To all,
I am trying to plot a procedure phi(beta, x) which uses dimensional units (length).  The code listed below returns an error message regarding "invalid units".  I have redefined the standard units to report length in inches, but I don't see why this should prevent me from plotting the procedure over a range of x (the procedure works when the arguments are specified discretely.  Thank you for your assistance.
Define constant beta:
I need mentorship and material that is going to assist me in how to use maple.
         I need help with this problem !!!!!!!!   My brain is turning to mashed patato's  Thank-You
  In a study on infants, one of the characteristics measured was head circumfrence. The mean head circumference of 15 infants was 34.6 centimeters (cm).
The data in the table represents the ages of the winners of an award for the past five years. Use the data to answer questions (D) and  (E)
39     40
48     48
42
> deq := diff(theta(t), t, t) = -g*sin(theta(t))/L;
I have a particular system of partial differential equations to which I want to apply a change of variables involving square roots using PDEtools[dchange]. The result turns out to be not in a simple form due to the square roots. Why is this so ? Is there a better way solving the problem than the one I am suggesting below ? The system of partial differential equations of interest is the following:
Hallo Everybody,
I hope someone can help me.
I want to solve numerically the diffusion equation,
          diff(csh(rh, t), t) = Dif*(diff(rh^2*(diff(csh(rh, t), rh)), rh))/(r0*rh^2)
          where "Dif" is the diffusivity and "r0" is the initial value of rh (the equations were normalized).
subject to the following boundary and initial conditions:
I'm using Maple V R4 for OS/2 (the last version available for OS/2), and have two software questions:
- How do I change the font used in the math expression bar?
In the present font, which is fixed width, the parentheses
and bracket symbols, () and [], are almost indistinguish-
able. I'd like to use another fixed-width font that does
not have this problem.
- There seems to be a limit to the number of characters that
the expression bar will hold, limiting the size of the ex-
pression appearing in a text setting. Is there a way to
increase this limit?
I’m using maple 11. In my problem, I’ve five axioms:
i am deriving lagrangian shape function symbolically for an 1-D element of order p in FEM....so the eleemnt will have p+1 nodes....
                                   N(k,i) = product((X-Xother)) / product(Xcurrent-Xother)
Hallo dear proffesionals of Maple
I use Debian 4.0 r3 version with gcc compiler v 4.xx
I have installed properly in my computer the Maple 11 version.
the problem is :
Does anyone here know of any Maple code (public, or in the Maple Library, or on www.mapleapps.com, etc) that implements alpha-beta pruning?
I would like to see some examples of how this can be implemented and used in Maple, and possibly learn from it.
I like the access to colors and pen size at the top of the drawing canvas.  But when I re-open a file that has a canvas, all the pen work reverts to the smallest width.  I tried opening the same worksheet in version 11 and the width of the pen was preserved; so the information must be in the file.  When I change the width of lines and arrows, that change is saved.
I am on a OS X 10.5.  Is this a bug or a feature?
I recently asked about HTTP Requests and found out it could be done with either a Socket or with the HTTP package. The reason I asked is that I would like to connect to Blackboard (Course Management System). I would like Bb to launch a Maple worksheet or maplet and then Maple to be able to insert grades into the Bb gradebook. Does anyone know how to do that?
Hello fellow digitheads, I'm running the spanking new Maple 12 and I would like to graph the rather harmless expression for wave motion a sin(x - v*t) When I type it in and bring up the Plot Builder assistant it gives me the option (among many) of making one variable the animation variable and the other two "slidable". When I hit "Plot" an "Interactive Parameter Maplet" pops up where I can slide the value of those parameters while it cycles through the animation.
First 354 355 356 357 358 359 360 Last Page 356 of 371
