I attached a program here and the desire is the calculation of Nu.As you could see through the attached file, the F2(r) function contains an 'integral' which makes it difficult if I want to calculate F2(r=1) and it goes the same for D(F2)(r=\phi). So I firstly corrected the F2(r) function as FF2(r) in which the parameter R is calculated in the top of the file. Afte I replace the values of \phi and 1 in the FF2(r) not in F2(r) just because of the integral. The Nu is calculated finally, but it differs from the initial guess. How could I make a loop in order to correct the initial guess by replacing the first Nu calculated in the end of the program??
Ther is a problem and that is the "k" which must be entered in this part in each loop:
Digits:= 10:
K:=Nu->( k )
I do not know whether or not it is possible to change it so that the program identify the 'k' and replace it in the "K:=Nu->( k )" for k.
SolveCode.mw
Download SolveCode.mw
Numerical evaluation of HeunBPrime fails if abs(z)>1:
HeunBPrime(.2, .3, .4, .5, 1.5);
Warning, breaking the computation of HeunBPrime after 20000 terms, the series is not converging
                      9.604689581*10^15896
while this gives the correct value:
subs(z = 1.5, convert(series(HeunBPrime(.2, .3, .4, .5, z), z = 0, 40), polynom));
                          15.37195056
I must be missing something in my Fourier integral.  My understanding is that the sinc function is the transform of a square wave.  In the link below I am getting something slightly different.  I have the parameter tau to define relative to the period, T, to vary the width aspect ratio of the wave,  If tau=T I do get the sinc function.
What am I missing or is what I have correct?
Sq_wave_Fourier_transform.mw
  how can I find equation discribing elliptic intersections and use lagrange to show the higest and lowest value ?    g
How can i solve this nonlinear equation using adomian decomposition method in maple?
utt −uxx +u^2 = 6xt(x^2 −t^2)+x^6t^6
I'm having this
2+2;
Typesetting:-mn("4"), [4]
everytime I try a calculation. Could someone explain me what is this typesetting thing, and how can it be prevented? I haven't used Maple for a while and I cannot recall having seen it before. Thank you
Hello.
Please help me. I Have to solve some equations with Adomian Decomposition Method in Maple. But i don't know it.
I just know AGM, HPM and Perturbation Method in Maple.
please send me instructions and codes.
I'm sorry, I can't speak English well. I hope you understand what I mean.
thank you
It seems rather arbitrary that proc..end proc is allowed inside functions, but none of the other statements from ?index,statement are:
seq(try ln(i) catch: -infinity end try, i=0..2)
seq(proc() try ln(i) catch: -infinity end try end proc(), i=0..2)
Only the second one works, even though syntactically it doesn't seem to be different from the first one.
It would be really convenient to have any statement allowed inside a function, including assignments (as :=, not as assign()) and compound statements:
s:=0: seq(s:=s+i, i=1..10)
s:=0: seq(proc() global s:=s+i end proc(), i=1..10)
This is more compact than using a loop.
hello , there , i want ask a Question ,
i have a vector result n hier , and there is a long part with ^1/2 (like unter) , which is not defined before , just from compute ,i want to replace this part with A, and have tried to use subs , but it didnt work .
And i have tried to define it before compute, and then use subs , aber it also didnt work .
so how can i replace or define this part in the result?
Good day!
I am working to solve a double series (LP  minimization) problem of the form
z = add(add(x[i,j]*y[i,j]*z[j], j=1..6), i=1..3).
However, this returns a set [ ].
Since LPSolve does not operate on a set (removing the brackets manually will enable LPSolve to obtain the solution), can anyone suggest what is wrong with the structure of this z-equation? x, y are matrices and z is a column vector.
Hello everyone!
Total beginner here. So far I am just using the right click options in Maple,  and worked wonderfully until now.
Two questions for some charitable sould out there:
1) I have a system of inequalities that I need to solve. I am interested in the *conditions between the variables under which a given inequality is satisfied*.
Using the "solve" command I only get a few of these. Do you know any script that can obtain more solutions?
2) I have some (long) equations and want to be able to visualize them in different ways to make sense of it. So far I have only been using "simplify" and "combine", but it keeps on returning the same result even if I can see there are other possible ways of factoring the equation. How can I tell Maple to give me "different optiosn" as to visualize the equation?
Thank you all!!
