Question: Problem with integration when computing power series sum
Hello
I have a problem with Maple. I would like to compute following sum using differentiation:
an:=x^(4*n-3)/(4*n-3)
This power series is convergent for x in (-1,1).
Sum(an,n=1..infinity);
diff(%,x);
s1:=value(%);
pf:=convert(s1,parfrac);
Now when integrating:
subs(x=t,pf);
int(%,t);
the result is: 1/2*arctan(t)-1/4*ln(t-1)+1/4*ln(t+1) .
The problem is that ln(t-1) is not defined for t in (-1,1). This is caused by integration of the equation:
-1/4/(t-1)
which is
-1/4*ln(t-1)
But if I would integrate the equation in the following form:
1/4*(1/(1-t))
then the result of int(%,t); is
-1/4*ln(1-t)
which is defined for t in (-1,1).
So how can I deal with this? How can I force Maple to use the form 1/4*(1/(1-t)) instead of  -1/4/(t-1) without having to rewrite it manually?
Thank you.
