is possible to solve this pde via maple?
m1.mwm1.mw
sys := [-(-r^2+1)*(diff(theta(r, z), z))+(diff(theta(r, z), r)+r*(diff(theta(r, z), r, r)))/r+diff(theta(r, z), z, z)+(diff(theta(r, z), r))*(diff(sigma(r, z), r))+(diff(sigma(r, z), z))*(diff(theta(r, z), z))+(diff(theta(r, z), r))^2+(diff(theta(r, z), z))^2 = 0, -(-r^2+1)*(diff(sigma(r, z), z))+(diff(sigma(r, z), r)+r*(diff(sigma(r, z), r, r)))/r+diff(sigma(r, z), z, z)+(diff(theta(r, z), r)+r*(diff(theta(r, z), r, r)))/r+diff(theta(r, z), z, z) = 0]; IBCs := {sigma(1, z) = 1, sigma(r, 0) = 1, theta(1, z) = 1, theta(r, 0) = 1, (D[1](sigma))(0, z) = 0, (D[1](theta))(0, z) = 0, (D[2](sigma))(r, 1) = 0, (D[2](theta))(r, 1) = 0}
[-(-r^2+1)*(diff(theta(r, z), z))+(diff(theta(r, z), r)+r*(diff(diff(theta(r, z), r), r)))/r+diff(diff(theta(r, z), z), z)+(diff(theta(r, z), r))*(diff(sigma(r, z), r))+(diff(sigma(r, z), z))*(diff(theta(r, z), z))+(diff(theta(r, z), r))^2+(diff(theta(r, z), z))^2 = 0, -(-r^2+1)*(diff(sigma(r, z), z))+(diff(sigma(r, z), r)+r*(diff(diff(sigma(r, z), r), r)))/r+diff(diff(sigma(r, z), z), z)+(diff(theta(r, z), r)+r*(diff(diff(theta(r, z), r), r)))/r+diff(diff(theta(r, z), z), z) = 0]
Download m1.mw
convert(...,Int) in Maple 2018.2 works for fourier, invfourier, laplace, but does not work for invlaplace.
Why is that? Is there a workaround?
expr:=fourier(f(x), x, w):
convert(expr,Int);
expr:=invfourier(f(w), w, x):
convert(expr,Int);
expr:=laplace(f(s),s,t):
convert(expr,Int)
expr:=invlaplace(f(s),s,t):
convert(expr,Int)
Was expecting to see the Mellin's inverse formula.
Maple 2018.2 on windows 10
 write a programe for fractional calculus and it shows subscript error plzz help me with that
hai,
greetings,
I require help to plot graphs by changing differernt parameters. i am enclosing my codes and sample codes,
 my_codes.mw
nanofluid_sample.mw
Thanks in advance.
Ok so when a module is loaded, there is a .dll file that loads a list of symbols into maple.exe, what can be done if an error occurs for which the debugging output declares that the PDB file for the module could not be found?
I have read that the program database file stores debugging information related to the locating symbols, how can i fix this if my computer isn't finding theres files for a list of .dll it attempts to load into maple.exe, or is there a way for which i can make these files for each corresponding module?
It seems that the forum activity of the user  Markiyan Hirnyk   is no longer accessible.
Is it a site problem?
how I can pdsolve these equations?
moadelat.mw
f1 := -3*(diff(theta(r, z), z))+(diff(r*(diff(theta(r, z), r)), r))/r+diff(theta(r, z), z, z)+2*((diff(theta(r, z), r))*(diff(sigma(r, z), r))+(diff(sigma(r, z), z))*(diff(theta(r, z), z)))+4*((diff(theta(r, z), r))^2+(diff(theta(r, z), z))^2) = 0; f2 := -3*(diff(sigma(r, z), z))+2*((diff(r*(diff(sigma(r, z), r)), r))/r+diff(sigma(r, z), z, z))+(diff(r*(diff(theta(r, z), r)), r))/r+diff(theta(r, z), z, z) = 0
-3*(diff(theta(r, z), z))+(diff(theta(r, z), r)+r*(diff(diff(theta(r, z), r), r)))/r+diff(diff(theta(r, z), z), z)+2*(diff(theta(r, z), r))*(diff(sigma(r, z), r))+2*(diff(sigma(r, z), z))*(diff(theta(r, z), z))+4*(diff(theta(r, z), r))^2+4*(diff(theta(r, z), z))^2 = 0
-3*(diff(sigma(r, z), z))+2*(diff(sigma(r, z), r)+r*(diff(diff(sigma(r, z), r), r)))/r+2*(diff(diff(sigma(r, z), z), z))+(diff(theta(r, z), r)+r*(diff(diff(theta(r, z), r), r)))/r+diff(diff(theta(r, z), z), z) = 0
f3 := sigma(r, 0) = 1, theta(r, 0) = 1, (D[2](theta))(r, 1) = 0, (D[2](sigma))(r, 1) = 0, (D[1](theta))(0, z) = 0, (D[1](sigma))(0, z) = 0, sigma(1, z) = 1, theta(1, z) = 1
Download moadelat.mw
I have multiple accounts. I would like to delete them. Please tell me how to delete it. Thank you.
I'm using the differential operator D to differentiate variables and look at the structure of the equations, i.e. turn things like
D[1]u-vt+v^2=0 into
D[1,2](u)-D[2](v)*t+v*D[1](t)+2*v*D[2](v)=0
However, it is assumed that this is a commutative operator, i.e. D[1,2]=D[2,1]. Can I use an option to have it not commute, or should I look into using the DETools package?
Mike
How can I calculate the Euler-Lagrange equation from the Lagrangian density from Gauged Baby Skyrme model in maple using the physics package? Here, the rules of the operation in the inner space are the same that of the vectors conventional: dot and cross products, etc...
Following below the Lagrangian density.
Errata:
If I used factor, it didn't simplify to 0. As you may notice that this value should be 0.
every time I input a formula I get:
Typesetting:-mparsed(x^2 +5 -2,x^2+3; "_noterminate")
I can't get rid of this error: this is very basic, what happened?
TIA, Roberto
I think   looks much nicer than
it is indeed the answer to .  Both above are equal but there are less terms on the left.  It's just what Maple does - it doesn't like radicals in the denominator.  For just a little overhead I would prefer a collection of any sqrt value into the denominator than to have to split it up.  Maybe just my preference.  Perhaps an option could be available within the Maple system to allow numeric radicals in the denominator?
I get the following errors when attempting to use the Sockets package to interface with the serial input and output for a USB device connected and reported to have no known problems by Windows 10:
with(Sockets):
LookupService("busboy");
Error, could not determine determine port number for service "busboy"
LookupService(998);
Errror, cannot  determine "tcp"  service on port 998
server :=
proc (sid)
Sockets:-Write(sid, sprintf("Hello %s on port %d, from %s\r\n", Sockets:-GetPeerHost(sid), Sockets:-GetPeerPort(sid), Sockets:-GetHostName()))
Sockets:-Serve(GetPeerPort(sid), server);
Error, (in Sockets:-GetPeerHost) Unknown error
sid := Open("localhost", "echo");
Error, (in Sockets:-Serve) cannot bind address: Unknown error
How can we solve the following pde by Maple?
where v is velocity, v with dot is acceleration. (So, I think we will assume that acceleration is fixed.) And \delta is Dirac distribution.  E,I,m, M , g are fixed numbers.
Boundary conditions are:
Initial conditions are:
You can find the equation in the code: question.mw
First 138 139 140 141 142 143 144 Last Page 140 of 371
