I must do some formula manipulation
Classification of conic sections
restart; with(student):
A*x^2+B*y^2+C*x+D*y+E=0;
A*x^2+B*y^2+C*x+D*y+E = 0
f:= A*x^2+B*y^2+C*x+D*y+E;
completesquare(f, x);
A*(x+(1/2)*C/A)^2-(1/4)*C^2/A+B*y^2+D*y+E
ans:=Student[Precalculus][CompleteSquare]( (4), [y] );
B*(y+(1/2)*D/B)^2+A*x^2+C*x+E-(1/4)*D^2/B
ans1:=Student[Precalculus][CompleteSquare]( (4), [x] );
ans+ans1;
B*(y+(1/2)*D/B)^2+A*x^2+C*x+2*E-(1/4)*D^2/B+A*(x+(1/2)*C/A)^2-(1/4)*C^2/A+B*y^2+D*y
B*(y + D/(2*B))^2 + A*x^2 + C*x + 2*E - D^2/(4*B) + A*(x + C/(2*A))^2 - C^2/(4*A) + B*y^2 + D*y = 0;
B*(y+(1/2)*D/B)^2+A*x^2+C*x+2*E-(1/4)*D^2/B+A*(x+(1/2)*C/A)^2-(1/4)*C^2/A+B*y^2+D*y = 0
Now i must  get this form A( )^2 +B( )^2 = M
Download vraag_herleiding_conic_sections_formule.mw
Any chance to get a dataplot with units in one or both axis?
Or is this another thing where units are cause of trouble?
plotunits1.mw
I want to know if there is any option to convert the Maple code into MATLAB version to work across platforms. I have tried the code generation option in Maple and I could not understand how to use the single line code generated. I am working on an already written Maple code and conversion of code to use on both platforms is kind of important. Please advice me on the same.
Regards!
I like to show a domain as a roster of gridlines
The plotbuilder has not this option gridlines , so i must program this ?
How would you highlight specific numbers in a list?
For example, using
a:=[1,3,4,5,3,4,9,4,5,3,9,2,3,4,2,5,21,32,22,12,15,3,2,5,4]
Highlight all the 5's in the list to red for example like this
I'm willing to draw phase portrait for the equation of ode fifth order
u'''''+6(u'u'''+(u'')^2)-u'''(a+2b)=0
where a and b are arbitrary constant not equal to zero and (') represents derivative w.r.t  'x'.
We have just run into a problem (loss of data), when 2 users have opened the same workbook.
Does Maple support Multiuser access to a workbook, and if not - why isn't there any lock mechanism in place to prevent that?
I've asked about this 5 years ago
https://www.mapleprimes.com/questions/203628-Maple-2015-No-Longer-Autoscroll-As
And according to the reply there at the time, this is supposed to have been fixed in Maple 2015.1:
It appears that the scrolling issue has been fixed in the next version of Maple
But ever since then, whenever I use Maple, the worksheet do not auto-scroll as the program runs and prints outout to the screen. I have to keep using the mouse to move the bar down to see the latest prints.
Not only that, the bar itself (on the right side) shrinks in size as more outpout is printed.
It becomes smaller and smaller with time, and becomes very hard to grab it with the mouse since it become so thin.  Once all the output is deleted, the bar become long again.
So I think there is an option to enable autoscrolling somewhere.
But I am not able to find it. I looked at options, display, general and interface and see nothing there to turn it on.
Sometimes I get the feeling that the folks at Maplesoft do not use Maple interface the way we users use it, becuase this is such a basic interface problem and any one who uses Maple interface for more than one day must see these problems all the time.
So how come these are still not fixed?  Here is a screen shot showing the bar on the right after long print out, and showing how it was before.
I use only worksheet mode, not document mode. On windows 10.
Hi, I want to use Maple to derive the eigenvectors of a 3x3 matrix A. I can obtian the 3 eigenvalues correctly by using eigenvalues(A), and the results are "u, -a+u, a+u". But after inputing eigenvectors(A), I can only get "[-a+u, 1, {r}], [a+u, 1, {r}], [u, 1, {r}]". All the 3 eigenvectors are written as {r}, I dont know why...and how can I tranform {r} into visiable results?
I would be very appreciate if anyone could give me some help!
How to draw a circle transfomed by orthogonal affinity to oblique line and k ration ? Thank you.
 Help me please.  How can i simulate murmuration in maple.
Dear All.
I hope we are all staying safe.
