Hi, I'm looking to create a discovery activity to introduce the cosine . Any ideas for using Maple components with a slider to vary the position of a point on a line while displaying distances and their ratios? Thank you
Doc2.pdf
Can anyone assist with this error please?
#Clear memory and load package.
#Initialise variables,matrices and vectors.
b:=<<18>,<-2>>:
c:=<<1>,<1>>:
i:=0:
P:=<1.08,1.37,1.56,1.61>;
t:=<5,10,15,20>;
tol:=1e-6:
#Initialise Gauss-Newton matrices.
n:=Dimension(t):
f:=Matrix(n,1):
J:=Matrix(n,2):
#Display initial parameter values.
printf("Gauss-Newton Method\n");
printf("-------------------\n");
printf("Before iterations,A = %f and B = %f\n",b(1),b(2));
#Perform the Gauss-Newton method.
while max(abs(evalf(c)))>tol do
  i:=i+1;
  for r from 1 to n do
     f(r,1):=evalf((In(b(1)+t[r])+b(2))-P[r]);
     J(r,1):=evalf(1/b(1)+t[r]);
     J(r,2):=evalf(1);
c:=Multiply(MatrixInverse(Multiply(Transpose(J),J)),Multiply(Transpose(J),f));
b:=b-c;
printf("After iterations %d, A = %f and B = %f\n",i,b(1),b(2));
Vector(4, {(1) = 1.08, (2) = 1.37, (3) = 1.56, (4) = 1.61})
Vector[column](%id = 36893488152076174028)
Gauss-Newton Method
Before iterations,A = 18.000000 and B = -2.000000
After iterations 1, A =
Error, (in fprintf) number expected for floating point format
Download Asst_3_Q4b.mw
can you do groupwork on a single documet
Dear Colleagues,
I wish to use plot3d to the attached code but always encoutered error. However, pointplot3d runs perfectly. Please I need your assistance in this regards.
Thank you all and best regards.K2_Problem_2_two_body_kepler_e=0.mw
I have been having problem in solving this question because of the 'Whittaker'.
Can anyone please asist me how to integrate below problem with the 'Whitaker?
f := exp(-1.5*t)*(GAMMA(2)*t^(2-alpha)/GAMMA(3-alpha)-t^(1-alpha)/GAMMA(2-alpha)+t^2-t);
               /   (2 - alpha)        (1 - alpha)           \
               |  t                  t                 2    |
   exp(-1.5 t) |---------------- - ---------------- + t  - t|
               \GAMMA(3 - alpha)   GAMMA(2 - alpha)         /
int(f, t);
2.^(3.-1.*alpha)*3.^(alpha-3.)*(t^(-.5000000000*alpha)*3.^(-.5000000000*alpha)*2.^(.5000000000*alpha)*(alpha-3.)*(-2.+alpha)*exp(-.7500000000*t)*WhittakerM(-.5000000000*alpha, -.5000000000*alpha+.5000000000, 1.500000000*t)/(3.-1.*alpha)+t^(-.5000000000*alpha)*3.^(-.5000000000*alpha)*2.^(.5000000000*alpha)*(1.500000000*t-1.*alpha+2.)*(alpha-3.)*exp(-.7500000000*t)*WhittakerM(-.5000000000*alpha+1., -.5000000000*alpha+.5000000000, 1.500000000*t)/(3.-1.*alpha))/GAMMA(3.-1.*alpha)-1.*2.^(2.-1.*alpha)*3.^(-2.+alpha)*(t^(-.5000000000*alpha)*3.^(-.5000000000*alpha)*2.^(.5000000000*alpha)*exp(-.7500000000*t)*WhittakerM(-.5000000000*alpha, -.5000000000*alpha+.5000000000, 1.500000000*t)+t^(-.5000000000*alpha)*3.^(-.5000000000*alpha)*2.^(.5000000000*alpha)*(-2.+alpha)*exp(-.7500000000*t)*WhittakerM(-.5000000000*alpha+1., -.5000000000*alpha+.5000000000, 1.500000000*t)/(2.-1.*alpha))/GAMMA(2.-1.*alpha)+.1481481481+(0.9876543210e-1*(-6.750000000*t^2-9.*t-6.))*exp(-1.500000000*t)-(.2222222222*(-2.-3.*t))*exp(-1.500000000*t)
I clicked on the author's page link and was redirected to front page instead. Does this link work? Why does it not work for me?
