I have a polynomial of 4th order and I wanted to use allvalues on the RootOf expression. It then says:
Error, (in evala/Normal/preproc) reducible RootOf detected.  Substitutions are {RootOf(4678560000000000000000000000000000000000+(16573041*CO^2+70122975000000000000*CO-623180900000000000000000000000000)*_Z^4+(-19887649200*CO^2-82987335000000000000000*CO+745755960000000000000000000000000000)*_Z^3+(5966294760000*CO^2+23851989000000000000000000*CO-221858784000000000000000000000000000000)*_Z^2+(417684600000000000000000000*CO-757598400000000000000000000000000000000)*_Z) = 600, RootOf(4678560000000000000000000000000000000000+(16573041*CO^2+70122975000000000000*CO-623180900000000000000000000000000)*_Z^4+(-19887649200*CO^2-82987335000000000000000*CO+...
Error, (in allvalues) numeric exception: division by zero
So apparently the expression is reducible but how do I do that?
Can any one help in coding.
 I have in my Maple documents many good quality plots resulting from simulations. I need to export (or paste) them to templates of transactions in Word without loosing quality, and beeing flexible to some degree to fit the dimension.
Until now when I paste such plots the quality is lost and especially on descripltion on axes (vertical).
What I have to do? Do I need to go throuhg pdf format ?
How do I simplify the integral,  where a(u) and b(u) are T-periodic and s,t belongs to the interval [0,T]
I have been using CodeTools::Usage with Maple 17 to compare timings of a couple of matrix inversion routines against each other and against the Maple library routines LinearAlgebra::MatrixInverse and LinearAlgebra::Determinant.
The small section of code that I use to collect the cpu times for each method is:
udata := Usage(invTest(x,y,z,delta,mu), output=['cputime', 'bytesused'],
              iterations=nRepeats, quiet);
dat[1]:=udata[1]; dat[2]:=udata[2];
nRepeats has been set to 25.
In order to get the timings as accurate as possible, I only open a couple of terminal windows on my laptop so as to run the tests with as low a loaded machine as I can get. (I'm running Ubuntu 14.04 on an 8 core Intel (R) Core i7-3840QM, 2.8GHz CPU with 16Gb of memory.)
A test run consists of a sequence of test matrices each of which is run for an increasing sequence of matrix orders. I either time an implementation on its own or I time both an implementation and the Maple library routines. In the later case for each test matrix and order of matrix, I use Usage to first time the Maple routines and then the times for one of the implementations:
if compMaple then
udata := Usage(MatrixInverse(A), output=['cputime', 'bytesused'],
mdat[1]:=udata[1]; mdat[2]:=udata[2];
udata := Usage(Determinant(A), output=[cputime, bytesused],
mdat[1]:=mdat[1]+udata[1];
mdat[2]:=mdat[2]+udata[2];
  mdat[1..2] := 0:
I have noticed the following:
a) If I time both Maple and an implementation, and the same implementation on its own I can get timings that vary up to a factor of 2 or more,
b) Changes in timings for the same test run and as close to the same environment as I can get (i.e., just the two user terminal windows open) can generate timing differences of up to 50%.
c) Sometimes `chaotic' timings are generated, for example,
    n = 150, t = 3 (secs)
    n = 200, t = 24 (secs)
    n = 250, t = 18 (secs)
which cannot be reflecting the times required to perform the calculations. This type of behaviour always seems to occur when the reported memory bytecount is increasing from ~0.25* 10^9 to over 10^9.
Is there anything I can be doing here to get more consistent timings?
I want to use the timings from these tests in a journal article so it would be good to have the same test run under very similar conditions to return timings within a few percent difference of one another. I certainly get this sort of tolerances (<10%) if I use the Fortran cpu_time intrinsic to time Fortran code.
Any advice would be gratefully received.
Hi !
I am importing a matrix from a text file. I am using the command,
ImportMatrix("Filelocation/Filename.txt", 'source' = 'delimited', 'delimiter' = " ");
I see the following error:
Error, (in ImportMatrix) cannot interpret file
I think it is because of the huge size.(700 MB, and 28 GB respectively)
How to import such a matrix in maple?
thanks,
Hello dear!
