Example of Duffing equation with boundary conditions.
y'' + 0.2y' + y^3 - 0.3cos(s) = 0;
y(0) = y (2Pi);
y'(0) = y'(2Pi);
For convenience, we replace the original equation with a system of two first order equations:
x1'(t) = 2*Pi*x2(t);
x2'(t) = - 0.4*Pi*x2(t) - 2*Pi*x1(t)^3 +0.6*Pi*cos(2*Pi*t);
x1(0) = x1(1);
x2(0) = x2(1);
I have long wanted to apply an optimization package to solve a boundary value problem for ODE. The decision helped procedure for solving ODE, written by forum member vv.
It seems to me that two solutions have been found and that the solutions are weakly sensitive to the initial approximations. These are two closed trajectories. For example, these are points that belong to these solutions:
(0.5966963,  1.0482816) , ( - 0.3132584, 0.0664941).
I am wondering: are the solutions right, and how justified is the use of optimization methods for such tasks?
At the end of the program, the solution is checked on the original Duffing equation using standard Maple functions.   Duffing_equation_BC.mw
(In the figures, the trajectory bypass occurs three times.)
If worksheet execution was started and computer is locked before execution ends, Maple will stop responding and all work is lost. Execution of whole worksheet takes very long time, sometimes over 3 hours, so "do not lock computer during execution" is not solving the problem.
What are the most efficient way to write and evaluate a procedure in maple? Thank you.
I have made a document to give the results for a problem in table form and graph form.
The tables work out well. The graph results also come out well when I have that section alone in the document. But it does not give the updated curve here. Please correct me where I made mistake.
Cost in $:
Present Value:
Interest in % per year:         ``
 Period in years:
Additional Months
Principal $
Interest % per year
Year
Present value at the year end
4
UpdateExpr procedure does not update equation, instead turns out a value on LHS
Cost:
Interest % per year (float)
Startup Code Region contains all the codes.
Download Doubt_x_symbolic_required.mw
I use MapleSim to model the dynamics of motorcycles.
I have been at MapleSim2018 for a few months and I have a problem of simplifying the equations generated by MapleSim from my model.
In MapleSim2018, he tells me:
Processing Equations...
SelectCompiler: Check for installed compiler successful
Simplifying system with 8919 equations
DSN/ix1lite: Warning, equation size increased past 100000 while performing equation simplification. Model will be simulated in partially unsimplified form
Simplification removed 8428 equations. Remaining equations: 491
Generating simulation code
the same model (exactly the same) in MapleSim2016, he tells me :
Simplifying system with 8942 equations
Simplification removed 8494 equations. Remaining equations: 448
When I generate code from two versions of Maple (2016 and 2018) and compile it into an executable, the MapleSim 2018 executable runs 20% slower than the MapleSim 2016 version of the executable (the results and the behavior of both models are equivalent)
It is very strange that a new version of MapleSim generates a slower code than the old version. it may be due to the limitation of DSN / ix1lite in MapleSim2018 ... while MapleSim2016 does not have this limitation (with more equations to simplify!).
I need help, if it is possible to activate the complete simplification in DSN / ix1lite?
it is a big problem for me, the use of MapleSim2018 is not possible because of that. My model does not pass in real time.
thanks.
Hello every one,
My slideshow now contains a lot of animation sequences and take
a very long time to load and a large amount of physical memory (>20GB).
To reduce this size I have decided to convert these animations to GIF format.
Unfortunatly Maple/MaplePayer do not play GIF animations.
I decide to put URLs (image icons pointing to GIF files) in the document.
Now the GIF are play by a WEB browser (program to operate in fullscreen
mode to minimize any disturbance in the audience with IE11).
Now the issue:
Using F11 to start the Slideshow, cliking the URL start the browser with the requested
animated GIF, that is fine, but now Maple/MaplePayer both auto-exit fullscreen
mode just after that click. The speaker (me) now need to manage the return to
fullscreen (F11) at the current slide while
thinking about what i have to
say next.
Is there any trick to prevent auto-exit from fulls-screen mode in this situation?
Thank you for your help
LL
Des suggestions de solutions? Merci.
A) a) Écrire une procédure qui produit une itération du calcul babylonien de la racine carrée d'un nombre positif k à partir     d'une première approximation x0 .
    Entrée: k , x0 .
    Sortie:  x1 = (x0+ k/x0)/2 .
b) En utilisant la procédure trouvée en a), en écrire une autre, qui prend en entrée un entier positif n en plus des entiers k   et x0 vus en a) et qui retourne en sortie n itérations du calcul babylonien de la racine carée de k.
 B)
Écrire une procédure récursive Maple qui prend en entrée deux nombres n et k et qui utilise l'identité (n k) = (n -1k)+(n-1 k-1) pour retourner en sortie le coefficient binomial (n k) , cette procédure ne doit pas utiliser la commande Maple binomial.
TRADUCTION:
Suggestions for solutions? Thank you.
A) a) Write a procedure that produces an iteration of the Babylonian calculus of the square root of a positive number k from a     first approximation x0.
    Input: k, x0.
   Output: x1 = (x0 + k / x0) / 2.
b) Using the procedure found in a), write another one, which takes as input a positive integer n in addition to the integers k and   x0 seen in a) and which returns in exit n iterations of the Babylonian calculation of the square root of k.
