Dear collagues
I write a code to solve a system of ODE. It solve the ODES in a wide range of parameters but as I decrease NBT below 0.5, it doesnt converge. I do my best but I couldn't find the answer. Would you please help me? Thank you
Here is my code and it should be run for 0.1<NBT<10. the value of NBT is input directly in res1.
EPSILONE:=1000:
Digits:=15:
a[mu1]:=5.45:
b[mu1]:=108.2:
a[k1]:=1.292:
b[k1]:=-11.99:
rhop:=4175:
rhobf:=998.2:
mu1[bf]:=9.93/10000:
k1[bf]:=0.597:
rhost(eta):=1-phi(eta)+phi(eta)*rhop/rhobf;
k:=unapply(k1[bf]*(1+a[k1]*phi(eta)+b[k1]*phi(eta)^2),eta);
eq1:=(diff(u(eta), eta))*a[mu1]*(diff(phi(eta), eta))+2*(diff(u(eta), eta))*b[mu1]*phi(eta)*(diff(phi(eta), eta))+((diff(u(eta), eta))+(diff(u(eta), eta))*a[mu1]*phi(eta)+(diff(u(eta), eta))*b[mu1]*phi(eta)^2)/(eta+EPSILONE)+diff(u(eta), eta, eta)+(diff(u(eta), eta, eta))*a[mu1]*phi(eta)+(diff(u(eta), eta, eta))*b[mu1]*phi(eta)^2+1-phi(eta)+phi(eta)*rhop/rhobf:
eq2:=(1+a[k1]*phi(eta)+b[k1]*phi(eta)^2)*(diff(T(eta), eta))/(eta+EPSILONE) + (a[k1]*(diff(phi(eta), eta))+2*b[k1]*phi(eta)*(diff(phi(eta), eta)))*(diff(T(eta), eta))+(1+a[k1]*phi(eta)+b[k1]*phi(eta)^2)*(diff(T(eta), eta, eta));
eq3:=diff(phi(eta),eta)+phi(eta)/(N_bt*(1+gama1*T(eta))^2)*diff(T(eta),eta):
eq2:=subs(phi(0)=phi0,eq2):
eq3:=subs(phi(0)=phi0,eq3):
eval(dsolve({eq3,phi(1)=phiv},phi(eta)),(T)(1)=1):
Phi:=normal(combine(%)):
Teq:=isolate(eval(eq2,Phi),diff(T(eta),eta)):
ueq1:=eval(eq1,Phi)=0:
ueq2:=subs(Teq,ueq1):
lambda:=0;
Ha:=0;
N_bt:=cc*NBT+(1-cc)*0.8;
kratio:=k1[p]/k1[bf]:
GUESS:=[T(eta) =0.0001*eta, u(eta) =0.1*eta, phi(eta) = 0.3*(eta-1)^4];
res1 := dsolve(subs(NBT=0.48,gama1=0.2,phiv=0.06,{eq1,eq2,eq3,u(0)=lambda*D(u)(0),D(u)(1)=0,T(0)=0,phi(1)=phiv,T(1)=1}), numeric,method=bvp[midrich],maxmesh=4000,approxsoln=GUESS, output=listprocedure,continuation=cc):
G0,G1,G2:=op(subs(subs(res1),[phi(eta),u(eta),diff(T(eta),eta)])):
masst:=evalf(int((1-G0(eta)+G0(eta)*rhop/rhobf)*G1(eta), eta = 0..1));
heatt:=(1+a[k1]*G0(0)+b[k1]*G0(0)^2)*G2(0);
plots:-odeplot(res1,[[eta,T(eta)]],0..1,legend=[T],color=["Black"],linestyle=Solid,axes=boxed,thickness=3);
plots:-odeplot(res1,[[eta,u(eta)]],0..1,legend=[u],color=["Black"],linestyle=Solid,axes=boxed,thickness=3);
plots:-odeplot(res1,[[eta,phi(eta)]],0..1,legend=[phi],color=["Black"],linestyle=Solid,axes=boxed,thickness=3);
Amir
 Maple code when open saved maple sheet?
and keep it can run code and show latest result after open
i mean user can not extend or find code or display code in maple sheet , just can run result
I'm having a bit of trouble figuring out some error messages in the Maple debugger. When I debug some procedures I'm getting error messages like "Error, invalid input: %1 expects its %-2 argument, %3, to be of type %4, but received %5". Since the procedure calls a lot of other procedures I have to check every single one of them, to see, which one gives me the error message. It would be easier if I would know, what procedure/type hides behind the variables %1,... Is there a way to check this from within the debugger?
Thanks a lot.
Why have there been so many old Posts and Questions moving to the top of the Active Conversations stack the past two days, even though they have no new activity? This makes MaplePrimes very difficult to use! Please make it so that the Active Conversations stack is sorted by the actual time of the most-recent addition to the thread.
Im working on an assignment involving a rocket being launched vertically from rest.
