How i can get this special parameter i try to do substitution in another mw file but stilli can't reach this parameter and without this parameter my PDE is not give me zero so i have to find this r[i] parameter, some letter of my mw file are not similar to paper but r[i]=l[i] as mention is paper al clear and i found all structure just this remain, i am looking for equation (14), thanks for any help
with(PDEtools)
with(LinearAlgebra)
with(SolveTools)
_local(gamma)
Warning, A new binding for the name `gamma` has been created. The global instance of this name is still accessible using the :- prefix, :-`gamma`.  See ?protect for details.
declare(u(x, y, z, t))
u(x, y, z, t)*`will now be displayed as`*u
declare(f(x, y, z, t))
f(x, y, z, t)*`will now be displayed as`*f
pde1 := a*(diff(u(x, y, z, t), x, t))-((a^4-6*a^2*b^2+b^4)*(1/16))*(diff(u(x, y, z, t), `$`(x, 4)))-(1/4)*(3*(-a^2+b^2))*(diff(u(x, y, z, t)^2, `$`(x, 2)))+alpha*(diff(u(x, y, z, t), `$`(x, 2)))+beta*(diff(u(x, y, z, t), x, y))+delta*(diff(u(x, y, z, t), x, z))+lambda*(diff(u(x, y, z, t), `$`(z, 2)))+mu*(diff(u(x, y, z, t), y, z))+mu^2*(diff(u(x, y, z, t), `$`(y, 2)))/(4*lambda)
a*(diff(diff(u(x, y, z, t), t), x))-(1/16)*(a^4-6*a^2*b^2+b^4)*(diff(diff(diff(diff(u(x, y, z, t), x), x), x), x))-(3/4)*(-a^2+b^2)*(2*(diff(u(x, y, z, t), x))^2+2*u(x, y, z, t)*(diff(diff(u(x, y, z, t), x), x)))+alpha*(diff(diff(u(x, y, z, t), x), x))+beta*(diff(diff(u(x, y, z, t), x), y))+delta*(diff(diff(u(x, y, z, t), x), z))+lambda*(diff(diff(u(x, y, z, t), z), z))+mu*(diff(diff(u(x, y, z, t), y), z))+(1/4)*mu^2*(diff(diff(u(x, y, z, t), y), y))/lambda
Tr := {beta = alpha, delta = alpha, mu = 2*lambda}
pde := subs(Tr, pde1)
a*(diff(diff(u(x, y, z, t), t), x))-(1/16)*(a^4-6*a^2*b^2+b^4)*(diff(diff(diff(diff(u(x, y, z, t), x), x), x), x))-(3/4)*(-a^2+b^2)*(2*(diff(u(x, y, z, t), x))^2+2*u(x, y, z, t)*(diff(diff(u(x, y, z, t), x), x)))+alpha*(diff(diff(u(x, y, z, t), x), x))+alpha*(diff(diff(u(x, y, z, t), x), y))+alpha*(diff(diff(u(x, y, z, t), x), z))+lambda*(diff(diff(u(x, y, z, t), z), z))+2*lambda*(diff(diff(u(x, y, z, t), y), z))+lambda*(diff(diff(u(x, y, z, t), y), y))
pde_linear, pde_nonlinear := selectremove(proc (term) options operator, arrow; not has((eval(term, u(x, y, z, t) = T*u(x, y, z, t)))/T, T) end proc, expand(pde))
a*(diff(diff(u(x, y, z, t), t), x))-(1/16)*(diff(diff(diff(diff(u(x, y, z, t), x), x), x), x))*a^4+(3/8)*(diff(diff(diff(diff(u(x, y, z, t), x), x), x), x))*a^2*b^2-(1/16)*(diff(diff(diff(diff(u(x, y, z, t), x), x), x), x))*b^4+alpha*(diff(diff(u(x, y, z, t), x), x))+alpha*(diff(diff(u(x, y, z, t), x), y))+alpha*(diff(diff(u(x, y, z, t), x), z))+lambda*(diff(diff(u(x, y, z, t), z), z))+2*lambda*(diff(diff(u(x, y, z, t), y), z))+lambda*(diff(diff(u(x, y, z, t), y), y)), (3/2)*(diff(u(x, y, z, t), x))^2*a^2-(3/2)*(diff(u(x, y, z, t), x))^2*b^2+(3/2)*u(x, y, z, t)*(diff(diff(u(x, y, z, t), x), x))*a^2-(3/2)*u(x, y, z, t)*(diff(diff(u(x, y, z, t), x), x))*b^2
