Hi Guys,
got my last Problem solved :) Now i do have a new one...
restart; with(RealDomain); with(CodeGeneration); with(ExcelTools); with(plots);
dx1:=133;
dy1:=132;
n := 1;
for i to 256 do
for j to 256 do
r := evalf(sqrt((i-dx1)^2+(j-dy1)^2));
Ints := R0[i, j];
IntsR[n] := [r, Ints];
n := n+1
IntsR := [seq(IntsR[i], i = 1 .. n-1)]
The list IntsR consists of unsorted values doublets. Now it would be nice to get some sort of mean value of my Ints over r.  Didnt really find a solution for it until now... do you have any hint?
I saw a question earlier today regarding 3 particles in a gravitational field.  It has since disappeared.
I see no rhyme or reason why it was deleted by someone, whoever did.  It was Math related and it was Maple related hence no reason for it's deletion.  This happened just before Mapleprimes and Maplesoft went offline for a couple of hours.
Can someone explain?  Did anyone else see it?
i count the number among group
but when the list a large such as over 1000 records, the count will be over 30,000
use which denominator to find probability?
is there any functions in maple for this case?
correlationlist1 := [[1,2,3],[1,3,5]....]:
PAB := Matrix(50):
for ii from 1 to nops(correlationlist) do
 for jj from 1 to nops(correlationlist[ii]) do
  for kk from 1 to nops(correlationlist) do
   for qq from 1 to nops(correlationlist[kk]) do
    if ii <> kk then
     #print("scan=",correlationlist2[kk],"kk=",kk,"qq=",qq,"row=",correlationlist[ii][jj],"column=",correlationlist[kk][qq]):
     PAB[correlationlist[ii][jj],correlationlist[kk][qq]] := PAB[correlationlist[ii][jj],correlationlist[kk][qq]] + 1: # group to group relations
If there is a list
[[1,2],[2,2],[3,3]...
how to use correlate function?
assume [1,2] and [2,1] count as 2
when find correlation between 1and 2
and how about
if [1,2] and [2,1] are different
first position as key
means 1 relate with 2 count as 1 case for 1 only
[2,1] count as 1 case for 2 only
If input a group of outputs which are binary numbers
can it simplify to give a logic that can output these outputs
I'm studying for an exam and earlier today I was working in my Maple sheet. I saved it as usual and no .bak file was in the directory afterwards. When I now later in the day tried to open it, I got the pop up message:
"There were problems during the loading process. your worksheet may be incomplete" and half of the content is missing.
I've searched on google and tried to solve it myself, unfortunately without any luck.
I would really appreciate any help.
Best regards
Dear please check once it showing an error program.mw as intial value is not conververging
proc:=changecoords([x,y],logrithmic);
dsolvediff(x,t):=Matrix([[ 1 , 0],
        [ 0 , i ]])x+Vector[column]([ x^i ,
                 0]);
x:=y+h(y);
for i from 2 to 10;
solve;
endproc;
MakeIteration := proc( expr::algebraic, x::name )
    local iteration := diff(x,t)=Matrix([[ 1 , 0 ],
        [ 0 , i]])x+Vector[column]([ x^i ,
                 0]),x:=y+h(y);
for i from 2 to 10 ;
end do ;
    unapply(iteration, x);
endproc;
Error, missing operator or `;`
Hi , I would like to solve nonlinear equation by using maple,but I wander how I can write it since there is a change of veriable bysubstiuting the value of y in the diifferenitat . Iactually coudnot write the equation sine it contains differential ,matrix and vector . do Ihave to use dalembertian?
best regards
Dear MaplePrimes team,
For display a beautiful parametric surface with hole (or pierced surface), unfortunately unlike CAD (computer-aided design) tool, Maple requires a large grid number. Therefore the computing is too long and requires huge RAM only with grid of [500,500] on a modern computer.
Fig. 1: For a complex surface such an aircraft fuselage here, Needs high grid, therefore, the compilation is too long with modern computer (Intel Core i7, 2.4 GHz CPU, 16 GB RAM). If displays supplementary windows holes on fuselage, the software may bug when the RAM is full.
Question 1:
In matter of low cost computation, do you have better solution to create a fast surface with smooth hole from given a parametric surface equation S(x,y) and given any convex/concave-closed parametric curve C(t) that is projected on surface S(x,y)?
Fig. 2: These surfaces are been created in Maple 2016 from given initial parametric surface equation and curve projected on the surface. But requires huge grid, huge RAM, and long time to get smooth hole when free CAD tools are fast and low RAM.
