What is the best way to get some one on one training in maple , has anyone done this?
Download Analisa_Dinamik_Limb_v1_(30).mwAnalisa_Dinamik_Limb_v1_(30).mw
So I have an equation that basically takes the component of vectors to be used as an equation. The variables that I after are FB1z, FB2x, and FB3y For example here is my equation:
EOM1:=(AFB1[1]+AFB2[1]+AFB3[1])=TEOM[1]
EOM2:=(AFB1[2]+AFB2[2]+AFB3[2])=TEOM[2]
EOM3:=(AFB1[3]+AFB2[3]+AFB3[3])-TEOM[3]:
FBBp1:=FBPP1=(EulP1[1]+EulP2[1]+EulP3[1]):
FBBp2:=FBPP2=(EulP1[2]+EulP2[2]+EulP3[2]):
FBBp3:=FBPP3=(EulP1[3]+EulP2[3]+EulP3[3]):
However there are unknown variable in AFB2[1] named FB2x and AFB3[1] named FB3y. Then AFB1[2] has unknown equation named FB1z and AFB3[2] has FB3y and so on. While in my FBBp1,FBBp2,and FBBp3 holds all of the variable of FB1z, FB2x, and FB3x
I have tried to use 'solve' command to find the variable but my computer won't stop processing it:
sls:=solve({EOM1,EOM2,EOM3,FBBp1,FBBp2,FBBp3},{FB1z,FB2x,FB3y}):
I tried to use the Gauss-Elimination by forming a matrix but it doesn't work as well since I am really confused how to take out the variables out of the vector component.
zzz:=Matrix([0,AFB2[1],AFB3[1],jjj[1]],[AFB1[2],0,AFB3[2],jjj[2]],[AFB1[3],AFB2[3],0,jjj[3]],[FBP1[1],FBP2[1],FBP3[1],EulP[1]],[FBP1[2],FBP2[2],FBP3[2],EulP[2]],[FBP1[3],FBP2[3],FBP3[3],EulP[3]]):
GaussElimination:=(zzz)
I would be very grateful If someone could help me. Thankyou
Edit: here are the .txt files and .mpl files that required to run the program
Inverse_Kinematics_ADRIAN2.mw
RotInertiax0_ADRIAN.txt
Download DisplacementXYZ.txt
inersia_platfrom.txt
There is an .mpl file that I couldn't upload so I will upload it in the comments
According to the help manual...
To perform an action when the data table is updated, click the data table, and then, from the Data Table context panel, select Edit Content Changed Code to open the Code Editor dialog for the data table.
I am unable to make this work, nothing happens when I click on that button.
Edit - Component code - shows everything greyed out.
Any hints?
Since I've updated maple to version 2019 it's has become very slow. Erverytime I enter something it seems to reload all the side buttons just like when a new worksheet is started. This is very annoying because during this loading time you cannot enter anything. Has anyone any suggestions? btw I've bought my pc in march 2020 and it has enough CPU and GPU.
I am not able to get the proper integration results
Question_integration_eqn18.mw
Dm(A, p, i(t)) := A^gamma*(a-b*p+c*i(t))
Lsc := cl*(int(Dm(A, p, i(t))*(1-1/(1+delta(T-t))), t = t2 .. T))
cl*(int(A^gamma*(a-b*p+c*i(t))*(1-1/(1+delta(T-t))), t = t2 .. T))
simplify(Lsc)
cl*A^gamma*(int((a-b*p+c*i(t))*delta(T-t)/(1+delta(T-t)), t = t2 .. T))
subs(i(t) = (A^gamma*(-b*p+a)*ln(1+delta*(T-t))-R*delta)/delta, Lsc)
cl*(int(A^gamma*(a-b*p+c*(A^gamma*(-b*p+a)*ln(1+delta*(T-t))-R*delta)/delta)*(1-1/(1+delta(T-t))), t = t2 .. T))
simplify(%)
cl*(int(-(-A^(2*gamma)*c*(-b*p+a)*ln(1+delta*(T-t))+A^gamma*delta*(R*c+b*p-a))*delta(T-t)/(1+delta(T-t)), t = t2 .. T))/delta
Download Question_integration_eqn18.mw
So, here again, I'm still having this problem with Maple 2020 on Machbook OS 10.13.6 (all updates have been performed): Maple 2020 does not start. I see an icon appearing in the dock but it then disappears soon without showing anything like splash something. I reinstalled and restarted the copmuter several times, reactivated the software several times (always successful), and still I'm having the problem. I installed java and then it worked for one time, but after that the same problem happens and I'm still having this issue.