B) Write a Maple recursive procedure that takes as input two numbers n and k and uses the identity (n k) = (n-1 k)+ (n-1 k-1) to   return the binomial coefficient (n k), this procedure should not use the binomial Maple command.
Hi , how we can read the fractional differential equations in maple with out solving . I means just read and determine which is the order of fractional differential equations.
Hello everyone!
In previous versions of Maple (e.g. Maple 2016) it used to be possible to use scaletorange and colorscheme options together as in:
densityplot(sin(x+y), x = -1 .. 1, y = -1 .. 1, colorscheme = [black, red, yellow, white], scaletorange = -.5 .. .5);
But Maple 2018 returns an error:
Error, (in plots/densityplot) the scaletorange option cannot be used with the colorscheme option
Why is that and can one work around this error in any simple way?
I need an example programme please help me i m beginner
Hello there,
I have created a MAPLE document in a slideshow format.
Is there a way to print a copy of my presentation with header and footer included and in a format that fits on letter format paper or pdf.
LL
I understand that Maple 2018 is now able to solve 3 independent variable PDE & BC problems in bounded domains through separation of variables by product and eigenfunction expansion.
My solution domain is (x,y,t), (i.e three independent variables) but I would like to need to use numerical integration.  Are there plans to make numerical integration for PDEs with three independent availables, and if so when is that facility likely to be available?
Melvin
How I can perform integration by parts, with respect to the x[0..1],y[0..1],t
PART.mw
U := (1/2)*(E*(diff(u(x, y), x)-z*(diff(w(x, y), x, x))+(1/2)*(diff(w(x, y), x))^2)/(-upsilon^2+1)+E*upsilon*(diff(v(x, y), y)-z*(diff(w(x, y), y, y))+(1/2)*(diff(w(x, y), y))^2)/(-upsilon^2+1))*(diff(u(x, y), x)-z*(diff(w(x, y), x, x))+(1/2)*(diff(w(x, y), x))^2)+(1/2)*(E*upsilon*(diff(u(x, y), x)-z*(diff(w(x, y), x, x))+(1/2)*(diff(w(x, y), x))^2)/(-upsilon^2+1)+E*(diff(v(x, y), y)-z*(diff(w(x, y), y, y))+(1/2)*(diff(w(x, y), y))^2)/(-upsilon^2+1))*(diff(v(x, y), y)-z*(diff(w(x, y), y, y))+(1/2)*(diff(w(x, y), y))^2)+E*(1-upsilon)*((1/2)*(diff(v(x, y), x))-z*(diff(w(x, y), x, y))+(1/2)*(diff(u(x, y), y))+(1/2)*(diff(w(x, y), x))*(diff(w(x, y), y)))^2/(-upsilon^2+1)+2*E*l^2*(diff(w(x, y), x, y))^2/(2+2*upsilon)+2*E*l^2*(-(1/2)*(diff(w(x, y), x, x))+(1/2)*(diff(w(x, y), y, y)))^2/(2+2*upsilon)+2*E*l^2*((1/4)*(diff(v(x, y), x, x))-(1/4)*(diff(u(x, y), x, y)))^2/(2+2*upsilon)+2*E*l^2*((1/4)*(diff(v(x, y), x, y))-(1/4)*(diff(u(x, y), y, y)))^2/(2+2*upsilon)
with(IntegrationTools)
Download PART.mw
 1)  Copy/paste problem .
 Looks like Maple is not able to copy/paste the output
 from a summation command . Look at my example .
 I have to use the  " lprint " command .
2)   Mysterious small box character .
 Suppose I want to edit a command . I want to replace a character with a left bracket
 (or right bracket or left accolade but strangely not the right accolade).
 I put the cursor on the character and type the left bracket (or right...) .
 The left bracket ( or right ...)  is inserted . Now when I try to delete the character,
 a small box appear . The  character I am trying to delete is shifting to the right .
  Like  I said , just a little annoying .
3)  Open file problem .
 The first file I open in Maple with the  ctrl-o command , the "open file window" appears in
  the center of the screen . All the others files I am opening , the "open file window"  show up
  in the bottom left corner , top center or top right corner ... randomly .
  Very annoying on a 27" screen . For this last one ,I am not shure  if it is a Maple 2018 problem
   or a Windows 10 64 bits problem . I have few programs in my computer .
  When I use Microsoft Paint or Wordpad ,I don't see this problem .
  I don't know if somebody else can confirm those annoying things . If I am not the only one
  then I am hoping the next updates or versions will fix that .
    Thanks !
Good morning everyone
I'm sorry if I'm asking a simple question, but I would like to create a maplet from a maple code I written.
My first problem is I would like to now how to create a table like in excel, to be fill up by the user of the maplet.
Basically, the maplet will consist of enter two parameters who define the number of colums and row needed for the table,
Then fill up this table, which gonna be plot, and then a button to fit this curve using an equation. And the starting value in order to fit the curve will also be set up by the user.
Thanks you in advance if you can help me to set up this table in the maplet.
cheers!
First 133 134 135 136 137 138 139 Last Page 135 of 371
