is it possible to find why Maple fails to solve these two equations in two unknowns? Has this always been the case? I do not have older versions of Maple to check. The trace shows that it found solution but then itg says no solution was found. This is very strange.
17020
interface(version)
`Standard Worksheet Interface, Maple 2023.2, Windows 10, November 24 2023 Build ID 1762575`
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 1622. The version installed in this computer is 1618 created 2023, November 29, 17:28 hours Pacific Time, found in the directory C:\Users\Owner\maple\toolbox\2023\Physics Updates\lib\`
sol:=1/4*exp(-t) * (c2*(-1+exp(4*t)) + c1*(3+exp(4*t))):
expand(simplify(sol));
-(1/4)*c2/exp(t)+(1/4)*(exp(t))^3*c2+(3/4)*c1/exp(t)+(1/4)*(exp(t))^3*c1
eq1:=-3=eval(sol,t=4):
expand(simplify(eq1));
-3 = (1/4)*c1*exp(12)+(1/4)*c2*exp(12)+(3/4)*exp(-4)*c1-(1/4)*exp(-4)*c2
eq1:=-17=eval(diff(sol,t),t=4);
-17 = -(1/4)*exp(-4)*(c2*(-1+exp(16))+c1*(3+exp(16)))+(1/4)*exp(-4)*(4*c2*exp(16)+4*c1*exp(16))
-17 = (1/4)*exp(-4)*c2+(3/4)*c2*exp(12)-(3/4)*exp(-4)*c1+(3/4)*c1*exp(12)
infolevel[solve]:=5;
solve([eq1,eq2],[c1,c2])
Main: Entering solver with 2 equations in 2 variables
Main: attempting to solve as a linear system
Linear: solving 2 linear equations
Algebraic: # equations is: 2
Main: Linear solver successful. Exiting solver returning 1 solution
solve: Warning: no solutions found
Download unable_to_solve_2_equations_dec_26_2023.mw
For reference this is the solution given by Mathematica
Please help to plot this equation
fwf-v.mw
Greetings! I need a maple code of logarithm of residuals for graphical comparison of iterative methods. Can anyone help me out by sharing a code comparing log of residuals of 2 or 3 iterative methods?
I have this image on a vase and I want to flatten it using Maple to see how it would look on a flat piece of paper.  How can we go about it.
The image is attached.
Image1-Greek.zip
I am trying to decompose an isprime into sum of 2 squares.
Can you tell me why yhse procedure are not goog.
Sumof2Squares:= proc(p::And(prime, satisfies(p-> irem(p,4)=1)))
local x, y:= 1;
   x:= mods(Roots(x^2+y^2), p)[2,1];
   while x^2+y^2 > p do
      (x,y):= FermatDescent(x,y,p)
   (x,y)
FermatDescent:= proc(x::posint, y::posint, p::posint)
local
   m:= (x^2+y^2)/p,
   a:= mods(x,m),
   b:= mods(y,m);
   (abs((a*x+b*y)/m), abs((a*y-b*x)/m))
trace(FermatDescent);
Sumof2Squares(1973);
How to solve this type of ode in maple
need the value of S, Q, E
When there are print commands in a loop their content is printed as soon as this command is executed.
This is not the case with printf whose displays are delayed (buffered?).
Is there a way to force the display of printf when the command is executed?
TIA
Motivation: I want to display intermediate execution times in a prettier way than print offers.
I thought I was improving my code by adding ::type to all the _self in my OOP code. As this is one main advantage in programming in Maple, which is being able to attach types to all name and variables. Make code more robust.
But it turned out Maple is not very happy now and gives that drearded error
    Error, static procedure ... refers to non-static local or export ... in surrounding scope
Only place I found that adding ::type_name is to _self is allowed, is on the constructor signature.
But in no other method of the object module. local or export method, it does not matter.
My question is, why is that?
So I went and removed all those _self::type_name and made it just _self to make Maple happy.
I also noticed this happes regardless of having kernelopts('assertlevel'=2): there or not.  Attached  is the worksheet.
Just tryting to understand the logic, that is all.