How to define constants - MaplePrimes
I can import maple, but I get an error when importing namespace/symbols:
import maple.namespace as mpl
I'm having problems with my maple not saving. I get no error message and no windows pop up.
The error occurred after the summer holidays in Maple 2022. I use Windows 11, everything is up to date. Have no Anti-virus programs.
  I have tried the following after I discovered the error:
- To install Maple 2023
- Uninstall and delete all maple folders, then reinstall Maple 2023
- Pressed Ctrl + s
- Press "Save as..."
- Pressed on the floppy disk/save icon
- Restarted computer and updated windows
- Run Maple as administrator
The only thing I can be allowed to do is:
- Ctrl + p
- Print to PDF/printer
Really hope you can help!
I don't know where my last exchange with @mz6687  has been moved (not to the initial question  https://www.mapleprimes.com/questions/237066-Determinant-The-System-Hangs for what I see).
Nevertheless here is the reply I was sending to @mz6687  which ended with the message "Page not found".
Are_you_ok_with_that.mw
Could the one who moved the question meanwhile be so kind as to attach this reply?
TIA
For some of the users with eye problems like me, the white canvas is burning eyes out of sockets as the monitor needs to be close up. Even turning down the intensity do not work especially since all other applications on Linux can be configured to have a dark-theme, but NOT Maple it seems.
What is the reason for this resistance from Maple Developers to just ram this white canvas down our throats verion after version.
Users have been asking since about Maple 11 to change  this.
I mean, Maple is not exactly cheap, which would have been an excuse, and is formidable intellectual software, so "ability" should not be a problem
However am I to believe that just changing the canvas color, turns out to be  a serious intellectual challenge for developers ?
Google yields such custom canvas request spanning more than a decade, but users arrive at crickets and a dead end.
Please be kind and give us a customizable canvas or any DARK theme of your choice for users with visual challenges and the lots of normal users who also want a custom canvas color or dark theme. It is overdue.
At the moment I use the cumbersome table-solution with a gray background, which helps some, but it is clunky and no alternative for long term use as the window and bars itself are still white and distracts and defeats the objective somewhat.
`c₁₁`, `c₁₂`, `c₁₃`, `e₃₁`, `c₆₆`, `c₄₄`, `e₁₅`, rho, `&varepsilon;₁₁`, `&varepsilon;₃₃` = constants;
`U₁` := unapply(`U₁`(t, x, y, z), x, y, z, t);
`U₂` := unapply(`U₂`(t, x, y, z), x, y, x, t);
`U₃` := unapply(`U₃`(t, x, y, z), x, y, z, t);
phi := unapply(phi(t, x, y, z), x, y, z, t);
PDE1 := `c₁₁`*Diff(`U₁`, y, y) + `c₁₂`*Diff(`U₂`, x, y) + `c₁₃`*Diff(`U₃`, x, z) + `e₃₁`*Diff(phi, x, z) + `c₆₆`*Diff(`U₂`, x, y) + `c₆₆`*Diff(`U₁`, y, y) + `c₄₄`*Diff(`U₃`, x, z) + `c₄₄`*Diff(`U₁`, z, z) + `e₁₅`*Diff(phi, x, y) = rho*Diff(`U₁`, t, t);
PDE2 := `c₆₆`*Diff(`U₂`, x, y) + `c₆₆`*Diff(`U₁`, y, x) + `c₁₂`*Diff(`U₁`, x, y) + `c₁₁`*Diff(`U₂`, y, y) + `c₁₃`*Diff(`U₃`, y, z) + `e₃₁`*Diff(phi, z, y) + `c₄₄`*Diff(`U₃`, y, z) + `c₄₄`*Diff(`U₂`, y, z) + `e₁₅`*Diff(phi, y, z) = rho*Diff(`U₂`, t, t);
PDE3 := `c₄₄`*Diff(`U₃`, x, x) + `c₄₄`*Diff(`U₁`, z, x) + `e₁₅`*Diff(phi, y, x) + `c₄₄`*Diff(`U₃`, y, y) + `c₄₄`*Diff(`U₂`, z, y) + `e₁₅`*Diff(phi, y, y) + `c₁₃`*Diff(`U₁`, x, z) + `c₁₃`*Diff(`U₂`, y, z) + `c₃₃`*Diff(`U₃`, z, z) + `e₃₃`*Diff(phi, z, z) = rho*Diff(`U₃`, t, t);
PDE4 := `e₁₅`*Diff(`U₃`, x, x) + `e₁₅`*Diff(`U₁`, y, x) - `&varepsilon;₁₁`*Diff(phi, x, x) + `e₁₅`*Diff(`U₃`, yx y) + `e₁₅`*Diff(`U₂`, z, y) - `&varepsilon;₁₁`*Diff(phi, y, y) + `e₃₁`*Diff(`U₁`, y, z) + `e₃₁`*Diff(`U₂`, y, z) + `e₃₃`*Diff(`U₃`, x, z) - `&varepsilon;₃₃`*Diff(phi, z, z) = 0;
pds := [PDE1, PDE2, PDE3, PDE4];
sol := pdsolve(pds);
i was solving the above set of pde. but it was showing the following errors,
Error, (in U₁) too many levels of recursion
Error, (in unapply) variables must be unique and of type name
Error, (in U₃) too many levels of recursion
Error, (in phi) too many levels of recursion
Error, (in pdsolve/sys/info) required an indication of the solving variables for the given system
can anyone help me?
