Hi quick question.  When I am writing in maple 2D input the next line seems to add a space and I have to manually go and take the spaces out.  Is there a quick fix for this?
Hello everybody
I'm using discrete distributions from the Statistics package and I found a rather strange result.
In short the theoritical values of some statistics of a NegativeBinomial(1, P) Random Variable (P being the probability of success equal to 1e-4) are correctly computed, but their empirical estimators computed from a sample of this RV are roughly wrong.
For NegativeBinomial(1, P) is similar to Geometric(P) I asked Maple to compute the theoritical values of some statistics of Geometric(P) and next to assess their empirical values from a sample of Geometric(P).
Some discrepancies still remain but they can be explained by statistical fluctuations.
Could you please look to the attached file (an error on my part is still possible) and help me to fix this ?
PS : the histogram of Sample(NegativeBinomial(K, P), AnySizeYouWant) is obviously wrong (it should look like a decreasing exponential)
Download NegativeBinomial.mw
I have recently reinstalled the MapleSim 6.4 but the probe windows do not appeaar anymore.
The image below shows that there are 3 probes (none are disabled) and when I run the simulation nothing happens.,
I have encountered bug in factors/fsolve while working with 19-th degree polynomial:
Digits:=150:
T:=-6.22380759047872668130713536877030256364968636070065651396334810246948704517800844289400608484048587112392332204805530128070851889819985512874202683743*10^11*x^15+1.30320674544020861155773378297484119553167774488351680864188235543008368581731239587845304516984389100205019741111280194189829856859808540642557769603*10^10*x^6-4.66269056752439302342961934783764679009596024511170531603537327397832302302620600217387943312388922053304167698527169182278585860427802821480352854136*10^11*x^9-2.23704996926446119043671514798254764988240075983626880645807120500701523185370168392321824617257975062292105400290171941856646211919772527234308968846*10^9*x^5+1.70227750800986164284793608409450414651109713000703213281475661248797845709368255736580952492853671050778821135335145407044800619189451776936359075686*10^12*x^12+2.75132914316444017343930750158891109941047127103886960894939389127711887329536485172215512793127850186551483171384960841607262449527761786758828223621*10^8*x^4-34932.1305741980482332724462824276603543110574918698909627427160477228536038554704823433224807581628905769847550345090785500099182662763447500819501675*x+1.14859089243616386902401277001127426741536679789632050800564282457083136981495352758127041512610195469873039580049988570650313838832989727748112868586*10^12*x^14-6.60479740997269404871863401649844958253760499264982628400515571200965556608668632440745621931354881132921476624343305820884923453724427367494415551238*10^10*x^17-5.62833694496139881587566825658979473046292640751330993837612787833792702707901920475562429114656627532669843830531312111426766840057855202536781521123*10^10*x^7-1.41317084251894030640575308228417182186337397538022537825365672333611503622567981167488384741420461775617951229535582868905095341476313150469092017698*10^12*x^11-8.21268191019727949807038061270674769712976810595535494085869238004490345847174711476348954310804852930678468602300916137608391140935636924900016951244*10^8*x^19+397.252699937115297695173788383107213691513398731729934944369484808586994493337920006396692649274392699364304534062337678482629861430643165733668575822+2.45061767631130714142188028061597642324588736935628490184983950396964320020866945354270367821778753632385377702112725604392839751008695021580743844404*10^11*x^16+1.08699947236093139248842860047684411564605736115175003178583710408973712475471303403438454553797809672473740940054172927497665894877177132800140413775*10^10*x^18+1.84485142971549353599220669614768264648023215439682851036030548807708252959822522849421648368214446092969270608024147362000126035954415744321702508798*10^11*x^8-2.30461084758765666852675422975553976835398815305842562217293737088819307979848024374022174488508670823626363788957243202121075401744096241597591787541*10^7*x^3+9.17691101238967627829517731270700894639677345422963842539705370480050031196020089039807157125184117990094461042715726886282973724309183151499484709563*10^11*x^10-1.59505142070054081045558935086478494555622632474984266672719416019069437321867830698450310020630535513817946854845186492455277659549284062382504657541*10^12*x^13+1.21399269842294123787022397507857250840398420627023248941081275489711499859955449395398103964932227544163416388726749227644470585060488880538430515276*10^6*x^2:
infolevel[fsolve]:=3:
fsolve(T,fulldigits); # <-- completes without issues
factors(T);           # <-- freezes with log:
fsolve: ill-conditioned polynom of degree 19, with 0(0) given roots
fsolve: 1th root found in 9 iters at 165 Digits
fsolve: 2th root found in 11 iters at 164 Digits
fsolve: 3th root found in 11 iters at 165 Digits
fsolve: 4th root found in 10 iters at 174 Digits
fsolve: 5th root found in 10 iters at 167 Digits
fsolve: 6th root found in 11 iters at 168 Digits
fsolve: 7th root found in 11 iters at 174 Digits
fsolve: 8th root found in 11 iters at 170 Digits
fsolve: 9th root found in 11 iters at 181 Digits
fsolve: 10th root found in 11 iters at 172 Digits
fsolve: 11th root found in 12 iters at 175 Digits
fsolve: 12th root found in 11 iters at 182 Digits
fsolve: 14th root found in 14 iters at 177 Digits
fsolve: 15th root found in 10 iters at 176 Digits
fsolve: 16th root found in 11 iters at 173 Digits
Warning,  computation interrupted
The most interesting thing is that standalone 'fsolve' finishes fine, but 'factors' freezes in 'fsolve:-polyill' on the same polynomial.
