I'm trying to run the basic example posted in the hepf files at "OpenMaple, Java, Examples".  The procedure to produce a test.class file from the test.java file seems to work fine.  But I get an error message when I try to run the test.class file as per directions.  What I am seeing is
Exception in thread "main" java.lang.NoClassDefFoundError: C:/.../test
then a bunch of stuff and finally
Could not find the main class: C:/.../test. Program will exit.
the cylinder r = a*cos(O) cut out of the sphere of radius a centered at origin. any help. thanks
Hi everyone.
I have an assignment due in my computing class. However, I'm stuck on these 6 questions. Any help would be greatly appreciated. Please show all work, step by step. Unfortunately though, I can't use Maple shortcuts like "sum" to sum the terms in a sequence, so try not to use those.
Thanks in advanced :)
Hi ,everyone.When I entered the following code I got the error massage "Warning, solutions may have been lost." I want to solve x,how can I deal with this problem?Thanks a lot.
 p := 1730;
 r := .15;
mu := .17;
c := 120000;
k := 60000;
sigma := .2;
y := .89;
CI := 500000000;
with(Statistics);
Hi everybody, Using pdsolove(SyPDE, BIC, numeric), I have to model propagation of two waves , u(x,t) and v(x,t) , in two elastic test rods that are in contact. The problem are boundary conditions at the contact surfaces: values of forces and strain are equal at the first rod right end and at the second rod left end: D[1](u)(l_1,t)=D[1](v)(0,t) and (u)(l_1,t)=(v)(0,t) Maple can't do that. Should I put in code some transitional Maple expression or function for force and strain, like, for force X:=(delta*x)/l, in order to get this: D[1](u)(l_1,t)=X, D[1](v)(l_1,t)=X,
Hey, does anyone here know how to program the product Nystrom method for solving integral equations of the second kind? Thanks
Dear all:
   suppossed i have a function as following :
f(x):=2*sin(x)*(sin(x)+I3*sin(3*x)+I5*sin(5*x))
where  x is belong to (0,Pi/2), I3,I5 is defined to I3^2+I5^2 < .232.
i have ploted some curves of f(x) . As to different I3 and I5, the curve of f(x) have different point of intersection with y=1 function, may one point or two  point or three where 0<x<Pi/2.
hi,i am new to this and when i start up maple 12 i get the following error:"Java Virtual Machine Launcher, could not create the java virtual machine".
I have a problem with define(f,multilinear). I want that Maple threats alpha[i,j] as a constant such that f(e[1], alpha[2, 4]*e[4])=alpha[2,4] f(e[1],e[4]). I've added all the alpha[i,j] to the constants, but still, he fails to compute f(e[1], alpha[2, 4]*e[4]).
It works when I add alpha(i,j) to the constants, but then the rest of my program doesn't work, so it really should be with [,] and not with (,).
I've recently updated to Maple 12 (on Mac OS X.4.11) and am still learning how to use it. A search on Maple FAQs didn't turn up any answers to the following questions.
I am posting it again. I need the plot of W(i+1/2)=1/2*(W(i)+W(i+1))+1/2*sqrt(sagma*t)*g(i)    where g(i) is an independent N(0,1) sample. Please some one help. i have attached a file of the plot which I need.
Download 10597_10597_Brwonian Motion.doc
View file details
cheers
zhkhan
In my 3 D histogram the colums have a 1*1 base, so normally they would be labeled 1,2,3,4,5 on the x and the y axes but instead of this I want to label them 0.25,.05,0.75,1,1.25,1.5 and so on.......... Is there a way to do it?
Hi experts, I created a 3D histogram with(plots); with(LinearAlgebra); A := [[2],[3],[3],[4]]; matrixplot(A, heights = histogram, labels = [c1, c2, ExpectedProfit], tickmarks = [spacing(2), [seq(i, i = 0 .. 8, 3)], default], axes = normal) Now I want to assign a colour to each column. When the value is 2 of the Matrix it should be red for example, when it is 3 for example yellow and so on. Later Later I want to expand it to a Matrix with B[n,m]n=10 values... Thanks alot in advance for your help!
Hi to all,
I am new to maple. I want a maple procedure for the following Boundary values problem.
Download 10597_Elliptic PDE.doc
View file details
I installed maple 12 as root user successfully. But sometimes simple command like
1+1 or any command takes a long time to complete. After a long delay maple
displays result. It's happening very often and it's annoying. I'm using Debian
Etch, kernel 2.16.8-custom.
First 348 349 350 351 352 353 354 Last Page 350 of 372
