I have a rather burly system of PDE that I need solved in maple.  It's a little complicated to explain the set-up, but I am solving for some coefficients of a function expansion where each coefficient is solved in terms of some other known functions.
Basically the problem is the technique and code works perfectly for another application, but it fails me here.  For one, when I try rifsimp(%,[a[0](x,y,t),b[0](x,y,t),c[0](x,y,t)]), it runs for...
Plase write for me a code for the following problem:
Let (d): (x-1)/2 = (y+2)/1 = z/1 be a line and
(P): x + 2y -z - 3 = 0 be a plane.
Write the equation of the line (Delta) lies in the plane (P), perpendicular to the line (d) and the distance between (d) and (Delta) equal to sqrt(2).
I just purchased Maple 15 student edition. I am attemping to create a plot. When I type the command I encounter a problem. The following keys will not work, ()[]{}. When I enter the ( the curser disapears and I am unable to enter any more keystrokes.  If I enter to many keystrokes Maple freezes and I can must close the program.
I want to connect Maple to a database with around 10 000 time series.
I have played around with Microsoft Access, SQL Server and MySQL.
However, none of them seems to be up to the task.
One of the problems that I had was that the connection (tcp-ip) between
Maple and the database was very slow also the databases them self did not
handle the large amount of data very well. Maples database
examples are not very helpful either. They only show "cute" examples
There is a cool option of dropping one graph from multigraph (after that it goes as separated one). How to get  this dropped structure itself? I.e. i have "graph" component with command AllPlots that itself is
AllPlots:=plots[display](AllPlotsStructure,...);
AllPlotsStructure is a list of plot/textplot.
After all i removed one structure by drag-and-drop on component. How to update AllPlotsStructure correctly?
I have a sequence of difference polynomials (which I obtained by the method of finite differences) and I would like to find out if there is a recurrence relation between them.
The generating function of general difference polynomials is given by:
e^{zt}=\sum_{n=0}^\infty p_n(z)
\left[\left(e^t-1\right)e^{\beta t}\right]^n.
I tried to solve a non linear coupled boundary value problem in MAPLE using DSolve command. The code is :
alias(eta = e, theta = t)
Eq[1] := 5*(diff(F(e), `$`(e, 3)))+(m+3)*F(e)*(diff(F(e), `$`(e, 2)))-(2*m+1)*(diff(F(e), e))^2-(4*m+2)*H(e)-(m-2)*e*(diff(H(e), e)) = 0
Eq[2] := diff(H(e), e) = t(e)
Eq[3] := 5*(diff(t(e), `$`(e, 2)))/Pr-(m+3)*F(e)*(diff(t(e), e))-5*m*(diff(F(e), e))*t(e) = 0
BCs := [F(0), (D(F))(0), (D(F))(infinity), t(0)-1, t(infinity), H(infinity)]
Is there any command in Maple 15 to linearize an PDE non-linear? Or or there is a package or help file to do so?
I'm handling with Non-linear PDEs in my work and I would like to solve them by these methods.
Thank You
Washington Inacio
It's possible to define a field in Maple 15 with 2 kinds of indices, say type spacetime μ,ν,ρ... and one of the type integer, i,j,k varying from 1 to n?
I would like to define a field like Aμi where:
Aμ1=Aμ
Aμ2=Bμ
and so on.
Thank you Washington Inacio
Write the equation for the plane P contains the straight line
d: x = 2 + t, y = t, z = 2 + 2t,
so that, the distance
Problem: Write the equation of the straight line (d) through the point A(1,-2,3), cut the straight line
Delta: x = 3*t+1, y = t, z = t-1 and parallel to the plane (P): x + 2*y + 3*z + 4 = 0.
We know that, if the straight line (d) through the point A and parallel to the plane (P), then (d) lies on a plane (Q), which (Q) through the point A and parallel to the plane (P).
i need to write a program for my calculator to solve these eqution
Vr =any number i enter it
Ir =any number i enter it
L= any number i enter it
Z= any number i enter it
Y=any number i enter it
w=sqr (ZxY)
Zc= sqr (Z\Y)
A=D= cosh wL
B=Zc sinh wL
C= (1\Zc) sinh wL
Vs = AxVr + BxIr
Is = CxVr + DxIr
Vs= the number we get from the Vs eqution
Ir = the...
I am learning about programming; I have this equation:
2*K2*alpha*t=ln[(A0+E(beta-1/2)/(A0-E(beta+1/2)
The values of t, E are a list of values.
and K2 alpha and beta are unknown but i dont know how to do for graph the part of ln vs time and fit it to a line.
How can I show that the Least Square solution x = (A'.A)^-1.A'.y
Is different when A is an orthogonal matrix compared to an
overdetermined or underdetermind matrix.
Preferably transform the matrix using Singular Value Decomposition (SVD)
or something similar.
Thanx
For LSSolve I have the objective function as a procedure that calls another procedure (procPatientres) according to below:
p:=proc(x::Vector, y::Vector)
y[1]:=procPatientres("patient specific parameters", x[1],x[2]);
y[2]:=procPatientres("patient specific parameters", x[1],x[2]);
This is a test example where I only fit to patients. Since the returned residuals, y[1] and y[2], are just values the first derivative is simple zero and I...
First 323 324 325 326 327 328 329 Last Page 325 of 371