My system is: Windows 7 x64, Maple 2017.0.
Would appreciate any help on how to avoid the issue with 'factors'.
ode1a := diff(y1(tt), tt) = 1.342398800*10^5*y1(tt)+89591.20000*y2(tt)+44647.44000*y3(tt);
ode2a := diff(y2(tt), tt) = 89591.20000*y1(tt)+89803.24000*y2(tt)+44901.60000*y3(tt);
ode3a := diff(y3(tt), tt) = 44647.44000*y1(tt)+44901.60000*y2(tt)+44859.24000*y3(tt);
would like to find the origin eigenstate before it collapse to eigenvalues
how to apply ricci flow in this situation?
i find help file , and can not find some relationship between this application and inputs of ricci related function
which functions in maple can help to find origin of eigenstate
I have a few "regular practices" on the interface that i want to implement into conjecturing automata, and i would really really be super appreciative if i can interface it with simon's/maplsoft's inverse symbollic calculator, the only problem really is  the HTTP aspect is going  to ( im assuming) need certain information only known to the people who brought the symbolliic calc online. So thats my  question / request for help
From clues:
a1 := subs(y=n,1/y!*x^y); # diff make it equal to the left term
a2 := subs(y=n-1,1/y!*x^y);
simplify(factor(a1 - a2));
To find limit of below
nterm := sum(tanh(product(sum(kk, kk=1..jj),jj=1..y))*1/y!*x^y, y=n..n);
n2term := sum(tanh(product(sum(kk, kk=1..jj),jj=1..y))*1/y!*x^y, y=(n+1)..(n+1));
simplify(factor(n2term - nterm));
simplify(limit((subs(x=x+h, n2term)-n2term)/h, h=0)) = nterm;
question is to find a limit make n2term equal nterm after calculation
Hi all!
I am using the solve command for solving 200 equations (linear in 200 unknowns) symbolically. The solve command computes efficiently for 50 equations, after which the efficiency decreases (RAM memory and computation issues).
Is there some other better way available to solve a system of algebraic equations symbolically?
Can I get help with equations, need to use the metrics.
1.  2*(3+4)-2*(4-3)
2.  (6+4):2+(4-5+2)*3-2
3.  -5*(-2+5)*(2-5)-3*(-2)
4.  7*(2-6*3+4)-5*8:2
5.  2*(6+4):4
6.  14+2*(5+23):2+4
7.  2*(9+3)+3*(6*(-2)-2:(6-2)*(-3)-10
It would be nice to have asymptotics for hypergeom that are valid around abs(z)=infinity for any value of argument(z):
limit(hypergeom([1, 1], [2, 2], I*z), z = infinity); # zero
      limit(hypergeom([1, 1], [2, 2], I z), z = infinity)
series and asympt can give the expansions for +infinity or -infinity, not necessarily valid for other directions. FunctionAdvisor gives only the expansion at +infinity (which in this case is valid for Re(z)>0). Changes of variables like z->-z or z->1/z seem to never work in FunctionAdvisor(asymptotic_expansion, ...).
Also the expansions around z=1:
limit(hypergeom([1, 1, 1], [1/2, 2], z)*(z-1), z = 1); # zero
          /         /           [1   ]   \               \
     limit|hypergeom|[1, 1, 1], [-, 2], z| (z - 1), z = 1|
          \         \           [2   ]   /               /
And on the branch cuts:
limit(hypergeom([1/3, 1/3], [1/2], 2+I*a), a = 0); # the directional limits are different
                            /[1  1]  [1]   \
                   hypergeom|[-, -], [-], 2|
                            \[3  3]  [2]   /
Is any package or algorithm which enable me to compute constraint structure of a singular Lagrangian in physical phenomena?
i would be very thankfull if someone help me in thisway please :)
g3 := tanh(x+1);
a:=eval(diff(g3,x$n)/n!, x=0) assuming n>=0:
tanhx := sum(a*x^n, n=0..infinity):
tanhx2 := subs(x^n=subs(_C1=0, subs(t=n!, g2))*x^n, tanhx):
diff(tanhx2, x) - tanhx2;
would like to find a operator to make it equalt to itself , a new differential operator for new transcendental function tanhx2
I wonder - would it be possible to automate the following way of adding a legend to plots? If so - how?
plot([f(x), g(x), 7], legend = ['f(x)' = f(x), 'g(x)' = g(x), y = 7]);
In my opinion such a legend makes the plot much more readable - but most students (and others) will usually be too lazy to type this out, hence the wish for it be to automated.
Any help will be much appreciated.
In Maple 17, the following expression needs to be integrated with respect to q3, p3 and q. Here, mu is a real, positive scalar.
a := 1/(sqrt(mu^2+(px-p3x-q3x)^2)*sqrt(mu^2+(-p3x+qx-q3x)^2)*sqrt(mu^2+q3x^2)*(sqrt(mu^2+(-p3x+qx-q3x)^2)+sqrt(mu^2+q3x^2)))
However, the integration will not work with the "int" command (e.g. wrt q3). The indefinite integration will work if the integral is evaluated using the steps: highlight expression -> right click -> Integrate -> wrt q3 command.
The output of the integral (using the above method) is very long, it's impossible to manipulate the answer (on my i5, 8GB machine running Maple 17) because it is very tough to copy such a long output. Also, there is no way to specify that mu is a positive scalar.
Is there a better way to perform the integration, e.g. between 0 and lambda, -1 through 1, or -infinity to +infinity?
Assume I had a 2D line
how to put and draw this line into a new geometric world defined by patch?
First 165 166 167 168 169 170 171 Last Page 167 of 371
