Question: Chopped off plot using geometry,draw
When I use the labelling facility in the geometry package, the plot area does not include all of the drawing. For example, in the code below the word "top" at the top of the circle is cut off. restart;with(geometry):with(plots): point(top,0,1):point(bottom,0,-1): circle(c,[top,bottom]): draw([c,top,bottom],printtext=true,axes=none); I see it if I have axes, but I want to use axes=none. It seems like a bug. A couple of workarounds failed to solve the problem. I added the view option to draw: draw([c,top,bottom],printtext=true,axes=none,view=[-5..5,-5..5]); expecting to see a smaller circle. Instead the circle appears the same size, still with the word "top" chopped off. Surprisingly, the points are drawn in LARGER symbols! So I thought that using the view option in display might override that internal options that draw uses: display(draw([c,top,bottom],printtext=true,axes=none),view=[-5..5,-5..5]); but this give the same as the previous result. Dragging the box around the plot after the fact works, but it would be nice to get it done in code. Any suggestions? Thanks, David.
