Question: Live Output in text?
In the file I just uploaded, Georgeworksheet14.mw, the final statement is a text statement which has had two matrices copied into it. These matrices were copied from the output of equation 3). Is there any way I could make this 'live'. In other words, is there any way I could make it so that the matrices displayed in the last statement would change if the output of statement 3 changed? Also, I was forced to put the statements about the ZZZ matrices at the bottom of the worksheet because when you click the T (text) button, a new document block is always created at the bottom of the file. If I had wanted to put the statement about the ZZZ matrices right under equation 3), is there a way to have done this?
