Maple Tutors allow for copying of MathML but I need LaTeX of it. Any help please?
If we have an equation for the generalized Bloch sphere i.e.,
\partial_{t}(u^{2} + v^{2} + w^{2}) = 0,
where u, v and w are functions of x and t and the initial conditions u=v=0, w=-1. Then how to plot this equation on maple?
Being an absolut newbie to Maple I find some of the functions a bit strange and difficult.
One of the things is e.g. rounding numbers.
In Pyton and other languages it is quite simple and straightforward when rounding a number.
round(number, digits)
If you have digits = 0 then you get an integer, otherwise you get a number with the number of digits chosen.
In Maple the round function is just for rounding to an integer.
To round to something else currently I don't really know what I would use. There is the evalf function, which one can use like evalf[digits](number), but that doesn't give you the value with digits. It gives you a number with significant digits, which means, also including the numbers before the comma delimiter.
Python
round(15.76543,2) = 15.77
Maple
evalf[2](15.76543) = 16
Wouldn't it be much easier to expand the functionality of the round function in Maple?
"Frame your math" does not work on a new iPhone XS; however, surprisingly, it work just fine on an old iPad (4th gen).
I am logged in. The app has access to the camera. The companion app does allow manual entry of equation to upload to the Maple cloud.
I expect it's something simple--like some sort of permissions setting, but I cannot find it . . .
BTW: The error is "The request timed out. Check your Internet connection."
Noticed an issue with Vector and excel.  Not even really excel but I found it through that.
If I select a row in excel and do a copy paste into Maple it sometimes appears as if it's a list.  ie it shows up as [1,2,3,4]  other times it shows up as [ 1 2 3 4 ] signifying an array (for this example I've saved as the data under the variable a).  Running whattype(a) on the data shows they're both arrays.  Of course it's probably wise to instead load data through Excel into Maple by using the ExcelTools and Import option, however I didn't think there was no reason to use the copy paste option.  It does, to some extent, or maybe, well, it shows a limitation.
In the first instance when it shows up as a list, I thought it might be simple enough just to add other numbers in the list ie/ just tack on ,5,6,7,8 after the 4.  But after pressing enter we get the error
Error, invalid sequence
I don't understand why I couldn't just add to the copied data but maybe it's the formatting of the data that was pasted into maple?
With the original copied data, I can use with(plots):  listplot(a) no problem however, we want to add data.  ArrayTools will let us Append data to the vector
with(ArrayTools):
Append(a,5,6,7,8)
listplot(a) # will throw another error
                  Error, (in plots:-pointplot) points cannot be converted to floating-point values (this doesn't show in Maple 2019 but does come up in Maple 18)
For Maple 2019 it with responds with a returned array [ 1 2 3 4 5,6,7,8]
Running listplot on that Appended Array.  Maple only recognizes the next 1 added value.
So this means appending values using ArrayTools and Append only allows us to append one value at a time?  Is that a bug?  Are there better ways to append values to vectors?  The only solution for that is to convert to a list and use op to append more values.  But perhaps Maple should have understood the copied values from Excel should have been a list or listlist of values?