This is using Maple 2023.2.1
interface(version)
interface(warnlevel=4);
A:=module()
  export module person()
   option object;
   local m_name::string;
   local m_age::integer;
   export ModuleCopy::static:=proc(_self::A:-person,proto::A:-person,name::string,age::integer,$)
          _self:-m_age := age;
          _self:-m_name:=name;
          NULL;
   export name::static:=proc(_self,$) m_name; end proc;
   export age::static:=proc(_self,$) m_age; end proc;
 end module;
export  module young_person()
   option object;
   local m_person::A:-person;
   export ModuleCopy::static:=proc(_self::A:-young_person,proto::A:-young_person,p::A:-person,$)
          _self:-m_person := p;
          _self:-process_it();
   local process_it::static:=proc(_self,$)
         print(m_person:-name());
         print(m_person:-age());
   #to fix the problem, check _self::A... to just _self,  then no error!
   export process_it_from_outside::static:=proc(_self::A:-young_person,$)
end module;
end module;
_m2782933017664
o:=Object(A:-person,"me",99);
module person () local m_name::string, m_age::integer; option object; end module
p:=Object(A:-young_person,o);
Error, static procedure `young_person:-process_it_from_outside` refers to non-static local or export `young_person:-m_person::A:-person` in surrounding scope
Download why_adding_type_on_self_gives_error.mw
I just got an email saying a maple primes moderator deleted my question as 'SPAM'. It was not remotely SPAM but a strraight forward question about how to determine lengths of lines drawn in Maple Sketcher.
The email tells me and gives me a link to 'contact' but it's not clear which of the many possible contacts listed to use!
Here's the email:
Your MaplePrimes post Length of a line drawn in Sketcher? was deleted by a moderator for the following reason: Spam. If you believe this was done in error, please contact Maplesoft customer service: https://www.maplesoft.com/contact.
I am an ophthalmologist and a novice in programing. I am having a problem obtaining the x-y coordinate equations for each of the fitted Splines.  I can send the raw data and MapleSoft work sheet for which I need the individual spline equations, in x-y coodinates not parametric format and also need to be able to plot the splines on the raw data. I will pay for the service. Can you please obtain the x-y Cartesian equations for each of the fitted Splines and give me a step-wise method for obtaining them?  I am unable to attach the raw data and the worksheet to this email.  Please send me your personal email so that I can send them.
Your assistance is most appreciated.
With my best,
Ron
Ronald A Schachar MD , PhD
7241 Encelia Drive
La Jolla, CA 92037
Cell: (858) 784-1705
Email: ron@2ras.com
WHen using _self in object, help says
"As of Maple 2021, if the method has a formal parameter named _self, references
to its object's local or exported variables may be written without prefixing them.
That is, _self:-variable may be written as just variable. Maple will
add the self:- prefix internally when the method is simplified."
And the above is true for all static methods inside an object module, except for ModuleCopy which is also static.
It seems ModuleCopy is special. But why?  I am thinking it is because at time this is called, the object itself does not yet exist, but for all other methods, the object by then is fully constructed. But wanted to be sure.
Here is an example
person := module()
option object;
export ModuleCopy :: static := proc(_self :: person
                                   , proto :: person, name::string, age::integer,$
         m_age := age;
         m_name := name;
export name::static:= proc(_self, $);
    RETURN(m_name); #no need to write _self:-m_name;
export age::static:= proc(_self, $);
    RETURN(m_age); #no need to write _self:-m_age;
export set_name::static:= proc(_self, name, $);
    m_name := name;   #no need to write _self:-m_name := name
    NULL;
export process::static:=proc(_self,$)
   print("name is ",m_name," age is ",m_age);
end module:
And now
o:=Object(person,"me",10);
Error, static procedure `ModuleCopy` refers to non-static local or export `m_age::integer` in surrounding scope
Changing ModuleCopy to
         _self:-m_name := name;
Now there is no error. But notice that in all other static methods, I can write  m_name directly without using _self:-m_name;
I looked at help page for ModuleCopy but see no mention of this.
Why ModuleCopy is different?
