Am trying to teach myself "circle inversion" to solve circle geometry problems.  Towards this end I wrote a Maple 7 program to draw a Pappus chain of circles.  Pappus lived around 200AD, and I read that he considered this problem ancient!
   The output diagram may not come out on this forum, but it comes out as a collection of tangential circles, and I have no problems with that.  In drawing the circles I was thinking of using the infinity symbol.  The following line uses the infinity, but with a minus sign.  Maple is "happy" with this and outputs square braces, suggesting an empty list?  I changed the program by omitting the -ve sign - and Maple came up with an error message.  I would have expected the output to include the value zero  ie [0]  I think it is just that the infinity symbol is not allowed in the seq command.
[seq( i, i=0..-infinity )];  #???  why the -?,
In the next part I define X, Y and rad as the coordinates and radii of a sequence of circles: subscript i, ranging from start to nterm, (for the number of terms).  These are set at 1 and 286.   The program works OK with these values, but if the variable start is changed to zero, 0, it doesn't work.  I thought I might have a division by zero, but can't find one.  I also drew a circle with a radius of zero - no problem!  (...except it's difficult to see:-))
   My main puzzle is why does it come up with the error message "invalid subscript selector" when the variable start is set to 0?
With i=start=0 I am asking it to draw a circle of radius zero at some specified coords - but it doesn't like it!
  Any comments would be appreciated.  Merry Christmas.
David
# Pappus Chain of circles
with(plottools):
#Maple 7
#r is ratio of AC/AB = diam of large circle, to a smaller internally tangential one
r:=1.35:
#Why will start=0 not work?
start:=1:
#nterm=286 is smallest value where axes have "true" origin of (0.0)
#nterm<= 285 puts "x-axis" below y=-0.6
nterm:=286:
X := [seq( 0.5*r*(1+r)/(((i*(1-r))^2)+r), i=start..nterm )]:
Y := [seq( i*r*(1-r)/(((i*(1-r))^2)+r), i=start..nterm )]:
rad:=[seq(0.5*r*(1-r)/((i*(1-r))^2+r), i=start..nterm)]:
#Gives [] output with -ve sign:  empty list?  Why is 0 not included?
# Not allowed to use with seq
#ccc:=[seq(circle([X[i],Y[i]],rad[i]), i=1..5)]:  #nops(X))]:
ccc:=[seq(circle([X[i],Y[i]],rad[i]), i=start..nterm)]:
#c := circle([1,1], 0, color=red):
#plots[display](c, scaling=constrained);
plots[display](ccc, scaling=constrained);
OUTPUT
Long time asker of minimization problems here.
Following on from my question on 2D packing.
I found this "solved" problem for packing 3D items efficiently. See Illustration 6.13
https://www.researchgate.net/file.PostFileLoader.html?id=59938b635b49527571134c33&assetKey=AS%3A527790252490752%401502846410852
Some discrepancies with constraint set-up (first one), number of variables and the optimized solution.
3DbinPack2.mw
When I export a worksheet table as HTML,MATH EXPRESSIONS: GIF the resulting .html file is 100% readable.
screenshot:
But when i send the html file to myself over email, I get gibberish
The (acer) code for the top is... .....Equation(Standings[id]:-mu &+- Standings[id]:-sigma....
and below opponents rating: ....Cell(Equation(thetable[id][':-losses'][r][1] &+- thetable[id][':-losses'][r][2],......
Anyone shed?
Does any body have example of maple code for solving optimal control problem in deterministic model using Pontryagin's maximum (or minimum) principle?
While using a version of Maple on the inverse symbolic calculator I first described my idea for a new constant in 1999 and other people named it after me, calling it the MRB constant. While looking for an applied math purpose for the MRB constant =sum((-1)^k (k^(1/k)-1),k=1..infinity), I noticed that the absolute value of its summand is the interest rate to multiply an investment k times in k years=k^(1/k)-1. Any ideas on how this might be related to other subjects?
Say I want to use multiples commands on an expression
simplify(expand(eval(expr,x=y+1)))
Now similar I could use
(simplify@expand)(expr)
but how do I do it with sth like eval which needs extra arguments
(simplify@expand@eval(x->y, x=y+1))(f)
t := 5;
u := exp((1/2)*x-2*t*(1/3));
                            /1     10\
                         exp|- x - --|
                            \2     3 /
plot(u(x), x = -4 .. 4);
this is the exact solution graph
while below is the approximate solution graph
h := -1;
                               -1
t := 5;
u := exp((1/2)*x)*(1+t*(27*h^4+108*h^3+240*h^2+256*h)/2^7+t^2*(27*h^4+24*h^3+168*h^2)/2^7+(1/3)*t^3*(9*h^4+16*h^3)/2^6+(1/4)*t^4*h^4/2^4);
                         6877    /1  \
                         ---- exp|- x|
                         192     \2  /
Please help me
I'm getting the message
Secure Connection Failed
when trying to get into this forum using the latest version of Firefox.