Hompotopy perturbation method
restart; with(LinearAlgebra);
PDEtools[declare](f(x), prime = x);
PDEtools[declare](g(x), prime = x);
N := 3;
F := sum(p^i*f[i](x), i = 0 .. N);
G := sum(p^i*g[i](x), i = 0 .. N);
FEq := (1-p)*(diff(F, x$3))+p*(diff(F, x$3)-(2*(diff(F, x$1))*(diff(F, x$1))-(5/2*F)*(diff(F, x$2))+M*(diff(F, x$1))) . A);
GEq := (1-p)*(diff(G, x$2))+p*(diff(G, x$2)+(5/2*(1/(1+R)) . Pr)*F*(diff(G, x$1)))*K(L);
M := 1;
A := (((1-W)^2.5*(1-W))*`ρf`+W*`ρt`)/`ρf`;
Pr := 6.2;
K := ((1-W)*`ρf`*Cf+W*`ρt`*Cs)/`ρf`;
L := .5;
`ρf` := 998.3;
`ρt` := 3970;
W := .2;
R := 1.0;
Cs := 765;
Cf := 4182;
coeff(FEq, p, 0);
coeff(GEq, p, 0);
for i from 0 to N do Fequ[i] := coeff(FEq, p, i) = 0 end do;
for i from 0 to N do Gequ[i] := coeff(GEq, p, i) = 0 end do;
Fcond[1][0] := f[0](0) = 0, (D(f[0]))(0) = 1, (D(f[0]))(5) = 0; for j to N do Fcond[1][j] := f[j](0) = 0, (D(f[j]))(0) = 0, (D(f[j]))(5) = 0 end do;
Gcond[0] := g[0](0) = 1, g[0](5) = 0; for j to N do Gcond[j] := g[j](0) = 0, g[j](5) = 0 end do;
for i from 0 to N do dsolve({Fequ[i], Fcond[1][i]}, f[i](x)); f[i](x) := rhs(%) end do;
for i from 0 to N do dsolve({Gcond[i], Gequ[i]}, g[i](x)); g[i](x) := rhs(%) end do;
Fa := simplify(sum(f[n](x), n = 0 .. N)); dFa := diff(Fa, x); subs(x = 2.4, dFa);
Ga := simplify(sum(g[n](x), n = 0 .. N)); dGa := diff(Ga, x); subs(x = 2.4, dGa);
plot(Ga, x = 0 .. 5);
plot(dFa, x = 0 .. 5);
ND sove solution
Eq1 := diff(F(x), x$3)-(2*(diff(F(x), x$1))*(diff(F(x), x$1))-(5/2*F(x))*(diff(F(x), x$2))+M*(diff(F(x), x$1))) . A = 0;
Eq2 := (diff(G(x), x$2)+(5/2*(1/(1+R)))*Pr*F(x)*(diff(G(x), x$1)))*K(L) = 0;
M := 1;
Pr := 6.2;
L := 1;
`ρf` := 998.3;
`ρt` := 3970;
W := .2;
R := 2.0;
Cs := 765;
Cf := 4182;
Cd1 := F(0) = 0, (D(F))(0) = 1, (D(F))(5) = 0;
dsys := {Cd1, Eq1};
dsol := dsolve(dsys, numeric, output = operator);
dsol(.1);
plots[odeplot](dsol, [x, diff(F(x), x$1)], 0 .. 5, color = green);
Cd2 := G(0) = 1, G(5) = 0;
dsys := {Cd1, Cd2, Eq1, Eq2};
plots[odeplot](dsol, [x, G(x)], 0 .. 5, color = green)
I find some book teach motion planning in topology
but do it need to formulate the equations for the environments such as a map with obstacle in 2d or 3D?  the environment is quite complex, how can these equations be formulated?
how do i Import part or all  PDF files into maple
I believe this was easier in older versions of maple or worked partially.
How I can pdsolve these equations in toroidal coordinates?
Initial conditions are arbitrary.
Please see attached pdf .
Where.pdf
Weston1958
Can old maple version saved .m files in window be readable in maple 2015 Linux version?
Hello (again)
I thought I won't need help with that type of question but I came across an example that says otherwise.  Here it is
vars:=[x,y,z];
model7 := [x*(-RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)-5/4)+y*alpha[1, 2]-33/(32*RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)), x*z*alpha[2, 6]+y*RootOf(64*_Z^3+80*_Z^2+1104*_Z+561), x^2*(17*RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)+17)/(alpha[1, 2]*alpha[2, 6])-17*x*y/alpha[2, 6]+2*z*x-z-(163/32+RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)^2+5*RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)*(1/4))/(alpha[1, 2]*alpha[2, 6])]
then I issued the command
map(w->coeffs(w,vars),model7);
to get
[-33/(32*RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)), -RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)-5/4, alpha[1, 2], RootOf(64*_Z^3+80*_Z^2+1104*_Z+561), alpha[2, 6], -(163/32+RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)^2+5*RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)*(1/4))/(alpha[1, 2]*alpha[2, 6]), -1, (17*RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)+17)/(alpha[1, 2]*alpha[2, 6]), -17/alpha[2, 6], 2]
clearly the order does not follow model7's.
I have also tried
[seq(coeffs(expand(model7[i]), indets(model7[i], suffixed({vars[]}))),i=1..nops(model7))];
Is there a solution to it?
Many thanks (again)
Ed
How to learn Maple Programming effectively, whether Python will help?