eq17 := u(x, y, z, t) = (-a^4+6*a^2*b^2-b^4)*((diff(diff(f(x, y, z, t), x), x))/f(x, y, z, t)-(diff(f(x, y, z, t), x))^2/f(x, y, z, t)^2)/(2*a^2-2*b^2)
``NULL
betai := k[i]*(t*w[i]+y*l[i]+z*r[i]+x)+eta[i]
W := w[i] = ((a^4-6*a^2*b^2+b^4)*k[i]^2-16*lambda*l[i]^2+(-32*lambda*r[i]-16*alpha)*l[i]-16*lambda*r[i]^2-16*alpha*r[i]-16*alpha)/(16*a)
AA := A[12] = (16*(l[1]-l[2]+r[1]-r[2])^2*lambda+3*(k[1]-k[2])^2*(a^2+2*a*b-b^2)*(a^2-2*a*b-b^2))/(16*(l[1]-l[2]+r[1]-r[2])^2*lambda+3*(k[1]+k[2])^2*(a^2+2*a*b-b^2)*(a^2-2*a*b-b^2))
F2 := 1+exp(beta[1])+A[1, 2]*exp(beta[1]+beta[2])+exp(beta[2])
F22 := f(x, y, z, t) = 1+exp((a^4*t*k[1]^3-6*a^2*b^2*t*k[1]^3+b^4*t*k[1]^3-16*lambda*t*k[1]*l[1]^2-32*lambda*t*k[1]*l[1]*r[1]-16*lambda*t*k[1]*r[1]^2+16*a*y*k[1]*l[1]+16*a*z*k[1]*r[1]-16*alpha*t*k[1]*l[1]-16*alpha*t*k[1]*r[1]+16*a*x*k[1]-16*alpha*t*k[1]+16*a*eta[1])/(16*a))+exp((a^4*t*k[2]^3-6*a^2*b^2*t*k[2]^3+b^4*t*k[2]^3-16*lambda*t*k[2]*l[2]^2-32*lambda*t*k[2]*l[2]*r[2]-16*lambda*t*k[2]*r[2]^2+16*a*y*k[2]*l[2]+16*a*z*k[2]*r[2]-16*alpha*t*k[2]*l[2]-16*alpha*t*k[2]*r[2]+16*a*x*k[2]-16*alpha*t*k[2]+16*a*eta[2])/(16*a))
eq := eval(eq17, F22)
u(x, y, z, t) = (-a^4+6*a^2*b^2-b^4)*((k[1]^2*exp((1/16)*(a^4*t*k[1]^3-6*a^2*b^2*t*k[1]^3+b^4*t*k[1]^3-16*lambda*t*k[1]*l[1]^2-32*lambda*t*k[1]*l[1]*r[1]-16*lambda*t*k[1]*r[1]^2+16*a*y*k[1]*l[1]+16*a*z*k[1]*r[1]-16*alpha*t*k[1]*l[1]-16*alpha*t*k[1]*r[1]+16*a*x*k[1]-16*alpha*t*k[1]+16*a*eta[1])/a)+k[2]^2*exp((1/16)*(a^4*t*k[2]^3-6*a^2*b^2*t*k[2]^3+b^4*t*k[2]^3-16*lambda*t*k[2]*l[2]^2-32*lambda*t*k[2]*l[2]*r[2]-16*lambda*t*k[2]*r[2]^2+16*a*y*k[2]*l[2]+16*a*z*k[2]*r[2]-16*alpha*t*k[2]*l[2]-16*alpha*t*k[2]*r[2]+16*a*x*k[2]-16*alpha*t*k[2]+16*a*eta[2])/a))/(1+exp((1/16)*(a^4*t*k[1]^3-6*a^2*b^2*t*k[1]^3+b^4*t*k[1]^3-16*lambda*t*k[1]*l[1]^2-32*lambda*t*k[1]*l[1]*r[1]-16*lambda*t*k[1]*r[1]^2+16*a*y*k[1]*l[1]+16*a*z*k[1]*r[1]-16*alpha*t*k[1]*l[1]-16*alpha*t*k[1]*r[1]+16*a*x*k[1]-16*alpha*t*k[1]+16*a*eta[1])/a)+exp((1/16)*(a^4*t*k[2]^3-6*a^2*b^2*t*k[2]^3+b^4*t*k[2]^3-16*lambda*t*k[2]*l[2]^2-32*lambda*t*k[2]*l[2]*r[2]-16*lambda*t*k[2]*r[2]^2+16*a*y*k[2]*l[2]+16*a*z*k[2]*r[2]-16*alpha*t*k[2]*l[2]-16*alpha*t*k[2]*r[2]+16*a*x*k[2]-16*alpha*t*k[2]+16*a*eta[2])/a))-(k[1]*exp((1/16)*(a^4*t*k[1]^3-6*a^2*b^2*t*k[1]^3+b^4*t*k[1]^3-16*lambda*t*k[1]*l[1]^2-32*lambda*t*k[1]*l[1]*r[1]-16*lambda*t*k[1]*r[1]^2+16*a*y*k[1]*l[1]+16*a*z*k[1]*r[1]-16*alpha*t*k[1]*l[1]-16*alpha*t*k[1]*r[1]+16*a*x*k[1]-16*alpha*t*k[1]+16*a*eta[1])/a)+k[2]*exp((1/16)*(a^4*t*k[2]^3-6*a^2*b^2*t*k[2]^3+b