In help(EllipticF): Why is the parameter k not called “the modulus of the elliptic function” as in the definition of the inverse Jacobi functions in help(InverseJacobiPQ)?
Instead, it is called “the parameter” which can be confused with the parameter m=k^2 used in other notations (which is refered to "a parameter m" in the EllipticF help page).
Is there a reason for this, or should the parameter definitions of the first, second and thrid elliptic integrals not be aligned with the parameter definitions of the Jacobi functions and their inverses?
DLMF for example defines k as modulus for both, the Elliptic Integrals and the Jacobian Elliptic Functions.
A user who wants to transfer an expression from a different notation to Maple might misinterpret parameters.
The interrupt button is great for stopping long calculations. But if there is an accidental calculation of a long list that has a mistype for example and the computer is busy calculating behind the scenes getting ready to output to the screen (evaluating icon has a heartbeat) there is no interrupt for that.  You either wait for the output or kill maple and start again (you may be able to save the worksheet before you close it - that might be an option).
I am reading (and enjoying) this:
"On the computation of the nth decimal digit of various transcendental numbers" by
Simon Plouffe, 1996 (2009)
On the third page Simon calculates this:
a := 1/binomial(100, 50);
              a := ------------------------------
                   100891344545564193334812497256
ifactor(denom(a));
(8)  (81)  (11) (13) (17) (19) (29) (31) (53) (59) (61) (67) (71) (73) (79) (83) (89) (97)
and builds a sum of fractions where the above primefactors are the denominators in this sum.
5/8 + 20/81 + 10/11 + 2/13 + 13/17 + 10/19 + 4/29 + 5/31 + 23/53 + 41/59 + 29/61 + 37/67 + 33/71 +19/73 + 36/79 + 7/83 + 13/89 + 88/97
Solving a diophantine equation and using continued fractions are the steps to get that fractions (see link above).
May someone explain these steps to me ?
The following code effectively converts the image to the JPG format.
with(GraphTheory):
s:=DrawGraph(CompleteGraph(5),size=[250,250])
Export("D:\\s1.jpg",s)
But I would like to export it using PDF format. However, the modified code below seems to be quite unsuccessful. I am aware that Maple has export options in the front end, but I still prefer to use code for this purpose.
Export("D:\\s1.pdf",s)
Error, (in Export) invalid input: member received _ImportExport:-InfoTable["PDF"][4], which is not valid for its 2nd argument, s
There are two reasons for this.
with(GraphTheory):
Graphs:=[NonIsomorphicGraphs(6,8,output=graphs,outputform = graph)]:
num_g:=nops(Graphs):
num:=ceil((num_g)/5.):
M1:=Matrix (num,5,(i,j)->`if`((i-1)*5+j<=num_g, DrawGraph(Graphs[(i-1)*5+j],size=[250,250] ,overrideoptions ,showlabels=false,style=planar, stylesheet =  [
 vertexcolor     = orange
,vertexfontcolor = black
,vertexborder    = false
,edgethickness   = 0.6
,edgecolor       = MidnightBlue
,vertexshape     =  "circle"
,vertexfont      = [Arial, 4],
vertexthickness=5], caption = cat(H__,5*(i-1)+j),captionfont=["ROMAN",7]),plot(x = 0 .. 1, axes = none))):
DocumentTools:-Tabulate (M1[1..5,.. ],widthmode=percentage ,width=80 , exterior =all):
First 48 49 50 51 52 53 54 Last Page 50 of 372