I went through steps suggestged in the help and arrived at JAVA reisntallation. What else can I try?
Please help me. Thanks.
Hiro
Suddently Maple 2020 (on Macbook) stops launching... I reinstalled it and restarted a couple of times.
Can someone give me some clues about what is causing this problem.
I really need it right now...
Hiro
doubt_1.mw
Hi, I am trying to solve two simultaneous equations (for t1) they are as follows-
eq 1
i__m2(0) = (-(-b*`#msub(mi("θ",fontstyle = "normal"),mi("m"))`+`#msub(mi("θ",fontstyle = "normal"),mi("m"))`^2-2*c)*exp(0)*a*N^alpha/`#msub(mi("θ",fontstyle = "normal"),mi("m"))`^3+(-c*t__2^2*`#msub(mi("θ",fontstyle = "normal"),mi("m"))`^2+b*t__2*`#msub(mi("θ",fontstyle = "normal"),mi("m"))`^2+2*c*t__2*`#msub(mi("θ",fontstyle = "normal"),mi("m"))`-b*`#msub(mi("θ",fontstyle = "normal"),mi("m"))`+`#msub(mi("θ",fontstyle = "normal"),mi("m"))`^2-2*c)*exp(`#msub(mi("θ",fontstyle = "normal"),mi("m"))`*t__2)*a*N^alpha/`#msub(mi("θ",fontstyle = "normal"),mi("m"))`^3)*exp(0)
eq 2
i__m1(t__1) = ((-c*t__1^2*`#msub(mi("θ",fontstyle = "normal"),mi("m"))`^2+b*t__1*`#msub(mi("θ",fontstyle = "normal"),mi("m"))`^2+2*c*t__1*`#msub(mi("θ",fontstyle = "normal"),mi("m"))`-b*`#msub(mi("θ",fontstyle = "normal"),mi("m"))`+`#msub(mi("θ",fontstyle = "normal"),mi("m"))`^2-2*c)*exp(`#msub(mi("θ",fontstyle = "normal"),mi("m"))`*t__1)*a*N^alpha*(lambda-1)/`#msub(mi("θ",fontstyle = "normal"),mi("m"))`^3-(-b*`#msub(mi("θ",fontstyle = "normal"),mi("m"))`+`#msub(mi("θ",fontstyle = "normal"),mi("m"))`^2-2*c)*a*N^alpha*(lambda-1)/`#msub(mi("θ",fontstyle = "normal"),mi("m"))`^3)*exp(-`#msub(mi("θ",fontstyle = "normal"),mi("m"))`*t__1)
rhs(i__m2(0) = (-(-b*theta__m+theta__m^2-2*c)*exp(0)*a*N^alpha/theta__m^3+(-c*t__2^2*theta__m^2+b*t__2*theta__m^2+2*c*t__2*theta__m-b*theta__m+theta__m^2-2*c)*exp(theta__m*t__2)*a*N^alpha/theta__m^3)*exp(0)) = rhs(i__m1(t__1) = ((-c*t__1^2*theta__m^2+b*t__1*theta__m^2+2*c*t__1*theta__m-b*theta__m+theta__m^2-2*c)*exp(theta__m*t__1)*a*N^alpha*(lambda-1)/theta__m^3-(-b*theta__m+theta__m^2-2*c)*a*N^alpha*(lambda-1)/theta__m^3)*exp(-theta__m*t__1))
solve({-(-b*theta__m+theta__m^2-2*c)*a*N^alpha/theta__m^3+(-c*t__2^2*theta__m^2+b*t__2*theta__m^2+2*c*t__2*theta__m-b*theta__m+theta__m^2-2*c)*exp(theta__m*t__2)*a*N^alpha/theta__m^3 = ((-c*t__1^2*theta__m^2+b*t__1*theta__m^2+2*c*t__1*theta__m-b*theta__m+theta__m^2-2*c)*exp(theta__m*t__1)*a*N^alpha*(lambda-1)/theta__m^3-(-b*theta__m+theta__m^2-2*c)*a*N^alpha*(lambda-1)/theta__m^3)*exp(-theta__m*t__1)}, [t__1]);
Can someone, please help. Thanks in advance.
How to install this old package for Maple 6 , should be trivial but turns te be out a puzzle with no result so far.