^4*t*k[2]^3-16*lambda*t*k[2]*l[2]^2-32*lambda*t*k[2]*l[2]*r[2]-16*lambda*t*k[2]*r[2]^2+16*a*y*k[2]*l[2]+16*a*z*k[2]*r[2]-16*alpha*t*k[2]*l[2]-16*alpha*t*k[2]*r[2]+16*a*x*k[2]-16*alpha*t*k[2]+16*a*eta[2])/a))^2/(1+exp((1/16)*(a^4*t*k[1]^3-6*a^2*b^2*t*k[1]^3+b^4*t*k[1]^3-16*lambda*t*k[1]*l[1]^2-32*lambda*t*k[1]*l[1]*r[1]-16*lambda*t*k[1]*r[1]^2+16*a*y*k[1]*l[1]+16*a*z*k[1]*r[1]-16*alpha*t*k[1]*l[1]-16*alpha*t*k[1]*r[1]+16*a*x*k[1]-16*alpha*t*k[1]+16*a*eta[1])/a)+exp((1/16)*(a^4*t*k[2]^3-6*a^2*b^2*t*k[2]^3+b^4*t*k[2]^3-16*lambda*t*k[2]*l[2]^2-32*lambda*t*k[2]*l[2]*r[2]-16*lambda*t*k[2]*r[2]^2+16*a*y*k[2]*l[2]+16*a*z*k[2]*r[2]-16*alpha*t*k[2]*l[2]-16*alpha*t*k[2]*r[2]+16*a*x*k[2]-16*alpha*t*k[2]+16*a*eta[2])/a))^2)/(2*a^2-2*b^2)
pdetest(eq, pde)
Download fusion-undon.mw
I have a problem calculating integral analytically.
Can anyone help me in this regard?
problem_2_integral_&_moshtagh.mw
Occasionally I want to convert 2D-Math input to 1D-Math input. This is either not fully working with comments or changes the format. Example:
Try converting the input below to Maple 1D-Math (select -> right click -> 2D-Math -> convert to -> 1D-Math)
statement
statement
The*comment*dissapears:
statement;
statement
The Maple Input at the top can be converted by selecting the style C Maple Input from the edit tab but the font changes not to the default font for 1D Math-Input;
statement
statement
The above is in italic and not in bold. However the default for 1D-Math Input is the following
statement
statement
Also pasting code with comments in MaplePrimes (function insert code snippet) removes comments.
Any other ways? Ideally, I would also like to convert a whole document in one go, That is probably asked too much.
Download convert_comment_to_1D.mw
in try to figure out why in some function i can find this critical point for ploting i need that point , untill now i just find in one function and other i can't and my program not runing for other and really this is make problem for my invistigation i want to fixed that and i upload that file i did and that file i can't find it for , thanks for any help?
line-undone.mw
Line-1-Done.mw
I can't find the help page for Abel second kind, class B.
Maple has help page for Abel second kind, class A and Abel second kind, class C. But not for class B.
Here is an example of Abel second kind class B
ode:=(3*t*y(t)+y(t)^2)+(t^2+t*y(t))*diff(y(t),t)=0;
DEtools:-odeadvisor(ode)
I wanted to know the difference and the transformation used for class B to make it Abel first kind.
I googled and can't find it. Also local help skips over class B.
Is this documented somewhere else?
btw, find error on the help page for class A. Transformation used is wrong. Will leave this for another question.
