Thought it would be a neat way to create identation for loops and if branches in a text editor and copy the code into Maple. But Maple inserts a new prompt at the beginning of every line.
Is there a solution in 2018?
with(Physics[Vectors]);
This should  equal Dirac delta function
I know this must have been addressed somewhere previously.  However I have searched extensively and not been able to find an answer.  Sorry for asking again.
The set and list produced by map (see below) contain duplicates.  How to remove duplicates?
p := (1+5^(1/2))*(1/2)
1/2+(1/2)*5^(1/2)
with(Bits)
[And, FirstNonzeroBit, GetBits, Iff, Implies, Join, Nand, Nor, Not, Or, Settings, Split, String, Xor]
with(LinearAlgebra)
[`&x`, Add, Adjoint, BackwardSubstitute, BandMatrix, Basis, BezoutMatrix, BidiagonalForm, BilinearForm, CARE, CharacteristicMatrix, CharacteristicPolynomial, Column, ColumnDimension, ColumnOperation, ColumnSpace, CompanionMatrix, CompressedSparseForm, ConditionNumber, ConstantMatrix, ConstantVector, Copy, CreatePermutation, CrossProduct, DARE, DeleteColumn, DeleteRow, Determinant, Diagonal, DiagonalMatrix, Dimension, Dimensions, DotProduct, EigenConditionNumbers, Eigenvalues, Eigenvectors, Equal, ForwardSubstitute, FrobeniusForm, FromCompressedSparseForm, FromSplitForm, GaussianElimination, GenerateEquations, GenerateMatrix, Generic, GetResultDataType, GetResultShape, GivensRotationMatrix, GramSchmidt, HankelMatrix, HermiteForm, HermitianTranspose, HessenbergForm, HilbertMatrix, HouseholderMatrix, IdentityMatrix, IntersectionBasis, IsDefinite, IsOrthogonal, IsSimilar, IsUnitary, JordanBlockMatrix, JordanForm, KroneckerProduct, LA_Main, LUDecomposition, LeastSquares, LinearSolve, LyapunovSolve, Map, Map2, MatrixAdd, MatrixExponential, MatrixFunction, MatrixInverse, MatrixMatrixMultiply, MatrixNorm, MatrixPower, MatrixScalarMultiply, MatrixVectorMultiply, MinimalPolynomial, Minor, Modular, Multiply, NoUserValue, Norm, Normalize, NullSpace, OuterProductMatrix, Permanent, Pivot, PopovForm, ProjectionMatrix, QRDecomposition, RandomMatrix, RandomVector, Rank, RationalCanonicalForm, ReducedRowEchelonForm, Row, RowDimension, RowOperation, RowSpace, ScalarMatrix, ScalarMultiply, ScalarVector, SchurForm, SingularValues, SmithForm, SplitForm, StronglyConnectedBlocks, SubMatrix, SubVector, SumBasis, SylvesterMatrix, SylvesterSolve, ToeplitzMatrix, Trace, Transpose, TridiagonalForm, UnitVector, VandermondeMatrix, VectorAdd, VectorAngle, VectorMatrixMultiply, VectorNorm, VectorScalarMultiply, ZeroMatrix, ZeroVector, Zip]
with(VectorCalculus)
[`&x`, `*`, `+`, `-`, `.`, `<,>`, `<|>`, About, AddCoordinates, ArcLength, BasisFormat, Binormal, Compatibility, ConvertVector, CrossProduct, Curl, Curvature, D, Del, DirectionalDiff, Divergence, DotProduct, Flux, GetCoordinateParameters, GetCoordinates, GetNames, GetPVDescription, GetRootPoint, GetSpace, Gradient, Hessian, IsPositionVector, IsRootedVector, IsVectorField, Jacobian, Laplacian, LineInt, MapToBasis, Nabla, Norm, Normalize, PathInt, PlotPositionVector, PlotVector, PositionVector, PrincipalNormal, RadiusOfCurvature, RootedVector, ScalarPotential, SetCoordinateParameters, SetCoordinates, SpaceCurve, SurfaceInt, TNBFrame, Tangent, TangentLine, TangentPlane, TangentVector, Torsion, Vector, VectorField, VectorPotential, VectorSpace, Wronskian, diff, eval, evalVF, int, limit, series]