Question 2:
Because I noted that the Maple’s view option renderers smooth edges of any surface. My question is: Is it possible to use the internal structure of display/view used by Maple to apply at free boundaries? I think it will be possible to create many class of view, for examples: cylindrical sector, spherical sector views or more rather to be limited with conventional cubic view. And thus, I think it will be possible to create own smooth hole or multiple-hole on surface and get smooth pierced surface.
I know that almost of technicians/engineers will recommend me to use a CAD tool to create surface with hole. But the objective here is to keep purely a mathematical mind and work with exact equations (analytic equations).
On a free CAD tool, even the complex holes are created very fast only with low RAM. Why not on Maple?
Best.
Guy.
Hi , I have question about poincare's theorem which needs to change the veriable and that transform the coordinates , but when I change the variable from x to y if doesn't defined any suggestion ? Please
I want to maximize a total profit (TP) function which is dependent on five independent variables (E,W,T, theta, tp). All these five variables can have non negative values. The TP function is given below- ( first TP is directly copied from maple worksheet and than copied again as a picture for clear viewing).
 TP = (p1*(Q-q)+p1*(1-theta)*(q-E)+s*E-c*Q-o-h*((1/6)*alpha*W^beta*a*p1^(-b)*tp^3/m-(1/2)*alpha*W^beta*a*p1^(-b)*tp^2+Q*tp)-(t1-tp)*h*((1/2*(-(2/3)*t1+m-(1/3)*tp))*W^beta*a*alpha*(t1-tp)*(-p1*(-1+theta))^(-b)+W*m)/m-(1/2)*h*(W+E)*(T-t1))/T-u*W
I am trying the maximize TP with respect to above five independent variables. I tried to solve  five equations ( representing first order partial derivative of TP with respect to each of the independent variables equated to zero) simultaneously by "solve" and "fsolve" command but both these commands fail to give any output. I have also tried three other commands in optimization package ( QPSolve, NLPSolve, Maximize) but all these three commands also doesn't give any output. I want to prove the concavity of TP function with respect to five independent variables, please guide how it can be done. ( I have computed the Hessian matrix but since five first order equations doesn't give output ( through fsolve command) so I am unable to compute Hessian at these first order optimiality condition solution.). The values of the paramters in the TP equation are -
[alpha = 50, beta = .7, c = 20, h = 4, m = .4, o = 10, p1 = 40, s = 10, u = 5, a = 15000, b = 2]
with(plots); with(DEtools);
`&epsilon;` := .1;
de1 := x[0](t)+`&epsilon;`*x[1](t);
ode2 := sin(t)-`&epsilon;`*t*sin(t);
MODEL := {ode1, ode2};
VARS := {x(t), y(t)};
DOMAIN := t = 0 .. 20;
RANGE := x = -3 .. 3, y = -3 .. 3; COLORS := [BLACK, BLUE];
IC1 := [x[0](0) = 0, x[1](0) = 0]; IC2 := [(D(x[0]))(0) = 1, (D(x[1]))(0) = 0];
DEplot(MODEL, VARS, DOMAIN, RANGE, [IC1, IC2], stepsize = .1, arrows = THIN, linecolor = COLORS);
Error, (in DEtools/DEplot/CheckInitial) the 'number' option must be specified before initial conditions
Hi, is anyone using the Geometry Expressions software together with Maple? I've found about this software on forum and installed a free demo version. It is using symbolic geometry, which I haven't been able to find this feature on other software, and can work very well with Maple, but unfortunatelly, my demo version doesn't work properly, and their oficial website http://saltire.com/ has lots of errors 404 page not found. I have requested support, but have had no answer so far. I was so happy finding this software, but now I am thinking maybe wasting my time. If you are using it, or maybe think it would be good to give it a go, please let me know if it is working for you. A particular feature which is not working for me is 'creating angles'. Thank you.
Dears I have the following statment in Matlab
r=8;             ZUM=U(1)-YU(1);            IT=0;
for r=2:10
    ZU(r)=abs(U(r)-YU(r));
    if ZU(r)> ZUM
        ZUM=ZU(r);
        ZUM=ZUM;
    end
end
ZUM;
while IT < 20
    IT=IT+1
    if ZUM < (0.1)^r
    IT=20;
  for r=1:Nx
  YU(r)=U(r);
  end
YU;
I need to write this statment in Maple
All the 3d plot in my maple are upside down.....the tickmarks..the numbering even the lebeling are also upside down...how do i solve it....plz help
First 171 172 173 174 175 176 177 Last Page 173 of 371
