Question: Uploading Images
Hello, I wonder if someone could help me understand the best way to insert images into a MAPLE worksheet. I am using TURBOCAD to create diagrams. When I was using MATHCAD I could select any area of the TURBOCAD worksheet, copy it, go into a MATHCAD worksheet and paste. While this proceedure has some problems, in general I could work around them and it worked pretty well. I have tried the same thing in MAPLE and it doesn't work very well, as indicated by the worksheet I have uploaded with this post, 'GeorgeWorksheet1'. What seems to be happening is that I get an extremely low-res copy which is useless. So I tried another approach. TURBOCAD has the ability to save a JPEG image of a worksheet, so I saved my TURBOCAD worksheet as 'F1.jpg' (which I have also uploaded). I then insert this file into a MAPLE worksheet using the using the Insert/Image command. This is the second image in my MAPLE uploaded worksheet, 'GeorgeWorksheet1'.This works better, but the image takes up alot of space on the MAPLE worksheet. The problem is, when I try to contract this image by clicking on it and grabbing the little thingies on the side of the frame and moving them, I am able to decrease the size of the image but in doing so I loose so much resolution as to make the image useless. Any suggestions as to how to get a diagram from TURBOCAD to MAPLE and have the diagram not take up the entire width of the page but still have good resolution would be greatly appreciated.
