136193810001048e-15, (3582, 1) = 2.16499074428706, (3582, 2) = 0.10678132310122837e-15, (3583, 1) = 2.1659338428203516, (3583, 2) = 0.21350593189481055e-15, (3584, 1) = 2.1668769413536433, (3584, 2) = -0.1067246190380988e-15, (3585, 1) = 2.1678200398869345, (3585, 2) = 0.21339256474562976e-15, (3586, 1) = 2.1687631384202257, (3586, 2) = .0, (3587, 1) = 2.1697062369535174, (3587, 2) = 0.10663963977228961e-15, (3588, 1) = 2.170649335486809, (3588, 2) = .0, (3589, 1) = 2.1715924340201003, (3589, 2) = 0.21316607628336548e-15, (3590, 1) = 2.1725355325533915, (3590, 2) = -0.21310950537752109e-15, (3591, 1) = 2.173478631086683, (3591, 2) = 0.3195794324300787e-15, (3592, 1) = 2.174421729619975, (3592, 2) = .0, (3593, 1) = 2.175364828153266, (3593, 2) = .0, (3594, 1) = 2.1763079266865573, (3594, 2) = .0, (3595, 1) = 2.177251025219849, (3595, 2) = .0, (3596, 1) = 2.1781941237531406, (3596, 2) = .0, (3597, 1) = 2.179137222286432, (3597, 2) = 0.2127140824602222e-15, (3598, 1) = 2.180080320819723, (3598, 2) = -0.21265767537552946e-15, (3599, 1) = 2.1810234193530147, (3599, 2) = .0, (3600, 1) = 2.1819665178863064, (3600, 2) = 0.10627246131071877e-15, (3601, 1) = 2.1829096164195976, (3601, 2) = .0, (3602, 1) = 2.183852714952889, (3602, 2) = -0.10621612587290515e-15, (3603, 1) = 2.1847958134861805, (3603, 2) = .0, (3604, 1) = 2.185738912019472, (3604, 2) = 0.10615983136903683e-15, (3605, 1) = 2.1866820105527633, (3605, 2) = 0.10613169946563933e-15, (3606, 1) = 2.1876411174685924, (3606, 2) = 0.31830930161377203e-15, (3607, 1) = 2.1886002243844214, (3607, 2) = 0.21214902438239127e-15, (3608, 1) = 2.1895593313002504, (3608, 2) = 0.10604593442470526e-15, (3609, 1) = 2.19051843821608, (3609, 2) = -0.3180521017130824e-15, (3610, 1) = 2.1914775451319093, (3610, 2) = 0.31796643188818115e-15, (3611, 1) = 2.1924366520477383, (3611, 2) = -0.21192052919805143e-15, (3612, 1) = 2.1933957589635673, (3612, 2) = -0.1059317291458021e-15, (3613, 1) = 2.1943548658793963, (3613, 2) = -0.3177096128067751e-15, (3614, 1) = 2.1953139727952253, (3614, 2) = -0.21174937993517415e-15, (3615, 1) = 2.196273079711055, (3615, 2) = .0, (3616, 1) = 2.1972321866268842, (3616, 2) = .0, (3617, 1) = 2.1981912935427133, (3617, 2) = 0.1057892105085881e-15, (3618, 1) = 2.1991504004585423, (3618, 2) = 0.10576073850113873e-15, (3619, 1) = 2.2001095073743713, (3619, 2) = -0.10573227706504649e-15, (3620, 1) = 2.2010686142902003, (3620, 2) = 0.21140765239889258e-15, (3621, 1) = 2.2020277212060297, (3621, 2) = -0.1056753859034634e-15, (3622, 1) = 2.202986828121859, (3622, 2) = -0.10564695617621372e-15, (3623, 1) = 2.203945935037688, (3623, 2) = .0, (3624, 1) = 2.204905041953517, (3624, 2) = .0, (3625, 1) = 2.2058641488693462, (3625, 2) = 0.2111234607957608e-15, (3626, 1) = 2.2068232557851752, (3626, 2) = 0.2110666858730658e-15, (3627, 1) = 2.2077823627010047, (3627, 2) = -0.2110099320787123e-15, (3628, 1) = 2.208741469616834, (3628, 2) = -0.10547659970540963e-15, (3629, 1) = 2.209700576532663, (3629, 2) = 0.31634473180122993e-15, (3630, 1) = 2.210659683448492, (3630, 2) = .0, (3631, 1) = 2.211618790364321, (3631, 2) = -0.21078312814681025e-15, (3632, 1) = 2.21257789728015, (3632, 2) = .0, (3633, 1) = 2.2135370041959797, (3633, 2) = .0, (3634, 1) = 2.214496111111809, (3634, 2) = 0.1053066234757171e-15, (3635, 1) = 2.215455218027638, (3635, 2) = -0.10527833105726391e-15, (3636, 1) = 2.216414324943467, (3636, 2) = .0, (3637, 1) = 2.217373431859296, (3637, 2) = 0.10522177788544817e-15, (3638, 1) = 2.218255037751256, (3638, 2) = .0, (3639, 1) = 2.219136643643216, (3639, 2) = .0, (3640, 1) = 2.2200182495351757, (3640, 2) = 0.10514387205577618e-15, (3641, 1) = 2.2208998554271355, (3641, 2) = 0.10511792127547345e-15, (3642, 1) = 2.222663067211055, (3642, 2) = .0, (3643, 1) = 2.224426278994975, (3643, 2) = -0.10501420728007288e-15, (3644, 1) = 2.2253078848869348, (3644, 2) = -0.2099766021169078e-15, (3645, 1) = 2.2261894907788946, (3645, 2) = -0.31488721123804943e-15, (3646, 1) = 2.2270710966708545, (3646, 2) = -0.10493651534189409e-15, (3647, 1) = 2.2279527025628143, (3647, 2) = -0.1049106358452138e-15, (3648, 1) = 2.228834308454774, (3648, 2) = -0.1048847652550964e-15, (3649, 1) = 2.229715914346734, (3649, 2) = .0, (3650, 1) = 2.2305975202386934, (3650, 2) = .0, (3651, 1) = 2.2314791261306532, (3651, 2) = 0.20961441383047014e-15, (3652, 1) = 2.232360732022613, (3652, 2) = -0.10478137194245137e-15, (3653, 1) = 2.2332423379145725, (3653, 2) = .0, (3654, 1) = 2.2341239438065323, (3654, 2) = .0, (3655, 1) = 2.235005549698492, (3655, 2) = -0.20940784086572552e-15, (3656, 1) = 2.235887155590452, (3656, 2) = -0.10467812106284409e-15, (3657, 1) = 2.236768761482412, (3657, 2) = -0.10465233059119377e-15, (3658, 1) = 2.2376503673743717, (3658, 2) = -0.20925309803394044e-15, (3659, 1) = 2.2385319732663316, (3659, 2) = -0.10460077633922581e-15, (3660, 1) = 2.242058396834171, (3660, 2) = .0, (3661, 1) = 2.2455848204020104, (3661, 2) = 0.10439491507478187e-15, (3662, 1) = 2.246524583734297, (3662, 2) = 0.10436752785104794e-15, (3663, 1) = 2.2474643470665834, (3663, 2) = 0.41736060290017063e-15, (3664, 1) = 2.2484041103988694, (3664, 2) = 0.3129383510866102e-15, (3665, 1) = 2.249343873731156, (3665, 2) = -0.10428542676129317e-15, (3666, 1) = 2.2512234003957285, (3666, 2) = .0, (3667, 1) = 2.2531029270603016, (3667, 2) = 0.10417609995193435e-15, (3668, 1) = 2.254042690392588, (3668, 2) = -0.2082975869503592e-15, (3669, 1) = 2.2549824537248746, (3669, 2) = .0, (3670, 1) = 2.255922217057161, (3670, 2) = -0.10409421078341916e-15, (3671, 1) = 2.2568619803894476, (3671, 2) = .0, (3672, 1) = 2.257801743721734, (3672, 2) = 0.1040396684320175e-15, (3673, 1) = 2.2587415070540207, (3673, 2) = .0, (3674, 1) = 2.2596812703863067, (3674, 2) = 0.10398516641050138e-15, (3675, 1) = 2.2606210337185932, (3675, 2) = -0.3118737915604342e-15, (3676, 1) = 2.2615607970508798, (3676, 2) = 0.3117921141248335e-15, (3677, 1) = 2.262500560383166, (3677, 2) = 0.10390348897355795e-15, (3678, 1) = 2.2634403237154523, (3678, 2) = 0.20775256662926983e-15, (3679, 1) = 2.264380087047739, (3679, 2) = -0.20769817546030254e-15, (3680, 1) = 2.2653198503800254, (3680, 2) = -0.2076438044374843e-15, (3681, 1) = 2.266259613712312, (3681, 2) = -0.10379472677903534e-15, (3682, 1) = 2.2671993770445984, (3682, 2) = 0.41507024563860525e-15, (3683, 1) = 2.268139140376885, (3683, 2) = 0.4149616244368128e-15, (3684, 1) = 2.2690789037091714, (3684, 2) = .0, (3685, 1) = 2.270018667041458, (3685, 2) = -0.2073722514190623e-15, (3686, 1) = 2.270958430373744, (3686, 2) = 0.10365900060749717e-15, (3687, 1) = 2.2718981937060305, (3687, 2) = 0.2072637711375583e-15, (3688, 1) = 2.272837957038317, (3688, 2) = .0, (3689, 1) = 2.273777720370603, (3689, 2) = .0, (3690, 1) = 2.2747174837028896, (3690, 2) = .0, (3691, 1) = 2.275657247035176, (3691, 2) = .0, (3692, 1) = 2.27658985682789, (3692, 2) = -0.10349666725547921e-15, (3693, 1) = 2.2775224666206033, (3693, 2) = -0.10346981839465073e-15, (3694, 1) = 2.2784550764133167, (3694, 2) = -0.31032893830373936e-15, (3695, 1) = 2.2793876862060305, (3695, 2) = .0, (3696, 1) = 2.2803202959987443, (3696, 2) = -0.10338933121094607e-15, (3697, 1) = 2.2812529057914577, (3697, 2) = 0.10336252194448387e-15, (3698, 1) = 2.282185515584171, (3698, 2) = -0.1033357225729805e-15, (3699, 1) = 2.283118125376885, (3699, 2) = -0.30992679928490777e-15, (3700, 1) = 2.2840507351695987, (3700, 2) = .0, (3701, 1) = 2.284983344962312, (3701, 2) = 0.20651076762704515e-15, (3702, 1) = 2.2859159547550254, (3702, 2) = -0.10322862400711997e-15, (3703, 1) = 2.286848564547739, (3703, 2) = .0, (3704, 1) = 2.2877811743404526, (3704, 2) = -0.103175134055488e-15, (3705, 1) = 2.288713784133166, (3705, 2) = 0.10314840390725129e-15, (3706, 1) = 2.2896463939258798, (3706, 2) = -0.309365050926154e-15, (3707, 1) = 2.290579003718593, (3707, 2) = -0.3092849197751038e-15, (3708, 1) = 2.2915116135113065, (3708, 2) = .0, (3709, 1) = 2.2924442233040203, (3709, 2) = -0.10304158212943616e-15, (3710, 1) = 2.2933768330967337, (3710, 2) = .0, (3711, 1) = 2.294309442889447, (3711, 2) = 0.20597646101632273e-15, (3712, 1) = 2.295242052682161, (3712, 2) = 0.10296156950902445e-15, (3713, 1) = 2.2961746624748742, (3713, 2) = .0, (3714, 1) = 2.2971072722675876, (3714, 2) = 0.2058165542519057e-15, (3715, 1) = 2.2980398820603014, (3715, 2) = .0, (3716, 1) = 2.298972491853015, (3716, 2) = -0.3085650726580291e-15, (3717, 1) = 2.2999051016457286, (3717, 2) = -0.10282841256575913e-15, (3718, 1) = 2.300837711438442, (3718, 2) = .0, (3719, 1) = 2.3017703212311558, (3719, 2) = 0.20555043770014479e-15, (3720, 1) = 2.3027029310238696, (3720, 2) = 0.20549727356953198e-15, (3721, 1) = 2.303635540816583, (3721, 2) = .0, (3722, 1) = 2.3045681506092963, (3722, 2) = -0.20539100446234032e-15, (3723, 1) = 2.30550076040201, (3723, 2) = -0.10266894973963883e-15, (3724, 1) = 2.3064983629899496, (3724, 2) = -0.1026405577359215e-15, (3725, 1) = 2.3074959655778895, (3725, 2) = 0.10261217700626076e-15, (3726, 1) = 2.3084935681658294, (3726, 2) = -0.20516761509728935e-15, (3727, 1) = 2.309491170753769, (3727, 2) = 0.1025554493610532e-15, (3728, 1) = 2.3104887733417083, (3728, 2) = 0.10252710244145795e-15, (3729, 1) = 2.3114863759296482, (3729, 2) = -0.2049975335756448e-15, (3730, 1) = 2.312483978517588, (3730, 2) = 0.10247044239810198e-15, (3731, 1) = 2.3134815811055276, (3731, 2) = 0.40976851708097535e-15, (3732, 1) = 2.314479183693467, (3732, 2) = .0, (3733, 1) = 2.315476786281407, (3733, 2) = 0.10238553679186284e-15, (3734, 1) = 2.316474388869347, (3734, 2) = .0, (3735, 1) = 2.3174719914572863, (3735, 2) = -0.10232898933609544e-15, (3736, 1) = 2.318469594045226, (3736, 2) = 0.20460146497294845e-15, (3737, 1) = 2.3194671966331657, (3737, 2) = -0.10227248688622923e-15, (3738, 1) = 2.3204647992211056, (3738, 2) = -0.10224425253325143e-15, (3739, 1) = 2.321462401809045, (3739, 2) = .0, (3740, 1) = 2.3294432225125625, (3740, 2) = .0, (3741, 1) = 2.33742404321608, (3741, 2) = .0, (3742, 1) = 2.3391847253517586, (3742, 2) = 0.10171652031587755e-15, (3743, 1) = 2.3409454074874367, (3743, 2) = 0.20333417649693696e-15, (3744, 1) = 2.3418257485552756, (3744, 2) = .0, (3745, 1) = 2.342706089623115, (3745, 2) = -0.3048530732042105e-15, (3746, 1) = 2.343586430690954, (3746, 2) = -0.20318601111315456e-15, (3747, 1) = 2.3444667717587935, (3747, 2) = 0.10156832876212071e-15, (3748, 1) = 2.3453471128266328, (3748, 2) = 0.20308732136623806e-15, (3749, 1) = 2.346227453894472, (3749, 2) = .0, (3750, 1) = 2.3471077949623114, (3750, 2) = 0.10149435066513218e-15, (3751, 1) = 2.34798813603015, (3751, 2) = 0.20293941744592371e-15, (3752, 1) = 2.348868477097989, (3752, 2) = -0.20289015097975218e-15, (3753, 1) = 2.3497488181658284, (3753, 2) = -0.20284090192854247e-15, (3754, 1) = 2.3506291592336677, (3754, 2) = -0.10139583514453923e-15, (3755, 1) = 2.351509500301507, (3755, 2) = -0.304113684087203e-15, (3756, 1) = 2.3532701824371856, (3756, 2) = -0.20264407980886825e-15, (3757, 1) = 2.3550308645728637, (3757, 2) = -0.10127288657738387e-15, (3758, 1) = 2.3559112056407026, (3758, 2) = 0.10124832295887504e-15, (3759, 1) = 2.356791546708542, (3759, 2) = 0.202447536069721e-15, (3760, 1) = 2.357671887776381, (3760, 2) = .0, (3761, 1) = 2.3585522288442204, (3761, 2) = -0.40469873705495434e-15, (3762, 1) = 2.3594325699120597, (3762, 2) = -0.1011501554133327e-15, (3763, 1) = 2.360312910979899, (3763, 2) = 0.10112563525082403e-15, (3764, 1) = 2.3611932520477383, (3764, 2) = 0.10110112377455263e-15, (3765, 1) = 2.362073593115577, (3765, 2) = -0.10107662098285432e-15, (3766, 1) = 2.362953934183416, (3766, 2) = -0.30315638062218203e-15, (3767, 1) = 2.3638342752512553, (3767, 2) = 0.20205528289299806e-15, (3768, 1) = 2.3647146163190946, (3768, 2) = 0.10100316469849252e-15, (3769, 1) = 2.365594957386934, (3769, 2) = 0.2019573932567201e-15, (3770, 1) = 2.3666106882286426, (3770, 2) = 0.10095047633495419e-15, (3771, 1) = 2.3676264190703513, (3771, 2) = 0.30276680276704684e-15, (3772, 1) = 2.36864214991206, (3772, 2) = -0.1008940703879416e-15, (3773, 1) = 2.3696578807537683, (3773, 2) = .0, (3774, 1) = 2.3706736115954765, (3774, 2) = 0.30251313182981763e-15, (3775, 1) = 2.371689342437185, (3775, 2) = 0.1008095480277685e-15, (3776, 1) = 2.372705073278894, (3776, 2) = .0, (3777, 1) = 2.3737208041206026, (3777, 2) = .0, (3778, 1) = 2.3747365349623113, (3778, 2) = -0.10072512947697167e-15, (3779, 1) = 2.3757522658040195, (3779, 2) = .0, (3780, 1) = 2.376767996645728, (3780, 2) = -0.10066890807971923e-15, (3781, 1) = 2.3777837274874365, (3781, 2) = 0.10064081466409365e-15, (3782, 1) = 2.379815189170854, (3782, 2) = 0.10058466238546711e-15, (3783, 1) = 2.381846650854271, (3783, 2) = 0.10052855615908826e-15, (3784, 1) = 2.389972497587939, (3784, 2) = 0.10030459134234017e-15, (3785, 1) = 2.3980983443216077, (3785, 2) = 0.10008136161336926e-15, (3786, 1) = 2.3990149630967332, (3786, 2) = .0, (3787, 1) = 2.3999315818718587, (3787, 2) = 0.10003110118962009e-15, (3788, 1) = 2.4008482006469842, (3788, 2) = -0.10000598497576103e-15, (3789, 1) = 2.40176481942211, (3789, 2) = 0.19996175618227785e-15, (3790, 1) = 2.402681438197236, (3790, 2) = -0.999557805336682e-16, (3791, 1) = 2.4035980569723616, (3791, 2) = -0.9993069230125898e-16, (3792, 1) = 2.404514675747487, (3792, 2) = .0, (3793, 1) = 2.4054312945226126, (3793, 2) = -0.9988054380324358e-16, (3794, 1) = 2.4090977696231155, (3794, 2) = .0, (3795, 1) = 2.412764244723618, (3795, 2) = 0.9968032239266605e-16, (3796, 1) = 2.4145974822738694, (3796, 2) = .0, (3797, 1) = 2.4164307198241204, (3797, 2) = -0.9958043499833494e-16, (3798, 1) = 2.417347338599246, (3798, 2) = .0, (3799, 1) = 2.418263957374372, (3799, 2) = -0.9953054706895071e-16, (3800, 1) = 2.4191805761494978, (3800, 2) = .0, (3801, 1) = 2.4200971949246233, (3801, 2) = 0.9948069629506732e-16, (3802, 1) = 2.4210138136997488, (3802, 2) = 0.1989115696720395e-15, (3803, 1) = 2.4219304324748743, (3803, 2) = -0.994308826593367e-16, (3804, 1) = 2.4228470512499998, (3804, 2) = 0.9940598976283939e-16, (3805, 1) = 2.4237636700251257, (3805, 2) = 0.9938110614434492e-16, (3806, 1) = 2.4246802888002517, (3806, 2) = .0, (3807, 1) = 2.425596907575377, (3807, 2) = 0.9933136673261262e-16, (3808, 1) = 2.4265135263505027, (3808, 2) = -0.297919532804966e-15, (3809, 1) = 2.427430145125628, (3809, 2) = 0.19856332881319065e-15, (3810, 1) = 2.428337091491834, (3810, 2) = -0.2977712675590503e-15, (3811, 1) = 2.42924403785804, (3811, 2) = 0.9923252303644986e-16, (3812, 1) = 2.4301509842242464, (3812, 2) = 0.19841593190950544e-15, (3813, 1) = 2.4310579305904523, (3813, 2) = 0.19836683587822604e-15, (3814, 1) = 2.431964876956658, (3814, 2) = 0.19831775797476247e-15, (3815, 1) = 2.4328718233228646, (3815, 2) = -0.19826869819480808e-15, (3816, 1) = 2.4337787696890705, (3816, 2) = 0.9910982826702439e-16, (3817, 1) = 2.4346857160552764, (3817, 2) = .0, (3818, 1) = 2.4355926624214823, (3818, 2) = -0.2971824413292307e-15, (3819, 1) = 2.4364996087876882, (3819, 2) = .0, (3820, 1) = 2.4374065551538946, (3820, 2) = 0.19802367099641323e-15, (3821, 1) = 2.4383135015201005, (3821, 2) = 0.19797471986665202e-15, (3822, 1) = 2.4392204478863064, (3822, 2) = 0.19792578683004258e-15, (3823, 1) = 2.440127394252513, (3823, 2) = -0.19787687188221832e-15, (3824, 1) = 2.4410343406187187, (3824, 2) = 0.2967419625282077e-15, (3825, 1) = 2.4419412869849246, (3825, 2) = .0, (3826, 1) = 2.4428482333511305, (3826, 2) = -0.9886511776383947e-16, (3827, 1) = 2.4437551797173365, (3827, 2) = -0.19768139289118102e-15, (3828, 1) = 2.444662126083543, (3828, 2) = 0.2964488524822867e-15, (3829, 1) = 2.4455690724497487, (3829, 2) = 0.9879188090714926e-16, (3830, 1) = 2.4464760188159547, (3830, 2) = -0.987674866825426e-16, (3831, 1) = 2.447382965182161, (3831, 2) = -0.9874310148472964e-16, (3832, 1) = 2.448289911548367, (3832, 2) = -0.19743745062298838e-15, (3833, 1) = 2.449196857914573, (3833, 2) = 0.9869435816061642e-16, (3834, 1) = 2.450103804280779, (3834, 2) = .0, (3835, 1) = 2.4510107506469847, (3835, 2) = -0.2959369527511101e-15, (3836, 1) = 2.451917697013191, (3836, 2) = 0.9862131081987721e-16, (3837, 1) = 2.452824643379397, (3837, 2) = .0, (3838, 1) = 2.453731589745603, (3838, 2) = 0.9857265766364859e-16, (3839, 1) = 2.4546385361118093, (3839, 2) = .0, (3840, 1) = 2.455545482478015, (3840, 2) = 0.1970480810865436e-15, (3841, 1) = 2.456452428844221, (3841, 2) = 0.9849974549091394e-16, (3842, 1) = 2.457427687547111, (3842, 2) = -0.9847363054955124e-16, (3843, 1) = 2.45840294625, (3843, 2) = 0.9844752601479256e-16, (3844, 1) = 2.4593782049528894, (3844, 2) = .0, (3845, 1) = 2.460353463655779, (3845, 2) = 0.29518604446154045e-15, (3846, 1) = 2.4613287223586684, (3846, 2) = -0.9836927482202804e-16, (3847, 1) = 2.4623039810615577, (3847, 2) = .0, (3848, 1) = 2.4632792397644474, (3848, 2) = -0.9831715934158476e-16, (3849, 1) = 2.4642544984673367, (3849, 2) = -0.9829111718730103e-16, (3850, 1) = 2.465229757170226, (3850, 2) = -0.9826508541986209e-16, (3851, 1) = 2.4662050158731157, (3851, 2) = -0.19647812807285386e-15, (3852, 1) = 2.467180274576005, (3852, 2) = -0.19642610606830005e-15, (3853, 1) = 2.4681555332788943, (3853, 2) = -0.9818705241018132e-16, (3854, 1) = 2.469130791981784, (3854, 2) = 0.29448318648499897e-15, (3855, 1) = 2.4701060506846733, (3855, 2) = 0.9813508228574598e-16, (3856, 1) = 2.4710813093875625, (3856, 2) = 0.19621822555911376e-15, (3857, 1) = 2.4720565680904523, (3857, 2) = 0.9808315364023108e-16, (3858, 1) = 2.4759576029020103, (3858, 2) = 0.9797942069404823e-16, (3859, 1) = 2.479858637713568, (3859, 2) = 0.9787585338710099e-16, (3860, 1) = 2.480833896416457, (3860, 2) = -0.19569997483952726e-15, (3861, 1) = 2.481809155119347, (3861, 2) = -0.2934723953711084e-15, (3862, 1) = 2.482784413822236, (3862, 2) = 0.19559657299200553e-15, (3863, 1) = 2.4837596725251254, (3863, 2) = -0.9777245153374347e-16, (3864, 1) = 2.484734931228015, (3864, 2) = -0.9774662690066726e-16, (3865, 1) = 2.4857101899309044, (3865, 2) = -0.19544162518769134e-15, (3866, 1) = 2.4866854486337937, (3866, 2) = -0.19539001722069187e-15, (3867, 1) = 2.4876607073366834, (3867, 2) = 0.19533842989446222e-15, (3868, 1) = 2.4886399111620605, (3868, 2) = 0.1952866546471211e-15, (3869, 1) = 2.489619114987437, (3869, 2) = -0.9761745009799379e-16, (3870, 1) = 2.490598318812814, (3870, 2) = .0, (3871, 1) = 2.491577522638191, (3871, 2) = -0.19513145365845167e-15, (3872, 1) = 2.492556726463568, (3872, 2) = -0.19507976156008236e-15, (3873, 1) = 2.4935359302889446, (3873, 2) = 0.975140451169935e-16, (3874, 1) = 2.4945151341143212, (3874, 2) = 0.9748821983708058e-16, (3875, 1) = 2.4954943379396983, (3875, 2) = 0.19492480987459226e-15, (3876, 1) = 2.4994111532412058, (3876, 2) = 0.973592490791722e-16, (3877, 1) = 2.5033279685427137, (3877, 2) = .0, (3878, 1) = 2.5043071723680903, (3878, 2) = .0, (3879, 1) = 2.5052863761934674, (3879, 2) = 0.19440965236437975e-15, (3880, 1) = 2.5062655800188445, (3880, 2) = 0.1943582505284591e-15, (3881, 1) = 2.5072447838442216, (3881, 2) = .0, (3882, 1) = 2.5082239876695986, (3882, 2) = .0, (3883, 1) = 2.5092031914949753, (3883, 2) = -0.29130625368154495e-15, (3884, 1) = 2.510182395320352, (3884, 2) = -0.9707642499912273e-16, (3885, 1) = 2.511161599145729, (3885, 2) = 0.19410155153841098e-15, (3886, 1) = 2.5150784144472365, (3886, 2) = 0.9694828210273637e-16, (3887, 1) = 2.518995229748744, (3887, 2) = .0, (3888, 1) = 2.5198861602418345, (3888, 2) = 0.19364540108802925e-15, (3889, 1) = 2.5207770907349247, (3889, 2) = -0.1935989122443477e-15, (3890, 1) = 2.521668021228015, (3890, 2) = -0.9677622022533561e-16, (3891, 1) = 2.5225589517211056, (3891, 2) = 0.19350598570230612e-15, (3892, 1) = 2.523449882214196, (3892, 2) = .0, (3893, 1) = 2.5243408127072864, (3893, 2) = 0.1934131273227103e-15, (3894, 1) = 2.5252317432003766, (3894, 2) = 0.9668336184103341e-16, (3895, 1) = 2.526122673693467, (3895, 2) = 0.9666016853395471e-16, (3896, 1) = 2.527013604186558, (3896, 2) = .0, (3897, 1) = 2.527904534679648, (3897, 2) = 0.9661380745008579e-16, (3898, 1) = 2.5287954651727382, (3898, 2) = 0.9659063966856902e-16, (3899, 1) = 2.529686395665829, (3899, 2) = 0.19313496078168438e-15, (3900, 1) = 2.5305773261589195, (3900, 2) = -0.1930886592290715e-15, (3901, 1) = 2.53146825665201, (3901, 2) = 0.965211873372777e-16, (3902, 1) = 2.5323591871451008, (3902, 2) = 0.28949416067008077e-15, (3903, 1) = 2.533250117638191, (3903, 2) = 0.9647492827040646e-16, (3904, 1) = 2.534141048131281, (3904, 2) = 0.964518114760369e-16, (3905, 1) = 2.535031978624372, (3905, 2) = -0.9642870317120306e-16, (3906, 1) = 2.5359229091174624, (3906, 2) = 0.9640560335352068e-16, (3907, 1) = 2.536813839610553, (3907, 2) = -0.9638251202060302e-16, (3908, 1) = 2.5377047701036437, (3908, 2) = 0.19271885834012191e-15, (3909, 1) = 2.538595700596734, (3909, 2) = 0.19267270959900582e-15, (3910, 1) = 2.539486631089824, (3910, 2) = .0, (3911, 1) = 2.5403775615829147, (3911, 2) = .0, (3912, 1) = 2.5412684920760054, (3912, 2) = -0.3850687301751256e-15, (3913, 1) = 2.5421594225690956, (3913, 2) = -0.9624414206919594e-16, (3914, 1) = 2.5430503530621857, (3914, 2) = .0, (3915, 1) = 2.5439412835552764, (3915, 2) = .0, (3916, 1) = 2.544832214048367, (3916, 2) = -0.1923501428875116e-15, (3917, 1) = 2.545723144541457, (3917, 2) = 0.28845619448006134e-15, (3918, 1) = 2.5466140750345474, (3918, 2) = -0.28838720000391364e-15, (3919, 1) = 2.547505005527638, (3919, 2) = -0.19221215393038565e-15, (3920, 1) = 2.5484511341363065, (3920, 2) = -0.28824501653203494e-15, (3921, 1) = 2.549397262744975, (3921, 2) = -0.19211455384010633e-15, (3922, 1) = 2.5503433913536435, (3922, 2) = -0.9603289119041629e-16, (3923, 1) = 2.5512895199623116, (3923, 2) = .0, (3924, 1) = 2.5522356485709796, (3924, 2) = -0.19196829660497664e-15, (3925, 1) = 2.553181777179648, (3925, 2) = -0.19191958227676084e-15, (3926, 1) = 2.5541279057883166, (3926, 2) = 0.19187088698058789e-15, (3927, 1) = 2.555074034396985, (3927, 2) = -0.9591110535531323e-16, (3928, 1) = 2.5560201630056536, (3928, 2) = .0, (3929, 1) = 2.5569662916143217, (3929, 2) = 0.9586245761299246e-16, (3930, 1) = 2.5579124202229897, (3930, 2) = 0.9583814799980692e-16, (3931, 1) = 2.558858548831658, (3931, 2) = 0.19162769577607235e-15, (3932, 1) = 2.5598046774403267, (3932, 2) = -0.2873686718242513e-15, (3933, 1) = 2.560750806048995, (3933, 2) = -0.1915305523140341e-15, (3934, 1) = 2.5616969346576637, (3934, 2) = -0.9574100453190057e-16, (3935, 1) = 2.5626430632663317, (3935, 2) = 0.9571674239646282e-16, (3936, 1) = 2.563589191875, (3936, 2) = -0.9569248974776271e-16, (3937, 1) = 2.5645353204836683, (3937, 2) = -0.19133649316571305e-15, (3938, 1) = 2.5654814490923368, (3938, 2) = -0.9564401289879768e-16, (3939, 1) = 2.5664275777010053, (3939, 2) = .0, (3940, 1) = 2.5673737063096738, (3940, 2) = .0, (3941, 1) = 2.568319834918342, (3941, 2) = -0.9557136870219882e-16, (3942, 1) = 2.56926596352701, (3942, 2) = -0.1910943458240185e-15, (3943, 1) = 2.5702120921356784, (3943, 2) = 0.9552298658789338e-16, (3944, 1) = 2.571158220744347, (3944, 2) = -0.19099761945377664e-15, (3945, 1) = 2.5721043493530154, (3945, 2) = 0.9547464232602853e-16, (3946, 1) = 2.573050477961684, (3946, 2) = .0, (3947, 1) = 2.573996606570352, (3947, 2) = -0.1908526717857384e-15, (3948, 1) = 2.5758888637876884, (3948, 2) = -0.9537806726463776e-16, (3949, 1) = 2.5777811210050254, (3949, 2) = .0, (3950, 1) = 2.578704450056533, (3950, 2) = -0.3812252633172485e-15, (3951, 1) = 2.5796277791080406, (3951, 2) = .0, (3952, 1) = 2.580551108159548, (3952, 2) = -0.19051860322277324e-15, (3953, 1) = 2.5814744372110554, (3953, 2) = -0.1904716159522089e-15, (3954, 1) = 2.582397766262563, (3954, 2) = -0.19042464663913256e-15, (3955, 1) = 2.58332109531407, (3955, 2) = .0, (3956, 1) = 2.5842444243655778, (3956, 2) = -0.1903307618631577e-15, (3957, 1) = 2.5851677534170854, (3957, 2) = .0, (3958, 1) = 2.5870144115201006, (3958, 2) = .0, (3959, 1) = 2.588861069623116, (3959, 2) = .0, (3960, 1) = 2.5897843986746234, (3960, 2) = 0.38009907586934954e-15, (3961, 1) = 2.590707727726131, (3961, 2) = -0.19000272998777094e-15, (3962, 1) = 2.591631056777638, (3962, 2) = -0.1899559399424451e-15, (3963, 1) = 2.5925543858291458, (3963, 2) = 0.18990916779308137e-15, (3964, 1) = 2.599941018241206, (3964, 2) = 0.1895356341774449e-15, (3965, 1) = 2.607327650653266, (3965, 2) = 0.18916324265453786e-15, (3966, 1) = 2.608328549086055, (3966, 2) = .0, (3967, 1) = 2.609329447518844, (3967, 2) = -0.18906251988541435e-15, (3968, 1) = 2.610330345951633, (3968, 2) = .0, (3969, 1) = 2.611331244384422, (3969, 2) = .0, (3970, 1) = 2.612332142817211, (3970, 2) = -0.18891159247623002e-15, (3971, 1) = 2.6133330412499998, (3971, 2) = .0, (3972, 1) = 2.6143339396827887, (3972, 2) = .0, (3973, 1) = 2.6153348381155777, (3973, 2) = 0.18876085298595087e-15, (3974, 1) = 2.6163357365483666, (3974, 2) = .0, (3975, 1) = 2.6173366349811555, (3975, 2) = .0, (3976, 1) = 2.6183375334139445, (3976, 2) = 0.18861030121785352e-15, (3977, 1) = 2.6193384318467334, (3977, 2) = 0.18856015897712856e-15, (3978, 1) = 2.6203393302795224, (3978, 2) = 0.18851003756520593e-15, (3979, 1) = 2.6213402287123113, (3979, 2) = .0, (3980, 1) = 2.6223411271451003, (3980, 2) = .0, (3981, 1) = 2.623342025577889, (3981, 2) = .0, (3982, 1) = 2.627345619309045, (3982, 2) = .0, (3983, 1) = 2.6313492130402008, (3983, 2) = .0, (3984, 1) = 2.6323501114729897, (3984, 2) = 0.18791020259923022e-15, (3985, 1) = 2.6333510099057786, (3985, 2) = .0, (3986, 1) = 2.6343519083385676, (3986, 2) = .0, (3987, 1) = 2.6353528067713565, (3987, 2) = 0.18776071085299943e-15, (3988, 1) = 2.6363537052041455, (3988, 2) = 0.37542184340582138e-15, (3989, 1) = 2.6373546036369344, (3989, 2) = -0.18766115325648267e-15, (3990, 1) = 2.6383555020697234, (3990, 2) = .0, (3991, 1) = 2.6393564005025123, (3991, 2) = -0.18756167844497367e-15, (3992, 1) = 2.6402224559265073, (3992, 2) = -0.3750373348026512e-15, (3993, 1) = 2.6410885113505023, (3993, 2) = -0.37495134367435264e-15, (3994, 1) = 2.6419545667744972, (3994, 2) = .0, (3995, 1) = 2.6428206221984922, (3995, 2) = .0, (3996, 1) = 2.643686677622487, (3996, 2) = .0, (3997, 1) = 2.644552733046482, (3997, 2) = .0, (3998, 1) = 2.645418788470477, (3998, 2) = 0.18726092604042684e-15, (3999, 1) = 2.646284843894472, (3999, 2) = 0.1872180232521413e-15, (4000, 1) = 2.647150899318467, (4000, 2) = .0, (4001, 1) = 2.648016954742462, (4001, 2) = .0, (4002, 1) = 2.648883010166457, (4002, 2) = -0.3741788150850886e-15, (4003, 1) = 2.649749065590452, (4003, 2) = .0, (4004, 1) = 2.650615121014447, (4004, 2) = 0.18700374090052853e-15, (4005, 1) = 2.651481176438442, (4005, 2) = .0, (4006, 1) = 2.6523472318624366, (4006, 2) = .0, (4007, 1) = 2.6532132872864316, (4007, 2) = 0.18687535658729083e-15, (4008, 1) = 2.6540793427104266, (4008, 2) = 0.1868325926367734e-15, (4009, 1) = 2.654945398134421, (4009, 2) = 0.18678984408845392e-15, (4010, 1) = 2.655811453558416, (4010, 2) = .0, (4011, 1) = 2.656677508982411, (4011, 2) = -0.18670439317899112e-15, (4012, 1) = 2.657543564406406, (4012, 2) = 0.18666169080813283e-15, (4013, 1) = 2.658409619830401, (4013, 2) = -0.18661900382004222e-15, (4014, 1) = 2.659275675254396, (4014, 2) = .0, (4015, 1) = 2.660141730678391, (4015, 2) = .0, (4016, 1) = 2.661007786102386, (4016, 2) = -0.18649103510372526e-15, (4017, 1) = 2.661873841526381, (4017, 2) = 0.37289681919608293e-15, (4018, 1) = 2.662739896950376, (4018, 2) = -0.3728115989015615e-15, (4019, 1) = 2.663605952374371, (4019, 2) = 0.37272640931413366e-15, (4020, 1) = 2.664472007798366, (4020, 2) = -0.1863206252120207e-15, (4021, 1) = 2.665338063222361, (4021, 2) = 0.18627806111076112e-15, (4022, 1) = 2.666204118646356, (4022, 2) = -0.18623551234840422e-15, (4023, 1) = 2.667070174070351, (4023, 2) = 0.1861929789200639e-15, (4024, 1) = 2.682985312311557, (4024, 2) = 0.18541408400828309e-15, (4025, 1) = 2.698900450552763, (4025, 2) = 0.1846403352237645e-15, (4026, 1) = 2.7138615171859293, (4026, 2) = 0.18391763585807612e-15, (4027, 1) = 2.7288225838190954, (4027, 2) = 0.18319943124837754e-15, (4028, 1) = 2.732526723580402, (4028, 2) = 0.1830223055514468e-15, (4029, 1) = 2.7362308633417083, (4029, 2) = 0.18284545339606363e-15, (4030, 1) = 2.737156898282035, (4030, 2) = .0, (4031, 1) = 2.7380829332223615, (4031, 2) = 0.18275712977308415e-15, (4032, 1) = 2.739008968162688, (4032, 2) = -0.18271299355366235e-15, (4033, 1) = 2.7399350031030147, (4033, 2) = .0, (4034, 1) = 2.7408610380433416, (4034, 2) = 0.18262477226805964e-15, (4035, 1) = 2.7417870729836684, (4035, 2) = .0, (4036, 1) = 2.7427131079239953, (4036, 2) = .0, (4037, 1) = 2.7436391428643216, (4037, 2) = -0.18249256813000958e-15, (4038, 1) = 2.744565177804648, (4038, 2) = -0.18244853413667359e-15, (4039, 1) = 2.745491212744975, (4039, 2) = .0, (4040, 1) = 2.7464172476853017, (4040, 2) = 0.36472103438375473e-15, (4041, 1) = 2.7473432826256285, (4041, 2) = -0.3646330684560569e-15, (4042, 1) = 2.7482693175659554, (4042, 2) = 0.36454513652323313e-15, (4043, 1) = 2.7491953525062818, (4043, 2) = 0.18222861928644236e-15, (4044, 1) = 2.750121387446608, (4044, 2) = 0.18218468729630458e-15, (4045, 1) = 2.751047422386935, (4045, 2) = 0.182140772285e-15, (4046, 1) = 2.751973457327262, (4046, 2) = .0, (4047, 1) = 2.7528994922675882, (4047, 2) = 0.36410598634813562e-15, (4048, 1) = 2.7538255272079146, (4048, 2) = 0.18200912906202415e-15, (4049, 1) = 2.7547515621482415, (4049, 2) = -0.18196528190398155e-15, (4050, 1) = 2.7556775970885683, (4050, 2) = .0, (4051, 1) = 2.7566036320288947, (4051, 2) = -0.18187763842504664e-15, (4052, 1) = 2.757529666969221, (4052, 2) = .0, (4053, 1) = 2.758455701909548, (4053, 2) = 0.3635801253750768e-15, (4054, 1) = 2.7593824735175883, (4054, 2) = 0.18174626539962624e-15, (4055, 1) = 2.7603092451256286, (4055, 2) = 0.18170248505533114e-15, (4056, 1) = 2.761236016733669, (4056, 2) = .0, (4057, 1) = 2.762162788341709, (4057, 2) = .0, (4058, 1) = 2.7630895599497487, (4058, 2) = 0.18157124562175187e-15, (4059, 1) = 2.764016331557789, (4059, 2) = 0.36305506597903947e-15, (4060, 1) = 2.7649431031658294, (4060, 2) = .0, (4061, 1) = 2.7658698747738697, (4061, 2) = .0, (4062, 1) = 2.76679664638191, (4062, 2) = -0.36279299308452855e-15, (4063, 1) = 2.76772341798995, (4063, 2) = -0.18135285152216156e-15, (4064, 1) = 2.76865018959799, (4064, 2) = -0.18130922338946347e-15, (4065, 1) = 2.76957696120603, (4065, 2) = -0.1812656121379154e-15, (4066, 1) = 2.7705037328140705, (4066, 2) = .0, (4067, 1) = 2.771430504422111, (4067, 2) = -0.1811784402532427e-15, (4068, 1) = 2.772357276030151, (4068, 2) = .0, (4069, 1) = 2.773284047638191, (4069, 2) = 0.18109133581807344e-15, (4070, 1) = 2.774210819246231, (4070, 2) = -0.18104780887839833e-15, (4071, 1) = 2.7751375908542713, (4071, 2) = -0.1810042987823107e-15, (4072, 1) = 2.7760643624623116, (4072, 2) = 0.18096080552354437e-15, (4073, 1) = 2.776991134070352, (4073, 2) = -0.18091732909583142e-15, (4074, 1) = 2.7779179056783923, (4074, 2) = 0.1808738694929026e-15, (4075, 1) = 2.778844677286432, (4075, 2) = -0.18083042670848674e-15, (4076, 1) = 2.779771448894472, (4076, 2) = -0.18078700073631125e-15, (4077, 1) = 2.7806982205025124, (4077, 2) = .0, (4078, 1) = 2.7816249921105527, (4078, 2) = .0, (4079, 1) = 2.782551763718593, (4079, 2) = .0, (4080, 1) = 2.7834785353266334, (4080, 2) = .0, (4081, 1) = 2.7844053069346733, (4081, 2) = -0.18057012283938876e-15, (4082, 1) = 2.785332078542713, (4082, 2) = .0, (4083, 1) = 2.7862588501507535, (4083, 2) = .0, (4084, 1) = 2.787185621758794, (4084, 2) = 0.3608803948926682e-15, (4085, 1) = 2.788112393366834, (4085, 2) = .0, (4086, 1) = 2.7890576417430903, (4086, 2) = -0.180352802051252e-15, (4087, 1) = 2.7900028901193465, (4087, 2) = .0, (4088, 1) = 2.7909481384956027, (4088, 2) = -0.1802646133952961e-15, (4089, 1) = 2.791893386871859, (4089, 2) = -0.3604410903530725e-15, (4090, 1) = 2.792838635248115, (4090, 2) = -0.36035298871003757e-15, (4091, 1) = 2.7937838836243714, (4091, 2) = -0.18013246092406445e-15, (4092, 1) = 2.7947291320006276, (4092, 2) = .0, (4093, 1) = 2.795674380376884, (4093, 2) = 0.18004444620712068e-15, (4094, 1) = 2.796619628753141, (4094, 2) = .0, (4095, 1) = 2.797564877129397, (4095, 2) = .0, (4096, 1) = 2.7985101255056533, (4096, 2) = .0, (4097, 1) = 2.7994553738819095, (4097, 2) = -0.17986862516593803e-15, (4098, 1) = 2.8004006222581657, (4098, 2) = .0, (4099, 1) = 2.801345870634422, (4099, 2) = .0, (4100, 1) = 2.802291119010678, (4100, 2) = .0, (4101, 1) = 2.8032363673869343, (4101, 2) = .0, (4102, 1) = 2.8051268641394467, (4102, 2) = .0, (4103, 1) = 2.807017360891959, (4103, 2) = .0, (4104, 1) = 2.8079626092682153, (4104, 2) = .0, (4105, 1) = 2.8089078576444715, (4105, 2) = .0, (4106, 1) = 2.8098531060207277, (4106, 2) = .0, (4107, 1) = 2.8107983543969843, (4107, 2) = 0.17934282533002958e-15, (4108, 1) = 2.811743602773241, (4108, 2) = 0.35859824209755124e-15, (4109, 1) = 2.812688851149497, (4109, 2) = 0.17925543402419754e-15, (4110, 1) = 2.8136340995257534, (4110, 2) = .0, (4111, 1) = 2.8145793479020096, (4111, 2) = -0.3583362234364664e-15, (4112, 1) = 2.815524596278266, (4112, 2) = 0.35824895284685213e-15, (4113, 1) = 2.816469844654522, (4113, 2) = 0.3581617167169055e-15, (4114, 1) = 2.817415093030778, (4114, 2) = -0.17903725751659975e-15, (4115, 1) = 2.8183603414070344, (4115, 2) = 0.1789936738911522e-15, (4116, 1) = 2.8193622888505017, (4116, 2) = -0.1789474947672592e-15, (4117, 1) = 2.820364236293969, (4117, 2) = 0.17890133497156205e-15, (4118, 1) = 2.821366183737436, (4118, 2) = 0.35771038899211835e-15, (4119, 1) = 2.822368131180904, (4119, 2) = .0, (4120, 1) = 2.824372026067839, (4120, 2) = .0, (4121, 1) = 2.8263759209547734, (4121, 2) = .0, (4122, 1) = 2.8273778683982407, (4122, 2) = -0.17857875691885318e-15, (4123, 1) = 2.828379815841708, (4123, 2) = .0, (4124, 1) = 2.829381763285175, (4124, 2) = .0, (4125, 1) = 2.8303837107286425, (4125, 2) = -0.1784407983043064e-15, (4126, 1) = 2.8313856581721097, (4126, 2) = -0.17839485059034481e-15, (4127, 1) = 2.832387605615577, (4127, 2) = 0.17834892210846632e-15, (4128, 1) = 2.8333895530590443, (4128, 2) = .0, (4129, 1) = 2.834391500502512, (4129, 2) = 0.1782571228088839e-15, (4130, 1) = 2.8353934479459797, (4130, 2) = 0.17821125197513945e-15, (4131, 1) = 2.836395395389447, (4131, 2) = .0, (4132, 1) = 2.8373973428329142, (4132, 2) = .0, (4133, 1) = 2.8383992902763815, (4133, 2) = .0, (4134, 1) = 2.8394012377198488, (4134, 2) = .0, (4135, 1) = 2.840403185163316, (4135, 2) = 0.17798218564595916e-15, (4136, 1) = 2.8414051326067833, (4136, 2) = .0, (4137, 1) = 2.8424070800502506, (4137, 2) = .0, (4138, 1) = 2.84641486982412, (4138, 2) = .0, (4139, 1) = 2.8504226595979896, (4139, 2) = .0, (4140, 1) = 2.857772161130653, (4140, 2) = .0, (4141, 1) = 2.8651216626633165, (4141, 2) = .0, (4142, 1) = 2.8660403503548997, (4142, 2) = 0.17681742239209285e-15, (4143, 1) = 2.8669590380464824, (4143, 2) = .0, (4144, 1) = 2.867877725738065, (4144, 2) = .0, (4145, 1) = 2.8687964134296484, (4145, 2) = -0.17669294838105775e-15, (4146, 1) = 2.869715101121231, (4146, 2) = .0, (4147, 1) = 2.870633788812814, (4147, 2) = .0, (4148, 1) = 2.871552476504397, (4148, 2) = -0.17656861761623587e-15, (4149, 1) = 2.87247116419598, (4149, 2) = -0.17652720583146772e-15, (4150, 1) = 2.8733898518875627, (4150, 2) = -0.352971619876197e-15, (4151, 1) = 2.874308539579146, (4151, 2) = -0.17644442992991494e-15, (4152, 1) = 2.8752272272707287, (4152, 2) = .0, (4153, 1) = 2.8761459149623114, (4153, 2) = -0.35272343508849966e-15, (4154, 1) = 2.8770646026538946, (4154, 2) = .0, (4155, 1) = 2.8779832903454774, (4155, 2) = 0.17627906862475654e-15, (4156, 1) = 2.87890197803706, (4156, 2) = .0, (4157, 1) = 2.8798206657286434, (4157, 2) = 0.1761964831217115e-15, (4158, 1) = 2.8807275284453517, (4158, 2) = -0.35231149046565515e-15, (4159, 1) = 2.8816343911620605, (4159, 2) = 0.1761150227744522e-15, (4160, 1) = 2.8825412538787694, (4160, 2) = .0, (4161, 1) = 2.8834481165954777, (4161, 2) = -0.17603362412530448e-15, (4162, 1) = 2.884354979312186, (4162, 2) = .0, (4163, 1) = 2.8852618420288945, (4163, 2) = .0, (4164, 1) = 2.886168704745603, (4164, 2) = .0, (4165, 1) = 2.8870755674623116, (4165, 2) = .0, (4166, 1) = 2.8879824301790205, (4166, 2) = 0.17583039711764693e-15, (4167, 1) = 2.888889292895729, (4167, 2) = .0, (4168, 1) = 2.889796155612437, (4168, 2) = 0.17574921403503496e-15, (4169, 1) = 2.8907030183291456, (4169, 2) = 0.17570864555274877e-15, (4170, 1) = 2.891609881045854, (4170, 2) = 0.17566809243516342e-15, (4171, 1) = 2.8925167437625627, (4171, 2) = .0, (4172, 1) = 2.8934236064792715, (4172, 2) = .0, (4173, 1) = 2.89433046919598, (4173, 2) = .0, (4174, 1) = 2.8952373319126883, (4174, 2) = .0, (4175, 1) = 2.896144194629397, (4175, 2) = -0.1754655571082707e-15, (4176, 1) = 2.897051057346106, (4176, 2) = .0, (4177, 1) = 2.8979579200628143, (4177, 2) = 0.1753846503209281e-15, (4178, 1) = 2.8988647827795226, (4178, 2) = .0, (4179, 1) = 2.899771645496231, (4179, 2) = .0, (4180, 1) = 2.9006785082129394, (4180, 2) = 0.17526340500104947e-15, (4181, 1) = 2.901585370929648, (4181, 2) = 0.1752230205001096e-15, (4182, 1) = 2.902492233646357, (4182, 2) = .0, (4183, 1) = 2.9033990963630654, (4183, 2) = .0, (4184, 1) = 2.9043059590797737, (4184, 2) = -0.17510195873051703e-15, (4185, 1) = 2.905212821796482, (4185, 2) = -0.1750616353651001e-15, (4186, 1) = 2.9061196845131905, (4186, 2) = .0, (4187, 1) = 2.9070265472298993, (4187, 2) = -0.17498103443500342e-15, (4188, 1) = 2.907933409946608, (4188, 2) = 0.17494075685834503e-15, (4189, 1) = 2.9088402726633165, (4189, 2) = 0.1749004945326272e-15, (4190, 1) = 2.909809693982412, (4190, 2) = -0.17485747162761633e-15, (4191, 1) = 2.9107791153015077, (4191, 2) = .0, (4192, 1) = 2.9117485366206033, (4192, 2) = .0, (4193, 1) = 2.9127179579396985, (4193, 2) = 0.17472850736420283e-15, (4194, 1) = 2.9136873792587936, (4194, 2) = .0, (4195, 1) = 2.9146568005778892, (4195, 2) = .0, (4196, 1) = 2.915626221896985, (4196, 2) = 0.17459969962454513e-15, (4197, 1) = 2.9165956432160804, (4197, 2) = -0.17455679846023123e-15, (4198, 1) = 2.917565064535176, (4198, 2) = -0.1745139146581724e-15, (4199, 1) = 2.918534485854271, (4199, 2) = 0.17447104821104975e-15, (4200, 1) = 2.9195039071733664, (4200, 2) = -0.1744281991115443e-15, (4201, 1) = 2.920473328492462, (4201, 2) = 0.1743853673523369e-15, (4202, 1) = 2.9214427498115576, (4202, 2) = .0, (4203, 1) = 2.922412171130653, (4203, 2) = .0, (4204, 1) = 2.923381592449749, (4204, 2) = .0, (4205, 1) = 2.924351013768844, (4205, 2) = .0, (4206, 1) = 2.9262898564070348, (4206, 2) = .0, (4207, 1) = 2.928228699045226, (4207, 2) = .0, (4208, 1) = 2.9291981203643216, (4208, 2) = .0, (4209, 1) = 2.9301675416834168, (4209, 2) = .0, (4210, 1) = 2.931136963002512, (4210, 2) = .0, (4211, 1) = 2.9321063843216075, (4211, 2) = -0.17387273612075552e-15, (4212, 1) = 2.933075805640703, (4212, 2) = .0, (4213, 1) = 2.9340452269597987, (4213, 2) = 0.17378753935571828e-15, (4214, 1) = 2.9350146482788944, (4214, 2) = .0, (4215, 1) = 2.9359840695979895, (4215, 2) = -0.17370241151267663e-15, (4216, 1) = 2.9369534909170847, (4216, 2) = -0.17365987341860345e-15, (4217, 1) = 2.9379229122361803, (4217, 2) = .0, (4218, 1) = 2.938892333555276, (4218, 2) = 0.17357484884875093e-15, (4219, 1) = 2.9398617548743715, (4219, 2) = 0.1735323623583312e-15, (4220, 1) = 2.9408290658479896, (4220, 2) = .0, (4221, 1) = 2.9417963768216078, (4221, 2) = .0, (4222, 1) = 2.942763687795226, (4222, 2) = 0.1734052830531144e-15, (4223, 1) = 2.943730998768844, (4223, 2) = .0, (4224, 1) = 2.944698309742462, (4224, 2) = .0, (4225, 1) = 2.9456656207160803, (4225, 2) = 0.17327835755802982e-15, (4226, 1) = 2.946632931689698, (4226, 2) = .0, (4227, 1) = 2.947600242663316, (4227, 2) = -0.17319382591441912e-15, (4228, 1) = 2.9485675536369342, (4228, 2) = -0.1731515856767319e-15, (4229, 1) = 2.949534864610552, (4229, 2) = 0.173109362485428e-15, (4230, 1) = 2.95050217558417, (4230, 2) = -0.17306715633323588e-15, (4231, 1) = 2.951469486557788, (4231, 2) = .0, (4232, 1) = 2.9524367975314063, (4232, 2) = 0.17298279511710196e-15, (4233, 1) = 2.9534041085050244, (4233, 2) = .0, (4234, 1) = 2.9543714194786426, (4234, 2) = 0.1728985019701616e-15, (4235, 1) = 2.9553387304522607, (4235, 2) = -0.17285638090446213e-15, (4236, 1) = 2.956306041425879, (4236, 2) = -0.1728142768342491e-15, (4237, 1) = 2.957273352399497, (4237, 2) = .0, (4238, 1) = 2.958240663373115, (4238, 2) = -0.17273011965120173e-15, (4239, 1) = 2.959207974346733, (4239, 2) = -0.17268806652382753e-15, (4240, 1) = 2.9601752853203513, (4240, 2) = 0.17264603036286022e-15, (4241, 1) = 2.9611425962939695, (4241, 2) = .0, (4242, 1) = 2.962109907267587, (4242, 2) = .0, (4243, 1) = 2.9630772182412053, (4243, 2) = .0, (4244, 1) = 2.965011840188441, (4244, 2) = .0, (4245, 1) = 2.9669464621356774, (4245, 2) = .0, (4246, 1) = 2.9679137731092955, (4246, 2) = .0, (4247, 1) = 2.9688810840829136, (4247, 2) = .0, (4248, 1) = 2.9698483950565318, (4248, 2) = 0.17222660030643525e-15, (4249, 1) = 2.97081570603015, (4249, 2) = -0.17218475029622467e-15, (4250, 1) = 2.9717277152167076, (4250, 2) = .0, (4251, 1) = 2.9726397244032654, (4251, 2) = .0, (4252, 1) = 2.973551733589823, (4252, 2) = .0, (4253, 1) = 2.974463742776381, (4253, 2) = .0, (4254, 1) = 2.9753757519629387, (4254, 2) = .0, (4255, 1) = 2.9762877611494964, (4255, 2) = .0, (4256, 1) = 2.977199770336054, (4256, 2) = 0.17190897133445217e-15, (4257, 1) = 2.9781117795226124, (4257, 2) = 0.17186963423562996e-15, (4258, 1) = 2.981759816268844, (4258, 2) = 0.17171243533612443e-15, (4259, 1) = 2.985407853015075, (4259, 2) = 0.1715554753377235e-15, (4260, 1) = 2.9863198622016327, (4260, 2) = .0, (4261, 1) = 2.9872318713881905, (4261, 2) = -0.17147708480472767e-15, (4262, 1) = 2.9881438805747482, (4262, 2) = 0.17143791188348517e-15, (4263, 1) = 2.989055889761306, (4263, 2) = .0, (4264, 1) = 2.9899678989478637, (4264, 2) = .0, (4265, 1) = 2.9908799081344215, (4265, 2) = .0, (4266, 1) = 2.9917919173209793, (4266, 2) = -0.17128136902493735e-15, (4267, 1) = 2.9927039265075375, (4267, 2) = -0.17124227048649253e-15, (4268, 1) = 2.9936159356940957, (4268, 2) = .0, (4269, 1) = 2.9945279448806534, (4269, 2) = 0.1711641179784604e-15, (4270, 1) = 2.995439954067211, (4270, 2) = -0.17112506399671105e-15, (4271, 1) = 2.996351963253769, (4271, 2) = -0.17108602485503213e-15, (4272, 1) = 2.9972639724403267, (4272, 2) = 0.17104700054734363e-15, (4273, 1) = 2.9981759816268845, (4273, 2) = 0.17100799106756611e-15, (4274, 1) = 2.9990879908134422, (4274, 2) = .0, (4275, 1) = 3.0, (4275, 2) = .0}, datatype = float[8]), COLOUR(RGB, .47058824, 0., 0.54901961e-1, _ATTRIBUTE("source" = "mathdefault"))), AXESLABELS(x, ""), VIEW(-3. .. 3., DEFAULT, _ATTRIBUTE("source" = "mathdefault")), _ATTRIBUTE("input" = [TABLE([1 = plot, 2 = [(1/3)*(-6-2*x^2+(12+5*x^2-4*x*(x^2+3)^(1/2))^(1/2)*(x^2+3)^(1/2)+x*(x^2+3)^(1/2))/(x^2+3)^(1/2)], 3 = (x = -3 .. 3)]), "originalview" = [-3. .. 3., -0.702562299607569015e-15 .. 0.705095266891650214e-15], "originalaxesticks" = AXESTICKS(DEFAULT, DEFAULT, _ATTRIBUTE("source" = "mathdefault"))]))]
#plotting, shows the residue is zero for one solution, depending on if a>1 or a<-1
map(X->plot(eval(X,a=-2),x=-3..3),the_residue);
