Question: Grading code not simplifying properly... Help!
Hi,
I've recently started creating questions using MapleTA, and at the moment I've hit a stumbling block.
For a particular question, the students need to enter a formula. When I input the answer in decimal form, the question is graded correctly; when I put it in fractional form, it's not. I've used the simplify command in every perturbation I know, but I can't get it to work.
More details:
Algorithm
$a = rint(3,10)
condition:not(eq($a,0))
$b = $a/2*rint(-7,7)
condition:not(eq($b,0))
condition:not(eq($b,1))
condition:not(eq($b,$a))
condition:not(eq($b,-$a))
$re = maple("MathML[ExportPresentation]( ($a*(X[n]))+($b*(X[n-1])) = 0)")
$s = -$b/$a
Question:
Consider the recursion formula $re.
Give the general solution Xn=Edit where A is an arbitrary constant.
Solution box has:
Answer: (A)*($s)^n
and I've also tried
Answer: simplify((A)*($s)^n);
I've tried the following grading codes:
is($ANSWER-RESPONSE=0);
is(simplify($ANSWER)-simplify($RESPONSE)=0);
...and others like that, in different combinations.
Without fail, if $s is not an integer, then an otherwise correct answer expressed as a fraction is marked wrong.
Please help!
-A
