Question: confused about a differentiation
I am having a problem differentiating a function. I have a fluid in a channel with moving walls corresponding to y=a(t) (upper wall) and y=-a(t) (lower wall). The fluid is driven by suction out of the walls. The speed of the fluid being sucked out of the walls is the constant v_w. I am using the variable eta=y/a(t) to model the fluid. y is the normal direction to teh channel and x is the streamwise direction of the channel. So I have
x=streamwise direction of the channel
y=normal direction of the channel
a(t)=height of the channel
v_w=constant
t=time
eta=y/a(t) is the similarity variable
u=streamwise velocity
Xi=-v_w*x*F(eta,t)/(a(t)^2)
I want top partially differentiate Xi with respect to t.
I am confused as a(t) depends on t, eta depends on a(t) which in turn depends on t and F depends on t. What would i write on maple to get the correct differentiation?