My objective is to write a procedure that will read data from xml at different mentioned condition, read ICBO value at different condition of VGS i.e ICBO value at VGS=5V
BJT_ICBO := proc(parsedXML, VGS at condition )
can some one help me to write procedure
kindly send me OHAM source code in Maple for PDEs. I need it.
Hi, can someone explain me why CodeGeneration in C throws the error : Error, (in Print) improper op or subscript selector ? Interestingly, CodeGeneration in Python or Matlab works. Source code is attached. Thanks in advance!
membrane_energy.mw
Membrane Energy
restart; with(VectorCalculus); with(LinearAlgebra); with(CodeGeneration)
Define variables
Vectors for vertices of current position
v1 := Vector(3, symbol = v1_i) = Vector[column]([[v1_i[1]], [v1_i[2]], [v1_i[3]]], ["x", "y", "z"])
v2 := Vector(3, symbol = v2_i) = Vector[column]([[v2_i[1]], [v2_i[2]], [v2_i[3]]], ["x", "y", "z"])NULL
v3 := Vector(3, symbol = v3_i) = Vector[column]([[v3_i[1]], [v3_i[2]], [v3_i[3]]], ["x", "y", "z"])NULL
n := `&x`(v2-v1, v3-v1)
v4 := v1+n/norm(n, 2)^.5
Vector for vertices of next position
v1n := Vector(3, symbol = v1n_i) = Vector[column]([[v1n_i[1]], [v1n_i[2]], [v1n_i[3]]], ["x", "y", "z"])NULL
v2n := Vector(3, symbol = v2n_i) = Vector[column]([[v2n_i[1]], [v2n_i[2]], [v2n_i[3]]], ["x", "y", "z"])NULL
v3n := Vector(3, symbol = v3n_i) = Vector[column]([[v3n_i[1]], [v3n_i[2]], [v3n_i[3]]], ["x", "y", "z"])NULL
nn := `&x`(v2n-v1n, v3n-v1n)
v4n := v1n+nn/norm(nn, 2)^.5``
Define Transformation
V := LinearAlgebra:-Transpose(Matrix([v2-v1, v3-v1, v4-v1]))
Dimension(V) = 3, 3
Vn := LinearAlgebra:-Transpose(Matrix([v2n-v1n, v3n-v1n, v4n-v1n]))
Dimension(Vn) = 3, 3NULL
Note we have Vn = T*V and if the current triangle is not degenerate, then T = Vn/V. As we can pre-compute 1/V we define a new matrix for it:
Vinv := Matrix(3, 3, symbol = Vinv_ij) =
Matrix(%id = 18446746713267339006)
(1.2.1)
T := MatrixMatrixMultiply(Vn, Vinv)
Dimension(T) = 3, 3``
Define Energy
E := Trace(MatrixMatrixMultiply(T, LinearAlgebra:-Transpose(T)))``
Gradient and Hessian
gradE := Gradient(E, [v1n[1], v1n[2], v1n[3], v2n[1], v2n[2], v2n[3], v3n[1], v3n[2], v3n[3]])
Dimension(gradE) = 9NULL
CodeGeneration[C](gradE, defaulttype = numeric, optimize = tryhard, functionprecision = double, precision = double, deducetypes = false, resultname = 'gradE')t1 = v2n_i[0] - v1n_i[0];
t2 = v2n_i[1] - v1n_i[1];
t3 = v2n_i[2] - v1n_i[2];
t4 = t1 * Vinv_ij[0][0] + t2 * Vinv_ij[1][0] + t3 * Vinv_ij[2][0];