Maple 2023.2 on windows 10
%fig1
%s1=sbeta./sgamma; sg= with gamma; sb= with beta; c=etar./eta;
%sigma=a./b;ur=uhat;
r=0.4:0.000001:1;
b1=0.0;b2=0.0;s=10000;sb=0;s1=sb./s;j=0;EZ=1;zeta0=-1;beta=1;i=(-1).^(1./2);
alpha=0.628; sigma=0.4; ur=0;
k=10;c=0.0000001;
%k1=k.^2.*zeta0./(1+c);
T1=(1+c)./(2.*s.*(i.*alpha.^2.*j-4.*c));
T2=(4.*s.*c-i.*alpha.^2)./(1+c);
r11=(4.*s.*c+i.*alpha.^2.*(c-j.*s.*(1+c)))./(c.*(1+c));r22=alpha.^2.*s.*(4.*i.*c+alpha.^2.*j)./(c.*(1+c));
alpha11=((1./2).*(r11+(r11.^2-4.*r22).^(1./2))).^(1./2);alpha12=-((1./2).*(r11+(r11.^2-4.*r22).^(1./2))).^(1./2);
alpha22=((1./2).*(r11-(r11.^2-4.*r22).^(1./2))).^(1./2);alpha21=-((1./2).*(r11-(r11.^2-4.*r22).^(1./2))).^(1./2);
KK=-(k1.*(k.^2-s.*(4-i.*alpha.^2.*j.*c.^(-1))))./(k.^4-(r11).*k.^2+r22);
A1=(beta*besselk(0, k)-besselk(0, k.* sigma))./(besseli(0, k.* sigma).*besselk(0, k )-besselk(0, k.* sigma).*besseli(0, k));
B1=(besseli(0, k.* sigma)-beta.*besseli(0, k))./(besseli(0, k.* sigma).*besselk(0, k )-besselk(0, k.* sigma).*besseli(0, k));
c1 = (((T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((-T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ) .* ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))))) ./ (((-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) - (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) .* (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) - (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)));
c2 = (((-T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ) .* ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))))) ./ (((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) - (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)));
c3 = (((T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((-T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) - ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ)) ./ (((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) - (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) .* ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) - ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)));
c4 = (((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ) .* ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))))) ./ (((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) .* ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))));
u1 = c1 .* besselk(0, alpha11 .* r) + c2 .* besseli(0, alpha12 .* r) + c3 .* besselk(0, alpha22 .* r) + c4 .* besseli(0, alpha21 .* r) + KK .* EZ .* A1 .* besseli(0, k .* r) + KK .* EZ .* B1 .* besselk(0, k .* r) + ur ./ (i*alpha .^ 2);
%nu1 = -T1 .* alpha11 .* besselk(1, alpha11 .* r) .* (alpha11 .^ 2 + T2) .* c1 + T1 .* alpha12 .* besseli(1, alpha12 .* r) .* (alpha12 .^ 2 + T2) .* c2 - T1 .* alpha22 .* besselk(1, alpha22 .* r) .* (alpha22 .^ 2 + T2) .* c3 + T1 .* alpha21 .* besseli(1, alpha21 .* r) .* (alpha21 .^ 2 + T2) .* c4 + T1 .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(1, k .* r) - B1 .* besselk(1, k .* r));
%tr1 = -besselk(1, alpha11 .* r) .* alpha11 .* (2 .* T1 .* c .* alpha11 .^ 2 + 2 .* T1 .* T2 .* c + c + 1) .* c1 + besseli(1, alpha12 .* r) .* alpha12 .* (2 .* T1 .* c .* alpha12 .^ 2 + 2 .* T1 .* T2 .* c + c + 1) .* c2 - besselk(1, alpha22 .* r) .* alpha22 .* (2 .* T1 .* c .* alpha22 .^ 2 + 2 .* T1 .* T2 .* c + c + 1) .* c3 + besseli(1, alpha21 .* r) .* alpha21 .* (2 .* T1 .* c .* alpha21 .^ 2 + 2 .* T1 .* T2 .* c + c + 1) .* c4 + EZ .* k .* (2 .* KK .* T1 .* c .* k .^ 2 + 2 .* KK .* T1 .* T2 .* c + 2 .* T1 .* c .* k1 + KK .* c + KK) .* (A1 .* besseli(1, k .* r) - B1 .* besselk(1, k .* r));
%m1 = T1 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* r) .* alpha11 .* r + s1 .* besselk(1, alpha11 .* r) + besselk(1, alpha11 .* r)) ./ r .* c1 - T1 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* r) .* alpha12 .* r + s1 .* besseli(1, alpha12 .* r) + besseli(1, alpha12 .* r)) ./ r .* c2 + T1 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* r) .* alpha22 .* r + s1 .* besselk(1, alpha22 .* r) + besselk(1, alpha22 .* r)) ./ r .* c3 - T1 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* r) .* alpha21 .* r + s1 .* besseli(1, alpha21 .* r) + besseli(1, alpha21 .* r)) ./ r .* c4 - T1 .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* r) .* k .* r - B1 .* besselk(0, k .* r) .* k .* r + A1 .* besseli(1, k .* r) .* s1 - B1 .* besselk(1, k .* r) .* s1 + A1 .* besseli(1, k .* r) - B1 .* besselk(1, k .* r)) ./ r;
