how to convert between (system of polynomials or module) and rational function which is a four dimensional space
1. is module in algebraic geometry or group cohomology to classify homology group?
2. is final result like this? for example,
a dictionary  or table store
homology group 1, key=invariant = 1 hole in topological space , value = module 1, module 2 module 3 etc
homology group 2, key=invariant = 2 holes in topological space , value =module 4, module 5, module 6 etc
homology group 3, key=invariant = 3 holes in topological space , value = module 7, module 8.. etc
 ... etc
3. i find betti number can count holes, however how to know the form for
all combination?
i mean if it is module, how to change the module to get the full combination
http://www.singular.uni-kl.de/Manual/html/sing_159.htm
i find betti number's input is just ideal, but it is not module
if ideal is enough, why need module?
how to permuate module? and what do it classify and result in module?
1. is module in algebraic geometry for classification of topological space which a poset is a frame
2. which invariant is for doing this classification of topological space in algebraic geometry or group cohomology?
3. if want to do full combination before classification, which kind of polynomials be a full combination
4. is poset just like function fst and snd function for meet and join in functional programming instead of using "and" and "or" logic? how a matrix group related with topological space which a poset is a frame?
5. is there any invariant function for classification of topological space in maple?
   I have a set of linear equations in terms of Ax+B=0, where A and B are matrices.
  I used linsolve or LinearSolve to solve the equations.
   Is there any simple way to run linsolve/LinearSolve parallelly? suppose I already have matrices A and B.
Thank you very much
#page 320 and 322 of book Singular introduction to commutative algebra
it return too many recursion
hilbertseries([a+a*c, a+a*b, a+b+c]);
eq1 := a+a*c;
eq2 := a+a*b;
eq3 := a+b+c;
eq1a := Homogenize(eq1, h);
eq2a := Homogenize(eq2, h);
eq3a := Homogenize(eq3, h);
T3:=lexdeg([a,b,c,h]);
GB := Basis([eq1a,eq2a,eq3a], T3); #a
#MonomialHilbertPoincare(LeadingMonomial(GB[1],T3), LeadingMonomial(GB[2],T3), LeadingMonomial(GB[3],T3));
with(PolynomialIdeals):
MonomialHilbertPoincare := proc (I3)
#I3:=[LeadingMonomial(GB[1],T3), LeadingMonomial(GB[2],T3), LeadingMonomial(GB[3],T3)];
T2:=lexdeg([h,c,b,a]);
varj := [h,c,b,a];
I2 := InterReduce(I3, T2);
s := nops(I2);
if I2[1] = 0 then return 1 end if:
if I2[1] = 1 then return 0 end if:
if degree(I2[s]) = 1 then return (1-varj[1])^s end if:
lt := LeadingTerm(I2[s],T2);
leadexp := [degree(lt[2],h),degree(lt[2],c),degree(lt[2],b),degree(lt[2],a)];
j := 1;
for z from 1 to nops(leadexp) do
                if leadexp[j] = 0 then
                                j := j + 1;
finallist := [];
for z from 1 to nops(GB) do
                finallist := [op(finallist), GB[z]+varj[j]];
quotientlist := Generators(Quotient(GB, varj[j]));
finallist2 := [];
for z from 1 to nops(quotientlist) do
                finallist2 := [op(finallist2), op(z,quotientlist)];
return MonomialHilbertPoincare(finallist) + varj[1]*MonomialHilbertPoincare(finallist2);
F:=[LeadingMonomial(GB[1],T3), LeadingMonomial(GB[2],T3), LeadingMonomial(GB[3],T3)];
MonomialHilbertPoincare(F);
but if restart the program,the menu of Plot Builder is appear,in same function(x^2+y^2+(1/1000000000)*z-25 = 0),why thing like this happen?
when run the order like this, the menu of Plot builder disapper
Thank you in advance for your help
How can I pde with maple?please explain completely,and other question :How can I solve pde with plot in maple because some questions dont have exact answer?
if DegreeLexicographic is T2:=lexdeg([a,b,c],[x,y,z]);
DegreeReverseLexicographic = T2:=lexdeg([c,b,a],[z,y,x])  ?
quotientlist := Quotient(GB, varj[j]);
finallist2 := [];
if
there are only 3 monomials in quotientlist, but nops return 6
Let a finite set of closed intervals in the plane be given.
How to find all the intersections of these, outputing the intersection points together with the intersecting intervals?
This is a problem of computational geometry
(see http://en.wikipedia.org/wiki/Line_segment_intersection).
In other words, how to realize the sweep line algorithm in Maple?
PS. I'd like to note that computational geometry has serious applications, in particular, in robotics.
how to compute the ideal mapping from ideal A to ideal B
Let Poly2 denote the vector space of polynomials
(with real coefficients) of degree less than 3.
Poly2 = {a1t^2+ a2 t+ a3 |a1; a2; a3 €R}
You may assume that {1,t; t^2}is a basis for Poly2.
(1) Show that L1 = {t^2 + 1; t-2 ; t + 3}and L2 = {2 t^2 + t; t^2 + 3; t}
are bases for Poly2.
(2) Let = 8t^2- 4+ 6 and = 7t^2- t + 9. Find the coordinates for
and with respect to the basis L1 and with respect to the basis L2
(3) find the coordinate change matrix P from the basis L1 to the basis L2.find P^-1
Just I answer part (1) can you help me to answer 2 and 3
I am considering to write a wrapper for plot and related commands (could redefine the commands or introduce a new name) which facilitates export of Maple plots to postscript. The command should interpret some of the options and remove them from the options sequence before submitting the remaining ones to the original plot().
E.g. it should recognize a title="TITLE" parameter and process TITLE (e.g. write it to a specific file). Similarly I would want to be able to pass additional parameters, e.g. filename="FILE" in order to specify how the output file name should be set. Is this a sensible approach. How can I realize this detailed option 'parsing' in Maple?
how to calculate hlibert series as in maple with Gröbner Bases
would like to know the algorithm and try in another programming language such as F#
i find the algorithm in book Singular introduction to commutative algebra
page 320 and 322
1. is it equal to the hilbert series function in maple?
InterReduce(F, ???);
 2. what is the maple function for degree reverse lex ordering ?
David Cox using Algebraic Geometry page 82 use resultant to eliminate variable h
eq1b := eq1a - x;
eq2b := eq2a - y;
eq3b := eq3a - z;
GB := Basis([eq1b,eq2b,eq3b], T2);
r1 := resultant(eq1b, eq2b, h);
r2 := resultant(eq1b, eq3b, h);
r1 = r2
page 82 teach how to eliminate, after do question 2, discover r1 and r2 are the same.
how to eliminate the variable h with resultant after homogenize ideal with variable h
First 261 262 263 264 265 266 267 Last Page 263 of 371