t5 = t1 * Vinv_ij[0][1] + t2 * Vinv_ij[1][1] + t3 * Vinv_ij[2][1];
t6 = t1 * Vinv_ij[0][2] + t2 * Vinv_ij[1][2] + t3 * Vinv_ij[2][2];
t7 = v3n_i[0] - v1n_i[0];
t8 = v3n_i[1] - v1n_i[1];
t9 = v3n_i[2] - v1n_i[2];
t10 = t7 * Vinv_ij[0][0] + t8 * Vinv_ij[1][0] + t9 * Vinv_ij[2][0];
t11 = t7 * Vinv_ij[0][1] + t8 * Vinv_ij[1][1] + t9 * Vinv_ij[2][1];
t12 = t7 * Vinv_ij[0][2] + t8 * Vinv_ij[1][2] + t9 * Vinv_ij[2][2];
t13 = t2 * t9 - t3 * t8;
t14 = fabs(t13);
t15 = t1 * t9 - t3 * t7;
t16 = fabs(t15);
t17 = t1 * t8 - t2 * t7;
t18 = fabs(t17);
t19 = pow(t14, 0.2e1) + pow(t16, 0.2e1) + pow(t18, 0.2e1);
t20 = pow(t19, -0.5e1 / 0.4e1);
t19 = t19 * t20;
t21 = Vinv_ij[0][0] * t13;
t22 = Vinv_ij[1][0] * t15;
t23 = Vinv_ij[2][0] * t17;
t24 = (t23 + t21 - t22) * t19;
t25 = -v2n_i[2] + v3n_i[2];
t26 = fabs(t15) / t15;
t27 = -v2n_i[1] + v3n_i[1];
t28 = fabs(t17) / t17;
t21 = t23 + t21 - t22;
t22 = (t16 * t25 * t26 + t18 * t27 * t28) * t20;
t23 = 0.1e1 / 0.2e1;
t29 = Vinv_ij[0][1] * t13;
t30 = Vinv_ij[1][1] * t15;
t31 = Vinv_ij[2][1] * t17;
t32 = (t31 + t29 - t30) * t19;
t29 = t31 + t29 - t30;
t30 = Vinv_ij[0][2] * t13;
t15 = Vinv_ij[1][2] * t15;
t17 = Vinv_ij[2][2] * t17;
t31 = (t17 + t30 - t15) * t19;
t15 = t17 + t30 - t15;
t17 = t6 + t12;
t30 = t5 + t11;
t33 = t4 + t10;
t13 = fabs(t13) / t13;
t34 = -v2n_i[0] + v3n_i[0];
t35 = (t14 * t25 * t13 - t18 * t34 * t28) * t20;
t35 = t17 * Vinv_ij[1][2] - t24 * (t23 * t35 * t21 - t19 * (t25 * Vinv_ij[0][0] - t34 * Vinv_ij[2][0])) + t30 * Vinv_ij[1][1] - t31 * (t23 * t35 * t15 - t19 * (t25 * Vinv_ij[0][2] - t34 * Vinv_ij[2][2])) - t32 * (t23 * t35 * t29 - t19 * (t25 * Vinv_ij[0][1] - t34 * Vinv_ij[2][1])) + t33 * Vinv_ij[1][0];
t36 = (t14 * t27 * t13 + t16 * t34 * t26) * t20;
t34 = Vinv_ij[2][2] * t17 - t24 * (-t23 * t36 * t21 + t19 * (t27 * Vinv_ij[0][0] - t34 * Vinv_ij[1][0])) + t30 * Vinv_ij[2][1] - t31 * (-t23 * t36 * t15 + t19 * (t27 * Vinv_ij[0][2] - t34 * Vinv_ij[1][2])) - t32 * (-t23 * t36 * t29 + t19 * (t27 * Vinv_ij[0][1] - t34 * Vinv_ij[1][1])) + t33 * Vinv_ij[2][0];
t36 = (t16 * t9 * t26 + t18 * t8 * t28) * t20;
t36 = t24 * (-t23 * t36 * t21 - t19 * (-t8 * Vinv_ij[2][0] + t9 * Vinv_ij[1][0])) + t31 * (-t23 * t36 * t15 - t19 * (-t8 * Vinv_ij[2][2] + t9 * Vinv_ij[1][2])) + t32 * (-t23 * t36 * t29 - t19 * (-t8 * Vinv_ij[2][1] + t9 * Vinv_ij[1][1])) + t4 * Vinv_ij[0][0] + t5 * Vinv_ij[0][1] + t6 * Vinv_ij[0][2];
t37 = (t14 * t9 * t13 - t18 * t7 * t28) * t20;