b := proc (x, w) options operator, arrow; (-1)^GetBits(x, w, output = number) end proc
proc (x, w) options operator, arrow; (-1)^Bits:-GetBits(x, w, output = number) end proc
l := proc (x, t, u, v) options operator, arrow; frac(x)*Vector([b(floor(x), 0)*t, b(floor(x), 1)*u, b(floor(x), 2)*v])+(1-frac(x))*Vector([b(floor(x), 0)*v, b(floor(x), 1)*t, b(floor(x), 2)*u]) end proc
proc (x, t, u, v) options operator, arrow; VectorCalculus:-`+`(VectorCalculus:-`*`(frac(x), VectorCalculus:-Vector([VectorCalculus:-`*`(b(floor(x), 0), t), VectorCalculus:-`*`(b(floor(x), 1), u), VectorCalculus:-`*`(b(floor(x), 2), v)])), VectorCalculus:-`*`(VectorCalculus:-`+`(1, VectorCalculus:-`-`(frac(x))), VectorCalculus:-Vector([VectorCalculus:-`*`(b(floor(x), 0), v), VectorCalculus:-`*`(b(floor(x), 1), t), VectorCalculus:-`*`(b(floor(x), 2), u)]))) end proc
map(l, {0, 1, 2, 3, 4, 5, 6, 7, 8}, 0, 1, p)
{Vector(3, {(1) = -1/2-(1/2)*5^(1/2), (2) = 0, (3) = -1}, attributes = [coords = cartesian]), Vector(3, {(1) = 1/2+(1/2)*5^(1/2), (2) = 0, (3) = -1}, attributes = [coords = cartesian]), Vector(3, {(1) = -1/2-(1/2)*5^(1/2), (2) = 0, (3) = -1}, attributes = [coords = cartesian]), Vector(3, {(1) = 1/2+(1/2)*5^(1/2), (2) = 0, (3) = 1}, attributes = [coords = cartesian]), Vector(3, {(1) = 1/2+(1/2)*5^(1/2), (2) = 0, (3) = 1}, attributes = [coords = cartesian]), Vector(3, {(1) = -1/2-(1/2)*5^(1/2), (2) = 0, (3) = 1}, attributes = [coords = cartesian]), Vector(3, {(1) = 1/2+(1/2)*5^(1/2), (2) = 0, (3) = -1}, attributes = [coords = cartesian]), Vector(3, {(1) = 1/2+(1/2)*5^(1/2), (2) = 0, (3) = 1}, attributes = [coords = cartesian]), Vector(3, {(1) = -1/2-(1/2)*5^(1/2), (2) = 0, (3) = 1}, attributes = [coords = cartesian])}
map(l, [0, 1, 2, 3, 4, 5, 6, 7, 8], 0, 1, p)
[Vector(3, {(1) = 1/2+(1/2)*5^(1/2), (2) = 0, (3) = 1}, attributes = [coords = cartesian]), Vector(3, {(1) = -1/2-(1/2)*5^(1/2), (2) = 0, (3) = 1}, attributes = [coords = cartesian]), Vector(3, {(1) = 1/2+(1/2)*5^(1/2), (2) = 0, (3) = 1}, attributes = [coords = cartesian]), Vector(3, {(1) = -1/2-(1/2)*5^(1/2), (2) = 0, (3) = 1}, attributes = [coords = cartesian]), Vector(3, {(1) = 1/2+(1/2)*5^(1/2), (2) = 0, (3) = -1}, attributes = [coords = cartesian]), Vector(3, {(1) = -1/2-(1/2)*5^(1/2), (2) = 0, (3) = -1}, attributes = [coords = cartesian]), Vector(3, {(1) = 1/2+(1/2)*5^(1/2), (2) = 0, (3) = -1}, attributes = [coords = cartesian]), Vector(3, {(1) = -1/2-(1/2)*5^(1/2), (2) = 0, (3) = -1}, attributes = [coords = cartesian]), Vector(3, {(1) = 1/2+(1/2)*5^(1/2), (2) = 0, (3) = 1}, attributes = [coords = cartesian])]
q := ListTools:-MakeUnique(%)
q := [Vector(3, {(1) = 1/2+(1/2)*5^(1/2), (2) = 0, (3) = 1}, attributes = [coords = cartesian]), Vector(3, {(1) = -1/2-(1/2)*5^(1/2), (2) = 0, (3) = 1}, attributes = [coords = cartesian]), Vector(3, {(1) = 1/2+(1/2)*5^(1/2), (2) = 0, (3) = 1}, attributes = [coords = cartesian]), Vector(3, {(1) = -1/2-(1/2)*5^(1/2), (2) = 0, (3) = 1}, attributes = [coords = cartesian]), Vector(3, {(1) = 1/2+(1/2)*5^(1/2), (2) = 0, (3) = -1}, attributes = [coords = cartesian]), Vector(3, {(1) = -1/2-(1/2)*5^(1/2), (2) = 0, (3) = -1}, attributes = [coords = cartesian]), Vector(3, {(1) = 1/2+(1/2)*5^(1/2), (2) = 0, (3) = -1}, attributes = [coords = cartesian]), Vector(3, {(1) = -1/2-(1/2)*5^(1/2), (2) = 0, (3) = -1}, attributes = [coords = cartesian]), Vector(3, {(1) = 1/2+(1/2)*5^(1/2), (2) = 0, (3) = 1}, attributes = [coords = cartesian])]
