Question: Cannot insert nummeric value of variable assumed real
Hi
I have a problem with an assumed real variable that are not inserted into equations if it is given an nummeric value. I have tried to make and example below:
> restart;
> with(plottools);
> with(linalg);
>with(plots);
> assume(theta, real);
>A := e^(I*theta)
... alot of other stuff
>theta := 0
>A             # here is the problem
                                           e^(I*theta~)
>A:= e^(I*theta)          # but if i define the equation after setting theta = 0 it does what it is told
                                          A := e^(I*0)
If Ido not assume theta real the problem is not there. Does anyone know what the problem is?
Thanks in advance.
regards Brian Bak