[INTERFACE_PLOT(CURVES(Matrix(4275, 2, {(1, 1) = -3.0, (1, 2) = -0.6837200662697115e-15, (2, 1) = -2.9990141990577888, (2, 2) = .0, (3, 1) = -2.998028398115578, (3, 2) = .0, (4, 1) = -2.997042597173367, (4, 2) = 0.17105647169475397e-15, (5, 1) = -2.996056796231156, (5, 2) = 0.34219731609203613e-15, (6, 1) = -2.9950709952889447, (6, 2) = 0.171140861731156e-15, (7, 1) = -2.9940851943467335, (7, 2) = .0, (8, 1) = -2.9930993934045222, (8, 2) = -0.3424506422675371e-15, (9, 1) = -2.9921135924623115, (9, 2) = -0.17126757686660214e-15, (10, 1) = -2.9911277915201007, (10, 2) = -0.17130984996402752e-15, (11, 1) = -2.9901419905778894, (11, 2) = -0.17135214043372566e-15, (12, 1) = -2.989156189635678, (12, 2) = .0, (13, 1) = -2.988170388693467, (13, 2) = 0.17143677352066652e-15, (14, 1) = -2.9871845877512557, (14, 2) = -0.3429582323065476e-15, (15, 1) = -2.986198786809045, (15, 2) = .0, (16, 1) = -2.985212985866834, (16, 2) = 0.34312770727035483e-15, (17, 1) = -2.984227184924623, (17, 2) = .0, (18, 1) = -2.9832413839824117, (18, 2) = -0.17164866079055953e-15, (19, 1) = -2.982255583040201, (19, 2) = .0, (20, 1) = -2.98126978209799, (20, 2) = -0.5152006130426966e-15, (21, 1) = -2.980283981155779, (21, 2) = -0.1717760022958917e-15, (22, 1) = -2.9792981802135676, (22, 2) = 0.17181848436768184e-15, (23, 1) = -2.978312379271357, (23, 2) = -0.34372196780791236e-15, (24, 1) = -2.977326578329146, (24, 2) = 0.34380700182480444e-15, (25, 1) = -2.976340777386935, (25, 2) = 0.3438920708014155e-15, (26, 1) = -2.9753549764447236, (26, 2) = .0, (27, 1) = -2.974369175502513, (27, 2) = 0.5160934705429525e-15, (28, 1) = -2.973383374560302, (28, 2) = -0.3441474876433322e-15, (29, 1) = -2.9723975736180908, (29, 2) = .0, (30, 1) = -2.9714117726758795, (30, 2) = -0.17215897030923173e-15, (31, 1) = -2.9704259717336683, (31, 2) = 0.17220160983816225e-15, (32, 1) = -2.969440170791457, (32, 2) = 0.3444885338015571e-15, (33, 1) = -2.9684543698492463, (33, 2) = .0, (34, 1) = -2.967596629720477, (34, 2) = -0.34464817345364115e-15, (35, 1) = -2.966738889591708, (35, 2) = 0.6894449809588651e-15, (36, 1) = -2.9658811494629393, (36, 2) = 0.34479683409705105e-15, (37, 1) = -2.9650234093341705, (37, 2) = 0.5173068064749464e-15, (38, 1) = -2.9641656692054017, (38, 2) = 0.17247280057415324e-15, (39, 1) = -2.963307929076633, (39, 2) = 0.3450200246022126e-15, (40, 1) = -2.962450188947864, (40, 2) = .0, (41, 1) = -2.9615924488190952, (41, 2) = 0.17258447570862857e-15, (42, 1) = -2.9607347086903264, (42, 2) = -0.1726217273993334e-15, (43, 1) = -2.9598769685615576, (43, 2) = 0.17265899242142473e-15, (44, 1) = -2.9590192284327888, (44, 2) = -0.3453925415599416e-15, (45, 1) = -2.95816148830402, (45, 2) = -0.3454671249600798e-15, (46, 1) = -2.957303748175251, (46, 2) = 0.1727708675267006e-15, (47, 1) = -2.9564460080464823, (47, 2) = 0.5184245577750646e-15, (48, 1) = -2.9555882679177135, (48, 2) = 0.17284551768007146e-15, (49, 1) = -2.9547305277889446, (49, 2) = -0.34576572559383864e-15, (50, 1) = -2.953872787660176, (50, 2) = .0, (51, 1) = -2.953015047531407, (51, 2) = .0, (52, 1) = -2.952157307402638, (52, 2) = .0, (53, 1) = -2.9512995672738693, (53, 2) = -0.17303237698367246e-15, (54, 1) = -2.9504418271451005, (54, 2) = -0.17306978898554786e-15, (55, 1) = -2.9495840870163317, (55, 2) = .0, (56, 1) = -2.948726346887563, (56, 2) = -0.17314465317100996e-15, (57, 1) = -2.947868606758794, (57, 2) = -0.1731821053647361e-15, (58, 1) = -2.947010866630025, (58, 2) = 0.34643914193177104e-15, (59, 1) = -2.9461531265012564, (59, 2) = 0.34651409995905623e-15, (60, 1) = -2.9452953863724876, (60, 2) = .0, (61, 1) = -2.9444376462437187, (61, 2) = .0, (62, 1) = -2.94357990611495, (62, 2) = 0.1733695675461156e-15, (63, 1) = -2.942722165986181, (63, 2) = -0.1734071002604319e-15, (64, 1) = -2.9418644258574123, (64, 2) = -0.1734446464125922e-15, (65, 1) = -2.9410066857286434, (65, 2) = -0.1734822060076669e-15, (66, 1) = -2.9400420672456034, (66, 2) = -0.17352446176671971e-15, (67, 1) = -2.9390774487625633, (67, 2) = -0.5207002036233832e-15, (68, 1) = -2.9381128302795227, (68, 2) = -0.3472180486762057e-15, (69, 1) = -2.9371482117964827, (69, 2) = 0.3473026623297139e-15, (70, 1) = -2.9361835933134426, (70, 2) = -0.17369365502860198e-15, (71, 1) = -2.935218974830402, (71, 2) = 0.17373599593655003e-15, (72, 1) = -2.934254356347362, (72, 2) = 0.5213350616877389e-15, (73, 1) = -2.933289737864322, (73, 2) = -0.17382072891390294e-15, (74, 1) = -2.932325119381282, (74, 2) = .0, (75, 1) = -2.9313605008982417, (75, 2) = .0, (76, 1) = -2.930395882415201, (76, 2) = -0.3478959127835101e-15, (77, 1) = -2.929431263932161, (77, 2) = 0.17399039971637317e-15, (78, 1) = -2.928466645449121, (78, 2) = -0.5220985804070349e-15, (79, 1) = -2.9275020269660805, (79, 2) = -0.34815067531376457e-15, (80, 1) = -2.9265374084830404, (80, 2) = .0, (81, 1) = -2.9255727900000004, (81, 2) = 0.3483206880676687e-15, (82, 1) = -2.9246081715169603, (82, 2) = 0.3484057458080118e-15, (83, 1) = -2.92364355303392, (83, 2) = 0.5227362567147701e-15, (84, 1) = -2.9226789345508797, (84, 2) = -0.1742879820437983e-15, (85, 1) = -2.9217143160678396, (85, 2) = -0.1743305623278421e-15, (86, 1) = -2.9207496975847995, (86, 2) = 0.17437315976426613e-15, (87, 1) = -2.919785079101759, (87, 2) = .0, (88, 1) = -2.918820460618719, (88, 2) = -0.1744584061230997e-15, (89, 1) = -2.917855842135679, (89, 2) = -0.5235031651797936e-15, (90, 1) = -2.9168912236526383, (90, 2) = .0, (91, 1) = -2.9159266051695982, (91, 2) = -0.17458640448447792e-15, (92, 1) = -2.914961986686558, (92, 2) = 0.3492582099732283e-15, (93, 1) = -2.9139973682035176, (93, 2) = -0.17467182269160613e-15, (94, 1) = -2.9130327497204775, (94, 2) = 0.17471455760666398e-15, (95, 1) = -2.9120681312374375, (95, 2) = 0.17475730973899757e-15, (96, 1) = -2.911103512754397, (96, 2) = -0.3496001581916334e-15, (97, 1) = -2.910138894271357, (97, 2) = 0.5245285970529922e-15, (98, 1) = -2.9091678816708546, (98, 2) = 0.34977190660166464e-15, (99, 1) = -2.908196869070352, (99, 2) = .0, (100, 1) = -2.907225856469849, (100, 2) = 0.34994436193571535e-15, (101, 1) = -2.9062548438693465, (101, 2) = -0.3500306420661747e-15, (102, 1) = -2.9043128186683416, (102, 2) = -0.3502033073274869e-15, (103, 1) = -2.9023707934673366, (103, 2) = -0.3503761126873514e-15, (104, 1) = -2.901399780866834, (104, 2) = 0.17523128397049935e-15, (105, 1) = -2.9004287682663317, (105, 2) = -0.3505490582633923e-15, (106, 1) = -2.8994577556658294, (106, 2) = 0.35063558366923363e-15, (107, 1) = -2.8984867430653267, (107, 2) = 0.3507221441732236e-15, (108, 1) = -2.897515730464824, (108, 2) = 0.35080873979006193e-15, (109, 1) = -2.8965447178643218, (109, 2) = -0.35089537053444803e-15, (110, 1) = -2.8955737052638195, (110, 2) = 0.17549101821054021e-15, (111, 1) = -2.894602692663317, (111, 2) = 0.1755343687323284e-15, (112, 1) = -2.893631680062814, (112, 2) = -0.1755777368399371e-15, (113, 1) = -2.892660667462312, (113, 2) = -0.17562112254071432e-15, (114, 1) = -2.8916896548618096, (114, 2) = 0.17566452584200772e-15, (115, 1) = -2.890718642261307, (115, 2) = .0, (116, 1) = -2.8897476296608042, (116, 2) = -0.5272541558265948e-15, (117, 1) = -2.8887766170603015, (117, 2) = 0.17579484142245506e-15, (118, 1) = -2.887805604459799, (118, 2) = -0.35167663039856186e-15, (119, 1) = -2.8868345918592966, (119, 2) = 0.1758818066133545e-15, (120, 1) = -2.8858635792587943, (120, 2) = -0.1759253156720207e-15, (121, 1) = -2.8848925666582916, (121, 2) = 0.17596884238262402e-15, (122, 1) = -2.883921554057789, (122, 2) = -0.35202477350501646e-15, (123, 1) = -2.8829505414572862, (123, 2) = -0.1760559487890168e-15, (124, 1) = -2.8819795288567835, (124, 2) = -0.17609952849949254e-15, (125, 1) = -2.8810085162562813, (125, 2) = -0.3522862517825555e-15, (126, 1) = -2.880037503655779, (126, 2) = 0.5285602229151428e-15, (127, 1) = -2.8790664910552763, (127, 2) = 0.3524607474962865e-15, (128, 1) = -2.8781000935081655, (128, 2) = 0.7050952668916502e-15, (129, 1) = -2.877133695961055, (129, 2) = 0.17631727724036903e-15, (130, 1) = -2.876167298413945, (130, 2) = -0.17636075530774803e-15, (131, 1) = -2.875200900866834, (131, 2) = .0, (132, 1) = -2.8742345033197236, (132, 2) = .0, (133, 1) = -2.8732681057726133, (133, 2) = 0.17649129488176424e-15, (134, 1) = -2.8723017082255025, (134, 2) = .0, (135, 1) = -2.871335310678392, (135, 2) = -0.1765784091466743e-15, (136, 1) = -2.869402515584171, (136, 2) = -0.1766655937848698e-15, (137, 1) = -2.86746972048995, (137, 2) = -0.17675284885419526e-15, (138, 1) = -2.8665033229428394, (138, 2) = -0.5303895084558156e-15, (139, 1) = -2.865536925395729, (139, 2) = 0.1768401744124845e-15, (140, 1) = -2.8645705278486187, (140, 2) = 0.35376772728612097e-15, (141, 1) = -2.863604130301508, (141, 2) = -0.53078271155268e-15, (142, 1) = -2.862637732754397, (142, 2) = 0.5309138851296269e-15, (143, 1) = -2.8616713352072867, (143, 2) = -0.35403007445446525e-15, (144, 1) = -2.8607049376601763, (144, 2) = .0, (145, 1) = -2.8597385401130655, (145, 2) = -0.17710257459930127e-15, (146, 1) = -2.8587721425659547, (146, 2) = -0.17714636980179287e-15, (147, 1) = -2.8578057450188443, (147, 2) = -0.5315705480746572e-15, (148, 1) = -2.856839347471734, (148, 2) = .0, (149, 1) = -2.855872949924623, (149, 2) = -0.3545557231235198e-15, (150, 1) = -2.8549065523775123, (150, 2) = 0.354643455113296e-15, (151, 1) = -2.853940154830402, (151, 2) = 0.17736561126768445e-15, (152, 1) = -2.8529737572832916, (152, 2) = -0.17740951270208713e-15, (153, 1) = -2.852007359736181, (153, 2) = 0.3549068637341466e-15, (154, 1) = -2.8510409621890704, (154, 2) = 0.1774973687698591e-15, (155, 1) = -2.85007456464196, (155, 2) = .0, (156, 1) = -2.8491081670948493, (156, 2) = 0.17758529581769027e-15, (157, 1) = -2.848141769547739, (157, 2) = 0.17762928597716363e-15, (158, 1) = -2.8472457953140706, (158, 2) = 0.177670086357763e-15, (159, 1) = -2.846349821080402, (159, 2) = 0.1777109020157289e-15, (160, 1) = -2.8454538468467336, (160, 2) = -0.17775173295680784e-15, (161, 1) = -2.8445578726130654, (161, 2) = 0.3555851583734913e-15, (162, 1) = -2.843661898379397, (162, 2) = 0.17783344071128745e-15, (163, 1) = -2.842765924145729, (163, 2) = 0.35574863507235517e-15, (164, 1) = -2.8418699499120605, (164, 2) = .0, (165, 1) = -2.8409739756783923, (165, 2) = 0.1779561171099769e-15, (166, 1) = -2.840078001444724, (166, 2) = .0, (167, 1) = -2.8391820272110557, (167, 2) = 0.35607595590816793e-15, (168, 1) = -2.838286052977387, (168, 2) = .0, (169, 1) = -2.8373900787437187, (169, 2) = -0.356239800228854e-15, (170, 1) = -2.8364941045100505, (170, 2) = -0.17816088420253625e-15, (171, 1) = -2.8355981302763817, (171, 2) = .0, (172, 1) = -2.8347021560427135, (172, 2) = 0.1782428984233217e-15, (173, 1) = -2.833806181809045, (173, 2) = -0.35656785713494435e-15, (174, 1) = -2.832910207575377, (174, 2) = .0, (175, 1) = -2.8320142333417087, (175, 2) = 0.17836603495196796e-15, (176, 1) = -2.8311182591080404, (176, 2) = -0.35681422240756532e-15, (177, 1) = -2.830222284874372, (177, 2) = -0.35689640567257344e-15, (178, 1) = -2.829326310640704, (178, 2) = .0, (179, 1) = -2.8284303364070356, (179, 2) = -0.35706086453258455e-15, (180, 1) = -2.827534362173367, (180, 2) = .0, (181, 1) = -2.8266383879396986, (181, 2) = 0.3572254465756697e-15, (182, 1) = -2.8257424137060303, (182, 2) = .0, (183, 1) = -2.8248464394723616, (183, 2) = .0, (184, 1) = -2.8239504652386933, (184, 2) = 0.5362088262136301e-15, (185, 1) = -2.823054491005025, (185, 2) = -0.5363324708665847e-15, (186, 1) = -2.8221585167713568, (186, 2) = -0.35763744121086135e-15, (187, 1) = -2.8212625425376885, (187, 2) = .0, (188, 1) = -2.82036656830402, (188, 2) = 0.1789012275582189e-15, (189, 1) = -2.819470594070352, (189, 2) = 0.3578850084117687e-15, (190, 1) = -2.8185428646482413, (190, 2) = -0.17898526007027041e-15, (191, 1) = -2.8176151352261307, (191, 2) = -0.1790280325110895e-15, (192, 1) = -2.81668740580402, (192, 2) = 0.17907082153469127e-15, (193, 1) = -2.8157596763819095, (193, 2) = 0.17911362714742437e-15, (194, 1) = -2.814831946959799, (194, 2) = .0, (195, 1) = -2.8139042175376883, (195, 2) = .0, (196, 1) = -2.812976488115578, (196, 2) = 0.17924214358388055e-15, (197, 1) = -2.8120487586934675, (197, 2) = 0.17928501561660214e-15, (198, 1) = -2.811121029271357, (198, 2) = -0.1793279042701809e-15, (199, 1) = -2.8101932998492467, (199, 2) = 0.17937080955095843e-15, (200, 1) = -2.809265570427136, (200, 2) = -0.17941373146527522e-15, (201, 1) = -2.8083378410050255, (201, 2) = -0.17945667001947054e-15, (202, 1) = -2.807410111582915, (202, 2) = 0.1794996252198824e-15, (203, 1) = -2.8064823821608043, (203, 2) = 0.17954259707284763e-15, (204, 1) = -2.8055546527386936, (204, 2) = -0.17958558558470176e-15, (205, 1) = -2.804626923316583, (205, 2) = -0.1796285907617791e-15, (206, 1) = -2.8036991938944724, (206, 2) = .0, (207, 1) = -2.802771464472362, (207, 2) = .0, (208, 1) = -2.801843735050251, (208, 2) = -0.5392731190430244e-15, (209, 1) = -2.8009160056281406, (209, 2) = -0.17980077824896295e-15, (210, 1) = -2.79998827620603, (210, 2) = 0.3596877336942536e-15, (211, 1) = -2.7990605467839194, (211, 2) = 0.17988697214849298e-15, (212, 1) = -2.798132817361809, (212, 2) = -0.3598601883187735e-15, (213, 1) = -2.7972050879396986, (213, 2) = .0, (214, 1) = -2.796277358517588, (214, 2) = -0.18001638833505147e-15, (215, 1) = -2.795349629095478, (215, 2) = .0, (216, 1) = -2.794421899673367, (216, 2) = .0, (217, 1) = -2.7934941702512566, (217, 2) = -0.18014595507806002e-15, (218, 1) = -2.792566440829146, (218, 2) = 0.36037835495774915e-15, (219, 1) = -2.7916387114070353, (219, 2) = 0.18023241663345568e-15, (220, 1) = -2.7907109819849247, (220, 2) = -0.3605513450962351e-15, (221, 1) = -2.789783252562814, (221, 2) = .0, (222, 1) = -2.788823793467337, (222, 2) = .0, (223, 1) = -2.7878643343718594, (223, 2) = -0.3608170075984219e-15, (224, 1) = -2.786904875276382, (224, 2) = -0.36090662002223266e-15, (225, 1) = -2.7859454161809047, (225, 2) = 0.18049813418358176e-15, (226, 1) = -2.784985957085427, (226, 2) = 0.36108595264716403e-15, (227, 1) = -2.7840264979899496, (227, 2) = .0, (228, 1) = -2.7830670388944725, (228, 2) = -0.1806327145340773e-15, (229, 1) = -2.782107579798995, (229, 2) = 0.18067761061851327e-15, (230, 1) = -2.7811481207035174, (230, 2) = 0.18072252469836577e-15, (231, 1) = -2.7801886616080402, (231, 2) = -0.18076745678060083e-15, (232, 1) = -2.7792292025125627, (232, 2) = 0.3616248137443657e-15, (233, 1) = -2.778269743417085, (233, 2) = -0.36171474996014847e-15, (234, 1) = -2.777310284321608, (234, 2) = 0.18090236111123575e-15, (235, 1) = -2.7763508252261304, (235, 2) = -0.18094736527262623e-15, (236, 1) = -2.775391366130653, (236, 2) = .0, (237, 1) = -2.7744319070351757, (237, 2) = 0.18103742771392059e-15, (238, 1) = -2.7734724479396986, (238, 2) = -0.18108248600773297e-15, (239, 1) = -2.772512988844221, (239, 2) = -0.36225512471918305e-15, (240, 1) = -2.7715535297487435, (240, 2) = .0, (241, 1) = -2.7705940706532663, (241, 2) = .0, (242, 1) = -2.7686751524623117, (242, 2) = .0, (243, 1) = -2.766756234271357, (243, 2) = .0, (244, 1) = -2.76579677517588, (244, 2) = 0.1814436030314179e-15, (245, 1) = -2.7648373160804023, (245, 2) = -0.36297764819533963e-15, (246, 1) = -2.7638778569849247, (246, 2) = .0, (247, 1) = -2.7629183978894476, (247, 2) = -0.18157932059867486e-15, (248, 1) = -2.76195893879397, (248, 2) = .0, (249, 1) = -2.7609994796984925, (249, 2) = 0.36333977927443635e-15, (250, 1) = -2.7600400206030153, (250, 2) = -0.18171520137538525e-15, (251, 1) = -2.7590805615075378, (251, 2) = -0.5452815938061456e-15, (252, 1) = -2.758124179409548, (252, 2) = .0, (253, 1) = -2.757167797311558, (253, 2) = -0.18185095451052506e-15, (254, 1) = -2.756211415213568, (254, 2) = -0.18189619321723014e-15, (255, 1) = -2.755255033115578, (255, 2) = -0.18194144999026813e-15, (256, 1) = -2.7542986510175878, (256, 2) = -0.18198672483648614e-15, (257, 1) = -2.753342268919598, (257, 2) = .0, (258, 1) = -2.7523858868216085, (258, 2) = -0.18207732877583946e-15, (259, 1) = -2.7514295047236184, (259, 2) = 0.1821226578826582e-15, (260, 1) = -2.7504731226256283, (260, 2) = -0.36433601018004734e-15, (261, 1) = -2.749516740527638, (261, 2) = 0.1822133704047721e-15, (262, 1) = -2.748560358429648, (262, 2) = -0.36451750766747493e-15, (263, 1) = -2.7476039763316584, (263, 2) = .0, (264, 1) = -2.7466475942336688, (264, 2) = .0, (265, 1) = -2.7456912121356787, (265, 2) = -0.36479002574848597e-15, (266, 1) = -2.7447348300376886, (266, 2) = 0.5473214064851178e-15, (267, 1) = -2.7437784479396985, (267, 2) = .0, (268, 1) = -2.7428220658417084, (268, 2) = -0.182531435188514e-15, (269, 1) = -2.7418656837437183, (269, 2) = 0.36515389121632936e-15, (270, 1) = -2.740909301645728, (270, 2) = 0.3652449483932481e-15, (271, 1) = -2.7399529195477386, (271, 2) = 0.1826680209607058e-15, (272, 1) = -2.738996537449749, (272, 2) = 0.18271358590722116e-15, (273, 1) = -2.738040155351759, (273, 2) = .0, (274, 1) = -2.7370837732537687, (274, 2) = .0, (275, 1) = -2.7361273911557786, (275, 2) = 0.18285038990944698e-15, (276, 1) = -2.732301862763819, (276, 2) = 0.1830330502126225e-15, (277, 1) = -2.728476334371859, (277, 2) = 0.18321600230515695e-15, (278, 1) = -2.727492577829774, (278, 2) = .0, (279, 1) = -2.7265088212876885, (279, 2) = -0.36662042086233053e-15, (280, 1) = -2.725525064745603, (280, 2) = .0, (281, 1) = -2.7245413082035173, (281, 2) = .0, (282, 1) = -2.7235575516614317, (282, 2) = -0.366903335365733e-15, (283, 1) = -2.7225737951193465, (283, 2) = -0.18349885881296602e-15, (284, 1) = -2.7215900385772613, (284, 2) = .0, (285, 1) = -2.7206062820351757, (285, 2) = -0.3671865983733038e-15, (286, 1) = -2.71962252549309, (286, 2) = 0.18364054844495743e-15, (287, 1) = -2.718638768951005, (287, 2) = 0.36737563418809145e-15, (288, 1) = -2.71765501240892, (288, 2) = -0.36747021028253783e-15, (289, 1) = -2.7166712558668342, (289, 2) = .0, (290, 1) = -2.7156874993247486, (290, 2) = 0.55148921837854e-15, (291, 1) = -2.7147037427826635, (291, 2) = -0.367754171490447e-15, (292, 1) = -2.7137199862405783, (292, 2) = -0.1839244514584466e-15, (293, 1) = -2.7127362296984927, (293, 2) = 0.367943673213039e-15, (294, 1) = -2.711752473156407, (294, 2) = 0.18401924119677582e-15, (295, 1) = -2.710768716614322, (295, 2) = -0.36813333047309243e-15, (296, 1) = -2.709784960072237, (296, 2) = -0.18411410873315806e-15, (297, 1) = -2.708801203530151, (297, 2) = .0, (298, 1) = -2.7078174469880656, (298, 2) = -0.18420905412620043e-15, (299, 1) = -2.70683369044598, (299, 2) = -0.18425655603726987e-15, (300, 1) = -2.7058499339038944, (300, 2) = -0.36860815486891777e-15, (301, 1) = -2.7048661773618092, (301, 2) = -0.36870323665015765e-15, (302, 1) = -2.703882420819724, (302, 2) = .0, (303, 1) = -2.7028986642776385, (303, 2) = 0.5533402758475237e-15, (304, 1) = -2.701914907735553, (304, 2) = -0.1844943580305903e-15, (305, 1) = -2.7009311511934673, (305, 2) = -0.18454197696798346e-15, (306, 1) = -2.6999473946513817, (306, 2) = 0.18458961543531576e-15, (307, 1) = -2.6989636381092965, (307, 2) = .0, (308, 1) = -2.6979798815672114, (308, 2) = 0.36936990197792184e-15, (309, 1) = -2.6969961250251258, (309, 2) = .0, (310, 1) = -2.696129631727387, (310, 2) = .0, (311, 1) = -2.6952631384296484, (311, 2) = 0.18481671893509234e-15, (312, 1) = -2.69439664513191, (312, 2) = 0.36971755426267234e-15, (313, 1) = -2.693530151834171, (313, 2) = 0.18490085051662062e-15, (314, 1) = -2.6917971652386936, (314, 2) = 0.1849850428741782e-15, (315, 1) = -2.6900641786432162, (315, 2) = 0.18506929604747803e-15, (316, 1) = -2.6891976853454773, (316, 2) = 0.18511144545243226e-15, (317, 1) = -2.688331192047739, (317, 2) = .0, (318, 1) = -2.6874646987500004, (318, 2) = -0.18519578992373258e-15, (319, 1) = -2.6865982054522615, (319, 2) = 0.18523798499998562e-15, (320, 1) = -2.6857317121545226, (320, 2) = 0.37056039061981633e-15, (321, 1) = -2.684865218856784, (321, 2) = -0.37064484171689636e-15, (322, 1) = -2.6839987255590456, (322, 2) = .0, (323, 1) = -2.6831322322613067, (323, 2) = 0.3708138353823235e-15, (324, 1) = -2.682265738963568, (324, 2) = .0, (325, 1) = -2.6813992456658293, (325, 2) = 0.3709829510753326e-15, (326, 1) = -2.680532752368091, (326, 2) = .0, (327, 1) = -2.679666259070352, (327, 2) = -0.1855760944374662e-15, (328, 1) = -2.678799765772613, (328, 2) = -0.37123685358937443e-15, (329, 1) = -2.6779332724748746, (329, 2) = .0, (330, 1) = -2.677066779177136, (330, 2) = 0.18570313734842222e-15, (331, 1) = -2.676200285879397, (331, 2) = -0.18574551555478973e-15, (332, 1) = -2.6753337925816583, (332, 2) = .0, (333, 1) = -2.67446729928392, (333, 2) = .0, (334, 1) = -2.6736008059861813, (334, 2) = -0.37174548390192993e-15, (335, 1) = -2.6727343126884424, (335, 2) = -0.18591518135844328e-15, (336, 1) = -2.6718678193907035, (336, 2) = .0, (337, 1) = -2.671001326092965, (337, 2) = 0.18600010611601735e-15, (338, 1) = -2.6701348327952266, (338, 2) = .0, (339, 1) = -2.6692683394974877, (339, 2) = .0, (340, 1) = -2.6380534203015076, (340, 2) = .0, (341, 1) = -2.6067103296482412, (341, 2) = .0, (342, 1) = -2.5765054540703516, (342, 2) = .0, (343, 1) = -2.5756483002983668, (343, 2) = -0.19076840315949823e-15, (344, 1) = -2.5747911465263815, (344, 2) = -0.3816242550950504e-15, (345, 1) = -2.5739339927543967, (345, 2) = .0, (346, 1) = -2.573076838982412, (346, 2) = .0, (347, 1) = -2.572219685210427, (347, 2) = -0.28641509068682744e-15, (348, 1) = -2.5713625314384423, (348, 2) = -0.954935901235301e-16, (349, 1) = -2.570505377666457, (349, 2) = 0.9551549111545099e-16, (350, 1) = -2.5696482238944722, (350, 2) = 0.9553739987357744e-16, (351, 1) = -2.5687910701224874, (351, 2) = -0.5733558984006798e-15, (352, 1) = -2.567933916350502, (352, 2) = -0.19116248139452112e-15, (353, 1) = -2.5670767625785174, (353, 2) = -0.1912063455344389e-15, (354, 1) = -2.5662196088065325, (354, 2) = -0.9562511261218829e-16, (355, 1) = -2.5653624550345477, (355, 2) = 0.573882361406182e-15, (356, 1) = -2.564505301262563, (356, 2) = 0.2870070469078209e-15, (357, 1) = -2.5636481474905777, (357, 2) = 0.28707293645733297e-15, (358, 1) = -2.562790993718593, (358, 2) = 0.9571294978606678e-16, (359, 1) = -2.561933839946608, (359, 2) = -0.38293971415598723e-15, (360, 1) = -2.561076686174623, (360, 2) = 0.9575691508008838e-16, (361, 1) = -2.560219532402638, (361, 2) = -0.9577890941152688e-16, (362, 1) = -2.559362378630653, (362, 2) = -0.9580091153549586e-16, (363, 1) = -2.5585052248586684, (363, 2) = -0.9582292145417696e-16, (364, 1) = -2.5576480710866836, (364, 2) = 0.4792246958487499e-15, (365, 1) = -2.5567909173146983, (365, 2) = 0.9586696468439277e-16, (366, 1) = -2.5559337635427135, (366, 2) = 0.2876669940008438e-15, (367, 1) = -2.5550766097707287, (367, 2) = 0.1918220782391791e-15, (368, 1) = -2.5542194559987434, (368, 2) = 0.28779926413346933e-15, (369, 1) = -2.5533623022267586, (369, 2) = 0.9595514477715212e-16, (370, 1) = -2.552505148454774, (370, 2) = -0.1919544186394897e-15, (371, 1) = -2.550790840910804, (371, 2) = -0.96021361843385e-16, (372, 1) = -2.549076533366834, (372, 2) = .0, (373, 1) = -2.548057294626256, (373, 2) = -0.2882754895795086e-15, (374, 1) = -2.547038055885678, (374, 2) = 0.3844725005949087e-15, (375, 1) = -2.5460188171451, (375, 2) = -0.9614443150301223e-16, (376, 1) = -2.5449995784045223, (376, 2) = -0.9617074892630896e-16, (377, 1) = -2.5439803396639444, (377, 2) = -0.2885912322666931e-15, (378, 1) = -2.5429611009233666, (378, 2) = -0.4811170849719406e-15, (379, 1) = -2.5419418621827887, (379, 2) = .0, (380, 1) = -2.540922623442211, (380, 2) = .0, (381, 1) = -2.539903384701633, (381, 2) = .0, (382, 1) = -2.538884145961055, (382, 2) = 0.9632888611741792e-16, (383, 1) = -2.5378649072204773, (383, 2) = 0.9635528112475323e-16, (384, 1) = -2.5368456684798995, (384, 2) = -0.19276337445979282e-15, (385, 1) = -2.5358264297393216, (385, 2) = 0.9640810443642858e-16, (386, 1) = -2.5348071909987437, (386, 2) = .0, (387, 1) = -2.533787952258166, (387, 2) = .0, (388, 1) = -2.532768713517588, (388, 2) = 0.4824371135005433e-15, (389, 1) = -2.53174947477701, (389, 2) = -0.19302776869585102e-15, (390, 1) = -2.5307302360364323, (390, 2) = 0.3861614284598993e-15, (391, 1) = -2.5297109972958545, (391, 2) = -0.965668410048127e-16, (392, 1) = -2.5286917585552766, (392, 2) = -0.19318667204198198e-15, (393, 1) = -2.5276725198146988, (393, 2) = 0.1932396843341147e-15, (394, 1) = -2.526653281074121, (394, 2) = -0.28993907833966513e-15, (395, 1) = -2.525634042333543, (395, 2) = .0, (396, 1) = -2.524614803592965, (396, 2) = 0.19339885483999333e-15, (397, 1) = -2.5235955648523873, (397, 2) = -0.9672597812100573e-16, (398, 1) = -2.5225763261118095, (398, 2) = 0.9675253996957657e-16, (399, 1) = -2.5215570873712316, (399, 2) = 0.19355822593846185e-15, (400, 1) = -2.5205378486306538, (400, 2) = 0.2904170913704586e-15, (401, 1) = -2.519518609890076, (401, 2) = 0.968322924358554e-16, (402, 1) = -2.518499371149498, (402, 2) = 0.29057669672954133e-15, (403, 1) = -2.51748013240892, (403, 2) = -0.2906565496468964e-15, (404, 1) = -2.516460893668342, (404, 2) = -0.9691214535671028e-16, (405, 1) = -2.5155974647613064, (405, 2) = -0.1938694243809906e-15, (406, 1) = -2.5147340358542714, (406, 2) = 0.9695728704386608e-16, (407, 1) = -2.5138706069472363, (407, 2) = 0.9697986991894269e-16, (408, 1) = -2.5130071780402012, (408, 2) = 0.38800984327137136e-15, (409, 1) = -2.512143749133166, (409, 2) = -0.9702505974268198e-16, (410, 1) = -2.5112803202261307, (410, 2) = 0.38819066678229265e-15, (411, 1) = -2.510416891319095, (411, 2) = -0.9707028167862716e-16, (412, 1) = -2.50955346241206, (412, 2) = 0.970929046939523e-16, (413, 1) = -2.508690033505025, (413, 2) = 0.38846214297461877e-15, (414, 1) = -2.50782660459799, (414, 2) = .0, (415, 1) = -2.506963175690955, (415, 2) = 0.19432164390920672e-15, (416, 1) = -2.5060997467839194, (416, 2) = -0.29155043136014973e-15, (417, 1) = -2.505236317876884, (417, 2) = .0, (418, 1) = -2.504372888969849, (418, 2) = -0.3889152463254799e-15, (419, 1) = -2.503509460062814, (419, 2) = 0.19450298176285877e-15, (420, 1) = -2.5026460311557788, (420, 2) = -0.1945483564610832e-15, (421, 1) = -2.5017826022487437, (421, 2) = .0, (422, 1) = -2.5009191733417087, (422, 2) = -0.9731957708426971e-16, (423, 1) = -2.5000557444346736, (423, 2) = 0.9734228859305206e-16, (424, 1) = -2.499192315527638, (424, 2) = 0.19473001631844062e-15, (425, 1) = -2.4983288866206026, (425, 2) = 0.3895509431394062e-15, (426, 1) = -2.4974654577135675, (426, 2) = 0.9741047147202047e-16, (427, 1) = -2.4966020288065325, (427, 2) = -0.2922996456683979e-15, (428, 1) = -2.4957385998994974, (428, 2) = -0.9745596703925785e-16, (429, 1) = -2.4948751709924624, (429, 2) = -0.9747872692346334e-16, (430, 1) = -2.4940117420854273, (430, 2) = 0.9750149487748058e-16, (431, 1) = -2.4931483131783923, (431, 2) = .0, (432, 1) = -2.4922848842713567, (432, 2) = .0, (433, 1) = -2.4914214553643212, (433, 2) = -0.9756984717901327e-16, (434, 1) = -2.490558026457286, (434, 2) = 0.3903705897315014e-15, (435, 1) = -2.489694597550251, (435, 2) = 0.9761545576683555e-16, (436, 1) = -2.488831168643216, (436, 2) = 0.6834679052806047e-15, (437, 1) = -2.487826795562186, (437, 2) = 0.29299446981154127e-15, (438, 1) = -2.486822422481156, (438, 2) = 0.1953827706004078e-15, (439, 1) = -2.485818049400126, (439, 2) = 0.19543591655045426e-15, (440, 1) = -2.4848136763190953, (440, 2) = 0.4887227109939594e-15, (441, 1) = -2.483809303238065, (441, 2) = 0.5866268224446115e-15, (442, 1) = -2.4828049301570347, (442, 2) = -0.2933932287130688e-15, (443, 1) = -2.4818005570760047, (443, 2) = 0.9782435969274914e-16, (444, 1) = -2.4807961839949746, (444, 2) = -0.39140394976988014e-15, (445, 1) = -2.4797918109139445, (445, 2) = -0.978776261567036e-16, (446, 1) = -2.4787874378329144, (446, 2) = -0.2937128275158891e-15, (447, 1) = -2.4777830647518844, (447, 2) = 0.29379280947427013e-15, (448, 1) = -2.4767786916708543, (448, 2) = -0.39183043247301945e-15, (449, 1) = -2.475774318589824, (449, 2) = -0.39193716288915774e-15, (450, 1) = -2.474769945508794, (450, 2) = -0.19602196861337505e-15, (451, 1) = -2.473765572427764, (451, 2) = 0.3921507554984189e-15, (452, 1) = -2.4727611993467336, (452, 2) = -0.19612880885838334e-15, (453, 1) = -2.471756826265703, (453, 2) = -0.294273392920782e-15, (454, 1) = -2.470752453184673, (454, 2) = -0.9811786851095252e-16, (455, 1) = -2.469748080103643, (455, 2) = 0.2944338511332089e-15, (456, 1) = -2.468743707022613, (456, 2) = -0.1963427531541523e-15, (457, 1) = -2.4677393339415827, (457, 2) = 0.9819814711209781e-16, (458, 1) = -2.4667349608605527, (458, 2) = 0.39289971461035516e-15, (459, 1) = -2.4657305877795226, (459, 2) = 0.1965034424033295e-15, (460, 1) = -2.4647262146984925, (460, 2) = -0.9827852476243637e-16, (461, 1) = -2.4627174685364324, (461, 2) = .0, (462, 1) = -2.4607087223743718, (462, 2) = 0.9838584918451468e-16, (463, 1) = -2.4597043492933413, (463, 2) = -0.29523812355073875e-15, (464, 1) = -2.458699976212311, (464, 2) = -0.9843957754623024e-16, (465, 1) = -2.457695603131281, (465, 2) = 0.39386583310216538e-15, (466, 1) = -2.456691230050251, (466, 2) = -0.19698670008249836e-15, (467, 1) = -2.45580218968907, (467, 2) = -0.2955514890635415e-15, (468, 1) = -2.454913149327889, (468, 2) = 0.9854098465292685e-16, (469, 1) = -2.454024108966708, (469, 2) = 0.1971296298772136e-15, (470, 1) = -2.4531350686055275, (470, 2) = 0.9858865388033573e-16, (471, 1) = -2.452246028244347, (471, 2) = -0.1972250029604516e-15, (472, 1) = -2.451356987883166, (472, 2) = 0.4931817887019293e-15, (473, 1) = -2.450467947521985, (473, 2) = -0.29598066798876467e-15, (474, 1) = -2.449578907160804, (474, 2) = .0, (475, 1) = -2.448689866799623, (475, 2) = 0.3948319140141032e-15, (476, 1) = -2.447800826438442, (476, 2) = 0.19746373885157827e-15, (477, 1) = -2.446911786077261, (477, 2) = 0.9875576901881766e-16, (478, 1) = -2.44602274571608, (478, 2) = 0.4938983864235027e-15, (479, 1) = -2.445133705354899, (479, 2) = 0.9880359422552348e-16, (480, 1) = -2.444244664993718, (480, 2) = -0.19765503968673796e-15, (481, 1) = -2.443355624632537, (481, 2) = 0.9885145414031616e-16, (482, 1) = -2.4424665842713567, (482, 2) = -0.1977507942368815e-15, (483, 1) = -2.441577543910176, (483, 2) = -0.19779869755963026e-15, (484, 1) = -2.440688503548995, (484, 2) = 0.1978466182530167e-15, (485, 1) = -2.439799463187814, (485, 2) = -0.9894727816058599e-16, (486, 1) = -2.438910422826633, (486, 2) = -0.39588502353644107e-15, (487, 1) = -2.438021382465452, (487, 2) = 0.9899524229913999e-16, (488, 1) = -2.437132342104271, (488, 2) = -0.9901923740773056e-16, (489, 1) = -2.4362433017430902, (489, 2) = 0.990432412119339e-16, (490, 1) = -2.4353542613819092, (490, 2) = -0.4953362685689927e-15, (491, 1) = -2.4344652210207283, (491, 2) = 0.29727382474610867e-15, (492, 1) = -2.4335761806595473, (492, 2) = 0.19823060963737707e-15, (493, 1) = -2.4326871402983663, (493, 2) = 0.3965573737031744e-15, (494, 1) = -2.4317980999371858, (494, 2) = .0, (495, 1) = -2.4309090595760052, (495, 2) = 0.39674978703798835e-15, (496, 1) = -2.4300200192148242, (496, 2) = 0.19842302298030869e-15, (497, 1) = -2.4291309788536433, (497, 2) = 0.9923558493271527e-16, (498, 1) = -2.4282419384924623, (498, 2) = .0, (499, 1) = -2.42726652031093, (499, 2) = -0.29785829717723247e-15, (500, 1) = -2.426291102129397, (500, 2) = 0.9931254152348676e-16, (501, 1) = -2.425315683947864, (501, 2) = 0.9933899448508224e-16, (502, 1) = -2.4243402657663315, (502, 2) = .0, (503, 1) = -2.423364847584799, (503, 2) = 0.198783863820843e-15, (504, 1) = -2.422389429403266, (504, 2) = -0.1988368327588944e-15, (505, 1) = -2.4214140112217333, (505, 2) = .0, (506, 1) = -2.420438593040201, (506, 2) = -0.19894283368675255e-15, (507, 1) = -2.4194631748586684, (507, 2) = 0.2984937985305904e-15, (508, 1) = -2.4184877566771354, (508, 2) = 0.995244593593018e-16, (509, 1) = -2.4175123384956025, (509, 2) = 0.9955099639330328e-16, (510, 1) = -2.41653692031407, (510, 2) = -0.4978877197407067e-15, (511, 1) = -2.4155615021325376, (511, 2) = -0.29881230607925224e-15, (512, 1) = -2.414586083951005, (512, 2) = -0.19926134126145506e-15, (513, 1) = -2.4136106657694727, (513, 2) = 0.9965724976366245e-16, (514, 1) = -2.41263524758794, (514, 2) = 0.39873535771123007e-15, (515, 1) = -2.411659829406407, (515, 2) = 0.9971043962574264e-16, (516, 1) = -2.4106844112248744, (516, 2) = 0.19947410072008472e-15, (517, 1) = -2.409708993043342, (517, 2) = 0.19952734326655154e-15, (518, 1) = -2.4087335748618095, (518, 2) = 0.9979030344800654e-16, (519, 1) = -2.407758156680277, (519, 2) = 0.19963389161358569e-15, (520, 1) = -2.406782738498744, (520, 2) = 0.9984359871218741e-16, (521, 1) = -2.4058073203172112, (521, 2) = -0.4993513108336871e-15, (522, 1) = -2.4048319021356788, (522, 2) = -0.9989693617298456e-16, (523, 1) = -2.4038564839541463, (523, 2) = -0.19984724146692993e-15, (524, 1) = -2.4028810657726134, (524, 2) = 0.4997515792535463e-15, (525, 1) = -2.4019056475910805, (525, 2) = -0.29993106458172734e-15, (526, 1) = -2.400930229409548, (526, 2) = .0, (527, 1) = -2.3999548112280156, (527, 2) = -0.10003046456824765e-15, (528, 1) = -2.3989793930464827, (528, 2) = -0.40022880775096684e-15, (529, 1) = -2.3980039748649498, (529, 2) = 0.2001678997531374e-15, (530, 1) = -2.3970285566834173, (530, 2) = -0.20022141677445107e-15, (531, 1) = -2.3960997279082914, (531, 2) = .0, (532, 1) = -2.395170899133166, (532, 2) = .0, (533, 1) = -2.3942420703580405, (533, 2) = 0.10018720793692287e-15, (534, 1) = -2.3933132415829146, (534, 2) = -0.10021272697344301e-15, (535, 1) = -2.392384412807789, (535, 2) = .0, (536, 1) = -2.3914555840326637, (536, 2) = -0.3007913815176433e-15, (537, 1) = -2.3905267552575378, (537, 2) = -0.10028934167271572e-15, (538, 1) = -2.3895979264824123, (538, 2) = 0.30094469732835817e-15, (539, 1) = -2.388669097707287, (539, 2) = -0.20068093230307697e-15, (540, 1) = -2.387740268932161, (540, 2) = -0.702562299607569e-15, (541, 1) = -2.3868114401570355, (541, 2) = 0.4015665162407382e-15, (542, 1) = -2.38588261138191, (542, 2) = 0.10041722493094686e-15, (543, 1) = -2.384953782606784, (543, 2) = 0.3013284912463861e-15, (544, 1) = -2.3840249538316587, (544, 2) = 0.10046844551581898e-15, (545, 1) = -2.3830961250565332, (545, 2) = 0.10049407023410172e-15, (546, 1) = -2.3821672962814073, (546, 2) = -0.10051970457238944e-15, (547, 1) = -2.3812384675062814, (547, 2) = -0.20109069706551277e-15, (548, 1) = -2.380309638731156, (548, 2) = -0.5028550105863595e-15, (549, 1) = -2.3793808099560305, (549, 2) = -0.20119333065600087e-15, (550, 1) = -2.3784519811809046, (550, 2) = .0, (551, 1) = -2.3775231524057787, (551, 2) = -0.6038881238179768e-15, (552, 1) = -2.3765943236306533, (552, 2) = -0.20134742547606802e-15, (553, 1) = -2.375665494855528, (553, 2) = -0.10069941447415969e-15, (554, 1) = -2.374736666080402, (554, 2) = 0.5036256292337303e-15, (555, 1) = -2.373807837305276, (555, 2) = 0.10075084685782764e-15, (556, 1) = -2.3728790085301505, (556, 2) = -0.6046594650566036e-15, (557, 1) = -2.371950179755025, (557, 2) = .0, (558, 1) = -2.371021350979899, (558, 2) = -0.20165613548462724e-15, (559, 1) = -2.3700925222047737, (559, 2) = .0, (560, 1) = -2.3691636934296483, (560, 2) = .0, (561, 1) = -2.3682348646545224, (561, 2) = 0.30271612633804696e-15, (562, 1) = -2.367306035879397, (562, 2) = -0.10093116398310662e-15, (563, 1) = -2.3663369004930903, (563, 2) = 0.3028742457249567e-15, (564, 1) = -2.365367765106784, (564, 2) = -0.2019700206929676e-15, (565, 1) = -2.3643986297204775, (565, 2) = -0.40404779719941617e-15, (566, 1) = -2.363429494334171, (566, 2) = 0.4041555950827052e-15, (567, 1) = -2.3624603589478643, (567, 2) = -0.10106585876119107e-15, (568, 1) = -2.3614912235615577, (568, 2) = -0.1010928292736326e-15, (569, 1) = -2.360522088175251, (569, 2) = -0.2022396206204581e-15, (570, 1) = -2.3595529527889445, (570, 2) = 0.10114680187320226e-15, (571, 1) = -2.358583817402638, (571, 2) = 0.10117380396476797e-15, (572, 1) = -2.3576146820163313, (572, 2) = -0.6072048995228127e-15, (573, 1) = -2.356645546630025, (573, 2) = -0.30368351922752383e-15, (574, 1) = -2.3556764112437185, (574, 2) = 0.10125487343308223e-15, (575, 1) = -2.354707275857412, (575, 2) = -0.10128191766104885e-15, (576, 1) = -2.3537381404711057, (576, 2) = 0.10130897242859198e-15, (577, 1) = -2.352769005084799, (577, 2) = -0.1013360377378895e-15, (578, 1) = -2.3517998696984925, (578, 2) = -0.3040893407733385e-15, (579, 1) = -2.350830734312186, (579, 2) = -0.40556079996170857e-15, (580, 1) = -2.3498615989258793, (580, 2) = 0.5070864846899551e-15, (581, 1) = -2.3488924635395727, (581, 2) = 0.20288880887191367e-15, (582, 1) = -2.347923328153266, (582, 2) = -0.10147152248647028e-15, (583, 1) = -2.345985057380653, (583, 2) = -0.10152579025369115e-15, (584, 1) = -2.34404678660804, (584, 2) = -0.1015801002566905e-15, (585, 1) = -2.3430776512217335, (585, 2) = -0.20321454220380524e-15, (586, 1) = -2.3421085158354273, (586, 2) = 0.10163445251240087e-15, (587, 1) = -2.3411393804491207, (587, 2) = .0, (588, 1) = -2.340170245062814, (588, 2) = 0.5084442351882487e-15, (589, 1) = -2.3392011096765075, (589, 2) = 0.3051481804697425e-15, (590, 1) = -2.338231974290201, (590, 2) = 0.20348656769831796e-15, (591, 1) = -2.3372628389038943, (591, 2) = .0, (592, 1) = -2.3362937035175877, (592, 2) = -0.10179776296354429e-15, (593, 1) = -2.335403734701633, (593, 2) = -0.10182279155590261e-15, (594, 1) = -2.3345137658856783, (594, 2) = -0.40739131628723183e-15, (595, 1) = -2.3336237970697233, (595, 2) = -0.20374575102569212e-15, (596, 1) = -2.332733828253769, (596, 2) = 0.10189793088059777e-15, (597, 1) = -2.331843859437814, (597, 2) = 0.10192299517663919e-15, (598, 1) = -2.330953890621859, (598, 2) = -0.20389613680508314e-15, (599, 1) = -2.3300639218059045, (599, 2) = 0.20394630111974261e-15, (600, 1) = -2.3291739529899496, (600, 2) = -0.10199824165018998e-15, (601, 1) = -2.3282839841739946, (601, 2) = 0.20404668335010845e-15, (602, 1) = -2.32739401535804, (602, 2) = -0.2040969012720317e-15, (603, 1) = -2.326504046542085, (603, 2) = -0.5103678426731089e-15, (604, 1) = -2.3256140777261303, (604, 2) = -0.10209869537241396e-15, (605, 1) = -2.324724108910176, (605, 2) = .0, (606, 1) = -2.323834140094221, (606, 2) = -0.5107448793585027e-15, (607, 1) = -2.322944171278266, (607, 2) = -0.20434825907250845e-15, (608, 1) = -2.3220542024623114, (608, 2) = 0.10219929214611281e-15, (609, 1) = -2.321164233646357, (609, 2) = -0.30667339110838053e-15, (610, 1) = -2.320274264830402, (610, 2) = -0.4089985768312346e-15, (611, 1) = -2.319384296014447, (611, 2) = -0.10227483366266542e-15, (612, 1) = -2.3184943271984926, (612, 2) = 0.30690009620659825e-15, (613, 1) = -2.3176043583825376, (613, 2) = -0.30697571828372364e-15, (614, 1) = -2.3167143895665827, (614, 2) = -0.30705136722384877e-15, (615, 1) = -2.315824420750628, (615, 2) = 0.2047513620209568e-15, (616, 1) = -2.3149344519346733, (616, 2) = -0.20480183047395257e-15, (617, 1) = -2.3140444831187184, (617, 2) = -0.20485231684450722e-15, (618, 1) = -2.313154514302764, (618, 2) = -0.5122570528389109e-15, (619, 1) = -2.312264545486809, (619, 2) = -0.1024766716750288e-15, (620, 1) = -2.311374576670854, (620, 2) = 0.20500388349091017e-15, (621, 1) = -2.3104846078548995, (621, 2) = -0.10252722078051754e-15, (622, 1) = -2.3095946390389446, (622, 2) = 0.20510501756333498e-15, (623, 1) = -2.3087046702229896, (623, 2) = -0.30773341725105344e-15, (624, 1) = -2.307814701407035, (624, 2) = 0.10260311168800948e-15, (625, 1) = -2.306854749808417, (625, 2) = 0.10263041761675781e-15, (626, 1) = -2.305894798209799, (626, 2) = 0.10265773398395816e-15, (627, 1) = -2.304934846611181, (627, 2) = -0.10268506079139855e-15, (628, 1) = -2.303974895012563, (628, 2) = 0.20542479608171972e-15, (629, 1) = -2.303014943413945, (629, 2) = 0.10273974573411591e-15, (630, 1) = -2.302054991815327, (630, 2) = 0.2055342077458668e-15, (631, 1) = -2.3010950402167087, (631, 2) = 0.3083834173772157e-15, (632, 1) = -2.3001350886180907, (632, 2) = -0.10282185149428375e-15, (633, 1) = -2.2991751370194726, (633, 2) = -0.20569848196062826e-15, (634, 1) = -2.2982151854208546, (634, 2) = .0, (635, 1) = -2.2972552338222365, (635, 2) = 0.2058081026235504e-15, (636, 1) = -2.2962952822236185, (636, 2) = -0.4117258886426405e-15, (637, 1) = -2.2953353306250004, (637, 2) = .0, (638, 1) = -2.2943753790263823, (638, 2) = -0.10298634523331998e-15, (639, 1) = -2.293415427427764, (639, 2) = -0.20602759492101097e-15, (640, 1) = -2.2924554758291458, (640, 2) = -0.41216504060209144e-15, (641, 1) = -2.2914955242305277, (641, 2) = 0.6184123998303544e-15, (642, 1) = -2.290535572631909, (642, 2) = .0, (643, 1) = -2.289575621033291, (643, 2) = 0.10312371101439893e-15, (644, 1) = -2.288615669434673, (644, 2) = -0.20630243114507906e-15, (645, 1) = -2.287655717836055, (645, 2) = -0.10317873060187286e-15, (646, 1) = -2.286695766237437, (646, 2) = 0.10320625610404879e-15, (647, 1) = -2.285735814638819, (647, 2) = -0.5161689604035486e-15, (648, 1) = -2.284775863040201, (648, 2) = -0.20652267706698115e-15, (649, 1) = -2.283815911441583, (649, 2) = -0.10328889546401874e-15, (650, 1) = -2.2828559598429647, (650, 2) = 0.10331646287391408e-15, (651, 1) = -2.2818960082443467, (651, 2) = 0.4133761630591555e-15, (652, 1) = -2.2809360566457286, (652, 2) = -0.10337162913824785e-15, (653, 1) = -2.2799761050471106, (653, 2) = -0.31019768398766433e-15, (654, 1) = -2.2790161534484925, (654, 2) = -0.5171341866964958e-15, (655, 1) = -2.2780562018498745, (655, 2) = 0.10345445717006284e-15, (656, 1) = -2.2770962502512564, (656, 2) = 0.10348208748975331e-15, (657, 1) = -2.276099130329774, (657, 2) = 0.31053239620260396e-15, (658, 1) = -2.2751020104082915, (658, 2) = .0, (659, 1) = -2.274104890486809, (659, 2) = 0.20713651037164296e-15, (660, 1) = -2.2731077705653266, (660, 2) = -0.31079100118938056e-15, (661, 1) = -2.272110650643844, (661, 2) = 0.4145030277304559e-15, (662, 1) = -2.2711135307223618, (662, 2) = -0.10365452479599339e-15, (663, 1) = -2.2701164108008793, (663, 2) = -0.2073666079766e-15, (664, 1) = -2.269119290879397, (664, 2) = 0.3111362835336787e-15, (665, 1) = -2.2681221709579145, (665, 2) = -0.20748179273291058e-15, (666, 1) = -2.267125051036432, (666, 2) = 0.10376970955566125e-15, (667, 1) = -2.2661279311149496, (667, 2) = .0, (668, 1) = -2.265130811193467, (668, 2) = -0.10382736994265401e-15, (669, 1) = -2.2641336912719847, (669, 2) = 0.10385621714374281e-15, (670, 1) = -2.2631365713505023, (670, 2) = .0, (671, 1) = -2.26213945142902, (671, 2) = 0.20782789113858114e-15, (672, 1) = -2.261142331507538, (672, 2) = .0, (673, 1) = -2.260145211586056, (673, 2) = 0.20794343874027372e-15, (674, 1) = -2.2591480916645734, (674, 2) = 0.10400062329031372e-15, (675, 1) = -2.258150971743091, (675, 2) = -0.20805907711823302e-15, (676, 1) = -2.2571538518216085, (676, 2) = -0.10405846517812606e-15, (677, 1) = -2.256156731900126, (677, 2) = .0, (678, 1) = -2.2551596119786437, (678, 2) = -0.3123490574191233e-15, (679, 1) = -2.2541624920571612, (679, 2) = -0.10414531315206073e-15, (680, 1) = -2.253165372135679, (680, 2) = .0, (681, 1) = -2.2521682522141964, (681, 2) = -0.1042032685809379e-15, (682, 1) = -2.251171132292714, (682, 2) = 0.31269679000155654e-15, (683, 1) = -2.2501740123712315, (683, 2) = .0, (684, 1) = -2.249176892449749, (684, 2) = 0.20858057384840325e-15, (685, 1) = -2.2481797725282666, (685, 2) = -0.20863863152927123e-15, (686, 1) = -2.247182652606784, (686, 2) = 0.20869671194111773e-15, (687, 1) = -2.2461855326853017, (687, 2) = -0.3131322226303394e-15, (688, 1) = -2.2451884127638193, (688, 2) = 0.31321941145429126e-15, (689, 1) = -2.2443204169409547, (689, 2) = .0, (690, 1) = -2.2434524211180906, (690, 2) = -0.10445709636647749e-15, (691, 1) = -2.2425844252952265, (691, 2) = 0.10448242223344258e-15, (692, 1) = -2.241716429472362, (692, 2) = -0.10450775671907201e-15, (693, 1) = -2.2408484336494974, (693, 2) = -0.20906619964860584e-15, (694, 1) = -2.2399804378266333, (694, 2) = 0.20911690310013325e-15, (695, 1) = -2.239112442003769, (695, 2) = .0, (696, 1) = -2.2382444461809046, (696, 2) = -0.1046091808668894e-15, (697, 1) = -2.23737645035804, (697, 2) = -0.3139036753793479e-15, (698, 1) = -2.236508454535176, (698, 2) = 0.4186397787075077e-15, (699, 1) = -2.2356404587123118, (699, 2) = -0.31405601855722473e-15, (700, 1) = -2.234772462889447, (700, 2) = -0.10471074298727357e-15, (701, 1) = -2.2339044670665826, (701, 2) = 0.3142084652470919e-15, (702, 1) = -2.2330364712437185, (702, 2) = 0.31428472741569423e-15, (703, 1) = -2.2321684754208544, (703, 2) = 0.3143610154702661e-15, (704, 1) = -2.23130047959799, (704, 2) = -0.20962488627561885e-15, (705, 1) = -2.2304324837751253, (705, 2) = 0.10483788974926145e-15, (706, 1) = -2.229564487952261, (706, 2) = 0.2097266899839466e-15, (707, 1) = -2.228696492129397, (707, 2) = .0, (708, 1) = -2.2278284963065325, (708, 2) = -0.20982856274918968e-15, (709, 1) = -2.226960500483668, (709, 2) = 0.1049397625161989e-15, (710, 1) = -2.2260925046608038, (710, 2) = 0.41986100916980613e-15, (711, 1) = -2.2252245088379397, (711, 2) = -0.20998150140837027e-15, (712, 1) = -2.224356513015075, (712, 2) = 0.4200650310089047e-15, (713, 1) = -2.2234885171922105, (713, 2) = -0.21008354687479012e-15, (714, 1) = -2.2226205213693464, (714, 2) = 0.21013459552101264e-15, (715, 1) = -2.2217525255464823, (715, 2) = -0.1050928307223684e-15, (716, 1) = -2.2208845297236177, (716, 2) = 0.31535511697135157e-15, (717, 1) = -2.2200165339007536, (717, 2) = 0.21028784513109819e-15, (718, 1) = -2.2191485380778895, (718, 2) = -0.10516948144845457e-15, (719, 1) = -2.218280542255025, (719, 2) = 0.10519504897328468e-15, (720, 1) = -2.217412546432161, (720, 2) = -0.1052206251408177e-15, (721, 1) = -2.2164750871639445, (721, 2) = -0.21049651562236763e-15, (722, 1) = -2.2155376278957286, (722, 2) = 0.31582770169432686e-15, (723, 1) = -2.2146001686275127, (723, 2) = -0.2106071068050994e-15, (724, 1) = -2.213662709359297, (724, 2) = -0.21066243265090856e-15, (725, 1) = -2.212725250091081, (725, 2) = -0.10535888933442923e-15, (726, 1) = -2.2117877908228647, (726, 2) = .0, (727, 1) = -2.2108503315546484, (727, 2) = 0.1054142656143079e-15, (728, 1) = -2.2099128722864325, (728, 2) = 0.10544196888704938e-15, (729, 1) = -2.206163035213568, (729, 2) = 0.10555288288440966e-15, (730, 1) = -2.202413198140704, (730, 2) = 0.1056639583741751e-15, (731, 1) = -2.201475738872488, (731, 2) = -0.10569175248623417e-15, (732, 1) = -2.2005382796042716, (732, 2) = 0.2114391133916237e-15, (733, 1) = -2.1996008203360553, (733, 2) = 0.10574737100372875e-15, (734, 1) = -2.1986633610678394, (734, 2) = 0.21155039082159364e-15, (735, 1) = -2.1977259017996236, (735, 2) = -0.2116060598356386e-15, (736, 1) = -2.1967884425314073, (736, 2) = 0.5291543726279536e-15, (737, 1) = -2.195850983263191, (737, 2) = -0.21171745846979365e-15, (738, 1) = -2.194913523994975, (738, 2) = -0.2117731880930292e-15, (739, 1) = -2.193976064726759, (739, 2) = 0.10591446896121231e-15, (740, 1) = -2.193038605458543, (740, 2) = 0.3178270619392478e-15, (741, 1) = -2.1921011461903266, (741, 2) = -0.10597024910287611e-15, (742, 1) = -2.1911636869221107, (742, 2) = 0.21199630866266892e-15, (743, 1) = -2.190226227653895, (743, 2) = -0.10602606966585716e-15, (744, 1) = -2.1892887683856785, (744, 2) = -0.10605399510716812e-15, (745, 1) = -2.1883513091174622, (745, 2) = .0, (746, 1) = -2.1874138498492464, (746, 2) = -0.31832962893901744e-15, (747, 1) = -2.186445362694724, (747, 2) = -0.21227751505504294e-15, (748, 1) = -2.185476875540201, (748, 2) = -0.31850294859582627e-15, (749, 1) = -2.1845083883856784, (749, 2) = 0.31858965698104754e-15, (750, 1) = -2.183539901231156, (750, 2) = 0.318676397740442e-15, (751, 1) = -2.1825714140766337, (751, 2) = 0.21250878058412838e-15, (752, 1) = -2.181602926922111, (752, 2) = 0.3188499763904511e-15, (753, 1) = -2.180634439767588, (753, 2) = -0.31893681428533836e-15, (754, 1) = -2.1796659526130657, (754, 2) = 0.10634122818764783e-15, (755, 1) = -2.1786974654585434, (755, 2) = -0.10637019574177494e-15, (756, 1) = -2.1777289783040206, (756, 2) = 0.10639917409150304e-15, (757, 1) = -2.1767604911494978, (757, 2) = .0, (758, 1) = -2.1757920039949754, (758, 2) = .0, (759, 1) = -2.1748235168404526, (759, 2) = 0.10648617392089172e-15, (760, 1) = -2.17385502968593, (760, 2) = -0.10651519545956955e-15, (761, 1) = -2.1728865425314074, (761, 2) = 0.10654422779706848e-15, (762, 1) = -2.1719180553768846, (762, 2) = -0.3197198128020024e-15, (763, 1) = -2.170949568222362, (763, 2) = -0.21320464974193623e-15, (764, 1) = -2.1699810810678395, (764, 2) = -0.21326277921712268e-15, (765, 1) = -2.1690125939133167, (765, 2) = 0.2133209302947216e-15, (766, 1) = -2.168044106758794, (766, 2) = 0.21337910297587185e-15, (767, 1) = -2.1670756196042715, (767, 2) = -0.3201559458925364e-15, (768, 1) = -2.1661071324497487, (768, 2) = -0.10674775657663745e-15, (769, 1) = -2.165138645295226, (769, 2) = -0.3203306259775469e-15, (770, 1) = -2.1641701581407036, (770, 2) = .0, (771, 1) = -2.1602962095226133, (771, 2) = 0.10692263114123979e-15, (772, 1) = -2.156422260904523, (772, 2) = 0.21407886061174847e-15, (773, 1) = -2.1554747851695986, (773, 2) = 0.3212040687699889e-15, (774, 1) = -2.1545273094346737, (774, 2) = .0, (775, 1) = -2.153579833699749, (775, 2) = 0.10712523919271416e-15, (776, 1) = -2.1526323579648245, (776, 2) = 0.10715386284539252e-15, (777, 1) = -2.1507374064949754, (777, 2) = .0, (778, 1) = -2.148842455025126, (778, 2) = -0.10726846091760924e-15, (779, 1) = -2.147894979290202, (779, 2) = 0.10729713630270658e-15, (780, 1) = -2.146947503555277, (780, 2) = -0.1073258220352519e-15, (781, 1) = -2.146000027820352, (781, 2) = .0, (782, 1) = -2.1450525520854278, (782, 2) = 0.10738322454386457e-15, (783, 1) = -2.144105076350503, (783, 2) = 0.10741194132049488e-15, (784, 1) = -2.143157600615578, (784, 2) = -0.214881336891398e-15, (785, 1) = -2.1422101248806538, (785, 2) = 0.10746940591973216e-15, (786, 1) = -2.141262649145729, (786, 2) = -0.10749815374283905e-15, (787, 1) = -2.140315173410804, (787, 2) = -0.21505382383050756e-15, (788, 1) = -2.1393676976758798, (788, 2) = .0, (789, 1) = -2.138420221940955, (789, 2) = 0.2151689186177805e-15, (790, 1) = -2.13747274620603, (790, 2) = -0.32283974559158147e-15, (791, 1) = -2.1365252704711057, (791, 2) = .0, (792, 1) = -2.135577794736181, (792, 2) = -0.32301257407318835e-15, (793, 1) = -2.134630319001256, (793, 2) = -0.10769967829697926e-15, (794, 1) = -2.1336828432663317, (794, 2) = 0.10772850892021091e-15, (795, 1) = -2.1327353675314074, (795, 2) = 0.2155146997884795e-15, (796, 1) = -2.1317878917964825, (796, 2) = -0.32335860365761073e-15, (797, 1) = -2.1308404160615577, (797, 2) = .0, (798, 1) = -2.1298929403266333, (798, 2) = 0.4313757396897332e-15, (799, 1) = -2.128945464591709, (799, 2) = .0, (800, 1) = -2.127997988856784, (800, 2) = -0.5395085501539278e-15, (801, 1) = -2.1270505131218593, (801, 2) = -0.4317224524484466e-15, (802, 1) = -2.126103037386935, (802, 2) = -0.10795952654497126e-15, (803, 1) = -2.1251863058951006, (803, 2) = .0, (804, 1) = -2.1242695744032667, (804, 2) = .0, (805, 1) = -2.123352842911433, (805, 2) = -0.32413053262753633e-15, (806, 1) = -2.1224361114195984, (806, 2) = .0, (807, 1) = -2.121519379927764, (807, 2) = -0.32429864665130923e-15, (808, 1) = -2.1206026484359297, (808, 2) = 0.10812758242398457e-15, (809, 1) = -2.1196859169440954, (809, 2) = 0.10815562565503407e-15, (810, 1) = -2.1187691854522614, (810, 2) = -0.10818367857690563e-15, (811, 1) = -2.1178524539604275, (811, 2) = 0.10821174118957695e-15, (812, 1) = -2.116935722468593, (812, 2) = 0.21647962698603162e-15, (813, 1) = -2.116018990976759, (813, 2) = .0, (814, 1) = -2.1151022594849245, (814, 2) = -0.32488796151605385e-15, (815, 1) = -2.11418552799309, (815, 2) = 0.10832408854746743e-15, (816, 1) = -2.113268796501256, (816, 2) = .0, (817, 1) = -2.1123520650094223, (817, 2) = -0.32514096110971264e-15, (818, 1) = -2.111435333517588, (818, 2) = 0.21681690163343615e-15, (819, 1) = -2.1105186020257536, (819, 2) = .0, (820, 1) = -2.1096018705339197, (820, 2) = -0.10846474078102821e-15, (821, 1) = -2.1086851390420858, (821, 2) = 0.10849290029829097e-15, (822, 1) = -2.1077684075502514, (822, 2) = .0, (823, 1) = -2.105934944566583, (823, 2) = -0.10857743698889752e-15, (824, 1) = -2.104101481582915, (824, 2) = -0.2172676864602091e-15, (825, 1) = -2.1031847500910805, (825, 2) = 0.1086620608844318e-15, (826, 1) = -2.1022680185992466, (826, 2) = 0.3260708646829638e-15, (827, 1) = -2.1013512871074127, (827, 2) = -0.21743705051914002e-15, (828, 1) = -2.1004345556155783, (828, 2) = .0, (829, 1) = -2.099517824123744, (829, 2) = 0.217550056777231e-15, (830, 1) = -2.0986010926319096, (830, 2) = .0, (831, 1) = -2.0976843611400753, (831, 2) = 0.10883157026973888e-15, (832, 1) = -2.0967676296482414, (832, 2) = -0.10885985574171297e-15, (833, 1) = -2.0804816452763824, (833, 2) = .0, (834, 1) = -2.064195660904523, (834, 2) = 0.10987113802319607e-15, (835, 1) = -2.0632810558228645, (835, 2) = .0, (836, 1) = -2.062366450741206, (836, 2) = -0.3297848788677448e-15, (837, 1) = -2.0614518456595476, (837, 2) = .0, (838, 1) = -2.0605372405778897, (838, 2) = -0.10998548638776058e-15, (839, 1) = -2.0596226354962317, (839, 2) = -0.2200281950783066e-15, (840, 1) = -2.0587080304145733, (840, 2) = -0.33012815493978614e-15, (841, 1) = -2.057793425332915, (841, 