Equal(q[1], q[9])
qq := [op({q[]})]
qq := [Vector(3, {(1) = 1/2+(1/2)*5^(1/2), (2) = 0, (3) = -1}, attributes = [coords = cartesian]), Vector(3, {(1) = -1/2-(1/2)*5^(1/2), (2) = 0, (3) = -1}, attributes = [coords = cartesian]), Vector(3, {(1) = 1/2+(1/2)*5^(1/2), (2) = 0, (3) = 1}, attributes = [coords = cartesian]), Vector(3, {(1) = -1/2-(1/2)*5^(1/2), (2) = 0, (3) = 1}, attributes = [coords = cartesian]), Vector(3, {(1) = 1/2+(1/2)*5^(1/2), (2) = 0, (3) = -1}, attributes = [coords = cartesian]), Vector(3, {(1) = -1/2-(1/2)*5^(1/2), (2) = 0, (3) = -1}, attributes = [coords = cartesian]), Vector(3, {(1) = 1/2+(1/2)*5^(1/2), (2) = 0, (3) = 1}, attributes = [coords = cartesian]), Vector(3, {(1) = -1/2-(1/2)*5^(1/2), (2) = 0, (3) = 1}, attributes = [coords = cartesian]), Vector(3, {(1) = 1/2+(1/2)*5^(1/2), (2) = 0, (3) = 1}, attributes = [coords = cartesian])]
LinearAlgebra:-Equal(qq[1], qq[5])
Download cp.mw
To restrict the domain of a vector field, I have multiplied a coordinate with a non-real complex number (namely a sqrt(of negative expression)). This does work, as shown in this Maple 2017 worksheet program (below). My question is whether this is the best technique of accomplishing this result, or else how to do it better? Would be interested in suggestions for improvements. Here is my program so far:
print(` ------- ------- ------- ------- ------- ------- -------`);
print(` Vector Field inside Torus`);
print(` Assignment:  `);
print(` In a circular pipe of radius (my2r), water is flowing in the direction `);
print(` of the pipe, with speed (my2r)^2-(mya)^2, where (mya) is the distance  `);
print(` to the axis of the pipe.  `);
print(` Depict the vector field describing the flow if the pipe goes around in `);
print(` the shape of a torus with major radius (my1r).  `);
print(`   `);
print(`   `);
print(`   `);
print(`\n(Section 1) major radius of torus:`);
my1r  := 5;
print(`\n(Section 2) minor radius of torus (pipe radius):`);
my2r := 4;
print(`\n(Section 3) definition of torus (polar coordinates):`);
c00 := [(my1r+my2r*cos(s))*cos(t),(my1r+my2r*cos(s))*sin(t),my2r*sin(s)];
print(`\n(Section 4) 3D plot of solid torus (polar coordinates):`);
plot3d({c00},scaling=constrained,color=red);
print(`\n(Section 5) 3D plot of wireframe torus (polar coordinates):`);
P1 := plot3d({c00},scaling=constrained,style=wireframe);
print(`\n(Section 6) implicit definition of torus (cartesian coordinates):`);
c01 := (sqrt(x^2+y^2)-my1r)^2+z^2-my2r^2;
print(`\n(Section 7) implicit 3D plot of solid torus (cartesian coordinates):`);
gx := my1r+my2r; # min and max of each coordinate
implicitplot3d(c01,x=-gx..gx,y=-gx..gx,z=-gx..gx,numpoints=9000);
print(`\n(Section 8) vector field definition (cartesian coordinates):`);
my1vfx := -y;
my1vfy := x;
my1vfz := 0;
