Question: Error, (in …) integer overflow detected in compiled code
Recently, I read an old article about how to call external subroutines to speed up the evaluation tremendously. The core of that article is:
Evidently, the Typesetting:-mrow(Typesetting:-mi( is equivalent to irem(a, b) when b>0, and the `∸`(a, b) is equivalent to max(a - b, 0)
The 𝙲 code in that article was composed separately. However, now that it is possible to generate external functions, compile and access them using a single Compiler:-Compile command, it is better to complete the entire process on the fly (in order to reduce oversights and typographical errors while coding). (Besides, the original π™ΌπšŠπš™πš•πšŽ implementation appears verbose and less elegant.) So I write:
JonesM1 := Compiler:-Compile((n::posint) -> add(max(1 - max(add(ifelse(j = 0, max(j - 1, 0)!**2, irem(max(j - 1, 0)!**2, j)), j = 0 .. i) - n, 0), 0), i = 0 .. n**2), 'O' = 2): # literal translation of the above formula
But unfortunately, I then get:
JonesM1(1);
                               2
JonesM1(2);
                               3
JonesM1(3);
                               5
JonesM1(4);
Error, (in JonesM1) integer overflow detected in compiled code
How do I get rid of this error message?
Note. Of course there exist a ready-to-use built-in function ithprime, but the chief aim is not to find the n-th prime number as quickly as possible; I want to see if π™ΌπšŠπš™πš•πšŽ can directly create a compiled version of the one-liner that implements the so-called Jones' algorithm instead of writing separate 𝙲 code like that article. (Don't confound the means with the ends.)
ο»Ώ