2) = .0, (842, 1) = -2.0568788202512565, (842, 2) = .0, (843, 1) = -2.055964215169598, (843, 2) = .0, (844, 1) = -2.0550496100879396, (844, 2) = .0, (845, 1) = -2.054135005006281, (845, 2) = 0.22037193299845549e-15, (846, 1) = -2.0532203999246232, (846, 2) = 0.22042928998856533e-15, (847, 1) = -2.0523057948429653, (847, 2) = 0.22048666621366153e-15, (848, 1) = -2.051391189761307, (848, 2) = .0, (849, 1) = -2.0504765846796484, (849, 2) = -0.220601476362456e-15, (850, 1) = -2.04956197959799, (850, 2) = -0.33098836542437707e-15, (851, 1) = -2.0486473745163316, (851, 2) = .0, (852, 1) = -2.047732769434673, (852, 2) = 0.33116075371156295e-15, (853, 1) = -2.046818164353015, (853, 2) = 0.2208313274086623e-15, (854, 1) = -2.045903559271357, (854, 2) = -0.22088883823303296e-15, (855, 1) = -2.044988954189699, (855, 2) = 0.11047318413953757e-15, (856, 1) = -2.0440743491080404, (856, 2) = 0.33150587631753003e-15, (857, 1) = -2.043159744026382, (857, 2) = .0, (858, 1) = -2.0422451389447236, (858, 2) = 0.11055953686471267e-15, (859, 1) = -2.0385867186180904, (859, 2) = .0, (860, 1) = -2.034928298291457, (860, 2) = -0.11079023344658713e-15, (861, 1) = -2.033951762148241, (861, 2) = -0.33246320897278664e-15, (862, 1) = -2.032975226005025, (862, 2) = .0, (863, 1) = -2.0319986898618088, (863, 2) = .0, (864, 1) = -2.0310221537185926, (864, 2) = -0.33274093181681085e-15, (865, 1) = -2.0300456175753765, (865, 2) = -0.11094452391121877e-15, (866, 1) = -2.0290690814321604, (866, 2) = -0.22195082964115327e-15, (867, 1) = -2.0280925452889447, (867, 2) = -0.4440252666627288e-15, (868, 1) = -2.0271160091457285, (868, 2) = 0.2220744588903827e-15, (869, 1) = -2.0261394730025124, (869, 2) = -0.2221363063154881e-15, (870, 1) = -2.0251629368592967, (870, 2) = -0.2221981756039289e-15, (871, 1) = -2.0241864007160806, (871, 2) = -0.2222600667529218e-15, (872, 1) = -2.0232098645728644, (872, 2) = 0.2223219797596511e-15, (873, 1) = -2.0222333284296483, (873, 2) = .0, (874, 1) = -2.021256792286432, (874, 2) = .0, (875, 1) = -2.020280256143216, (875, 2) = .0, (876, 1) = -2.01930372, (876, 2) = 0.11128492515325335e-15, (877, 1) = -2.018327183856784, (877, 2) = .0, (878, 1) = -2.0173506477135676, (878, 2) = -0.11134695832539925e-15, (879, 1) = -2.0163741115703515, (879, 2) = 0.22275598258015983e-15, (880, 1) = -2.0153975754271354, (880, 2) = 0.1114090351717891e-15, (881, 1) = -2.0144210392839192, (881, 2) = .0, (882, 1) = -2.013444503140703, (882, 2) = 0.1114711556800654e-15, (883, 1) = -2.0124679669974874, (883, 2) = 0.11150223230347792e-15, (884, 1) = -2.0114914308542713, (884, 2) = .0, (885, 1) = -2.010514894711055, (885, 2) = -0.11156441828084243e-15, (886, 1) = -2.0095383585678395, (886, 2) = 0.11159552763154137e-15, (887, 1) = -2.0085618224246233, (887, 2) = 0.11162664788805526e-15, (888, 1) = -2.007585286281407, (888, 2) = -0.2233155580974327e-15, (889, 1) = -2.006608750138191, (889, 2) = .0, (890, 1) = -2.005632213994975, (890, 2) = 0.2234401481514521e-15, (891, 1) = -2.004655677851759, (891, 2) = -0.11175123793865606e-15, (892, 1) = -2.0036791417085427, (892, 2) = 0.22356482539779193e-15, (893, 1) = -1.9966000466080402, (893, 2) = 0.22401746018861886e-15, (894, 1) = -1.9895209515075378, (894, 2) = 0.22447123872408967e-15, (895, 1) = -1.9877511777324122, (895, 2) = 0.11229243094827764e-15, (896, 1) = -1.9859814039572865, (896, 2) = .0, (897, 1) = -1.9850965170697237, (897, 2) = -0.11237771523117296e-15, (898, 1) = -1.9842116301821608, (898, 2) = 0.22481232232058554e-15, (899, 1) = -1.983326743294598, (899, 2) = -0.1124346160042371e-15, (900, 1) = -1.9824418564070352, (900, 2) = .0, (901, 1) = -1.9815569695194724, (901, 2) = 0.22498310486061986e-15, (902, 1) = -1.9806720826319095, (902, 2) = -0.4500801360370562e-15, (903, 1) = -1.9797871957443467, (903, 2) = 0.22509704899338774e-15, (904, 1) = -1.9789023088567839, (904, 2) = .0, (905, 1) = -1.978017421969221, (905, 2) = -0.11260553219050094e-15, (906, 1) = -1.9771325350816582, (906, 2) = .0, (907, 1) = -1.9762476481940956, (907, 2) = .0, (908, 1) = -1.9753627613065328, (908, 2) = -0.1126911105039668e-15, (909, 1) = -1.9714931009170855, (909, 2) = .0, (910, 1) = -1.9676234405276383, (910, 2) = 0.1129410599597707e-15, (911, 1) = -1.9666560254302765, (911, 2) = -0.33891705433657e-15, (912, 1) = -1.9656886103329145, (912, 2) = -0.11300365354661607e-15, (913, 1) = -1.9647211952355528, (913, 2) = 0.22606993252136857e-15, (914, 1) = -1.963753780138191, (914, 2) = -0.11306628958534568e-15, (915, 1) = -1.9627863650408293, (915, 2) = -0.33929287055460093e-15, (916, 1) = -1.9618189499434675, (916, 2) = .0, (917, 1) = -1.9608515348461055, (917, 2) = .0, (918, 1) = -1.9598841197487438, (918, 2) = -0.11319168894165835e-15, (919, 1) = -1.9521447989698493, (919, 2) = .0, (920, 1) = -1.9444054781909548, (920, 2) = 0.11369498047668599e-15, (921, 1) = -1.9434952159767587, (921, 2) = 0.22744932420352506e-15, (922, 1) = -1.9425849537625628, (922, 2) = -0.34126305921146626e-15, (923, 1) = -1.941674691548367, (923, 2) = -0.11378405338053478e-15, (924, 1) = -1.940764429334171, (924, 2) = -0.1138137630295562e-15, (925, 1) = -1.9398541671199752, (925, 2) = .0, (926, 1) = -1.938943904905779, (926, 2) = 0.11387321033507437e-15, (927, 1) = -1.938033642691583, (927, 2) = -0.11390294798680927e-15, (928, 1) = -1.937123380477387, (928, 2) = -0.1139326949679956e-15, (929, 1) = -1.9362131182631912, (929, 2) = 0.22792490255243156e-15, (930, 1) = -1.935302856048995, (930, 2) = 0.22798443381807475e-15, (931, 1) = -1.934392593834799, (931, 2) = 0.2280439837280265e-15, (932, 1) = -1.9334823316206031, (932, 2) = 0.1140517761386814e-15, (933, 1) = -1.9325720694064072, (933, 2) = .0, (934, 1) = -1.9316618071922111, (934, 2) = 0.3423341179115183e-15, (935, 1) = -1.930751544978015, (935, 2) = -0.22828236971199566e-15, (936, 1) = -1.9298412827638192, (936, 2) = 0.4566840255380755e-15, (937, 1) = -1.9289310205496233, (937, 2) = -0.11420083722019955e-15, (938, 1) = -1.9280207583354272, (938, 2) = -0.2284613547209771e-15, (939, 1) = -1.927110496121231, (939, 2) = 0.22852105360563897e-15, (940, 1) = -1.9262002339070352, (940, 2) = .0, (941, 1) = -1.9252899716928393, (941, 2) = -0.11432025358326666e-15, (942, 1) = -1.9243797094786432, (942, 2) = .0, (943, 1) = -1.9234694472644471, (943, 2) = 0.11438001754070914e-15, (944, 1) = -1.9225591850502513, (944, 2) = 0.11440991345422749e-15, (945, 1) = -1.9216489228360554, (945, 2) = 0.34331945596221893e-15, (946, 1) = -1.9207386606218593, (946, 2) = -0.34340919941272006e-15, (947, 1) = -1.9198283984076632, (947, 2) = -0.22899931380408243e-15, (948, 1) = -1.9189181361934673, (948, 2) = 0.1145295899447738e-15, (949, 1) = -1.9180078739792714, (949, 2) = 0.22911906452610604e-15, (950, 1) = -1.9170976117650755, (950, 2) = .0, (951, 1) = -1.9161873495508797, (951, 2) = 0.3438583341459078e-15, (952, 1) = -1.9152770873366836, (952, 2) = 0.22929882968752e-15, (953, 1) = -1.913374114748744, (953, 2) = 0.11471209960938318e-15, (954, 1) = -1.9114711421608042, (954, 2) = .0, (955, 1) = -1.9105196558668343, (955, 2) = 0.11480620262167956e-15, (956, 1) = -1.9095681695728643, (956, 2) = -0.2296751810196671e-15, (957, 1) = -1.9086166832788947, (957, 2) = -0.11486898850122146e-15, (958, 1) = -1.9076651969849248, (958, 2) = 0.22980079318507823e-15, (959, 1) = -1.9067137106909549, (959, 2) = -0.1149318147804635e-15, (960, 1) = -1.9057622243969852, (960, 2) = 0.11496324306165295e-15, (961, 1) = -1.9048107381030153, (961, 2) = 0.11499468143274694e-15, (962, 1) = -1.9038592518090454, (962, 2) = 0.34507838967109812e-15, (963, 1) = -1.9029077655150755, (963, 2) = -0.11505758843111208e-15, (964, 1) = -1.9019562792211056, (964, 2) = -0.23017811410313567e-15, (965, 1) = -1.9010047929271359, (965, 2) = 0.11512053574829717e-15, (966, 1) = -1.900053306633166, (966, 2) = -0.3454560735535348e-15, (967, 1) = -1.899101820339196, (967, 2) = 0.11518352335673693e-15, (968, 1) = -1.8981503340452264, (968, 2) = 0.2304300645229598e-15, (969, 1) = -1.8971988477512565, (969, 2) = 0.11524655122856148e-15, (970, 1) = -1.8962473614572866, (970, 2) = -0.11527808025445007e-15, (971, 1) = -1.8952958751633167, (971, 2) = -0.2306192386711899e-15, (972, 1) = -1.8943443888693468, (972, 2) = 0.11534116846842616e-15, (973, 1) = -1.893392902575377, (973, 2) = 0.11537272764935434e-15, (974, 1) = -1.8924414162814072, (974, 2) = 0.461617187499084e-15, (975, 1) = -1.8914899299874373, (975, 2) = 0.23087175228209633e-15, (976, 1) = -1.8905384436934676, (976, 2) = -0.11546746544453847e-15, (977, 1) = -1.8895869573994977, (977, 2) = .0, (978, 1) = -1.8886354711055278, (978, 2) = 0.34659202244541606e-15, (979, 1) = -1.8876839848115579, (979, 2) = 0.2311245870830464e-15, (980, 1) = -1.886732498517588, (980, 2) = 0.34678176887101024e-15, (981, 1) = -1.8857810122236183, (981, 2) = 0.1156255623911677e-15, (982, 1) = -1.8848295259296484, (982, 2) = -0.3469716355207546e-15, (983, 1) = -1.8838992741614322, (983, 2) = 0.11568816464024824e-15, (984, 1) = -1.8829690223932163, (984, 2) = 0.11571912700597038e-15, (985, 1) = -1.8820387706250001, (985, 2) = 0.2315001978676903e-15, (986, 1) = -1.881108518856784, (986, 2) = 0.11578108042028178e-15, (987, 1) = -1.880178267088568, (987, 2) = .0, (988, 1) = -1.879248015320352, (988, 2) = -0.11584307205438634e-15, (989, 1) = -1.8783177635521358, (989, 2) = 0.11587408219478183e-15, (990, 1) = -1.8773875117839198, (990, 2) = -0.2318102037583883e-15, (991, 1) = -1.8736665047110554, (991, 2) = -0.2320585519662002e-15, (992, 1) = -1.869945497638191, (992, 2) = -0.23230720498685046e-15, (993, 1) = -1.8625034834924623, (993, 2) = -0.2328054235107654e-15, (994, 1) = -1.8550614693467338, (994, 2) = -0.23330485532267047e-15, (995, 1) = -1.8540875819566582, (995, 2) = 0.23337030223489247e-15, (996, 1) = -1.853113694566583, (996, 2) = 0.4668715396887413e-15, (997, 1) = -1.8521398071765076, (997, 2) = 0.11675062907076656e-15, (998, 1) = -1.8511659197864323, (998, 2) = 0.2335667671167618e-15, (999, 1) = -1.850192032396357, (999, 2) = -0.1168161483801961e-15, (1000, 1) = -1.8492181450062815, (1000, 2) = .0, (1001, 1) = -1.848244257616206, (1001, 2) = 0.1168817090069839e-15, (1002, 1) = -1.8472703702261306, (1002, 2) = 0.4676580192087024e-15, (1003, 1) = -1.8433748206658291, (1003, 2) = 0.3511373732391786e-15, (1004, 1) = -1.8394792711055277, (1004, 2) = 0.23435448414408477e-15, (1005, 1) = -1.8385053837154524, (1005, 2) = .0, (1006, 1) = -1.837531496325377, (1006, 2) = 0.11724302923490122e-15, (1007, 1) = -1.8365576089353017, (1007, 2) = .0, (1008, 1) = -1.8355837215452262, (1008, 2) = 0.3519265723622633e-15, (1009, 1) = -1.8346098341551507, (1009, 2) = 0.11734178694682448e-15, (1010, 1) = -1.8336359467650754, (1010, 2) = 0.2347494533760396e-15, (1011, 1) = -1.832662059375, (1011, 2) = 0.11740767667241593e-15, (1012, 1) = -1.8316881719849247, (1012, 2) = -0.23488127378946203e-15, (1013, 1) = -1.8277926224246233, (1013, 2) = -0.23514516011339296e-15, (1014, 1) = -1.8238970728643218, (1014, 2) = -0.23540937319302986e-15, (1015, 1) = -1.8163933184170855, (1015, 2) = -0.1179596143496049e-15, (1016, 1) = -1.8088895639698492, (1016, 2) = .0, (1017, 1) = -1.8079515946639448, (1017, 2) = 0.4729885116409428e-15, (1018, 1) = -1.8070136253580402, (1018, 2) = 0.11827912075501641e-15, (1019, 1) = -1.8060756560521356, (1019, 2) = -0.11831112295923665e-15, (1020, 1) = -1.8051376867462312, (1020, 2) = -0.11834313451757265e-15, (1021, 1) = -1.8041997174403268, (1021, 2) = 0.11837515542467873e-15, (1022, 1) = -1.8032617481344222, (1022, 2) = .0, (1023, 1) = -1.8023237788285176, (1023, 2) = -0.236878450527417e-15, (1024, 1) = -1.8013858095226132, (1024, 2) = -0.35541382255449233e-15, (1025, 1) = -1.8004478402167088, (1025, 2) = 0.23700666486624054e-15, (1026, 1) = -1.7995098709108042, (1026, 2) = -0.11853540000312102e-15, (1027, 1) = -1.7985719016048995, (1027, 2) = -0.2371349537787097e-15, (1028, 1) = -1.7976339322989952, (1028, 2) = 0.11859956308632143e-15, (1029, 1) = -1.7966959629930905, (1029, 2) = -0.2372633171769963e-15, (1030, 1) = -1.795757993687186, (1030, 2) = .0, (1031, 1) = -1.7948200243812815, (1031, 2) = 0.23739175497255965e-15, (1032, 1) = -1.793882055075377, (1032, 2) = .0, (1033, 1) = -1.7862083823618091, (1033, 2) = .0, (1034, 1) = -1.7785347096482411, (1034, 2) = .0, (1035, 1) = -1.777575500559045, (1035, 2) = -0.23857588597736536e-15, (1036, 1) = -1.7766162914698491, (1036, 2) = -0.2386419349687778e-15, (1037, 1) = -1.7756570823806532, (1037, 2) = 0.11935400157588248e-15, (1038, 1) = -1.7746978732914571, (1038, 2) = .0, (1039, 1) = -1.7737386642022612, (1039, 2) = 0.11942009852029875e-15, (1040, 1) = -1.7727794551130653, (1040, 2) = 0.2389063227203826e-15, (1041, 1) = -1.7718202460238692, (1041, 2) = -0.1194862337698107e-15, (1042, 1) = -1.7708610369346733, (1042, 2) = -0.1195193157425779e-15, (1043, 1) = -1.7699018278454774, (1043, 2) = .0, (1044, 1) = -1.7689426187562813, (1044, 2) = -0.3587565250533334e-15, (1045, 1) = -1.7679834096670854, (1045, 2) = 0.11961861897359046e-15, (1046, 1) = -1.7670242005778896, (1046, 2) = 0.35895521739793253e-15, (1047, 1) = -1.7660649914886934, (1047, 2) = 0.11968486882156434e-15, (1048, 1) = -1.7651057823994976, (1048, 2) = .0, (1049, 1) = -1.7641465733103017, (1049, 2) = -0.11975115676204282e-15, (1050, 1) = -1.7631873642211056, (1050, 2) = 0.1197843150000556e-15, (1051, 1) = -1.7555772333919597, (1051, 2) = .0, (1052, 1) = -1.747967102562814, (1052, 2) = -0.1203117208288999e-15, (1053, 1) = -1.747015836209171, (1053, 2) = 0.1203447624975164e-15, (1054, 1) = -1.7460645698555277, (1054, 2) = -0.12037781339533178e-15, (1055, 1) = -1.7451133035018844, (1055, 2) = -0.24082174703048046e-15, (1056, 1) = -1.7441620371482411, (1056, 2) = 0.2408878857002195e-15, (1057, 1) = -1.7422595044409548, (1057, 2) = 0.1205101091360732e-15, (1058, 1) = -1.7403569717336684, (1058, 2) = .0, (1059, 1) = -1.7394057053800251, (1059, 2) = 0.12060942749742065e-15, (1060, 1) = -1.7384544390263819, (1060, 2) = -0.24128510394163445e-15, (1061, 1) = -1.7375031726727386, (1061, 2) = -0.2413513712170323e-15, (1062, 1) = -1.7365519063190955, (1062, 2) = .0, (1063, 1) = -1.7356006399654524, (1063, 2) = 0.2414839606948491e-15, (1064, 1) = -1.7346493736118092, (1064, 2) = .0, (1065, 1) = -1.7336981072581659, (1065, 2) = 0.12080831165508722e-15, (1066, 1) = -1.7327468409045226, (1066, 2) = -0.24168298200725827e-15, (1067, 1) = -1.7318727259202262, (1067, 2) = -0.24174397483920903e-15, (1068, 1) = -1.7309986109359297, (1068, 2) = -0.2418049830605751e-15, (1069, 1) = -1.730124495951633, (1069, 2) = .0, (1070, 1) = -1.7292503809673367, (1070, 2) = .0, (1071, 1) = -1.7283762659830402, (1071, 2) = -0.12099404997209398e-15, (1072, 1) = -1.7275021509987436, (1072, 2) = .0, (1073, 1) = -1.7266280360144473, (1073, 2) = -0.4842205091970862e-15, (1074, 1) = -1.7257539210301507, (1074, 2) = -0.12108567745490408e-15, (1075, 1) = -1.7248798060458541, (1075, 2) = .0, (1076, 1) = -1.7240056910615578, (1076, 2) = 0.24229360144096615e-15, (1077, 1) = -1.7231315760772612, (1077, 2) = 0.2423547476369245e-15, (1078, 1) = -1.7222574610929646, (1078, 2) = .0, (1079, 1) = -1.7213833461086683, (1079, 2) = 0.12123854291473592e-15, (1080, 1) = -1.7205092311243717, (1080, 2) = -0.2425382778018931e-15, (1081, 1) = -1.7196351161400751, (1081, 2) = .0, (1082, 1) = -1.7187610011557788, (1082, 2) = 0.242660707438319e-15, (1083, 1) = -1.7117680812814071, (1083, 2) = 0.2431510334055877e-15, (1084, 1) = -1.7047751614070352, (1084, 2) = 0.2436423264639009e-15, (1085, 1) = -1.7027714925753767, (1085, 2) = 0.12189163656150302e-15, (1086, 1) = -1.7007678237437185, (1086, 2) = .0, (1087, 1) = -1.6997659893278894, (1087, 2) = .0, (1088, 1) = -1.6987641549120602, (1088, 2) = .0, (1089, 1) = -1.697762320496231, (1089, 2) = 0.2441359837731839e-15, (1090, 1) = -1.696760486080402, (1090, 2) = -0.1221032923588109e-15, (1091, 1) = -1.6927531484170855, (1091, 2) = -0.2444891838803665e-15, (1092, 1) = -1.688745810753769, (1092, 2) = -0.3671581420387618e-15, (1093, 1) = -1.6847384730904524, (1093, 2) = -0.24505531585048567e-15, (1094, 1) = -1.6807311354271357, (1094, 2) = -0.12266942301622437e-15, (1095, 1) = -1.676723797763819, (1095, 2) = .0, (1096, 1) = -1.6727164601005025, (1096, 2) = 0.12295341404433523e-15, (1097, 1) = -1.67182040745603, (1097, 2) = -0.1229852026713176e-15, (1098, 1) = -1.6709243548115578, (1098, 2) = .0, (1099, 1) = -1.6700283021670854, (1099, 2) = 0.1230488027645834e-15, (1100, 1) = -1.669132249522613, (1100, 2) = .0, (1101, 1) = -1.6682361968781407, (1101, 2) = 0.12311243325821272e-15, (1102, 1) = -1.6673401442336684, (1102, 2) = 0.12314425988556085e-15, (1103, 1) = -1.666444091589196, (1103, 2) = 0.246352188178858e-15, (1104, 1) = -1.6655480389447237, (1104, 2) = .0, (1105, 1) = -1.6619638283668343, (1105, 2) = -0.1233353784790137e-15, (1106, 1) = -1.6583796177889447, (1106, 2) = -0.18519441233283416e-15, (1107, 1) = -1.6574835651444721, (1107, 2) = .0, (1108, 1) = -1.6565875124999998, (1108, 2) = .0, (1109, 1) = -1.6556914598555275, (1109, 2) = .0, (1110, 1) = -1.6547954072110551, (1110, 2) = 0.24718124914609064e-15, (1111, 1) = -1.6538993545665828, (1111, 2) = 0.12362256400714662e-15, (1112, 1) = -1.6530033019221104, (1112, 2) = -0.24730902179331355e-15, (1113, 1) = -1.652107249277638, (1113, 2) = -0.6184323261665423e-16, (1114, 1) = -1.6512111966331657, (1114, 2) = -0.12371842700881007e-15, (1115, 1) = -1.6503151439886934, (1115, 2) = -0.12375039621484556e-15, (1116, 1) = -1.649419091344221, (1116, 2) = 0.1237823728430745e-15, (1117, 1) = -1.6485230386997487, (1117, 2) = -0.1857215353276979e-15, (1118, 1) = -1.6476269860552764, (1118, 2) = -0.1857695224989426e-15, (1119, 1) = -1.646730933410804, (1119, 2) = .0, (1120, 1) = -1.6458348807663317, (1120, 2) = 0.1239103534102578e-15, (1121, 1) = -1.6449388281218593, (1121, 2) = -0.2478847340469778e-15, (1122, 1) = -1.644042775477387, (1122, 2) = 0.18596158201253297e-15, (1123, 1) = -1.6430873964667085, (1123, 2) = 0.12400853716721657e-15, (1124, 1) = -1.64213201745603, (1124, 2) = -0.12404269468613184e-15, (1125, 1) = -1.6411766384453519, (1125, 2) = -0.4342690119415209e-15, (1126, 1) = -1.6402212594346735, (1126, 2) = 0.18616655214385327e-15, (1127, 1) = -1.639265880423995, (1127, 2) = -0.37243565189769764e-15, (1128, 1) = -1.6383105014133168, (1128, 2) = -0.12417940815423409e-15, (1129, 1) = -1.6373551224026384, (1129, 2) = -0.24842721463412787e-15, (1130, 1) = -1.63639974339196, (1130, 2) = .0, (1131, 1) = -1.6354443643812815, (1131, 2) = -0.18642304578601346e-15, (1132, 1) = -1.634488985370603, (1132, 2) = .0, (1133, 1) = -1.6335336063599246, (1133, 2) = 0.6217524341767231e-16, (1134, 1) = -1.6325782273492462, (1134, 2) = -0.12438472737854106e-15, (1135, 1) = -1.6316228483385677, (1135, 2) = 0.18662846424874288e-15, (1136, 1) = -1.6306674693278893, (1136, 2) = -0.1866798497797059e-15, (1137, 1) = -1.629712090317211, (1137, 2) = -0.24897499685939526e-15, (1138, 1) = -1.6287567113065327, (1138, 2) = -0.6226088594235382e-16, (1139, 1) = -1.6278013322958542, (1139, 2) = -0.24911210708133153e-15, (1140, 1) = -1.626845953285176, (1140, 2) = -0.31147585846676076e-15, (1141, 1) = -1.6258905742744976, (1141, 2) = -0.24924928282384534e-15, (1142, 1) = -1.6249351952638191, (1142, 2) = -0.18698842140808107e-15, (1143, 1) = -1.6239798162531407, (1143, 2) = -0.12469326195613192e-15, (1144, 1) = -1.6230244372424623, (1144, 2) = .0, (1145, 1) = -1.6220690582317838, (1145, 2) = 0.6238095754271466e-16, (1146, 1) = -1.6211136792211054, (1146, 2) = -0.12479625384188377e-15, (1147, 1) = -1.620158300210427, (1147, 2) = 0.6241530035571057e-16, (1148, 1) = -1.6192029211997485, (1148, 2) = -0.1248649556829092e-15, (1149, 1) = -1.6182475421890703, (1149, 2) = -0.31224829686295607e-15, (1150, 1) = -1.6172921631783919, (1150, 2) = .0, (1151, 1) = -1.6153814051570352, (1151, 2) = .0, (1152, 1) = -1.6134706471356783, (1152, 2) = .0, (1153, 1) = -1.606155290201005, (1153, 2) = 0.6266747362171195e-16, (1154, 1) = -1.5988399332663317, (1154, 2) = 0.1883986570155935e-15, (1155, 1) = -1.5970110940326634, (1155, 2) = 0.1256652161085474e-15, (1156, 1) = -1.5951822547989951, (1156, 2) = .0, (1157, 1) = -1.5933534155653266, (1157, 2) = .0, (1158, 1) = -1.5915245763316583, (1158, 2) = .0, (1159, 1) = -1.590610156714824, (1159, 2) = 0.18884524692251065e-15, (1160, 1) = -1.58969573709799, (1160, 2) = -0.6296497380722231e-16, (1161, 1) = -1.5887813174811558, (1161, 2) = -0.12596307102792318e-15, (1162, 1) = -1.5878668978643216, (1162, 2) = 0.25199240302272797e-15, (1163, 1) = -1.5869524782474875, (1163, 2) = 0.2520586781079843e-15, (1164, 1) = -1.5860380586306533, (1164, 2) = -0.25212496729000674e-15, (1165, 1) = -1.585123639013819, (1165, 2) = .0, (1166, 1) = -1.584209219396985, (1166, 2) = 0.6306439696440484e-16, (1167, 1) = -1.5801478375251257, (1167, 2) = .0, (1168, 1) = -1.5760864556532663, (1168, 2) = -0.632118240120027e-16, (1169, 1) = -1.5750711101853014, (1169, 2) = 0.3793816299785946e-15, (1170, 1) = -1.5740557647173365, (1170, 2) = -0.1897461707131557e-15, (1171, 1) = -1.5730404192493719, (1171, 2) = 0.12653435945635753e-15, (1172, 1) = -1.572025073781407, (1172, 2) = 0.6328564012677454e-16, (1173, 1) = -1.5699943828454774, (1173, 2) = 0.6332257361743712e-16, (1174, 1) = -1.5679636919095477, (1174, 2) = 0.6335952398093842e-16, (1175, 1) = -1.5659330009736179, (1175, 2) = .0, (1176, 1) = -1.5639023100376883, (1176, 2) = -0.6343347507620617e-16, (1177, 1) = -1.5628869645697234, (1177, 2) = 0.19035591989246738e-15, (1178, 1) = -1.5618716191017588, (1178, 2) = 0.6347047568192068e-16, (1179, 1) = -1.5608562736337939, (1179, 2) = .0, (1180, 1) = -1.559840928165829, (1180, 2) = 0.38104495745020525e-15, (1181, 1) = -1.5588255826978643, (1181, 2) = -0.1905780232031802e-15, (1182, 1) = -1.5578102372298994, (1182, 2) = -0.19063358007476676e-15, (1183, 1) = -1.5567948917619345, (1183, 2) = 0.38137829863140453e-15, (1184, 1) = -1.5557795462939699, (1184, 2) = 0.12716315393450422e-15, (1185, 1) = -1.55374885535804, (1185, 2) = 0.6361864367064832e-16, (1186, 1) = -1.5517181644221105, (1186, 2) = -0.636557267366915e-16, (1187, 1) = -1.5508389498523871, (1187, 2) = .0, (1188, 1) = -1.5499597352826635, (1188, 2) = -0.19106355334679608e-15, (1189, 1) = -1.54908052071294, (1189, 2) = -0.25481567149697545e-15, (1190, 1) = -1.5482013061432163, (1190, 2) = 0.25487995068748737e-15, (1191, 1) = -1.5473220915734927, (1191, 2) = 0.12747212100621446e-15, (1192, 1) = -1.546442877003769, (1192, 2) = -0.19125640908768343e-15, (1193, 1) = -1.5455636624340454, (1193, 2) = -0.19130464573449414e-15, (1194, 1) = -1.5446844478643218, (1194, 2) = -0.19135289143350654e-15, (1195, 1) = -1.5438052332945982, (1195, 2) = -0.12760076411228874e-15, (1196, 1) = -1.5429260187248746, (1196, 2) = 0.1276329399486306e-15, (1197, 1) = -1.542046804155151, (1197, 2) = 0.12766512178711754e-15, (1198, 1) = -1.5411675895854273, (1198, 2) = 0.6384865480840514e-16, (1199, 1) = -1.53940916044598, (1199, 2) = -0.6388085160295997e-16, (1200, 1) = -1.5376507313065328, (1200, 2) = -0.19173918094185346e-15, (1201, 1) = -1.5367715167368092, (1201, 2) = -0.6392916912429196e-16, (1202, 1) = -1.5358923021670856, (1202, 2) = -0.6394528089713252e-16, (1203, 1) = -1.535013087597362, (1203, 2) = 0.1918841868807239e-15, (1204, 1) = -1.5341338730276384, (1204, 2) = 0.2559100532321593e-15, (1205, 1) = -1.5332546584579148, (1205, 2) = .0, (1206, 1) = -1.5323754438881911, (1206, 2) = -0.32004878750995085e-15, (1207, 1) = -1.5314962293184675, (1207, 2) = -0.6402588400358314e-16, (1208, 1) = -1.530617014748744, (1208, 2) = .0, (1209, 1) = -1.5297378001790203, (1209, 2) = 0.1921744373635135e-15, (1210, 1) = -1.5288585856092967, (1210, 2) = 0.3844456863551492e-15, (1211, 1) = -1.527979371039573, (1211, 2) = 0.1281808384849356e-15, (1212, 1) = -1.5271001564698494, (1212, 2) = 0.25642624132791263e-15, (1213, 1) = -1.5262209419001258, (1213, 2) = -0.1282454086440405e-15, (1214, 1) = -1.5253417273304022, (1214, 2) = 0.32069425603438964e-15, (1215, 1) = -1.5244625127606786, (1215, 2) = .0, (1216, 1) = -1.523583298190955, (1216, 2) = .0, (1217, 1) = -1.522585381790201, (1217, 2) = -0.6418949053484519e-16, (1218, 1) = -1.5215874653894474, (1218, 2) = -0.6420783113017716e-16, (1219, 1) = -1.5205895489886938, (1219, 2) = -0.25690470166255205e-15, (1220, 1) = -1.51959163258794, (1220, 2) = 0.19273357014822226e-15, (1221, 1) = -1.518593716187186, (1221, 2) = -0.12852575004595045e-15, (1222, 1) = -1.5175957997864322, (1222, 2) = 0.25712492131123205e-15, (1223, 1) = -1.5165978833856784, (1223, 2) = 0.12859917857736485e-15, (1224, 1) = -1.5155999669849247, (1224, 2) = -0.19295385569105542e-15, (1225, 1) = -1.514602050584171, (1225, 2) = -0.38601790886527693e-15, (1226, 1) = -1.5136041341834172, (1226, 2) = -0.19306406406491626e-15, (1227, 1) = -1.5126062177826634, (1227, 2) = -0.2574922460825847e-15, (1228, 1) = -1.5116083013819095, (1228, 2) = -0.32195719316280756e-15, (1229, 1) = -1.5106103849811556, (1229, 2) = 0.19322945804606314e-15, (1230, 1) = -1.509612468580402, (1230, 2) = 0.6442820366030422e-16, (1231, 1) = -1.5086145521796483, (1231, 2) = 0.19333977467600087e-15, (1232, 1) = -1.5076166357788945, (1232, 2) = .0, (1233, 1) = -1.5036249701758795, (1233, 2) = .0, (1234, 1) = -1.4996333045728645, (1234, 2) = .0, (1235, 1) = -1.4986353881721106, (1235, 2) = -0.3231533293636525e-15, (1236, 1) = -1.497637471771357, (1236, 2) = 0.193947277924268e-15, (1237, 1) = -1.4966395553706033, (1237, 2) = .0, (1238, 1) = -1.4956416389698495, (1238, 2) = -0.2587438264386308e-15, (1239, 1) = -1.4946437225690956, (1239, 2) = -0.647043937910699e-16, (1240, 1) = -1.4936458061683417, (1240, 2) = 0.647228344252181e-16, (1241, 1) = -1.4926478897675879, (1241, 2) = .0, (1242, 1) = -1.4916499733668342, (1242, 2) = 0.6475972601519632e-16, (1243, 1) = -1.490740480901382, (1243, 2) = 0.32388270951813847e-15, (1244, 1) = -1.4898309884359295, (1244, 2) = 0.32396680315129076e-15, (1245, 1) = -1.4889214959704773, (1245, 2) = 0.19443054656432598e-15, (1246, 1) = -1.488012003505025, (1246, 2) = 0.12965401314036683e-15, (1247, 1) = -1.4871025110395728, (1247, 2) = 0.19453150130840953e-15, (1248, 1) = -1.4861930185741206, (1248, 2) = -0.25944265511575454e-15, (1249, 1) = -1.4852835261086683, (1249, 2) = 0.3243874829577184e-15, (1250, 1) = -1.484374033643216, (1250, 2) = -0.12978866440044395e-15, (1251, 1) = -1.4834645411777638, (1251, 2) = -0.19473351179368133e-15, (1252, 1) = -1.4825550487123116, (1252, 2) = -0.38956807066477426e-15, (1253, 1) = -1.4816455562468593, (1253, 2) = 0.38966913439088567e-15, (1254, 1) = -1.480736063781407, (1254, 2) = 0.6496170245381901e-16, (1255, 1) = -1.4798265713159549, (1255, 2) = -0.2599142077453168e-15, (1256, 1) = -1.4789170788505026, (1256, 2) = 0.6499540417218052e-16, (1257, 1) = -1.4780075863850504, (1257, 2) = -0.6501225915419168e-16, (1258, 1) = -1.4770980939195981, (1258, 2) = -0.6502911687516436e-16, (1259, 1) = -1.4761886014541459, (1259, 2) = -0.3902758639672999e-15, (1260, 1) = -1.4752791089886936, (1260, 2) = -0.4554398835358131e-15, (1261, 1) = -1.4743696165232414, (1261, 2) = 0.2603188255984541e-15, (1262, 1) = -1.4734601240577891, (1262, 2) = -0.1301931500082179e-15, (1263, 1) = -1.4716411391268847, (1263, 2) = -0.6513032031394257e-16, (1264, 1) = -1.46982215419598, (1264, 2) = 0.6516407637614293e-16, (1265, 1) = -1.4689126617305277, (1265, 2) = -0.26072383368412965e-15, (1266, 1) = -1.4680031692650752, (1266, 2) = -0.2607913725278454e-15, (1267, 1) = -1.467093676799623, (1267, 2) = 0.6521473050154311e-16, (1268, 1) = -1.4661841843341707, (1268, 2) = -0.3261581026118693e-15, (1269, 1) = -1.4652746918687185, (1269, 2) = -0.26099405274812997e-15, (1270, 1) = -1.4643651994032663, (1270, 2) = 0.19579622546424182e-15, (1271, 1) = -1.463455706937814, (1271, 2) = -0.1305646128361249e-15, (1272, 1) = -1.4625462144723618, (1272, 2) = 0.3264960348475251e-15, (1273, 1) = -1.461551372647613, (1273, 2) = -0.13063539301984078e-15, (1274, 1) = -1.4605565308228643, (1274, 2) = .0, (1275, 1) = -1.4595616889981156, (1275, 2) = 0.6535468493420199e-16, (1276, 1) = -1.4585668471733668, (1276, 2) = 0.2614927351933575e-15, (1277, 1) = -1.457572005348618, (1277, 2) = -0.32695842875306815e-15, (1278, 1) = -1.4565771635238693, (1278, 2) = .0, (1279, 1) = -1.4555823216991206, (1279, 2) = .0, (1280, 1) = -1.4545874798743719, (1280, 2) = 0.6544721003686383e-16, (1281, 1) = -1.4535926380496231, (1281, 2) = -0.19639717272649923e-15, (1282, 1) = -1.4525977962248744, (1282, 2) = -0.3929054489143248e-15, (1283, 1) = -1.4516029544001257, (1283, 2) = 0.13100552351494923e-15, (1284, 1) = -1.450608112575377, (1284, 2) = -0.2620851401894011e-15, (1285, 1) = -1.4496132707506282, (1285, 2) = .0, (1286, 1) = -1.4486184289258794, (1286, 2) = 0.19667502192309153e-15, (1287, 1) = -1.4476235871011307, (1287, 2) = 0.6557687292455359e-16, (1288, 1) = -1.446628745276382, (1288, 2) = -0.26238163274254173e-15, (1289, 1) = -1.4456339034516332, (1289, 2) = 0.19684183924221585e-15, (1290, 1) = -1.4446390616268845, (1290, 2) = -0.19689746279890087e-15, (1291, 1) = -1.4436442198021358, (1291, 2) = -0.13130206346413106e-15, (1292, 1) = -1.442649377977387, (1292, 2) = -0.3283478940054364e-15, (1293, 1) = -1.4416545361526383, (1293, 2) = 0.13137625759278588e-15, (1294, 1) = -1.4406596943278895, (1294, 2) = -0.13141336341530218e-15, (1295, 1) = -1.4396648525031408, (1295, 2) = 0.1971757125735142e-15, (1296, 1) = -1.438670010678392, (1296, 2) = -0.6574379623657129e-16, (1297, 1) = -1.4376751688536433, (1297, 2) = 0.6576235783344253e-16, (1298, 1) = -1.4366803270288946, (1298, 2) = .0, (1299, 1) = -1.4356854852041459, (1299, 2) = 0.13159897927967557e-15, (1300, 1) = -1.4346906433793971, (1300, 2) = 0.19745417948525078e-15, (1301, 1) = -1.4327009597298996, (1301, 2) = 0.13171041744756575e-15, (1302, 1) = -1.430711276080402, (1302, 2) = 0.6589236890638412e-16, (1303, 1) = -1.4298528958322865, (1303, 2) = -0.1977252115405529e-15, (1304, 1) = -1.4289945155841708, (1304, 2) = 0.6592444086547626e-16, (1305, 1) = -1.4281361353360553, (1305, 2) = -0.19782143986623553e-15, (1306, 1) = -1.4272777550879399, (1306, 2) = -0.6595652110979516e-16, (1307, 1) = -1.4264193748398242, (1307, 2) = 0.13194512864349855e-15, (1308, 1) = -1.4255609945917087, (1308, 2) = -0.26395443833753103e-15, (1309, 1) = -1.4247026143435932, (1309, 2) = 0.264018627563159e-15, (1310, 1) = -1.4238442340954776, (1310, 2) = 0.13204141246809996e-15, (1311, 1) = -1.4229858538473619, (1311, 2) = .0, (1312, 1) = -1.4221274735992464, (1312, 2) = 0.6605281100337651e-16, (1313, 1) = -1.421269093351131, (1313, 2) = -0.1321377328310595e-15, (1314, 1) = -1.4204107131030153, (1314, 2) = -0.13216984767342019e-15, (1315, 1) = -1.4195523328548996, (1315, 2) = 0.661009832599247e-16, (1316, 1) = -1.418693952606784, (1316, 2) = 0.6611704467816617e-16, (1317, 1) = -1.4178355723586686, (1317, 2) = 0.13226621616882505e-15, (1318, 1) = -1.416977192110553, (1318, 2) = .0, (1319, 1) = -1.4161188118624373, (1319, 2) = .0, (1320, 1) = -1.4152604316143218, (1320, 2) = -0.6618131016074265e-16, (1321, 1) = -1.4144020513662063, (1321, 2) = -0.6619738144849714e-16, (1322, 1) = -1.4135436711180906, (1322, 2) = -0.26485381875571077e-15, (1323, 1) = -1.412685290869975, (1323, 2) = -0.331147649374623e-15, (1324, 1) = -1.4118269106218595, (1324, 2) = -0.662456069993635e-16, (1325, 1) = -1.410968530373744, (1325, 2) = -0.13252337211021065e-15, (1326, 1) = -1.4101101501256283, (1326, 2) = -0.6627776703499632e-16, (1327, 1) = -1.4092517698775127, (1327, 2) = 0.66293849931868e-16, (1328, 1) = -1.4083933896293972, (1328, 2) = 0.6630993473853714e-16, (1329, 1) = -1.4075350093812817, (1329, 2) = -0.13265204289561155e-15, (1330, 1) = -1.406676629133166, (1330, 2) = -0.1326842201049223e-15, (1331, 1) = -1.4058182488850504, (1331, 2) = 0.13271640109055146e-15, (1332, 1) = -1.404959868636935, (1332, 2) = 0.13274858583801445e-15, (1333, 1) = -1.4041014883888194, (1333, 2) = .0, (1334, 1) = -1.4032431081407037, (1334, 2) = .0, (1335, 1) = -1.4022655132349249, (1335, 2) = -0.6642481713882445e-16, (1336, 1) = -1.401287918329146, (1336, 2) = -0.1993294601941194e-15, (1337, 1) = -1.4003103234233671, (1337, 2) = -0.6646149204701111e-16, (1338, 1) = -1.3993327285175883, (1338, 2) = -0.19943949922470236e-15, (1339, 1) = -1.3983551336118094, (1339, 2) = -0.19949452941253855e-15, (1340, 1) = -1.3973775387060305, (1340, 2) = 0.2660660888958381e-15, (1341, 1) = -1.3963999438002515, (1341, 2) = 0.19960461096998368e-15, (1342, 1) = -1.3954223488944726, (1342, 2) = 0.6655322075801319e-16, (1343, 1) = -1.3944447539886937, (1343, 2) = .0, (1344, 1) = -1.3934671590829146, (1344, 2) = -0.13317985717891256e-15, (1345, 1) = -1.3924895641771358, (1345, 2) = 0.13321657192842358e-15, (1346, 1) = -1.391511969271357, (1346, 2) = -0.2665065825211186e-15, (1347, 1) = -1.390534374365578, (1347, 2) = .0, (1348, 1) = -1.3895567794597992, (1348, 2) = -0.6666337179206961e-16, (1349, 1) = -1.3885791845540203, (1349, 2) = 0.13336347653117387e-15, (1350, 1) = -1.3876015896482414, (1350, 2) = -0.133400213972014e-15, (1351, 1) = -1.3866239947424626, (1351, 2) = 0.13343695588432778e-15, (1352, 1) = -1.3856463998366837, (1352, 2) = 0.20021055336859892e-15, (1353, 1) = -1.3846688049309046, (1353, 2) = 0.6675522651689735e-16, (1354, 1) = -1.3836912100251257, (1354, 2) = -0.6677360411301472e-16, (1355, 1) = -1.3827136151193469, (1355, 2) = -0.20037595169985153e-15, (1356, 1) = -1.3817360202135678, (1356, 2) = -0.33405182933205638e-15, (1357, 1) = -1.380758425307789, (1357, 2) = -0.6682875000107795e-16, (1358, 1) = -1.37978083040201, (1358, 2) = -0.2673885451704234e-15, (1359, 1) = -1.3778256405904523, (1359, 2) = -0.1337678306014768e-15, (1360, 1) = -1.3758704507788946, (1360, 2) = -0.6692070279953791e-16, (1361, 1) = -1.3748928558731157, (1361, 2) = 0.1338781994086061e-15, (1362, 1) = -1.3739152609673368, (1362, 2) = -0.26782999478928663e-15, (1363, 1) = -1.3729376660615578, (1363, 2) = 0.6697589976706892e-16, (1364, 1) = -1.371960071155779, (1364, 2) = -0.1339886058039883e-15, (1365, 1) = -1.3710157627386934, (1365, 2) = 0.6701208137183715e-16, (1366, 1) = -1.3700714543216082, (1366, 2) = -0.33514930873679063e-15, (1367, 1) = -1.3691271459045227, (1367, 2) = -0.26819057607231063e-15, (1368, 1) = -1.3681828374874372, (1368, 2) = 0.6706542817349381e-16, (1369, 1) = -1.3672385290703517, (1369, 2) = 0.13416642840616398e-15, (1370, 1) = -1.3662942206532662, (1370, 2) = -0.20130300628888484e-15, (1371, 1) = -1.365349912236181, (1371, 2) = .0, (1372, 1) = -1.3644056038190955, (1372, 2) = -0.6713658343129289e-16, (1373, 1) = -1.3625169869849247, (1373, 2) = .0, (1374, 1) = -1.3606283701507538, (1374, 2) = 0.6720776799818873e-16, (1375, 1) = -1.3596840617336683, (1375, 2) = -0.6722556863954547e-16, (1376, 1) = -1.3587397533165828, (1376, 2) = 0.3362168552966555e-15, (1377, 1) = -1.3577954448994976, (1377, 2) = 0.13452235049358705e-15, (1378, 1) = -1.356851136482412, (1378, 2) = -0.1345579623823156e-15, (1379, 1) = -1.3559068280653266, (1379, 2) = -0.6729678888162605e-16, (1380, 1) = -1.3549625196482413, (1380, 2) = 0.3365729915368876e-15, (1381, 1) = -1.3540182112311558, (1381, 2) = .0, (1382, 1) = -1.3530739028140704, (1382, 2) = 0.5388017785706576e-15, (1383, 1) = -1.3521295943969849, (1383, 2) = -0.6736803688777905e-16, (1384, 1) = -1.3511852859798994, (1384, 2) = 0.13477170629199265e-15, (1385, 1) = -1.3502409775628141, (1385, 2) = .0, (1386, 1) = -1.3492966691457287, (1386, 2) = -0.2696859627759048e-15, (1387, 1) = -1.3483523607286432, (1387, 2) = -0.6743931196179816e-16, (1388, 1) = -1.347408052311558, (1388, 2) = .0, (1389, 1) = -1.3464637438944724, (1389, 2) = 0.20242487829024386e-15, (1390, 1) = -1.345519435477387, (1390, 2) = 0.33746392804231574e-15, (1391, 1) = -1.343630818643216, (1391, 2) = 0.2025853283950062e-15, (1392, 1) = -1.3417422018090452, (1392, 2) = 0.13512821271650467e-15, (1393, 1) = -1.3407985102858042, (1393, 2) = -0.27032771539192e-15, (1394, 1) = -1.339854818762563, (1394, 2) = 0.20279925868408135e-15, (1395, 1) = -1.3389111272393217, (1395, 2) = -0.6761757848720178e-16, (1396, 1) = -1.3379674357160805, (1396, 2) = 0.40581243368573307e-15, (1397, 1) = -1.3370237441928392, (1397, 2) = 0.33826617132358255e-15, (1398, 1) = -1.336080052669598, (1398, 2) = 0.6767106442722301e-16, (1399, 1) = -1.3351363611463567, (1399, 2) = -0.13537779218104665e-15, (1400, 1) = -1.3341926696231154, (1400, 2) = -0.20312018772992697e-15, (1401, 1) = -1.3304179035301507, (1401, 2) = -0.6777807652231818e-16, (1402, 1) = -1.3266431374371859, (1402, 2) = .0, (1403, 1) = -1.3256994459139446, (1403, 2) = -0.6786729276774424e-16, (1404, 1) = -1.3247557543907034, (1404, 2) = -0.1357702803765349e-15, (1405, 1) = -1.3238120628674621, (1405, 2) = -0.20370896691700808e-15, (1406, 1) = -1.322868371344221, (1406, 2) = 0.203762517325079e-15, (1407, 1) = -1.32192467982098, (1407, 2) = 0.679386905847244e-16, (1408, 1) = -1.3209809882977388, (1408, 2) = .0, (1409, 1) = -1.3200372967744975, (1409, 2) = .0, (1410, 1) = -1.3190936052512563, (1410, 2) = .0, (1411, 1) = -1.318149913728015, (1411, 2) = 0.34005054830243826e-15, (1412, 1) = -1.3172062222047738, (1412, 2) = .0, (1413, 1) = -1.3162625306815325, (1413, 2) = -0.13609165387342669e-15, (1414, 1) = -1.3153188391582915, (1414, 2) = -0.1361273749365728e-15, (1415, 1) = -1.3143751476350505, (1415, 2) = -0.6808154924643594e-16, (1416, 1) = -1.3134314561118092, (1416, 2) = .0, (1417, 1) = -1.312487764588568, (1417, 2) = 0.6811727649513037e-16, (1418, 1) = -1.3115440730653267, (1418, 2) = 0.34067570970974324e-15, (1419, 1) = -1.3106038532129398, (1419, 2) = 0.3407647142877007e-15, (1420, 1) = -1.309663633360553, (1420, 2) = -0.681707449516565e-16, (1421, 1) = -1.308723413508166, (1421, 2) = -0.6818854821248227e-16, (1422, 1) = -1.307783193655779, (1422, 2) = 0.6820635262817842e-16, (1423, 1) = -1.3068429738033922, (1423, 2) = -0.13644831637376467e-15, (1424, 1) = -1.3059027539510053, (1424, 2) = 0.1364839297534155e-15, (1425, 1) = -1.3049625340986184, (1425, 2) = 0.20477931805723426e-15, (1426, 1) = -1.3040223142462313, (1426, 2) = .0, (1427, 1) = -1.3030820943938441, (1427, 2) = .0, (1428, 1) = -1.3021418745414572, (1428, 2) = .0, (1429, 1) = -1.3012016546890703, (1429, 2) = 0.13666202974996318e-15, (1430, 1) = -1.3002614348366834, (1430, 2) = 0.13669765620119752e-15, (1431, 1) = -1.2993212149842965, (1431, 2) = 0.27346656949388135e-15, (1432, 1) = -1.2983809951319096, (1432, 2) = .0, (1433, 1) = -1.2974407752795227, (1433, 2) = -0.6840227401264883e-16, (1434, 1) = -1.2965005554271358, (1434, 2) = 0.6842009135473232e-16, (1435, 1) = -1.295560335574749, (1435, 2) = 0.6843790969562326e-16, (1436, 1) = -1.294620115722362, (1436, 2) = .0, (1437, 1) = -1.2936798958699751, (1437, 2) = 0.684735493251183e-16, (1438, 1) = -1.292739676017588, (1438, 2) = -0.2739654823572322e-15, (1439, 1) = -1.2917994561652009, (1439, 2) = 0.13701838560695306e-15, (1440, 1) = -1.290859236312814, (1440, 2) = .0, (1441, 1) = -1.289919016460427, (1441, 2) = 0.6854484003265776e-16, (1442, 1) = -1.2889787966080402, (1442, 2) = .0, (1443, 1) = -1.2852179171984925, (1443, 2) = .0, (1444, 1) = -1.2814570377889447, (1444, 2) = .0, (1445, 1) = -1.280553780857412, (1445, 2) = -0.13744485582317373e-15, (1446, 1) = -1.2796505239258793, (1446, 2) = 0.1374791204381242e-15, (1447, 1) = -1.2787472669943467, (1447, 2) = 0.3437834662184316e-15, (1448, 1) = -1.2778440100628141, (1448, 2) = -0.6877382697428641e-16, (1449, 1) = -1.2769407531312815, (1449, 2) = 0.3439548069983428e-15, (1450, 1) = -1.2760374961997487, (1450, 2) = -0.1376161930172368e-15, (1451, 1) = -1.275134239268216, (1451, 2) = 0.20647569686970244e-15, (1452, 1) = -1.2742309823366833, (1452, 2) = 0.13768473746452015e-15, (1453, 1) = -1.2733277254051507, (1453, 2) = -0.20657851747325928e-15, (1454, 1) = -1.2724244684736181, (1454, 2) = .0, (1455, 1) = -1.2715212115420855, (1455, 2) = 0.13778756382586245e-15, (1456, 1) = -1.2706179546105527, (1456, 2) = -0.6891092088662661e-16, (1457, 1) = -1.26971469767902, (1457, 2) = 0.13785612092961915e-15, (1458, 1) = -1.2688114407474873, (1458, 2) = 0.6894520063610007e-16, (1459, 1) = -1.2679081838159547, (1459, 2) = 0.6896234138909726e-16, (1460, 1) = -1.2670049268844221, (1460, 2) = -0.6897948271237953e-16, (1461, 1) = -1.2661016699528895, (1461, 2) = -0.1379932491890089e-15, (1462, 1) = -1.265198413021357, (1462, 2) = .0, (1463, 1) = -1.2642951560898243, (1463, 2) = -0.6903090998940851e-16, (1464, 1) = -1.2633918991582915, (1464, 2) = 0.1380961069583974e-15, (1465, 1) = -1.2615853852952261, (1465, 2) = 0.6908234198582653e-16, (1466, 1) = -1.259778871432161, (1466, 2) = .0, (1467, 1) = -1.2588756145006283, (1467, 2) = -0.6913377838987428e-16, (1468, 1) = -1.2579723575690955, (1468, 2) = 0.34575462391617705e-15, (1469, 1) = -1.2570691006375627, (1469, 2) = -0.13833614323973592e-15, (1470, 1) = -1.2561658437060301, (1470, 2) = .0, (1471, 1) = -1.2552625867744975, (1471, 2) = 0.2768094663049513e-15, (1472, 1) = -1.254359329842965, (1472, 2) = 0.6921951467256799e-16, (1473, 1) = -1.2534560729114324, (1473, 2) = 0.13847332633071038e-15, (1474, 1) = -1.2525528159798995, (1474, 2) = -0.6925381204284337e-16, (1475, 1) = -1.251576371315955, (1475, 2) = 0.6927235085267674e-16, (1476, 1) = -1.25059992665201, (1476, 2) = .0, (1477, 1) = -1.2496234819880654, (1477, 2) = .0, (1478, 1) = -1.2486470373241207, (1478, 2) = -0.6932796974780773e-16, (1479, 1) = -1.2476705926601759, (1479, 2) = 0.34673255075758775e-15, (1480, 1) = -1.2466941479962312, (1480, 2) = -0.2080951527486492e-15, (1481, 1) = -1.2457177033322866, (1481, 2) = -0.6938359202685466e-16, (1482, 1) = -1.2447412586683417, (1482, 2) = -0.13880426693670776e-15, (1483, 1) = -1.2427883693404522, (1483, 2) = -0.6943921728347694e-16, (1484, 1) = -1.2408354800125627, (1484, 2) = .0, (1485, 1) = -1.239859035348618, (1485, 2) = 0.2084845353269897e-15, (1486, 1) = -1.2388825906846734, (1486, 2) = -0.6951338821739625e-16, (1487, 1) = -1.2379061460207286, (1487, 2) = 0.6953193155029857e-16, (1488, 1) = -1.236929701356784, (1488, 2) = 0.3477523754619682e-15, (1489, 1) = -1.2359532566928393, (1489, 2) = -0.13913803765668532e-15, (1490, 1) = -1.2349768120288944, (1490, 2) = 0.6958756274277772e-16, (1491, 1) = -1.2340003673649498, (1491, 2) = .0, (1492, 1) = -1.2330239227010051, (1492, 2) = 0.6962465104548932e-16, (1493, 1) = -1.2320474780370603, (1493, 2) = 0.20892958620865464e-15, (1494, 1) = -1.2310710333731156, (1494, 2) = -0.6966173987700442e-16, (1495, 1) = -1.230094588709171, (1495, 2) = .0, (1496, 1) = -1.2291181440452261, (1496, 2) = -0.13939765822666683e-15, (1497, 1) = -1.2281416993812813, (1497, 2) = 0.13943474768885795e-15, (1498, 1) = -1.2271652547173366, (1498, 2) = -0.13947183726004147e-15, (1499, 1) = -1.226188810053392, (1499, 2) = -0.34877231727239413e-15, (1500, 1) = -1.2252123653894471, (1500, 2) = 0.13954601660428838e-15, (1501, 1) = -1.2242359207255025, (1501, 2) = -0.20937465947198565e-15, (1502, 1) = -1.2232594760615578, (1502, 2) = -0.20943029401294324e-15, (1503, 1) = -1.222283031397613, (1503, 2) = -0.6982864282735507e-16, (1504, 1) = -1.2213065867336683, (1504, 2) = -0.13969437522134893e-15, (1505, 1) = -1.2203759641677134, (1505, 2) = 0.27945944832958586e-15, (1506, 1) = -1.2194453416017588, (1506, 2) = -0.13976507297994717e-15, (1507, 1) = -1.218514719035804, (1507, 2) = .0, (1508, 1) = -1.2175840964698492, (1508, 2) = .0, (1509, 1) = -1.2166534739038943, (1509, 2) = 0.2098066775711861e-15, (1510, 1) = -1.2157228513379397, (1510, 2) = -0.13990646640766335e-15, (1511, 1) = -1.214792228771985, (1511, 2) = -0.6997090708422143e-16, (1512, 1) = -1.2138616062060301, (1512, 2) = 0.13997716163542317e-15, (1513, 1) = -1.2129309836400752, (1513, 2) = 0.14001250878084966e-15, (1514, 1) = -1.2120003610741206, (1514, 2) = 0.1400478555769193e-15, (1515, 1) = -1.211069738508166, (1515, 2) = -0.7004160099789015e-16, (1516, 1) = -1.210139115942211, (1516, 2) = -0.1401185480095325e-15, (1517, 1) = -1.2092084933762561, (1517, 2) = 0.14015389359022693e-15, (1518, 1) = -1.2082778708103015, (1518, 2) = 0.14018923870986607e-15, (1519, 1) = -1.2073472482443468, (1519, 2) = -0.14022458334040377e-15, (1520, 1) = -1.206416625678392, (1520, 2) = 0.2103898911806177e-15, (1521, 1) = -1.205486003112437, (1521, 2) = -0.21044290653261986e-15, (1522, 1) = -1.2045553805464824, (1522, 2) = 0.28066122803243145e-15, (1523, 1) = -1.2036247579805277, (1523, 2) = -0.7018297820445579e-16, (1524, 1) = -1.2026941354145728, (1524, 2) = -0.2808025963430885e-15, (1525, 1) = -1.201763512848618, (1525, 2) = -0.7021831963788757e-16, (1526, 1) = -1.2008328902826633, (1526, 2) = .0, (1527, 1) = -1.1999022677167086, (1527, 2) = -0.7025365969771634e-16, (1528, 1) = -1.1989716451507537, (1528, 2) = -0.21081398753090682e-15, (1529, 1) = -1.1980410225847988, (1529, 2) = -0.2108669948102973e-15, (1530, 1) = -1.1971104000188442, (1530, 2) = -0.7030666696281534e-16, (1531, 1) = -1.1961797774528895, (1531, 2) = 0.1406486704816034e-15, (1532, 1) = -1.1952491548869346, (1532, 2) = .0, (1533, 1) = -1.193387909755025, (1533, 2) = 0.703773374428548e-16, (1534, 1) = -1.1915266646231155, (1534, 2) = 0.14082533981402613e-15, (1535, 1) = -1.1905472281940954, (1535, 2) = -0.7043126198676495e-16, (1536, 1) = -1.1895677917650753, (1536, 2) = -0.35224926747267833e-15, (1537, 1) = -1.1885883553360552, (1537, 2) = 0.14093688882681087e-15, (1538, 1) = -1.1876089189070351, (1538, 2) = -0.7048703472642434e-16, (1539, 1) = -1.186629482478015, (1539, 2) = -0.14101124883322465e-15, (1540, 1) = -1.185650046048995, (1540, 2) = 0.2115726404008776e-15, (1541, 1) = -1.1846706096199748, (1541, 2) = -0.21162840558127368e-15, (1542, 1) = -1.1836911731909547, (1542, 2) = 0.21168416873981352e-15, (1543, 1) = -1.1827117367619346, (1543, 2) = -0.21173992982519496e-15, (1544, 1) = -1.1817323003329145, (1544, 2) = -0.14119712585735e-15, (1545, 1) = -1.1807528639038944, (1545, 2) = 0.7061714852360672e-16, (1546, 1) = -1.1797734274748743, (1546, 2) = -0.3531786668800104e-15, (1547, 1) = -1.1787939910458543, (1547, 2) = .0, (1548, 1) = -1.1778145546168342, (1548, 2) = -0.21201870235280056e-15, (1549, 1) = -1.176835118187814, (1549, 2) = 0.7069148330560222e-16, (1550, 1) = -1.175855681758794, (1550, 2) = 0.21213019504599924e-15, (1551, 1) = -1.1748762453297739, (1551, 2) = 0.7072864589611672e-16, (1552, 1) = -1.1738968089007538, (1552, 2) = .0, (1553, 1) = -1.1729173724717337, (1553, 2) = -0.7076580510131993e-16, (1554, 1) = -1.1719379360427136, (1554, 2) = .0, (1555, 1) = -1.1709584996136935, (1555, 2) = -0.212408882345592e-15, (1556, 1) = -1.1699790631846734, (1556, 2) = -0.7082153725670996e-16, (1557, 1) = -1.1689996267556533, (1557, 2) = .0, (1558, 1) = -1.1680201903266332, (1558, 2) = 0.7085868738792645e-16, (1559, 1) = -1.167040753897613, (1559, 2) = -0.14175452201831313e-15, (1560, 1) = -1.166061317468593, (1560, 2) = -0.7089583364399038e-16, (1561, 1) = -1.1650818810395729, (1561, 2) = 0.2127432158243452e-15, (1562, 1) = -1.1641024446105528, (1562, 2) = -0.7093297588385408e-16, (1563, 1) = -1.1631230081815327, (1563, 2) = 0.7095154545350046e-16, (1564, 1) = -1.1621435717525126, (1564, 2) = 0.2129103418979505e-15, (1565, 1) = -1.1611641353234925, (1565, 2) = 0.7098868140353539e-16, (1566, 1) = -1.1601846988944724, (1566, 2) = .0, (1567, 1) = -1.1459986857286433, (1567, 2) = .0, (1568, 1) = -1.1318126725628141, (1568, 2) = .0, (1569, 1) = -1.1161344723618092, (1569, 2) = .0, (1570, 1) = -1.1004562721608042, (1570, 2) = .0, (1571, 1) = -1.0995177106752516, (1571, 2) = -0.7215437023537088e-16, (1572, 1) = -1.0985791491896988, (1572, 2) = 0.2886882411704876e-15, (1573, 1) = -1.097640587704146, (1573, 2) = 0.7218974824388096e-16, (1574, 1) = -1.0967020262185931, (1574, 2) = -0.14441486814347668e-15, (1575, 1) = -1.0957634647330403, (1575, 2) = 0.7222511775875846e-16, (1576, 1) = -1.0948249032474875, (1576, 2) = .0, (1577, 1) = -1.0938863417619347, (1577, 2) = -0.21678143592124545e-15, (1578, 1) = -1.092947780276382, (1578, 2) = -0.7227815580005117e-16, (1579, 1) = -1.0920092187908295, (1579, 2) = -0.7229583074884879e-16, (1580, 1) = -1.0910706573052766, (1580, 2) = 0.36156751734621554e-15, (1581, 1) = -1.0901320958197238, (1581, 2) = -0.21699352183092985e-15, (1582, 