my1fld := [my1vfx,my1vfy,my1vfz];
print(`\n(Section 9) 3D plot of vector field (cartesian coordinates):`);
fieldplot3d(my1fld,x=-gx..gx,y=-gx..gx,z=-gx..gx);
print(`\n(Section 10) definition of vector field with unit length vectors (cartesian coordinates):`);
my1vl := sqrt(my1vfx^2+my1vfy^2+my1vfz^2); # vector length
my2fld := [my1vfx/my1vl,my1vfy/my1vl,my1vfz/my1vl];
print(`\n(Section 11) 3D plot of vector field with unit length vectors (cartesian coordinates):`);
fieldplot3d(my2fld,x=-gx..gx,y=-gx..gx,z=-gx..gx);
print(`\n(Section 12) definition of vector field with asked for length vectors (cartesian coordinates):`);
mya := sqrt((sqrt(x^2+y^2)-my1r)^2+z^2);
c01r := sqrt(my2r^2-mya^2); # also used for domain restricting vector field below
my1tsz := solve([c01],[z]);
assign(my1tsz[1][1]);
my1tz := z;
unassign('z');
assign(my1tsz[2][1]);
my2tz := z;
unassign('z');
my1vp := c01r/my2r; # vector length (maximum one unit)
my3fld := [my1vp*my1vfx/my1vl,my1vp*my1vfy/my1vl,my1vp*my1vfz/my1vl];
print(`\n(Section 13) 3D plot of vector field with asked for length vectors (cartesian coordinates):`);
fieldplot3d(my3fld,x=-gx..gx,y=-gx..gx,z=-gx..gx);
print(`\n(Section 14) same asked for vector field with 3-D arrow vectors:`);
print(`   `);
print(` (to get this to display properly it was necessary to do:  `);
print(` -> Maple 2017 -> Preferences... -> Precision ->   `);
print(`   [unselect] Limit expression length to   `);
print(`   Apply to Session`);
print(`   `);
gr := 15;
P3 := fieldplot3d(my3fld,x=-gx..gx,y=-gx..gx,z=-gx..gx,arrows=`3-D`,grid=[gr,gr,gr]);
print(`\n display asked for vector field within wireframe torus:`);
display([P1,P3]);
I've keep checking in every 18 months or so for the last 10 years... since Maple got a sort-of-notebook interface. I keep hopeing for a MathCad-like true notebook, where I can organize my document the way I want, instead of the clunky console I/O based interface. But every time I check, its not quite there.
Are we there yet?
I got decimal places problem,
not known correct or not
the value are different but difference is constant
i do not know how many places needed to get exact result
i do not believe the difference is constant
because the matrix are different
but even if using 36 decimal places still constant,
i notice increasing decimal places , the constant difference is changed
is it possible  to output fraction when calculate eigenvector?
Ok embarassing I posted this one and now it outputs this java error file log and yep i dont know that much about java at all.
Sometimes it works, sometimes it closes maple automatically and spits out the .txt error log i have attached if thats any help... MAPLE_EXAMPLE_16.mw  i honestly have never ever seen maple behave this way in more than a decade of playing around in it with stuff like this.
EDIT: Here is a version with smaller plot components that seems to be working.... MAPLE_EXAMPLE_17.mw
It says i am not allowed to upload a log file but this is what it looks like:
# A fatal error has been detected by the Java Runtime Environment:
# java.lang.OutOfMemoryError: requested 1024000 bytes for GrET in C:\BUILD_AREA\jdk6_18\hotspot\src\share\vm\utilities\growableArray.cpp. Out of swap space?