Hope you all are fine. I am trying to sloution the system of nonlinear system of ODEs (see attached file) but my solutions not converging please see and fix the problem. I am waiting your quick response.
Graph.mw
with(Groebner):
DoExist := proc(tau, n)
if rtable_num_elems(tau) >= n then
	return tau[n];
	return 0;
IsZero := proc(a, b)
if a=0 then
	return 0;
	return a/b;
end if
g1 := x^2-w*y;
g2 := x*y - w*z;
g3 := y^2 - x*z;
gro := Basis([g1,g2,g3],plex(x,y,z,w));
X1 := `*`(LeadingTerm(g1, tdeg(x, y, z, w)));
X2 := `*`(LeadingTerm(g2, tdeg(x, y, z, w)));
X3 := `*`(LeadingTerm(g3, tdeg(x, y, z, w)));
X12 := lcm(X1,X2);
X13 := lcm(X1,X3);
X23 := lcm(X2,X3);
S12 := SPolynomial(g1, g2, lexdeg([x, y, z, w]));
S23 := SPolynomial(g2, g3, lexdeg([x, y, z, w]));
S13 := SPolynomial(g1, g3, lexdeg([x, y, z, w]));
e1 := Vector([1,0,0]);
e2 := Vector([0,1,0]);
e3 := Vector([0,0,1]);
eq1:= S12 = h121*g1 + h122*g2 + h123*g3;
eq1 := S12 - expand(h121*g1 + h122*g2 + h123*g3):
NormalForm(eq1, Basis([g1, g2, g3], tdeg(x, y, z, w, h121, h122, h123)), tdeg(x, y, z, w, h121, h122, h123), 'Q');
h121 := 0;
h122 := 0;
h123 := 0;
s12 := IsZero(X12,X1)*e1-IsZero(X12,X2)*e2-Vector([DoExist(<Q>,3), DoExist(<Q>,2), DoExist(<Q>,1)]);
eq1 := S13-expand(h131*g1+h132*g2+h133*g3):
NormalForm(eq1, Basis([g1, g2, g3], tdeg(x, y, z, w, h131, h132, h133)), tdeg(x, y, z, w, h131, h132, h133), 'Q');
h131 := 0;
h132 := 0;
h133 := 0;
s13 := IsZero(X13,X1)*e1-IsZero(X13,X3)*e3-Vector([DoExist(<Q>,3), DoExist(<Q>,2), DoExist(<Q>,1)]);
eq1:= S23 - expand(h231*g1 + h232*g2 + h233*g3);
NormalForm(eq1, Basis([g1, g2, g3], tdeg(x, y, z, w, h231, h232, h233)), tdeg(x, y, z, w, h231, h232, h233), 'Q');
h231 := 0;
h232 := 0;
h233 := 0;
s23 := IsZero(X23,X2)*e2-IsZero(X23,X3)*e3-Vector([DoExist(<Q>,3), DoExist(<Q>,2), DoExist(<Q>,1)]);
#F = Syz*GrobnerBasis
F := simplify(MatrixMatrixMultiply(Matrix([[s12[1],s13[1],s23[1]],[s12[2],s13[2],s23[2]],[s12[3],s13[3],s23[3]]]), Matrix([[gro[1]],[gro[2]],[gro[3]]])));
F[1][1] - g1 = 0;
F[2][1] - g2 = 0;
F[3][1] - g3 = 0;
F := simplify(MatrixMatrixMultiply(Matrix([[s12[1],0,s23[1]],[s12[2],0,s23[2]],[s12[3],0,s23[3]]]), Matrix([[gro[1]],[gro[2]],[gro[3]]])));
F[1][1] - g1 = 0;
F[2][1] - g2 = 0;
F[3][1] - g3 = 0;
#F = GrobnerBasis*Syz
F := simplify(MatrixMatrixMultiply(Matrix([[gro[1],gro[2],gro[3]]]), Matrix([[s12[1],s13[1],s23[1]],[s12[2],s13[2],s23[2]],[s12[3],s13[3],s23[3]]])));
F[1][1] - g1 = 0;
F[1][2] - g2 = 0;
F[1][3] - g3 = 0;
F := simplify(MatrixMatrixMultiply(Matrix([[gro[1],gro[2],gro[3]]]), Matrix([[s12[1],0,s23[1]],[s12[2],0,s23[2]],[s12[3],0,s23[3]]])));
F[1][1] - g1 = 0;
F[1][2] - g2 = 0;
F[1][3] - g3 = 0;
F := simplify(MatrixMatrixMultiply(Matrix([[gro[1],gro[2],gro[3]]]), Matrix([[s12[1],s12[1],s12[1]],[s13[2],s13[2],s13[2]],[s23[3],s23[3],s23[3]]])));
F[1][1] - g1 = 0;
F[1][2] - g2 = 0;
F[1][3] - g3 = 0;
F := simplify(MatrixMatrixMultiply(Matrix([[gro[1],gro[2],gro[3]]]), Matrix([[s12[1],0,s12[1]],[s13[2],0,s13[2]],[s23[3],0,s23[3]]])));
F[1][1] - g1 = 0;
F[1][2] - g2 = 0;
F[1][3] - g3 = 0;
syz result is s12, s23
but after verify, F is not equal to GrobnerBasis*Syz
Is is possible to tell the latex output what to do if it finds a symbol?