1) = -1.089193534334171, (1582, 2) = 0.14469768430886524e-15, (1583, 1) = -1.0882549728486182, (1583, 2) = -0.1447330161679372e-15, (1584, 1) = -1.0873164113630653, (1584, 2) = .0, (1585, 1) = -1.0863778498775125, (1585, 2) = -0.1448036660571619e-15, (1586, 1) = -1.08543928839196, (1586, 2) = -0.7241949200824294e-16, (1587, 1) = -1.0779307965075378, (1587, 2) = -0.7256067767449474e-16, (1588, 1) = -1.0704223046231156, (1588, 2) = -0.7270170365334883e-16, (1589, 1) = -1.0694860276224873, (1589, 2) = 0.14543855467420623e-15, (1590, 1) = -1.0685497506218593, (1590, 2) = .0, (1591, 1) = -1.0676134736212313, (1591, 2) = .0, (1592, 1) = -1.0666771966206032, (1592, 2) = -0.14554396489507215e-15, (1593, 1) = -1.0657409196199752, (1593, 2) = 0.7278954544372584e-16, (1594, 1) = -1.064804642619347, (1594, 2) = -0.728071057227023e-16, (1595, 1) = -1.0638683656187187, (1595, 2) = 0.14564932653257104e-15, (1596, 1) = -1.0629320886180906, (1596, 2) = -0.7284221805627015e-16, (1597, 1) = -1.0619958116174626, (1597, 2) = 0.21857931022327596e-15, (1598, 1) = -1.0610595346168343, (1598, 2) = .0, (1599, 1) = -1.060123257616206, (1599, 2) = -0.21868459716658932e-15, (1600, 1) = -1.059186980615578, (1600, 2) = -0.7291240931522327e-16, (1601, 1) = -1.05825070361495, (1601, 2) = -0.21878985018972746e-15, (1602, 1) = -1.0573144266143217, (1602, 2) = -0.14589497589579172e-15, (1603, 1) = -1.0563781496136935, (1603, 2) = 0.729650229507998e-16, (1604, 1) = -1.0554418726130654, (1604, 2) = 0.7298255505354519e-16, (1605, 1) = -1.0545055956124374, (1605, 2) = -0.21900025271309264e-15, (1606, 1) = -1.0535693186118091, (1606, 2) = 0.7301761048479697e-16, (1607, 1) = -1.0526330416111809, (1607, 2) = 0.14607026755271625e-15, (1608, 1) = -1.0516967646105528, (1608, 2) = -0.21915796228161078e-15, (1609, 1) = -1.0507604876099248, (1609, 2) = 0.1461403428375945e-15, (1610, 1) = -1.0498242106092965, (1610, 2) = -0.1461753714651552e-15, (1611, 1) = -1.0488879336086683, (1611, 2) = 0.14621039403324876e-15, (1612, 1) = -1.0479516566080402, (1612, 2) = 0.1462454105046507e-15, (1613, 1) = -1.0470153796074122, (1613, 2) = -0.29256084168417145e-15, (1614, 1) = -1.046079102606784, (1614, 2) = 0.3657885625205698e-15, (1615, 1) = -1.0451428256061557, (1615, 2) = 0.3658760574142515e-15, (1616, 1) = -1.0442065486055276, (1616, 2) = 0.7319270733853824e-16, (1617, 1) = -1.0432702716048996, (1617, 2) = 0.14642040010487758e-15, (1618, 1) = -1.0423339946042716, (1618, 2) = -0.7322768960578766e-16, (1619, 1) = -1.0413977176036435, (1619, 2) = 0.14649035195959057e-15, (1620, 1) = -1.0404614406030153, (1620, 2) = -0.14652531831129346e-15, (1621, 1) = -1.0248143213065326, (1621, 2) = -0.1471086965114306e-15, (1622, 1) = -1.0091672020100502, (1622, 2) = -0.14769009945764272e-15, (1623, 1) = -1.008266479004397, (1623, 2) = .0, (1624, 1) = -1.0073657559987437, (1624, 2) = 0.7387845056847929e-16, (1625, 1) = -1.0064650329930904, (1625, 2) = 0.14779029116836663e-15, (1626, 1) = -1.0055643099874372, (1626, 2) = .0, (1627, 1) = -1.004663586981784, (1627, 2) = .0, (1628, 1) = -1.0037628639761307, (1628, 2) = 0.2218356264111475e-15, (1629, 1) = -1.0028621409704774, (1629, 2) = 0.7396188920894308e-16, (1630, 1) = -1.0019614179648242, (1630, 2) = 0.14795713183486065e-15, (1631, 1) = -1.001060694959171, (1631, 2) = -0.7399523891148694e-16, (1632, 1) = -1.0001599719535177, (1632, 2) = -0.22203572452020312e-15, (1633, 1) = -.9992592489478644, (1633, 2) = -0.2591000078990389e-15, (1634, 1) = -.9983585259422111, (1634, 2) = -0.14809047085969753e-15, (1635, 1) = -.9974578029365577, (1635, 2) = 0.14812378677770617e-15, (1636, 1) = -.9965570799309045, (1636, 2) = .0, (1637, 1) = -.9956563569252512, (1637, 2) = 0.7409519787944111e-16, (1638, 1) = -.994755633919598, (1638, 2) = -0.2593914553137913e-15, (1639, 1) = -.9938549109139447, (1639, 2) = 0.29651394805832157e-15, (1640, 1) = -.9929541879082915, (1640, 2) = 0.3707256288959744e-16, (1641, 1) = -.9920534649026382, (1641, 2) = 0.3708088032565543e-16, (1642, 1) = -.991152741896985, (1642, 2) = .0, (1643, 1) = -.9902520188913317, (1643, 2) = -0.22258505593900804e-15, (1644, 1) = -.9893512958856785, (1644, 2) = -0.18552910433334286e-15, (1645, 1) = -.9884505728800252, (1645, 2) = .0, (1646, 1) = -.9875498498743719, (1646, 2) = 0.11136731399458367e-15, (1647, 1) = -.9866491268687185, (1647, 2) = -0.3713074356820311e-16, (1648, 1) = -.9857484038630653, (1648, 2) = 0.37139047129013356e-16, (1649, 1) = -.984847680857412, (1649, 2) = -0.7429469734318147e-16, (1650, 1) = -.9839469578517588, (1650, 2) = 0.7431129637378047e-16, (1651, 1) = -.9830462348461055, (1651, 2) = .0, (1652, 1) = -.9821455118404523, (1652, 2) = -0.18586120549711752e-15, (1653, 1) = -.981244788834799, (1653, 2) = -0.7436106895703034e-16, (1654, 1) = -.9803440658291458, (1654, 2) = 0.2231329547642687e-15, (1655, 1) = -.9794216022644473, (1655, 2) = -0.22318389052145303e-15, (1656, 1) = -.9784991386997488, (1656, 2) = 0.14882320878427402e-15, (1657, 1) = -.9775766751350503, (1657, 2) = -0.14885714844691714e-15, (1658, 1) = -.9766542115703518, (1658, 2) = .0, (1659, 1) = -.9757317480056533, (1659, 2) = -0.3723125032331919e-16, (1660, 1) = -.9748092844409548, (1660, 2) = -0.11171918579880703e-15, (1661, 1) = -.9738868208762563, (1661, 2) = 0.11174461392928415e-15, (1662, 1) = -.9729643573115578, (1662, 2) = -0.37256678443944896e-16, (1663, 1) = -.9720418937468593, (1663, 2) = -0.11179544997687034e-15, (1664, 1) = -.9711194301821608, (1664, 2) = .0, (1665, 1) = -.9701969666174624, (1665, 2) = -0.1864104314597903e-15, (1666, 1) = -.9692745030527639, (1666, 2) = 0.26103385716449033e-15, (1667, 1) = -.9683520394880654, (1667, 2) = 0.2237940807778196e-15, (1668, 1) = -.9674295759233669, (1668, 2) = -0.3357672624040744e-15, (1669, 1) = -.9665071123586684, (1669, 2) = 0.1865796571300815e-15, (1670, 1) = -.9655846487939699, (1670, 2) = 0.7464877385943766e-16, (1671, 1) = -.9637397216645729, (1671, 2) = .0, (1672, 1) = -.9618947945351759, (1672, 2) = -0.37358185526686606e-16, (1673, 1) = -.9609723309704774, (1673, 2) = -0.3736662927156175e-16, (1674, 1) = -.9600498674057789, (1674, 2) = 0.11212521190406527e-15, (1675, 1) = -.9591274038410804, (1675, 2) = 0.7476701921209232e-16, (1676, 1) = -.9582049402763819, (1676, 2) = 0.7478389235120664e-16, (1677, 1) = -.9572824767116834, (1677, 2) = -0.7480076066663417e-16, (1678, 1) = -.9563600131469849, (1678, 2) = -0.14963524827653396e-15, (1679, 1) = -.9554375495822864, (1679, 2) = 0.2245034482379246e-15, (1680, 1) = -.9545150860175879, (1680, 2) = 0.7485133646960535e-16, (1681, 1) = -.9535926224528894, (1681, 2) = 0.3743409264449186e-16, (1682, 1) = -.952670158888191, (1682, 2) = .0, (1683, 1) = -.9517476953234925, (1683, 2) = 0.7490186813417427e-16, (1684, 1) = -.950825231758794, (1684, 2) = 0.14983740423905226e-15, (1685, 1) = -.9426771566834171, (1685, 2) = 0.375335885423714e-16, (1686, 1) = -.9345290816080403, (1686, 2) = -0.7521524905147453e-16, (1687, 1) = -.9324920628391961, (1687, 2) = .0, (1688, 1) = -.9304550440703518, (1688, 2) = 0.3764456474336513e-16, (1689, 1) = -.9294365346859297, (1689, 2) = -0.37653791545630494e-16, (1690, 1) = -.9284180253015076, (1690, 2) = 0.301304120152877e-15, (1691, 1) = -.9273995159170856, (1691, 2) = 0.7534447029961963e-16, (1692, 1) = -.9263810065326634, (1692, 2) = 0.2260887115423346e-15, (1693, 1) = -.9253624971482413, (1693, 2) = -0.11307199598046885e-15, (1694, 1) = -.9243439877638192, (1694, 2) = 0.22619925207042584e-15, (1695, 1) = -.9233254783793972, (1695, 2) = -0.3770908196441029e-16, (1696, 1) = -.922306968994975, (1696, 2) = -0.7543657034153772e-16, (1697, 1) = -.9212884596105528, (1697, 2) = -0.11318245485017655e-15, (1698, 1) = -.9202699502261308, (1698, 2) = 0.15094672515270667e-15, (1699, 1) = -.9192514408417087, (1699, 2) = 0.3774587417100299e-16, (1700, 1) = -.9182329314572866, (1700, 2) = -0.22653038150641676e-15, (1701, 1) = -.9173107546356785, (1701, 2) = 0.1888169042049196e-15, (1702, 1) = -.9163885778140705, (1702, 2) = 0.37771695231277246e-16, (1703, 1) = -.9154664009924625, (1703, 2) = 0.18890003372378932e-15, (1704, 1) = -.9145442241708543, (1704, 2) = 0.11336494611267128e-15, (1705, 1) = -.9126998705276383, (1705, 2) = 0.756098478378351e-16, (1706, 1) = -.9108555168844222, (1706, 2) = -0.37821520790866536e-16, (1707, 1) = -.9099333400628142, (1707, 2) = -0.7565962964372469e-16, (1708, 1) = -.9090111632412061, (1708, 2) = 0.37838105902078566e-16, (1709, 1) = -.9080889864195981, (1709, 2) = -0.37846394020906887e-16, (1710, 1) = -.9071668095979901, (1710, 2) = -0.18927339583864315e-15, (1711, 1) = -.906244632776382, (1711, 2) = -0.18931480665957398e-15, (1712, 1) = -.905322455954774, (1712, 2) = 0.3787124050282605e-16, (1713, 1) = -.904400279133166, (1713, 2) = 0.15151806667925117e-15, (1714, 1) = -.9034781023115579, (1714, 2) = -0.11366336946664532e-15, (1715, 1) = -.9025559254899498, (1715, 2) = -0.22737635969617685e-15, (1716, 1) = -.9016337486683418, (1716, 2) = 0.18952163520287754e-15, (1717, 1) = -.9007115718467338, (1717, 2) = 0.1516503643406501e-15, (1718, 1) = -.8997893950251257, (1718, 2) = 0.7584170414484605e-16, (1719, 1) = -.8988672182035177, (1719, 2) = -0.3792910999164596e-16, (1720, 1) = -.8979450413819097, (1720, 2) = -0.11381209449633025e-15, (1721, 1) = -.8970228645603016, (1721, 2) = .0, (1722, 1) = -.8961006877386936, (1722, 2) = .0, (1723, 1) = -.8951785109170856, (1723, 2) = 0.1138863323207555e-15, (1724, 1) = -.8942563340954774, (1724, 2) = -0.11391105957479701e-15, (1725, 1) = -.8933341572738694, (1725, 2) = -0.1139357774312878e-15, (1726, 1) = -.8924119804522614, (1726, 2) = 0.26590780033505853e-15, (1727, 1) = -.8905676268090453, (1727, 2) = 0.19001645715308148e-15, (1728, 1) = -.8887232731658292, (1728, 2) = 0.15207896615644015e-15, (1729, 1) = -.8877801746325378, (1729, 2) = 0.26619703782860455e-15, (1730, 1) = -.8868370760992463, (1730, 2) = -0.15214620651067387e-15, (1731, 1) = -.8858939775659549, (1731, 2) = 0.3043596130145613e-15, (1732, 1) = -.8849508790326635, (1732, 2) = -0.38053348247065845e-16, (1733, 1) = -.884007780499372, (1733, 2) = 0.15224696590710496e-15, (1734, 1) = -.8830646819660806, (1734, 2) = 0.38070131304311276e-16, (1735, 1) = -.8821215834327891, (1735, 2) = -0.38078517718020104e-16, (1736, 1) = -.8811784848994976, (1736, 2) = 0.22852140423744697e-15, (1737, 1) = -.880235386366206, (1737, 2) = -0.38095280257302125e-16, (1738, 1) = -.8792922878329146, (1738, 2) = 0.38103656359519963e-16, (1739, 1) = -.8783491892996231, (1739, 2) = -0.7622405800240201e-16, (1740, 1) = -.8774060907663317, (1740, 2) = -0.19060199085320449e-15, (1741, 1) = -.8764629922330403, (1741, 2) = 0.1143862915683739e-15, (1742, 1) = -.8755198936997488, (1742, 2) = .0, (1743, 1) = -.8745767951664574, (1743, 2) = 0.11443645418493224e-15, (1744, 1) = -.8736336966331659, (1744, 2) = -0.15261535956612066e-15, (1745, 1) = -.8726905980998745, (1745, 2) = -0.3816219152382765e-16, (1746, 1) = -.871747499566583, (1746, 2) = -0.3817053961343537e-16, (1747, 1) = -.8708044010332916, (1747, 2) = -0.19089442074287527e-15, (1748, 1) = -.8698613025000002, (1748, 2) = -0.1145616753523738e-15, (1749, 1) = -.8689182039667087, (1749, 2) = 0.11458668752485435e-15, (1750, 1) = -.8679751054334173, (1750, 2) = 0.38203896309246e-16, (1751, 1) = -.8670320069001258, (1751, 2) = .0, (1752, 1) = -.8660889083668343, (1752, 2) = -0.1146616592828431e-15, (1753, 1) = -.8651458098335427, (1753, 2) = -0.3822887605468371e-16, (1754, 1) = -.8642027113002513, (1754, 2) = -0.26766036764514964e-15, (1755, 1) = -.8632596127669598, (1755, 2) = .0, (1756, 1) = -.8623165142336684, (1756, 2) = -0.19126911532594407e-15, (1757, 1) = -.861373415700377, (1757, 2) = .0, (1758, 1) = -.8604303171670855, (1758, 2) = 0.15308174424479163e-15, (1759, 1) = -.8594872186337941, (1759, 2) = -0.3827873702022786e-16, (1760, 1) = -.8585441201005026, (1760, 2) = 0.38287034270728187e-16, (1761, 1) = -.8575850131846735, (1761, 2) = -0.3063637483598358e-15, (1762, 1) = -.8566259062688444, (1762, 2) = -0.15321559583540785e-15, (1763, 1) = -.8556667993530152, (1763, 2) = -0.76624650999568e-16, (1764, 1) = -.854707692437186, (1764, 2) = 0.2299244889312191e-15, (1765, 1) = -.8537485855213569, (1765, 2) = 0.1916458345626316e-15, (1766, 1) = -.8527894786055277, (1766, 2) = -0.7667516351831912e-16, (1767, 1) = -.8518303716896986, (1767, 2) = 0.7669198536499669e-16, (1768, 1) = -.8508712647738694, (1768, 2) = 0.7670879933985492e-16, (1769, 1) = -.8499121578580403, (1769, 2) = 0.15345121083528425e-15, (1770, 1) = -.8489530509422112, (1770, 2) = 0.11511360535962816e-15, (1771, 1) = -.847993944026382, (1771, 2) = -0.7675919378089084e-16, (1772, 1) = -.8470348371105528, (1772, 2) = -0.38387988007871626e-16, (1773, 1) = -.8460757301947237, (1773, 2) = -0.7679275025230654e-16, (1774, 1) = -.8451166232788945, (1774, 2) = 0.7680951646522366e-16, (1775, 1) = -.8441575163630654, (1775, 2) = 0.7682627462911661e-16, (1776, 1) = -.8431984094472362, (1776, 2) = 0.384215123592933e-16, (1777, 1) = -.8422393025314071, (1777, 2) = .0, (1778, 1) = -.841280195615578, (1778, 2) = -0.15375300114511706e-15, (1779, 1) = -.8403210886997488, (1779, 2) = 0.7689322628615918e-16, (1780, 1) = -.8393619817839196, (1780, 2) = 0.1538198876470687e-15, (1781, 1) = -.8374437679522613, (1781, 2) = 0.7694335426757932e-16, (1782, 1) = -.835525554120603, (1782, 2) = -0.3848836585021552e-16, (1783, 1) = -.8345664472047739, (1783, 2) = 0.7699340797373832e-16, (1784, 1) = -.8336073402889448, (1784, 2) = -0.19252518979375352e-15, (1785, 1) = -.8326482333731156, (1785, 2) = 0.15405347101219256e-15, (1786, 1) = -.8316891264572864, (1786, 2) = -0.11556508007081799e-15, (1787, 1) = -.8307300195414573, (1787, 2) = -0.7706002951518439e-16, (1788, 1) = -.8297709126256281, (1788, 2) = -0.15415332776865846e-15, (1789, 1) = -.828811805709799, (1789, 2) = .0, (1790, 1) = -.8278526987939698, (1790, 2) = 0.2698846752815498e-15, (1791, 1) = -.82697109290201, (1791, 2) = 0.38562587183947816e-16, (1792, 1) = -.8260894870100502, (1792, 2) = -0.3857021715139435e-16, (1793, 1) = -.8252078811180905, (1793, 2) = -0.3857784350397832e-16, (1794, 1) = -.8243262752261307, (1794, 2) = .0, (1795, 1) = -.8234446693341708, (1795, 2) = 0.7718617064895729e-16, (1796, 1) = -.822563063442211, (1796, 2) = 0.11580210231701274e-15, (1797, 1) = -.8216814575502511, (1797, 2) = 0.7721662513043839e-16, (1798, 1) = -.8207998516582914, (1798, 2) = 0.7723184138615494e-16, (1799, 1) = -.8172734280904521, (1799, 2) = .0, (1800, 1) = -.813747004522613, (1800, 2) = -0.3867665256731692e-16, (1801, 1) = -.8128653986306531, (1801, 2) = 0.1547369090270578e-15, (1802, 1) = -.8119837927386934, (1802, 2) = -0.7738359636070613e-16, (1803, 1) = -.8111021868467336, (1803, 2) = 0.386993653279622e-16, (1804, 1) = -.8102205809547738, (1804, 2) = -0.3870692868946458e-16, (1805, 1) = -.8093389750628139, (1805, 2) = -0.38714488254726355e-16, (1806, 1) = -.8084573691708541, (1806, 2) = -0.11616613204082115e-15, (1807, 1) = -.8075757632788942, (1807, 2) = -0.15491838382383855e-15, (1808, 1) = -.8066941573869345, (1808, 2) = -0.1162114322148915e-15, (1809, 1) = -.8058125514949748, (1809, 2) = 0.2712128184532167e-15, (1810, 1) = -.8049309456030149, (1810, 2) = 0.11625668634684021e-15, (1811, 1) = -.8040493397110551, (1811, 2) = -0.7751953071383803e-16, (1812, 1) = -.8031677338190952, (1812, 2) = -0.11630189419259033e-15, (1813, 1) = -.8022861279271354, (1813, 2) = 0.11632448068178203e-15, (1814, 1) = -.8014045220351756, (1814, 2) = -0.19391175917959137e-15, (1815, 1) = -.8005229161432159, (1815, 2) = -0.38789872879970764e-16, (1816, 1) = -.7996413102512561, (1816, 2) = 0.11639217004763878e-15, (1817, 1) = -.7846050969346732, (1817, 2) = 0.155699946532664e-15, (1818, 1) = -.7695688836180903, (1818, 2) = 0.19525696230744654e-15, (1819, 1) = -.7686362738253767, (1819, 2) = 0.27341434614501045e-15, (1820, 1) = -.7677036640326631, (1820, 2) = -0.11720096208101878e-15, (1821, 1) = -.7667710542399495, (1821, 2) = -0.19537388805438746e-15, (1822, 1) = -.765838444447236, (1822, 2) = 0.11724768913708996e-15, (1823, 1) = -.7649058346545226, (1823, 2) = .0, (1824, 1) = -.763973224861809, (1824, 2) = .0, (1825, 1) = -.7630406150690954, (1825, 2) = -0.39105890332269824e-16, (1826, 1) = -.7621080052763818, (1826, 2) = 0.1955682819030442e-15, (1827, 1) = -.7611753954836682, (1827, 2) = -0.1564856702055734e-15, (1828, 1) = -.7602427856909546, (1828, 2) = -0.7825834766447285e-16, (1829, 1) = -.759310175898241, (1829, 2) = 0.3913692521074463e-16, (1830, 1) = -.7583775661055275, (1830, 2) = -0.11743401502355414e-15, (1831, 1) = -.757444956312814, (1831, 2) = 0.15660965284460142e-15, (1832, 1) = -.7565123465201005, (1832, 2) = 0.35244134827405923e-15, (1833, 1) = -.7555797367273869, (1833, 2) = 0.11750364436000289e-15, (1834, 1) = -.7546471269346733, (1834, 2) = .0, (1835, 1) = -.7537145171419597, (1835, 2) = -0.3918332983791847e-16, (1836, 1) = -.7527819073492461, (1836, 2) = 0.15676418621010996e-15, (1837, 1) = -.7518492975565325, (1837, 2) = 0.11759627479627293e-15, (1838, 1) = -.750916687763819, (1838, 2) = -0.7841292992831721e-16, (1839, 1) = -.7499840779711056, (1839, 2) = -0.392141666362739e-16, (1840, 1) = -.749051468178392, (1840, 2) = 0.2353311796158457e-15, (1841, 1) = -.7481188583856784, (1841, 2) = -0.39229554850791137e-16, (1842, 1) = -.7471862485929648, (1842, 2) = 0.19618620684124896e-15, (1843, 1) = -.7462536388002512, (1843, 2) = -0.15697969123681187e-15, (1844, 1) = -.7453210290075376, (1844, 2) = 0.3925259916116407e-16, (1845, 1) = -.744388419214824, (1845, 2) = -0.23556162246984375e-15, (1846, 1) = -.7434558094221105, (1846, 2) = 0.27487555583693986e-15, (1847, 1) = -.7425231996293971, (1847, 2) = 0.1571023902325632e-15, (1848, 1) = -.7415905898366835, (1848, 2) = 0.15713301371660104e-15, (1849, 1) = -.7406579800439699, (1849, 2) = 0.2750363290405285e-15, (1850, 1) = -.7397253702512563, (1850, 2) = .0, (1851, 1) = -.7377301650753769, (1851, 2) = -0.11794466712013497e-15, (1852, 1) = -.7357349598994976, (1852, 2) = -0.15732481824165942e-15, (1853, 1) = -.7347373573115579, (1853, 2) = -0.15735741340548653e-15, (1854, 1) = -.7337397547236182, (1854, 2) = 0.27543247299647357e-15, (1855, 1) = -.7327421521356785, (1855, 2) = 0.39355632917984006e-16, (1856, 1) = -.7317445495477387, (1856, 2) = -0.1574550546515217e-15, (1857, 1) = -.7307469469597989, (1857, 2) = -0.2756032185315676e-15, (1858, 1) = -.7297493443718592, (1858, 2) = -0.2362800419934194e-15, (1859, 1) = -.7287517417839195, (1859, 2) = 0.7877623911845737e-16, (1860, 1) = -.7277541391959799, (1860, 2) = 0.11818867808165438e-15, (1861, 1) = -.7267565366080402, (1861, 2) = 0.27583028471217837e-15, (1862, 1) = -.7257589340201005, (1862, 2) = -0.7882484124902457e-16, (1863, 1) = -.7247613314321608, (1863, 2) = -0.19710254361480987e-15, (1864, 1) = -.7237637288442211, (1864, 2) = 0.3154287253389255e-15, (1865, 1) = -.7227661262562814, (1865, 2) = 0.3943666644227945e-16, (1866, 1) = -.7217685236683418, (1866, 2) = 0.3944473603225284e-16, (1867, 1) = -.7207709210804021, (1867, 2) = 0.7890559884365799e-16, (1868, 1) = -.7197733184924624, (1868, 2) = .0, (1869, 1) = -.7187757159045227, (1869, 2) = 0.3946890753793044e-16, (1870, 1) = -.717778113316583, (1870, 2) = -0.31581561786808375e-15, (1871, 1) = -.7167805107286433, (1871, 2) = -0.19742495333401418e-15, (1872, 1) = -.7157829081407036, (1872, 2) = -0.15797209128927798e-15, (1873, 1) = -.7147853055527638, (1873, 2) = 0.2765073407919642e-15, (1874, 1) = -.7137877029648241, (1874, 2) = 0.3950906823804315e-16, (1875, 1) = -.7127901003768844, (1875, 2) = .0, (1876, 1) = -.7117924977889447, (1876, 2) = 0.11857526506997022e-15, (1877, 1) = -.710794895201005, (1877, 2) = .0, (1878, 1) = -.7097972926130653, (1878, 2) = 0.39541083054041345e-16, (1879, 1) = -.7087996900251257, (1879, 2) = -0.11864721249288102e-15, (1880, 1) = -.707802087437186, (1880, 2) = 0.15822820882394317e-15, (1881, 1) = -.7069217463693468, (1881, 2) = -0.19782045046961084e-15, (1882, 1) = -.7060414053015076, (1882, 2) = -0.15828449189491448e-15, (1883, 1) = -.7051610642336684, (1883, 2) = 0.11873445250415668e-15, (1884, 1) = -.7042807231658292, (1884, 2) = -0.2375110419972206e-15, (1885, 1) = -.70340038209799, (1885, 2) = -0.7918438291497893e-16, (1886, 1) = -.7025200410301509, (1886, 2) = 0.19799602098940487e-15, (1887, 1) = -.7016396999623117, (1887, 2) = 0.1188186356300363e-15, (1888, 1) = -.7007593588944725, (1888, 2) = 0.2376792868990828e-15, (1889, 1) = -.6998790178266333, (1889, 2) = .0, (1890, 1) = -.6989986767587941, (1890, 2) = -0.3962720443647066e-16, (1891, 1) = -.6981183356909549, (1891, 2) = -0.23780515057103373e-15, (1892, 1) = -.6972379946231158, (1892, 2) = 0.35677056574863775e-15, (1893, 1) = -.6963576535552766, (1893, 2) = -0.3964815105644875e-16, (1894, 1) = -.6954773124874374, (1894, 2) = 0.2379307380255123e-15, (1895, 1) = -.6945969714195982, (1895, 2) = 0.11898626941427168e-15, (1896, 1) = -.693716630351759, (1896, 2) = .0, (1897, 1) = -.6866739018090455, (1897, 2) = 0.3972455761010677e-16, (1898, 1) = -.679631173266332, (1898, 2) = 0.7955945494436792e-16, (1899, 1) = -.6471277863316587, (1899, 2) = 0.4002983047667309e-16, (1900, 1) = -.6324618859296485, (1900, 2) = -0.4014015072579584e-16, (1901, 1) = -.6177959855276383, (1901, 2) = -0.8049765580611e-16, (1902, 1) = -.61054041459799, (1902, 2) = 0.4030197017955458e-16, (1903, 1) = -.6032848436683418, (1903, 2) = 0.16141876790575644e-15, (1904, 1) = -.6023778973021358, (1904, 2) = -0.807225046680219e-16, (1905, 1) = -.6014709509359297, (1905, 2) = -0.4036780601499214e-16, (1906, 1) = -.6005640045697237, (1906, 2) = -0.20187176503772307e-15, (1907, 1) = -.5996570582035177, (1907, 2) = -0.8076178659966317e-16, (1908, 1) = -.5978431654711056, (1908, 2) = .0, (1909, 1) = -.5960292727386935, (1909, 2) = 0.1212209616889085e-15, (1910, 1) = -.5951223263724875, (1910, 2) = 0.12124048152927617e-15, (1911, 1) = -.5942153800062815, (1911, 2) = 0.1616799747411654e-15, (1912, 1) = -.5933084336400755, (1912, 2) = -0.404264867444076e-16, (1913, 1) = -.5924014872738694, (1913, 2) = 0.40432973008616034e-16, (1914, 1) = -.5905875945414574, (1914, 2) = 0.12133777531505692e-15, (1915, 1) = -.5887737018090453, (1915, 2) = 0.24275309927962315e-15, (1916, 1) = -.5848726669974875, (1916, 2) = 0.16194621377313149e-15, (1917, 1) = -.5809716321859297, (1917, 2) = 0.4051412926053376e-16, (1918, 1) = -.5799963734830402, (1918, 2) = .0, (1919, 1) = -.5790211147801508, (1919, 2) = 0.1215836069126259e-15, (1920, 1) = -.5780458560772614, (1920, 2) = 0.12160418017542808e-15, (1921, 1) = -.5770705973743719, (1921, 2) = -0.8108315278518937e-16, (1922, 1) = -.5760953386714824, (1922, 2) = 0.8109683591715139e-16, (1923, 1) = -.575120079968593, (1923, 2) = 0.4055525140843358e-16, (1924, 1) = -.5741448212657037, (1924, 2) = -0.12168623018255932e-15, (1925, 1) = -.5731695625628141, (1925, 2) = -0.8113778780237872e-16, (1926, 1) = -.5653674929396986, (1926, 2) = -0.12186940889823572e-15, (1927, 1) = -.557565423316583, (1927, 2) = -0.16270739587272336e-15, (1928, 1) = -.5565862194912061, (1928, 2) = -0.28478486696502754e-15, (1929, 1) = -.5556070156658293, (1929, 2) = 0.16276098960969919e-15, (1930, 1) = -.5546278118404524, (1930, 2) = .0, (1931, 1) = -.5536486080150754, (1931, 2) = 0.16281444748614286e-15, (1932, 1) = -.5526694041896985, (1932, 2) = 0.8142056266466782e-16, (1933, 1) = -.5516902003643216, (1933, 2) = -0.40716942257660606e-16, (1934, 1) = -.5507109965389447, (1934, 2) = -0.12217078389839255e-15, (1935, 1) = -.5497317927135679, (1935, 2) = 0.8146047688606376e-16, (1936, 1) = -.548752588888191, (1936, 2) = 0.18331593153145426e-15, (1937, 1) = -.5477733850628141, (1937, 2) = -0.10185875077492447e-15, (1938, 1) = -.5467941812374373, (1938, 2) = -0.8150023667455182e-16, (1939, 1) = -.5458149774120603, (1939, 2) = -0.10189181935221203e-15, (1940, 1) = -.5448357735866833, (1940, 2) = .0, (1941, 1) = -.5438565697613065, (1941, 2) = 0.815398412365604e-16, (1942, 1) = -.5428773659359296, (1942, 2) = 0.24465902437629747e-15, (1943, 1) = -.5418981621105528, (1943, 2) = 0.20391539412377172e-15, (1944, 1) = -.5409189582851759, (1944, 2) = -0.611844673346019e-16, (1945, 1) = -.539939754459799, (1945, 2) = 0.10199050560750832e-15, (1946, 1) = -.5389605506344222, (1946, 2) = 0.10200687717478304e-15, (1947, 1) = -.5379813468090452, (1947, 2) = 0.18364180840120499e-15, (1948, 1) = -.5370021429836682, (1948, 2) = -0.12244746565829778e-15, (1949, 1) = -.5360229391582914, (1949, 2) = -0.6123351636916971e-16, (1950, 1) = -.5350437353329145, (1950, 2) = -0.10207214455310942e-15, (1951, 1) = -.5340645315075376, (1951, 2) = .0, (1952, 1) = -.5301477162060301, (1952, 2) = -0.20430646706190278e-16, (1953, 1) = -.5262309009045225, (1953, 2) = -0.4088708226856249e-16, (1954, 1) = -.5253399704114321, (1954, 2) = -0.6133939254659551e-16, (1955, 1) = -.5244490399183417, (1955, 2) = 0.1431456846965623e-15, (1956, 1) = -.5235581094252513, (1956, 2) = 0.1022614958322614e-15, (1957, 1) = -.5226671789321607, (1957, 2) = 0.16364168873474045e-15, (1958, 1) = -.5217762484390702, (1958, 2) = 0.6137435789634596e-16, (1959, 1) = -.5208853179459798, (1959, 2) = -0.16368819025443262e-15, (1960, 1) = -.5199943874528894, (1960, 2) = -0.6139177360633507e-16, (1961, 1) = -.519103456959799, (1961, 2) = 0.20466821554243753e-15, (1962, 1) = -.5155397349874372, (1962, 2) = 0.10239186085945716e-15, (1963, 1) = -.5119760130150754, (1963, 2) = 0.6146958778770338e-16, (1964, 1) = -.5101941520288946, (1964, 2) = .0, (1965, 1) = -.5084122910427137, (1965, 2) = -0.8200516991249051e-16, (1966, 1) = -.5075213605496232, (1966, 2) = -0.2050414044829672e-15, (1967, 1) = -.5066304300565327, (1967, 2) = -0.14354889225231038e-15, (1968, 1) = -.5057394995634423, (1968, 2) = -0.2050982495023389e-16, (1969, 1) = -.5048485690703519, (1969, 2) = 0.24615193765398556e-15, (1970, 1) = -.5039576385772615, (1970, 2) = -0.28721691830799224e-15, (1971, 1) = -.5030667080841711, (1971, 2) = 0.41036646051798756e-16, (1972, 1) = -.5021757775910807, (1972, 2) = 0.6156344414666744e-16, (1973, 1) = -.5012848470979901, (1973, 2) = -0.22576366151266857e-15, (1974, 1) = -.5003939166048997, (1974, 2) = 0.8210714623642785e-16, (1975, 1) = -.49950298611180927, (1975, 2) = -0.20529600035541822e-16, (1976, 1) = -.4986120556187188, (1976, 2) = -0.821296386093493e-16, (1977, 1) = -.4977211251256284, (1977, 2) = -0.3080282310615768e-15, (1978, 1) = -.49677499651696, (1978, 2) = -0.10269095375099138e-15, (1979, 1) = -.49582886790829167, (1979, 2) = -0.20541161724989832e-16, (1980, 1) = -.49488273929962334, (1980, 2) = 0.41088256644078176e-16, (1981, 1) = -.49393661069095496, (1981, 2) = 0.8218836213963866e-16, (1982, 1) = -.49204435347361825, (1982, 2) = 0.4110600356478264e-16, (1983, 1) = -.49015209625628153, (1983, 2) = .0, (1984, 1) = -.48920596764761315, (1984, 2) = -0.14393284928133099e-15, (1985, 1) = -.4882598390389448, (1985, 2) = 0.8225908553800659e-16, (1986, 1) = -.4873137104302765, (1986, 2) = 0.1028385136413804e-15, (1987, 1) = -.4863675818216081, (1987, 2) = 0.20570629636541713e-16, (1988, 1) = -.4854214532129397, (1988, 2) = 0.8229420841161149e-16, (1989, 1) = -.4844753246042714, (1989, 2) = -0.22634117133065455e-15, (1990, 1) = -.48352919599560307, (1990, 2) = -0.22637322052787907e-15, (1991, 1) = -.4825830673869347, (1991, 2) = .0, (1992, 1) = -.4816369387782663, (1992, 2) = -0.6175559226466392e-16, (1993, 1) = -.48069081016959797, (1993, 2) = -0.20588097582624055e-16, (1994, 1) = -.47974468156092964, (1994, 2) = -0.8236397305405929e-16, (1995, 1) = -.47879855295226126, (1995, 2) = 0.4118776891572972e-16, (1996, 1) = -.4778524243435929, (1996, 2) = 0.20596771159317025e-16, (1997, 1) = -.47690629573492455, (1997, 2) = 0.8239861344607657e-16, (1998, 1) = -.4759601671262562, (1998, 2) = 0.6180759317437207e-16, (1999, 1) = -.47501403851758783, (1999, 2) = -0.20605404242789555e-16, (2000, 1) = -.47406790990891945, (2000, 2) = 0.2060827290917865e-16, (2001, 1) = -.4731217813002511, (2001, 2) = -0.6183341115287812e-16, (2002, 1) = -.4721756526915828, (2002, 2) = 0.618419899854147e-16, (2003, 1) = -.4712295240829144, (2003, 2) = 0.12370111041236152e-15, (2004, 1) = -.470283395474246, (2004, 2) = 0.6185910679622706e-16, (2005, 1) = -.4693372668655777, (2005, 2) = 0.4124509649108e-16, (2006, 1) = -.46839113825690937, (2006, 2) = -0.8250155867792252e-16, (2007, 1) = -.467445009648241, (2007, 2) = 0.6188467959279098e-16, (2008, 1) = -.4526717448241204, (2008, 2) = 0.20671925931655937e-16, (2009, 1) = -.43789847999999987, (2009, 2) = -0.8285795061152573e-16, (2010, 1) = -.421884105075377, (2010, 2) = -0.20759312744740692e-16, (2011, 1) = -.4058697301507541, (2011, 2) = 0.20802744102675557e-16, (2012, 1) = -.40500367472675913, (2012, 2) = -0.8322021030617484e-16, (2013, 1) = -.40413761930276415, (2013, 2) = -0.12484414131293919e-15, (2014, 1) = -.40327156387876917, (2014, 2) = -0.4161931405004237e-16, (2015, 1) = -.4024055084547742, (2015, 2) = -0.18730757691585232e-15, (2016, 1) = -.4015394530307792, (2016, 2) = -0.8325697911158048e-16, (2017, 1) = -.4006733976067842, (2017, 2) = 0.8326612952911705e-16, (2018, 1) = -.39980734218278924, (2018, 2) = 0.1040940789966583e-15, (2019, 1) = -.39894128675879426, (2019, 2) = 0.20821095024586802e-16, (2020, 1) = -.3954770650628143, (2020, 2) = -0.2083016991851875e-16, (2021, 1) = -.3920128433668344, (2021, 2) = -0.6251753216370466e-16, (2022, 1) = -.3911467879428394, (2022, 2) = 0.18757276818258263e-15, (2023, 1) = -.39028073251884443, (2023, 2) = -0.10421827874930647e-15, (2024, 1) = -.38941467709484945, (2024, 2) = 0.6253766571666338e-16, (2025, 1) = -.38854862167085447, (2025, 2) = 0.10424058574817738e-15, (2026, 1) = -.3876825662468595, (2026, 2) = -0.6255102443313746e-16, (2027, 1) = -.3868165108228645, (2027, 2) = -0.10426280776033071e-15, (2028, 1) = -.3859504553988695, (2028, 2) = -0.6256433210494875e-16, (2029, 1) = -.38508439997487454, (2029, 2) = 0.12514193353253096e-15, (2030, 1) = -.3816201782788946, (2030, 2) = 0.2086579242511914e-16, (2031, 1) = -.3781559565829147, (2031, 2) = -0.6262358214029808e-16, (2032, 1) = -.3771612604428393, (2032, 2) = 0.626310683320978e-16, (2033, 1) = -.37616656430276396, (2033, 2) = 0.1252770749623803e-15, (2034, 1) = -.37517186816268855, (2034, 2) = 0.41763993045332736e-16, (2035, 1) = -.3741771720226132, (2035, 2) = 0.8353789943064093e-16, (2036, 1) = -.37318247588253783, (2036, 2) = 0.10443473746103857e-15, (2037, 1) = -.3721877797424624, (2037, 2) = -0.6266824325944698e-16, (2038, 1) = -.37119308360238706, (2038, 2) = 0.626756269020052e-16, (2039, 1) = -.3701983874623117, (2039, 2) = -0.1253659867697668e-15, (2040, 1) = -.36920369132223635, (2040, 2) = 0.8358712358493315e-16, (2041, 1) = -.368208995182161, (2041, 2) = 0.6269767479410576e-16, (2042, 1) = -.3672142990420856, (2042, 2) = 0.2090166322726174e-16, (2043, 1) = -.3662196029020102, (2043, 2) = -0.41808191554970336e-16, (2044, 1) = -.36522490676193486, (2044, 2) = -0.14634565802935658e-15, (2045, 1) = -.36423021062185945, (2045, 2) = -0.20908943615267977e-16, (2046, 1) = -.3632355144817841, (2046, 2) = 0.8364543556011115e-16, (2047, 1) = -.36224081834170874, (2047, 2) = -0.4182753678703764e-16, (2048, 1) = -.360251426061558, (2048, 2) = .0, (2049, 1) = -.35826203378140725, (2049, 2) = 0.10461674283765212e-15, (2050, 1) = -.3572673376413319, (2050, 2) = 0.10462864559664188e-15, (2051, 1) = -.3562726415012565, (2051, 2) = .0, (2052, 1) = -.3552779453611811, (2052, 2) = -0.10465236394317436e-15, (2053, 1) = -.35428324922110577, (2053, 2) = -0.1465298512548394e-15, (2054, 1) = -.35229385694095505, (2054, 2) = -0.10468772306248048e-15, (2055, 1) = -.3503044646608043, (2055, 2) = 0.20942229968539928e-16, (2056, 1) = -.3493097685207289, (2056, 2) = 0.14661194708907484e-15, (2057, 1) = -.3483150723806535, (2057, 2) = -0.6284067573530189e-16, (2058, 1) = -.34732037624057815, (2058, 2) = -0.6284764226408642e-16, (2059, 1) = -.3463256801005028, (2059, 2) = -0.4190306078490953e-16, (2060, 1) = -.3453906134359299, (2060, 2) = -0.20953702480475162e-16, (2061, 1) = -.34445554677135704, (2061, 2) = -0.8382347747586433e-16, (2062, 1) = -.34352048010678415, (2062, 2) = 0.10479015526404027e-15, (2063, 1) = -.34258541344221133, (2063, 2) = -0.6288056258067311e-16, (2064, 1) = -.3416503467776385, (2064, 2) = 0.2096233878611445e-15, (2065, 1) = -.3407152801130656, (2065, 2) = 0.10482242412693605e-15, (2066, 1) = -.33978021344849274, (2066, 2) = -0.1886996307566499e-15, (2067, 1) = -.33884514678391986, (2067, 2) = -0.2096876122376414e-16, (2068, 1) = -.337910080119347, (2068, 2) = 0.10485445786366968e-15, (2069, 1) = -.3369750134547741, (2069, 2) = 0.1887571501333594e-15, (2070, 1) = -.3360399467902012, (2070, 2) = 0.20975136544972353e-16, (2071, 1) = -.3351048801256284, (2071, 2) = -0.41954502316328886e-16, (2072, 1) = -.33416981346105556, (2072, 2) = 0.1258761630962216e-15, (2073, 1) = -.3332347467964827, (2073, 2) = -0.20981464613575865e-16, (2074, 1) = -.3322996801319098, (2074, 2) = -0.4196712689155414e-16, (2075, 1) = -.3313646134673369, (2075, 2) = -0.4197131401529236e-16, (2076, 1) = -.32762434680904545, (2076, 2) = -0.6298193535677917e-16, (2077, 1) = -.323884080150754, (2077, 2) = -0.10501107587291804e-15, (2078, 1) = -.3201438134924625, (2078, 2) = -0.210103668597565e-16, (2079, 1) = -.31640354683417105, (2079, 2) = 0.2101843319550895e-16, (2080, 1) = -.31547751189384443, (2080, 2) = 0.8408166833614214e-16, (2081, 1) = -.3145514769535178, (2081, 2) = 0.18920156145395016e-15, (2082, 1) = -.3136254420131912, (2082, 2) = 0.21024369090054714e-16, (2083, 1) = -.31269940707286453, (2083, 2) = -0.1471843603876006e-15, (2084, 1) = -.31177337213253786, (2084, 2) = 0.8411320014793264e-16, (2085, 1) = -.31084733719221125, (2085, 2) = 0.6309077280505216e-16, (2086, 1) = -.30992130225188463, (2086, 2) = 0.2103220988770733e-16, (2087, 1) = -.308995267311558, (2087, 2) = 0.14723909823307364e-15, (2088, 1) = -.3080692323712314, (2088, 2) = 0.10518049302637826e-15, (2089, 1) = -.3071431974309048, (2089, 2) = -0.42076070055247026e-16, (2090, 1) = -.3062171624905782, (2090, 2) = .0, (2091, 1) = -.3052911275502515, (2091, 2) = .0, (2092, 1) = -.30436509260992484, (2092, 2) = 0.8417524997581494e-16, (2093, 1) = -.3034390576695982, (2093, 2) = -0.841829108024683e-16, (2094, 1) = -.3025130227292716, (2094, 2) = 0.42095275183956794e-16, (2095, 1) = -.301586987788945, (2095, 2) = -0.631486264905182e-16, (2096, 1) = -.3006609528486184, (2096, 2) = 0.21051441410678857e-16, (2097, 1) = -.29973491790829176, (2097, 2) = -0.8421334131594395e-16, (2098, 1) = -.29880888296796515, (2098, 2) = 0.6316567174178138e-16, (2099, 1) = -.2978828480276385, (2099, 2) = 0.8422842864404982e-16, (2100, 1) = -.2969568130873118, (2100, 2) = -0.2105898506576267e-16, (2101, 1) = -.2960307781469852, (2101, 2) = -0.10530428811854509e-15, (2102, 1) = -.2951047432066586, (2102, 2) = -0.42125449660786673e-16, (2103, 1) = -.29417870826633197, (2103, 2) = 0.1474521067695764e-15, (2104, 1) = -.29325267332600535, (2104, 2) = -0.16853154537757007e-15, (2105, 1) = -.29232663838567874, (2105, 2) = -0.21068294298451682e-16, (2106, 1) = -.2914006034453521, (2106, 2) = 0.4214028011143753e-16, (2107, 1) = -.29047456850502545, (2107, 2) = -0.2107198043959265e-16, (2108, 1) = -.2895485335646988, (2108, 2) = -0.10536907722839629e-15, (2109, 1) = -.28862249862437217, (2109, 2) = 0.2107564506959526e-16, (2110, 1) = -.28769646368404556, (2110, 2) = 0.6323240792090446e-16, (2111, 1) = -.28677042874371894, (2111, 2) = -0.2107928815343624e-16, (2112, 1) = -.2719420830150756, (2112, 2) = -0.10553837513580722e-16, (2113, 1) = -.2571137372864323, (2113, 2) = 0.6340398330151759e-16, (2114, 1) = -.25333274378140713, (2114, 2) = 0.4228263192801426e-16, (2115, 1) = -.249551750276382, (2115, 2) = -0.5286969597644592e-16, (2116, 1) = -.2486065019001257, (2116, 2) = 0.10574752261344068e-15, (2117, 1) = -.24766125352386942, (2117, 2) = -0.21151124856712646e-16, (2118, 1) = -.24671600514761313, (2118, 2) = 0.12691643633123167e-15, (2119, 1) = -.24577075677135685, (2119, 2) = 0.200966307083625e-15, (2120, 1) = -.24482550839510056, (2120, 2) = -0.21155951029207025e-16, (2121, 1) = -.24388026001884427, (2121, 2) = -0.13752406284427361e-15, (2122, 1) = -.242935011642588, (2122, 2) = -0.12695483647229113e-15, (2123, 1) = -.2419897632663317, (2123, 2) = -0.10580362435820027e-16, (2124, 1) = -.24009926651381913, (2124, 2) = 0.42327756613983416e-16, (2125, 1) = -.23820876976130656, (2125, 2) = 0.12700205042295055e-15, (2126, 1) = -.23726352138505027, (2126, 2) = 0.7408997641611484e-16, (2127, 1) = -.236318273008794, (2127, 2) = -0.529252878255858e-16, (2128, 1) = -.2353730246325377, (2128, 2) = 0.4234331943923509e-16, (2129, 1) = -.23442777625628142, (2129, 2) = 0.14821238918168656e-15, (2130, 1) = -.23348252788002513, (2130, 2) = .0, (2131, 1) = -.23253727950376885, (2131, 2) = -0.20117445427962175e-15, (2132, 1) = -.23159203112751256, (2132, 2) = -0.7412222822618231e-16, (2133, 1) = -.23064678275125627, (2133, 2) = 0.16943435816848419e-15, (2134, 1) = -.229701534375, (2134, 2) = 0.21180804174945808e-16, (2135, 1) = -.2287562859987437, (2135, 2) = -0.14827615390693048e-15, (2136, 1) = -.22781103762248742, (2136, 2) = -0.10591902672673073e-15, (2137, 1) = -.22686578924623113, (2137, 2) = 0.11651913407299252e-15, (2138, 1) = -.210834630150754, (2138, 2) = 0.10604848484014125e-16, (2139, 1) = -.19480347105527684, (2139, 2) = -0.10616192465937432e-16, (2140, 1) = -.19296609567211098, (2140, 2) = -0.2123487514435111e-16, (2141, 1) = -.19112872028894512, (2141, 2) = -0.3185601393294197e-16, (2142, 1) = -.1902100325973622, (2142, 2) = 0.14866997479337565e-15, (2143, 1) = -.18929134490577926, (2143, 2) = -0.6371936202155551e-16, (2144, 1) = -.18837265721419633, (2144, 2) = -0.7434350405177748e-16, (2145, 1) = -.1874539695226134, (2145, 2) = 0.11683215101824166e-15, (2146, 1) = -.18653528183103046, (2146, 2) = -0.7435194092456719e-16, (2147, 1) = -.18561659413944753, (2147, 2) = 0.8497843361907099e-16, (2148, 1) = -.1846979064478646, (2148, 2) = 0.8498319763683297e-16, (2149, 1) = -.18377921875628167, (2149, 2) = -0.12748190821877755e-15, (2150, 1) = -.18286053106469874, (2150, 2) = -0.21248164283619602e-16, (2151, 1) = -.1819418433731158, (2151, 2) = -0.1274960288866755e-15, (2152, 1) = -.18102315568153288, (2152, 2) = -0.4250101258544536e-16, (2153, 1) = -.18010446798994995, (2153, 2) = -0.10625834357788638e-16, (2154, 1) = -.1727549664572865, (2154, 2) = -0.5315190440718991e-16, (2155, 1) = -.16540546492462305, (2155, 2) = -0.9571269143075583e-16, (2156, 1) = -.1644986022079145, (2156, 2) = 0.319058070560214e-16, (2157, 1) = -.16359173949120598, (2157, 2) = 0.8508633386488587e-16, (2158, 1) = -.16268487677449744, (2158, 2) = 0.53181558171788855e-16, (2159, 1) = -.1617780140577889, (2159, 2) = 0.20209974570208045e-15, (2160, 1) = -.16087115134108038, (2160, 2) = -0.8509874393821979e-16, (2161, 1) = -.15996428862437184, (2161, 2) = -0.8510283557171153e-16, (2162, 1) = -.1590574259076633, (2162, 2) = 0.11702199390736953e-15, (2163, 1) = -.15815056319095477, (2163, 2) = -0.10638868899123155e-16, (2164, 1) = -.15724370047424624, (2164, 2) = 0.9575434705633714e-16, (2165, 1) = -.1563368377575377, (2165, 2) = 0.10639872069350463e-15, (2166, 1) = -.15542997504082917, (2166, 2) = 0.19152664956938538e-15, (2167, 1) = -.15452311232412064, (2167, 2) = -0.20217641500174961e-15, (2168, 1) = -.1536162496074121, (2168, 2) = -0.17026169038357397e-15, (2169, 1) = -.15270938689070357, (2169, 2) = 0.31925533571616466e-16, (2170, 1) = -.15180252417399503, (2170, 2) = -0.9578097513877981e-16, (2171, 1) = -.1508956614572865, (2171, 2) = -0.42571255156434966e-16, (2172, 1) = -.14726821059045236, (2172, 2) = -0.5322359174336967e-16, (2173, 1) = -.14364075972361823, (2173, 2) = -0.14372879695796277e-15, (2174, 1) = -.1427338970069097, (2174, 2) = -0.8517628206449939e-16, (2175, 1) = -.14182703429020116, (2175, 2) = 0.7453243086328868e-16, (2176, 1) = -.14092017157349263, (2176, 2) = 0.2129588429426603e-16, (2177, 1) = -.1400133088567841, (2177, 2) = 0.37269369649347416e-16, (2178, 1) = -.13910644614007556, (2178, 2) = 0.15973256498990768e-16, (2179, 1) = -.13819958342336702, (2179, 2) = -0.10649281158877284e-16, (2180, 1) = -.1372927207066585, (2180, 2) = 0.5324860902979808e-17, (2181, 1) = -.13638585798994995, (2181, 2) = 0.9585143645554642e-16, (2182, 1) = -.13250817271356807, (2182, 2) = 0.47933997633309165e-16, (2183, 1) = -.1286304874371862, (2183, 2) = -0.5326893594986433e-17, (2184, 1) = -.12475280216080431, (2184, 2) = 0.6393313604672153e-16, (2185, 1) = -.12087511688442243, (2185, 2) = 0.11190066142849303e-15, (2186, 1) = -.11893627424623149, (2186, 2) = 0.5861915289475668e-16, (2187, 1) = -.11699743160804055, (2187, 2) = -0.21317673285387816e-16, (2188, 1) = -.11602801028894508, (2188, 2) = 0.11192197954661254e-15, (2189, 1) = -.1150585889698496, (2189, 2) = -0.9060687516425084e-16, (2190, 1) = -.11408916765075414, (2190, 2) = -0.17589041772216898e-15, (2191, 1) = -.11311974633165867, (2191, 2) = 0.10660414978892288e-16, (2192, 1) = -.11118090369346773, (2192, 2) = 0.21322368907704153e-16, (2193, 1) = -.10924206105527678, (2193, 2) = 0.11728134867419223e-15, (2194, 1) = -.10827263973618131, (2194, 2) = -0.3198694207704766e-16, (2195, 1) = -.10730321841708584, (2195, 2) = 0.5331341987293466e-17, (2196, 1) = -.10633379709799037, (2196, 2) = -0.12262508229380325e-15, (2197, 1) = -.1053643757788949, (2197, 2) = 0.9597072603266759e-16, (2198, 1) = -.1043970648052768, (2198, 2) = -0.26659433253618306e-16, (2199, 1) = -.1034297538316587, (2199, 2) = -0.6931684058841777e-16, (2200, 1) = -.1024624428580406, (2200, 2) = -0.10131257959073905e-15, (2201, 1) = -.1014951318844225, (2201, 2) = -0.47991741854087124e-16, (2202, 1) = -.1005278209108044, (2202, 2) = -0.15997766554748014e-16, (2203, 1) = -0.9956050993718629e-1, (2203, 2) = -0.5866036330728577e-16, (2204, 1) = -0.9859319896356819e-1, (2204, 2) = 0.9065981184156307e-16, (2205, 1) = -0.9762588798995009e-1, (2205, 2) = .0, (2206, 1) = -0.9665857701633199e-1, (2206, 2) = .0, (2207, 1) = -0.9569126604271389e-1, (2207, 2) = 0.3200057806878286e-16, (2208, 1) = -0.9472395506909578e-1, (2208, 2) = -0.11733904414003065e-15, (2209, 1) = -0.9375664409547768e-1, (2209, 2) = -0.9067382665383183e-16, (2210, 1) = -0.9278933312185958e-1, (2210, 2) = 0.9601046025226955e-16, (2211, 1) = -0.9182202214824148e-1, (2211, 2) = -0.6400887315890239e-16, (2212, 1) = -0.9085471117462338e-1, (2212, 2) = -0.106684588459105e-16, (2213, 1) = -0.8988740020100527e-1, (2213, 2) = 0.10668768874326127e-15, (2214, 1) = -0.8601815630653287e-1, (2214, 2) = 0.3200992818219975e-16, (2215, 1) = -0.8214891241206046e-1, (2215, 2) = -0.3201339157041806e-16, (2216, 1) = -0.8118160143844236e-1, (2216, 2) = 0.37349938132483404e-16, (2217, 1) = -0.8021429046482426e-1, (2217, 2) = 0.9070934772183352e-16, (2218, 1) = -0.7924697949120615e-1, (2218, 2) = 0.32015885218611706e-16, (2219, 1) = -0.7827966851758805e-1, (2219, 2) = 0.10672232211019196e-16, (2220, 1) = -0.7731235754396995e-1, (2220, 2) = 0.10672499380965353e-16, (2221, 1) = -0.7634504657035185e-1, (2221, 2) = 0.18677335685102096e-15, (2222, 1) = -0.7537773559673375e-1, (2222, 2) = 0.112066750039394e-15, (2223, 1) = -0.7441042462311565e-1, (2223, 2) = -0.1707724971868033e-15, (2224, 1) = -0.7354220558103021e-1, (2224, 2) = 0.12808211000513082e-15, (2225, 1) = -0.7267398653894477e-1, (2225, 2) = 0.5870554028559285e-16, (2226, 1) = -0.7180576749685934e-1, (2226, 2) = 0.10940806298639849e-15, (2227, 1) = -0.709375484547739e-1, (2227, 2) = -0.19480373879157097e-15, (2228, 1) = -0.7006932941268847e-1, (2228, 2) = -0.15744732488413281e-15, (2229, 1) = -0.6920111037060303e-1, (2229, 2) = -0.6404765809283866e-16, (2230, 1) = -0.683328913285176e-1, (2230, 2) = -0.8806727978210664e-16, (2231, 1) = -0.6746467228643216e-1, (2231, 2) = 0.12009410140290027e-15, (2232, 1) = -0.6399179611809042e-1, (2232, 2) = 0.11209634464099439e-15, (2233, 1) = -0.6051891994974867e-1, (2233, 2) = 0.8007458078729983e-17, (2234, 1) = -0.587824818655778e-1, (2234, 2) = 0.4270791587233935e-16, (2235, 1) = -0.5704604378140693e-1, (2235, 2) = 0.4537868005165116e-16, (2236, 1) = -0.56177824739321494e-1, (2236, 2) = -0.13079951260900082e-15, (2237, 1) = -0.5530960569723606e-1, (2237, 2) = 0.1414793038891078e-15, (2238, 1) = -0.5444138665515062e-1, (2238, 2) = 0.14682047489101297e-15, (2239, 1) = -0.5357316761306519e-1, (2239, 2) = -0.17618732098915961e-15, (2240, 1) = -0.5270494857097975e-1, (2240, 2) = -0.17885957388689635e-15, (2241, 1) = -0.51836729528894315e-1, (2241, 2) = 0.4004379339081653e-16, (2242, 1) = -0.5096851048680888e-1, (2242, 2) = -0.12280279162161411e-15, (2243, 1) = -0.50100291444723444e-1, (2243, 2) = -0.5339329830218344e-17, (2244, 1) = -0.4923207240263801e-1, (2244, 2) = .0, (2245, 1) = -0.4836385336055257e-1, (2245, 2) = -0.10411989626712084e-15, (2246, 1) = -0.47495634318467136e-1, (2246, 2) = -0.40046669014202627e-16, (2247, 1) = -0.466274152763817e-1, (2247, 2) = -0.24028328428373913e-16, (2248, 1) = -0.4559894721105508e-1, (2248, 2) = -0.26698564463992518e-16, (2249, 1) = -0.4457047914572845e-1, (2249, 2) = -0.7742703284302311e-16, (2250, 1) = -0.4354201108040183e-1, (2250, 2) = 0.854380154629592e-16, (2251, 1) = -0.42513543015075206e-1, (2251, 2) = 0.2669977343197491e-17, (2252, 1) = -0.4045660688442196e-1, (2252, 2) = -0.8010159737027595e-17, (2253, 1) = -0.3839967075376871e-1, (2253, 2) = -0.11748551719147537e-15, (2254, 1) = -0.34285798492462216e-1, (2254, 2) = .0, (2255, 1) = -0.3017192623115572e-1, (2255, 2) = 0.4005564568361986e-16, (2256, 1) = -0.2194418170854273e-1, (2256, 2) = 0.26705671834811037e-16, (2257, 1) = -0.13716437185929742e-1, (2257, 2) = -0.6676744414276193e-16, (2258, 1) = -0.11995288417085526e-1, (2258, 2) = 0.1335358731369121e-17, (2259, 1) = -0.1027413964824131e-1, (2259, 2) = 0.12619220621511217e-15, (2260, 1) = -0.9413565263819201e-2, (2260, 2) = -0.9681439983554242e-16, (2261, 1) = -0.8552990879397093e-2, (2261, 2) = -0.11784679726685513e-15, (2262, 1) = -0.7692416494974985e-2, (2262, 2) = -0.9080567576104399e-16, (2263, 1) = -0.6831842110552877e-2, (2263, 2) = 0.39393720812774675e-16, (2264, 1) = -0.5971267726130769e-2, (2264, 2) = -0.6075991825144748e-16, (2265, 1) = -0.5110693341708661e-2, (2265, 2) = 0.159244654244179e-15, (2266, 1) = -0.4250118957286553e-2, (2266, 2) = -0.7177703696021608e-17, (2267, 1) = -0.33895445728644447e-2, (2267, 2) = 0.1200180142401461e-15, (2268, 1) = -0.25289701884423366e-2, (2268, 2) = -0.4907555791343083e-16, (2269, 1) = -0.16683958040202285e-2, (2269, 2) = 0.10040464576881005e-15, (2270, 1) = -0.8078214195981204e-3, (2270, 2) = 0.731960977663649e-16, (2271, 1) = 0.52752964823987725e-4, (2271, 2) = -0.117574374592121e-15, (2272, 1) = 0.69373480402008525e-2, (2272, 2) = -0.5575211680423016e-16, (2273, 1) = 0.13821943115577717e-1, (2273, 2) = -0.5341392945047707e-17, (2274, 1) = 0.4603117206030127e-1, (2274, 2) = 0.12548242527247554e-15, (2275, 1) = 0.5371631924623099e-1, (2275, 2) = 0.7474594502734436e-16, (2276, 1) = 0.6140146643216071e-1, (2276, 2) = 0.3736746839804874e-16, (2277, 1) = 0.6236210983040193e-1, (2277, 2) = 0.1601431238417255e-15, (2278, 1) = 0.6332275322864314e-1, (2278, 2) = 0.7206295749385416e-16, (2279, 1) = 0.6428339662688436e-1, (2279, 2) = 0.16547452618535426e-15, (2280, 1) = 0.6524404002512557e-1, (2280, 2) = 0.667222174819657e-16, (2281, 1) = 0.6620468342336679e-1, (2281, 2) = -0.8807147617923846e-16, (2282, 1) = 0.67165326821608e-1, (2282, 2) = -0.1200949068386945e-15, (2283, 1) = 0.6812597021984922e-1, (2283, 2) = -0.6938666767601285e-16, (2284, 1) = 0.6908661361809043e-1, (2284, 2) = 0.3469257287194996e-16, (2285, 1) = 0.7100790041457286e-1, (2285, 2) = 0.1867977953132541e-16, (2286, 1) = 0.7292918721105529e-1, (2286, 2) = -0.8538934889338953e-16, (2287, 1) = 0.738898306092965e-1, (2287, 2) = -0.16010127241311958e-16, (2288, 1) = 0.7485047400753772e-1, (2288, 2) = -0.10139506228099218e-15, (2289, 1) = 0.7581111740577894e-1, (2289, 2) = 0.16009361222461493e-16, (2290, 1) = 0.7677176080402015e-1, (2290, 2) = 0.20278029783765077e-15, (2291, 1) = 0.7762950093278899e-1, (2291, 2) = -0.16008618225337283e-16, (2292, 