Question: How to do Parameter setting?
The attached sheet contains equations H1 to H6 and K1 to K3. What data do I need to modify to ensure that the values of H1 to H6 fall between 0 and 1, and K1 to K3 are negative? The parameter ranges are also given in the sheet. Is there a method to achieve this?
rouhg.mw