V  [jvm.dll+0x15df8a]
V  [jvm.dll+0x1e1e14]
V  [jvm.dll+0x1a1aad]
V  [jvm.dll+0xc834f]
V  [jvm.dll+0xca01c]
V  [jvm.dll+0xca370]
V  [jvm.dll+0xce42a]
V  [jvm.dll+0x1d8592]
V  [jvm.dll+0xc9398]
V  [jvm.dll
Java Threads: ( => current thread )
  0x522e7c00 JavaThread "Timer-28" [_thread_blocked, id=23236, stack(0x5f2f0000,0x5f6f0000)]
  0x522e7400 JavaThread "Timer-22" [_thread_blocked, id=24248, stack(0x6b440000,0x6b840000)]
  0x522e2c00 JavaThread "WMI:MapleClientSocket:Kernel Connection " daemon [_thread_blocked, id=11140, stack(0x6a2d0000,0x6a6d0000)]
  0x522e7000 JavaThread "WMI:MapleClientSocket:Kernel Connection " daemon [_thread_blocked, id=6792, stack(0x64d30000,0x65130000)]
  0x522e6400 JavaThread "WMI:MapleClientSocket:Kernel Connection " daemon [_thread_blocked, id=20280, stack(0x6a6d0000,0x6aad0000)]
  0x522e4400 JavaThread "Timer-18" daemon [_thread_blocked, id=23888, stack(0x63f20000,0x64320000)]
  0x522e6800 JavaThread "Timer-17" [_thread_blocked, id=17320, stack(0x69ed0000,0x6a2d0000)]
  0x522e5000 JavaThread "WMI:MapleClientSocket:Kernel Connection " daemon [_thread_blocked, id=13480, stack(0x69ad0000,0x69ed0000)]
  0x522e4800 JavaThread "Timer-16" daemon [_thread_blocked, id=18184, stack(0x68ed0000,0x692d0000)]
  0x522e3000 JavaThread "Timer-15" [_thread_blocked, id=23296, stack(0x692d0000,0x696d0000)]
  0x522e3800 JavaThread "WMI:MapleClientSocket:Kernel Connection " daemon [_thread_blocked, id=16388, stack(0x66820000,0x66c20000)]
  0x522e1400 JavaThread "Timer-14" daemon [_thread_blocked, id=24500, stack(0x61c50000,0x62050000)]
  0x522e0c00 JavaThread "Timer-13" [_thread_blocked, id=15848, stack(0x659b0000,0x65db0000)]
  0x522e0000 JavaThread "WMI:MapleClientSocket:Kernel Connection " daemon [_thread_blocked, id=7260, stack(0x655b0000,0x659b0000)]
  0x466cb000 JavaThread "Timer-12" daemon [_thread_blocked, id=1112, stack(0x64320000,0x64720000)]
  0x4699b800 JavaThread "Timer-11" [_thread_blocked, id=24540, stack(0x64930000,0x64d30000)]
  0x4699b400 JavaThread "Timer-10" daemon [_thread_blocked, id=21144, stack(0x60bf0000,0x60ff0000)]
  0x4699d400 JavaTh
How to translate the elliptic curve from the 4th to the 3rd curve with maple?
thanks.
Is there any way to get random numbers in Maple with the Sobol method?
As the title suggests, that is what one of my current "fool around" projects requires. I have tried to do this using the HTTP package together with the StringTools package, and had mixed results, the main issue being is that in performing the HTTP Get request it  returns an error code unless i constantly import valid "spam" from my clipboard from an external internet brower.
I will keep working on the way i forsee this being possible, and dont ask why a want to do this from a command line approach rather than just using a search engine, yes i have a good reason for this. If you have done this before, id appreciate the help as it will enable me to improve my life quite a bit.
can anyone tell me the difference between subs and eval and  evalf ?
The  partition function is geven as'
Zvib(Beta)"=integrate(exp^Beta*alpha^2*h^2/4*units*m *(B-2A)+Beta*alpha^2*h^2*B^/8*units*m*(n+c)^2+Beta*alpha^2*h^2*rho^2*drho,rho=(c+n) from to lambda+c
I need to find the intersection points of two circles (x-7)^2+(y-2)^2=100 and (x-11)^2+(y-5)^2=75 using the modified Newton secant method.
I have already done this by using these two equations to make one in terms of x. But, i am looking for suggestions on how to make a multiple variable version of the secant method.
I believe I am having memory issues which is causing the MAPLE kernal to terminate.  If I assign m a value then it seems to work, but I would like to leave m unassigned so that S1 can later be evaluated for any arbitrary m.  Is there a way around this?
T := M*tau;
`assuming`([simplify(expand(combine(S1)))], [m::integer])
Download MAPLE_crashing.mw
can maple code saved into database for self modifying easily?
self modifying , metaprogramming , database, snapshot, blockchain for code integrity etc
First 155 156 157 158 159 160 161 Last Page 157 of 371