I'm not currently working on the topic of fluids and I'm not very familiar with it. However, my partner is working on it and is using other software. They have a question about whether Maple can handle this kind of work. Are there any examples available? I’d appreciate any help
thanks!
Dear Maple experts,
is there a possibility/command to get a vizualization of the output of the command FeedbackConnect?
I was thinking of something like this:
as it is given on the maple-help page for that command (but not generated via a maple command as far as I understood)
Thanks in advance !
I have repeatedly seen this on two Windows PCs:
The assignement operator := is rendered as a roman d
This happens after using Maple for some time.
 Exiting Maple and restart of Maple is required. Has someone noticed the same?
All on Windows 10 and for sure in screen reader mode (my default, cannot report on the new GUI).
It seems that the new Ribbon interface has several bugs (probably an update will come soon). So, not only the Export As is not working, but I see that (at least in Windows), opening a worksheet with a large output will display the output using the Maple input font.
Just save a .mw with the content:
expand((x+1)^200);
and then open it.
hello everyone,
I am a bit shortsighted even with my glasses.
So my question is easy :: is there a way that when I open a (new) worksheet the magnification is 150%.
I can do it easily by hand but I am looking for 'something' in my maple.ini file to do this?
As well with the help pages.
Because even if I have a 150% magnification and I call a help page the display is still 100 % not 150%.
A part that I would like to set for every session a Digits:16 .
In the .ini file where I must input this? A ";" or not?
Thank you veru much.
Jean-Michel
I don't know what combination of keys I used, but I deleted all the answers and comments to this question in one go.
https://mapleprimes.com/posts/229696-I-Find-An-Error
Can some moderator recover all of them?
Thanks in advance and sorry for the inconvenience
This question is about a particularity of a widely used function, which looks like a bug at the first glance, but is not (after carefully studying the help page).
The function “add” (a built-in function with special evaluation rules) is intended to be used on sequences. If for any reason (in a procedure for example) a sequence degenerates to a single scalar expression and add is applied to it, the expression can change. This is most likely undesired. In the case below (simplified from a real case that happened to me) a product is transformed into a nonsense sum.
data := 1.*Unit(m);
accu_length := add(data);
data := data, 2.*Unit(m);
                       data := 1. Unit(m)
                  accu_length := 1. + Unit(m)
                 data := 1. Unit(m), 2. Unit(m)
                   accu_length := 3. Unit(m)
It is quite likely that the above unit error will be noticed. In the following case it is more likely that a change in value remains unnoticed.
data := 2/5;
add(data);
                           data := -
                               7
I was wondering whether Maple could issue a warning to prevent this use error of add, when certain types of expressions are passed to add.
Alternatively Maple could return the expression unchanged. So far, I have not found a case where it makes sense to apply add to operands of a scalar expression (excluding set, list, array, ... ).
This leads to the question of whether this functionality (add working on a scalar expression) is needed at all. I tried a few and none of them is useful
[a = b, a^b, a@b, a/b, sin(a), int(f(x), x), a[b]];
map(add, %);
        [        b       a                            ]
        [a = b, a , a@b, -, sin(a), int(f(x), x), a[b]]
        [                b                            ]
          [                         1                ]
          [a + b, a + b, a + b, a + -, a, f(x) + x, b]
          [                         b                ]
Anything else which could make sense?
In the File menu,  the Export As dialog is missing. Only the default (.pdf) can be used; no .mpl or .tex)
The Save As dialog is incomplete (e.g. save to .mws).
Or, is the installation corrupted?
I need to take up an issue which is quite old, but still unsolved.
https://www.mapleprimes.com/questions/234249-Text-Quality-On-Screen
The problem is that in specific display configurations with one (rotated) vertical screen and multiple horizontal screens, the quality of fonts especially is significantly lower in Maple as with a configuration with just horizontal screens.
The affect is visible in Maple when it is on the horizontal (unrotated) screens.
Here are screenshots for comparision, and the layout of my desktop.
Screen layout:
Screenshot rotated
Screenshot unrotated
It seems that the problem is present when starting Maple. Changing the rotation of the screen when Maple is running does not affect the font quality in Maple.
Other (Windows) programs are not affected at all of this changes, so this seems to be a Java issue.
Your MaplePrimes post The package ODECSplines - Description was deleted by a moderator for the following reason: 3. If you believe this was done in error, please contact Maplesoft customer service: https://www.maplesoft.com/contact.
Does anyone know what is ment by reason 3. ?
First 13 14 15 16 17 18 19 Last Page 15 of 371