k=40;c=0.0000001;
k1=k.^2.*zeta0./(1+c);
T1=(1+c)./(2.*s.*(i.*alpha.^2.*j-4.*c));
T2=(4.*s.*c-i.*alpha.^2)./(1+c);
r11=(4.*s.*c+i.*alpha.^2.*(c-j.*s.*(1+c)))./(c.*(1+c));r22=alpha.^2.*s.*(4.*i.*c+alpha.^2.*j)./(c.*(1+c));
alpha11=((1./2).*(r11+(r11.^2-4.*r22).^(1./2))).^(1./2);alpha12=-((1./2).*(r11+(r11.^2-4.*r22).^(1./2))).^(1./2);
alpha22=((1./2).*(r11-(r11.^2-4.*r22).^(1./2))).^(1./2);alpha21=-((1./2).*(r11-(r11.^2-4.*r22).^(1./2))).^(1./2);
KK=-(k1.*(k.^2-s.*(4-i.*alpha.^2.*j.*c.^(-1))))./(k.^4-(r11).*k.^2+r22);
A1=(beta*besselk(0, k)-besselk(0, k.* sigma))./(besseli(0, k.* sigma).*besselk(0, k )-besselk(0, k.* sigma).*besseli(0, k));
B1=(besseli(0, k.* sigma)-beta.*besseli(0, k))./(besseli(0, k.* sigma).*besselk(0, k )-besselk(0, k.* sigma).*besseli(0, k));
c1 = (((T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((-T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ) .* ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))))) ./ (((-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) - (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) .* (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) - (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)));
c2 = (((-T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ) .* ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))))) ./ (((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) - (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)));
c3 = (((T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((-T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) - ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ)) ./ (((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) - (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) .* ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) - ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)));
c4 = (((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ) .* ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))))) ./ (((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) .* ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))));
u2 = c1 .* besselk(0, alpha11 .* r) + c2 .* besseli(0, alpha12 .* r) + c3 .* besselk(0, alpha22 .* r) + c4 .* besseli(0, alpha21 .* r) + KK .* EZ .* A1 .* besseli(0, k .* r) + KK .* EZ .* B1 .* besselk(0, k .* r) + ur ./ (i.*alpha .^ 2);
%nu1 = -T1 .* alpha11 .* besselk(1, alpha11 .* r) .* (alpha11 .^ 2 + T2) .* c1 + T1 .* alpha12 .* besseli(1, alpha12 .* r) .* (alpha12 .^ 2 + T2) .* c2 - T1 .* alpha22 .* besselk(1, alpha22 .* r) .* (alpha22 .^ 2 + T2) .* c3 + T1 .* alpha21 .* besseli(1, alpha21 .* r) .* (alpha21 .^ 2 + T2) .* c4 + T1 .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(1, k .* r) - B1 .* besselk(1, k .* r));
%tr1 = -besselk(1, alpha11 .* r) .* alpha11 .* (2 .* T1 .* c .* alpha11 .^ 2 + 2 .* T1 .* T2 .* c + c + 1) .* c1 + besseli(1, alpha12 .* r) .* alpha12 .* (2 .* T1 .* c .* alpha12 .^ 2 + 2 .* T1 .* T2 .* c + c + 1) .* c2 - besselk(1, alpha22 .* r) .* alpha22 .* (2 .* T1 .* c .* alpha22 .^ 2 + 2 .* T1 .* T2 .* c + c + 1) .* c3 + besseli(1, alpha21 .* r) .* alpha21 .* (2 .* T1 .* c .* alpha21 .^ 2 + 2 .* T1 .* T2 .* c + c + 1) .* c4 + EZ .* k .* (2 .* KK .* T1 .* c .* k .^ 2 + 2 .* KK .* T1 .* T2 .* c + 2 .* T1 .* c .* k1 + KK .* c + KK) .* (A1 .* besseli(1, k .* r) - B1 .* besselk(1, k .* r));