I have a eq. of motion that looks like this: v(t)=vs*ln(-m0/(r*t-m0))-g*t
Now Im supposed to implement the air resistance, and write an expression for the total force on the rocket. After that creating a plot displaying the speed v(t) as a function of time for both, with and without air resistance.
All constants are known including CD, rho and A for the dragforce.
I would be grateful if anyone could help me with this!
Hello altogether,
I want to plot the numerical result of an ODE, which seems to be pretty simple at first sight, but the difficulty is that the boundaries are depending on the solution.
The following pseudo-code describes what I want to have, but it doesn't work. This code fills the RAM pretty fast and you will have to kill the process.
Free-boundary_prob.mw
Is it possible to calculate a solution to this problem numerically (or even analytically) and if yes, how?
Since I am new here, I am sorry for any bad-to-read maple code or any noob errors I have made. I would be very thankful, for any response and help.
Greetings
butterflyfart
sys := [(diff(c(t), t))*(diff(a(t), t))*(diff(b(t), t))+(diff(c(t), t))*t^2, (diff(c(t), t))*(diff(a(t), t))*t+(diff(c(t), t))*t*(diff(b(t), t)), (diff(c(t), t))*(diff(a(t), t))*(diff(b(t), t))+(diff(c(t), t))*(diff(a(t), t))*t+(diff(c(t), t))*t^2]
DEplot(sys, [a(t), b(t), c(t)], t = 0 .. 2, a = -15 .. 15, b = -15 .. 15, c = -15 .. 15, color = magnitude, title = `Stable Limit Cycles`, arrows = curve, dirfield = 800, axes = none);
odeplot(sys, [t, a(t), b(t), c(t)], -4 .. 4, color = orange);
with(RegularChains);
with(ConstructibleSetTools);
source1 := PolynomialRing([a, b, c, d]);
target1 := PolynomialRing([e1, e2, e3, e4]);
source1list := [eq2a, eq3a, eq4a, 0];
target1list := [eq2b, eq3b, eq4b, eq5b];
cs := PolynomialMapPreimage(target1list, source1list, source1, target1)
return
cs := constructible_set
then i type
Elements(constructible_set)
it return
 since source has less number of variables, in order to use this function
i add a dummy variable d to this and use 0 for the fourth equation
dsol := dsolve([eq2=diff(s(t),t), eq3=diff(s(t),t), eq4=diff(s(t),t)], [a(t),b(t),c(t)]);
eval(subs(t(t)=t,subs(_C1(t) = _C1, subs(_C2(t) = _C2, subs(_C3(t) = _C3, sol1)))));
after subs t(t) = t , it still  have t(t)
Dear Collagues
I wrote a code to solve a system of ode numerically. When the equations have been solved, I want to find the value of MTE which is in integral form. I check and see that the value of MTE is calculated wrong. I dont know why?
I calculated the values of MTE twice (another variable is masst below res1). Two different answers!!
I would be most grateful if you could help me.
Here is my code
EPSILONE:=1:
#Digits:=10:
a[mu1]:=39.11:
b[mu1]:=533.9:
a[k1]:=7.47:
b[k1]:=0:
rhop:=5180:
rhobf:=998.2:
#gama1:=0.2;
k1[bf]:=0.597:
#mu:=unapply(mu1[bf]/(1-phi(eta))^2.5,eta);
mu:=unapply(mu1[bf]*(1+a[mu1]*phi(eta)+b[mu1]*phi(eta)^2),eta);
#mu1[bf]:=9.93/10000:
mu(eta)/mu1[bf];
#eq1:=diff((mu(eta)/mu1[bf])*diff(u(eta),eta),eta)+rhost(eta)-Ha^2*u(eta);
eq1:=(a[mu1]*(diff(phi(eta), eta))+2*b[mu1]*phi(eta)*(diff(phi(eta), eta)))*(diff(u(eta), eta))+(1+a[mu1]*phi(eta)+b[mu1]*phi(eta)^2)*(diff(u(eta), eta, eta))+rhost(eta)-Ha^2*u(eta);
eq2:=diff((k(eta)/k1[bf])*diff(T(eta),eta),eta);
eq2:=subs(phi(0)=phi0,eq2);
eq3:=subs(phi(0)=phi0,eq3);
eval(dsolve({eq3,phi(1)=phiv},phi(eta)),(T)(1)=1);
Phi:=normal(combine(%));
Teq:=isolate(eval(eq2,Phi),diff(T(eta),eta));
Agama1:=<<0.1>,<0.2>,<0.3>>:
ANBT:=<<0.2>,<1>,<10>>:
Aphiv:=<<0.02>,<0.06>,<0.1>>:
lambda:=0;
Ha:=0;
#NBT:=0.5:
N_bt:=cc*NBT+(1-cc)*10;
#phiv:=0.02:
kratio:=k1[p]/k1[bf];
eq1;
eq2;
eq3;
res1 := dsolve(subs(NBT=1,gama1=0.3,phiv=0.06,{eq1,eq2,eq3,u(0)=lambda*D(u)(0),D(u)(1)=0,T(0)=0,phi(1)=phiv,T(1)=1}), numeric,method=bvp[midrich],output=listprocedure,continuation=cc):
for iNBT from 1 to 3 do
for iphi from 1 to 3 do
for igamma from 1 to 3 do
res := dsolve(subs(NBT=ANBT(iNBT),gama1=Agama1(igamma),phiv=Aphiv(iphi),{eq1,eq2,eq3,u(0)=lambda*D(u)(0),D(u)(1)=0,T(0)=0,phi(1)=phiv,T(1)=1}), numeric,method=bvp[midrich],output=listprocedure,continuation=cc):
F0,F1,F2:=op(subs(subs(res),[phi(eta),u(eta),diff(T(eta),eta)])):
MTE[iNBT,iphi,igamma]:=evalf(Int((1-F0(eta)+F0(eta)*rhop/rhobf)*F1(eta), eta = 0..1)):
HTC[iNBT,iphi,igamma]:=(1+a[k1]*F0(0)+b[k1]*F0(0)^2)*F2(0):
print (convert(HTC[iNBT,iphi,igamma],float,9));
print (convert(MTE[iNBT,iphi,igamma],float,9));
Amir
1.