### This is the Maple initialization file created for use with the
### LAMP modules. For Maple 6 in Windows 95, 98, 2000, or NT, this file
### should be installed in the folder
###        C:\Program Files\Maple 6\BIN.WNT
### The last three letters, WNT, may vary with the version of Windows.
### The following lines set up libname, so Maple knows to look in the
### proper folder to find the Lamp library. If you did not put the
### Lamplib folder in C:\lamp6\lamplib, you must edit the first line.
lamppath := "C:\\lamp6\\lamplib\\":
libname := `lamppath`, libname:
### The following line enables one to use the command read(lampstart)
### to establish the Lamp environment. It is optional.
lampstart := cat(lamppath,"lamp.txt"):
I working on wavelets method to solve fractional partial differential equations. The problem when I solved and create a system of algebraic equation using Newton itertaion method the system not solved becuase its appear as amtrix forum when I substitute a collcetion points as follows :
for i from 1 to N do           # calculate left side of equ. at a collection points
    for j from 1 to N do
        ll[i,j]:=eval(q(T[i],T[j]));
ll:
sys := []:
                   # create the system of equations
    l[i,j]:= eval(ual(T[i],T[j])+ ubet(T[i],T[j])+uth(T[i],T[j])+ uwt(T[i],T[j]));
    sys:=[op(sys),(evalf(l[i,j]-ll[i,j]=0 ))]:
sys;
Coefficients:= fsolve(sys);
the results appears as:
[Vector[column](1, [0.92016313e-1+.38891735*c[1, 1]-.24496159000000003*c[2, 1]-.3889173499999999*c[1, 2]+.24496159000000003*c[2, 2]]) = 0., Vector[column](1, [-.9381081886+1.24805825*c[1, 1]-.66648505*c[2, 1]-.4702235500000001*c[1, 2]+.17656187000000007*c[2, 2]]) = 0., Vector[column](1, [2.131874035+.76110696*c[1, 1]-.12722801999999994*c[2, 1]-.76110696*c[1, 2]+.12722802*c[2, 2]]) = 0., Vector[column](1, [.355172452+1.5700572*c[1, 1]+.3444861000000001*c[2, 1]-0.47843280000000044e-1*c[1, 2]-.59894214*c[2, 2]]) = 0.]
please can you help me fix this problem
Hello to all, does anyone create an example for me that how to calculate and plot streamline of fluid flow.
I have a particular problem that I haven't managed to find the solution to by googling.
9/10 times that I open Maple 2020 I can't seem to open any of my saved documents. it opens the start tab, and I'm still able to open a new document or worksheet, but then when I try to change to text instead of math, it won't let me. I can type, but I can't press backspace or enter.
I have tried restarting and shutting down my computer, but every time I have to just force quit Maple because it won't respond half of the time and it won't quit normally.
I'm running the latest version of Maple and using macOS Catalina version 10.15.5.
How to plot the following functions?
plot(4*sqrt(L/g)*EllipticF(Pi/2, sin(theta0/2)), theta0 = 1 .. 20)
Hi. I have a relatively complicated inequality with three real variables. I was wondering how I can plot it three-dimensionally. The inequality is
0 <= -2*sqrt(4+2*a^2*(1-sqrt(1+8*alpha*m/a^3))/alpha)*(1+2*alpha*(2-a^2*(1-sqrt(1+8*alpha*m/a^3))/(2*alpha))/(3*a^2))/a
where \(a\) and \(m\) and non-negative, while \(alpha\) could have any value. I am using Maple 2017.
 Suppose that A is an m×n real matrix. The function TA:ℝn→ℝm   defined by
TA(x)=Ax,  for all 𝕩∈ℝn
     is a linear transformation.
let A=<< 87, -66, -90, 12, 48>|<-36, -40, -82, -54, 15>|<99, 79, 76, -31, 27>|<-69, 15, -10, 45, -9>>
and x= <9,-4,2,-17>.
Then TA(x)=   Preview
   Alternatively, you can copy your answer from your Maple worksheet and paste it to the answer box.
(b) Suppose now that the linear map T:ℝ2→ℝ3  is defined by, for all 𝕩=(x1,x2)∈ℝ2
 T(x)=  <<x1+6x2>|<−2x2>|<−4x1+2x2>>
     Enter the matrix M , in Maple syntax, in the box below such that T(x)=Mx  for all x∈ℝ2,
  M=    Preview
Can someone pls help me with this question. TIA.
First 105 106 107 108 109 110 111 Last Page 107 of 371
