Question: how to obtain the plot command used after updating plot in GUI options?
This is probably asked before but can't find it.
After making a plot, then RIGHT-CLICKing on it, option menu comes up that allows one to modify the plot (like adding gridlines, or change the line style).
How does one find the Maple command after doing such changes, so one can use the command in the code?
Here is an example. I modified a little acers plot in this answer and added the points to the plot
eq:=-0.0004*x^2 - 2.7680*10^(-28)*x^12 - 2.1685*10^(-43)*x^18 - 1.3245*10^(-37)*x^16 - 1.6917*10^(-32)*x^14 + 0.7650 + 6.6773*10^(-18)*x^8 - 2.5543*10^(-23)*x^10 - 8.0002*10^(-13)*x^6 + 3.6079*10^(-8)*x^4 = 0:
the_roots:=fsolve(eq):
the_roots:=map(X->[X,0],[the_roots]):
p1:=plot(lhs(eq),x=-210..210,size=[500,200]):
p2:=plot(the_roots,style=point, color=red, symbol=solidcircle, symbolsize=20):
plots:-display(p1,p2)
I was lazy to look up the grid option syntax. So right clicked on the plot and found option to add gridline. So said, great. And the above is the result.
But now I'd like to see the command used so I know where the grid option goes and how its syntax is. There does not seem to be option in the interface to display the Maple command used.
How would one find it?
Maple 2024.1 on windows 10