with(RegularChains):
with(ConstructibleSetTools):
source1 := PolynomialRing([a,b,c]);
target1 := PolynomialRing([e1,e2,e3,e4]);
source1list := [eq2a, eq3a,eq4a];
target1list := [eq2b, eq3b, eq4b,eq5b];
cs := PolynomialMapPreimage(target1list, source1list, source1, target1);
Error, (in RegularChains:-ConstructibleSetTools:-PolynomialMapPreimage) number of map functions is different from number of variables in target space
in maple 15 do not have error, however now it has error for the code below
with(RegularChains): with(RegularChains): with(ConstructibleSetTools):
source1 := PolynomialRing([e1, e2, e3]);
target1 := PolynomialRing([a, b, c]);
source1list := [-1*e1+2*e2+*e3, -1*e1+2*e2+*e3, -1*e1+2*e2+*e3];
target1list := [.....]; cs :=
Error, invalid product/quotient
Hi guys,
i want to find d'alembertian of a function of Ricci scalar (f(R)) , but it seems something is wrong .
f(R).mw
thanks in advance
I need you help to finish some steps of this idea to approximate the roots of a given equation (polynom). Thanks in advance for your help.
I have a sturm sequence, I would like to use Bisection method to approximation the roots using Sturm decomposition of my polynom. For example, my polynom is  P=x^6-4*x^3+x-2
s := sturmseq(x^6-4*x^3+x-2,x);
sturm(s,x,-2,2); # The number of roots in the interval (-2,2)
Here, i would like to find the roots in (-M,M) :
Bounding all roots in [-M,M] where M = max{1, sum^(n-1) |ai|/an}.
f0 = f, f1 = f', then use -remainder,
I know that  sturm(s,x,-M,M); gives the number of roots in (-M,M)  but is it possible to use the variation of sign like :
      gives a Sturm sequence for f.
      variation of sign, varsign(a0,a1,...,ar).
      Thm: (Sturm) varsign(f0(alpha),...,fr(alpha)) - varsign(f0(beta),..., fr(beta))
      is the number of distinct roots of f in [alpha,beta].
then i would like Isolating roots of rational polynomials
Method: reduce, remove rational roots, divide and conquer in [-M,M],
      then use bisection  in disjoint closed intervals ctg one root each
 Bisection method :
Bisection
      Setup: f(a) < 0, f(b) > 0 (or conversely).
      Repeated subdivision of [a,b] guaranteed to get close to a root.
      Error analysis: for error eps, solve (b-a)/ 2^(n+1)  < tol for n. where tol is the tolerance
in harmonic ocillator version, why it has error after it dsolve?
with(Physics[Vectors]):
with(SumTools):
Setup(mathematicalnotation = true):
Qs is Qss*cos(m*t+phi);
H := 1/(8*Pi*c^2)*Summation(Commutator(diff(Qs*cos(w*t+phi),t)*diff(conjugate(Qs*cos(w*t+phi)),t)+w^2*Qs*cos(w*t+phi)*conjugate(Qs*cos(w*t+phi))),ks=1..3)-1/c*(Summation(conjugate(Qs*cos(w*t+phi)),ks=1..3));
or
H := 1/(8*Pi*c^2)*Summation(Commutator(diff(Qs,t)*diff(conjugate(Qs),t)+w^2*Qs*conjugate(Qs)),ks=1..3);
#Qs = p, Ps := Pss*sin(m*t+phi) Ps = qs
i use
 HJ := subs(Qs= diff(f(q,P,t), q), H);
H:=subs( f(q,P,t) = f1(q) + f2(t), HJ);
sol:=dsolve({rhs(H)=E,lhs(H)=E});
S:=rhs(sol[1][1]+sol[1][2]);
p:=diff(S,q);
Q:=diff(S,E);
First 222 223 224 225 226 227 228 Last Page 224 of 371
