Not that I care about the virtual rating numbers here, but I am wondering why would one suddenly lose 15 point after posting a problem they found in Maple? Is this typical?
https://www.mapleprimes.com/questions/229443-Why-These-ODEs-Hang-Or-Return-Unsolved
3 hrs ago, I was 3001  and when I came to check on the status if any, now it says 2986.
Just wondering why, that is all. Again, this really does not bother me at all as I do not care about these virtual cloud credit points, and I only post here on occasions and when I found some problem. I just like to know why this happened just now, that is all.
Can anyone help me to frame the equations in Fractional Reduced Differential Transform Method
system of nonlinear ordinary differential equations
ds/ dt = b−γ s(t)− (δ s(t)(i(t) + βa(t)) /N − ε s(t) m(t)
de/ dt = δ (s(t)(i(t) + βa(t))/ N + ε s(t) m(t) − (1−ϑ) θ e(t) − ϑ α e(t) − γ e(t)
di/ dt = (1−ϑ) θ e(t) − (ρ + γ) i(t)
da/ dt = ϑ α e(t) − (σ + γ) a(t)
dr /dt = ρ i(t) + σ a(t) − γ r(t)
dm /dt = τ i(t) + κ a(t) − ω m(t)
choosing lightmodel=none and shading=none, produces a dark grey grided surface
plot3d(x*y, x = 0 .. 10, y = 0 .. 10, lightmodel = none, shading = none)
adding the style=wireframe option gives a blank plot.  Grid probably white?  Changing style to patchnogrid the surface is indeed white. However chosing both shading and style options to none regardless of the lightmodel will produce a plot that appears empty.  Is this to be expected?
However, just the style=wireframe option produces a colored grided wireframe as to expect
plot3d(x*y, x = 0 .. 10, y = 0 .. 10, lightmodel = none, style = wireframe)
Dear users
All my recent questions are removed by "mapleprimes" automatically. who knows the reason?
solve({l*(2*l^2*lambda^4*sigma*w*a[2]+l^2*lambda^2*mu*w*b[1]+6*l*lambda^2*m*sigma*a[0]^2-6*l*lambda^2*m*b[1]^2+6*l*m*mu^2*a[0]^2-l*lambda^2*rho*sigma*a[0]-l*mu^2*rho*a[0]+4*lambda^2*sigma*w*a[0]+4*mu^2*w*a[0]) = 0, l*(2*l^2*lambda^3*sigma*w*a[1]+6*l^2*lambda^2*mu*w*b[2]+2*l^2*lambda*mu^2*w*a[1]+12*l*lambda^2*m*sigma*a[0]*a[1]-12*l*lambda^2*m*b[1]*b[2]-l*lambda^2*rho*sigma*a[1]+12*l*m*mu^2*a[0]*a[1]-l*mu^2*rho*a[1]+4*lambda^2*sigma*w*a[1]+4*mu^2*w*a[1]) = 0, l*(5*l^2*lambda^3*sigma*w*b[2]-3*l^2*lambda^2*mu*sigma*w*a[1]-7*l^2*lambda*mu^2*w*b[2]-3*l^2*mu^3*w*a[1]+12*l*lambda^2*m*sigma*a[0]*b[2]+12*l*lambda^2*m*sigma*a[1]*b[1]-l*lambda^2*rho*sigma*b[2]+24*l*lambda*m*mu*b[1]*b[2]+12*l*m*mu^2*a[0]*b[2]+12*l*m*mu^2*a[1]*b[1]-l*mu^2*rho*b[2]+4*lambda^2*sigma*w*b[2]+4*mu^2*w*b[2]) = 0, l*(8*l^2*lambda^3*sigma*w*a[2]+6*l^2*lambda*mu^2*w*a[2]+12*l*lambda^2*m*sigma*a[0]*a[2]+6*l*lambda^2*m*sigma*a[1]^2+l^2*lambda*mu*w*b[1]-6*l*lambda^2*m*b[2]^2-l*lambda^2*rho*sigma*a[2]+12*l*m*mu^2*a[0]*a[2]+6*l*m*mu^2*a[1]^2-6*l*lambda*m*b[1]^2-l*mu^2*rho*a[2]+4*lambda^2*sigma*w*a[2]+4*mu^2*w*a[2]) = 0, -l*(4*l^2*lambda^3*mu*sigma*w*a[2]-l^2*lambda^3*sigma*w*b[1]+l^2*lambda*mu^2*w*b[1]-12*l*lambda^2*m*sigma*a[0]*b[1]+l*lambda^2*rho*sigma*b[1]-12*l*lambda*m*mu*b[1]^2-12*l*m*mu^2*a[0]*b[1]+l*mu^2*rho*b[1]-4*lambda^2*sigma*w*b[1]-4*mu^2*w*b[1]) = 0, 6*l^2*(l*lambda^2*sigma*w*a[2]+lambda^2*m*sigma*a[2]^2+l*mu^2*w*a[2]+m*mu^2*a[2]^2-lambda*m*b[2]^2) = 0, 2*l^2*(l*lambda^2*sigma*w*a[1]+6*lambda^2*m*sigma*a[1]*a[2]+3*l*lambda*mu*w*b[2]+l*mu^2*w*a[1]+6*m*mu^2*a[1]*a[2]-6*lambda*m*b[1]*b[2]) = 0, -2*l^2*(5*l*lambda^2*mu*sigma*w*a[2]-l*lambda^2*sigma*w*b[1]+5*l*mu^3*w*a[2]-6*lambda^2*m*sigma*a[1]*b[2]-6*lambda^2*m*sigma*a[2]*b[1]-l*mu^2*w*b[1]-6*lambda*m*mu*b[2]^2-6*m*mu^2*a[1]*b[2]-6*m*mu^2*a[2]*b[1]) = 0, 6*l^2*b[2]*(l*w+2*m*a[2]) = 0}, {a[0], a[1], a[2], b[1], b[2]});
{a[0] = 0, a[1] = 0, a[2] = 0, b[1] = 0, b[2] = 0},
   /       l rho - 4 w                                        \
  { a[0] = -----------, a[1] = 0, a[2] = 0, b[1] = 0, b[2] = 0 }
   \          6 l m                                           /
HOW TO WRITE BOX COUNTING DIMENSION IN FRCATAL
Hi.