Please I want to solve Sine Gordon Equation using a numerical method I constructed (non-classical), I need to compare the result of the method with the exact solution to generate the errors. However, since the exact solution has two variables, x, and t, I really don't know how to accommodate the two in my coding.
Can someone be of help in this regard?
Thank you and kind regards
Download Discretization_of_Sine_Gordon_Equation.mw
Download Sine_Gordon_Implementation_Trial.mw
Hi there,
Can someone explain to me why is it happening? If smaller equal than coloured well, if smaller then just the equal line appears. Why?
with(plots);
dm1 := .23; pm12 := .7; dm12 := .23;
inequal(pm1*(dm12+am21)-pm12*(dm1+am21) <= 0, pm1 = 0 .. 1, am21 = 0 .. 1, color = "Nautical 1");
inequal(pm1*(dm12+am21)-pm12*(dm1+am21) < 0, pm1 = 0 .. 1, am21 = 0 .. 1, color = "Nautical 1")
Thank you!
Hi ,
i want to find simple equation of rotate Ellipse  ( El1,EL2,El3 in the  worksheet), with calssic formula
Ideas? Thanks
QuestionConiqueRotation.mw
Etude d'un cas particulier a := 5: b := 7: k := 9: A := [a, 0]: B := [0, b]: #A et B fixes P := [t, 0]: Q := [0, k/t]:#P et Q 2 points mobiles cir := -a*x-b*y+x^2+y^2 = 0: sol := solve(subs(y = 5, cir), x): cen := [solve(diff(cir, x)), solve(diff(cir, y))]: x0 := sol[1]: y0 := 5: M := [x0, y0]: R := sqrt(cen[1]^2+cen[2]^2): beta := arctan(diff(solve(EQ(M, cen), y), x)): Recherche des valeurs de t pour que les 2 droites soient perpendiculaires eq := t^2*(y0-b)+t*(a*b-a*y0+b*x0-k)-x0*(a*b-k) = 0; sol := solve(eq, t); t := sol[1]; tp := sol[2]; P1 := [t, 0]; Q1 := [0, k/t]; PQ1 := simplify(x*(-a*b+b*t+k)+y*t*(t-a)-t*(-a*b+b*t+k)) = 0:#1ere tangente PQ2 := simplify(x*(-a*b+b*tp+k)+y*tp*(tp-a)-tp*(-a*b+b*tp+k)) = 0:#2ième tangente P2 := [tp, 0]; Q2 := [0, k/tp]; CIR := implicitplot(cir, x = -4 .. 8, y = -4 .. 12, color = red); Fig := proc (alpha) local Dr1, DR1, Dr2, DR2, N, u0, v0, Po, t, tp, sol; global a, b, k, cen, R; u0 := cen[1]+R*cos(alpha); v0 := cen[2]+R*sin(alpha); N := [u0, v0]; sol := solve(t^2*(v0-b)+t*(b*u0-a*v0+a*b-k)-u0*(a*b-k) = 0, t); t := sol[1]; tp := sol[2]; Dr1 := simplify(x*(-a*b+b*t+k)+y*t*(t-a)-t*(-a*b+b*t+k)) = 0; DR1 := implicitplot(Dr1, x = -4 .. 8, y = -4 .. 12, color = brown); Dr2 := simplify(x*(-a*b+b*tp+k)+y*tp*(tp-a)-tp*(-a*b+b*tp+k)) = 0; DR2 := implicitplot(Dr2, x = -4 .. 8, y = -4 .. 12, color = pink); Po := pointplot([N[]], symbol = solidcircle, color = [black], symbolsize = 8); display([Po, DR1, DR2]) end proc; DrPQ1 := implicitplot(PQ1, x = -4 .. 22, y = -4 .. 12, color = blue); DrPQ2 := implicitplot(PQ2, x = -4 .. 22, y = -4 .. 12, color = blue); Points := pointplot([A[], B[], M[], P1[], P2[], Q1[], Q2[], cen[]], symbol = solidcircle, color = [green], symbolsize = 10); T := plots:-textplot([[A[], "A"], [B[], "B"], [M[], "M"], [P1[], "P1"], [P2[], "P2"], [Q1[], "Q1"], [Q2[], "Q2"], [cen[], "cen"]], font = [times, 10], align = {below, left}); n := 19; display([seq(Fig(2*i*Pi/n), i = 0 .. n), Fig(beta), CIR, DrPQ1, DrPQ2, Points, T], scaling = constrained, size = [500, 500]); I would find out the focus of the ellipse. Thank you.
First 106 107 108 109 110 111 112 Last Page 108 of 371