t9 = t24 * (-t23 * t37 * t21 + t19 * (-t7 * Vinv_ij[2][0] + t9 * Vinv_ij[0][0])) + t31 * (-t15 * t23 * t37 + t19 * (-t7 * Vinv_ij[2][2] + t9 * Vinv_ij[0][2])) + t32 * (-t23 * t29 * t37 + t19 * (-t7 * Vinv_ij[2][1] + t9 * Vinv_ij[0][1])) + t4 * Vinv_ij[1][0] + t5 * Vinv_ij[1][1] + t6 * Vinv_ij[1][2];
t37 = (t14 * t8 * t13 + t16 * t7 * t26) * t20;
t4 = t24 * (t23 * t37 * t21 - t19 * (-t7 * Vinv_ij[1][0] + t8 * Vinv_ij[0][0])) + t31 * (t15 * t23 * t37 - t19 * (-t7 * Vinv_ij[1][2] + t8 * Vinv_ij[0][2])) + t32 * (t23 * t29 * t37 - t19 * (-t7 * Vinv_ij[1][1] + t8 * Vinv_ij[0][1])) + t4 * Vinv_ij[2][0] + t5 * Vinv_ij[2][1] + t6 * Vinv_ij[2][2];
t5 = (t16 * t3 * t26 + t18 * t2 * t28) * t20;
t5 = t10 * Vinv_ij[0][0] + t11 * Vinv_ij[0][1] + t12 * Vinv_ij[0][2] + t24 * (t21 * t23 * t5 + t19 * (-t2 * Vinv_ij[2][0] + t3 * Vinv_ij[1][0])) + t31 * (t15 * t23 * t5 + t19 * (-t2 * Vinv_ij[2][2] + t3 * Vinv_ij[1][2])) + t32 * (t23 * t29 * t5 + t19 * (-t2 * Vinv_ij[2][1] + t3 * Vinv_ij[1][1]));
t6 = (-t18 * t1 * t28 + t14 * t3 * t13) * t20;
t3 = t10 * Vinv_ij[1][0] + t11 * Vinv_ij[1][1] + t12 * Vinv_ij[1][2] + t24 * (t21 * t23 * t6 - t19 * (-t1 * Vinv_ij[2][0] + t3 * Vinv_ij[0][0])) + t31 * (t15 * t23 * t6 - t19 * (-t1 * Vinv_ij[2][2] + t3 * Vinv_ij[0][2])) + t32 * (t23 * t29 * t6 - t19 * (-t1 * Vinv_ij[2][1] + t3 * Vinv_ij[0][1]));
t6 = (t16 * t1 * t26 + t14 * t2 * t13) * t20;
t1 = t10 * Vinv_ij[2][0] + t11 * Vinv_ij[2][1] + t12 * Vinv_ij[2][2] + t24 * (-t21 * t23 * t6 + t19 * (-t1 * Vinv_ij[1][0] + t2 * Vinv_ij[0][0])) + t31 * (-t15 * t23 * t6 + t19 * (-t1 * Vinv_ij[1][2] + t2 * Vinv_ij[0][2])) + t32 * (-t23 * t29 * t6 + t19 * (-t1 * Vinv_ij[1][1] + t2 * Vinv_ij[0][1]));
t2 = 0.2e1;
gradE[0] = -t2 * (-t24 * (t23 * t22 * t21 + t19 * (t25 * Vinv_ij[1][0] - t27 * Vinv_ij[2][0])) + t33 * Vinv_ij[0][0] + t30 * Vinv_ij[0][1] + t17 * Vinv_ij[0][2] - t32 * (t23 * t22 * t29 + t19 * (t25 * Vinv_ij[1][1] - t27 * Vinv_ij[2][1])) - t31 * (t23 * t22 * t15 + t19 * (t25 * Vinv_ij[1][2] - t27 * Vinv_ij[2][2])));
gradE[1] = -t2 * t35;
gradE[2] = -t2 * t34;
gradE[3] = t2 * t36;
gradE[4] = t2 * t9;
gradE[5] = t2 * t4;
gradE[6] = t2 * t5;
gradE[7] = t2 * t3;
gradE[8] = t2 * t1;
Hessian
hessE := Hessian(E, [v1n[1], v1n[2], v1n[3], v2n[1], v2n[2], v2n[3], v3n[1], v3n[2], v3n[3]])
Dimension(hessE)
9, 9
(1.5.1)
CodeGeneration[C](hessE, optimize = tryhard, deducetypes = false, resultname = 'hessE')
Download membrane_energy.mw
First 111 112 113 114 115 116 117 Last Page 113 of 371