Is there a way in Maple to evaluate the following integral - where the "w" are set to go to zero to avoid singularities? B.t.w. Maple just returns the integral unevaluated with or without the "w" with the simple "int" command.
int(ln(((p1-p3)^2+w^2)/(p1+p3)^(w^2+2))*ln(((p1-p4)^2+w^2)/((p1+p4)^2+w^2))*sin(p1)/(p1*p3*p4), p1 = 0 .. infinity);
or even
int(ln(((p1-p3)^2+w^2)/(p1+p3)^(w^2+2))*ln(((p1-p4)^2+w^2)/((p1+p4)^2+w^2))*sin(p1)/(p1*p3*p4), p1 = 0 .. 100, numeric);
Here's something neat to be done in Maple.
This anaglyph or stereo image uses the red green glasses to make the model appear more 3 dimensional.  The static-non-stereo image of the animated plot below is done in maple by plot3d(sin(x*y)^2,x=-2..2,y=-2..2,scaling=constrained)
Anyone?
hi
how i can pdsolve these partial differentialequations?
10.mw
restart; R := 1; UB := 1; lambda := 1; pe1 := 1; pe2 := 1; L := 1; Gr := 1; Br := 1; p := 1; LinearAlgebra:-HermitianTranspose(L) := 1; Nb := 1; Nt := 1; a := lambda*pe1*u(r, z)*(diff(sigma(r, z), z))-(diff(r*(diff(sigma(r, z), r)), r))/r-lambda^2*(diff(sigma(r, z), z, z))-Nt*((diff(r*(diff(theta(r, z), r)), r))/r+lambda^2*(diff(theta(r, z), z, z)))/Nb
u(r, z)*(diff(sigma(r, z), z))-(diff(sigma(r, z), r)+r*(diff(diff(sigma(r, z), r), r)))/r-(diff(diff(sigma(r, z), z), z))-(diff(theta(r, z), r)+r*(diff(diff(theta(r, z), r), r)))/r-(diff(diff(theta(r, z), z), z))
b := lambda*pe2*u(r, z)*(diff(theta(r, z), z))-(diff(r*(diff(theta(r, z), r)), r))/r-lambda^2*(diff(theta(r, z), z, z))-Nb*((diff(sigma(r, z), r))*(diff(theta(r, z), r))+(diff(sigma(r, z), z))*(diff(theta(r, z), z))*lambda^2)-Nt*((diff(theta(r, z), r))^2+lambda^2*(diff(theta(r, z), z))^2)
u(r, z)*(diff(theta(r, z), z))-(diff(theta(r, z), r)+r*(diff(diff(theta(r, z), r), r)))/r-(diff(diff(theta(r, z), z), z))-(diff(sigma(r, z), r))*(diff(theta(r, z), r))-(diff(sigma(r, z), z))*(diff(theta(r, z), z))-(diff(theta(r, z), r))^2-(diff(theta(r, z), z))^2
c := -p+(diff(r*(diff(u(r, z), r)), r))/r-L^2*(diff(r*(diff((diff(r*(diff(u(r, z), r)), r))/r, r)), r))/r+Gr*theta(r, z)+Br*sigma(r, z)
-1+(diff(u(r, z), r)+r*(diff(diff(u(r, z), r), r)))/r-(-(diff(u(r, z), r)+r*(diff(diff(u(r, z), r), r)))/r^2+(2*(diff(diff(u(r, z), r), r))+r*(diff(diff(diff(u(r, z), r), r), r)))/r+r*(2*(diff(u(r, z), r)+r*(diff(diff(u(r, z), r), r)))/r^3-2*(2*(diff(diff(u(r, z), r), r))+r*(diff(diff(diff(u(r, z), r), r), r)))/r^2+(3*(diff(diff(diff(u(r, z), r), r), r))+r*(diff(diff(diff(diff(u(r, z), r), r), r), r)))/r))/r+theta(r, z)+sigma(r, z)
bc := {sigma(R, z) = 0, sigma(r, 0) = 1, theta(R, z) = 0, theta(r, 0) = 1, u(R, z) = UB, (D[1](sigma))(0, z) = 0, (D[1](sigma))(r, LinearAlgebra:-HermitianTranspose(L)) = 0, (D[1](theta))(0, z) = 0, (D[1](theta))(r, LinearAlgebra:-HermitianTranspose(L)) = 0, (D[1](u))(0, z) = 0, (D[2](u))(R, z) = 0}
{sigma(1, z) = 0, sigma(r, 0) = 1, theta(1, z) = 0, theta(r, 0) = 1, u(1, z) = 1, (D[1](sigma))(0, z) = 0, (D[1](sigma))(r, 1) = 0, (D[1](theta))(0, z) = 0, (D[1](theta))(r, 1) = 0, (D[1](u))(0, z) = 0, (D[2](u))(1, z) = 0}
Download 10.mw
First 160 161 162 163 164 165 166 Last Page 162 of 371