Suppose I have the following expression:
O3^2 + k_O3NO
The normal latex output just takes it as it is and also translates k_O3NO to k_O3NO with the underscore.
I however want it to read (latex notation in math mode)
\left[ \text{O}_3 \right]^2 + k_{\text{O}_3\text{NO}}
So is that possible without changing everything manually?
edit: Just as a remark, the output at the moment for this expression reads
{{\it O3}}^{2}+{\it k\_O3NO}
and is kinda awful if compiled in latex...
Is it also possible for maple to latex realizing where a line-break is necessary?
GREETINGS
How to derive a maple code for this attachment.
Anybody know how to put this in coding for Jacobian Matrix?
i want to solve equation system u0(x,t),u1(x,t),v1(x,t),v0(x,t)v2(x,t) dependent on f(x,t).
I attached file.
worksheet.mwworksheet.mw
So I needed a CAS, and I spent a couple of months trying to get a basic understanding of SymPy and various applications starting with "M". We have Maple version 2016.
My "prototype problem" can be solved by hand, and is a system of quadratic Bellman equations, for i=1,2.  I'll return to it below, as I am obviously too clumsy to get even the second-to-simplest max/min working.  Oh, and I can't even insert Maple Math here in the forum, it does not like maximize or minimize.
Let's start easy. I enter
maximize((b-x)x,x)
which works as I expect. Then already at
maximize((abs(b)-x)x,x>=0)
I am stuck. Please, sweet Maple, you know that the answer is the same as before, don't you? (In the meantime I have tried to feed it maximize((b-x)x,x=0..1)... )
I was hoping my "proper" problem should be doable. What I really need is a sequence of quadratic optimization problems, where I have a vector x maximizing b'x-x'Ax subject to linear constraints, so it should not be too hard.  The "prototype problem" I needed for starters, is a system where for i=1,2 I have
v_i(0,y)=0 and inductively v_i(t+1,y)=max{x_i*(b_i-x_1-x_2)+ r_i v_i(t,y-x)}
where b_i and r_i are constants, x=(x_1,x_2), y=(y_1,y_2), and everything is nonnegative - including, the choice variables x_i must be between 0 and min{y_i, b_i-x_1-x_2}. And I want to plot both functions and the x with time as a slider, but ... I don't think I'll ever get that far?
Sorry for whining. (I know why I dropped out of computer science.)
Daer maple useres,
I am solving around 170 linear algebraic equations (symbolic) using linearalgebra " solve" command. I see the cpu usage is only 15%; as I the cpu is  i-7, octacore ,15% means around 1 core is in use. With time (12 hours)  cpu usage goes down to 0% showing free memory approx 0.
Why  is it happening? Is it due to high memory usage in storing large symobic expressions? Is there a way to engage all the cores( 100% Cpu)?
Thanks and regards.
Using Insert->Table... and inserting information in the cells.
So I've created Table1 but I can't seem to call any row/column cell information using that name.  How do we do that?  Also, what is the best way to search for information in those cells and return information in adjacent cells?
First 162 163 164 165 166 167 168 Last Page 164 of 371