I'm working on an electronics project currently. In that project I have been trying to solve a system of inequalities, as shown by the picture from Maple below:
R__1 := 1;
lign1 := V__i/(R__4*(1/R__1 + 1/R__2 + 1/R__3 + 1/R__4)) = C*(k__1 - R/R__C + R);
lign2 := V__i*(1/R__1 + 1/R__4)/(1/R__1 + 1/R__2 + 1/R__3 + 1/R__4) = C*(k__2 - R/R__C + R);
lign3 := V__i*(1/R__2 + 1/R__4)/(1/R__1 + 1/R__2 + 1/R__3 + 1/R__4) = C*(k__3 - R/R__C + R);
lign4 := V__i*(1/R__3 + 1/R__4)/(1/R__1 + 1/R__2 + 1/R__3 + 1/R__4) = C*(k__4 - R/R__C + R);
lign5 := V__i*(1/R__1 + 1/R__2 + 1/R__4)/(1/R__1 + 1/R__2 + 1/R__3 + 1/R__4) = C*(k__5 - R/R__C + R);
lign6 := V__i*(1/R__1 + 1/R__3 + 1/R__4)/(1/R__1 + 1/R__2 + 1/R__3 + 1/R__4) = C*(k__6 - R/R__C + R);
lign7 := V__i*(1/R__2 + 1/R__3 + 1/R__4)/(1/R__1 + 1/R__2 + 1/R__3 + 1/R__4) = C*(k__7 - R/R__C + R);
solve({lign1, lign2, lign3, lign4, lign5, lign6, lign7}, [R__4, R__2, R__3, R__C, R, C, V__i]);
Here's a picture as well:
However, the solution is simply that V_i = 0 and C=0, which is not really helping me. Am I doing something wrong here or is my system of equalities simply unsolvabe?
Can you please post the procedure for interfacing maple with visual molecular dynamics (VMD) software. Thank you.
I want to do the following: Suppose we are given a linear recurrence operator with polynomial coefficients say (n+2)N^2+(2n^2-3n+5)+(n-4) where N is the shift operator with respect to n. I want to apply the following substitution:
(i) N-> (N+1)
(ii) n->n(N^(-1)+1)
and compute the corresponding equation. To do this, I want to use Maple's Ore_Algebra package. However, I could not define N and N^(-1), i.e N inverse, at the same time.
To sum up, I want to get something like
A := Ore_Algebra(shift= [N,n] , dual_shift=[Ninv,n]); however it is not allowed.
Thanks, in advance.
I'm trying to upload a file to Maple Cloud for the first time, but I am getting an error due to the way I use libraries.
The first lines of the startup code in the sheet look like this.
libname := "S:/Maple/NODE_Library", libname;
with(NODETreMaterial);
with(NODETreTverrsnitt);
The libraries are on a network drive on our server.
The question is - how can I solve this? Would it be better to somehow upload those libraries to Maple Cloud (no idea how to do that by the way), or can it be solved in a different way?
When executing DEBUG within inline code (not within a procedure) the values displayed in successive debug windows (on clicking continue) are added to the end of my worksheet. How can the latter display be prevented?
is it possible to solve the attached partial differential equation with zero initial boundary condition?
If not by assuming diff(u(sigma, tau, phi, t), t, t)=0 is there an answer for the equation?
lapla.mw
Suppose two following Eqs.:
(1) du/dt+d(u*w)/dx=0
(2) dw/dt+wdw/dx=0
I want to expand u(x,t) and w(x,t) in the power series of epsilon
u=u0+epsilon*u1+epsilon^2*u2+…
w=w0+epsilon*w1+epsilon^2*w2+…
and change the variables x,t to X,T as follows
 X=(x-alpha*t) and T=beta*t,
and solving Eqs. (1) and (2) for different order of epsilon (epsilon, epsilon^2, epsilon^3,…) to finding u0,w0,u1,w1,…
How do I do that?
Maple 2020 offers many improvements motivated and driven by our users.
Maple 2018  has recently has  become sluggish to start up  -and very slow to respond to input. Can anyone suggest remedies?  I have plenty of space and CPU. Other apps seem to start fine.  Can any suggest a diagnosis and/or solution?
Melvin
First 110 111 112 113 114 115 116 Last Page 112 of 371