%m1 = T1 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* r) .* alpha11 .* r + s1 .* besselk(1, alpha11 .* r) + besselk(1, alpha11 .* r)) ./ r .* c1 - T1 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* r) .* alpha12 .* r + s1 .* besseli(1, alpha12 .* r) + besseli(1, alpha12 .* r)) ./ r .* c2 + T1 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* r) .* alpha22 .* r + s1 .* besselk(1, alpha22 .* r) + besselk(1, alpha22 .* r)) ./ r .* c3 - T1 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* r) .* alpha21 .* r + s1 .* besseli(1, alpha21 .* r) + besseli(1, alpha21 .* r)) ./ r .* c4 - T1 .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* r) .* k .* r - B1 .* besselk(0, k .* r) .* k .* r + A1 .* besseli(1, k .* r) .* s1 - B1 .* besselk(1, k .* r) .* s1 + A1 .* besseli(1, k .* r) - B1 .* besselk(1, k .* r)) ./ r;
k=70;c=.0000001;
k1=k.^2.*zeta0./(1+c);
T1=(1+c)./(2.*s.*(i.*alpha.^2.*j-4.*c));
T2=(4.*s.*c-i.*alpha.^2)./(1+c);
r11=(4.*s.*c+i.*alpha.^2.*(c-j.*s.*(1+c)))./(c.*(1+c));r22=alpha.^2.*s.*(4.*i.*c+alpha.^2.*j)./(c.*(1+c));
alpha11=((1./2).*(r11+(r11.^2-4.*r22).^(1./2))).^(1./2);alpha12=-((1./2).*(r11+(r11.^2-4.*r22).^(1./2))).^(1./2);
alpha22=((1./2).*(r11-(r11.^2-4.*r22).^(1./2))).^(1./2);alpha21=-((1./2).*(r11-(r11.^2-4.*r22).^(1./2))).^(1./2);
KK=-(k1.*(k.^2-s.*(4-i.*alpha.^2.*j.*c.^(-1))))./(k.^4-(r11).*k.^2+r22);
A1=(beta*besselk(0, k)-besselk(0, k.* sigma))./(besseli(0, k.* sigma).*besselk(0, k )-besselk(0, k.* sigma).*besseli(0, k));
B1=(besseli(0, k.* sigma)-beta.*besseli(0, k))./(besseli(0, k.* sigma).*besselk(0, k )-besselk(0, k.* sigma).*besseli(0, k));
c1 = (((T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((-T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ) .* ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))))) ./ (((-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) - (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) .* (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) - (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)));
c2 = (((-T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ) .* ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))))) ./ (((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) - (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)));
c3 = (((T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((-T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) - ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ)) ./ (((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) - (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) .* ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) - ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)));
c4 = (((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ) .* ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))))) ./ (((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) .* ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))));
u3 = c1 .* besselk(0, alpha11 .* r) + c2 .* besseli(0, alpha12 .* r) + c3 .* besselk(0, alpha22 .* r) + c4 .* besseli(0, alpha21 .* r) + KK .* EZ .* A1 .* besseli(0, k .* r) + KK .* EZ .* B1 .* besselk(0, k .* r) + ur ./ (i.*alpha .^ 2);
%nu1 = -T1 .* alpha11 .* besselk(1, alpha11 .* r) .* (alpha11 .^ 2 + T2) .* c1 + T1 .* alpha12 .* besseli(1, alpha12 .* r) .* (alpha12 .^ 2 + T2) .* c2 - T1 .* alpha22 .* besselk(1, alpha22 .* r) .* (alpha22 .^ 2 + T2) .* c3 + T1 .* alpha21 .* besseli(1, alpha21 .* r) .* (alpha21 .^ 2 + T2) .* c4 + T1 .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(1, k .* r) - B1 .* besselk(1, k .* r));
%tr1 = -besselk(1, alpha11 .* r) .* alpha11 .* (2 .* T1 .* c .* alpha11 .^ 2 + 2 .* T1 .* T2 .* c + c + 1) .* c1 + besseli(1, alpha12 .* r) .* alpha12 .* (2 .* T1 .* c .* alpha12 .^ 2 + 2 .* T1 .* T2 .* c + c + 1) .* c2 - besselk(1, alpha22 .* r) .* alpha22 .* (2 .* T1 .* c .* alpha22 .^ 2 + 2 .* T1 .* T2 .* c + c + 1) .* c3 + besseli(1, alpha21 .* r) .* alpha21 .* (2 .* T1 .* c .* alpha21 .^ 2 + 2 .* T1 .* T2 .* c + c + 1) .* c4 + EZ .* k .* (2 .* KK .* T1 .* c .* k .^ 2 + 2 .* KK .* T1 .* T2 .* c + 2 .* T1 .* c .* k1 + KK .* c + KK) .* (A1 .* besseli(1, k .* r) - B1 .* besselk(1, k .* r));