1) = 0.7848724106155783e-1, (2292, 2) = 0.1067217444949785e-16, (2293, 1) = 0.7934498119032667e-1, (2293, 2) = 0.4802370368829295e-16, (2294, 1) = 0.802027213190955e-1, (2294, 2) = -0.1654112145473712e-15, (2295, 1) = 0.8106046144786434e-1, (2295, 2) = -0.11738590351984235e-15, (2296, 1) = 0.8191820157663318e-1, (2296, 2) = -0.106711976937239e-16, (2297, 1) = 0.8277594170540202e-1, (2297, 2) = -0.10670947019243388e-15, (2298, 1) = 0.8363368183417086e-1, (2298, 2) = -0.10670693751639533e-16, (2299, 1) = 0.844914219629397e-1, (2299, 2) = -0.8002828418600937e-16, (2300, 1) = 0.8534916209170854e-1, (2300, 2) = 0.20273340934650471e-15, (2301, 1) = 0.8620690222047737e-1, (2301, 2) = 0.7468942876970225e-16, (2302, 1) = 0.8706464234924621e-1, (2302, 2) = -0.5334827380593208e-17, (2303, 1) = 0.8792238247801505e-1, (2303, 2) = -0.14937143950976423e-15, (2304, 1) = 0.8878012260678389e-1, (2304, 2) = 0.6934927819255353e-16, (2305, 1) = 0.8963786273555273e-1, (2305, 2) = -0.5334424159167188e-17, (2306, 1) = 0.9049560286432157e-1, (2306, 2) = -0.11202003042526517e-15, (2307, 1) = 0.9392656337939692e-1, (2307, 2) = 0.53337262423079385e-17, (2308, 1) = 0.9735752389447228e-1, (2308, 2) = 0.1226623266706147e-15, (2309, 1) = .10078848440954763, (2309, 2) = 0.5865796607126657e-16, (2310, 1) = .10421944492462298, (2310, 2) = -0.42655355681431076e-16, (2311, 1) = .11965334065326627, (2311, 2) = 0.5861748933767739e-16, (2312, 1) = .13508723638190956, (2312, 2) = 0.12248398809991742e-15, (2313, 1) = .1506234379899496, (2313, 2) = 0.10642958290047928e-15, (2314, 1) = .16615963959798963, (2314, 2) = 0.4253721723140017e-16, (2315, 1) = .1671260371451002, (2315, 2) = 0.425349547912076e-16, (2316, 1) = .16809243469221075, (2316, 2) = 0.1063316989868651e-15, (2317, 1) = .1690588322393213, (2317, 2) = 0.21265195824116644e-16, (2318, 1) = .17002522978643186, (2318, 2) = 0.10632022739480042e-15, (2319, 1) = .17099162733354242, (2319, 2) = .0, (2320, 1) = .17195802488065298, (2320, 2) = 0.7441603989935703e-16, (2321, 1) = .17292442242776354, (2321, 2) = -0.10630278121795438e-15, (2322, 1) = .1738908199748741, (2322, 2) = -0.1275562826545046e-15, (2323, 1) = .17582361506909522, (2323, 2) = -0.7439953421325761e-16, (2324, 1) = .17775641016331634, (2324, 2) = -0.42509227419571166e-16, (2325, 1) = .1787228077104269, (2325, 2) = 0.8501362464354404e-16, (2326, 1) = .17968920525753745, (2326, 2) = 0.23377411499468465e-15, (2327, 1) = .180655602804648, (2327, 2) = -0.3187645807074801e-16, (2328, 1) = .18162200035175857, (2328, 2) = 0.9562385470037267e-16, (2329, 1) = .1835547954459797, (2329, 2) = -0.10623636693304055e-16, (2330, 1) = .1854875905402008, (2330, 2) = -0.8497910396820743e-16, (2331, 1) = .18645398808731137, (2331, 2) = 0.1062175890933895e-16, (2332, 1) = .18742038563442193, (2332, 2) = -0.10621126666229842e-16, (2333, 1) = .18838678318153249, (2333, 2) = 0.42481965073664003e-16, (2334, 1) = .18935318072864304, (2334, 2) = -0.42479410870491403e-16, (2335, 1) = .1903195782757536, (2335, 2) = 0.11681132117142191e-15, (2336, 1) = .19128597582286416, (2336, 2) = 0.10618566164040298e-15, (2337, 1) = .19225237336997472, (2337, 2) = -0.743254271531919e-16, (2338, 1) = .19321877091708528, (2338, 2) = -0.31851801058336147e-16, (2339, 1) = .19418516846419584, (2339, 2) = -0.636996763794999e-16, (2340, 1) = .1951515660113064, (2340, 2) = 0.9554359768135886e-16, (2341, 1) = .19611796355841696, (2341, 2) = -0.1061529472526289e-15, (2342, 1) = .19708436110552752, (2342, 2) = -0.9553167912337314e-16, (2343, 1) = .19798033533919585, (2343, 2) = -0.9552611579026104e-16, (2344, 1) = .1988763095728642, (2344, 2) = 0.16981427235776681e-15, (2345, 1) = .19977228380653256, (2345, 2) = .0, (2346, 1) = .2006682580402009, (2346, 2) = 0.955092803075285e-16, (2347, 1) = .20156423227386921, (2347, 2) = 0.6366908001931881e-16, (2348, 1) = .20246020650753757, (2348, 2) = .0, (2349, 1) = .20335618074120593, (2349, 2) = 0.10610247430472555e-16, (2350, 1) = .20425215497487426, (2350, 2) = -0.2015825984962475e-15, (2351, 1) = .20514812920854258, (2351, 2) = -0.53044853894990116e-16, (2352, 1) = .20604410344221094, (2352, 2) = 0.53041642137191383e-16, (2353, 1) = .2069400776758793, (2353, 2) = -0.14850756751574578e-15, (2354, 1) = .20783605190954763, (2354, 2) = 0.10607035680124617e-15, (2355, 1) = .20873202614321595, (2355, 2) = 0.16970216459789155e-15, (2356, 1) = .2096280003768843, (2356, 2) = 0.53028661086099944e-16, (2357, 1) = .21052397461055267, (2357, 2) = -0.21210152942385927e-16, (2358, 1) = .211419948844221, (2358, 2) = 0.1166485985588647e-15, (2359, 1) = .21858774271356773, (2359, 2) = 0.6359432756920897e-16, (2360, 1) = .22575553658291447, (2360, 2) = 0.10593520872866105e-16, (2361, 1) = .2276109954271356, (2361, 2) = .0, (2362, 1) = .2294664542713567, (2362, 2) = -0.12708707187667144e-15, (2363, 1) = .23039418369346726, (2363, 2) = 0.31769548057306136e-16, (2364, 1) = .23132191311557782, (2364, 2) = 0.42356426208739434e-16, (2365, 1) = .23224964253768837, (2365, 2) = 0.20117885755854658e-15, (2366, 1) = .23317737195979893, (2366, 2) = .0, (2367, 1) = .2341051013819095, (2367, 2) = 0.9528175072783238e-16, (2368, 1) = .23503283080402004, (2368, 2) = -0.11644717800727155e-15, (2369, 1) = .2359605602261306, (2369, 2) = -0.317560505122193e-16, (2370, 1) = .23688828964824116, (2370, 2) = -0.4233836172540453e-16, (2371, 1) = .23781601907035171, (2371, 2) = -0.3175148362581398e-16, (2372, 1) = .23874374849246227, (2372, 2) = -0.6349837502624182e-16, (2373, 1) = .23967147791457283, (2373, 2) = -0.13756982616698799e-15, (2374, 1) = .24059920733668338, (2374, 2) = 0.740706632795407e-16, (2375, 1) = .24152693675879394, (2375, 2) = 0.3174224856479654e-16, (2376, 1) = .2424546661809045, (2376, 2) = -0.6347983746171608e-16, (2377, 1) = .24338239560301506, (2377, 2) = 0.317375804808428e-16, (2378, 1) = .2443101250251256, (2378, 2) = 0.10578411273493813e-16, (2379, 1) = .24523785444723617, (2379, 2) = 0.10577626251840976e-16, (2380, 1) = .24616558386934673, (2380, 2) = .0, (2381, 1) = .24709331329145728, (2381, 2) = -0.21152095623267826e-16, (2382, 1) = .24802104271356784, (2382, 2) = 0.21150508793885533e-15, (2383, 1) = .25173196040201007, (2383, 2) = 0.8457642255690107e-16, (2384, 1) = .2554428780904523, (2384, 2) = -0.3170642000000497e-16, (2385, 1) = .27079422361809025, (2385, 2) = -0.6332944276200843e-16, (2386, 1) = .2861455691457282, (2386, 2) = -0.12648307443738808e-15, (2387, 1) = .2871019512437182, (2387, 2) = -0.1264718257336615e-15, (2388, 1) = .2880583333417081, (2388, 2) = 0.4215351417063231e-16, (2389, 1) = .28901471543969803, (2389, 2) = 0.10537435400073131e-15, (2390, 1) = .289971097537688, (2390, 2) = -0.8429191508630725e-16, (2391, 1) = .290927479635678, (2391, 2) = 0.8428432401771868e-16, (2392, 1) = .2918838617336679, (2392, 2) = -0.6320753251061694e-16, (2393, 1) = .29284024383165785, (2393, 2) = 0.42134536547502284e-16, (2394, 1) = .29379662592964784, (2394, 2) = 0.8426141327969903e-16, (2395, 1) = .2947530080276378, (2395, 2) = -0.1263805958815837e-15, (2396, 1) = .29570939012562775, (2396, 2) = 0.12636903755790988e-15, (2397, 1) = .2966657722236177, (2397, 2) = 0.8423829665193158e-16, (2398, 1) = .29762215432160766, (2398, 2) = 0.6317290908549447e-16, (2399, 1) = .29857853641959764, (2399, 2) = -0.6316707858334981e-16, (2400, 1) = .29953491851758757, (2400, 2) = 0.1263224619946165e-15, (2401, 1) = .3004913006155775, (2401, 2) = -0.8420715512293245e-16, (2402, 1) = .3014476827135675, (2402, 2) = -0.12629896926577672e-15, (2403, 1) = .30240406481155746, (2403, 2) = -0.8419144784570191e-16, (2404, 1) = .3033604469095474, (2404, 2) = 0.4209178007420019e-16, (2405, 1) = .3043168290075373, (2405, 2) = 0.10521956221488693e-15, (2406, 1) = .3052732111055273, (2406, 2) = -0.8416771673623967e-16, (2407, 1) = .3071859753015072, (2407, 2) = 0.21037945691909856e-16, (2408, 1) = .3090987394974871, (2408, 2) = 0.8413575840362169e-16, (2409, 1) = .3100551215954771, (2409, 2) = -0.16825542474771028e-15, (2410, 1) = .31101150369346703, (2410, 2) = -0.10514955475744493e-15, (2411, 1) = .31196788579145696, (2411, 2) = 0.16822310544052267e-15, (2412, 1) = .31292426788944694, (2412, 2) = .0, (2413, 1) = .31483703208542685, (2413, 2) = 0.4204357228023463e-16, (2414, 1) = .31674979628140676, (2414, 2) = 0.10508845029985638e-15, (2415, 1) = .3324899009547737, (2415, 2) = 0.41966273813450055e-16, (2416, 1) = .34823000562814066, (2416, 2) = -0.628412722035759e-16, (2417, 1) = .34909649892587935, (2417, 2) = -0.4189012702302825e-16, (2418, 1) = .34996299222361804, (2418, 2) = -0.8377212736451939e-16, (2419, 1) = .35082948552135673, (2419, 2) = 0.6282298718244846e-16, (2420, 1) = .3516959788190954, (2420, 2) = 0.10469477587345123e-15, (2421, 1) = .3525624721168341, (2421, 2) = 0.16749528149500868e-15, (2422, 1) = .3534289654145728, (2422, 2) = -0.16747888614536876e-15, (2423, 1) = .3542954587123115, (2423, 2) = -0.6279842076813834e-16, (2424, 1) = .3551619520100502, (2424, 2) = -0.10465374327322694e-15, (2425, 1) = .3560284453077889, (2425, 2) = -0.6278605790435957e-16, (2426, 1) = .35689493860552757, (2426, 2) = 0.2092661886729384e-16, (2427, 1) = .35776143190326626, (2427, 2) = -0.8369818942532648e-16, (2428, 1) = .35862792520100495, (2428, 2) = -0.20922471439404155e-16, (2429, 1) = .35949441849874364, (2429, 2) = 0.20920391120689015e-16, (2430, 1) = .36036091179648233, (2430, 2) = 0.1255098384262222e-15, (2431, 1) = .361227405094221, (2431, 2) = 0.4183243458927791e-16, (2432, 1) = .3620938983919597, (2432, 2) = -0.10457061897846047e-15, (2433, 1) = .3629603916896984, (2433, 2) = -0.10456012955866804e-15, (2434, 1) = .3638268849874371, (2434, 2) = -0.6272977094092159e-16, (2435, 1) = .3646933782851758, (2435, 2) = 0.14635471903940781e-15, (2436, 1) = .3655598715829145, (2436, 2) = 0.104528529959622e-15, (2437, 1) = .36642636488065317, (2437, 2) = 0.14632513427061424e-15, (2438, 1) = .36729285817839186, (2438, 2) = 0.6270441259306777e-16, (2439, 1) = .36815935147613055, (2439, 2) = -0.12539608055382896e-15, (2440, 1) = .36902584477386924, (2440, 2) = -0.14628052808728403e-15, (2441, 1) = .372491817964824, (2441, 2) = -0.6266598295858841e-16, (2442, 1) = .37595779115577876, (2442, 2) = 0.6264010298793423e-16, (2443, 1) = .37693325738065314, (2443, 2) = -0.8351037587704028e-16, (2444, 1) = .3779087236055275, (2444, 2) = 0.835005925775809e-16, (2445, 1) = .3788841898304019, (2445, 2) = -0.6261809058263602e-16, (2446, 1) = .3798596560552763, (2446, 2) = -0.41740480249764044e-16, (2447, 1) = .38083512228015065, (2447, 2) = -0.10433888971293332e-15, (2448, 1) = .38181058850502503, (2448, 2) = 0.20865310320183703e-16, (2449, 1) = .3827860547298994, (2449, 2) = 0.6258851179162183e-16, (2450, 1) = .3837615209547738, (2450, 2) = -0.20860358779867844e-16, (2451, 1) = .38473698717964816, (2451, 2) = 0.2085787487438546e-16, (2452, 1) = .38571245340452254, (2452, 2) = 0.12513231332193858e-15, (2453, 1) = .3866879196293969, (2453, 2) = -0.6255867247175973e-16, (2454, 1) = .3876633858542713, (2454, 2) = 0.10425195345712275e-15, (2455, 1) = .38961431830402005, (2455, 2) = 0.6253612272959732e-16, (2456, 1) = .3915652507537688, (2456, 2) = 0.2084033625915752e-16, (2457, 1) = .3993689805527638, (2457, 2) = 0.6245990992072181e-16, (2458, 1) = .40717271035175884, (2458, 2) = 0.8319705266952144e-16, (2459, 1) = .4081521819346734, (2459, 2) = -0.4159328060049592e-16, (2460, 1) = .40913165351758796, (2460, 2) = -0.20794012126863069e-15, (2461, 1) = .4101111251005025, (2461, 2) = -0.18712240788385166e-15, (2462, 1) = .41109059668341713, (2462, 2) = 0.2078873988748689e-16, (2463, 1) = .41207006826633175, (2463, 2) = 0.1870748625113345e-15, (2464, 1) = .4130495398492463, (2464, 2) = .0, (2465, 1) = .41402901143216086, (2465, 2) = 0.1454655432663959e-15, (2466, 1) = .4150084830150754, (2466, 2) = 0.6233439606554612e-16, (2467, 1) = .41598795459799, (2467, 2) = 0.8310186755270013e-16, (2468, 1) = .41696742618090454, (2468, 2) = .0, (2469, 1) = .4179468977638191, (2469, 2) = 0.1038506043312419e-15, (2470, 1) = .4189263693467337, (2470, 2) = 0.8306975996484435e-16, (2471, 1) = .4208853125125629, (2471, 2) = 0.8304825018435976e-16, (2472, 1) = .422844255678392, (2472, 2) = 0.830266568738845e-16, (2473, 1) = .42480319884422113, (2473, 2) = 0.4150249012309204e-16, (2474, 1) = .4267621420100503, (2474, 2) = -0.41491610257270335e-16, (2475, 1) = .4287210851758795, (2475, 2) = 0.20740344473186933e-16, (2476, 1) = .4306800283417086, (2476, 2) = 0.4146972629755238e-16, (2477, 1) = .43165949992462316, (2477, 2) = -0.8292845900994515e-16, (2478, 1) = .4326389715075377, (2478, 2) = 0.10364680604551495e-15, (2479, 1) = .4336184430904523, (2479, 2) = -0.829064101014325e-16, (2480, 1) = .4345979146733669, (2480, 2) = -0.2072383870799121e-16, (2481, 1) = .4355773862562815, (2481, 2) = -0.1657685581099948e-15, (2482, 1) = .43655685783919607, (2482, 2) = 0.8287318279754895e-16, (2483, 1) = .4375363294221106, (2483, 2) = -0.1035775826083355e-15, (2484, 1) = .4385158010050252, (2484, 2) = -0.16570185789886917e-15, (2485, 1) = .4394597033668342, (2485, 2) = -0.8284017695223107e-16, (2486, 1) = .44040360572864323, (2486, 2) = -0.20707351508688378e-16, (2487, 1) = .4413475080904523, (2487, 2) = -0.10352327027664327e-15, (2488, 1) = .44229141045226134, (2488, 2) = 0.20701951884063093e-16, (2489, 1) = .44323531281407036, (2489, 2) = 0.4139849000196497e-16, (2490, 1) = .44417921517587944, (2490, 2) = -0.18626880070965472e-15, (2491, 1) = .44512311753768846, (2491, 2) = 0.16555053699016376e-15, (2492, 1) = .4460670198994975, (2492, 2) = 0.16552876913481397e-15, (2493, 1) = .4470109222613065, (2493, 2) = .0, (2494, 1) = .44795482462311553, (2494, 2) = -0.20685640121966727e-16, (2495, 1) = .4488987269849246, (2495, 2) = -0.8273162038499955e-16, (2496, 1) = .44984262934673364, (2496, 2) = -0.18612148861373908e-15, (2497, 1) = .45078653170854266, (2497, 2) = 0.4135484208787315e-16, (2498, 1) = .45173043407035174, (2498, 2) = 0.12404803217775429e-15, (2499, 1) = .45267433643216076, (2499, 2) = -0.20671918364745714e-16, (2500, 1) = .4536182387939698, (2500, 2) = 0.12401496033272532e-15, (2501, 1) = .4545621411557788, (2501, 2) = -0.6199919132374419e-16, (2502, 1) = .45550604351758783, (2502, 2) = -0.20663629528296606e-16, (2503, 1) = .4564499458793969, (2503, 2) = 0.18594771590497486e-15, (2504, 1) = .45739384824120594, (2504, 2) = -0.6197424149259235e-16, (2505, 1) = .45833775060301496, (2505, 2) = .0, (2506, 1) = .45928165296482404, (2506, 2) = 0.20652513012626947e-16, (2507, 1) = .46022555532663306, (2507, 2) = 0.16519777892286132e-15, (2508, 1) = .4611694576884421, (2508, 2) = -0.20646927123146455e-16, (2509, 1) = .4621133600502511, (2509, 2) = .0, (2510, 1) = .46305726241206013, (2510, 2) = 0.6192396863622227e-16, (2511, 1) = .4640011647738692, (2511, 2) = -0.412770277779628e-16, (2512, 1) = .46494506713567824, (2512, 2) = 0.20635700329150292e-16, (2513, 1) = .46683287185929634, (2513, 2) = -0.8252023809681342e-16, (2514, 1) = .4687206765829144, (2514, 2) = -0.10312200256907522e-15, (2515, 1) = .4695778303548993, (2515, 2) = .0, (2516, 1) = .4704349841268842, (2516, 2) = -0.6185773757891463e-16, (2517, 1) = .47129213789886915, (2517, 2) = 0.10308331464946157e-15, (2518, 1) = .47214929167085407, (2518, 2) = 0.8245630508519189e-16, (2519, 1) = .473006445442839, (2519, 2) = -0.8244594355420802e-16, (2520, 1) = .4738635992148239, (2520, 2) = 0.18548002607719273e-15, (2521, 1) = .4747207529868088, (2521, 2) = 0.20606293969410024e-16, (2522, 1) = .47557790675879374, (2522, 2) = 0.6181107732727538e-16, (2523, 1) = .4790065218467334, (2523, 2) = 0.1029662466417493e-15, (2524, 1) = .4824351369346731, (2524, 2) = 0.16466197784882144e-15, (2525, 1) = .483292290706658, (2525, 2) = -0.4116022505229249e-16, (2526, 1) = .48414944447864294, (2526, 2) = -0.41154948316817393e-16, (2527, 1) = .48500659825062786, (2527, 2) = .0, (2528, 1) = .4858637520226128, (2528, 2) = -0.20572186453569706e-16, (2529, 1) = .4867209057945977, (2529, 2) = -0.6170861137789799e-16, (2530, 1) = .4875780595665826, (2530, 2) = -0.4113376830915323e-16, (2531, 1) = .48843521333856754, (2531, 2) = 0.8225691017663344e-16, (2532, 1) = .48929236711055246, (2532, 2) = 0.4112313459894231e-16, (2533, 1) = .4901495208825374, (2533, 2) = -0.2055890342527804e-16, (2534, 1) = .4910066746545223, (2534, 2) = .0, (2535, 1) = .4918638284265072, (2535, 2) = 0.8221425922976676e-16, (2536, 1) = .49272098219849214, (2536, 2) = 0.20550890073339897e-15, (2537, 1) = .49357813597047706, (2537, 2) = -0.20548211728815055e-16, (2538, 1) = .494435289742462, (2538, 2) = -0.1643642382291636e-15, (2539, 1) = .4952924435144469, (2539, 2) = -0.12325706536567415e-15, (2540, 1) = .4961495972864318, (2540, 2) = 0.14378108556350008e-15, (2541, 1) = .5124574171356782, (2541, 2) = 0.40976627890218606e-16, (2542, 1) = .5287652369849245, (2542, 2) = -0.2043520605299e-16, (2543, 1) = .5322189526130652, (2543, 2) = -0.40847598661878507e-16, (2544, 1) = .5356726682412059, (2544, 2) = -0.102061688066145e-15, (2545, 1) = .536536097148241, (2545, 2) = 0.1224567817695733e-15, (2546, 1) = .5373995260552762, (2546, 2) = 0.16325268984879055e-15, (2547, 1) = .5382629549623114, (2547, 2) = -0.2040370542675191e-16, (2548, 1) = .5391263838693465, (2548, 2) = .0, (2549, 1) = .5408532416834169, (2549, 2) = 0.12237025572462535e-15, (2550, 1) = .5425800994974872, (2550, 2) = 0.14272475331003202e-15, (2551, 1) = .5494875307537685, (2551, 2) = 0.6109784160314565e-16, (2552, 1) = .5563949620100499, (2552, 2) = .0, (2553, 1) = .5644299466582912, (2553, 2) = 0.40629618905927314e-16, (2554, 1) = .5724649313065324, (2554, 2) = 0.16229525712061281e-15, (2555, 1) = .576482423630653, (2555, 2) = 0.8109140695614593e-16, (2556, 1) = .5804999159547737, (2556, 2) = .0, (2557, 1) = .5815042890358039, (2557, 2) = -0.4051037155582948e-16, (2558, 1) = .582508662116834, (2558, 2) = -0.40503279542197146e-16, (2559, 1) = .5835130351978641, (2559, 2) = 0.4049617902288474e-16, (2560, 1) = .5845174082788943, (2560, 2) = -0.4048907001391982e-16, (2561, 1) = .5855217813599245, (2561, 2) = -0.8096390506266669e-16, (2562, 1) = .5865261544409546, (2562, 2) = -0.8094965318231913e-16, (2563, 1) = .5875305275219848, (2563, 2) = 0.8093538441887194e-16, (2564, 1) = .5885349006030149, (2564, 2) = .0, (2565, 1) = .5903129813253767, (2565, 2) = 0.40447883601047095e-16, (2566, 1) = .5920910620477385, (2566, 2) = 0.8087038306565667e-16, (2567, 1) = .5929801024089194, (2567, 2) = .0, (2568, 1) = .5938691427701004, (2568, 2) = 0.8084494657322868e-16, (2569, 1) = .5947581831312813, (2569, 2) = 0.1212483131237999e-15, (2570, 1) = .5956472234924621, (2570, 2) = -0.8081945790299792e-16, (2571, 1) = .596536263853643, (2571, 2) = 0.4040334702845194e-16, (2572, 1) = .5974253042148239, (2572, 2) = -0.161587834466404e-15, (2573, 1) = .5983143445760049, (2573, 2) = 0.8078112745417933e-16, (2574, 1) = .5992033849371857, (2574, 2) = 0.12115248711318852e-15, (2575, 1) = .6000924252983666, (2575, 2) = 0.8075550911933351e-16, (2576, 1) = .6009814656595476, (2576, 2) = .0, (2577, 1) = .6018705060207284, (2577, 2) = -0.4036491961535824e-16, (2578, 1) = .6027595463819093, (2578, 2) = .0, (2579, 1) = .6036485867430902, (2579, 2) = -0.8070411796671843e-16, (2580, 1) = .6045376271042711, (2580, 2) = -0.8069123812470872e-16, (2581, 1) = .605426667465452, (2581, 2) = 0.16135669101153364e-15, (2582, 1) = .6063157078266329, (2582, 2) = -0.806654401322015e-16, (2583, 1) = .6072047481878138, (2583, 2) = -0.40326261013161784e-16, (2584, 1) = .6080937885489948, (2584, 2) = -0.40319795605222845e-16, (2585, 1) = .6089828289101756, (2585, 2) = -0.1612532954137647e-15, (2586, 1) = .6098718692713565, (2586, 2) = -0.8061369153794975e-16, (2587, 1) = .6107609096325374, (2587, 2) = 0.40300361362982895e-16, (2588, 1) = .6116499499937182, (2588, 2) = .0, (2589, 1) = .6125389903548992, (2589, 2) = 0.8057474726212262e-16, (2590, 1) = .6134280307160801, (2590, 2) = -0.8056174065490653e-16, (2591, 1) = .615206111438442, (2591, 2) = .0, (2592, 1) = .6169841921608037, (2592, 2) = 0.8050958891164143e-16, (2593, 1) = .6179596103423364, (2593, 2) = .0, (2594, 1) = .6189350285238691, (2594, 2) = .0, (2595, 1) = .6199104467054017, (2595, 2) = .0, (2596, 1) = .6208858648869344, (2596, 2) = 0.8045214079960945e-16, (2597, 1) = .6218612830684671, (2597, 2) = .0, (2598, 1) = .6228367012499998, (2598, 2) = -0.16084665461670252e-15, (2599, 1) = .6238121194315325, (2599, 2) = -0.8040889830713818e-16, (2600, 1) = .624787537613065, (2600, 2) = 0.1607889090163901e-15, (2601, 1) = .6267383739761303, (2601, 2) = 0.40182761317549225e-16, (2602, 1) = .6286892103391957, (2602, 2) = -0.4016826596251107e-16, (2603, 1) = .630640046702261, (2603, 2) = 0.4015374130696278e-16, (2604, 1) = .6325908830653264, (2604, 2) = 0.8027837493776266e-16, (2605, 1) = .6364925557914571, (2605, 2) = 0.401099927170006e-16, (2606, 1) = .6403942285175878, (2606, 2) = .0, (2607, 1) = .6413696466991203, (2607, 2) = -0.40073337226608026e-16, (2608, 1) = .642345064880653, (2608, 2) = .0, (2609, 1) = .6433204830621857, (2609, 2) = -0.8011724998622324e-16, (2610, 1) = .6442959012437184, (2610, 2) = -0.40051258213034646e-16, (2611, 1) = .6452713194252511, (2611, 2) = -0.8008776868744276e-16, (2612, 1) = .6462467376067837, (2612, 2) = -0.4003650339990748e-16, (2613, 1) = .6472221557883164, (2613, 2) = 0.800582307926547e-16, (2614, 1) = .6481975739698491, (2614, 2) = 0.12006516104314216e-15, (2615, 1) = .6519128890703516, (2615, 2) = .0, (2616, 1) = .6556282041708541, (2616, 2) = -0.39965155963492205e-16, (2617, 1) = .6565570329459798, (2617, 2) = 0.3995805705329883e-16, (2618, 1) = .6574858617211053, (2618, 2) = -0.1198528556483064e-15, (2619, 1) = .6584146904962309, (2619, 2) = 0.1198315213938236e-15, (2620, 1) = .6593435192713566, (2620, 2) = 0.39936722811520056e-16, (2621, 1) = .6612011768216078, (2621, 2) = .0, (2622, 1) = .6630588343718591, (2622, 2) = -0.7981638020783779e-16, (2623, 1) = .6649164919221103, (2623, 2) = 0.3989388667072963e-16, (2624, 1) = .6667741494723616, (2624, 2) = 0.7975911730667652e-16, (2625, 1) = .6686318070226128, (2625, 2) = -0.3986520615324645e-16, (2626, 1) = .6704894645728641, (2626, 2) = -0.7970165854384239e-16, (2627, 1) = .6714182933479897, (2627, 2) = .0, (2628, 1) = .6723471221231153, (2628, 2) = -0.15934571244317285e-15, (2629, 1) = .6732759508982409, (2629, 2) = 0.23897531074194034e-15, (2630, 1) = .6742047796733666, (2630, 2) = 0.11946600831376672e-15, (2631, 1) = .6751336084484922, (2631, 2) = .0, (2632, 1) = .6760624372236178, (2632, 2) = -0.11942266006398627e-15, (2633, 1) = .6769912659987434, (2633, 2) = 0.3980031964913139e-16, (2634, 1) = .677920094773869, (2634, 2) = -0.15917231984930356e-15, (2635, 1) = .6788892301601757, (2635, 2) = .0, (2636, 1) = .6798583655464822, (2636, 2) = 0.7955590609267827e-16, (2637, 1) = .6808275009327887, (2637, 2) = 0.39770379877467724e-16, (2638, 1) = .6817966363190953, (2638, 2) = .0, (2639, 1) = .6837349070917083, (2639, 2) = 0.3974762169974804e-16, (2640, 1) = .6856731778643214, (2640, 2) = 0.7946483499790077e-16, (2641, 1) = .6895497194095475, (2641, 2) = 0.7940386523288305e-16, (2642, 1) = .6934262609547737, (2642, 2) = 0.7934269304827855e-16, (2643, 1) = .6953645317273868, (2643, 2) = .0, (2644, 1) = .6973028024999999, (2644, 2) = -0.3964066013887314e-16, (2645, 1) = .6982719378863064, (2645, 2) = -0.11889891893736646e-15, (2646, 1) = .6992410732726129, (2646, 2) = -0.3962527962260049e-16, (2647, 1) = .7002102086589195, (2647, 2) = 0.39617580083602013e-16, (2648, 1) = .701179344045226, (2648, 2) = 0.7921974875283238e-16, (2649, 1) = .7021484794315325, (2649, 2) = .0, (2650, 1) = .7031176148178391, (2650, 2) = -0.3959444451461767e-16, (2651, 1) = .7040867502041456, (2651, 2) = .0, (2652, 1) = .7050558855904521, (2652, 2) = 0.7915798030285886e-16, (2653, 1) = .7060250209767587, (2653, 2) = 0.19785626908744475e-15, (2654, 1) = .7069941563630652, (2654, 2) = -0.7912702280200256e-16, (2655, 1) = .7079632917493717, (2655, 2) = 0.19777881458111621e-15, (2656, 1) = .7089324271356783, (2656, 2) = 0.11864402513222017e-15, (2657, 1) = .709822395951633, (2657, 2) = 0.11862264590954929e-15, (2658, 1) = .7107123647675878, (2658, 2) = -0.11860125143994806e-15, (2659, 1) = .7116023335835426, (2659, 2) = 0.7905322783766248e-16, (2660, 1) = .7124923023994973, (2660, 2) = -0.3951947229741751e-16, (2661, 1) = .714272240031407, (2661, 2) = .0, (2662, 1) = .7160521776633165, (2662, 2) = 0.11847256628836148e-15, (2663, 1) = .7169421464792713, (2663, 2) = 0.7896737734386331e-16, (2664, 1) = .7178321152952261, (2664, 2) = -0.3947651692020216e-16, (2665, 1) = .7187220841111809, (2665, 2) = -0.15787736074104489e-15, (2666, 1) = .7196120529271357, (2666, 2) = -0.39462158478100844e-16, (2667, 1) = .7205020217430904, (2667, 2) = -0.39454971809709136e-16, (2668, 1) = .7213919905590452, (2668, 2) = -0.3944778019107022e-16, (2669, 1) = .7222819593750001, (2669, 2) = -0.39440583633164276e-16, (2670, 1) = .7231719281909548, (2670, 2) = 0.3943338214696744e-16, (2671, 1) = .7240618970069095, (2671, 2) = .0, (2672, 1) = .7249518658228643, (2672, 2) = 0.78837928867171e-16, (2673, 1) = .7258418346388191, (2673, 2) = -0.3941174822833231e-16, (2674, 1) = .7267318034547738, (2674, 2) = 0.7880905427730414e-16, (2675, 1) = .7276217722707287, (2675, 2) = -0.7879460235100072e-16, (2676, 1) = .7285117410866835, (2676, 2) = -0.3939007034982856e-16, (2677, 1) = .7294017099026382, (2677, 2) = 0.236297008035503e-15, (2678, 1) = .730291678718593, (2678, 2) = .0, (2679, 1) = .7311816475345478, (2679, 2) = 0.39368348807142737e-16, (2680, 1) = .7320716163505026, (2680, 2) = 0.39361098640819154e-16, (2681, 1) = .7329615851664574, (2681, 2) = .0, (2682, 1) = .7338515539824122, (2682, 2) = .0, (2683, 1) = .7347415227983669, (2683, 2) = 0.7867863867716254e-16, (2684, 1) = .7356314916143217, (2684, 2) = 0.19666025003241477e-15, (2685, 1) = .7365214604302766, (2685, 2) = 0.11797432773069693e-15, (2686, 1) = .7374114292462313, (2686, 2) = 0.7863499412147371e-16, (2687, 1) = .76812988040201, (2687, 2) = 0.390634255014834e-16, (2688, 1) = .8000377178894471, (2688, 2) = -0.3879401047494016e-16, (2689, 1) = .8009057137123115, (2689, 2) = -0.3878660768549733e-16, (2690, 1) = .8017737095351758, (2690, 2) = -0.7755840222388405e-16, (2691, 1) = .8026417053580401, (2691, 2) = .0, (2692, 1) = .8035097011809045, (2692, 2) = .0, (2693, 1) = .8043776970037688, (2693, 2) = -0.7751391756788666e-16, (2694, 1) = .8052456928266332, (2694, 2) = -0.7749907434250042e-16, (2695, 1) = .8061136886494975, (2695, 2) = 0.3874211182307057e-16, (2696, 1) = .8069816844723617, (2696, 2) = -0.3873468274911146e-16, (2697, 1) = .807849680295226, (2697, 2) = .0, (2698, 1) = .8087176761180903, (2698, 2) = -0.11615944038795736e-15, (2699, 1) = .8095856719409547, (2699, 2) = 0.11613711980860815e-15, (2700, 1) = .810453667763819, (2700, 2) = 0.1161147881682214e-15, (2701, 1) = .8113216635866833, (2701, 2) = -0.38697481831942027e-16, (2702, 1) = .8121896594095477, (2702, 2) = -0.1934501530340542e-15, (2703, 1) = .813057655232412, (2703, 2) = -0.11604772717103243e-15, (2704, 1) = .8139256510552764, (2704, 2) = -0.15470046876879833e-15, (2705, 1) = .8147936468781407, (2705, 2) = -0.7733531004405704e-16, (2706, 1) = .815661642701005, (2706, 2) = .0, (2707, 1) = .8165296385238694, (2707, 2) = -0.7730543960836182e-16, (2708, 1) = .8173976343467337, (2708, 2) = -0.7729049355155115e-16, (2709, 1) = .8182656301695981, (2709, 2) = 0.3863777014721946e-16, (2710, 1) = .8191336259924624, (2710, 2) = -0.772605798562645e-16, (2711, 1) = .8200016218153268, (2711, 2) = 0.7724561225625455e-16, (2712, 1) = .820869617638191, (2712, 2) = -0.1930765937840572e-15, (2713, 1) = .8217376134610552, (2713, 2) = 0.772156556475704e-16, (2714, 1) = .8226056092839196, (2714, 2) = 0.3860033333864258e-16, (2715, 1) = .8234736051067839, (2715, 2) = .0, (2716, 1) = .8243416009296483, (2716, 2) = 0.19292666875175896e-15, (2717, 1) = .8252095967525126, (2717, 2) = .0, (2718, 1) = .8260775925753769, (2718, 2) = -0.3857032006856131e-16, (2719, 1) = .8269455883982413, (2719, 2) = 0.7712561593303909e-16, (2720, 1) = .8278135842211056, (2720, 2) = -0.15422116947915506e-15, (2721, 1) = .8353132583668341, (2721, 2) = -0.11547063549822252e-15, (2722, 1) = .8428129325125626, (2722, 2) = -0.3842487725313913e-16, (2723, 1) = .8465627695854269, (2723, 2) = 0.767842332104199e-16, (2724, 1) = .8503126066582911, (2724, 2) = 0.1150778841937043e-15, (2725, 1) = .8512500659265072, (2725, 2) = 0.7670215956975074e-16, (2726, 1) = .8521875251947233, (2726, 2) = -0.11502858321292834e-15, (2727, 1) = .8531249844629394, (2727, 2) = 0.766692772026465e-16, (2728, 1) = .8540624437311554, (2728, 2) = 0.1533056495507734e-15, (2729, 1) = .8549999029993713, (2729, 2) = 0.7663636488370646e-16, (2730, 1) = .8559373622675874, (2730, 2) = -0.11492984632667985e-15, (2731, 1) = .8568748215358035, (2731, 2) = 0.38301711400560786e-16, (2732, 1) = .8578122808040196, (2732, 2) = 0.11488041098577965e-15, (2733, 1) = .86168622942211, (2733, 2) = 0.7651875208624763e-16, (2734, 1) = .8655601780402005, (2734, 2) = -0.3822521965162568e-16, (2735, 1) = .866528665194723, (2735, 2) = -0.382166709461809e-16, (2736, 1) = .8674971523492456, (2736, 2) = .0, (2737, 1) = .8684656395037682, (2737, 2) = 0.3819956209605085e-16, (2738, 1) = .8694341266582909, (2738, 2) = 0.15276400790795718e-15, (2739, 1) = .8704026138128136, (2739, 2) = .0, (2740, 1) = .8713711009673362, (2740, 2) = -0.7634774082969169e-16, (2741, 1) = .8723395881218587, (2741, 2) = -0.19082649498659146e-15, (2742, 1) = .8733080752763813, (2742, 2) = -0.7631344767834076e-16, (2743, 1) = .8810559725125622, (2743, 2) = -0.3808798943896259e-16, (2744, 1) = .888803869748743, (2744, 2) = .0, (2745, 1) = .8925937726884416, (2745, 2) = -0.3798520524641197e-16, (2746, 1) = .8963836756281403, (2746, 2) = -0.7590266861061323e-16, (2747, 1) = .9001735785678389, (2747, 2) = 0.3791741087543785e-16, (2748, 1) = .9039634815075375, (2748, 2) = 0.11365030710539805e-15, (2749, 1) = .9058584329773868, (2749, 2) = 0.7573285788616664e-16, (2750, 1) = .9077533844472361, (2750, 2) = 0.37849409526480174e-16, (2751, 1) = .9087008601821607, (2751, 2) = .0, (2752, 1) = .9096483359170854, (2752, 2) = -0.37832377544293696e-16, (2753, 1) = .9105958116520101, (2753, 2) = 0.22694314121940795e-15, (2754, 1) = .9115432873869347, (2754, 2) = 0.1890766654432178e-15, (2755, 1) = .9124907631218593, (2755, 2) = 0.3780680621200649e-16, (2756, 1) = .913438238856784, (2756, 2) = -0.11339482875439385e-15, (2757, 1) = .9143857145917087, (2757, 2) = -0.15115897287392319e-15, (2758, 1) = .9153331903266333, (2758, 2) = -0.3778120712450629e-16, (2759, 1) = .9162806660615579, (2759, 2) = -0.3777266798098069e-16, (2760, 1) = .9172281417964826, (2760, 2) = 0.15105650319732782e-15, (2761, 1) = .9181756175314073, (2761, 2) = 0.7551116118195264e-16, (2762, 1) = .9191230932663319, (2762, 2) = -0.1509881294692734e-15, (2763, 1) = .920039824758166, (2763, 2) = 0.37738758661988526e-16, (2764, 1) = .9209565562500002, (2764, 2) = -0.15092192861936211e-15, (2765, 1) = .9218732877418343, (2765, 2) = 0.15088881142469178e-15, (2766, 1) = .9227900192336685, (2766, 2) = -0.7542784155254814e-16, (2767, 1) = .9246234822173369, (2767, 2) = 0.3769734831388391e-16, (2768, 1) = .9264569452010052, (2768, 2) = 0.7536152969953868e-16, (2769, 1) = .9273736766928393, (2769, 2) = 0.37672469017676014e-16, (2770, 1) = .9282904081846735, (2770, 2) = .0, (2771, 1) = .9292071396765076, (2771, 2) = -0.7531173840909491e-16, (2772, 1) = .9301238711683418, (2772, 2) = 0.18823782621966497e-15, (2773, 1) = .9310406026601761, (2773, 2) = -0.752785171884297e-16, (2774, 1) = .9319573341520102, (2774, 2) = 0.3763094926557724e-16, (2775, 1) = .9328740656438443, (2775, 2) = 0.37622637268193915e-16, (2776, 1) = .9337907971356785, (2776, 2) = .0, (2777, 1) = .9356242601193467, (2777, 2) = .0, (2778, 1) = .9374577231030151, (2778, 2) = .0, (2779, 1) = .9383744545948494, (2779, 2) = -0.37572709808638786e-16, (2780, 1) = .9392911860866835, (2780, 2) = -0.15025751765606566e-15, (2781, 1) = .9402079175785176, (2781, 2) = 0.37556046431659035e-16, (2782, 1) = .9411246490703518, (2782, 2) = 0.3754771087164536e-16, (2783, 1) = .9420413805621859, (2783, 2) = 0.3753937274404348e-16, (2784, 1) = .94295811205402, (2784, 2) = 0.11259309617673255e-15, (2785, 1) = .9438748435458542, (2785, 2) = -0.150090755305177e-15, (2786, 1) = .9447915750376884, (2786, 2) = 0.11254302916868943e-15, (2787, 1) = .9457083065295226, (2787, 2) = .0, (2788, 1) = .9466250380213568, (2788, 2) = -0.1499905757753938e-15, (2789, 1) = .9475417695131909, (2789, 2) = 0.7497858124310064e-16, (2790, 1) = .948458501005025, (2790, 2) = .0, (2791, 1) = .9647444853768843, (2791, 2) = 0.7466417204681757e-16, (2792, 1) = .9810304697487435, (2792, 2) = 0.11154752253379023e-15, (2793, 1) = .9883473104020097, (2793, 2) = 0.37115082942215367e-16, (2794, 1) = .995664151055276, (2794, 2) = .0, (2795, 1) = .9965787561369343, (2795, 2) = -0.3703907340076078e-16, (2796, 1) = .9974933612185926, (2796, 2) = -0.18515308961614768e-15, (2797, 1) = .9984079663002507, (2797, 2) = -0.3702216048539291e-16, (2798, 1) = .999322571381909, (2798, 2) = -0.1480548043862654e-15, (2799, 1) = 1.0002371764635674, (2799, 2) = -0.7401047953210813e-16, (2800, 1) = 1.0011517815452255, (2800, 2) = -0.7399355300629806e-16, (2801, 1) = 1.002066386626884, (2801, 2) = .0, (2802, 1) = 1.0029809917085422, (2802, 2) = 0.14791937686910616e-15, (2803, 1) = 1.0048102018718588, (2803, 2) = 0.7392580862613607e-16, (2804, 1) = 1.0066394120351752, (2804, 2) = .0, (2805, 1) = 1.0075540171168336, (2805, 2) = -0.7387496066813548e-16, (2806, 1) = 1.0084686221984918, (2806, 2) = 0.14771600778087636e-15, (2807, 1) = 1.00938322728015, (2807, 2) = -0.7384104341421658e-16, (2808, 1) = 1.0102978323618084, (2808, 2) = 0.7382407925783139e-16, (2809, 1) = 1.0415469889447229, (2809, 2) = .0, (2810, 1) = 1.0424318758322857, (2810, 2) = -0.14645172268700133e-15, (2811, 1) = 1.0433167627198485, (2811, 2) = -0.7320933152090738e-16, (2812, 1) = 1.0442016496074114, (2812, 2) = .0, (2813, 1) = 1.0450865364949742, (2813, 2) = .0, (2814, 1) = 1.045971423382537, (2814, 2) = 0.7315972518273318e-16, (2815, 1) = 1.0468563102700998, (2815, 2) = 0.7314318416594472e-16, (2816, 1) = 1.0477411971576627, (2816, 2) = 0.14625328078021554e-15, (2817, 1) = 1.0486260840452255, (2817, 2) = 0.7311009387098198e-16, (2818, 1) = 1.0495109709327883, (2818, 2) = -0.14618708924861366e-15, (2819, 1) = 1.0503958578203512, (2819, 2) = 0.7307699266580155e-16, (2820, 1) = 1.051280744707914, (2820, 2) = .0, (2821, 1) = 1.0521656315954768, (2821, 2) = .0, (2822, 1) = 1.0530505184830397, (2822, 2) = -0.2190819620285806e-15, (2823, 1) = 1.0539354053706025, (2823, 2) = -0.7301075802715509e-16, (2824, 1) = 1.0548202922581653, (2824, 2) = -0.7299419274457893e-16, (2825, 1) = 1.0557051791457281, (2825, 2) = 0.7297762484406275e-16, (2826, 1) = 1.056590066033291, (2826, 2) = -0.7296105434118394e-16, (2827, 1) = 1.0574749529208538, (2827, 2) = .0, (2828, 1) = 1.0583598398084166, (2828, 2) = .0, (2829, 1) = 1.0592447266959795, (2829, 2) = 0.14582265474768327e-15, (2830, 1) = 1.0601296135835423, (2830, 2) = .0, (2831, 1) = 1.0610145004711051, (2831, 2) = 0.7287816333513988e-16, (2832, 1) = 1.061899387358668, (2832, 2) = 0.21858473263222426e-15, (2833, 1) = 1.0627842742462308, (2833, 2) = 0.728449892591206e-16, (2834, 1) = 1.066323821796482, (2834, 2) = .0, (2835, 1) = 1.0698633693467334, (2835, 2) = -0.7271219504501146e-16, (2836, 1) = 1.0708307844440952, (2836, 2) = -0.7269403576583911e-16, (2837, 1) = 1.071798199541457, (2837, 2) = -0.7267587369075083e-16, (2838, 1) = 1.072765614638819, (2838, 2) = .0, (2839, 1) = 1.0737330297361807, (2839, 2) = 0.14527908246457944e-15, (2840, 1) = 1.0756678599309044, (2840, 2) = 0.7260319782826366e-16, (2841, 1) = 1.077602690125628, (2841, 2) = .0, (2842, 1) = 1.0785701052229897, (2842, 2) = 0.7254866254515887e-16, (2843, 1) = 1.0795375203203514, (2843, 2) = 0.14506095763145813e-15, (2844, 1) = 1.0805049354177134, (2844, 2) = -0.7251229246819292e-16, (2845, 1) = 1.0814723505150752, (2845, 2) = -0.7249410352216139e-16, (2846, 1) = 1.082439765612437, (2846, 2) = -0.14495182399443253e-15, (2847, 1) = 1.083407180709799, (2847, 2) = 0.7245771791291017e-16, (2848, 1) = 1.0843745958071607, (2848, 2) = .0, (2849, 1) = 1.0853420109045224, (2849, 2) = 0.14484264428855958e-15, (2850, 1) = 1.0863094260018842, (2850, 2) = -0.7240312049891492e-16, (2851, 1) = 1.087276841099246, (2851, 2) = 0.14476983274421587e-15, (2852, 1) = 1.088244256196608, (2852, 2) = 0.1447334195665312e-15, (2853, 1) = 1.0892116712939697, (2853, 2) = 0.21704550225529652e-15, (2854, 1) = 1.0901790863913314, (2854, 2) = 0.7233028929695607e-16, (2855, 1) = 1.0911465014886934, (2855, 2) = .0, (2856, 1) = 1.0921139165860552, (2856, 2) = .0, (2857, 1) = 1.093081331683417, (2857, 2) = .0, (2858, 1) = 1.0969509920728642, (2858, 2) = .0, (2859, 1) = 1.1008206524623114, (2859, 2) = .0, (2860, 1) = 1.1017309146765073, (2860, 2) = .0, (2861, 1) = 1.1026411768907034, (2861, 2) = 0.14419096806461236e-15, (2862, 1) = 1.1035514391048995, (2862, 2) = 0.7207831874506795e-16, (2863, 1) = 1.1044617013190954, (2863, 2) = -0.7206115156327059e-16, (2864, 1) = 1.1053719635332913, (2864, 2) = 0.7204398250264764e-16, (2865, 1) = 1.1062822257474874, (2865, 2) = 0.7202681157890979e-16, (2866, 1) = 1.1071924879616835, (2866, 2) = 0.7200963880774484e-16, (2867, 1) = 1.1081027501758793, (2867, 2) = -0.2159773926144531e-15, (2868, 1) = 1.1090130123900752, (2868, 2) = -0.14395057557154067e-15, (2869, 1) = 1.1099232746042713, (2869, 2) = 0.7195810956622183e-16, (2870, 1) = 1.1108335368184674, (2870, 2) = 0.1438818591235368e-15, (2871, 1) = 1.1117437990326633, (2871, 2) = 0.7192374778798331e-16, (2872, 1) = 1.1126540612468592, (2872, 2) = 0.14381312852083395e-15, (2873, 1) = 1.1135643234610553, (2873, 2) = -0.7188937899459686e-16, (2874, 1) = 1.1144745856752514, (2874, 2) = .0, (2875, 1) = 1.1153848478894473, (2875, 2) = -0.21556500993057256e-15, (2876, 1) = 1.1162951101036431, (2876, 2) = 0.7183781292254543e-16, (2877, 1) = 1.1172053723178392, (2877, 2) = 0.7182062085852726e-16, (2878, 1) = 1.1181156345320353, (2878, 2) = -0.7180342713354934e-16, (2879, 1) = 1.1190258967462312, (2879, 2) = .0, (2880, 1) = 1.119936158960427, (2880, 2) = 0.14353806952450368e-15, (2881, 1) = 1.1208464211746232, (2881, 2) = -0.7175183614664384e-16, (2882, 1) = 1.1217566833888193, (2882, 2) = 0.21520390779449766e-15, (2883, 1) = 1.1226669456030152, (2883, 2) = 0.21515230239634965e-15, (2884, 1) = 1.123577207817211, (2884, 2) = 0.7170023076377152e-16, (2885, 1) = 1.1244874700314071, (2885, 2) = 0.716830258417169e-16, (2886, 1) = 1.1253977322456032, (2886, 2) = 0.7166581938118263e-16, (2887, 1) = 1.1263079944597991, (2887, 2) = 0.14329722279475146e-15, (2888, 1) = 1.128128518888191, (2888, 2) = 0.716141909206578e-16, (2889, 1) = 1.129949043316583, (2889, 2) = .0, (2890, 1) = 1.130900529610553, (2890, 2) = -0.14312353894742647e-15, (2891, 1) = 1.131852015904523, (2891, 2) = -0.7154377285020915e-16, (2892, 1) = 1.1328035021984926, (2892, 2) = -0.7152577467943313e-16, (2893, 1) = 1.1337549884924625, (2893, 2) = .0, (2894, 1) = 1.1347064747864324, (2894, 2) = 0.7148977376466282e-16, (2895, 1) = 1.135657961080402, (2895, 2) = 0.28588708421959645e-15, (2896, 1) = 1.136609447374372, (2896, 2) = -0.28581506746529833e-15, (2897, 1) = 1.1375609336683419, (2897, 2) = -0.7143576121598633e-16, (2898, 1) = 1.1385124199623118, (2898, 2) = 0.714177541209042e-16, (2899, 1) = 1.1394639062562817, (2899, 2) = 0.14279949119614143e-15, (2900, 1) = 1.1404153925502514, (2900, 2) = 0.14276347132890238e-15, (2901, 1) = 1.1413668788442213, (2901, 2) = 0.7136372433698364e-16, (2902, 1) = 1.1423183651381912, (2902, 2) = 0.2140371348977366e-15, (2903, 1) = 1.1432698514321609, (2903, 2) = .0, (2904, 1) = 1.1442213377261308, (2904, 2) = -0.14261936432092916e-15, (2905, 1) = 1.1451728240201007, (2905, 2) = 0.14258333085288082e-15, (2906, 1) = 1.14897876919598, (2906, 2) = 0.7121958556228884e-16, (2907, 1) = 1.1527847143718595, (2907, 2) = .0, (2908, 1) = 1.1537362006658294, (2908, 2) = -0.7112945789696922e-16, (2909, 1) = 1.1546876869597993, (2909, 2) = 0.7111142881887241e-16, (2910, 1) = 1.155639173253769, (2910, 2) = 0.7109339859773103e-16, (2911, 1) = 1.1565906595477389, (2911, 2) = -0.7107536725004775e-16, (2912, 1) = 1.1575421458417088, (2912, 2) = -0.7105733479229813e-16, (2913, 1) = 1.1584936321356785, (2913, 2) = -0.142078602481861e-15, (2914, 1) = 1.1594451184296484, (2914, 2) = .0, (2915, 1) = 1.1603966047236183, (2915, 2) = 0.2840129236919965e-15, (2916, 1) = 1.1613268564918342, (2916, 2) = .0, (2917, 1) = 1.1622571082600504, (2917, 2) = 0.1419359231085426e-15, (2918, 1) = 1.1631873600282665, (2918, 2) = .0, (2919, 1) = 1.1641176117964824, (2919, 2) = 0.7093268831423083e-16, (2920, 1) = 1.1650478635646986, (2920, 2) = 0.7091505028050499e-16, (2921, 1) = 1.1659781153329147, (2921, 2) = -0.14179482264909092e-15, (2922, 1) = 1.1669083671011307, (2922, 2) = 0.7087977146149884e-16, (2923, 1) = 1.1678386188693468, (2923, 2) = -0.7086213070648697e-16, (2924, 1) = 1.168768870637563, (2924, 2) = -0.7084448907460697e-16, (2925, 1) = 1.169699122405779, (2925, 2) = -0.7082684658093126e-16, (2926, 1) = 1.170629374173995, (2926, 2) = .0, (2927, 1) = 1.1715596259422112, (2927, 2) = 0.1415831181367175e-15, (2928, 1) = 1.1724898777104271, (2928, 2) = 0.707739140794832e-16, (2929, 1) = 1.1734201294786433, (2929, 2) = -0.7075626828885447e-16, (2930, 1) = 1.1743503812468594, (2930, 2) = .0, (2931, 1) = 1.1752806330150753, (2931, 2) = -0.7072097436210845e-16, (2932, 1) = 1.1762108847832913, (2932, 2) = 0.2121099787674448e-15, (2933, 1) = 1.1771411365515074, (2933, 2) = 0.14137135481483169e-15, (2934, 1) = 1.1780713883197236, (2934, 2) = 0.7066802783176145e-16, (2935, 1) = 1.1790016400879395, (2935, 2) = 0.7065037754367734e-16, (2936, 1) = 1.1799318918561557, (2936, 2) = .0, (2937, 1) = 1.1808621436243718, (2937, 2) = -0.14123014977879855e-15, (2938, 1) = 1.1817923953925877, (2938, 2) = 0.7059742255273343e-16, (2939, 1) = 1.1827226471608039, (2939, 2) = -0.7057976956269405e-16, (2940, 1) = 1.18365289892902, (2940, 2) = -0.2116863478019511e-15, (2941, 1) = 1.184583150697236, (2941, 2) = -0.14108892336256062e-15, (2942, 1) = 1.1855134024654521, (2942, 2) = -0.7052680681923724e-16, (2943, 1) = 1.1864436542336683, (2943, 2) = 0.7050915136248327e-16, (2944, 1) = 1.1873739060018842, (2944, 2) = -0.7049149532562265e-16, (2945, 1) = 1.1883041577701003, (2945, 2) = 0.7047383872323505e-16, (2946, 1) = 1.1892344095383165, (2946, 2) = .0, (2947, 1) = 1.1901646613065324, (2947, 2) = .0, (2948, 1) = 1.2057468595477387, (2948, 2) = 0.7014268208249618e-16, (2949, 1) = 1.221329057788945, (2949, 2) = 0.13969352167518056e-15, (2950, 1) = 1.2222670270948495, (2950, 2) = -0.6982894678383375e-16, (2951, 1) = 1.223204996400754, (2951, 2) = 0.6981113269318596e-16, (2952, 1) = 1.2241429657066587, (2952, 2) = -0.6979331857963151e-16, (2953, 1) = 1.225080935012563, (2953, 2) = -0.13955100891426003e-15, (2954, 1) = 1.2260189043184675, (2954, 2) = -0.1395153806792325e-15, (2955, 1) = 1.2269568736243721, (2955, 2) = .0, (2956, 1) = 1.2278948429302767, (2956, 2) = 0.6972206217516646e-16, (2957, 1) = 1.2288328122361811, (2957, 2) = 0.6970424815597555e-16, (2958, 1) = 1.2297707815420855, (2958, 2) = -0.6968643419726259e-16, (2959, 1) = 1.2307087508479901, (2959, 2) = -0.1393372406256761e-15, (2960, 1) = 1.2316467201538948, (2960, 2) = .0, (2961, 1) = 1.2325846894597992, (2961, 2) = .0, (2962, 1) = 1.2335226587657036, (2962, 2) = -0.6961517924302699e-16, (2963, 1) = 1.2344606280716082, (2963, 2) = -0.27838946317345703e-15, (2964, 1) = 1.2353985973775128, (2964, 2) = -0.695795524866701e-16, (2965, 1) = 1.2363365666834172, (2965, 2) = 0.20868521800981868e-15, (2966, 1) = 1.2372745359893216, (2966, 2) = .0, (2967, 1) = 1.2382125052952262, (2967, 2) = .0, (2968, 1) = 1.2391504746011308, (2968, 2) = -0.13901660192488553e-15, (2969, 1) = 1.2400884439070352, (2969, 2) = -0.694904885750229e-16, (2970, 1) = 1.2410264132129396, (2970, 2) = 0.13894535282434252e-15, (2971, 1) = 1.2419643825188442, (2971, 2) = 0.6945486448740135e-16, (2972, 1) = 1.2429023518247488, (2972, 2) = 0.1388741056284042e-15, (2973, 1) = 1.2438403211306532, (2973, 2) = -0.6941924140603775e-16, (2974, 1) = 1.2447782904365576, (2974, 2) = -0.1388028605526959e-15, (2975, 1) = 1.2457162597424623, (2975, 2) = 0.6938361943854776e-16, (2976, 1) = 1.2466542290483669, (2976, 2) = -0.6936580890602761e-16, (2977, 1) = 1.2475921983542713, (2977, 2) = -0.6934799869215342e-16, (2978, 1) = 1.2485301676601757, (2978, 2) = .0, (2979, 1) = 1.2494681369660803, (2979, 2) = .0, (2980, 1) = 1.250406106271985, (2980, 2) = .0, (2981, 1) = 1.2513440755778893, (2981, 2) = 0.20783028386872452e-15, (2982, 1) = 1.2523032846670854, (2982, 2) = 0.6925854961152203e-16, (2983, 1) = 1.2532624937562813, (2983, 2) = 0.6924033835035203e-16, (2984, 1) = 1.2542217028454772, (2984, 2) = -0.692221275201751e-16, (2985, 1) = 1.2551809119346733, (2985, 2) = 0.692039171350747e-16, (2986, 1) = 1.2561401210238692, (2986, 2) = .0, (2987, 1) = 1.257099330113065, (2987, 2) = .0, (2988, 1) = 1.2580585392022612, (2988, 2) = -0.6914928879066718e-16, (2989, 1) = 1.259017748291457, (2989, 2) = -0.1382621606523478e-15, (2990, 1) = 1.259976957380653, (2990, 2) = -0.6911287237677427e-16, (2991, 1) = 1.260936166469849, (2991, 2) = .0, (2992, 1) = 1.261895375559045, (2992, 2) = -0.13815291615784648e-15, (2993, 1) = 1.2628545846482409, (2993, 2) = .0, (2994, 1) = 1.263813793737437, (2994, 2) = -0.6904004600818268e-16, (2995, 1) = 1.2647730028266329, (2995, 2) = 0.690218408425715e-16, (2996, 1) = 1.2657322119158287, (2996, 2) = 0.6900363627519606e-16, (2997, 1) = 1.2666914210050249, (2997, 2) = -0.13797086463964089e-15, (2998, 1) = 1.267650630094221, (2998, 2) = -0.6896722899018228e-16, (2999, 1) = 1.2686098391834169, (2999, 2) = .0, (3000, 1) = 1.2695690482726127, (3000, 2) = -0.2067924727888093e-15, (3001, 1) = 1.2705282573618089, (3001, 2) = 0.6891262289267163e-16, (3002, 1) = 1.2714874664510047, (3002, 2) = 0.20668326660849053e-15, (3003, 1) = 1.2724466755402006, (3003, 2) = -0.13775244441403493e-15, (3004, 1) = 1.2734058846293967, (3004, 2) = -0.13771604583762508e-15, (3005, 1) = 1.2743650937185926, (3005, 2) = 0.6883982435176809e-16, (3006, 1) = 1.2782019300753764, (3006, 2) = .0, (3007, 1) = 1.2820387664321604, (3007, 2) = -0.6869426339482764e-16, (3008, 1) = 1.2858438318467333, (3008, 2) = -0.6862210513273439e-16, (3009, 1) = 1.2896488972613063, (3009, 2) = -0.6854996094638496e-16, (3010, 1) = 1.2906001636149496, (3010, 2) = 0.137063854390909e-15, (3011, 1) = 1.2915514299685928, (3011, 2) = 0.6851389438834673e-16, (3012, 1) = 1.2925026963222361, (3012, 2) = .0, (3013, 1) = 1.2934539626758792, (3013, 2) = 0.13695566331303597e-15, (3014, 1) = 1.2944052290295223, (3014, 2) = .0, (3015, 1) = 1.2953564953831656, (3015, 2) = 0.13688354570497042e-15, (3016, 1) = 1.2963077617368088, (3016, 2) = -0.20527123486508522e-15, (3017, 1) = 1.2972590280904521, (3017, 2) = .0, (3018, 1) = 1.2982102944440954, (3018, 2) = -0.6838769223228702e-16, (3019, 1) = 1.2991615607977387, (3019, 2) = 0.6836966743214868e-16, (3020, 1) = 1.300112827151382, (3020, 2) = .0, (3021, 1) = 1.301064093505025, (3021, 2) = -0.6833362101701497e-16, (3022, 1) = 1.3020153598586681, (3022, 2) = .0, (3023, 1) = 1.3029666262123114, (3023, 2) = 0.6829757893201859e-16, (3024, 1) = 1.3039178925659547, (3024, 2) = .0, (3025, 1) = 1.304869158919598, (3025, 2) = .0, (3026, 1) = 1.3058204252732413, (3026, 2) = 0.13648704828254054e-15, (3027, 1) = 1.3067716916268846, (3027, 2) = -0.6822550815038979e-16, (3028, 1) = 1.3077229579805278, (3028, 2) = -0.13641498663288446e-15, (3029, 1) = 1.308674224334171, (3029, 2) = .0, (3030, 1) = 1.309625490687814, (3030, 2) = 0.13634293433713697e-15, (3031, 1) = 1.3105767570414573, (3031, 2) = .0, (3032, 1) = 1.3115280233951006, (3032, 2) = .0, (3033, 1) = 1.3124792897487438, (3033, 2) = -0.6811743693074699e-16, (3034, 1) = 1.3133534047330402, (3034, 2) = 0.6810088973854901e-16, (3035, 1) = 1.3142275197173368, (3035, 2) = 