Question: A Procedure with process launch
Hello, I'm trying to make a wrapper procedure that will launch an external program with some dynamic arguments. To do this I created a proc and used the launch command from the process package. My procedure seems to be syntactically correct, but when I run it all it does is echo the procedure code. Since nothing was working I have created a simplified procedure that simply tries to launch Notepad. Instead of launching notepad it just echos out the source of the procedure: My definition of the procedure RunNotepad: > RunNotepad() := proc() > use process in > launch("notepad.exe"); > end use; > end proc; RunNotepad() := proc() (process:-launch)("notepad.exe") end proc; Trying to call it: > RunNotepad(); proc() (process:-launch)("notepad.exe") end proc; Can Launch be called from inside a procedure? Am I doing something wrong here? Thanks any help that you can provide, ricky