%m1 = T1 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* r) .* alpha11 .* r + s1 .* besselk(1, alpha11 .* r) + besselk(1, alpha11 .* r)) ./ r .* c1 - T1 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* r) .* alpha12 .* r + s1 .* besseli(1, alpha12 .* r) + besseli(1, alpha12 .* r)) ./ r .* c2 + T1 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* r) .* alpha22 .* r + s1 .* besselk(1, alpha22 .* r) + besselk(1, alpha22 .* r)) ./ r .* c3 - T1 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* r) .* alpha21 .* r + s1 .* besseli(1, alpha21 .* r) + besseli(1, alpha21 .* r)) ./ r .* c4 - T1 .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* r) .* k .* r - B1 .* besselk(0, k .* r) .* k .* r + A1 .* besseli(1, k .* r) .* s1 - B1 .* besselk(1, k .* r) .* s1 + A1 .* besseli(1, k .* r) - B1 .* besselk(1, k .* r)) ./ r;
k=100;c=.0000001;
k1=k.^2.*zeta0./(1+c);
T1=(1+c)./(2.*s.*(i.*alpha.^2.*j-4.*c));
T2=(4.*s.*c-i.*alpha.^2)./(1+c);
r11=(4.*s.*c+i.*alpha.^2.*(c-j.*s.*(1+c)))./(c.*(1+c));r22=alpha.^2.*s.*(4.*i.*c+alpha.^2.*j)./(c.*(1+c));
alpha11=((1./2).*(r11+(r11.^2-4.*r22).^(1./2))).^(1./2);alpha12=-((1./2).*(r11+(r11.^2-4.*r22).^(1./2))).^(1./2);
alpha22=((1./2).*(r11-(r11.^2-4.*r22).^(1./2))).^(1./2);alpha21=-((1./2).*(r11-(r11.^2-4.*r22).^(1./2))).^(1./2);
KK=-(k1.*(k.^2-s.*(4-i.*alpha.^2.*j.*c.^(-1))))./(k.^4-(r11).*k.^2+r22);
A1=(beta*besselk(0, k)-besselk(0, k.* sigma))./(besseli(0, k.* sigma).*besselk(0, k )-besselk(0, k.* sigma).*besseli(0, k));
B1=(besseli(0, k.* sigma)-beta.*besseli(0, k))./(besseli(0, k.* sigma).*besselk(0, k )-besselk(0, k.* sigma).*besseli(0, k));
c1 = (((T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((-T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ) .* ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))))) ./ (((-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) - (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) .* (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) - (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)));
c2 = (((-T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ) .* ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))))) ./ (((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) - (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)));
c3 = (((T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((-T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) - ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ)) ./ (((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) - (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) .* ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) - ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)));
c4 = (((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ) .* ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))))) ./ (((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) .* ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))));
u4 = c1 .* besselk(0, alpha11 .* r) + c2 .* besseli(0, alpha12 .* r) + c3 .* besselk(0, alpha22 .* r) + c4 .* besseli(0, alpha21 .* r) + KK .* EZ .* A1 .* besseli(0, k .* r) + KK .* EZ .* B1 .* besselk(0, k .* r) + ur ./ (i.*alpha .^ 2);
T = table2array(u1);
How can I draw Steiner trees of hypercubes in graph theory?
With the following steps
S1: Open Help pressing F1
S2: enter `if in the search field
S3: click a topic in the result list
S4: search within the topic with find/replace (Crtl f) the term `if
I get plenty of results where I cannot find the search term in the help topic. Why is that?
Is help ignoring the left single quotes ` ?
I don't think so: I get usefull results for `` and `i, which in the later case also lists the topic "ifelse" that contains `if in the textbody.
So, why does advanced searching with the exact phrase "`if" not list the "ifelse" topic?
Realted question:
Why does the search term "(* " not list the relevant help topic help(comment)?
Somehow related in the context of getting more specific results:
https://www.mapleprimes.com/questions/234462-Searching-The-Help-System-Why-Are-There-No-Hits-For-Solve
Are there any restrictions regarding path and filename length in Maple?
I am experiencing problems working with a file on a server, path and file length is 207 characters.
First 43 44 45 46 47 48 49 Last Page 45 of 371