0.13616868718946127e-15, (3036, 1) = 1.3151016347016333, (3036, 2) = -0.13613559701742537e-15, (3037, 1) = 1.3159757496859297, (3037, 2) = -0.1361025089797969e-15, (3038, 1) = 1.316849864670226, (3038, 2) = 0.6803471154767366e-16, (3039, 1) = 1.3177239796545226, (3039, 2) = .0, (3040, 1) = 1.3185980946388192, (3040, 2) = -0.6800162893044778e-16, (3041, 1) = 1.3194722096231155, (3041, 2) = -0.679850892741306e-16, (3042, 1) = 1.3229686695603013, (3042, 2) = .0, (3043, 1) = 1.3264651294974872, (3043, 2) = 0.6785281290491453e-16, (3044, 1) = 1.3334580493718589, (3044, 2) = .0, (3045, 1) = 1.3404509692462305, (3045, 2) = -0.6758849287575188e-16, (3046, 1) = 1.3414528036620597, (3046, 2) = -0.13513914348898202e-15, (3047, 1) = 1.3424546380778888, (3047, 2) = 0.13510130475342997e-15, (3048, 1) = 1.343456472493718, (3048, 2) = 0.13506346957153307e-15, (3049, 1) = 1.344458306909547, (3049, 2) = -0.6751281898495886e-16, (3050, 1) = 1.3454601413253762, (3050, 2) = -0.6749390498757581e-16, (3051, 1) = 1.3464619757412053, (3051, 2) = -0.6747499280687175e-16, (3052, 1) = 1.3474638101570346, (3052, 2) = -0.6745608245607167e-16, (3053, 1) = 1.3484656445728638, (3053, 2) = 0.13487434789674247e-15, (3054, 1) = 1.349467478988693, (3054, 2) = 0.6741826729693681e-16, (3055, 1) = 1.3504693134045223, (3055, 2) = 0.1347987250298108e-15, (3056, 1) = 1.3514711478203514, (3056, 2) = -0.1347609192307696e-15, (3057, 1) = 1.3524729822361805, (3057, 2) = .0, (3058, 1) = 1.3534748166520096, (3058, 2) = .0, (3059, 1) = 1.3544766510678388, (3059, 2) = .0, (3060, 1) = 1.355478485483668, (3060, 2) = 0.6730486710354368e-16, (3061, 1) = 1.356480319899497, (3061, 2) = -0.2691438952486872e-15, (3062, 1) = 1.3574821543153262, (3062, 2) = 0.13453416496268927e-15, (3063, 1) = 1.3584839887311553, (3063, 2) = 0.1344963862479319e-15, (3064, 1) = 1.3594858231469844, (3064, 2) = -0.6722930575291054e-16, (3065, 1) = 1.3604876575628135, (3065, 2) = .0, (3066, 1) = 1.3614894919786427, (3066, 2) = 0.6719153702112377e-16, (3067, 1) = 1.3624913263944718, (3067, 2) = -0.6717265568599715e-16, (3068, 1) = 1.3634931608103011, (3068, 2) = 0.6715377638840334e-16, (3069, 1) = 1.3644949952261303, (3069, 2) = -0.671348991410725e-16, (3070, 1) = 1.3654968296419594, (3070, 2) = 0.20134807187011785e-15, (3071, 1) = 1.3664986640577887, (3071, 2) = 0.20129145254392856e-15, (3072, 1) = 1.3675004984736179, (3072, 2) = 0.13415655965505393e-15, (3073, 1) = 1.368502332889447, (3073, 2) = -0.6705941090797328e-16, (3074, 1) = 1.3695041673052761, (3074, 2) = 0.20112163230570418e-15, (3075, 1) = 1.3705060017211053, (3075, 2) = .0, (3076, 1) = 1.3715078361369344, (3076, 2) = .0, (3077, 1) = 1.3725096705527635, (3077, 2) = -0.13396791298001917e-15, (3078, 1) = 1.3743017758417082, (3078, 2) = .0, (3079, 1) = 1.376093881130653, (3079, 2) = 0.6691649846183366e-16, (3080, 1) = 1.3769899337751252, (3080, 2) = -0.6689963834834616e-16, (3081, 1) = 1.3778859864195976, (3081, 2) = 0.20064834002991375e-15, (3082, 1) = 1.37878203906407, (3082, 2) = 0.13373184691104416e-15, (3083, 1) = 1.3796780917085425, (3083, 2) = .0, (3084, 1) = 1.380574144353015, (3084, 2) = .0, (3085, 1) = 1.3814701969974874, (3085, 2) = .0, (3086, 1) = 1.3823662496419598, (3086, 2) = -0.667985152526108e-16, (3087, 1) = 1.383262302286432, (3087, 2) = 0.13356333549870538e-15, (3088, 1) = 1.3841583549309044, (3088, 2) = 0.6676482208251848e-16, (3089, 1) = 1.3850544075753768, (3089, 2) = -0.13349595652158912e-15, (3090, 1) = 1.3859504602198491, (3090, 2) = 0.6673113629284928e-16, (3091, 1) = 1.3868465128643215, (3091, 2) = -0.6671429618733296e-16, (3092, 1) = 1.3877425655087938, (3092, 2) = 0.2000923738586339e-15, (3093, 1) = 1.3886386181532662, (3093, 2) = -0.20004186479429582e-15, (3094, 1) = 1.3895346707977385, (3094, 2) = -0.2666551485263652e-15, (3095, 1) = 1.3904307234422109, (3095, 2) = 0.26658781824773784e-15, (3096, 1) = 1.3913267760866832, (3096, 2) = .0, (3097, 1) = 1.3922228287311555, (3097, 2) = 0.666132951473964e-16, (3098, 1) = 1.393118881375628, (3098, 2) = -0.6659646831958248e-16, (3099, 1) = 1.3940149340201005, (3099, 2) = 0.13315928684550746e-15, (3100, 1) = 1.394910986664573, (3100, 2) = 0.13312564093079823e-15, (3101, 1) = 1.3958070393090454, (3101, 2) = .0, (3102, 1) = 1.3967030919535177, (3102, 2) = 0.19958754120893738e-15, (3103, 1) = 1.39759914459799, (3103, 2) = 0.6651236331480263e-16, (3104, 1) = 1.3993912498869348, (3104, 2) = -0.6647873506660546e-16, (3105, 1) = 1.4011833551758794, (3105, 2) = -0.19933534433558208e-15, (3106, 1) = 1.4021387341865579, (3106, 2) = -0.6642719493485009e-16, (3107, 1) = 1.4030941131972363, (3107, 2) = -0.6640927738253714e-16, (3108, 1) = 1.4040494922079145, (3108, 2) = -0.6639136213166049e-16, (3109, 1) = 1.405004871218593, (3109, 2) = -0.6637344919226924e-16, (3110, 1) = 1.4069156292399496, (3110, 2) = -0.6633763028802564e-16, (3111, 1) = 1.4088263872613065, (3111, 2) = -0.6630182074974433e-16, (3112, 1) = 1.41264790330402, (3112, 2) = .0, (3113, 1) = 1.4164694193467335, (3113, 2) = 0.13231735568461218e-15, (3114, 1) = 1.417424798357412, (3114, 2) = 0.132281591712735e-15, (3115, 1) = 1.4183801773680904, (3115, 2) = -0.2644916652808889e-15, (3116, 1) = 1.4193355563787686, (3116, 2) = 0.13221007848716093e-15, (3117, 1) = 1.420290935389447, (3117, 2) = -0.6608716463613002e-16, (3118, 1) = 1.4222016934108037, (3118, 2) = -0.13210284573488482e-15, (3119, 1) = 1.4241124514321606, (3119, 2) = -0.19804707327364495e-15, (3120, 1) = 1.425067830442839, (3120, 2) = -0.19799348692276856e-15, (3121, 1) = 1.4260232094535175, (3121, 2) = 0.13195993876829355e-15, (3122, 1) = 1.4269785884641957, (3122, 2) = -0.6596211233041856e-16, (3123, 1) = 1.427933967474874, (3123, 2) = .0, (3124, 1) = 1.4298447254962308, (3124, 2) = -0.6590855648250663e-16, (3125, 1) = 1.4317554835175876, (3125, 2) = -0.13174573087911547e-15, (3126, 1) = 1.4390708404522612, (3126, 2) = .0, (3127, 1) = 1.4463861973869347, (3127, 2) = 0.1311998552683734e-15, (3128, 1) = 1.447300617003769, (3128, 2) = 0.6558288997237591e-16, (3129, 1) = 1.4482150366206032, (3129, 2) = 0.6556585482337915e-16, (3130, 1) = 1.4491294562374373, (3130, 2) = -0.13109764439021597e-15, (3131, 1) = 1.4500438758542715, (3131, 2) = -0.13106358419091184e-15, (3132, 1) = 1.4509582954711058, (3132, 2) = 0.6551476453229834e-16, (3133, 1) = 1.4518727150879398, (3133, 2) = 0.32748869756746325e-15, (3134, 1) = 1.452787134704774, (3134, 2) = -0.13096143409375627e-15, (3135, 1) = 1.4537015543216083, (3135, 2) = -0.19639109142082847e-15, (3136, 1) = 1.4555303935552768, (3136, 2) = -0.6542966503830518e-16, (3137, 1) = 1.457359232788945, (3137, 2) = .0, (3138, 1) = 1.4582736524057793, (3138, 2) = .0, (3139, 1) = 1.4591880720226134, (3139, 2) = -0.6536163189665835e-16, (3140, 1) = 1.4601024916394476, (3140, 2) = .0, (3141, 1) = 1.4610169112562819, (3141, 2) = 0.19598289294163705e-15, (3142, 1) = 1.4620322567242465, (3142, 2) = 0.13061751738728257e-15, (3143, 1) = 1.4630476021922114, (3143, 2) = 0.6528988965929406e-16, (3144, 1) = 1.4640629476601763, (3144, 2) = -0.6527102388793822e-16, (3145, 1) = 1.465078293128141, (3145, 2) = 0.13050432277996196e-15, (3146, 1) = 1.4660936385961059, (3146, 2) = -0.13046660435160534e-15, (3147, 1) = 1.4671089840640708, (3147, 2) = 0.13042889251151338e-15, (3148, 1) = 1.4681243295320354, (3148, 2) = 0.6519559364016958e-16, (3149, 1) = 1.4691396750000003, (3149, 2) = -0.6517674433934107e-16, (3150, 1) = 1.4732010568718596, (3150, 2) = 0.6510138048867095e-16, (3151, 1) = 1.4772624387437188, (3151, 2) = 0.13005214098233611e-15, (3152, 1) = 1.4853852024874372, (3152, 2) = 0.6487561463444176e-16, (3153, 1) = 1.4935079662311557, (3153, 2) = -0.6472538185922412e-16, (3154, 1) = 1.4943871808008793, (3154, 2) = .0, (3155, 1) = 1.495266395370603, (3155, 2) = 0.12938577816735225e-15, (3156, 1) = 1.4961456099403265, (3156, 2) = .0, (3157, 1) = 1.4970248245100501, (3157, 2) = 0.6466040704649784e-16, (3158, 1) = 1.4979040390797738, (3158, 2) = -0.2585766802813061e-15, (3159, 1) = 1.4987832536494974, (3159, 2) = -0.19388380739206096e-15, (3160, 1) = 1.499662468219221, (3160, 2) = 0.6461170423375114e-16, (3161, 1) = 1.5005416827889446, (3161, 2) = -0.6459547538567642e-16, (3162, 1) = 1.5014208973586682, (3162, 2) = .0, (3163, 1) = 1.5023001119283919, (3163, 2) = 0.12912605172133627e-15, (3164, 1) = 1.5031793264981155, (3164, 2) = 0.1290936103919549e-15, (3165, 1) = 1.504058541067839, (3165, 2) = 0.6453058727130041e-16, (3166, 1) = 1.5049377556375627, (3166, 2) = -0.6451437209272258e-16, (3167, 1) = 1.5058169702072863, (3167, 2) = -0.12899631933263035e-15, (3168, 1) = 1.50669618477701, (3168, 2) = 0.12896389999627028e-15, (3169, 1) = 1.5075753993467336, (3169, 2) = -0.12893148618845027e-15, (3170, 1) = 1.511092257625628, (3170, 2) = .0, (3171, 1) = 1.5146091159045225, (3171, 2) = 0.12867237619416578e-15, (3172, 1) = 1.518125974183417, (3172, 2) = 0.642714780404671e-16, (3173, 1) = 1.5216428324623115, (3173, 2) = .0, (3174, 1) = 1.5226407488630653, (3174, 2) = 0.641884730577458e-16, (3175, 1) = 1.523638665263819, (3175, 2) = 0.6417013636646167e-16, (3176, 1) = 1.5246365816645726, (3176, 2) = -0.641518033826785e-16, (3177, 1) = 1.5256344980653265, (3177, 2) = 0.6413347411481257e-16, (3178, 1) = 1.5266324144660803, (3178, 2) = 0.19234544571377122e-15, (3179, 1) = 1.5276303308668342, (3179, 2) = -0.12819365352076442e-15, (3180, 1) = 1.528628247267588, (3180, 2) = .0, (3181, 1) = 1.5296261636683417, (3181, 2) = 0.6406019437004016e-16, (3182, 1) = 1.533617829271357, (3182, 2) = 0.6398697474726295e-16, (3183, 1) = 1.537609494874372, (3183, 2) = 0.6391381577410838e-16, (3184, 1) = 1.5386074112751258, (3184, 2) = -0.6389553556859938e-16, (3185, 1) = 1.5396053276758794, (3185, 2) = 0.19163177758328734e-15, (3186, 1) = 1.540603244076633, (3186, 2) = -0.6385898665967144e-16, (3187, 1) = 1.541601160477387, (3187, 2) = -0.12768143594475537e-15, (3188, 1) = 1.5435969932788947, (3188, 2) = -0.6380419217227465e-16, (3189, 1) = 1.5455928260804022, (3189, 2) = 0.6376768185808079e-16, (3190, 1) = 1.5465907424811558, (3190, 2) = -0.6374943252808944e-16, (3191, 1) = 1.5475886588819097, (3191, 2) = 0.19119356128019464e-15, (3192, 1) = 1.5485865752826635, (3192, 2) = .0, (3193, 1) = 1.5495844916834174, (3193, 2) = 0.6369470794147141e-16, (3194, 1) = 1.5505824080841712, (3194, 2) = 0.6367647423995784e-16, (3195, 1) = 1.5515803244849249, (3195, 2) = 0.6365824446518845e-16, (3196, 1) = 1.5525782408856785, (3196, 2) = -0.6364001862496868e-16, (3197, 1) = 1.5535761572864324, (3197, 2) = -0.6362179672708191e-16, (3198, 1) = 1.5681280367336683, (3198, 2) = 0.6335653294367944e-16, (3199, 1) = 1.5826799161809042, (3199, 2) = 0.12618426514661e-15, (3200, 1) = 1.598597385376884, (3200, 2) = 0.6280393549244186e-16, (3201, 1) = 1.6145148545728638, (3201, 2) = .0, (3202, 1) = 1.6153732348209795, (3202, 2) = -0.1250027504768325e-15, (3203, 1) = 1.616231615069095, (3203, 2) = -0.6248592704418267e-16, (3204, 1) = 1.6170899953172104, (3204, 2) = .0, (3205, 1) = 1.6179483755653261, (3205, 2) = 0.6245504041442577e-16, (3206, 1) = 1.6196651360615575, (3206, 2) = .0, (3207, 1) = 1.6213818965577886, (3207, 2) = -0.1247866126076396e-15, (3208, 1) = 1.622240276805904, (3208, 2) = .0, (3209, 1) = 1.6230986570540198, (3209, 2) = .0, (3210, 1) = 1.6239570373021355, (3210, 2) = 0.12469408020725685e-15, (3211, 1) = 1.6248154175502512, (3211, 2) = -0.18699487382229956e-15, (3212, 1) = 1.6256737977983668, (3212, 2) = -0.6231621240316425e-16, (3213, 1) = 1.6265321780464823, (3213, 2) = 0.6230080349480069e-16, (3214, 1) = 1.6273905582945978, (3214, 2) = .0, (3215, 1) = 1.6282489385427135, (3215, 2) = -0.12453999116330424e-15, (3216, 1) = 1.6291073187908292, (3216, 2) = -0.12450919316954305e-15, (3217, 1) = 1.6299656990389446, (3217, 2) = 0.1244784017992103e-15, (3218, 1) = 1.63082407928706, (3218, 2) = 0.6222380853007846e-16, (3219, 1) = 1.6316824595351758, (3219, 2) = -0.12441683896021239e-15, (3220, 1) = 1.6333992200314071, (3220, 2) = -0.6217765135443087e-16, (3221, 1) = 1.6351159805276383, (3221, 2) = .0, (3222, 1) = 1.6359743607757538, (3222, 2) = 0.6213152415983371e-16, (3223, 1) = 1.6368327410238694, (3223, 2) = .0, (3224, 1) = 1.6376911212719851, (3224, 2) = 0.6210078940443204e-16, (3225, 1) = 1.6385495015201008, (3225, 2) = 0.6208542705055165e-16, (3226, 1) = 1.6394078817682165, (3226, 2) = -0.12414013610196193e-15, (3227, 1) = 1.640266262016332, (3227, 2) = 0.24821884963811546e-15, (3228, 1) = 1.6411246422644474, (3228, 2) = .0, (3229, 1) = 1.6419830225125631, (3229, 2) = -0.620240112161635e-16, (3230, 1) = 1.642960617418342, (3230, 2) = 0.6200653469909372e-16, (3231, 1) = 1.6439382123241209, (3231, 2) = -0.18596718767397406e-15, (3232, 1) = 1.6449158072298997, (3232, 2) = 0.6197159479840229e-16, (3233, 1) = 1.6458934021356786, (3233, 2) = .0, (3234, 1) = 1.6478485919472363, (3234, 2) = -0.619192178639114e-16, (3235, 1) = 1.649803781758794, (3235, 2) = -0.12376864383207675e-15, (3236, 1) = 1.6537141613819095, (3236, 2) = -0.12362916607324408e-15, (3237, 1) = 1.657624541005025, (3237, 2) = -0.12348983026614253e-15, (3238, 1) = 1.6615349206281405, (3238, 2) = -0.12335063709287757e-15, (3239, 1) = 1.665445300251256, (3239, 2) = -0.1232115872267894e-15, (3240, 1) = 1.6664228951570348, (3240, 2) = .0, (3241, 1) = 1.6674004900628137, (3241, 2) = -0.12314211624197354e-15, (3242, 1) = 1.6683780849685925, (3242, 2) = .0, (3243, 1) = 1.6693556798743714, (3243, 2) = .0, (3244, 1) = 1.6713108696859291, (3244, 2) = .0, (3245, 1) = 1.6732660594974869, (3245, 2) = .0, (3246, 1) = 1.6742103679145723, (3246, 2) = .0, (3247, 1) = 1.6751546763316578, (3247, 2) = 0.12286695378587583e-15, (3248, 1) = 1.6760989847487433, (3248, 2) = .0, (3249, 1) = 1.6770432931658288, (3249, 2) = -0.1228000214657073e-15, (3250, 1) = 1.6779876015829143, (3250, 2) = 0.1227665680630645e-15, (3251, 1) = 1.6789319099999997, (3251, 2) = -0.24546624635458985e-15, (3252, 1) = 1.679876218417085, (3252, 2) = -0.12269968681729676e-15, (3253, 1) = 1.6808205268341705, (3253, 2) = -0.1226662589919395e-15, (3254, 1) = 1.6845977605025122, (3254, 2) = .0, (3255, 1) = 1.6883749941708541, (3255, 2) = 0.12239914469106117e-15, (3256, 1) = 1.692152227839196, (3256, 2) = .0, (3257, 1) = 1.6959294615075378, (3257, 2) = -0.12213258162440162e-15, (3258, 1) = 1.6968737699246232, (3258, 2) = .0, (3259, 1) = 1.6978180783417085, (3259, 2) = 0.12206602749982862e-15, (3260, 1) = 1.698762386758794, (3260, 2) = .0, (3261, 1) = 1.6997066951758795, (3261, 2) = 0.12199950816631723e-15, (3262, 1) = 1.700651003592965, (3262, 2) = 0.12196626156695634e-15, (3263, 1) = 1.7015953120100504, (3263, 2) = .0, (3264, 1) = 1.702539620427136, (3264, 2) = .0, (3265, 1) = 1.7034839288442214, (3265, 2) = .0, (3266, 1) = 1.711033461030151, (3266, 2) = -0.12160129968828694e-15, (3267, 1) = 1.7185829932160805, (3267, 2) = -0.2426731768599862e-15, (3268, 1) = 1.7195266847393218, (3268, 2) = .0, (3269, 1) = 1.720470376262563, (3269, 2) = 0.12127049908517769e-15, (3270, 1) = 1.7214140677858043, (3270, 2) = .0, (3271, 1) = 1.7223577593090453, (3271, 2) = .0, (3272, 1) = 1.7242451423555276, (3272, 2) = .0, (3273, 1) = 1.7261325254020101, (3273, 2) = .0, (3274, 1) = 1.7270762169252514, (3274, 2) = -0.1210394664300316e-15, (3275, 1) = 1.7280199084484926, (3275, 2) = .0, (3276, 1) = 1.7289635999717339, (3276, 2) = .0, (3277, 1) = 1.729907291494975, (3277, 2) = 0.24188117249229163e-15, (3278, 1) = 1.730850983018216, (3278, 2) = -0.1209076440811079e-15, (3279, 1) = 1.7317946745414572, (3279, 2) = -0.1208747108765149e-15, (3280, 1) = 1.7327383660646984, (3280, 2) = .0, (3281, 1) = 1.7336820575879397, (3281, 2) = -0.12080887137804057e-15, (3282, 1) = 1.7346222774403266, (3282, 2) = .0, (3283, 1) = 1.7355624972927135, (3283, 2) = .0, (3284, 1) = 1.7365027171451004, (3284, 2) = -0.1207105424377498e-15, (3285, 1) = 1.7374429369974873, (3285, 2) = .0, (3286, 1) = 1.7383831568498742, (3286, 2) = 0.1206450344887135e-15, (3287, 1) = 1.7393233767022611, (3287, 2) = 0.12061229393889292e-15, (3288, 1) = 1.740263596554648, (3288, 2) = 0.12057956234830073e-15, (3289, 1) = 1.741203816407035, (3289, 2) = .0, (3290, 1) = 1.7421440362594218, (3290, 2) = 0.24102825214587986e-15, (3291, 1) = 1.7430842561118087, (3291, 2) = -0.2409628428043554e-15, (3292, 1) = 1.7440244759641956, (3292, 2) = .0, (3293, 1) = 1.7449646958165825, (3293, 2) = .0, (3294, 1) = 1.7459049156689694, (3294, 2) = .0, (3295, 1) = 1.7468451355213563, (3295, 2) = .0, (3296, 1) = 1.7477853553737432, (3296, 2) = -0.120318032995418e-15, (3297, 1) = 1.7487255752261301, (3297, 2) = -0.12028538235170997e-15, (3298, 1) = 1.749665795078517, (3298, 2) = -0.12025274073651163e-15, (3299, 1) = 1.750606014930904, (3299, 2) = .0, (3300, 1) = 1.7515462347832909, (3300, 2) = 0.12018748461878353e-15, (3301, 1) = 1.7524864546356778, (3301, 2) = -0.1201548701297618e-15, (3302, 1) = 1.7534266744880647, (3302, 2) = -0.12012226469626578e-15, (3303, 1) = 1.7543668943404516, (3303, 2) = .0, (3304, 1) = 1.7553071141928385, (3304, 2) = 0.12005708102259613e-15, (3305, 1) = 1.7562473340452254, (3305, 2) = .0, (3306, 1) = 1.760008213454773, (3306, 2) = .0, (3307, 1) = 1.7637690928643206, (3307, 2) = .0, (3308, 1) = 1.7709951483165822, (3308, 2) = .0, (3309, 1) = 1.7782212037688438, (3309, 2) = .0, (3310, 1) = 1.7791244607003764, (3310, 2) = .0, (3311, 1) = 1.7800277176319093, (3311, 2) = 0.11920355956640708e-15, (3312, 1) = 1.780930974563442, (3312, 2) = 0.1191724933623645e-15, (3313, 1) = 1.7818342314949747, (3313, 2) = 0.11914143569284138e-15, (3314, 1) = 1.7827374884265073, (3314, 2) = -0.11911038656313036e-15, (3315, 1) = 1.78364074535804, (3315, 2) = .0, (3316, 1) = 1.7845440022895729, (3316, 2) = -0.11904831394421597e-15, (3317, 1) = 1.7854472592211055, (3317, 2) = 0.11901729046549906e-15, (3318, 1) = 1.7890602869472363, (3318, 2) = 0.1188932822103226e-15, (3319, 1) = 1.792673314673367, (3319, 2) = 0.11876941125784943e-15, (3320, 1) = 1.8082964292964827, (3320, 2) = .0, (3321, 1) = 1.8239195439195983, (3321, 2) = -0.11770392408643126e-15, (3322, 1) = 1.8313645244472363, (3322, 2) = .0, (3323, 1) = 1.8388095049748743, (3323, 2) = 0.11719985915676218e-15, (3324, 1) = 1.839740127540829, (3324, 2) = .0, (3325, 1) = 1.8406707501067838, (3325, 2) = 0.1171370194709795e-15, (3326, 1) = 1.8416013726727387, (3326, 2) = 0.2342112274142153e-15, (3327, 1) = 1.8425319952386934, (3327, 2) = -0.11707421733517215e-15, (3328, 1) = 1.843462617804648, (3328, 2) = .0, (3329, 1) = 1.8443932403706027, (3329, 2) = -0.23402290556952333e-15, (3330, 1) = 1.8453238629365574, (3330, 2) = -0.11698008461506316e-15, (3331, 1) = 1.8462544855025123, (3331, 2) = -0.11694872585485394e-15, (3332, 1) = 1.8471851080684671, (3332, 2) = .0, (3333, 1) = 1.8481157306344218, (3333, 2) = -0.11688603658024043e-15, (3334, 1) = 1.8490463532003765, (3334, 2) = .0, (3335, 1) = 1.8499769757663311, (3335, 2) = 0.1168233849953995e-15, (3336, 1) = 1.8509075983322858, (3336, 2) = 0.2335841466946657e-15, (3337, 1) = 1.8518382208982407, (3337, 2) = -0.23352154226899477e-15, (3338, 1) = 1.8527688434641956, (3338, 2) = -0.11672947836111536e-15, (3339, 1) = 1.8536994660301502, (3339, 2) = -0.11669819503138967e-15, (3340, 1) = 1.8546789024591703, (3340, 2) = -0.116665281004205e-15, (3341, 1) = 1.8556583388881904, (3341, 2) = -0.23326475489368275e-15, (3342, 1) = 1.8566377753172105, (3342, 2) = -0.1165994843641292e-15, (3343, 1) = 1.8576172117462306, (3343, 2) = 0.11656660176087526e-15, (3344, 1) = 1.8585966481752507, (3344, 2) = 0.11653372964186293e-15, (3345, 1) = 1.8595760846042708, (3345, 2) = 0.11650086801185206e-15, (3346, 1) = 1.860555521033291, (3346, 2) = -0.11646801687557918e-15, (3347, 1) = 1.8615349574623112, (3347, 2) = .0, (3348, 1) = 1.8634938303203517, (3348, 2) = 0.116369526476203e-15, (3349, 1) = 1.8654527031783918, (3349, 2) = 0.23260783752885726e-15, (3350, 1) = 1.866432139607412, (3350, 2) = .0, (3351, 1) = 1.867411576036432, (3351, 2) = -0.11623835313930327e-15, (3352, 1) = 1.8683910124654521, (3352, 2) = .0, (3353, 1) = 1.8693704488944722, (3353, 2) = .0, (3354, 1) = 1.8713293217525124, (3354, 2) = .0, (3355, 1) = 1.8732881946105526, (3355, 2) = .0, (3356, 1) = 1.8742676310395727, (3356, 2) = .0, (3357, 1) = 1.8752470674685928, (3357, 2) = -0.11597651222978588e-15, (3358, 1) = 1.876226503897613, (3358, 2) = -0.1159438296185689e-15, (3359, 1) = 1.8772059403266332, (3359, 2) = -0.11591115757807547e-15, (3360, 1) = 1.8781853767556536, (3360, 2) = .0, (3361, 1) = 1.8791648131846737, (3361, 2) = -0.11584584522653014e-15, (3362, 1) = 1.8801442496136938, (3362, 2) = .0, (3363, 1) = 1.8811236860427138, (3363, 2) = -0.231561150418934e-15, (3364, 1) = 1.882103122471734, (3364, 2) = 0.11574795608699228e-15, (3365, 1) = 1.883082558900754, (3365, 2) = .0, (3366, 1) = 1.8840619953297741, (3366, 2) = 0.11568274963521313e-15, (3367, 1) = 1.8850414317587942, (3367, 2) = 0.2313003246285292e-15, (3368, 1) = 1.8859280575816586, (3368, 2) = -0.11562067208998855e-15, (3369, 1) = 1.886814683404523, (3369, 2) = .0, (3370, 1) = 1.887701309227387, (3370, 2) = -0.1155617177342169e-15, (3371, 1) = 1.8885879350502515, (3371, 2) = .0, (3372, 1) = 1.8894745608731158, (3372, 2) = 0.115502798189039e-15, (3373, 1) = 1.89036118669598, (3373, 2) = -0.11547335147794973e-15, (3374, 1) = 1.8912478125188443, (3374, 2) = -0.11544391347851186e-15, (3375, 1) = 1.8921344383417087, (3375, 2) = -0.11541448419369572e-15, (3376, 1) = 1.893021064164573, (3376, 2) = -0.115385063626457e-15, (3377, 1) = 1.8939076899874374, (3377, 2) = .0, (3378, 1) = 1.8947943158103016, (3378, 2) = 0.11532624865646136e-15, (3379, 1) = 1.895680941633166, (3379, 2) = 0.2305937085190854e-15, (3380, 1) = 1.8974541932788944, (3380, 2) = 0.1152380916563503e-15, (3381, 1) = 1.8992274449246231, (3381, 2) = .0, (3382, 1) = 1.9010006965703519, (3382, 2) = .0, (3383, 1) = 1.9027739482160804, (3383, 2) = .0, (3384, 1) = 1.9036605740389447, (3384, 2) = 0.1150326978466032e-15, (3385, 1) = 1.9045471998618089, (3385, 2) = -0.2300067817404328e-15, (3386, 1) = 1.9054338256846732, (3386, 2) = .0, (3387, 1) = 1.9063204515075376, (3387, 2) = 0.11494480319248042e-15, (3388, 1) = 1.907207077330402, (3388, 2) = 0.11491552249659517e-15, (3389, 1) = 1.9080937031532663, (3389, 2) = -0.2297725011326347e-15, (3390, 1) = 1.9089803289761305, (3390, 2) = -0.11485698740434347e-15, (3391, 1) = 1.9098669547989948, (3391, 2) = 0.22965546602671173e-15, (3392, 1) = 1.9107535806218592, (3392, 2) = .0, (3393, 1) = 1.9116402064447233, (3393, 2) = .0, (3394, 1) = 1.9125268322675877, (3394, 2) = -0.11474002249292275e-15, (3395, 1) = 1.913413458090452, (3395, 2) = -0.114710803212422e-15, (3396, 1) = 1.9212525581909545, (3396, 2) = .0, (3397, 1) = 1.929091658291457, (3397, 2) = 0.11419557217291694e-15, (3398, 1) = 1.9300715458040199, (3398, 2) = 0.11416346174925876e-15, (3399, 1) = 1.9310514333165827, (3399, 2) = .0, (3400, 1) = 1.9320313208291455, (3400, 2) = .0, (3401, 1) = 1.9330112083417084, (3401, 2) = .0, (3402, 1) = 1.934970983366834, (3402, 2) = -0.11400307148613328e-15, (3403, 1) = 1.9369307583919595, (3403, 2) = -0.2278779819428276e-15, (3404, 1) = 1.9379106459045223, (3404, 2) = -0.11390696692429983e-15, (3405, 1) = 1.938890533417085, (3405, 2) = -0.11387495368804854e-15, (3406, 1) = 1.9398704209296478, (3406, 2) = .0, (3407, 1) = 1.9408503084422106, (3407, 2) = -0.11381095966011166e-15, (3408, 1) = 1.9428100834673363, (3408, 2) = .0, (3409, 1) = 1.944769858492462, (3409, 2) = 0.11368310146524453e-15, (3410, 1) = 1.9457084199780148, (3410, 2) = 0.11365251070845633e-15, (3411, 1) = 1.9466469814635676, (3411, 2) = -0.11362192989127905e-15, (3412, 1) = 1.9475855429491205, (3412, 2) = 0.2271827180324238e-15, (3413, 1) = 1.948524104434673, (3413, 2) = -0.11356079808573787e-15, (3414, 1) = 1.9494626659202257, (3414, 2) = -0.2270604942046473e-15, (3415, 1) = 1.9504012274057785, (3415, 2) = .0, (3416, 1) = 1.9513397888913313, (3416, 2) = .0, (3417, 1) = 1.9522783503768841, (3417, 2) = .0, (3418, 1) = 1.953216911862437, (3418, 2) = -0.1134081426880314e-15, (3419, 1) = 1.9541554733479898, (3419, 2) = -0.11337764147634972e-15, (3420, 1) = 1.9550940348335426, (3420, 2) = 0.1133471502261883e-15, (3421, 1) = 1.9560325963190952, (3421, 2) = .0, (3422, 1) = 1.9569711578046478, (3422, 2) = .0, (3423, 1) = 1.9579097192902006, (3423, 2) = -0.1132557362682836e-15, (3424, 1) = 1.9588482807757535, (3424, 2) = .0, (3425, 1) = 1.9597868422613063, (3425, 2) = 0.11319484348000855e-15, (3426, 1) = 1.960725403746859, (3426, 2) = .0, (3427, 1) = 1.961663965232412, (3427, 2) = .0, (3428, 1) = 1.9626025267179648, (3428, 2) = -0.1131035791187299e-15, (3429, 1) = 1.9635410882035174, (3429, 2) = .0, (3430, 1) = 1.96447964968907, (3430, 2) = .0, (3431, 1) = 1.9654182111746228, (3431, 2) = 0.11301240459653847e-15, (3432, 1) = 1.9663567726601756, (3432, 2) = 0.22596406612732906e-15, (3433, 1) = 1.9672953341457284, (3433, 2) = 0.11295167152167202e-15, (3434, 1) = 1.9682338956312813, (3434, 2) = -0.11292131997270936e-15, (3435, 1) = 1.969172457116834, (3435, 2) = -0.11289097841890947e-15, (3436, 1) = 1.970111018602387, (3436, 2) = -0.22572129372477954e-15, (3437, 1) = 1.9710495800879395, (3437, 2) = -0.2256606506105042e-15, (3438, 1) = 1.972926703059045, (3438, 2) = -0.11276971219745321e-15, (3439, 1) = 1.9748038260301506, (3439, 2) = .0, (3440, 1) = 1.9757401030307786, (3440, 2) = .0, (3441, 1) = 1.9766763800314069, (3441, 2) = 0.22529750671143865e-15, (3442, 1) = 1.9776126570320351, (3442, 2) = -0.1126185754240297e-15, (3443, 1) = 1.9785489340326632, (3443, 2) = .0, (3444, 1) = 1.9794852110332912, (3444, 2) = .0, (3445, 1) = 1.9804214880339195, (3445, 2) = 0.2250562028766702e-15, (3446, 1) = 1.9813577650345477, (3446, 2) = -0.1124979633860108e-15, (3447, 1) = 1.9822940420351758, (3447, 2) = -0.22493567061665455e-15, (3448, 1) = 1.9832303190358038, (3448, 2) = .0, (3449, 1) = 1.984166596036432, (3449, 2) = -0.2248152181688545e-15, (3450, 1) = 1.9851028730370603, (3450, 2) = -0.33713253282583757e-15, (3451, 1) = 1.9860391500376884, (3451, 2) = 0.22469484556315126e-15, (3452, 1) = 1.9869754270383164, (3452, 2) = .0, (3453, 1) = 1.9879117040389447, (3453, 2) = 0.11228727641447587e-15, (3454, 1) = 1.988847981039573, (3454, 2) = .0, (3455, 1) = 1.989784258040201, (3455, 2) = 0.1122271699975953e-15, (3456, 1) = 1.9916568120414573, (3456, 2) = 0.1121671035451661e-15, (3457, 1) = 1.9935293660427136, (3457, 2) = 0.11210707707118623e-15, (3458, 1) = 1.9944656430433416, (3458, 2) = .0, (3459, 1) = 1.9954019200439699, (3459, 2) = .0, (3460, 1) = 1.9963381970445981, (3460, 2) = 0.1120171123498563e-15, (3461, 1) = 1.9972744740452262, (3461, 2) = .0, (3462, 1) = 1.9982107510458542, (3462, 2) = -0.11195718588171396e-15, (3463, 1) = 1.9991470280464825, (3463, 2) = .0, (3464, 1) = 2.0000833050471107, (3464, 2) = 0.11189729943918493e-15, (3465, 1) = 2.0010195820477388, (3465, 2) = -0.11186737123158341e-15, (3466, 1) = 2.0019558590483673, (3466, 2) = -0.1118374530352262e-15, (3467, 1) = 2.0028921360489953, (3467, 2) = .0, (3468, 1) = 2.0038284130496233, (3468, 2) = 0.1117776466825661e-15, (3469, 1) = 2.0047646900502514, (3469, 2) = .0, (3470, 1) = 2.0057426350062815, (3470, 2) = -0.33514965280115223e-15, (3471, 1) = 2.0067205799623116, (3471, 2) = 0.11168535426875626e-15, (3472, 1) = 2.0076985249183417, (3472, 2) = 0.1116541685362281e-15, (3473, 1) = 2.0086764698743718, (3473, 2) = 0.11162299373783932e-15, (3474, 1) = 2.010632359786432, (3474, 2) = .0, (3475, 1) = 2.012588249698492, (3475, 2) = -0.11149840391922292e-15, (3476, 1) = 2.0135661946545222, (3476, 2) = -0.11146728381654418e-15, (3477, 1) = 2.0145441396105523, (3477, 2) = -0.11143617465789387e-15, (3478, 1) = 2.0155220845665824, (3478, 2) = -0.11140507644486232e-15, (3479, 1) = 2.0165000295226125, (3479, 2) = -0.22274797835804666e-15, (3480, 1) = 2.0174779744786426, (3480, 2) = .0, (3481, 1) = 2.0184559194346727, (3481, 2) = .0, (3482, 1) = 2.0194338643907033, (3482, 2) = 0.22256158616030915e-15, (3483, 1) = 2.0204118093467334, (3483, 2) = .0, (3484, 1) = 2.0213897543027635, (3484, 2) = -0.11121871711165588e-15, (3485, 1) = 2.022367699258794, (3485, 2) = 0.22237539112221466e-15, (3486, 1) = 2.023345644214824, (3486, 2) = 0.1111566849683112e-15, (3487, 1) = 2.024323589170854, (3487, 2) = .0, (3488, 1) = 2.0253015341268843, (3488, 2) = .0, (3489, 1) = 2.0262794790829144, (3489, 2) = -0.1110637189507936e-15, (3490, 1) = 2.0272574240389445, (3490, 2) = 0.11103275220328313e-15, (3491, 1) = 2.0282353689949746, (3491, 2) = -0.1110017964205829e-15, (3492, 1) = 2.0292133139510047, (3492, 2) = 0.11097085160405642e-15, (3493, 1) = 2.030191258907035, (3493, 2) = -0.22187983551010275e-15, (3494, 1) = 2.031169203863065, (3494, 2) = .0, (3495, 1) = 2.032147148819095, (3495, 2) = 0.11087808296491682e-15, (3496, 1) = 2.033125093775125, (3496, 2) = -0.2216943640528067e-15, (3497, 1) = 2.034103038731155, (3497, 2) = -0.11081629206064352e-15, (3498, 1) = 2.0350809836871853, (3498, 2) = .0, (3499, 1) = 2.0360589286432154, (3499, 2) = 0.11075454505244349e-15, (3500, 1) = 2.0369596516488686, (3500, 2) = 0.22145224838598683e-15, (3501, 1) = 2.037860374654522, (3501, 2) = -0.11069771264596454e-15, (3502, 1) = 2.038761097660175, (3502, 2) = 0.11066931041230062e-15, (3503, 1) = 2.0396618206658284, (3503, 2) = 0.11064091749293423e-15, (3504, 1) = 2.0405625436714816, (3504, 2) = 0.11061253388878681e-15, (3505, 1) = 2.041463266677135, (3505, 2) = .0, (3506, 1) = 2.042363989682788, (3506, 2) = -0.11055579462977878e-15, (3507, 1) = 2.0432647126884413, (3507, 2) = .0, (3508, 1) = 2.0441654356940946, (3508, 2) = -0.11049909264242537e-15, (3509, 1) = 2.045066158699748, (3509, 2) = 0.11047075562780472e-15, (3510, 1) = 2.045966881705401, (3510, 2) = 0.1104424279336983e-15, (3511, 1) = 2.0468676047110543, (3511, 2) = -0.11041410956095002e-15, (3512, 1) = 2.0477683277167076, (3512, 2) = -0.3311574015311786e-15, (3513, 1) = 2.048669050722361, (3513, 2) = .0, (3514, 1) = 2.049569773728014, (3514, 2) = 0.11032921037912872e-15, (3515, 1) = 2.0504704967336678, (3515, 2) = .0, (3516, 1) = 2.0513712197393215, (3516, 2) = -0.33081797263905206e-15, (3517, 1) = 2.0522719427449747, (3517, 2) = .0, (3518, 1) = 2.053172665750628, (3518, 2) = 0.11021614201832957e-15, (3519, 1) = 2.054073388756281, (3519, 2) = -0.11018789824551499e-15, (3520, 1) = 2.0549741117619345, (3520, 2) = 0.22031932760232526e-15, (3521, 1) = 2.0558748347675877, (3521, 2) = -0.11013143868600772e-15, (3522, 1) = 2.056775557773241, (3522, 2) = 0.11010322290077468e-15, (3523, 1) = 2.057676280778894, (3523, 2) = .0, (3524, 1) = 2.0585770037845474, (3524, 2) = .0, (3525, 1) = 2.0594777267902007, (3525, 2) = 0.11001863153169107e-15, (3526, 1) = 2.060378449795854, (3526, 2) = 0.2199809061463527e-15, (3527, 1) = 2.061279172801507, (3527, 2) = .0, (3528, 1) = 2.0621798958071604, (3528, 2) = -0.10993412415695929e-15, (3529, 1) = 2.0630806188128137, (3529, 2) = -0.2198119474011348e-15, (3530, 1) = 2.063981341818467, (3530, 2) = 0.32963349773852793e-15, (3531, 1) = 2.06488206482412, (3531, 2) = 0.10984970079441391e-15, (3532, 1) = 2.065804528388819, (3532, 2) = -0.21964179935152217e-15, (3533, 1) = 2.066726991953517, (3533, 2) = .0, (3534, 1) = 2.0676494555182154, (3534, 2) = 0.10976332681924654e-15, (3535, 1) = 2.068571919082914, (3535, 2) = 0.3292036652479678e-15, (3536, 1) = 2.069494382647613, (3536, 2) = -0.21941158628267618e-15, (3537, 1) = 2.070416846212311, (3537, 2) = -0.10967704099589996e-15, (3538, 1) = 2.0713393097770094, (3538, 2) = -0.21929659729387415e-15, (3539, 1) = 2.072261773341708, (3539, 2) = .0, (3540, 1) = 2.075951627600502, (3540, 2) = .0, (3541, 1) = 2.079641481859296, (3541, 2) = .0, (3542, 1) = 2.080563945423995, (3542, 2) = 0.10936141408636177e-15, (3543, 1) = 2.081486408988693, (3543, 2) = -0.109332779534696e-15, (3544, 1) = 2.0824088725533914, (3544, 2) = -0.2186083095715434e-15, (3545, 1) = 2.08333133611809, (3545, 2) = 0.21855107968007694e-15, (3546, 1) = 2.084253799682789, (3546, 2) = .0, (3547, 1) = 2.085176263247487, (3547, 2) = 0.10921833935988851e-15, (3548, 1) = 2.0860987268121853, (3548, 2) = 0.10918975382631585e-15, (3549, 1) = 2.087021190376884, (3549, 2) = -0.10916117809762246e-15, (3550, 1) = 2.0879436539415828, (3550, 2) = 0.109132612174203e-15, (3551, 1) = 2.088866117506281, (3551, 2) = .0, (3552, 1) = 2.0897885810709793, (3552, 2) = 0.10907550974470979e-15, (3553, 1) = 2.090711044635678, (3553, 2) = 0.2180939464787415e-15, (3554, 1) = 2.0916335082003767, (3554, 2) = -0.21803689308155024e-15, (3555, 1) = 2.092555971765075, (3555, 2) = 0.21797985929852646e-15, (3556, 1) = 2.0934784353297733, (3556, 2) = -0.21792284513032902e-15, (3557, 1) = 2.094400898894472, (3557, 2) = 0.10893292528879766e-15, (3558, 1) = 2.1106970490452257, (3558, 2) = .0, (3559, 1) = 2.1269931991959794, (3559, 2) = -0.10793236182565325e-15, (3560, 1) = 2.130681906482412, (3560, 2) = .0, (3561, 1) = 2.134370613768844, (3561, 2) = 0.10770757980598433e-15, (3562, 1) = 2.138059321055276, (3562, 2) = 0.10759542412724355e-15, (3563, 1) = 2.1417480283417083, (3563, 2) = 0.10748342532319486e-15, (3564, 1) = 2.1454367356281407, (3564, 2) = .0, (3565, 1) = 2.1491254429145727, (3565, 2) = -0.10725989828633626e-15, (3566, 1) = 2.1500476197361804, (3566, 2) = -0.1072320015179727e-15, (3567, 1) = 2.1509697965577885, (3567, 2) = 0.10720411455117596e-15, (3568, 1) = 2.1518919733793966, (3568, 2) = -0.10717623738564085e-15, (3569, 1) = 2.1528141502010048, (3569, 2) = 0.10714837002105295e-15, (3570, 1) = 2.153736327022613, (3570, 2) = -0.10712051245708854e-15, (3571, 1) = 2.154658503844221, (3571, 2) = 0.1070926646934147e-15, (3572, 1) = 2.155580680665829, (3572, 2) = 0.1070648267296893e-15, (3573, 1) = 2.156502857487437, (3573, 2) = -0.10703699856556099e-15, (3574, 1) = 2.1574459560207284, (3574, 2) = .0, (3575, 1) = 2.15838905455402, (3575, 2) = -0.10698011006390415e-15, (3576, 1) = 2.1593321530873117, (3576, 2) = -0.21390336237090535e-15, (3577, 1) = 2.160275251620603, (3577, 2) = .0, (3578, 1) = 2.161218350153894, (3578, 2) = -0.10689485417122674e-15, (3579, 1) = 2.162161448687186, (3579, 2) = -0.21373291206918353e-15, (3580, 1) = 2.1631045472204775, (3580, 2) = 0.10683806814435193e-15, (3581, 1) = 2.1640476457537687, (3581, 2) = -0.2136193810001048e-15, (3582, 1) = 2.16499074428706, (3582, 2) = 0.10678132310122837e-15, (3583, 1) = 2.1659338428203516, (3583, 2) = 0.21350593189481055e-15, (3584, 1) = 2.1668769413536433, (3584, 2) = -0.1067246190380988e-15, (3585, 1) = 2.1678200398869345, (3585, 2) = 0.21339256474562976e-15, (3586, 1) = 2.1687631384202257, (3586, 2) = .0, (3587, 1) = 2.1697062369535174, (3587, 2) = 0.10663963977228961e-15, (3588, 1) = 2.170649335486809, (3588, 2) = .0, (3589, 1) = 2.1715924340201003, (3589, 2) = 0.21316607628336548e-15, (3590, 1) = 2.1725355325533915, (3590, 2) = -0.21310950537752109e-15, (3591, 1) = 2.173478631086683, (3591, 2) = 0.3195794324300787e-15, (3592, 1) = 2.174421729619975, (3592, 2) = .0, (3593, 1) = 2.175364828153266, (3593, 2) = .0, (3594, 1) = 2.1763079266865573, (3594, 2) = .0, (3595, 1) = 2.177251025219849, (3595, 2) = .0, (3596, 1) = 2.1781941237531406, (3596, 2) = .0, (3597, 1) = 2.179137222286432, (3597, 2) = 0.2127140824602222e-15, (3598, 1) = 2.180080320819723, (3598, 2) = -0.21265767537552946e-15, (3599, 1) = 2.1810234193530147, (3599, 2) = .0, (3600, 1) = 2.1819665178863064, (3600, 2) = 0.10627246131071877e-15, (3601, 1) = 2.1829096164195976, (3601, 2) = .0, (3602, 1) = 2.183852714952889, (3602, 2) = -0.10621612587290515e-15, (3603, 1) = 2.1847958134861805, (3603, 2) = .0, (3604, 1) = 2.185738912019472, (3604, 2) = 0.10615983136903683e-15, (3605, 1) = 2.1866820105527633, (3605, 2) = 0.10613169946563933e-15, (3606, 1) = 2.1876411174685924, (3606, 2) = 0.31830930161377203e-15, (3607, 1) = 2.1886002243844214, (3607, 2) = 0.21214902438239127e-15, (3608, 1) = 2.1895593313002504, (3608, 2) = 0.10604593442470526e-15, (3609, 1) = 2.19051843821608, (3609, 2) = -0.3180521017130824e-15, (3610, 1) = 2.1914775451319093, (3610, 2) = 0.31796643188818115e-15, (3611, 1) = 2.1924366520477383, (3611, 2) = -0.21192052919805143e-15, (3612, 1) = 2.1933957589635673, (3612, 2) = -0.1059317291458021e-15, (3613, 1) = 2.1943548658793963, (3613, 2) = -0.3177096128067751e-15, (3614, 1) = 2.1953139727952253, (3614, 2) = -0.21174937993517415e-15, (3615, 1) = 2.196273079711055, (3615, 2) = .0, (3616, 1) = 2.1972321866268842, (3616, 2) = .0, (3617, 1) = 2.1981912935427133, (3617, 2) = 0.1057892105085881e-15, (3618, 1) = 2.1991504004585423, (3618, 2) = 0.10576073850113873e-15, (3619, 1) = 2.2001095073743713, (3619, 2) = -0.10573227706504649e-15, (3620, 1) = 2.2010686142902003, (3620, 2) = 0.21140765239889258e-15, (3621, 1) = 2.2020277212060297, (3621, 2) = -0.1056753859034634e-15, (3622, 1) = 2.202986828121859, (3622, 2) = -0.10564695617621372e-15, (3623, 1) = 2.203945935037688, (3623, 2) = .0, (3624, 1) = 2.204905041953517, (3624, 2) = .0, (3625, 1) = 2.2058641488693462, (3625, 2) = 0.2111234607957608e-15, (3626, 1) = 2.2068232557851752, (3626, 2) = 0.2110666858730658e-15, (3627, 1) = 2.2077823627010047, (3627, 2) = -0.2110099320787123e-15, (3628, 1) = 2.208741469616834, (3628, 2) = -0.10547659970540963e-15, (3629, 1) = 2.209700576532663, (3629, 2) = 0.31634473180122993e-15, (3630, 1) = 2.210659683448492, (3630, 2) = .0, (3631, 1) = 2.211618790364321, (3631, 2) = -0.21078312814681025e-15, (3632, 1) = 2.21257789728015, (3632, 2) = .0, (3633, 1) = 2.2135370041959797, (3633, 2) = .0, (3634, 1) = 2.214496111111809, (3634, 2) = 0.1053066234757171e-15, (3635, 1) = 2.215455218027638, (3635, 2) = -0.10527833105726391e-15, (3636, 1) = 2.216414324943467, (3636, 2) = .0, (3637, 1) = 2.217373431859296, (3637, 2) = 0.10522177788544817e-15, (3638, 1) = 2.218255037751256, (3638, 2) = .0, (3639, 1) = 2.219136643643216, (3639, 2) = .0, (3640, 1) = 2.2200182495351757, (3640, 2) = 0.10514387205577618e-15, (3641, 1) = 2.2208998554271355, (3641, 2) = 0.10511792127547345e-15, (3642, 1) = 2.222663067211055, (3642, 2) = .0, (3643, 1) = 2.224426278994975, (3643, 2) = -0.10501420728007288e-15, (3644, 1) = 2.2253078848869348, (3644, 2) = -0.2099766021169078e-15, (3645, 1) = 2.2261894907788946, (3645, 2) = -0.31488721123804943e-15, (3646, 1) = 2.2270710966708545, (3646, 2) = -0.10493651534189409e-15, (3647, 1) = 2.2279527025628143, (3647, 2) = -0.1049106358452138e-15, (3648, 1) = 2.228834308454774, (3648, 2) = -0.1048847652550964e-15, (3649, 1) = 2.229715914346734, (3649, 2) = .0, (3650, 1) = 2.2305975202386934, (3650, 2) = .0, (3651, 1) = 2.2314791261306532, (3651, 2) = 0.20961441383047014e-15, (3652, 1) = 2.232360732022613, (3652, 2) = -0.10478137194245137e-15, (3653, 1) = 2.2332423379145725, (3653, 2) = .0, (3654, 1) = 2.2341239438065323, (3654, 2) = .0, (3655, 1) = 2.235005549698492, (3655, 2) = -0.20940784086572552e-15, (3656, 1) = 2.235887155590452, (3656, 2) = -0.10467812106284409e-15, (3657, 1) = 2.236768761482412, (3657, 2) = -0.10465233059119377e-15, (3658, 1) = 2.2376503673743717, (3658, 2) = -0.20925309803394044e-15, (3659, 1) = 2.2385319732663316, (3659, 2) = -0.10460077633922581e-15, (3660, 1) = 2.242058396834171, (3660, 2) = .0, (3661, 1) = 2.2455848204020104, (3661, 2) = 0.10439491507478187e-15, (3662, 1) = 2.246524583734297, (3662, 2) = 0.10436752785104794e-15, (3663, 1) = 2.2474643470665834, (3663, 2) = 0.41736060290017063e-15, (3664, 1) = 2.2484041103988694, (3664, 2) = 0.3129383510866102e-15, (3665, 1) = 2.249343873731156, (3665, 2) = -0.10428542676129317e-15, (3666, 1) = 2.2512234003957285, (3666, 2) = .0, (3667, 1) = 2.2531029270603016, (3667, 2) = 0.10417609995193435e-15, (3668, 1) = 2.254042690392588, (3668, 2) = -0.2082975869503592e-15, (3669, 1) = 2.2549824537248746, (3669, 2) = .0, (3670, 1) = 2.255922217057161, (3670, 2) = -0.10409421078341916e-15, (3671, 1) = 2.2568619803894476, (3671, 2) = .0, (3672, 1) = 2.257801743721734, (3672, 2) = 0.1040396684320175e-15, (3673, 1) = 2.2587415070540207, (3673, 2) = .0, (3674, 1) = 2.2596812703863067, (3674, 2) = 0.10398516641050138e-15, (3675, 1) = 2.2606210337185932, (3675, 2) = -0.3118737915604342e-15, (3676, 1) = 2.2615607970508798, (3676, 2) = 0.3117921141248335e-15, (3677, 1) = 2.262500560383166, (3677, 2) = 0.10390348897355795e-15, (3678, 1) = 2.2634403237154523, (3678, 2) = 0.20775256662926983e-15, (3679, 1) = 2.264380087047739, (3679, 2) = -0.20769817546030254e-15, (3680, 1) = 2.2653198503800254, (3680, 2) = -0.2076438044374843e-15, (3681, 1) = 2.266259613712312, (3681, 2) = -0.10379472677903534e-15, (3682, 1) = 2.2671993770445984, (3682, 2) = 0.41507024563860525e-15, (3683, 1) = 2.268139140376885, (3683, 2) = 0.4149616244368128e-15, (3684, 1) = 2.2690789037091714, (3684, 2) = .0, (3685, 1) = 2.270018667041458, (3685, 2) = -0.2073722514190623e-15, (3686, 1) = 2.270958430373744, (3686, 2) = 0.10365900060749717e-15, (3687, 1) = 2.2718981937060305, (3687, 2) = 0.2072637711375583e-15, (3688, 1) = 2.272837957038317, (3688, 2) = .0, (3689, 1) = 2.273777720370603, (3689, 2) = .0, (3690, 1) = 2.2747174837028896, (3690, 2) = .0, (3691, 1) = 2.275657247035176, (3691, 2) = .0, (3692, 1) = 2.27658985682789, (3692, 2) = -0.10349666725547921e-15, (3693, 1) = 2.2775224666206033, (3693, 2) = -0.10346981839465073e-15, (3694, 1) = 2.2784550764133167, (3694, 2) = -0.31032893830373936e-15, (3695, 1) = 2.2793876862060305, (3695, 2) = .0, (3696, 1) = 2.2803202959987443, (3696, 2) = -0.10338933121094607e-15, (3697, 1) = 2.2812529057914577, (3697, 2) = 0.10336252194448387e-15, (3698, 1) = 2.282185515584171, (3698, 2) = -0.1033357225729805e-15, (3699, 1) = 2.283118125376885, (3699, 2) = -0.30992679928490777e-15, (3700, 1) = 2.2840507351695987, (3700, 2) = .0, (3701, 1) = 2.284983344962312, (3701, 2) = 0.20651076762704515e-15, (3702, 1) = 2.2859159547550254, (3702, 2) = -0.10322862400711997e-15, (3703, 1) = 2.286848564547739, (3703, 2) = .0, (3704, 1) = 2.2877811743404526, (3704, 2) = -0.103175134055488e-15, (3705, 1) = 2.288713784133166, (3705, 2) = 0.10314840390725129e-15, (3706, 1) = 2.2896463939258798, (3706, 2) = -0.309365050926154e-15, (3707, 1) = 2.290579003718593, (3707, 2) = -0.3092849197751038e-15, (3708, 1) = 2.2915116135113065, (3708, 2) = .0, (3709, 1) = 2.2924442233040203, (3709, 2) = -0.10304158212943616e-15, (3710, 1) = 2.2933768330967337, (3710, 2) = .0, (3711, 1) = 2.294309442889447, (3711, 2) = 0.20597646101632273e-15, (3712, 1) = 2.295242052682161, (3712, 2) = 0.10296156950902445e-15, (3713, 1) = 2.2961746624748742, (3713, 2) = .0, (3714, 1) = 2.2971072722675876, (3714, 2) = 0.2058165542519057e-15, (3715, 1) = 2.2980398820603014, (3715, 2) = .0, (3716, 1) = 2.298972491853015, (3716, 2) = -0.3085650726580291e-15, (3717, 1) = 2.2999051016457286, (3717, 2) = -0.10282841256575913e-15, (3718, 1) = 2.300837711438442, (3718, 2) = .0, (3719, 1) = 2.3017703212311558, (3719, 2) = 0.20555043770014479e-15, (3720, 1) = 2.3027029310238696, (3720, 2) = 0.20549727356953198e-15, (3721, 1) = 2.303635540816583, (3721, 2) = .0, (3722, 1) = 2.3045681506092963, (3722, 2) = -0.20539100446234032e-15, (3723, 1) = 2.30550076040201, (3723, 2) = -0.10266894973963883e-15, (3724, 1) = 2.3064983629899496, (3724, 2) = -0.1026405577359215e-15, (3725, 1) = 2.3074959655778895, (3725, 2) = 0.10261217700626076e-15, (3726, 1) = 2.3084935681658294, (3726, 2) = -0.20516761509728935e-15, (3727, 1) = 2.309491170753769, (3727, 2) = 0.1025554493610532e-15, (3728, 1) = 2.3104887733417083, (3728, 2) = 0.10252710244145795e-15, (3729, 1) = 2.3114863759296482, (3729, 2) = -0.2049975335756448e-15, (3730, 1) = 2.312483978517588, (3730, 2) = 0.10247044239810198e-15, (3731, 1) = 2.3134815811055276, (3731, 2) = 0.40976851708097535e-15, (3732, 1) = 2.314479183693467, (3732, 2) = .0, (3733, 1) = 2.315476786281407, (3733, 2) = 0.10238553679186284e-15, (3734, 1) = 2.316474388869347, (3734, 2) = .0, (3735, 1) = 2.3174719914572863, (3735, 2) = -0.10232898933609544e-15, (3736, 1) = 2.318469594045226, (3736, 2) = 0.20460146497294845e-15, (3737, 1) = 2.3194671966331657, (3737, 2) = -0.10227248688622923e-15, (3738, 1) = 2.3204647992211056, (3738, 2) = -0.10224425253325143e-15, (3739, 1) = 2.321462401809045, (3739, 2) = .0, (3740, 1) = 2.3294432225125625, (3740, 2) = .0, (3741, 1) = 2.33742404321608, (3741, 2) = .0, (3742, 1) = 2.3391847253517586, (3742, 2) = 0.10171652031587755e-15, (3743, 1) = 2.3409454074874367, (3743, 2) = 0.20333417649693696e-15, (3744, 1) = 2.3418257485552756, (3744, 2) = .0, (3745, 1) = 2.342706089623115, (3745, 2) = -0.3048530732042105e-15, (3746, 1) = 2.343586430690954, (3746, 2) = -0.20318601111315456e-15, (3747, 1) = 2.3444667717587935, (3747, 2) = 0.10156832876212071e-15, (3748, 1) = 2.3453471128266328, (3748, 2) = 0.20308732136623806e-15, (3749, 1) = 2.346227453894472, (3749, 2) = .0, (3750, 1) = 2.3471077949623114, (3750, 2) = 0.10149435066513218e-15, (3751, 1) = 2.34798813603015, (3751, 2) = 0.20293941744592371e-15, (3752, 1) = 2.348868477097989, (3752, 2) = -0.20289015097975218e-15, (3753, 1) = 2.3497488181658284, (3753, 2) = -0.20284090192854247e-15, (3754, 1) = 2.3506291592336677, (3754, 2) = -0.10139583514453923e-15, (3755, 1) = 2.351509500301507, (3755, 2) = -0.304113684087203e-15, (3756, 1) = 2.3532701824371856, (3756, 2) = -0.20264407980886825e-15, (3757, 1) = 2.3550308645728637, (3757, 2) = -0.10127288657738387e-15, (3758, 1) = 2.3559112056407026, (3758, 2) = 0.10124832295887504e-15, (3759, 1) = 2.356791546708542, (3759, 2) = 0.202447536069721e-15, (3760, 1) = 2.357671887776381, (3760, 2) = .0, (3761, 1) = 2.3585522288442204, (3761, 2) = -0.40469873705495434e-15, (3762, 1) = 2.3594325699120597, (3762, 2) = -0.1011501554133327e-15, (3763, 1) = 2.360312910979899, (3763, 2) = 0.10112563525082403e-15, (3764, 1) = 2.3611932520477383, (3764, 2) = 0.10110112377455263e-15, (3765, 1) = 2.362073593115577, (3765, 2) = -0.10107662098285432e-15, (3766, 1) = 2.362953934183416, (3766, 2) = -0.30315638062218203e-15, (3767, 1) = 2.3638342752512553, (3767, 2) = 0.20205528289299806e-15, (3768, 1) = 2.3647146163190946, (3768, 2) = 0.10100316469849252e-15, (3769, 1) = 2.365594957386934, (3769, 2) = 0.2019573932567201e-15, (3770, 1) = 2.3666106882286426, (3770, 2) = 0.10095047633495419e-15, (3771, 1) = 2.3676264190703513, (3771, 2) = 0.30276680276704684e-15, (3772, 1) = 2.36864214991206, (3772, 2) = -0.1008940703879416e-15, (3773, 1) = 2.3696578807537683, (3773, 2) = .0, (3774, 1) = 2.3706736115954765, (3774, 2) = 0.30251313182981763e-15, (3775, 1) = 2.371689342437185, (3775, 2) = 0.1008095480277685e-15, (3776, 1) = 2.372705073278894, (3776, 2) = .0, (3777, 1) = 2.3737208041206026, (3777, 2) = .0, (3778, 1) = 2.3747365349623113, (3778, 2) = -0.10072512947697167e-15, (3779, 1) = 2.3757522658040195, (3779, 2) = .0, (3780, 1) = 2.376767996645728, (3780, 2) = -0.10066890807971923e-15, (3781, 1) = 2.3777837274874365, (3781, 2) = 0.10064081466409365e-15, (3782, 1) = 2.379815189170854, (3782, 2) = 0.10058466238546711e-15, (3783, 1) = 2.381846650854271, (3783, 2) = 0.10052855615908826e-15, (3784, 1) = 2.389972497587939, (3784, 2) = 0.10030459134234017e-15, (3785, 1) = 2.3980983443216077, (3785, 2) = 0.10008136161336926e-15, (3786, 1) = 2.3990149630967332, (3786, 2) = .0, (3787, 1) = 2.3999315818718587, (3787, 2) = 0.10003110118962009e-15, (3788, 1) = 2.4008482006469842, (3788, 2) = -0.10000598497576103e-15, (3789, 1) = 2.40176481942211, (3789, 2) = 0.19996175618227785e-15, (3790, 1) = 2.402681438197236, (3790, 2) = -0.999557805336682e-16, (3791, 1) = 2.4035980569723616, (3791, 2) = -0.9993069230125898e-16, (3792, 1) = 2.404514675747487, (3792, 2) = .0, (3793, 1) = 2.4054312945226126, (3793, 2) = -0.9988054380324358e-16, (3794, 1) = 2.4090977696231155, (3794, 2) = .0, (3795, 1) = 2.412764244723618, (3795, 2) = 0.9968032239266605e-16, (3796, 1) = 2.4145974822738694, (3796, 2) = .0, (3797, 1) = 2.4164307198241204, (3797, 2) = -0.9958043499833494e-16, (3798, 1) = 2.417347338599246, (3798, 2) = .0, (3799, 1) = 2.418263957374372, (3799, 2) = -0.9953054706895071e-16, (3800, 1) = 2.4191805761494978, (3800, 2) = .0, (3801, 1) = 2.4200971949246233, (3801, 2) = 0.9948069629506732e-16, (3802, 1) = 2.4210138136997488, (3802, 2) = 0.1989115696720395e-15, (3803, 1) = 2.4219304324748743, (3803, 2) = -0.994308826593367e-16, (3804, 1) = 2.4228470512499998, (3804, 2) = 0.9940598976283939e-16, (3805, 1) = 2.4237636700251257, (3805, 