For writing this I used Internet Explorer.
The message continues with:
An error occurred during a connection to mapleprimes.com. You have received an invalid certificate. Please contact the server administrator or email correspondent and give them the following information: Your certificate contains the same serial number as another certificate issued by the certificate authority. Please get a new certificate containing a unique serial number. Error code: SEC_ERROR_REUSED_ISSUER_AND_SERIAL
    The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
    Please contact the website owners to inform them of this problem
Has anybody else experienced the same?
What to do?
Please, anyone with usefull informations to hint me. Looking forward to your favorable response.
Thanking you in advance
how could I force Maple to solve this pde
pdsolve(y*(diff(f(x, y, z, w), x))-x*(diff(f(x, y, z, w), y))+w*(diff(f(x, y, z, w), z))-z*(diff(f(x, y, z, w), w)) = 0)
When I hit enter, it happens nothing.
Below is MAPLE code to simplify a series.  MAPLE expresses the result in terms of functions which many people are not familiar with.  Is there a way to express the answer in terms of more conventional functions expecially if N is a positive integer?
Cn := ((-I)*(1/2))*(2*(I*Pi*n*tau-(2*I)*Pi*n)*cos(Pi*n*tau/T)-T*(2*I)*sin(Pi*n*tau/T)+(4*I)*Pi*n)/(Pi^2*n^2); S4 := a[0]+sum(Cn*sin(2*Pi*n*x/T), n = 1 .. k); a[0] := 0; T := 4; tau := 2; Cn; S5 := unapply(S4, k, x); T := simplify(S5(N, x))
convert(T, StandardFunctions);
(-polylog(2, exp(-((1/2)*I)*Pi*(x-1)))*N^2-exp(-((1/2)*I)*Pi*N*(x+1))*LerchPhi(exp(-((1/2)*I)*(x+1)*Pi), 2, N)*N^2+polylog(2, exp(((1/2)*I)*(x+1)*Pi))*N^2+exp(-((1/2)*I)*Pi*N*(x-1))*LerchPhi(exp(-((1/2)*I)*Pi*(x-1)), 2, N)*N^2+polylog(2, exp(-((1/2)*I)*(x+1)*Pi))*N^2-exp(((1/2)*I)*Pi*N*(x+1))*LerchPhi(exp(((1/2)*I)*(x+1)*Pi), 2, N)*N^2-polylog(2, exp(((1/2)*I)*Pi*(x-1)))*N^2+exp(((1/2)*I)*Pi*N*(x-1))*LerchPhi(exp(((1/2)*I)*Pi*(x-1)), 2, N)*N^2+exp(((1/2)*I)*Pi*N*(x+1))-exp(((1/2)*I)*Pi*N*(x-1))+exp(-((1/2)*I)*Pi*N*(x+1))-exp(-((1/2)*I)*Pi*N*(x-1))-I*exp(-((1/2)*I)*x*Pi*N)*LerchPhi(exp(-((1/2)*I)*x*Pi), 1, N)*N^2*Pi-I*ln(1-exp(-((1/2)*I)*x*Pi))*N^2*Pi+I*exp(((1/2)*I)*x*Pi*N)*LerchPhi(exp(((1/2)*I)*x*Pi), 1, N)*N^2*Pi+I*ln(1-exp(((1/2)*I)*x*Pi))*N^2*Pi-I*exp(((1/2)*I)*x*Pi*N)*N*Pi+I*exp(-((1/2)*I)*x*Pi*N)*N*Pi)/(N^2*Pi^2)
Download simplify.mw
Request help in solving the equation:
Eq_H_1 := C[11*m]*(int((t-(j-1)*T)*alpha*(-alpha*(K*T*beta+T*beta*j-K*T-T*beta-T*j-beta*t+T+t))^(-beta/(beta-1))*exp(-R[m]*t), t = (j-1)*T .. (K+j-1)*T))
I have to make a project that need to use openmaple in java. The problems is when i get the output data of the textCallBack method, i try to convert the output to utf-8 format using the UTF8Encoder provided in java Maple JAR file in order to display Vietnamese language but it doesn't work (the output type is String). Are there any solutions? Thank you.
Here are two inocent Vectors.
V1 := Vector[row]([`+`, 1, 2]);
_rtable[18446744074366295326]
V2 := Vector[row]([1, `+`, 2]);
_rtable[18446744074366288110]
lprint(V1);
Vector[row](3, {1 = `+`, 2 = 1, 3 = 2}, datatype = anything, storage = rectangular, order = Fortran_order, shape = [])
The questions:
1.  Try to guess the Maple's answer for:
V1, V2;
2. Try to explain.
Download v1v2.mw
First 158 159 160 161 162 163 164 Last Page 160 of 371