2) = 0.9938110614434492e-16, (3806, 1) = 2.4246802888002517, (3806, 2) = .0, (3807, 1) = 2.425596907575377, (3807, 2) = 0.9933136673261262e-16, (3808, 1) = 2.4265135263505027, (3808, 2) = -0.297919532804966e-15, (3809, 1) = 2.427430145125628, (3809, 2) = 0.19856332881319065e-15, (3810, 1) = 2.428337091491834, (3810, 2) = -0.2977712675590503e-15, (3811, 1) = 2.42924403785804, (3811, 2) = 0.9923252303644986e-16, (3812, 1) = 2.4301509842242464, (3812, 2) = 0.19841593190950544e-15, (3813, 1) = 2.4310579305904523, (3813, 2) = 0.19836683587822604e-15, (3814, 1) = 2.431964876956658, (3814, 2) = 0.19831775797476247e-15, (3815, 1) = 2.4328718233228646, (3815, 2) = -0.19826869819480808e-15, (3816, 1) = 2.4337787696890705, (3816, 2) = 0.9910982826702439e-16, (3817, 1) = 2.4346857160552764, (3817, 2) = .0, (3818, 1) = 2.4355926624214823, (3818, 2) = -0.2971824413292307e-15, (3819, 1) = 2.4364996087876882, (3819, 2) = .0, (3820, 1) = 2.4374065551538946, (3820, 2) = 0.19802367099641323e-15, (3821, 1) = 2.4383135015201005, (3821, 2) = 0.19797471986665202e-15, (3822, 1) = 2.4392204478863064, (3822, 2) = 0.19792578683004258e-15, (3823, 1) = 2.440127394252513, (3823, 2) = -0.19787687188221832e-15, (3824, 1) = 2.4410343406187187, (3824, 2) = 0.2967419625282077e-15, (3825, 1) = 2.4419412869849246, (3825, 2) = .0, (3826, 1) = 2.4428482333511305, (3826, 2) = -0.9886511776383947e-16, (3827, 1) = 2.4437551797173365, (3827, 2) = -0.19768139289118102e-15, (3828, 1) = 2.444662126083543, (3828, 2) = 0.2964488524822867e-15, (3829, 1) = 2.4455690724497487, (3829, 2) = 0.9879188090714926e-16, (3830, 1) = 2.4464760188159547, (3830, 2) = -0.987674866825426e-16, (3831, 1) = 2.447382965182161, (3831, 2) = -0.9874310148472964e-16, (3832, 1) = 2.448289911548367, (3832, 2) = -0.19743745062298838e-15, (3833, 1) = 2.449196857914573, (3833, 2) = 0.9869435816061642e-16, (3834, 1) = 2.450103804280779, (3834, 2) = .0, (3835, 1) = 2.4510107506469847, (3835, 2) = -0.2959369527511101e-15, (3836, 1) = 2.451917697013191, (3836, 2) = 0.9862131081987721e-16, (3837, 1) = 2.452824643379397, (3837, 2) = .0, (3838, 1) = 2.453731589745603, (3838, 2) = 0.9857265766364859e-16, (3839, 1) = 2.4546385361118093, (3839, 2) = .0, (3840, 1) = 2.455545482478015, (3840, 2) = 0.1970480810865436e-15, (3841, 1) = 2.456452428844221, (3841, 2) = 0.9849974549091394e-16, (3842, 1) = 2.457427687547111, (3842, 2) = -0.9847363054955124e-16, (3843, 1) = 2.45840294625, (3843, 2) = 0.9844752601479256e-16, (3844, 1) = 2.4593782049528894, (3844, 2) = .0, (3845, 1) = 2.460353463655779, (3845, 2) = 0.29518604446154045e-15, (3846, 1) = 2.4613287223586684, (3846, 2) = -0.9836927482202804e-16, (3847, 1) = 2.4623039810615577, (3847, 2) = .0, (3848, 1) = 2.4632792397644474, (3848, 2) = -0.9831715934158476e-16, (3849, 1) = 2.4642544984673367, (3849, 2) = -0.9829111718730103e-16, (3850, 1) = 2.465229757170226, (3850, 2) = -0.9826508541986209e-16, (3851, 1) = 2.4662050158731157, (3851, 2) = -0.19647812807285386e-15, (3852, 1) = 2.467180274576005, (3852, 2) = -0.19642610606830005e-15, (3853, 1) = 2.4681555332788943, (3853, 2) = -0.9818705241018132e-16, (3854, 1) = 2.469130791981784, (3854, 2) = 0.29448318648499897e-15, (3855, 1) = 2.4701060506846733, (3855, 2) = 0.9813508228574598e-16, (3856, 1) = 2.4710813093875625, (3856, 2) = 0.19621822555911376e-15, (3857, 1) = 2.4720565680904523, (3857, 2) = 0.9808315364023108e-16, (3858, 1) = 2.4759576029020103, (3858, 2) = 0.9797942069404823e-16, (3859, 1) = 2.479858637713568, (3859, 2) = 0.9787585338710099e-16, (3860, 1) = 2.480833896416457, (3860, 2) = -0.19569997483952726e-15, (3861, 1) = 2.481809155119347, (3861, 2) = -0.2934723953711084e-15, (3862, 1) = 2.482784413822236, (3862, 2) = 0.19559657299200553e-15, (3863, 1) = 2.4837596725251254, (3863, 2) = -0.9777245153374347e-16, (3864, 1) = 2.484734931228015, (3864, 2) = -0.9774662690066726e-16, (3865, 1) = 2.4857101899309044, (3865, 2) = -0.19544162518769134e-15, (3866, 1) = 2.4866854486337937, (3866, 2) = -0.19539001722069187e-15, (3867, 1) = 2.4876607073366834, (3867, 2) = 0.19533842989446222e-15, (3868, 1) = 2.4886399111620605, (3868, 2) = 0.1952866546471211e-15, (3869, 1) = 2.489619114987437, (3869, 2) = -0.9761745009799379e-16, (3870, 1) = 2.490598318812814, (3870, 2) = .0, (3871, 1) = 2.491577522638191, (3871, 2) = -0.19513145365845167e-15, (3872, 1) = 2.492556726463568, (3872, 2) = -0.19507976156008236e-15, (3873, 1) = 2.4935359302889446, (3873, 2) = 0.975140451169935e-16, (3874, 1) = 2.4945151341143212, (3874, 2) = 0.9748821983708058e-16, (3875, 1) = 2.4954943379396983, (3875, 2) = 0.19492480987459226e-15, (3876, 1) = 2.4994111532412058, (3876, 2) = 0.973592490791722e-16, (3877, 1) = 2.5033279685427137, (3877, 2) = .0, (3878, 1) = 2.5043071723680903, (3878, 2) = .0, (3879, 1) = 2.5052863761934674, (3879, 2) = 0.19440965236437975e-15, (3880, 1) = 2.5062655800188445, (3880, 2) = 0.1943582505284591e-15, (3881, 1) = 2.5072447838442216, (3881, 2) = .0, (3882, 1) = 2.5082239876695986, (3882, 2) = .0, (3883, 1) = 2.5092031914949753, (3883, 2) = -0.29130625368154495e-15, (3884, 1) = 2.510182395320352, (3884, 2) = -0.9707642499912273e-16, (3885, 1) = 2.511161599145729, (3885, 2) = 0.19410155153841098e-15, (3886, 1) = 2.5150784144472365, (3886, 2) = 0.9694828210273637e-16, (3887, 1) = 2.518995229748744, (3887, 2) = .0, (3888, 1) = 2.5198861602418345, (3888, 2) = 0.19364540108802925e-15, (3889, 1) = 2.5207770907349247, (3889, 2) = -0.1935989122443477e-15, (3890, 1) = 2.521668021228015, (3890, 2) = -0.9677622022533561e-16, (3891, 1) = 2.5225589517211056, (3891, 2) = 0.19350598570230612e-15, (3892, 1) = 2.523449882214196, (3892, 2) = .0, (3893, 1) = 2.5243408127072864, (3893, 2) = 0.1934131273227103e-15, (3894, 1) = 2.5252317432003766, (3894, 2) = 0.9668336184103341e-16, (3895, 1) = 2.526122673693467, (3895, 2) = 0.9666016853395471e-16, (3896, 1) = 2.527013604186558, (3896, 2) = .0, (3897, 1) = 2.527904534679648, (3897, 2) = 0.9661380745008579e-16, (3898, 1) = 2.5287954651727382, (3898, 2) = 0.9659063966856902e-16, (3899, 1) = 2.529686395665829, (3899, 2) = 0.19313496078168438e-15, (3900, 1) = 2.5305773261589195, (3900, 2) = -0.1930886592290715e-15, (3901, 1) = 2.53146825665201, (3901, 2) = 0.965211873372777e-16, (3902, 1) = 2.5323591871451008, (3902, 2) = 0.28949416067008077e-15, (3903, 1) = 2.533250117638191, (3903, 2) = 0.9647492827040646e-16, (3904, 1) = 2.534141048131281, (3904, 2) = 0.964518114760369e-16, (3905, 1) = 2.535031978624372, (3905, 2) = -0.9642870317120306e-16, (3906, 1) = 2.5359229091174624, (3906, 2) = 0.9640560335352068e-16, (3907, 1) = 2.536813839610553, (3907, 2) = -0.9638251202060302e-16, (3908, 1) = 2.5377047701036437, (3908, 2) = 0.19271885834012191e-15, (3909, 1) = 2.538595700596734, (3909, 2) = 0.19267270959900582e-15, (3910, 1) = 2.539486631089824, (3910, 2) = .0, (3911, 1) = 2.5403775615829147, (3911, 2) = .0, (3912, 1) = 2.5412684920760054, (3912, 2) = -0.3850687301751256e-15, (3913, 1) = 2.5421594225690956, (3913, 2) = -0.9624414206919594e-16, (3914, 1) = 2.5430503530621857, (3914, 2) = .0, (3915, 1) = 2.5439412835552764, (3915, 2) = .0, (3916, 1) = 2.544832214048367, (3916, 2) = -0.1923501428875116e-15, (3917, 1) = 2.545723144541457, (3917, 2) = 0.28845619448006134e-15, (3918, 1) = 2.5466140750345474, (3918, 2) = -0.28838720000391364e-15, (3919, 1) = 2.547505005527638, (3919, 2) = -0.19221215393038565e-15, (3920, 1) = 2.5484511341363065, (3920, 2) = -0.28824501653203494e-15, (3921, 1) = 2.549397262744975, (3921, 2) = -0.19211455384010633e-15, (3922, 1) = 2.5503433913536435, (3922, 2) = -0.9603289119041629e-16, (3923, 1) = 2.5512895199623116, (3923, 2) = .0, (3924, 1) = 2.5522356485709796, (3924, 2) = -0.19196829660497664e-15, (3925, 1) = 2.553181777179648, (3925, 2) = -0.19191958227676084e-15, (3926, 1) = 2.5541279057883166, (3926, 2) = 0.19187088698058789e-15, (3927, 1) = 2.555074034396985, (3927, 2) = -0.9591110535531323e-16, (3928, 1) = 2.5560201630056536, (3928, 2) = .0, (3929, 1) = 2.5569662916143217, (3929, 2) = 0.9586245761299246e-16, (3930, 1) = 2.5579124202229897, (3930, 2) = 0.9583814799980692e-16, (3931, 1) = 2.558858548831658, (3931, 2) = 0.19162769577607235e-15, (3932, 1) = 2.5598046774403267, (3932, 2) = -0.2873686718242513e-15, (3933, 1) = 2.560750806048995, (3933, 2) = -0.1915305523140341e-15, (3934, 1) = 2.5616969346576637, (3934, 2) = -0.9574100453190057e-16, (3935, 1) = 2.5626430632663317, (3935, 2) = 0.9571674239646282e-16, (3936, 1) = 2.563589191875, (3936, 2) = -0.9569248974776271e-16, (3937, 1) = 2.5645353204836683, (3937, 2) = -0.19133649316571305e-15, (3938, 1) = 2.5654814490923368, (3938, 2) = -0.9564401289879768e-16, (3939, 1) = 2.5664275777010053, (3939, 2) = .0, (3940, 1) = 2.5673737063096738, (3940, 2) = .0, (3941, 1) = 2.568319834918342, (3941, 2) = -0.9557136870219882e-16, (3942, 1) = 2.56926596352701, (3942, 2) = -0.1910943458240185e-15, (3943, 1) = 2.5702120921356784, (3943, 2) = 0.9552298658789338e-16, (3944, 1) = 2.571158220744347, (3944, 2) = -0.19099761945377664e-15, (3945, 1) = 2.5721043493530154, (3945, 2) = 0.9547464232602853e-16, (3946, 1) = 2.573050477961684, (3946, 2) = .0, (3947, 1) = 2.573996606570352, (3947, 2) = -0.1908526717857384e-15, (3948, 1) = 2.5758888637876884, (3948, 2) = -0.9537806726463776e-16, (3949, 1) = 2.5777811210050254, (3949, 2) = .0, (3950, 1) = 2.578704450056533, (3950, 2) = -0.3812252633172485e-15, (3951, 1) = 2.5796277791080406, (3951, 2) = .0, (3952, 1) = 2.580551108159548, (3952, 2) = -0.19051860322277324e-15, (3953, 1) = 2.5814744372110554, (3953, 2) = -0.1904716159522089e-15, (3954, 1) = 2.582397766262563, (3954, 2) = -0.19042464663913256e-15, (3955, 1) = 2.58332109531407, (3955, 2) = .0, (3956, 1) = 2.5842444243655778, (3956, 2) = -0.1903307618631577e-15, (3957, 1) = 2.5851677534170854, (3957, 2) = .0, (3958, 1) = 2.5870144115201006, (3958, 2) = .0, (3959, 1) = 2.588861069623116, (3959, 2) = .0, (3960, 1) = 2.5897843986746234, (3960, 2) = 0.38009907586934954e-15, (3961, 1) = 2.590707727726131, (3961, 2) = -0.19000272998777094e-15, (3962, 1) = 2.591631056777638, (3962, 2) = -0.1899559399424451e-15, (3963, 1) = 2.5925543858291458, (3963, 2) = 0.18990916779308137e-15, (3964, 1) = 2.599941018241206, (3964, 2) = 0.1895356341774449e-15, (3965, 1) = 2.607327650653266, (3965, 2) = 0.18916324265453786e-15, (3966, 1) = 2.608328549086055, (3966, 2) = .0, (3967, 1) = 2.609329447518844, (3967, 2) = -0.18906251988541435e-15, (3968, 1) = 2.610330345951633, (3968, 2) = .0, (3969, 1) = 2.611331244384422, (3969, 2) = .0, (3970, 1) = 2.612332142817211, (3970, 2) = -0.18891159247623002e-15, (3971, 1) = 2.6133330412499998, (3971, 2) = .0, (3972, 1) = 2.6143339396827887, (3972, 2) = .0, (3973, 1) = 2.6153348381155777, (3973, 2) = 0.18876085298595087e-15, (3974, 1) = 2.6163357365483666, (3974, 2) = .0, (3975, 1) = 2.6173366349811555, (3975, 2) = .0, (3976, 1) = 2.6183375334139445, (3976, 2) = 0.18861030121785352e-15, (3977, 1) = 2.6193384318467334, (3977, 2) = 0.18856015897712856e-15, (3978, 1) = 2.6203393302795224, (3978, 2) = 0.18851003756520593e-15, (3979, 1) = 2.6213402287123113, (3979, 2) = .0, (3980, 1) = 2.6223411271451003, (3980, 2) = .0, (3981, 1) = 2.623342025577889, (3981, 2) = .0, (3982, 1) = 2.627345619309045, (3982, 2) = .0, (3983, 1) = 2.6313492130402008, (3983, 2) = .0, (3984, 1) = 2.6323501114729897, (3984, 2) = 0.18791020259923022e-15, (3985, 1) = 2.6333510099057786, (3985, 2) = .0, (3986, 1) = 2.6343519083385676, (3986, 2) = .0, (3987, 1) = 2.6353528067713565, (3987, 2) = 0.18776071085299943e-15, (3988, 1) = 2.6363537052041455, (3988, 2) = 0.37542184340582138e-15, (3989, 1) = 2.6373546036369344, (3989, 2) = -0.18766115325648267e-15, (3990, 1) = 2.6383555020697234, (3990, 2) = .0, (3991, 1) = 2.6393564005025123, (3991, 2) = -0.18756167844497367e-15, (3992, 1) = 2.6402224559265073, (3992, 2) = -0.3750373348026512e-15, (3993, 1) = 2.6410885113505023, (3993, 2) = -0.37495134367435264e-15, (3994, 1) = 2.6419545667744972, (3994, 2) = .0, (3995, 1) = 2.6428206221984922, (3995, 2) = .0, (3996, 1) = 2.643686677622487, (3996, 2) = .0, (3997, 1) = 2.644552733046482, (3997, 2) = .0, (3998, 1) = 2.645418788470477, (3998, 2) = 0.18726092604042684e-15, (3999, 1) = 2.646284843894472, (3999, 2) = 0.1872180232521413e-15, (4000, 1) = 2.647150899318467, (4000, 2) = .0, (4001, 1) = 2.648016954742462, (4001, 2) = .0, (4002, 1) = 2.648883010166457, (4002, 2) = -0.3741788150850886e-15, (4003, 1) = 2.649749065590452, (4003, 2) = .0, (4004, 1) = 2.650615121014447, (4004, 2) = 0.18700374090052853e-15, (4005, 1) = 2.651481176438442, (4005, 2) = .0, (4006, 1) = 2.6523472318624366, (4006, 2) = .0, (4007, 1) = 2.6532132872864316, (4007, 2) = 0.18687535658729083e-15, (4008, 1) = 2.6540793427104266, (4008, 2) = 0.1868325926367734e-15, (4009, 1) = 2.654945398134421, (4009, 2) = 0.18678984408845392e-15, (4010, 1) = 2.655811453558416, (4010, 2) = .0, (4011, 1) = 2.656677508982411, (4011, 2) = -0.18670439317899112e-15, (4012, 1) = 2.657543564406406, (4012, 2) = 0.18666169080813283e-15, (4013, 1) = 2.658409619830401, (4013, 2) = -0.18661900382004222e-15, (4014, 1) = 2.659275675254396, (4014, 2) = .0, (4015, 1) = 2.660141730678391, (4015, 2) = .0, (4016, 1) = 2.661007786102386, (4016, 2) = -0.18649103510372526e-15, (4017, 1) = 2.661873841526381, (4017, 2) = 0.37289681919608293e-15, (4018, 1) = 2.662739896950376, (4018, 2) = -0.3728115989015615e-15, (4019, 1) = 2.663605952374371, (4019, 2) = 0.37272640931413366e-15, (4020, 1) = 2.664472007798366, (4020, 2) = -0.1863206252120207e-15, (4021, 1) = 2.665338063222361, (4021, 2) = 0.18627806111076112e-15, (4022, 1) = 2.666204118646356, (4022, 2) = -0.18623551234840422e-15, (4023, 1) = 2.667070174070351, (4023, 2) = 0.1861929789200639e-15, (4024, 1) = 2.682985312311557, (4024, 2) = 0.18541408400828309e-15, (4025, 1) = 2.698900450552763, (4025, 2) = 0.1846403352237645e-15, (4026, 1) = 2.7138615171859293, (4026, 2) = 0.18391763585807612e-15, (4027, 1) = 2.7288225838190954, (4027, 2) = 0.18319943124837754e-15, (4028, 1) = 2.732526723580402, (4028, 2) = 0.1830223055514468e-15, (4029, 1) = 2.7362308633417083, (4029, 2) = 0.18284545339606363e-15, (4030, 1) = 2.737156898282035, (4030, 2) = .0, (4031, 1) = 2.7380829332223615, (4031, 2) = 0.18275712977308415e-15, (4032, 1) = 2.739008968162688, (4032, 2) = -0.18271299355366235e-15, (4033, 1) = 2.7399350031030147, (4033, 2) = .0, (4034, 1) = 2.7408610380433416, (4034, 2) = 0.18262477226805964e-15, (4035, 1) = 2.7417870729836684, (4035, 2) = .0, (4036, 1) = 2.7427131079239953, (4036, 2) = .0, (4037, 1) = 2.7436391428643216, (4037, 2) = -0.18249256813000958e-15, (4038, 1) = 2.744565177804648, (4038, 2) = -0.18244853413667359e-15, (4039, 1) = 2.745491212744975, (4039, 2) = .0, (4040, 1) = 2.7464172476853017, (4040, 2) = 0.36472103438375473e-15, (4041, 1) = 2.7473432826256285, (4041, 2) = -0.3646330684560569e-15, (4042, 1) = 2.7482693175659554, (4042, 2) = 0.36454513652323313e-15, (4043, 1) = 2.7491953525062818, (4043, 2) = 0.18222861928644236e-15, (4044, 1) = 2.750121387446608, (4044, 2) = 0.18218468729630458e-15, (4045, 1) = 2.751047422386935, (4045, 2) = 0.182140772285e-15, (4046, 1) = 2.751973457327262, (4046, 2) = .0, (4047, 1) = 2.7528994922675882, (4047, 2) = 0.36410598634813562e-15, (4048, 1) = 2.7538255272079146, (4048, 2) = 0.18200912906202415e-15, (4049, 1) = 2.7547515621482415, (4049, 2) = -0.18196528190398155e-15, (4050, 1) = 2.7556775970885683, (4050, 2) = .0, (4051, 1) = 2.7566036320288947, (4051, 2) = -0.18187763842504664e-15, (4052, 1) = 2.757529666969221, (4052, 2) = .0, (4053, 1) = 2.758455701909548, (4053, 2) = 0.3635801253750768e-15, (4054, 1) = 2.7593824735175883, (4054, 2) = 0.18174626539962624e-15, (4055, 1) = 2.7603092451256286, (4055, 2) = 0.18170248505533114e-15, (4056, 1) = 2.761236016733669, (4056, 2) = .0, (4057, 1) = 2.762162788341709, (4057, 2) = .0, (4058, 1) = 2.7630895599497487, (4058, 2) = 0.18157124562175187e-15, (4059, 1) = 2.764016331557789, (4059, 2) = 0.36305506597903947e-15, (4060, 1) = 2.7649431031658294, (4060, 2) = .0, (4061, 1) = 2.7658698747738697, (4061, 2) = .0, (4062, 1) = 2.76679664638191, (4062, 2) = -0.36279299308452855e-15, (4063, 1) = 2.76772341798995, (4063, 2) = -0.18135285152216156e-15, (4064, 1) = 2.76865018959799, (4064, 2) = -0.18130922338946347e-15, (4065, 1) = 2.76957696120603, (4065, 2) = -0.1812656121379154e-15, (4066, 1) = 2.7705037328140705, (4066, 2) = .0, (4067, 1) = 2.771430504422111, (4067, 2) = -0.1811784402532427e-15, (4068, 1) = 2.772357276030151, (4068, 2) = .0, (4069, 1) = 2.773284047638191, (4069, 2) = 0.18109133581807344e-15, (4070, 1) = 2.774210819246231, (4070, 2) = -0.18104780887839833e-15, (4071, 1) = 2.7751375908542713, (4071, 2) = -0.1810042987823107e-15, (4072, 1) = 2.7760643624623116, (4072, 2) = 0.18096080552354437e-15, (4073, 1) = 2.776991134070352, (4073, 2) = -0.18091732909583142e-15, (4074, 1) = 2.7779179056783923, (4074, 2) = 0.1808738694929026e-15, (4075, 1) = 2.778844677286432, (4075, 2) = -0.18083042670848674e-15, (4076, 1) = 2.779771448894472, (4076, 2) = -0.18078700073631125e-15, (4077, 1) = 2.7806982205025124, (4077, 2) = .0, (4078, 1) = 2.7816249921105527, (4078, 2) = .0, (4079, 1) = 2.782551763718593, (4079, 2) = .0, (4080, 1) = 2.7834785353266334, (4080, 2) = .0, (4081, 1) = 2.7844053069346733, (4081, 2) = -0.18057012283938876e-15, (4082, 1) = 2.785332078542713, (4082, 2) = .0, (4083, 1) = 2.7862588501507535, (4083, 2) = .0, (4084, 1) = 2.787185621758794, (4084, 2) = 0.3608803948926682e-15, (4085, 1) = 2.788112393366834, (4085, 2) = .0, (4086, 1) = 2.7890576417430903, (4086, 2) = -0.180352802051252e-15, (4087, 1) = 2.7900028901193465, (4087, 2) = .0, (4088, 1) = 2.7909481384956027, (4088, 2) = -0.1802646133952961e-15, (4089, 1) = 2.791893386871859, (4089, 2) = -0.3604410903530725e-15, (4090, 1) = 2.792838635248115, (4090, 2) = -0.36035298871003757e-15, (4091, 1) = 2.7937838836243714, (4091, 2) = -0.18013246092406445e-15, (4092, 1) = 2.7947291320006276, (4092, 2) = .0, (4093, 1) = 2.795674380376884, (4093, 2) = 0.18004444620712068e-15, (4094, 1) = 2.796619628753141, (4094, 2) = .0, (4095, 1) = 2.797564877129397, (4095, 2) = .0, (4096, 1) = 2.7985101255056533, (4096, 2) = .0, (4097, 1) = 2.7994553738819095, (4097, 2) = -0.17986862516593803e-15, (4098, 1) = 2.8004006222581657, (4098, 2) = .0, (4099, 1) = 2.801345870634422, (4099, 2) = .0, (4100, 1) = 2.802291119010678, (4100, 2) = .0, (4101, 1) = 2.8032363673869343, (4101, 2) = .0, (4102, 1) = 2.8051268641394467, (4102, 2) = .0, (4103, 1) = 2.807017360891959, (4103, 2) = .0, (4104, 1) = 2.8079626092682153, (4104, 2) = .0, (4105, 1) = 2.8089078576444715, (4105, 2) = .0, (4106, 1) = 2.8098531060207277, (4106, 2) = .0, (4107, 1) = 2.8107983543969843, (4107, 2) = 0.17934282533002958e-15, (4108, 1) = 2.811743602773241, (4108, 2) = 0.35859824209755124e-15, (4109, 1) = 2.812688851149497, (4109, 2) = 0.17925543402419754e-15, (4110, 1) = 2.8136340995257534, (4110, 2) = .0, (4111, 1) = 2.8145793479020096, (4111, 2) = -0.3583362234364664e-15, (4112, 1) = 2.815524596278266, (4112, 2) = 0.35824895284685213e-15, (4113, 1) = 2.816469844654522, (4113, 2) = 0.3581617167169055e-15, (4114, 1) = 2.817415093030778, (4114, 2) = -0.17903725751659975e-15, (4115, 1) = 2.8183603414070344, (4115, 2) = 0.1789936738911522e-15, (4116, 1) = 2.8193622888505017, (4116, 2) = -0.1789474947672592e-15, (4117, 1) = 2.820364236293969, (4117, 2) = 0.17890133497156205e-15, (4118, 1) = 2.821366183737436, (4118, 2) = 0.35771038899211835e-15, (4119, 1) = 2.822368131180904, (4119, 2) = .0, (4120, 1) = 2.824372026067839, (4120, 2) = .0, (4121, 1) = 2.8263759209547734, (4121, 2) = .0, (4122, 1) = 2.8273778683982407, (4122, 2) = -0.17857875691885318e-15, (4123, 1) = 2.828379815841708, (4123, 2) = .0, (4124, 1) = 2.829381763285175, (4124, 2) = .0, (4125, 1) = 2.8303837107286425, (4125, 2) = -0.1784407983043064e-15, (4126, 1) = 2.8313856581721097, (4126, 2) = -0.17839485059034481e-15, (4127, 1) = 2.832387605615577, (4127, 2) = 0.17834892210846632e-15, (4128, 1) = 2.8333895530590443, (4128, 2) = .0, (4129, 1) = 2.834391500502512, (4129, 2) = 0.1782571228088839e-15, (4130, 1) = 2.8353934479459797, (4130, 2) = 0.17821125197513945e-15, (4131, 1) = 2.836395395389447, (4131, 2) = .0, (4132, 1) = 2.8373973428329142, (4132, 2) = .0, (4133, 1) = 2.8383992902763815, (4133, 2) = .0, (4134, 1) = 2.8394012377198488, (4134, 2) = .0, (4135, 1) = 2.840403185163316, (4135, 2) = 0.17798218564595916e-15, (4136, 1) = 2.8414051326067833, (4136, 2) = .0, (4137, 1) = 2.8424070800502506, (4137, 2) = .0, (4138, 1) = 2.84641486982412, (4138, 2) = .0, (4139, 1) = 2.8504226595979896, (4139, 2) = .0, (4140, 1) = 2.857772161130653, (4140, 2) = .0, (4141, 1) = 2.8651216626633165, (4141, 2) = .0, (4142, 1) = 2.8660403503548997, (4142, 2) = 0.17681742239209285e-15, (4143, 1) = 2.8669590380464824, (4143, 2) = .0, (4144, 1) = 2.867877725738065, (4144, 2) = .0, (4145, 1) = 2.8687964134296484, (4145, 2) = -0.17669294838105775e-15, (4146, 1) = 2.869715101121231, (4146, 2) = .0, (4147, 1) = 2.870633788812814, (4147, 2) = .0, (4148, 1) = 2.871552476504397, (4148, 2) = -0.17656861761623587e-15, (4149, 1) = 2.87247116419598, (4149, 2) = -0.17652720583146772e-15, (4150, 1) = 2.8733898518875627, (4150, 2) = -0.352971619876197e-15, (4151, 1) = 2.874308539579146, (4151, 2) = -0.17644442992991494e-15, (4152, 1) = 2.8752272272707287, (4152, 2) = .0, (4153, 1) = 2.8761459149623114, (4153, 2) = -0.35272343508849966e-15, (4154, 1) = 2.8770646026538946, (4154, 2) = .0, (4155, 1) = 2.8779832903454774, (4155, 2) = 0.17627906862475654e-15, (4156, 1) = 2.87890197803706, (4156, 2) = .0, (4157, 1) = 2.8798206657286434, (4157, 2) = 0.1761964831217115e-15, (4158, 1) = 2.8807275284453517, (4158, 2) = -0.35231149046565515e-15, (4159, 1) = 2.8816343911620605, (4159, 2) = 0.1761150227744522e-15, (4160, 1) = 2.8825412538787694, (4160, 2) = .0, (4161, 1) = 2.8834481165954777, (4161, 2) = -0.17603362412530448e-15, (4162, 1) = 2.884354979312186, (4162, 2) = .0, (4163, 1) = 2.8852618420288945, (4163, 2) = .0, (4164, 1) = 2.886168704745603, (4164, 2) = .0, (4165, 1) = 2.8870755674623116, (4165, 2) = .0, (4166, 1) = 2.8879824301790205, (4166, 2) = 0.17583039711764693e-15, (4167, 1) = 2.888889292895729, (4167, 2) = .0, (4168, 1) = 2.889796155612437, (4168, 2) = 0.17574921403503496e-15, (4169, 1) = 2.8907030183291456, (4169, 2) = 0.17570864555274877e-15, (4170, 1) = 2.891609881045854, (4170, 2) = 0.17566809243516342e-15, (4171, 1) = 2.8925167437625627, (4171, 2) = .0, (4172, 1) = 2.8934236064792715, (4172, 2) = .0, (4173, 1) = 2.89433046919598, (4173, 2) = .0, (4174, 1) = 2.8952373319126883, (4174, 2) = .0, (4175, 1) = 2.896144194629397, (4175, 2) = -0.1754655571082707e-15, (4176, 1) = 2.897051057346106, (4176, 2) = .0, (4177, 1) = 2.8979579200628143, (4177, 2) = 0.1753846503209281e-15, (4178, 1) = 2.8988647827795226, (4178, 2) = .0, (4179, 1) = 2.899771645496231, (4179, 2) = .0, (4180, 1) = 2.9006785082129394, (4180, 2) = 0.17526340500104947e-15, (4181, 1) = 2.901585370929648, (4181, 2) = 0.1752230205001096e-15, (4182, 1) = 2.902492233646357, (4182, 2) = .0, (4183, 1) = 2.9033990963630654, (4183, 2) = .0, (4184, 1) = 2.9043059590797737, (4184, 2) = -0.17510195873051703e-15, (4185, 1) = 2.905212821796482, (4185, 2) = -0.1750616353651001e-15, (4186, 1) = 2.9061196845131905, (4186, 2) = .0, (4187, 1) = 2.9070265472298993, (4187, 2) = -0.17498103443500342e-15, (4188, 1) = 2.907933409946608, (4188, 2) = 0.17494075685834503e-15, (4189, 1) = 2.9088402726633165, (4189, 2) = 0.1749004945326272e-15, (4190, 1) = 2.909809693982412, (4190, 2) = -0.17485747162761633e-15, (4191, 1) = 2.9107791153015077, (4191, 2) = .0, (4192, 1) = 2.9117485366206033, (4192, 2) = .0, (4193, 1) = 2.9127179579396985, (4193, 2) = 0.17472850736420283e-15, (4194, 1) = 2.9136873792587936, (4194, 2) = .0, (4195, 1) = 2.9146568005778892, (4195, 2) = .0, (4196, 1) = 2.915626221896985, (4196, 2) = 0.17459969962454513e-15, (4197, 1) = 2.9165956432160804, (4197, 2) = -0.17455679846023123e-15, (4198, 1) = 2.917565064535176, (4198, 2) = -0.1745139146581724e-15, (4199, 1) = 2.918534485854271, (4199, 2) = 0.17447104821104975e-15, (4200, 1) = 2.9195039071733664, (4200, 2) = -0.1744281991115443e-15, (4201, 1) = 2.920473328492462, (4201, 2) = 0.1743853673523369e-15, (4202, 1) = 2.9214427498115576, (4202, 2) = .0, (4203, 1) = 2.922412171130653, (4203, 2) = .0, (4204, 1) = 2.923381592449749, (4204, 2) = .0, (4205, 1) = 2.924351013768844, (4205, 2) = .0, (4206, 1) = 2.9262898564070348, (4206, 2) = .0, (4207, 1) = 2.928228699045226, (4207, 2) = .0, (4208, 1) = 2.9291981203643216, (4208, 2) = .0, (4209, 1) = 2.9301675416834168, (4209, 2) = .0, (4210, 1) = 2.931136963002512, (4210, 2) = .0, (4211, 1) = 2.9321063843216075, (4211, 2) = -0.17387273612075552e-15, (4212, 1) = 2.933075805640703, (4212, 2) = .0, (4213, 1) = 2.9340452269597987, (4213, 2) = 0.17378753935571828e-15, (4214, 1) = 2.9350146482788944, (4214, 2) = .0, (4215, 1) = 2.9359840695979895, (4215, 2) = -0.17370241151267663e-15, (4216, 1) = 2.9369534909170847, (4216, 2) = -0.17365987341860345e-15, (4217, 1) = 2.9379229122361803, (4217, 2) = .0, (4218, 1) = 2.938892333555276, (4218, 2) = 0.17357484884875093e-15, (4219, 1) = 2.9398617548743715, (4219, 2) = 0.1735323623583312e-15, (4220, 1) = 2.9408290658479896, (4220, 2) = .0, (4221, 1) = 2.9417963768216078, (4221, 2) = .0, (4222, 1) = 2.942763687795226, (4222, 2) = 0.1734052830531144e-15, (4223, 1) = 2.943730998768844, (4223, 2) = .0, (4224, 1) = 2.944698309742462, (4224, 2) = .0, (4225, 1) = 2.9456656207160803, (4225, 2) = 0.17327835755802982e-15, (4226, 1) = 2.946632931689698, (4226, 2) = .0, (4227, 1) = 2.947600242663316, (4227, 2) = -0.17319382591441912e-15, (4228, 1) = 2.9485675536369342, (4228, 2) = -0.1731515856767319e-15, (4229, 1) = 2.949534864610552, (4229, 2) = 0.173109362485428e-15, (4230, 1) = 2.95050217558417, (4230, 2) = -0.17306715633323588e-15, (4231, 1) = 2.951469486557788, (4231, 2) = .0, (4232, 1) = 2.9524367975314063, (4232, 2) = 0.17298279511710196e-15, (4233, 1) = 2.9534041085050244, (4233, 2) = .0, (4234, 1) = 2.9543714194786426, (4234, 2) = 0.1728985019701616e-15, (4235, 1) = 2.9553387304522607, (4235, 2) = -0.17285638090446213e-15, (4236, 1) = 2.956306041425879, (4236, 2) = -0.1728142768342491e-15, (4237, 1) = 2.957273352399497, (4237, 2) = .0, (4238, 1) = 2.958240663373115, (4238, 2) = -0.17273011965120173e-15, (4239, 1) = 2.959207974346733, (4239, 2) = -0.17268806652382753e-15, (4240, 1) = 2.9601752853203513, (4240, 2) = 0.17264603036286022e-15, (4241, 1) = 2.9611425962939695, (4241, 2) = .0, (4242, 1) = 2.962109907267587, (4242, 2) = .0, (4243, 1) = 2.9630772182412053, (4243, 2) = .0, (4244, 1) = 2.965011840188441, (4244, 2) = .0, (4245, 1) = 2.9669464621356774, (4245, 2) = .0, (4246, 1) = 2.9679137731092955, (4246, 2) = .0, (4247, 1) = 2.9688810840829136, (4247, 2) = .0, (4248, 1) = 2.9698483950565318, (4248, 2) = 0.17222660030643525e-15, (4249, 1) = 2.97081570603015, (4249, 2) = -0.17218475029622467e-15, (4250, 1) = 2.9717277152167076, (4250, 2) = .0, (4251, 1) = 2.9726397244032654, (4251, 2) = .0, (4252, 1) = 2.973551733589823, (4252, 2) = .0, (4253, 1) = 2.974463742776381, (4253, 2) = .0, (4254, 1) = 2.9753757519629387, (4254, 2) = .0, (4255, 1) = 2.9762877611494964, (4255, 2) = .0, (4256, 1) = 2.977199770336054, (4256, 2) = 0.17190897133445217e-15, (4257, 1) = 2.9781117795226124, (4257, 2) = 0.17186963423562996e-15, (4258, 1) = 2.981759816268844, (4258, 2) = 0.17171243533612443e-15, (4259, 1) = 2.985407853015075, (4259, 2) = 0.1715554753377235e-15, (4260, 1) = 2.9863198622016327, (4260, 2) = .0, (4261, 1) = 2.9872318713881905, (4261, 2) = -0.17147708480472767e-15, (4262, 1) = 2.9881438805747482, (4262, 2) = 0.17143791188348517e-15, (4263, 1) = 2.989055889761306, (4263, 2) = .0, (4264, 1) = 2.9899678989478637, (4264, 2) = .0, (4265, 1) = 2.9908799081344215, (4265, 2) = .0, (4266, 1) = 2.9917919173209793, (4266, 2) = -0.17128136902493735e-15, (4267, 1) = 2.9927039265075375, (4267, 2) = -0.17124227048649253e-15, (4268, 1) = 2.9936159356940957, (4268, 2) = .0, (4269, 1) = 2.9945279448806534, (4269, 2) = 0.1711641179784604e-15, (4270, 1) = 2.995439954067211, (4270, 2) = -0.17112506399671105e-15, (4271, 1) = 2.996351963253769, (4271, 2) = -0.17108602485503213e-15, (4272, 1) = 2.9972639724403267, (4272, 2) = 0.17104700054734363e-15, (4273, 1) = 2.9981759816268845, (4273, 2) = 0.17100799106756611e-15, (4274, 1) = 2.9990879908134422, (4274, 2) = .0, (4275, 1) = 3.0, (4275, 2) = .0}, datatype = float[8]), COLOUR(RGB, .47058824, 0., 0.54901961e-1, _ATTRIBUTE("source" = "mathdefault"))), AXESLABELS(x, ""), VIEW(-3. .. 3., DEFAULT, _ATTRIBUTE("source" = "mathdefault")), _ATTRIBUTE("input" = [TABLE([1 = plot, 2 = [(1/3)*(-6-2*x^2+(12+5*x^2-4*x*(x^2+3)^(1/2))^(1/2)*(x^2+3)^(1/2)+x*(x^2+3)^(1/2))/(x^2+3)^(1/2)], 3 = (x = -3 .. 3)]), "originalview" = [-3. .. 3., -0.702562299607569015e-15 .. 0.705095266891650214e-15], "originalaxesticks" = AXESTICKS(DEFAULT, DEFAULT, _ATTRIBUTE("source" = "mathdefault"))])), INTERFACE_PLOT(CURVES(Matrix(200, 2, {(1, 1) = -3.0, (1, 2) = 2.618802153517006, (2, 1) = -2.9684543698492463, (2, 2) = 2.6034550758917687, (3, 1) = -2.9410066857286434, (3, 2) = 2.590181362962417, (4, 1) = -2.910138894271357, (4, 2) = 2.575344310737094, (5, 1) = -2.8790664910552763, (5, 2) = 2.560508024329546, (6, 1) = -2.848141769547739, (6, 2) = 2.545843347529254, (7, 1) = -2.819470594070352, (7, 2) = 2.532339525525828, (8, 1) = -2.789783252562814, (8, 2) = 2.518452765450757, (9, 1) = -2.7590805615075378, (9, 2) = 2.5041958210804007, (10, 1) = -2.728476334371859, (10, 2) = 2.4900931430863973, (11, 1) = -2.6969961250251258, (11, 2) = 2.4757026400512974, (12, 1) = -2.6692683394974877, (12, 2) = 2.4631270922987567, (13, 1) = -2.6380534203015076, (13, 2) = 2.449084332125028, (14, 1) = -2.6067103296482412, (14, 2) = 2.435108692807071, (15, 1) = -2.5765054540703516, (15, 2) = 2.4217618332961304, (16, 1) = -2.549076533366834, (16, 2) = 2.4097471932125414, (17, 1) = -2.516460893668342, (17, 2) = 2.395594630396337, (18, 1) = -2.488831168643216, (18, 2) = 2.383722172327674, (19, 1) = -2.456691230050251, (19, 2) = 2.3700496670113598, (20, 1) = -2.4282419384924623, (20, 2) = 2.3580739981355596, (21, 1) = -2.3970285566834173, (21, 2) = 2.3450752692086643, (22, 1) = -2.367306035879397, (22, 2) = 2.3328374099950797, (23, 1) = -2.3362937035175877, (23, 2) = 2.3202178090411376, (24, 1) = -2.307814701407035, (24, 2) = 2.3087667359350257, (25, 1) = -2.2770962502512564, (25, 2) = 2.296566692349589, (26, 1) = -2.2451884127638193, (26, 2) = 2.28406500769504, (27, 1) = -2.217412546432161, (27, 2) = 2.2733275068829815, (28, 1) = -2.1874138498492464, (28, 2) = 2.261886426430375, (29, 1) = -2.156422260904523, (29, 2) = 2.2502407765573778, (30, 1) = -2.126103037386935, (30, 2) = 2.2390234610349937, (31, 1) = -2.0967676296482414, (31, 2) = 2.228339806259257, (32, 1) = -2.064195660904523, (32, 2) = 2.216678111428435, (33, 1) = -2.034928298291457, (33, 2) = 2.2063844067912797, (34, 1) = -2.0036791417085427, (34, 2) = 2.1955920067901236, (35, 1) = -1.9753627613065328, (35, 2) = 2.1859939179137977, (36, 1) = -1.9444054781909548, (36, 2) = 2.175703225298527, (37, 1) = -1.9152770873366836, (37, 2) = 2.1662186393631018, (38, 1) = -1.8848295259296484, (38, 2) = 2.1565152906060243, (39, 1) = -1.8550614693467338, (39, 2) = 2.1472421971205087, (40, 1) = -1.8238970728643218, (40, 2) = 2.1377665525179372, (41, 1) = -1.793882055075377, (41, 2) = 2.1288711086925667, (42, 1) = -1.7631873642211056, (42, 2) = 2.1200146603868495, (43, 1) = -1.7327468409045226, (43, 2) = 2.111478055543716, (44, 1) = -1.7047751614070352, (44, 2) = 2.103855865739976, (45, 1) = -1.6727164601005025, (45, 2) = 2.09538845788584, (46, 1) = -1.644042775477387, (46, 2) = 2.0880643481039733, (47, 1) = -1.6134706471356783, (47, 2) = 2.0805214734302417, (48, 1) = -1.584209219396985, (48, 2) = 2.073565895480531, (49, 1) = -1.5517181644221105, (49, 2) = 2.066153205692597, (50, 1) = -1.523583298190955, (50, 2) = 2.0600053043871487, (51, 1) = -1.4916499733668342, (51, 2) = 2.0533402668685277, (52, 1) = -1.4625462144723618, (52, 2) = 2.0475630519855956, (53, 1) = -1.430711276080402, (53, 2) = 2.041577007883342, (54, 1) = -1.4032431081407037, (54, 2) = 2.0366990612312046, (55, 1) = -1.371960071155779, (55, 2) = 2.0314758699762687, (56, 1) = -1.3417422018090452, (56, 2) = 2.0267749793640206, (57, 1) = -1.3115440730653267, (57, 2) = 2.0224241192898096, (58, 1) = -1.2814570377889447, (58, 2) = 2.018443010161291, (59, 1) = -1.2525528159798995, (59, 2) = 2.0149592710003934, (60, 1) = -1.2213065867336683, (60, 2) = 2.011578419968024, (61, 1) = -1.1915266646231155, (61, 2) = 2.0087379140907733, (62, 1) = -1.1601846988944724, (62, 2) = 2.0061609451697384, (63, 1) = -1.1318126725628141, (63, 2) = 2.0042018697946085, (64, 1) = -1.1004562721608042, (64, 2) = 2.0024599516310926, (65, 1) = -1.0704223046231156, (65, 2) = 2.0012181016584103, (66, 1) = -1.0404614406030153, (66, 2) = 2.0004051529975033, (67, 1) = -1.0091672020100502, (67, 2) = 2.000020961276726, (68, 1) = -.9803440658291458, (68, 2) = 2.000097064142108, (69, 1) = -.950825231758794, (69, 2) = 2.0006119928845933, (70, 1) = -.9182329314572866, (70, 2) = 2.0017057871067765, (71, 1) = -.8887232731658292, (71, 2) = 2.003182256488408, (72, 1) = -.8585441201005026, (72, 2) = 2.0051806163792336, (73, 1) = -.8278526987939698, (73, 2) = 2.0077301503538707, (74, 1) = -.7996413102512561, (74, 2) = 2.0105431625197916, (75, 1) = -.7695688836180903, (75, 2) = 2.0140468355507135, (76, 1) = -.7397253702512563, (76, 2) = 2.018049067665526, (77, 1) = -.707802087437186, (77, 2) = 2.0229207486171226, (78, 1) = -.679631173266332, (78, 2) = 2.0277362608405256, (79, 1) = -.6471277863316587, (79, 2) = 2.033905208171417, (80, 1) = -.6177959855276383, (80, 2) = 2.0400456979376016, (81, 1) = -.5887737018090453, (81, 2) = 2.0466660186095775, (82, 1) = -.557565423316583, (82, 2) = 2.054399251371265, (83, 1) = -.5262309009045225, (83, 2) = 2.062814356999972, (84, 1) = -.4977211251256284, (84, 2) = 2.0710458120302153, (85, 1) = -.467445009648241, (85, 2) = 2.080395573901162, (86, 1) = -.43789847999999987, (86, 2) = 2.0901321734962743, (87, 1) = -.4058697301507541, (87, 2) = 2.101378672267316, (88, 1) = -.3781559565829147, (88, 2) = 2.1116978358271643, (89, 1) = -.3463256801005028, (89, 2) = 2.1242303559862217, (90, 1) = -.31640354683417105, (90, 2) = 2.1366819898761236, (91, 1) = -.28677042874371894, (91, 2) = 2.1496599351368615, (92, 1) = -.2571137372864323, (92, 2) = 2.163298046445263, (93, 1) = -.22686578924623113, (93, 2) = 2.1778830484824354, (94, 1) = -.19480347105527684, (94, 2) = 2.194092538325835, (95, 1) = -.16540546492462305, (95, 2) = 2.2096373387205572, (96, 1) = -.13638585798994995, (96, 2) = 2.2256256753153867, (97, 1) = -.1053643757788949, (97, 2) = 2.243427241456501, (98, 1) = -0.7441042462311565e-1, (98, 2) = 2.2619243027301903, (99, 1) = -0.466274152763817e-1, (99, 2) = 2.2791527992671883, (100, 1) = -0.13716437185929742e-1, (100, 2) = 2.3003291995354886, (101, 1) = 0.13821943115577717e-1, (101, 2) = 2.3186892380141626, (102, 1) = 0.4603117206030127e-1, (102, 2) = 2.3409039338272386, (103, 1) = 0.7677176080402015e-1, (103, 2) = 2.3628497019174124, (104, 1) = .10421944492462298, (104, 2) = 2.383057596918908, (105, 1) = .13508723638190956, (105, 2) = 2.406472459979865, (106, 1) = .16615963959798963, (106, 2) = 2.4307765512356734, (107, 1) = .19708436110552752, (107, 2) = 2.4556929565983054, (108, 1) = .22575553658291447, (108, 2) = 2.479438807673681, (109, 1) = .2554428780904523, (109, 2) = 2.504676374505919, (110, 1) = .2861455691457282, (110, 2) = 2.531467989207787, (111, 1) = .31674979628140676, (111, 2) = 2.5588672247983357, (112, 1) = .34823000562814066, (112, 2) = 2.587766637483634, (113, 1) = .37595779115577876, (113, 2) = 2.6138168996886026, (114, 1) = .40717271035175884, (114, 2) = 2.6438039335574617, (115, 1) = .4385158010050252, (115, 2) = 2.674610242117389, (116, 1) = .4687206765829144, (116, 2) = 2.7049497742651196, (117, 1) = .4961495972864318, (117, 2) = 2.7330484328451297, (118, 1) = .5287652369849245, (118, 2) = 2.7671295854107036, (119, 1) = .5563949620100499, (119, 2) = 2.7965617517116854, (120, 1) = .5885349006030149, (120, 2) = 2.8314359637785733, (121, 1) = .6169841921608037, (121, 2) = 2.8628690617930492, (122, 1) = .6481975739698491, (122, 2) = 2.897955029430453, (123, 1) = .677920094773869, (123, 2) = 2.93193800399096, (124, 1) = .7089324271356783, (124, 2) = 2.9679809326740423, (125, 1) = .7374114292462313, (125, 2) = 3.001596770773898, (126, 1) = .76812988040201, (126, 2) = 3.038400902970377, (127, 1) = .8000377178894471, (127, 2) = 3.077217436963366, (128, 1) = .8278135842211056, (128, 2) = 3.1114851826847643, (129, 1) = .8578122808040196, (129, 2) = 3.148985004267594, (130, 1) = .888803869748743, (130, 2) = 3.188249411782034, (131, 1) = .9191230932663319, (131, 2) = 3.227165939645544, (132, 1) = .948458501005025, (132, 2) = 3.265284049533865, (133, 1) = .9810304697487435, (133, 2) = 3.3081310142232376, (134, 1) = 1.0102978323618084, (134, 2) = 3.3470902196124115, (135, 1) = 1.0415469889447229, (135, 2) = 3.389156386620323, (136, 1) = 1.0698633693467334, (136, 2) = 3.427683503758898, (137, 1) = 1.1008206524623114, (137, 2) = 3.4702384716157253, (138, 1) = 1.129949043316583, (138, 2) = 3.5106845456345934, (139, 1) = 1.1603966047236183, (139, 2) = 3.553372397295079, (140, 1) = 1.1901646613065324, (140, 2) = 3.5955032769361948, (141, 1) = 1.221329057788945, (141, 2) = 3.6400194488953788, (142, 1) = 1.2513440755778893, (142, 2) = 3.683279750414722, (143, 1) = 1.2820387664321604, (143, 2) = 3.7279016029740153, (144, 1) = 1.3124792897487438, (144, 2) = 3.7725259575619376, (145, 1) = 1.3404509692462305, (145, 2) = 3.8138497404616314, (146, 1) = 1.3725096705527635, (146, 2) = 3.861577424594867, (147, 1) = 1.4011833551758794, (147, 2) = 3.904588655774397, (148, 1) = 1.4317554835175876, (148, 2) = 3.9507750466152984, (149, 1) = 1.4610169112562819, (149, 2) = 3.9952900071216986, (150, 1) = 1.4935079662311557, (150, 2) = 4.045062749485724, (151, 1) = 1.5216428324623115, (151, 2) = 4.088447830439323, (152, 1) = 1.5535761572864324, (152, 2) = 4.138003011832534, (153, 1) = 1.5826799161809042, (153, 2) = 4.183449485466524, (154, 1) = 1.6145148545728638, (154, 2) = 4.233460969909385, (155, 1) = 1.6419830225125631, (155, 2) = 4.276858148281676, (156, 1) = 1.6732660594974869, (156, 2) = 4.3265525741832045, (157, 1) = 1.7034839288442214, (157, 2) = 4.374821138795024, (158, 1) = 1.7336820575879397, (158, 2) = 4.42331268131251, (159, 1) = 1.7637690928643206, (159, 2) = 4.471872332825193, (160, 1) = 1.792673314673367, (160, 2) = 4.518748792876914, (161, 1) = 1.8239195439195983, (161, 2) = 4.5696660229814015, (162, 1) = 1.8536994660301502, (162, 2) = 4.618422350438029, (163, 1) = 1.8850414317587942, (163, 2) = 4.669970641386326, (164, 1) = 1.913413458090452, (164, 2) = 4.716836417571029, (165, 1) = 1.944769858492462, (165, 2) = 4.7688495776710385, (166, 1) = 1.9748038260301506, (166, 2) = 4.8188779959480135, (167, 1) = 2.0047646900502514, (167, 2) = 4.868983012571075, (168, 1) = 2.0360589286432154, (168, 2) = 4.921523996578452, (169, 1) = 2.06488206482412, (169, 2) = 4.970097733788132, (170, 1) = 2.094400898894472, (170, 2) = 5.020019802315094, (171, 1) = 2.1269931991959794, (171, 2) = 5.075341211504158, (172, 1) = 2.156502857487437, (172, 2) = 5.125607972064607, (173, 1) = 2.1866820105527633, (173, 2) = 5.177185381228431, (174, 1) = 2.217373431859296, (174, 2) = 5.229810392176731, (175, 1) = 2.2455848204020104, (175, 2) = 5.278332330610496, (176, 1) = 2.275657247035176, (176, 2) = 5.330208765245516, (177, 1) = 2.30550076040201, (177, 2) = 5.381843230194378, (178, 1) = 2.33742404321608, (178, 2) = 5.4372404381487875, (179, 1) = 2.365594957386934, (179, 2) = 5.4862637352290635, (180, 1) = 2.3980983443216077, (180, 2) = 5.542982766786983, (181, 1) = 2.427430145125628, (181, 2) = 5.59430757925006, (182, 1) = 2.456452428844221, (182, 2) = 5.645218549289771, (183, 1) = 2.4876607073366834, (183, 2) = 5.7001025707611115, (184, 1) = 2.518995229748744, (184, 2) = 5.75534933696038, (185, 1) = 2.547505005527638, (185, 2) = 5.805735253004692, (186, 1) = 2.5777811210050254, (186, 2) = 5.859364570694414, (187, 1) = 2.607327650653266, (187, 2) = 5.911819591918552, (188, 1) = 2.6393564005025123, (188, 2) = 5.9688099166408275, (189, 1) = 2.667070174070351, (189, 2) = 6.018227766988365, (190, 1) = 2.698900450552763, (190, 2) = 6.075103704796472, (191, 1) = 2.7288225838190954, (191, 2) = 6.128682193645554, (192, 1) = 2.758455701909548, (192, 2) = 6.181847723993656, (193, 1) = 2.788112393366834, (193, 2) = 6.235157321929659, (194, 1) = 2.8183603414070344, (194, 2) = 6.289632209080143, (195, 1) = 2.8504226595979896, (195, 2) = 6.347485006729213, (196, 1) = 2.8798206657286434, (196, 2) = 6.400627815359849, (197, 1) = 2.9088402726633165, (197, 2) = 6.453175941222253, (198, 1) = 2.9398617548743715, (198, 2) = 6.509444982813266, (199, 1) = 2.97081570603015, (199, 2) = 6.565688117114613, (200, 1) = 3.0, (200, 2) = 6.618802153517006}, datatype = float[8]), COLOUR(RGB, .47058824, 0., 0.54901961e-1, _ATTRIBUTE("source" = "mathdefault"))), AXESLABELS(x, ""), VIEW(-3. .. 3., DEFAULT, _ATTRIBUTE("source" = "mathdefault")), _ATTRIBUTE("input" = [TABLE([1 = plot, 2 = [(1/3)*(6+2*x^2+(12+5*x^2+4*x*(x^2+3)^(1/2))^(1/2)*(x^2+3)^(1/2)+x*(x^2+3)^(1/2))/(x^2+3)^(1/2)], 3 = (x = -3 .. 3)]), "originalview" = [-3. .. 3., 2.00002096127672591 .. 6.61880215351700585], "originalaxesticks" = AXESTICKS(DEFAULT, DEFAULT, _ATTRIBUTE("source" = "mathdefault"))]))]
map(X->plot(eval(X,a=1.5),x=-3..3),the_residue);
[INTERFACE_PLOT(CURVES(Matrix(200, 2, {(1, 1) = -2.985, (1, 2) = 2.874025883, (2, 1) = -2.955, (2, 2) = 2.854642282, (3, 1) = -2.925, (3, 2) = 2.835344303, (4, 1) = -2.895, (4, 2) = 2.816134266, (5, 1) = -2.865, (5, 2) = 2.797014562, (6, 1) = -2.835, (6, 2) = 2.777987691, (7, 1) = -2.805, (7, 2) = 2.759056232, (8, 1) = -2.775, (8, 2) = 2.740222835, (9, 1) = -2.745, (9, 2) = 2.721490283, (10, 1) = -2.715, (10, 2) = 2.70286143, (11, 1) = -2.685, (11, 2) = 2.684339246, (12, 1) = -2.655, (12, 2) = 2.665926815, (13, 1) = -2.625, (13, 2) = 2.647627325, (14, 1) = -2.595, (14, 2) = 2.629444093, (15, 1) = -2.565, (15, 2) = 2.611380555, (16, 1) = -2.535, (16, 2) = 2.593440278, (17, 1) = -2.505, (17, 2) = 2.575626962, (18, 1) = -2.475, (18, 2) = 2.55794446, (19, 1) = -2.445, (19, 2) = 2.540396764, (20, 1) = -2.415, (20, 2) = 2.522988022, (21, 1) = -2.385, (21, 2) = 2.505722547, (22, 1) = -2.355, (22, 2) = 2.48860483, (23, 1) = -2.325, (23, 2) = 2.471639524, (24, 1) = -2.295, (24, 2) = 2.454831479, (25, 1) = -2.265, (25, 2) = 2.438185742, (26, 1) = -2.235, (26, 2) = 2.421707563, (27, 1) = -2.205, (27, 2) = 2.405402393, (28, 1) = -2.175, (28, 2) = 2.389275933, (29, 1) = -2.145, (29, 2) = 2.373334099, (30, 1) = -2.115, (30, 2) = 2.357583056, (31, 1) = -2.085, (31, 2) = 2.342029234, (32, 1) = -2.055, (32, 2) = 2.32667933, (33, 1) = -2.025, (33, 2) = 2.311540327, (34, 1) = -1.995, (34, 2) = 2.296619498, (35, 1) = -1.965, (35, 2) = 2.281924438, (36, 1) = -1.935, (36, 2) = 2.267463062, (37, 1) = -1.905, (37, 2) = 2.253243627, (38, 1) = -1.875, (38, 2) = 2.239274757, (39, 1) = -1.845, (39, 2) = 2.22556545, (40, 1) = -1.815, (40, 2) = 2.212125097, (41, 1) = -1.785, (41, 2) = 2.198963502, (42, 1) = -1.755, (42, 2) = 2.186090908, (43, 1) = -1.725, (43, 2) = 2.173518014, (44, 1) = -1.695, (44, 2) = 2.161255996, (45, 1) = -1.665, (45, 2) = 2.14931653, (46, 1) = -1.635, (46, 2) = 2.137711814, (47, 1) = -1.605, (47, 2) = 2.126454602, (48, 1) = -1.575, (48, 2) = 2.115558219, (49, 1) = -1.545, (49, 2) = 2.105036595, (50, 1) = -1.515, (50, 2) = 2.094904293, (51, 1) = -1.485, (51, 2) = 2.085176526, (52, 1) = -1.455, (52, 2) = 2.075869209, (53, 1) = -1.425, (53, 2) = 2.066998963, (54, 1) = -1.395, (54, 2) = 2.058583179, (55, 1) = -1.365, (55, 2) = 2.050640008, (56, 1) = -1.335, (56, 2) = 2.043188437, (57, 1) = -1.305, (57, 2) = 2.036248294, (58, 1) = -1.275, (58, 2) = 2.029840291, (59, 1) = -1.245, (59, 2) = 2.023986056, (60, 1) = -1.215, (60, 2) = 2.018708166, (61, 1) = -1.185, (61, 2) = 2.014030179, (62, 1) = -1.155, (62, 2) = 2.009976672, (63, 1) = -1.125, (63, 2) = 2.006573261, (64, 1) = -1.095, (64, 2) = 2.003846642, (65, 1) = -1.065, (65, 2) = 2.001824606, (66, 1) = -1.035, (66, 2) = 2.000536066, (67, 1) = -1.005, (67, 2) = 2.000011085, (68, 1) = -.975, (68, 2) = 2.000280886, (69, 1) = -.945, (69, 2) = 2.001377862, (70, 1) = -.915, (70, 2) = 2.003335576, (71, 1) = -.885, (71, 2) = 2.006188774, (72, 1) = -.855, (72, 2) = 2.009973355, (73, 1) = -.825, (73, 2) = 2.014726377, (74, 1) = -.795, (74, 2) = 2.02048599, (75, 1) = -.765, (75, 2) = 2.027291436, (76, 1) = -.735, (76, 2) = 2.03518296, (77, 1) = -.705, (77, 2) = 2.044201758, (78, 1) = -.675, (78, 2) = 2.054389892, (79, 1) = -.645, (79, 2) = 2.065790181, (80, 1) = -.615, (80, 2) = 2.078446082, (81, 1) = -.585, (81, 2) = 2.092401558, (82, 1) = -.555, (82, 2) = 2.107700918, (83, 1) = -.525, (83, 2) = 2.124388638, (84, 1) = -.495, (84, 2) = 2.142509158, (85, 1) = -.465, (85, 2) = 2.162106674, (86, 1) = -.435, (86, 2) = 2.183224896, (87, 1) = -.405, (87, 2) = 2.205906795, (88, 1) = -.375, (88, 2) = 2.230194338, (89, 1) = -.345, (89, 2) = 2.256128202, (90, 1) = -.315, (90, 2) = 2.283747478, (91, 1) = -.285, (91, 2) = 2.313089382, (92, 1) = -.255, (92, 2) = 2.344188946, (93, 1) = -.225, (93, 2) = 2.377078735, (94, 1) = -.195, (94, 2) = 2.411788538, (95, 1) = -.165, (95, 2) = 2.448345111, (96, 1) = -.135, (96, 2) = 2.48677191, (97, 1) = -.105, (97, 2) = 2.527088866, (98, 1) = -0.75e-1, (98, 2) = 2.569312178, (99, 1) = -0.45e-1, (99, 2) = 2.613454152, (100, 1) = -0.15e-1, (100, 2) = 2.659523058, (101, 1) = 0.15e-1, (101, 2) = 2.707523058, (102, 1) = 0.45e-1, (102, 2) = 2.757454151, (103, 1) = 0.75e-1, (103, 2) = 2.809312179, (104, 1) = .105, (104, 2) = 2.863088866, (105, 1) = .135, (105, 2) = 2.91877191, (106, 1) = .165, (106, 2) = 2.97634511, (107, 1) = .195, (107, 2) = 3.035788538, (108, 1) = .225, (108, 2) = 3.097078734, (109, 1) = .255, (109, 2) = 3.160188947, (110, 1) = .285, (110, 2) = 3.225089382, (111, 1) = .315, (111, 2) = 3.291747478, (112, 1) = .345, (112, 2) = 3.360128202, (113, 1) = .375, (113, 2) = 3.430194338, (114, 1) = .405, (114, 2) = 3.501906796, (115, 1) = .435, (115, 2) = 3.575224895, (116, 1) = .465, (116, 2) = 3.650106674, (117, 1) = .495, (117, 2) = 3.726509158, (118, 1) = .525, (118, 2) = 3.804388638, (119, 1) = .555, (119, 2) = 3.883700919, (120, 1) = .585, (120, 2) = 3.964401558, (121, 1) = .615, (121, 2) = 4.046446082, (122, 1) = .645, (122, 2) = 4.12979018, (123, 1) = .675, (123, 2) = 4.214389893, (124, 1) = .705, (124, 2) = 4.300201758, (125, 1) = .735, (125, 2) = 4.38718296, (126, 1) = .765, (126, 2) = 4.475291435, (127, 1) = .795, (127, 2) = 4.564485991, (128, 1) = .825, (128, 2) = 4.654726375, (129, 1) = .855, (129, 2) = 4.7459733570000004, (130, 1) = .885, (130, 2) = 4.838188773, (131, 1) = .915, (131, 2) = 4.931335578, (132, 1) = .945, (132, 2) = 5.025377862, (133, 1) = .975, (133, 2) = 5.120280888, (134, 1) = 1.005, (134, 2) = 5.216011086, (135, 1) = 1.035, (135, 2) = 5.312536068, (136, 1) = 1.065, (136, 2) = 5.4098246020000005, (137, 1) = 1.095, (137, 2) = 5.5078466420000005, (138, 1) = 1.125, (138, 2) = 5.606573264, (139, 1) = 1.155, (139, 2) = 5.705976674, (140, 1) = 1.185, (140, 2) = 5.806030179, (141, 1) = 1.215, (141, 2) = 5.906708166, (142, 1) = 1.245, (142, 2) = 6.007986059, (143, 1) = 1.275, (143, 2) = 6.109840297, (144, 1) = 1.305, (144, 2) = 6.212248294, (145, 1) = 1.335, (145, 2) = 6.315188439, (146, 1) = 1.365, (146, 2) = 6.418640003, (147, 1) = 1.395, (147, 2) = 6.522583178, (148, 1) = 1.425, (148, 2) = 6.6269989670000005, (149, 1) = 1.455, (149, 2) = 6.731869210999999, (150, 1) = 1.485, (150, 2) = 6.837176529, (151, 1) = 1.515, (151, 2) = 6.9429042889999995, (152, 1) = 1.545, (152, 2) = 7.049036596, (153, 1) = 1.575, (153, 2) = 7.1555582189999996, (154, 1) = 1.605, (154, 2) = 7.262454599, (155, 1) = 1.635, (155, 2) = 7.369711812, (156, 1) = 1.665, (156, 2) = 7.477316527999999, (157, 1) = 1.695, (157, 2) = 7.585255997, (158, 1) = 1.725, (158, 2) = 7.693518013, (159, 1) = 1.755, (159, 2) = 7.80209091, (160, 1) = 1.785, (160, 2) = 7.910963498999999, (161, 1) = 1.815, (161, 2) = 8.020125096, (162, 1) = 1.845, (162, 2) = 8.129565448, (163, 1) = 1.875, (163, 2) = 8.23927476, (164, 1) = 1.905, (164, 2) = 8.349243624, (165, 1) = 1.935, (165, 2) = 8.459463056, (166, 1) = 1.965, (166, 2) = 8.569924432, (167, 1) = 1.995, (167, 2) = 8.680619504, (168, 1) = 2.025, (168, 2) = 8.791540328, (169, 1) = 2.055, (169, 2) = 8.902679336, (170, 1) = 2.085, (170, 2) = 9.01402924, (171, 1) = 2.115, (171, 2) = 9.125583056, (172, 1) = 2.145, (172, 2) = 9.237334096, (173, 1) = 2.175, (173, 2) = 9.349275936, (174, 1) = 2.205, (174, 2) = 9.461402392, (175, 1) = 2.235, (175, 2) = 9.57370756, (176, 1) = 2.265, (176, 2) = 9.686185744, (177, 1) = 2.295, (177, 2) = 9.798831488, (178, 1) = 2.325, (178, 2) = 9.911639528, (179, 1) = 2.355, (179, 2) = 10.02460483, (180, 1) = 2.385, (180, 2) = 10.13772255, (181, 1) = 2.415, (181, 2) = 10.25098802, (182, 1) = 2.445, (182, 2) = 10.36439676, (183, 1) = 2.475, (183, 2) = 10.47794446, (184, 1) = 2.505, (184, 2) = 10.59162697, (185, 1) = 2.535, (185, 2) = 10.70544028, (186, 1) = 2.565, (186, 2) = 10.81938056, (187, 1) = 2.595, (187, 2) = 10.9334441, (188, 1) = 2.625, (188, 2) = 11.04762733, (189, 1) = 2.655, (189, 2) = 11.16192682, (190, 1) = 2.685, (190, 2) = 11.27633925, (191, 1) = 2.715, (191, 2) = 11.39086143, (192, 1) = 2.745, (192, 2) = 11.50549028, (193, 1) = 2.775, (193, 2) = 11.62022284, (194, 1) = 2.805, (194, 2) = 11.73505623, (195, 1) = 2.835, (195, 2) = 11.8499877, (196, 1) = 2.865, (196, 2) = 11.96501457, (197, 1) = 2.895, (197, 2) = 12.08013426, (198, 1) = 2.925, (198, 2) = 12.1953443, (199, 1) = 2.955, (199, 2) = 12.31064228, (200, 1) = 2.985, (200, 2) = 12.42602588}, datatype = float[8]), COLOUR(RGB, .47058824, 0., 0.54901961e-1, _ATTRIBUTE("source" = "mathdefault"))), AXESLABELS(x, ""), VIEW(-3. .. 3., DEFAULT, _ATTRIBUTE("source" = "mathdefault")), _ATTRIBUTE("input" = [TABLE([1 = plot, 2 = [.8000000000*(1.875+1.5*x^2+(2.8125+3.25*x^2+3.0*x*(x^2+1.25)^(1/2))^(1/2)*(x^2+1.25)^(1/2)+x*(x^2+1.25)^(1/2))/(x^2+1.25)^(1/2)], 3 = (x = -3 .. 3)]), "originalview" = [-2.98499999999999988 .. 2.98499999999999988, 2.00001108500000013 .. 12.4260258799999992], "originalaxesticks" = AXESTICKS(DEFAULT, DEFAULT, _ATTRIBUTE("source" = "mathdefault"))])), INTERFACE_PLOT(CURVES(Matrix(200, 2, {(1, 1) = -2.985, (1, 2) = .0, (2, 1) = -2.955, (2, 2) = 0.20256791e-8, (3, 1) = -2.925, (3, 2) = .0, (4, 1) = -2.895, (4, 2) = -0.1031130714e-8, (5, 1) = -2.865, (5, 2) = 0.1040507363e-8, (6, 1) = -2.835, (6, 2) = 0.131255348e-8, (7, 1) = -2.805, (7, 2) = -0.1854546118e-8, (8, 1) = -2.775, (8, 2) = 0.8022035152e-9, (9, 1) = -2.745, (9, 2) = .0, (10, 1) = -2.715, (10, 2) = -0.2724617221e-9, (11, 1) = -2.685, (11, 2) = -0.5501165294e-9, (12, 1) = -2.655, (12, 2) = -0.222160292e-8, (13, 1) = -2.625, (13, 2) = 0.2803890907e-9, (14, 1) = -2.595, (14, 2) = 0.8493766103999999e-9, (15, 1) = -2.565, (15, 2) = 0.5718216517e-9, (16, 1) = -2.535, (16, 2) = -0.577492216e-9, (17, 1) = -2.505, (17, 2) = 0.1458162811e-8, (18, 1) = -2.475, (18, 2) = 0.1472856981e-8, (19, 1) = -2.445, (19, 2) = -0.1190255386e-8, (20, 1) = -2.415, (20, 2) = -0.2104278254e-8, (21, 1) = -2.385, (21, 2) = 0.1518573446e-8, (22, 1) = -2.355, (22, 2) = 0.3068757022e-9, (23, 1) = -2.325, (23, 2) = .0, (24, 1) = -2.295, (24, 2) = 0.1566878414e-8, (25, 1) = -2.265, (25, 2) = 0.9501523448e-9, (26, 1) = -2.235, (26, 2) = 0.64024462e-9, (27, 1) = -2.205, (27, 2) = -0.9707752168e-9, (28, 1) = -2.175, (28, 2) = 0.9813817008e-9, (29, 1) = -2.145, (29, 2) = -0.3307303193e-9, (30, 1) = -2.115, (30, 2) = .0, (31, 1) = -2.085, (31, 2) = 0.3381454938e-9, (32, 1) = -2.055, (32, 2) = 0.3419607579e-9, (33, 1) = -2.025, (33, 2) = -0.34584996e-9, (34, 1) = -1.995, (34, 2) = 0.699629479e-9, (35, 1) = -1.965, (35, 2) = -0.1061570257e-8, (36, 1) = -1.935, (36, 2) = -0.7159553365e-9, (37, 1) = -1.905, (37, 2) = .0, (38, 1) = -1.875, (38, 2) = 0.1465851736e-8, (39, 1) = -1.845, (39, 2) = -0.3708306574e-9, (40, 1) = -1.815, (40, 2) = -0.1501136086e-8, (41, 1) = -1.785, (41, 2) = -0.1519298804e-8, (42, 1) = -1.755, (42, 2) = 0.1153363066e-8, (43, 1) = -1.725, (43, 2) = -0.3891746203e-9, (44, 1) = -1.695, (44, 2) = .0, (45, 1) = -1.665, (45, 2) = -0.7977867189999999e-9, (46, 1) = -1.635, (46, 2) = -0.403894909e-9, (47, 1) = -1.605, (47, 2) = -0.817986396e-9, (48, 1) = -1.575, (48, 2) = -0.8283791984e-9, (49, 1) = -1.545, (49, 2) = 0.838970788e-9, (50, 1) = -1.515, (50, 2) = -0.849763516e-9, (51, 1) = -1.485, (51, 2) = 0.4303797414e-9, (52, 1) = -1.455, (52, 2) = -0.4359802505e-9, (53, 1) = -1.425, (53, 2) = 0.441684025e-9, (54, 1) = -1.395, (54, 2) = -0.1342474849e-8, (55, 1) = -1.365, (55, 2) = .0, (56, 1) = -1.335, (56, 2) = 0.4594193414e-9, (57, 1) = -1.305, (57, 2) = .0, (58, 1) = -1.275, (58, 2) = .0, (59, 1) = -1.245, (59, 2) = .0, (60, 1) = -1.215, (60, 2) = -0.4845171333e-9, (61, 1) = -1.185, (61, 2) = -0.9820896064e-9, (62, 1) = -1.155, (62, 2) = 0.4976701943e-9, (63, 1) = -1.125, (63, 2) = 0.5043906598e-9, (64, 1) = -1.095, (64, 2) = -0.511202981e-9, (65, 1) = -1.065, (65, 2) = -0.1036206623e-8, (66, 1) = -1.035, (66, 2) = -0.5250871222e-9, (67, 1) = -1.005, (67, 2) = .0, (68, 1) = -.975, (68, 2) = .0, (69, 1) = -.945, (69, 2) = -0.5464826375e-9, (70, 1) = -.915, (70, 2) = 0.5537393072e-9, (71, 1) = -.885, (71, 2) = .0, (72, 1) = -.855, (72, 2) = .0, (73, 1) = -.825, (73, 2) = -0.575759383e-9, (74, 1) = -.795, (74, 2) = 0.5831459891e-9, (75, 1) = -.765, (75, 2) = .0, (76, 1) = -.735, (76, 2) = 0.2989552486e-9, (77, 1) = -.705, (77, 2) = -0.4842062758000001e-9, (78, 1) = -.675, (78, 2) = 0.245023761e-9, (79, 1) = -.645, (79, 2) = -0.1053654318e-8, (80, 1) = -.615, (80, 2) = -0.6269498139e-9, (81, 1) = -.585, (81, 2) = -0.6339978244e-10, (82, 1) = -.555, (82, 2) = 0.7050102983e-9, (83, 1) = -.525, (83, 2) = 0.1295376709e-9, (84, 1) = -.495, (84, 2) = -0.5234265486e-9, (85, 1) = -.465, (85, 2) = -0.1321355487e-9, (86, 1) = -.435, (86, 2) = 0.4001076823e-9, (87, 1) = -.405, (87, 2) = 0.6727619844e-9, (88, 1) = -.375, (88, 2) = 0.1356797286e-9, (89, 1) = -.345, (89, 2) = 0.1230713041e-8, (90, 1) = -.315, (90, 2) = 0.4132368549e-9, (91, 1) = -.285, (91, 2) = .0, (92, 1) = -.255, (92, 2) = 0.9069144768e-9, (93, 1) = -.225, (93, 2) = 0.4208866866e-9, (94, 1) = -.195, (94, 2) = 0.2114701607e-9, (95, 1) = -.165, (95, 2) = -0.2123623568e-9, (96, 1) = -.135, (96, 2) = .0, (97, 1) = -.105, (97, 2) = 0.7124069349999999e-9, (98, 1) = -0.75e-1, (98, 2) = 0.2498780189e-9, (99, 1) = -0.45e-1, (99, 2) = 0.4647258636e-9, (100, 1) = -0.15e-1, (100, 2) = -0.7154773629e-10, (101, 1) = 0.15e-1, (101, 2) = 0.7154773629e-10, (102, 1) = 0.45e-1, (102, 2) = 0.2502370035e-9, (103, 1) = 0.75e-1, (103, 2) = 0.46405917800000003e-9, (104, 1) = .105, (104, 2) = 0.7124069349999999e-9, (105, 1) = .135, (105, 2) = .0, (106, 1) = .165, (106, 2) = -0.4955121658e-9, (107, 1) = .195, (107, 2) = -0.2114701607e-9, (108, 1) = .225, (108, 2) = 0.2805911245e-9, (109, 1) = .255, (109, 2) = 0.4883385645e-9, (110, 1) = .285, (110, 2) = .0, (111, 1) = .315, (111, 2) = 0.2754912366e-9, (112, 1) = .345, (112, 2) = 0.1367458934e-9, (113, 1) = .375, (113, 2) = 0.5427189143e-9, (114, 1) = .405, (114, 2) = .0, (115, 1) = .435, (115, 2) = 0.2667384549e-9, (116, 1) = .465, (116, 2) = 0.1321355487e-9, (117, 1) = .495, (117, 2) = -0.1308566371e-9, (118, 1) = .525, (118, 2) = 0.5181506837e-9, (119, 1) = .555, (119, 2) = -0.640918453e-10, (120, 1) = .585, (120, 2) = 0.6339978244e-10, (121, 1) = .615, (121, 2) = -0.6269498139e-9, (122, 1) = .645, (122, 2) = -0.1859389974e-9, (123, 1) = .675, (123, 2) = 0.3675356414e-9, (124, 1) = .705, (124, 2) = -0.121051569e-9, (125, 1) = .735, (125, 2) = 0.2989552486e-9, (126, 1) = .765, (126, 2) = .0, (127, 1) = .795, (127, 2) = .0, (128, 1) = .825, (128, 2) = .0, (129, 1) = .855, (129, 2) = -0.5683881417999999e-9, (130, 1) = .885, (130, 2) = .0, (131, 1) = .915, (131, 2) = .0, (132, 1) = .945, (132, 2) = .0, (133, 1) = .975, (133, 2) = -0.5392832926e-9, (134, 1) = 1.005, (134, 2) = -0.5321491408e-9, (135, 1) = 1.035, (135, 2) = -0.5250871222e-9, (136, 1) = 1.065, (136, 2) = .0, (137, 1) = 1.095, (137, 2) = .0, (138, 1) = 1.125, (138, 2) = .0, (139, 1) = 1.155, (139, 2) = .0, (140, 1) = 1.185, (140, 2) = .0, (141, 1) = 1.215, (141, 2) = 0.4845171333e-9, (142, 1) = 1.245, (142, 2) = .0, (143, 1) = 1.275, (143, 2) = -0.4717629839e-9, (144, 1) = 1.305, (144, 2) = .0, (145, 1) = 1.335, (145, 2) = -0.4594193414e-9, (146, 1) = 1.365, (146, 2) = .0, (147, 1) = 1.395, (147, 2) = 0.4474916162e-9, (148, 1) = 1.425, (148, 2) = -0.441684025e-9, (149, 1) = 1.455, (149, 2) = .0, (150, 1) = 1.485, (150, 2) = 0.4303797414e-9, (151, 1) = 1.515, (151, 2) = .0, (152, 1) = 1.545, (152, 2) = .0, (153, 1) = 1.575, (153, 2) = .0, (154, 1) = 1.605, (154, 2) = .0, (155, 1) = 1.635, (155, 2) = 0.403894909e-9, (156, 1) = 1.665, (156, 2) = 0.1196680078e-8, (157, 1) = 1.695, (157, 2) = 0.1181961302e-8, (158, 1) = 1.725, (158, 2) = .0, (159, 1) = 1.755, (159, 2) = 0.3844543552e-9, (160, 1) = 1.785, (160, 2) = 0.379824701e-9, (161, 1) = 1.815, (161, 2) = 0.7505680427e-9, (162, 1) = 1.845, (162, 2) = 0.3708306574e-9, (163, 1) = 1.875, (163, 2) = -0.7329258677999999e-9, (164, 1) = 1.905, (164, 2) = 0.3621791667e-9, (165, 1) = 1.935, (165, 2) = -0.7159553365e-9, (166, 1) = 1.965, (166, 2) = -0.3538567523e-9, (167, 1) = 1.995, (167, 2) = 0.1049444218e-8, (168, 1) = 2.025, (168, 2) = 0.6916999200000001e-9, (169, 1) = 2.055, (169, 2) = -0.1367843032e-8, (170, 1) = 2.085, (170, 2) = -0.6762909876999999e-9, (171, 1) = 2.115, (171, 2) = .0, (172, 1) = 2.145, (172, 2) = 0.9921909576e-9, (173, 1) = 2.175, (173, 2) = 0.3271272336e-9, (174, 1) = 2.205, (174, 2) = -0.9707752168e-9, (175, 1) = 2.235, (175, 2) = 0.9603669296e-9, (176, 1) = 2.265, (176, 2) = .0, (177, 1) = 2.295, (177, 2) = -0.1566878414e-8, (178, 1) = 2.325, (178, 2) = -0.310095572e-9, (179, 1) = 2.355, (179, 2) = -0.9206271064e-9, (180, 1) = 2.385, (180, 2) = -0.1822288135e-8, (181, 1) = 2.415, (181, 2) = 0.3006111791e-9, (182, 1) = 2.445, (182, 2) = .0, (183, 1) = 2.475, (183, 2) = -0.1178285585e-8, (184, 1) = 2.505, (184, 2) = -0.1458162811e-8, (185, 1) = 2.535, (185, 2) = -0.577492216e-9, (186, 1) = 2.565, (186, 2) = 0.5718216517e-9, (187, 1) = 2.595, (187, 2) = 0.2831255369e-9, (188, 1) = 2.625, (188, 2) = -0.1121556363e-8, (189, 1) = 2.655, (189, 2) = 0.8331010952e-9, (190, 1) = 2.685, (190, 2) = -0.1100233059e-8, (191, 1) = 2.715, (191, 2) = 0.136230861e-8, (192, 1) = 2.745, (192, 2) = .0, (193, 1) = 2.775, (193, 2) = -0.2674011717e-9, (194, 1) = 2.805, (194, 2) = 0.1059740639e-8, (195, 1) = 2.835, (195, 2) = -0.1575064175e-8, (196, 1) = 2.865, (196, 2) = -0.7803805221999999e-9, (197, 1) = 2.895, (197, 2) = 0.1031130714e-8, (198, 1) = 2.925, (198, 2) = 0.2554773171e-9, (199, 1) = 2.955, (199, 2) = -0.7596296626e-9, (200, 1) = 2.985, (200, 2) = .0}, datatype = float[8]), COLOUR(RGB, .47058824, 0., 0.54901961e-1, _ATTRIBUTE("source" = "mathdefault"))), AXESLABELS(x, ""), VIEW(-3. .. 3., DEFAULT, _ATTRIBUTE("source" = "mathdefault")), _ATTRIBUTE("input" = [TABLE([1 = plot, 2 = [.8000000000*(-1.875-1.5*x^2+(2.8125+3.25*x^2-3.0*x*(x^2+1.25)^(1/2))^(1/2)*(x^2+1.25)^(1/2)+x*(x^2+1.25)^(1/2))/(x^2+1.25)^(1/2)], 3 = (x = -3 .. 3)]), "originalview" = [-2.98499999999999988 .. 2.98499999999999988, -0.222160292000000004e-8 .. 0.202567910000000010e-8], "originalaxesticks" = AXESTICKS(DEFAULT, DEFAULT, _ATTRIBUTE("source" = "mathdefault"))]))]
#betwee a=-1 and a=1 both solutions are wrong
map(X->plot(eval(X,a=.5),x=-3..3),the_residue);
[INTERFACE_PLOT(CURVES(Matrix(147, 2, {(1, 1) = -2.9850000001024455, (1, 2) = -0.8291209370582076e-15, (2, 1) = -2.955000000074506, (2, 2) = -0.8383249797434338e-15, (3, 1) = -2.925000000046566, (3, 2) = -.0, (4, 1) = -2.8950000000186265, (4, 2) = -0.42869410853640745e-15, (5, 1) = -2.8649999999906868, (5, 2) = -0.4336318893530789e-15, (6, 1) = -2.834999999962747, (6, 2) = -.0, (7, 1) = -2.8049999999348074, (7, 2) = -0.44387348071062017e-15, (8, 1) = -2.7749999999068677, (8, 2) = -0.4491868401936258e-15, (9, 1) = -2.7450000001117587, (9, 2) = -.0, (10, 1) = -2.715000000083819, (10, 2) = 0.460224548361483e-15, (11, 1) = -2.6850000000558794, (11, 2) = 0.9319202364876206e-15, (12, 1) = -2.6550000000279397, (12, 2) = -.0, (13, 1) = -2.625, (13, 2) = -.0, (14, 1) = -2.5949999999720603, (14, 2) = 0.4841079934905019e-15, (15, 1) = -2.5649999999441206, (15, 2) = -.0, (16, 1) = -2.534999999916181, (16, 2) = -0.9941207708674063e-15, (17, 1) = -2.5049999998882413, (17, 2) = 0.5038158538728184e-15, (18, 1) = -2.4750000000931323, (18, 2) = -0.10215378587121548e-14, (19, 1) = -2.4450000000651926, (19, 2) = 0.5179288767286773e-15, (20, 1) = -2.415000000037253, (20, 2) = -.0, (21, 1) = -2.3850000000093132, (21, 2) = -0.5329095663574006e-15, (22, 1) = -2.3549999999813735, (22, 2) = -0.5407521242642256e-15, (23, 1) = -2.324999999953434, (23, 2) = 0.5488453101039584e-15, (24, 1) = -2.294999999925494, (24, 2) = -.0, (25, 1) = -2.2649999998975545, (25, 2) = 0.5658362196110233e-15, (26, 1) = -2.2350000001024455, (26, 2) = -.0, (27, 1) = -2.205000000074506, (27, 2) = -0.5839976238715939e-15, (28, 1) = -2.175000000046566, (28, 2) = -.0, (29, 1) = -2.1450000000186265, (29, 2) = 0.6034631901774739e-15, (30, 1) = -2.1149999999906868, (30, 2) = -.0, (31, 1) = -2.084999999962747, (31, 2) = -0.31219443415915157e-15, (32, 1) = -2.0549999999348074, (32, 2) = -.0, (33, 1) = -2.0249999999068677, (33, 2) = -0.32347896537229686e-15, (34, 1) = -1.9949999999953434, (34, 2) = 0.3294625198680019e-15, (35, 1) = -1.9649999999674037, (35, 2) = -0.33569374392492335e-15, (36, 1) = -1.9350000000558794, (36, 2) = -.0, (37, 1) = -1.9050000000279397, (37, 2) = -0.3489685103602158e-15, (38, 1) = -1.875, (38, 2) = -.0, (39, 1) = -1.8449999999720603, (39, 2) = -.0, (40, 1) = -1.8149999999441206, (40, 2) = -.0, (41, 1) = -1.7850000000325963, (41, 2) = 0.37935888473606496e-15, (42, 1) = -1.7550000000046566, (42, 2) = -.0, (43, 1) = -1.724999999976717, (43, 2) = -0.3969017028004905e-15, (44, 1) = -1.6949999999487773, (44, 2) = -.0, (45, 1) = -1.665000000037253, (45, 2) = -.0, (46, 1) = -1.6350000000093132, (46, 2) = -0.4269666065238628e-15, (47, 1) = -1.6049999999813735, (47, 2) = -.0, (48, 1) = -1.5749999999534339, (48, 2) = -.0, (49, 1) = -1.5450000000419095, (49, 2) = -0.23139358038725645e-15, (50, 1) = -1.5150000000139698, (50, 2) = -0.2381678296027313e-15, (51, 1) = -1.4849999999860302, (51, 2) = -.0, (52, 1) = -1.4549999999580905, (52, 2) = -0.25321576063421446e-15, (53, 1) = -1.4250000000465661, (53, 2) = -.0, (54, 1) = -1.3950000000186265, (54, 2) = -0.5414256527761197e-15, (55, 1) = -1.3649999999906868, (55, 2) = -.0, (56, 1) = -1.334999999962747, (56, 2) = -.0, (57, 1) = -1.3050000000512227, (57, 2) = -0.303268159288592e-15, (58, 1) = -1.275000000023283, (58, 2) = -.0, (59, 1) = -1.2449999999953434, (59, 2) = -0.33099938186101356e-15, (60, 1) = -1.2149999999674037, (60, 2) = -.0, (61, 1) = -1.1850000000558794, (61, 2) = 0.18301445729146418e-15, (62, 1) = -1.1550000000279397, (62, 2) = -.0, (63, 1) = -1.125, (63, 2) = -.0, (64, 1) = -1.0949999999720603, (64, 2) = -.0, (65, 1) = -1.0649999999441206, (65, 2) = -.0, (66, 1) = -1.0350000000325963, (66, 2) = -.0, (67, 1) = -1.0050000000046566, (67, 2) = -.0, (68, 1) = -.9749999999767169, (68, 2) = -0.16524428406629887e-15, (69, 1) = -.9450000000069849, (69, 2) = 0.19570998894400967e-15, (70, 1) = -.9149999999790452, (70, 2) = -.0, (71, 1) = -.8850000000093132, (71, 2) = -0.20302825412549344e-15, (72, 1) = -.8690639063124763, (72, 2) = 0.25484039012618007e-15, (73, 1) = -.8671887188002074, (73, 2) = -.0, (74, 1) = .8671887188002074, (74, 2) = undefined, (75, 1) = .8671887188002074, (75, 2) = -2.3723738361139484, (76, 1) = .8690639063124763, (76, 2) = -2.4143158080874376, (77, 1) = .8850000000093132, (77, 2) = -2.603036347881809, (78, 1) = .9149999999790452, (78, 2) = -2.833785050499043, (79, 1) = .9450000000069849, (79, 2) = -3.0242486152151873, (80, 1) = .9749999999767169, (80, 2) = -3.1972157613099954, (81, 1) = 1.0050000000046566, (81, 2) = -3.359901952900556, (82, 1) = 1.0350000000325963, (82, 2) = -3.5156895298928057, (83, 1) = 1.0649999999441206, (83, 2) = -3.6664784720085737, (84, 1) = 1.0949999999720603, (84, 2) = -3.813457701696712, (85, 1) = 1.125, (85, 2) = -3.9574271067669815, (86, 1) = 1.1550000000279397, (86, 2) = -4.09895371084506, (87, 1) = 1.1850000000558794, (87, 2) = -4.238455685198987, (88, 1) = 1.2149999999674037, (88, 2) = -4.376251144704398, (89, 1) = 1.2449999999953434, (89, 2) = -4.512588220604918, (90, 1) = 1.275000000023283, (90, 2) = -4.647664483756664, (91, 1) = 1.3050000000512227, (91, 2) = -4.7816399902230815, (92, 1) = 1.334999999962747, (92, 2) = -4.914646323913328, (93, 1) = 1.3649999999906868, (93, 2) = -5.046793041993631, (94, 1) = 1.3950000000186265, (94, 2) = -5.178172370856263, (95, 1) = 1.4250000000465661, (95, 2) = -5.308862705242646, (96, 1) = 1.4549999999580905, (96, 2) = -5.438931256297706, (97, 1) = 1.4849999999860302, (97, 2) = -5.5684360919834, (98, 1) = 1.5150000000139698, (98, 2) = -5.697427724561123, (99, 1) = 1.5450000000419095, (99, 2) = -5.825950369239624, (100, 1) = 1.5749999999534339, (100, 2) = -5.954042947236029, (101, 1) = 1.6049999999813735, (101, 2) = -6.081739898237958, (102, 1) = 1.6350000000093132, (102, 2) = -6.2090718377261975, (103, 1) = 1.665000000037253, (103, 2) = -6.336066101499923, (104, 1) = 1.6949999999487773, (104, 2) = -6.462747193936845, (105, 1) = 1.724999999976717, (105, 2) = -6.589137164632822, (106, 1) = 1.7550000000046566, (106, 2) = -6.7152559200043225, (107, 1) = 1.7850000000325963, (107, 2) = -6.841121490955475, (108, 1) = 1.8149999999441206, (108, 2) = -6.966750257614648, (109, 1) = 1.8449999999720603, (109, 2) = -7.092157144052213, (110, 1) = 1.875, (110, 2) = -7.217355780804004, (111, 1) = 1.9050000000279397, (111, 2) = -7.342358649482328, (112, 1) = 1.9350000000558794, (112, 2) = -7.467177205835014, (113, 1) = 1.9649999999674037, (113, 2) = -7.591821986695158, (114, 1) = 1.9949999999953434, (114, 2) = -7.716302705696596, (115, 1) = 2.0249999999068677, (115, 2) = -7.84062833205218, (116, 1) = 2.0549999999348074, (116, 2) = -7.964807166649128, (117, 1) = 2.084999999962747, (117, 2) = -8.08884690237672, (118, 1) = 2.1149999999906868, (118, 2) = -8.212754682418078, (119, 1) = 2.1450000000186265, (119, 2) = -8.336537149776824, (120, 1) = 2.175000000046566, (120, 2) = -8.460200491773978, (121, 1) = 2.205000000074506, (121, 2) = -8.58375047974494, (122, 1) = 2.2350000001024455, (122, 2) = -8.707192504543793, (123, 1) = 2.2649999998975545, (123, 2) = -8.830531607417486, (124, 1) = 2.294999999925494, (124, 2) = -8.953772512437471, (125, 1) = 2.324999999953434, (125, 2) = -9.07691964651612, (126, 1) = 2.3549999999813735, (126, 2) = -9.199977166484143, (127, 1) = 2.3850000000093132, (127, 2) = -9.32294897915592, (128, 1) = 2.415000000037253, (128, 2) = -9.445838760377447, (129, 1) = 2.4450000000651926, (129, 2) = -9.568649972316873, (130, 1) = 2.4750000000931323, (130, 2) = -9.691385879187816, (131, 1) = 2.5049999998882413, (131, 2) = -9.814049560620312, (132, 1) = 2.534999999916181, (132, 2) = -9.93664392853661, (133, 1) = 2.5649999999441206, (133, 2) = -10.059171733382136, (134, 1) = 2.5949999999720603, (134, 2) = -10.18163557886507, (135, 1) = 2.625, (135, 2) = -10.304037931023824, (136, 1) = 2.6550000000279397, (136, 2) = -10.426381127424632, (137, 1) = 2.6850000000558794, (137, 2) = -10.548667385615923, (138, 1) = 2.715000000083819, (138, 2) = -10.670898810910073, (139, 1) = 2.7450000001117587, (139, 2) = -10.793077403555088, (140, 1) = 2.7749999999068677, (140, 2) = -10.915205064404796, (141, 1) = 2.8049999999348074, (141, 2) = -11.037283604823806, (142, 1) = 2.834999999962747, (142, 2) = -11.159314746655687, (143, 1) = 2.8649999999906868, (143, 2) = -11.28130013125142, (144, 1) = 2.8950000000186265, (144, 2) = -11.4032413233759, (145, 1) = 2.925000000046566, (145, 2) = -11.525139815712924, (146, 1) = 2.955000000074506, (146, 2) = -11.646997033050228, (147, 1) = 2.9850000001024455, (147, 2) = -11.768814336171081}, datatype = float[8]), COLOUR(RGB, .47058824, 0., 0.54901961e-1, _ATTRIBUTE("source" = "mathdefault"))), AXESLABELS(x, ""), VIEW(-3. .. 3., DEFAULT, _ATTRIBUTE("source" = "mathdefault")), _ATTRIBUTE("input" = [TABLE([1 = plot, 2 = [-1.333333333*(-.375+.5*x^2+(-.1875+1.25*x^2+1.0*x*(x^2-.75)^(1/2))^(1/2)*(x^2-.75)^(1/2)+x*(x^2-.75)^(1/2))/(x^2-.75)^(1/2)], 3 = (x = -3 .. 3)]), "originalview" = [-2.98500000010244548 .. 2.98500000010244548, -11.7688143361710811 .. 0.931920236487620605e-15], "originalaxesticks" = AXESTICKS(DEFAULT, DEFAULT, _ATTRIBUTE("source" = "mathdefault"))])), INTERFACE_PLOT(CURVES(Matrix(147, 2, {(1, 1) = -2.9850000001024455, (1, 2) = -.0, (2, 1) = -2.955000000074506, (2, 2) = -0.8383249797434338e-15, (3, 1) = -2.925000000046566, (3, 2) = -.0, (4, 1) = -2.8950000000186265, (4, 2) = -0.42869410853640745e-15, (5, 1) = -2.8649999999906868, (5, 2) = -0.4336318893530789e-15, (6, 1) = -2.834999999962747, (6, 2) = -.0, (7, 1) = -2.8049999999348074, (7, 2) = 0.44387348071062017e-15, (8, 1) = -2.7749999999068677, (8, 2) = 0.4491868401936258e-15, (9, 1) = -2.7450000001117587, (9, 2) = -.0, (10, 1) = -2.715000000083819, (10, 2) = -0.460224548361483e-15, (11, 1) = -2.6850000000558794, (11, 2) = 0.4659601182438103e-15, (12, 1) = -2.6550000000279397, (12, 2) = -0.4718481833150734e-15, (13, 1) = -2.625, (13, 2) = -.0, (14, 1) = -2.5949999999720603, (14, 2) = -0.4841079934905019e-15, (15, 1) = -2.5649999999441206, (15, 2) = -.0, (16, 1) = -2.534999999916181, (16, 2) = -.0, (17, 1) = -2.5049999998882413, (17, 2) = -0.10076317077456367e-14, (18, 1) = -2.4750000000931323, (18, 2) = -0.5107689293560774e-15, (19, 1) = -2.4450000000651926, (19, 2) = -0.5179288767286773e-15, (20, 1) = -2.415000000037253, (20, 2) = -.0, (21, 1) = -2.3850000000093132, (21, 2) = -.0, (22, 1) = -2.3549999999813735, (22, 2) = -.0, (23, 1) = -2.324999999953434, (23, 2) = 0.5488453101039584e-15, (24, 1) = -2.294999999925494, (24, 2) = -.0, (25, 1) = -2.2649999998975545, (25, 2) = 0.5658362196110233e-15, (26, 1) = -2.2350000001024455, (26, 2) = -.0, (27, 1) = -2.205000000074506, (27, 2) = 0.5839976238715939e-15, (28, 1) = -2.175000000046566, (28, 2) = -.0, (29, 1) = -2.1450000000186265, (29, 2) = -.0, (30, 1) = -2.1149999999906868, (30, 2) = -.0, (31, 1) = -2.084999999962747, (31, 2) = -.0, (32, 1) = -2.0549999999348074, (32, 2) = 0.317727644355489e-15, (33, 1) = -2.0249999999068677, (33, 2) = 0.32347896537229686e-15, (34, 1) = -1.9949999999953434, (34, 2) = -0.3294625198680019e-15, (35, 1) = -1.9649999999674037, (35, 2) = -.0, (36, 1) = -1.9350000000558794, (36, 2) = -0.3421895491340989e-15, (37, 1) = -1.9050000000279397, (37, 2) = -0.3489685103602158e-15, (38, 1) = -1.875, (38, 2) = -.0, (39, 1) = -1.8449999999720603, (39, 2) = -0.7269197165732082e-15, (40, 1) = -1.8149999999441206, (40, 2) = -0.37121985757208076e-15, (41, 1) = -1.7850000000325963, (41, 2) = -.0, (42, 1) = -1.7550000000046566, (42, 2) = -.0, (43, 1) = -1.724999999976717, (43, 2) = 0.3969017028004905e-15, (44, 1) = -1.6949999999487773, (44, 2) = 0.40637913681039384e-15, (45, 1) = -1.665000000037253, (45, 2) = -.0, (46, 1) = -1.6350000000093132, (46, 2) = -.0, (47, 1) = -1.6049999999813735, (47, 2) = -.0, (48, 1) = -1.5749999999534339, (48, 2) = -.0, (49, 1) = -1.5450000000419095, (49, 2) = -0.4627871607745129e-15, (50, 1) = -1.5150000000139698, (50, 2) = -.0, (51, 1) = -1.4849999999860302, (51, 2) = -.0, (52, 1) = -1.4549999999580905, (52, 2) = 0.25321576063421446e-15, (53, 1) = -1.4250000000465661, (53, 2) = -0.2616182125293251e-15, (54, 1) = -1.3950000000186265, (54, 2) = -.0, (55, 1) = -1.3649999999906868, (55, 2) = -.0, (56, 1) = -1.334999999962747, (56, 2) = -.0, (57, 1) = -1.3050000000512227, (57, 2) = 0.303268159288592e-15, (58, 1) = -1.275000000023283, (58, 2) = -0.31638791438219415e-15, (59, 1) = -1.2449999999953434, (59, 2) = -.0, (60, 1) = -1.2149999999674037, (60, 2) = -.0, (61, 1) = -1.1850000000558794, (61, 2) = -.0, (62, 1) = -1.1550000000279397, (62, 2) = -.0, (63, 1) = -1.125, (63, 2) = -.0, (64, 1) = -1.0949999999720603, (64, 2) = 0.22090915048843943e-15, (65, 1) = -1.0649999999441206, (65, 2) = -.0, (66, 1) = -1.0350000000325963, (66, 2) = -.0, (67, 1) = -1.0050000000046566, (67, 2) = -0.29029624201545924e-15, (68, 1) = -.9749999999767169, (68, 2) = -.0, (69, 1) = -.9450000000069849, (69, 2) = -.0, (70, 1) = -.9149999999790452, (70, 2) = -.0, (71, 1) = -.8850000000093132, (71, 2) = -.0, (72, 1) = -.8690639063124763, (72, 2) = -.0, (73, 1) = -.8671887188002074, (73, 2) = -.0, (74, 1) = .8671887188002074, (74, 2) = undefined, (75, 1) = .8671887188002074, (75, 2) = -2.252632662997572, (76, 1) = .8690639063124763, (76, 2) = -2.220691691087017, (77, 1) = .8850000000093132, (77, 2) = -2.116963650987861, (78, 1) = .9149999999790452, (78, 2) = -2.0462149481691982, (79, 1) = .9450000000069849, (79, 2) = -2.015751383562065, (80, 1) = .9749999999767169, (80, 2) = -2.002784237265827, (81, 1) = 1.0050000000046566, (81, 2) = -2.0000980457842794, (82, 1) = 1.0350000000325963, (82, 2) = -2.0043104689010405, (83, 1) = 1.0649999999441206, (83, 2) = -2.0135215262734025, (84, 1) = 1.0949999999720603, (84, 2) = -2.0265422966942763, (85, 1) = 1.125, (85, 2) = -2.0425728917330184, (86, 1) = 1.1550000000279397, (86, 2) = -2.0610462877639506, (87, 1) = 1.1850000000558794, (87, 2) = -2.0815443135190366, (88, 1) = 1.2149999999674037, (88, 2) = -2.1037488535017537, (89, 1) = 1.2449999999953434, (89, 2) = -2.1274117777102464, (90, 1) = 1.275000000023283, (90, 2) = -2.1523355146675116, (91, 1) = 1.3050000000512227, (91, 2) = -2.1783600083101056, (92, 1) = 1.334999999962747, (92, 2) = -2.20535367410799, (93, 1) = 1.3649999999906868, (93, 2) = -2.2332069561366987, (94, 1) = 1.3950000000186265, (94, 2) = -2.2618276273830777, (95, 1) = 1.4250000000465661, (95, 2) = -2.2911372931057055, (96, 1) = 1.4549999999580905, (96, 2) = -2.3210687415387756, (97, 1) = 1.4849999999860302, (97, 2) = -2.3515639059620943, (98, 1) = 1.5150000000139698, (98, 2) = -2.38257227349338, (99, 1) = 1.5450000000419095, (99, 2) = -2.4140496289238937, (100, 1) = 1.5749999999534339, (100, 2) = -2.445957050415619, (101, 1) = 1.6049999999813735, (101, 2) = -2.4782600995227004, (102, 1) = 1.6350000000093132, (102, 2) = -2.5109281601434716, (103, 1) = 1.665000000037253, (103, 2) = -2.5439338964787583, (104, 1) = 1.6949999999487773, (104, 2) = -2.577252803529966, (105, 1) = 1.724999999976717, (105, 2) = -2.610862832942999, (106, 1) = 1.7550000000046566, (106, 2) = -2.644744077680514, (107, 1) = 1.7850000000325963, (107, 2) = -2.678878506838372, (108, 1) = 1.8149999999441206, (108, 2) = -2.7132497396673294, (109, 1) = 1.8449999999720603, (109, 2) = -2.7478428533387755, (110, 1) = 1.875, (110, 2) = -2.782644216695993, (111, 1) = 1.9050000000279397, (111, 2) = -2.817641348126683, (112, 1) = 1.9350000000558794, (112, 2) = -2.85282279188301, (113, 1) = 1.9649999999674037, (113, 2) = -2.8881780105109938, (114, 1) = 1.9949999999953434, (114, 2) = -2.923697291618569, (115, 1) = 2.0249999999068677, (115, 2) = -2.959371664751114, (116, 1) = 2.0549999999348074, (116, 2) = -2.995192830263177, (117, 1) = 2.084999999962747, (117, 2) = -3.0311530946445964, (118, 1) = 2.1149999999906868, (118, 2) = -3.067245314712253, (119, 1) = 2.1450000000186265, (119, 2) = -3.103462847462517, (120, 1) = 2.175000000046566, (120, 2) = -3.1397995055743713, (121, 1) = 2.205000000074506, (121, 2) = -3.1762495177124217, (122, 1) = 2.2350000001024455, (122, 2) = -3.2128074930225825, (123, 1) = 2.2649999998975545, (123, 2) = -3.2494683890161373, (124, 1) = 2.294999999925494, (124, 2) = -3.2862274841051633, (125, 1) = 2.324999999953434, (125, 2) = -3.323080350135525, (126, 1) = 2.3549999999813735, (126, 2) = -3.3600228302765154, (127, 1) = 2.3850000000093132, (127, 2) = -3.397051017713751, (128, 1) = 2.415000000037253, (128, 2) = -3.4341612366012373, (129, 1) = 2.4450000000651926, (129, 2) = -3.47135002477082, (130, 1) = 2.4750000000931323, (130, 2) = -3.508614118008889, (131, 1) = 2.5049999998882413, (131, 2) = -3.545950435443641, (132, 1) = 2.534999999916181, (132, 2) = -3.5833560676363536, (133, 1) = 2.5649999999441206, (133, 2) = -3.6208282628998383, (134, 1) = 2.5949999999720603, (134, 2) = -3.6583644175259216, (135, 1) = 2.625, (135, 2) = -3.695962065476175, (136, 1) = 2.6550000000279397, (136, 2) = -3.733618869184381, (137, 1) = 2.6850000000558794, (137, 2) = -3.771332611102098, (138, 1) = 2.715000000083819, (138, 2) = -3.8091011859169632, (139, 1) = 2.7450000001117587, (139, 2) = -3.8469225933809583, (140, 1) = 2.7749999999068677, (140, 2) = -3.8847949313984955, (141, 1) = 2.8049999999348074, (141, 2) = -3.9227163910884983, (142, 1) = 2.834999999962747, (142, 2) = -3.9606852493656306, (143, 1) = 2.8649999999906868, (143, 2) = -3.998699864878906, (144, 1) = 2.8950000000186265, (144, 2) = -4.036758672863441, (145, 1) = 2.925000000046566, (145, 2) = -4.074860180635428, (146, 1) = 2.955000000074506, (146, 2) = -4.1130029634071334, (147, 1) = 2.9850000001024455, (147, 2) = -4.15118566039529}, datatype = float[8]), COLOUR(RGB, .47058824, 0., 0.54901961e-1, _ATTRIBUTE("source" = "mathdefault"))), AXESLABELS(x, ""), VIEW(-3. .. 3., DEFAULT, _ATTRIBUTE("source" = "mathdefault")), _ATTRIBUTE("input" = [TABLE([1 = plot, 2 = [-1.333333333*(.375-.5*x^2+(-.1875+1.25*x^2-1.0*x*(x^2-.75)^(1/2))^(1/2)*(x^2-.75)^(1/2)+x*(x^2-.75)^(1/2))/(x^2-.75)^(1/2)], 3 = (x = -3 .. 3)]), "originalview" = [-2.98500000010244548 .. 2.98500000010244548, -4.15118566039529036 .. 0.583997623871593893e-15], "originalaxesticks" = AXESTICKS(DEFAULT, DEFAULT, _ATTRIBUTE("source" = "mathdefault"))]))]
map(X->plot(eval(X,a=-1.5),x=-3..3),the_residue);
[INTERFACE_PLOT(CURVES(Matrix(200, 2, {(1, 1) = -2.985, (1, 2) = .0, (2, 1) = -2.955, (2, 2) = 0.20256791e-8, (3, 1) = -2.925, (3, 2) = .0, (4, 1) = -2.895, (4, 2) = -0.1031130714e-8, (5, 1) = -2.865, (5, 2) = 0.1040507363e-8, (6, 1) = -2.835, (6, 2) = 0.131255348e-8, (7, 1) = -2.805, (7, 2) = -0.1854546118e-8, (8, 1) = -2.775, (8, 2) = 0.8022035152e-9, (9, 1) = -2.745, (9, 2) = .0, (10, 1) = -2.715, (10, 2) = -0.2724617221e-9, (11, 1) = -2.685, (11, 2) = -0.5501165294e-9, (12, 1) = -2.655, (12, 2) = -0.222160292e-8, (13, 1) = -2.625, (13, 2) = 0.2803890907e-9, (14, 1) = -2.595, (14, 2) = 0.8493766103999999e-9, (15, 1) = -2.565, (15, 2) = 0.5718216517e-9, (16, 1) = -2.535, (16, 2) = -0.577492216e-9, (17, 1) = -2.505, (17, 2) = 0.1458162811e-8, (18, 1) = -2.475, (18, 2) = 0.1472856981e-8, (19, 1) = -2.445, (19, 2) = -0.1190255386e-8, (20, 1) = -2.415, (20, 2) = -0.2104278254e-8, (21, 1) = -2.385, (21, 2) = 0.1518573446e-8, (22, 1) = -2.355, (22, 2) = 0.3068757022e-9, (23, 1) = -2.325, (23, 2) = .0, (24, 1) = -2.295, (24, 2) = 0.1566878414e-8, (25, 1) = -2.265, (25, 2) = 0.9501523448e-9, (26, 1) = -2.235, (26, 2) = 0.64024462e-9, (27, 1) = -2.205, (27, 2) = -0.9707752168e-9, (28, 1) = -2.175, (28, 2) = 0.9813817008e-9, (29, 1) = -2.145, (29, 2) = -0.3307303193e-9, (30, 1) = -2.115, (30, 2) = .0, (31, 1) = -2.085, (31, 2) = 0.3381454938e-9, (32, 1) = -2.055, (32, 2) = 0.3419607579e-9, (33, 1) = -2.025, (33, 2) = -0.34584996e-9, (34, 1) = -1.995, (34, 2) = 0.699629479e-9, (35, 1) = -1.965, (35, 2) = -0.1061570257e-8, (36, 1) = -1.935, (36, 2) = -0.7159553365e-9, (37, 1) = -1.905, (37, 2) = .0, (38, 1) = -1.875, (38, 2) = 0.1465851736e-8, (39, 1) = -1.845, (39, 2) = -0.3708306574e-9, (40, 1) = -1.815, (40, 2) = -0.1501136086e-8, (41, 1) = -1.785, (41, 2) = -0.1519298804e-8, (42, 1) = -1.755, (42, 2) = 0.1153363066e-8, (43, 1) = -1.725, (43, 2) = -0.3891746203e-9, (44, 1) = -1.695, (44, 2) = .0, (45, 1) = -1.665, (45, 2) = -0.7977867189999999e-9, (46, 1) = -1.635, (46, 2) = -0.403894909e-9, (47, 1) = -1.605, (47, 2) = -0.817986396e-9, (48, 1) = -1.575, (48, 2) = -0.8283791984e-9, (49, 1) = -1.545, (49, 2) = 0.838970788e-9, (50, 1) = -1.515, (50, 2) = -0.849763516e-9, (51, 1) = -1.485, (51, 2) = 0.4303797414e-9, (52, 1) = -1.455, (52, 2) = -0.4359802505e-9, (53, 1) = -1.425, (53, 2) = 0.441684025e-9, (54, 1) = -1.395, (54, 2) = -0.1342474849e-8, (55, 1) = -1.365, (55, 2) = .0, (56, 1) = -1.335, (56, 2) = 0.4594193414e-9, (57, 1) = -1.305, (57, 2) = .0, (58, 1) = -1.275, (58, 2) = .0, (59, 1) = -1.245, (59, 2) = .0, (60, 1) = -1.215, (60, 2) = -0.4845171333e-9, (61, 1) = -1.185, (61, 2) = -0.9820896064e-9, (62, 1) = -1.155, (62, 2) = 0.4976701943e-9, (63, 1) = -1.125, (63, 2) = 0.5043906598e-9, (64, 1) = -1.095, (64, 2) = -0.511202981e-9, (65, 1) = -1.065, (65, 2) = -0.1036206623e-8, (66, 1) = -1.035, (66, 2) = -0.5250871222e-9, (67, 1) = -1.005, (67, 2) = .0, (68, 1) = -.975, (68, 2) = .0, (69, 1) = -.945, (69, 2) = -0.5464826375e-9, (70, 1) = -.915, (70, 2) = 0.5537393072e-9, (71, 1) = -.885, (71, 2) = .0, (72, 1) = -.855, (72, 2) = .0, (73, 1) = -.825, (73, 2) = -0.575759383e-9, (74, 1) = -.795, (74, 2) = 0.5831459891e-9, (75, 1) = -.765, (75, 2) = .0, (76, 1) = -.735, (76, 2) = 0.2989552486e-9, (77, 1) = -.705, (77, 2) = -0.4842062758000001e-9, (78, 1) = -.675, (78, 2) = 0.245023761e-9, (79, 1) = -.645, (79, 2) = -0.1053654318e-8, (80, 1) = -.615, (80, 2) = -0.6269498139e-9, (81, 1) = -.585, (81, 2) = -0.6339978244e-10, (82, 1) = -.555, (82, 2) = 0.7050102983e-9, (83, 1) = -.525, (83, 2) = 0.1295376709e-9, (84, 1) = -.495, (84, 2) = -0.5234265486e-9, (85, 1) = -.465, (85, 2) = -0.1321355487e-9, (86, 1) = -.435, (86, 2) = 0.4001076823e-9, (87, 1) = -.405, (87, 2) = 0.6727619844e-9, (88, 1) = -.375, (88, 2) = 0.1356797286e-9, (89, 1) = -.345, (89, 2) = 0.1230713041e-8, (90, 1) = -.315, (90, 2) = 0.4132368549e-9, (91, 1) = -.285, (91, 2) = .0, (92, 1) = -.255, (92, 2) = 0.9069144768e-9, (93, 1) = -.225, (93, 2) = 0.4208866866e-9, (94, 1) = -.195, (94, 2) = 0.2114701607e-9, (95, 1) = -.165, (95, 2) = -0.2123623568e-9, (96, 1) = -.135, (96, 2) = .0, (97, 1) = -.105, (97, 2) = 0.7124069349999999e-9, (98, 1) = -0.75e-1, (98, 2) = 0.2498780189e-9, (99, 1) = -0.45e-1, (99, 2) = 0.4647258636e-9, (100, 1) = -0.15e-1, (100, 2) = -0.7154773629e-10, (101, 1) = 0.15e-1, (101, 2) = 0.7154773629e-10, (102, 1) = 0.45e-1, (102, 2) = 0.2502370035e-9, (103, 1) = 0.75e-1, (103, 2) = 0.46405917800000003e-9, (104, 1) = .105, (104, 2) = 0.7124069349999999e-9, (105, 1) = .135, (105, 2) = .0, (106, 1) = .165, (106, 2) = -0.4955121658e-9, (107, 1) = .195, (107, 2) = -0.2114701607e-9, (108, 1) = .225, (108, 2) = 0.2805911245e-9, (109, 1) = .255, (109, 2) = 0.4883385645e-9, (110, 1) = .285, (110, 2) = .0, (111, 1) = .315, (111, 2) = 0.2754912366e-9, (112, 1) = .345, (112, 2) = 0.1367458934e-9, (113, 1) = .375, (113, 2) = 0.5427189143e-9, (114, 1) = .405, (114, 2) = .0, (115, 1) = .435, (115, 2) = 0.2667384549e-9, (116, 1) = .465, (116, 2) = 0.1321355487e-9, (117, 1) = .495, (117, 2) = -0.1308566371e-9, (118, 1) = .525, (118, 2) = 0.5181506837e-9, (119, 1) = .555, (119, 2) = -0.640918453e-10, (120, 1) = .585, (120, 2) = 0.6339978244e-10, (121, 1) = .615, (121, 2) = -0.6269498139e-9, (122, 1) = .645, (122, 2) = -0.1859389974e-9, (123, 1) = .675, (123, 2) = 0.3675356414e-9, (124, 1) = .705, (124, 2) = -0.121051569e-9, (125, 1) = .735, (125, 2) = 0.2989552486e-9, (126, 1) = .765, (126, 2) = .0, (127, 1) = .795, (127, 2) = .0, (128, 1) = .825, (128, 2) = .0, (129, 1) = .855, (129, 2) = -0.5683881417999999e-9, (130, 1) = .885, (130, 2) = .0, (131, 1) = .915, (131, 2) = .0, (132, 1) = .945, (132, 2) = .0, (133, 1) = .975, (133, 2) = -0.5392832926e-9, (134, 1) = 1.005, (134, 2) = -0.5321491408e-9, (135, 1) = 1.035, (135, 2) = -0.5250871222e-9, (136, 1) = 1.065, (136, 2) = .0, (137, 1) = 1.095, (137, 2) = .0, (138, 1) = 1.125, (138, 2) = .0, (139, 1) = 1.155, (139, 2) = .0, (140, 1) = 1.185, (140, 2) = .0, (141, 1) = 1.215, (141, 2) = 0.4845171333e-9, (142, 1) = 1.245, (142, 2) = .0, (143, 1) = 1.275, (143, 2) = -0.4717629839e-9, (144, 1) = 1.305, (144, 2) = .0, (145, 1) = 1.335, (145, 2) = -0.4594193414e-9, (146, 1) = 1.365, (146, 2) = .0, (147, 1) = 1.395, (147, 2) = 0.4474916162e-9, (148, 1) = 1.425, (148, 2) = -0.441684025e-9, (149, 1) = 1.455, (149, 2) = .0, (150, 1) = 1.485, (150, 2) = 0.4303797414e-9, (151, 1) = 1.515, (151, 2) = .0, (152, 1) = 1.545, (152, 2) = .0, (153, 1) = 1.575, (153, 2) = .0, (154, 1) = 1.605, (154, 2) = .0, (155, 1) = 1.635, (155, 2) = 0.403894909e-9, (156, 1) = 1.665, (156, 2) = 0.1196680078e-8, (157, 1) = 1.695, (157, 2) = 0.1181961302e-8, (158, 1) = 1.725, (158, 2) = .0, (159, 1) = 1.755, (159, 2) = 0.3844543552e-9, (160, 1) = 1.785, (160, 2) = 0.379824701e-9, (161, 1) = 1.815, (161, 2) = 0.7505680427e-9, (162, 1) = 1.845, (162, 2) = 0.3708306574e-9, (163, 1) = 1.875, (163, 2) = -0.7329258677999999e-9, (164, 1) = 1.905, (164, 2) = 0.3621791667e-9, (165, 1) = 1.935, (165, 2) = -0.7159553365e-9, (166, 1) = 1.965, (166, 2) = -0.3538567523e-9, (167, 1) = 1.995, (167, 2) = 0.1049444218e-8, (168, 1) = 2.025, (168, 2) = 0.6916999200000001e-9, (169, 1) = 2.055, (169, 2) = -0.1367843032e-8, (170, 1) = 2.085, (170, 2) = -0.6762909876999999e-9, (171, 1) = 2.115, (171, 2) = .0, (172, 1) = 2.145, (172, 2) = 0.9921909576e-9, (173, 1) = 2.175, (173, 2) = 0.3271272336e-9, (174, 1) = 2.205, (174, 2) = -0.9707752168e-9, (175, 1) = 2.235, (175, 2) = 0.9603669296e-9, (176, 1) = 2.265, (176, 2) = .0, (177, 1) = 2.295, (177, 2) = -0.1566878414e-8, (178, 1) = 2.325, (178, 2) = -0.310095572e-9, (179, 1) = 2.355, (179, 2) = -0.9206271064e-9, (180, 1) = 2.385, (180, 2) = -0.1822288135e-8, (181, 1) = 2.415, (181, 2) = 0.3006111791e-9, (182, 1) = 2.445, (182, 2) = .0, (183, 1) = 2.475, (183, 2) = -0.1178285585e-8, (184, 1) = 2.505, (184, 2) = -0.1458162811e-8, (185, 1) = 2.535, (185, 2) = -0.577492216e-9, (186, 1) = 2.565, (186, 2) = 0.5718216517e-9, (187, 1) = 2.595, (187, 2) = 0.2831255369e-9, (188, 1) = 2.625, (188, 2) = -0.1121556363e-8, (189, 1) = 2.655, (189, 2) = 0.8331010952e-9, (190, 1) = 2.685, (190, 2) = -0.1100233059e-8, (191, 1) = 2.715, (191, 2) = 0.136230861e-8, (192, 1) = 2.745, (192, 2) = .0, (193, 1) = 2.775, (193, 2) = -0.2674011717e-9, (194, 1) = 2.805, (194, 2) = 0.1059740639e-8, (195, 1) = 2.835, (195, 2) = -0.1575064175e-8, (196, 1) = 2.865, (196, 2) = -0.7803805221999999e-9, (197, 1) = 2.895, (197, 2) = 0.1031130714e-8, (198, 1) = 2.925, (198, 2) = 0.2554773171e-9, (199, 1) = 2.955, (199, 2) = -0.7596296626e-9, (200, 1) = 2.985, (200, 2) = .0}, datatype = float[8]), COLOUR(RGB, .47058824, 0., 0.54901961e-1, _ATTRIBUTE("source" = "mathdefault"))), AXESLABELS(x, ""), VIEW(-3. .. 3., DEFAULT, _ATTRIBUTE("source" = "mathdefault")), _ATTRIBUTE("input" = [TABLE([1 = plot, 2 = [.8000000000*(-1.875-1.5*x^2+(2.8125+3.25*x^2-3.0*x*(x^2+1.25)^(1/2))^(1/2)*(x^2+1.25)^(1/2)+x*(x^2+1.25)^(1/2))/(x^2+1.25)^(1/2)], 3 = (x = -3 .. 3)]), "originalview" = [-2.98499999999999988 .. 2.98499999999999988, -0.222160292000000004e-8 .. 0.202567910000000010e-8], "originalaxesticks" = AXESTICKS(DEFAULT, DEFAULT, _ATTRIBUTE("source" = "mathdefault"))])), INTERFACE_PLOT(CURVES(Matrix(200, 2, {(1, 1) = -2.985, (1, 2) = 2.874025883, (2, 1) = -2.955, (2, 2) = 2.854642282, (3, 1) = -2.925, (3, 2) = 2.835344303, (4, 1) = -2.895, (4, 2) = 2.816134266, (5, 1) = -2.865, (5, 2) = 2.797014562, (6, 1) = -2.835, (6, 2) = 2.777987691, (7, 1) = -2.805, (7, 2) = 2.759056232, (8, 1) = -2.775, (8, 2) = 2.740222835, (9, 1) = -2.745, (9, 2) = 2.721490283, (10, 1) = -2.715, (10, 2) = 2.70286143, (11, 1) = -2.685, (11, 2) = 2.684339246, (12, 1) = -2.655, (12, 2) = 2.665926815, (13, 1) = -2.625, (13, 2) = 2.647627325, (14, 1) = -2.595, (14, 2) = 2.629444093, (15, 1) = -2.565, (15, 2) = 2.611380555, (16, 1) = -2.535, (16, 2) = 2.593440278, (17, 1) = -2.505, (17, 2) = 2.575626962, (18, 1) = -2.475, (18, 2) = 2.55794446, (19, 1) = -2.445, (19, 2) = 2.540396764, (20, 1) = -2.415, (20, 2) = 2.522988022, (21, 1) = -2.385, (21, 2) = 2.505722547, (22, 1) = -2.355, (22, 2) = 2.48860483, (23, 1) = -2.325, (23, 2) = 2.471639524, (24, 1) = -2.295, (24, 2) = 2.454831479, (25, 1) = -2.265, (25, 2) = 2.438185742, (26, 1) = -2.235, (26, 2) = 2.421707563, (27, 1) = -2.205, (27, 2) = 2.405402393, (28, 1) = -2.175, (28, 2) = 2.389275933, (29, 1) = -2.145, (29, 2) = 2.373334099, (30, 1) = -2.115, (30, 2) = 2.357583056, (31, 1) = -2.085, (31, 2) = 2.342029234, (32, 1) = -2.055, (32, 2) = 2.32667933, (33, 1) = -2.025, (33, 2) = 2.311540327, (34, 1) = -1.995, (34, 2) = 2.296619498, (35, 1) = -1.965, (35, 2) = 2.281924438, (36, 1) = -1.935, (36, 2) = 2.267463062, (37, 1) = -1.905, (37, 2) = 2.253243627, (38, 1) = -1.875, (38, 2) = 2.239274757, (39, 1) = -1.845, (39, 2) = 2.22556545, (40, 1) = -1.815, (40, 2) = 2.212125097, (41, 1) = -1.785, (41, 2) = 2.198963502, (42, 1) = -1.755, (42, 2) = 2.186090908, (43, 1) = -1.725, (43, 2) = 2.173518014, (44, 1) = -1.695, (44, 2) = 2.161255996, (45, 1) = -1.665, (45, 2) = 2.14931653, (46, 1) = -1.635, (46, 2) = 2.137711814, (47, 1) = -1.605, (47, 2) = 2.126454602, (48, 1) = -1.575, (48, 2) = 2.115558219, (49, 1) = -1.545, (49, 2) = 2.105036595, (50, 1) = -1.515, (50, 2) = 2.094904293, (51, 1) = -1.485, (51, 2) = 2.085176526, (52, 1) = -1.455, (52, 2) = 2.075869209, (53, 1) = -1.425, (53, 2) = 2.066998963, (54, 1) = -1.395, (54, 2) = 2.058583179, (55, 1) = -1.365, (55, 2) = 2.050640008, (56, 1) = -1.335, (56, 2) = 2.043188437, (57, 1) = -1.305, (57, 2) = 2.036248294, (58, 1) = -1.275, (58, 2) = 2.029840291, (59, 1) = -1.245, (59, 2) = 2.023986056, (60, 1) = -1.215, (60, 2) = 2.018708166, (61, 1) = -1.185, (61, 2) = 2.014030179, (62, 1) = -1.155, (62, 2) = 2.009976672, (63, 1) = -1.125, (63, 2) = 2.006573261, (64, 1) = -1.095, (64, 2) = 2.003846642, (65, 1) = -1.065, (65, 2) = 2.001824606, (66, 1) = -1.035, (66, 2) = 2.000536066, (67, 1) = -1.005, (67, 2) = 2.000011085, (68, 1) = -.975, (68, 2) = 2.000280886, (69, 1) = -.945, (69, 2) = 2.001377862, (70, 1) = -.915, (70, 2) = 2.003335576, (71, 1) = -.885, (71, 2) = 2.006188774, (72, 1) = -.855, (72, 2) = 2.009973355, (73, 1) = -.825, (73, 2) = 2.014726377, (74, 1) = -.795, (74, 2) = 2.02048599, (75, 1) = -.765, (75, 2) = 2.027291436, (76, 1) = -.735, (76, 2) = 2.03518296, (77, 1) = -.705, (77, 2) = 2.044201758, (78, 1) = -.675, (78, 2) = 2.054389892, (79, 1) = -.645, (79, 2) = 2.065790181, (80, 1) = -.615, (80, 2) = 2.078446082, (81, 1) = -.585, (81, 2) = 2.092401558, (82, 1) = -.555, (82, 2) = 2.107700918, (83, 1) = -.525, (83, 2) = 2.124388638, (84, 1) = -.495, (84, 2) = 2.142509158, (85, 1) = -.465, (85, 2) = 2.162106674, (86, 1) = -.435, (86, 2) = 2.183224896, (87, 1) = -.405, (87, 2) = 2.205906795, (88, 1) = -.375, (88, 2) = 2.230194338, (89, 1) = -.345, (89, 2) = 2.256128202, (90, 1) = -.315, (90, 2) = 2.283747478, (91, 1) = -.285, (91, 2) = 2.313089382, (92, 1) = -.255, (92, 2) = 2.344188946, (93, 1) = -.225, (93, 2) = 2.377078735, (94, 1) = -.195, (94, 2) = 2.411788538, (95, 1) = -.165, (95, 2) = 2.448345111, (96, 1) = -.135, (96, 2) = 2.48677191, (97, 1) = -.105, (97, 2) = 2.527088866, (98, 1) = -0.75e-1, (98, 2) = 2.569312178, (99, 1) = -0.45e-1, (99, 2) = 2.613454152, (100, 1) = -0.15e-1, (100, 2) = 2.659523058, (101, 1) = 0.15e-1, (101, 2) = 2.707523058, (102, 1) = 0.45e-1, (102, 2) = 2.757454151, (103, 1) = 0.75e-1, (103, 2) = 2.809312179, (104, 1) = .105, (104, 2) = 2.863088866, (105, 1) = .135, (105, 2) = 2.91877191, (106, 1) = .165, (106, 2) = 2.97634511, (107, 1) = .195, (107, 2) = 3.035788538, (108, 1) = .225, (108, 2) = 3.097078734, (109, 1) = .255, (109, 2) = 3.160188947, (110, 1) = .285, (110, 2) = 3.225089382, (111, 1) = .315, (111, 2) = 3.291747478, (112, 1) = .345, (112, 2) = 3.360128202, (113, 1) = .375, (113, 2) = 3.430194338, (114, 1) = .405, (114, 2) = 3.501906796, (115, 1) = .435, (115, 2) = 3.575224895, (116, 1) = .465, (116, 2) = 3.650106674, (117, 1) = .495, (117, 2) = 3.726509158, (118, 1) = .525, (118, 2) = 3.804388638, (119, 1) = .555, (119, 2) = 3.883700919, (120, 1) = .585, (120, 2) = 3.964401558, (121, 1) = .615, (121, 2) = 4.046446082, (122, 1) = .645, (122, 2) = 4.12979018, (123, 1) = .675, (123, 2) = 4.214389893, (124, 1) = .705, (124, 2) = 4.300201758, (125, 1) = .735, (125, 2) = 4.38718296, (126, 1) = .765, (126, 2) = 4.475291435, (127, 1) = .795, (127, 2) = 4.564485991, (128, 1) = .825, (128, 2) = 4.654726375, (129, 1) = .855, (129, 2) = 4.7459733570000004, (130, 1) = .885, (130, 2) = 4.838188773, (131, 1) = .915, (131, 2) = 4.931335578, (132, 1) = .945, (132, 2) = 5.025377862, (133, 1) = .975, (133, 2) = 5.120280888, (134, 1) = 1.005, (134, 2) = 5.216011086, (135, 1) = 1.035, (135, 2) = 5.312536068, (136, 1) = 1.065, (136, 2) = 5.4098246020000005, (137, 1) = 1.095, (137, 2) = 5.5078466420000005, (138, 1) = 1.125, (138, 2) = 5.606573264, (139, 1) = 1.155, (139, 2) = 5.705976674, (140, 1) = 1.185, (140, 2) = 5.806030179, (141, 1) = 1.215, (141, 2) = 5.906708166, (142, 1) = 1.245, (142, 2) = 6.007986059, (143, 1) = 1.275, (143, 2) = 6.109840297, (144, 1) = 1.305, (144, 2) = 6.212248294, (145, 1) = 1.335, (145, 2) = 6.315188439, (146, 1) = 1.365, (146, 2) = 6.418640003, (147, 1) = 1.395, (147, 2) = 6.522583178, (148, 1) = 1.425, (148, 2) = 6.6269989670000005, (149, 1) = 1.455, (149, 2) = 6.731869210999999, (150, 1) = 1.485, (150, 2) = 6.837176529, (151, 1) = 1.515, (151, 2) = 6.9429042889999995, (152, 1) = 1.545, (152, 2) = 7.049036596, (153, 1) = 1.575, (153, 2) = 7.1555582189999996, (154, 1) = 1.605, (154, 2) = 7.262454599, (155, 1) = 1.635, (155, 2) = 7.369711812, (156, 1) = 1.665, (156, 2) = 7.477316527999999, (157, 1) = 1.695, (157, 2) = 7.585255997, (158, 1) = 1.725, (158, 2) = 7.693518013, (159, 1) = 1.755, (159, 2) = 7.80209091, (160, 1) = 1.785, (160, 2) = 7.910963498999999, (161, 1) = 1.815, (161, 2) = 8.020125096, (162, 1) = 1.845, (162, 2) = 8.129565448, (163, 1) = 1.875, (163, 2) = 8.23927476, (164, 1) = 1.905, (164, 2) = 8.349243624, (165, 1) = 1.935, (165, 2) = 8.459463056, (166, 1) = 1.965, (166, 2) = 8.569924432, (167, 1) = 1.995, (167, 2) = 8.680619504, (168, 1) = 2.025, (168, 2) = 8.791540328, (169, 1) = 2.055, (169, 2) = 8.902679336, (170, 1) = 2.085, (170, 2) = 9.01402924, (171, 1) = 2.115, (171, 2) = 9.125583056, (172, 1) = 2.145, (172, 2) = 9.237334096, (173, 1) = 2.175, (173, 2) = 9.349275936, (174, 1) = 2.205, (174, 2) = 9.461402392, (175, 1) = 2.235, (175, 2) = 9.57370756, (176, 1) = 2.265, (176, 2) = 9.686185744, (177, 1) = 2.295, (177, 2) = 9.798831488, (178, 1) = 2.325, (178, 2) = 9.911639528, (179, 1) = 2.355, (179, 2) = 10.02460483, (180, 1) = 2.385, (180, 2) = 10.13772255, (181, 1) = 2.415, (181, 2) = 10.25098802, (182, 1) = 2.445, (182, 2) = 10.36439676, (183, 1) = 2.475, (183, 2) = 10.47794446, (184, 1) = 2.505, (184, 2) = 10.59162697, (185, 1) = 2.535, (185, 2) = 10.70544028, (186, 1) = 2.565, (186, 2) = 10.81938056, (187, 1) = 2.595, (187, 2) = 10.9334441, (188, 1) = 2.625, (188, 2) = 11.04762733, (189, 1) = 2.655, (189, 2) = 11.16192682, (190, 1) = 2.685, (190, 2) = 11.27633925, (191, 1) = 2.715, (191, 2) = 11.39086143, (192, 1) = 2.745, (192, 2) = 11.50549028, (193, 1) = 2.775, (193, 2) = 11.62022284, (194, 1) = 2.805, (194, 2) = 11.73505623, (195, 1) = 2.835, (195, 2) = 11.8499877, (196, 1) = 2.865, (196, 2) = 11.96501457, (197, 1) = 2.895, (197, 2) = 12.08013426, (198, 1) = 2.925, (198, 2) = 12.1953443, (199, 1) = 2.955, (199, 2) = 12.31064228, (200, 1) = 2.985, (200, 2) = 12.42602588}, datatype = float[8]), COLOUR(RGB, .47058824, 0., 0.54901961e-1, _ATTRIBUTE("source" = "mathdefault"))), AXESLABELS(x, ""), VIEW(-3. .. 3., DEFAULT, _ATTRIBUTE("source" = "mathdefault")), _ATTRIBUTE("input" = [TABLE([1 = plot, 2 = [.8000000000*(1.875+1.5*x^2+(2.8125+3.25*x^2+3.0*x*(x^2+1.25)^(1/2))^(1/2)*(x^2+1.25)^(1/2)+x*(x^2+1.25)^(1/2))/(x^2+1.25)^(1/2)], 3 = (x = -3 .. 3)]), "originalview" = [-2.98499999999999988 .. 2.98499999999999988, 2.00001108500000013 .. 12.4260258799999992], "originalaxesticks" = AXESTICKS(DEFAULT, DEFAULT, _ATTRIBUTE("source" = "mathdefault"))]))]
Download which_ode_to_verify_against_V2.mw
For some reason the plots do not display above (may be because they are in list). Here is screen shot
The best way to solving such ode's is to avoid squaring the ode in the first place. Sometimes this is possible, but not in this example. At least I could not find a way using some change of variables to avoid squaring it.
